    4. Probleme mit sudo apt update / PUBKEY
      Thomas Braun Most Active @mp3junkie last edited by
      @mp3junkie
      Passt wieder.
        mp3junkie @Thomas Braun last edited by
        Danke.
        Was habe ich falsch gemacht?
          @mp3junkie sagte in Probleme mit sudo apt update / PUBKEY:
          Keine Ahnung. Ich weiß ja nicht mal was du genau wie gemacht hast. Geschweige denn was dann dabei falsch war.
            @mp3junkie
            Zeig mal die Langfassung von
            iob diag
            Könnte es evtl. sein, dass du von einer Vorversion auf RaspberryOS 12 'Bookworm' upgegraded hast und keine Neuinstallation?
              ========== Start marking the full check here ===========
              Script v.2024-10-19
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.6.62+rpt-rpi-2712
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Sat 2024-12-21 12:47:38 CET
                         Universal time: Sat 2024-12-21 11:47:38 UTC
                               RTC time: Sat 2024-12-21 11:47:38
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Display-Server: true
              Desktop:
              Terminal:       tty
              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
              *** MEMORY ***
              Mem:            8.4G        3.9G        3.0G         28M        1.7G        4.6G
              Swap:           209M          0B        209M
              Total:          8.7G        3.9G        3.2G
              Active iob-Instances:   39
                       8052 M total memory
                       3697 M used memory
                       3792 M active memory
                        893 M inactive memory
                       2852 M free memory
                        162 M buffer memory
                       1463 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
              Tasks: 260 total,   2 running, 258 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8052.2 total,   2852.3 free,   3698.6 used,   1626.0 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4353.7 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  3.9G     0  3.9G   0% /dev
              tmpfs          tmpfs     806M  6.2M  800M   1% /run
              /dev/nvme0n1p2 ext4      457G   12G  422G   3% /
              tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/nvme0n1p1 vfat      511M   77M  435M  15% /boot/firmware
              tmpfs          tmpfs     806M  176K  806M   1% /run/user/1000
              /dev/mmcblk0p2 ext4       58G   11G   45G  19% /media/pi/rootfs
              /dev/mmcblk0p1 vfat      510M   76M  435M  15% /media/pi/bootfs
              [Sat Dec 21 10:10:17 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:6D:4C:3A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4f3e1646-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Sat Dec 21 10:10:18 2024] EXT4-fs (nvme0n1p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 ro with ordered data mode. Quota mode: none.
              [Sat Dec 21 10:10:19 2024] EXT4-fs (nvme0n1p2): re-mounted f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w. Quota mode: none.
              [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): recovery complete
              [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w with ordered data mode. Quota mode: none.
              Show mounted filesystems:
              TARGET               SOURCE         FSTYPE      OPTIONS
              /                    /dev/nvme0n1p2 ext4        rw,noatime,commit=600
              |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              |-/media/pi/rootfs   /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
              `-/media/pi/bootfs   /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
              /var:
              1.5G    /var/
              639M    /var/log
              637M    /var/log/journal/bc573ed170a0404295df5010a84c38bc
              384M    /var/cache
              Archived and active journals take up 636.8M in the file system.
              /opt/iobroker/backups:
              215M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.4G    /opt/iobroker/iobroker-data/
              987M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              32M     /opt/iobroker/iobroker-data/objects.jsonl
              29M     /opt/iobroker/iobroker-data/states.jsonl
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2251966-if00
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.1
              /usr/bin/node           v20.18.1
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.4
              nodejs:
                Installed: 20.18.1-1nodesource1
                Candidate: 20.18.1-1nodesource1
                Version table:
               *** 20.18.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 9424)
              Core adapters versions
              js-controller:  7.0.3
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     3
              +-- iobroker.connector-local-control@0.0.4 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#dae4c44e29a8a44cfc5076aca69aac3694fac729)
              +-- iobroker.eusec@1.3.3 (git+ssh://git@github.com/bropat/ioBroker.eusec.git#14b7097588d080eeef69a8e2b91bfb2f9c6d1c09)
              +-- iobroker.lg-thinq@1.0.7 (git+ssh://git@github.com/TA2k/ioBroker.lg-thinq.git#4e823328b9f01752506f96dd8bdd78e98580c75d)
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
              + system.adapter.connector-local-control.0: connector-local-control: raspberrypi                              -  enabled
              + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
              + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                system.adapter.email.0                  : email                 : raspberrypi                              - disabled
              + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
              + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
              + system.adapter.hass.0                   : hass                  : raspberrypi                              -  enabled, port: 8123
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              - disabled
              + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
              + system.adapter.melcloud.0               : melcloud              : raspberrypi                              -  enabled
              + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
              + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
              + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                system.adapter.roborock.0               : roborock              : raspberrypi                              - disabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
              + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
              + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
                system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
              + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
              + system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
              + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name               │ url                                                     │ auto upgrade │
              │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
              │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
              Active repo(s): Stable (default)
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: Stable (default)
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "ble"          : 0.14.0   , installed 0.14.0
              Adapter    "bring"        : 1.8.4    , installed 1.8.4
              Adapter    "deconz"       : 1.4.1    , installed 1.4.1
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "email"        : 1.3.1    , installed 1.3.1
              Adapter    "ems-esp"      : 5.0.6    , installed 5.0.6
              Adapter    "eusec"        : 1.3.3    , installed 1.3.3
              Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
              Adapter    "harmony"      : 1.5.0    , installed 1.5.0
              Adapter    "hass"         : 1.4.0    , installed 1.4.0
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.3    , installed 7.0.3
              Adapter    "lg-thinq"     : 1.0.5    , installed 1.0.7
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "melcloud"     : 2.0.4    , installed 2.0.4
              Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
              Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
              Adapter    "operating-hours": 1.1.0  , installed 1.1.0
              Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "roborock"     : 0.6.17   , installed 0.6.17
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "solarmanpv"   : 0.6.2    , installed 0.6.2
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "windows-control": 0.1.5  , installed 0.1.5
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects:        23603
              States:         19117
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:7 https://apt.grafana.com stable InRelease
              Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6745       916/cupsd
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10662      2340/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10657      2340/iobroker.js-co
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6064       687/deCONZ
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9266       945/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       6807       687/deCONZ
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17117      3179/io.shelly.1
              tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       728463     129005/nc
              tcp6       0      0 :::3000                 :::*                    LISTEN      114        14423      1736/grafana
              tcp6       0      0 ::1:3350                :::*                    LISTEN      0          6738       930/xrdp-sesman
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21177      3734/io.socketio.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        10501      1498/influxd
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22614      3682/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12873      2457/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23036      3773/io.web.0
              tcp6       0      0 :::8083                 :::*                    LISTEN      1001       21362      3872/io.ws.0
              tcp6       0      0 :::3389                 :::*                    LISTEN      113        9416       952/xrdp
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       15009      2858/io.harmony.0
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6744       916/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          9268       945/sshd: /usr/sbin
              udp        0      0 0.0.0.0:37152           0.0.0.0:*                           104        6414       681/avahi-daemon: r
              udp        0      0 192.168.178.32:5353     0.0.0.0:*                           1001       18790      3263/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6412       681/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15830      3137/io.shelly.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15386      2784/io.deconz.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6953       687/deCONZ
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17289      3288/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17290      3288/io.tuya.0
              udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       17842      3375/io.connector-l
              udp6       0      0 fe80::a68d:18ea:57a:546 :::*                                0          140872     778/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        6413       681/avahi-daemon: r
              udp6       0      0 :::1900                 :::*                                1001       15389      2784/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       15388      2784/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       15387      2784/io.deconz.0
              udp6       0      0 :::39141                :::*                                104        6415       681/avahi-daemon: r
              2024-12-21 11:43:20.764  - info: fb-checkpresence.0 (31196) newActive Andreas false
              2024-12-21 11:43:40.713  - info: fb-checkpresence.0 (31196) newActive Andreas true
              2024-12-21 11:52:57.675  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
              2024-12-21 11:52:59.705  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
              2024-12-21 11:53:09.694  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
              2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
              2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
              2024-12-21 11:53:14.164  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
              2024-12-21 11:53:24.144  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
              2024-12-21 11:53:30.405  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
              2024-12-21 11:53:30.406  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
              2024-12-21 11:53:32.257  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
              2024-12-21 11:55:19.396  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
              2024-12-21 12:01:45.821  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.1 seconds ago and is ignored. Must be at least 2 seconds.
              2024-12-21 12:01:46.092  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
              2024-12-21 12:04:45.725  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertreppe zu] activated Zone 'Kellertreppe_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
              2024-12-21 12:11:47.246  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Abstellkammer zu] activated Zone 'Abstellkammer_Licht_Aus'. However, device(s) 'Abstellkammer' not turned off as these are already off.
              2024-12-21 12:26:43.722  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank links zu] activated Zone 'Schranklicht_Li_Aus'. However, device(s) 'Licht Kleiderschrank links' not turned off as these are already off.
              2024-12-21 12:30:57.980  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank rechts zu] activated Zone 'Schranklicht_Re_Aus'. However, device(s) 'Licht Kleiderschrank rechts' not turned off as these are already off.
              2024-12-21 12:44:03.066  - info: admin.0 (2457) ==> Connected system.user.admin from ::ffff:192.168.178.28
              2024-12-21 12:44:16.100  - error: backitup.0 (2686) [iobroker/grafana] Error on Grafana Datasource Request
              2024-12-21 12:44:16.139  - error: backitup.0 (2686) [iobroker/grafana] cannot found Grafana Backup files
              2024-12-21 12:44:46.961  - error: backitup.0 (2686) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
              2024-12-21 12:45:35.696  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
              2024-12-21 12:46:21.152  - info: admin.0 (2457) <== Disconnect system.user.admin from ::ffff:192.168.178.28 backitup
              iob diag has finished.
              Press any key for a summary
                @thomas-braun sagte in Probleme mit sudo apt update / PUBKEY:
                Ne, Bookworm habe ich bereits ein paar Monate laufen. Grafana habe ich wieder "in Betrieb genommen".
                  Tu das.
                  Ansonsten sieht das soweit okay aus.
                  Künftig den ersten User nicht 'pi' nennen sondern was eigenes ausdenken.
                  vorname oder forumsnick sind da besser.
                    iob fix ist erledigt.
                    Deine Hinweise habe ich notiert und werde sie umsetzen.
                    Danke für deine schnelle und perfekte Hilfe. 😀
                      puffy00007 @mp3junkie last edited by Homoran
                      @mp3junkie Hi, ich habe ein ähnliches Problem, könnt ih mir helfen?
                      pi@iobroker:/var/lib $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
                      Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
                      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Err:5 https://repos.influxdata.com/debian stable InRelease
                        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      Err:6 https://packages.grafana.com/oss/deb stable InRelease
                        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                      Fetched 6,907 B in 2s (3,699 B/s)
                      Reading package lists... Done
                      Building dependency tree... Done
                      104 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                      W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                      die Zugriffsrechte (ls -l /etc/apt/trusted.gpg.d/) dind alle auf 644
                        Thomas Braun Most Active @puffy00007 last edited by
                        @puffy00007 sagte in Probleme mit sudo apt update / PUBKEY:
                        DRINGENDST updaten...
                        Sowohl grafana wie auch influx müssen neu angelegt werden.
                        Mach es danach:
                        https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                          puffy00007 @Thomas Braun last edited by Homoran
                          @thomas-braun Bei Grafana ging alles gut, bei Influx sieht so aus:
                          pi@iobroker:/var/lib $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                          sha256sum: influxdata-archive_compat.key: No such file or directory
                          influxdata-archive_compat.key: FAILED open or read
                          sha256sum: WARNING: 1 listed file could not be read
                            @puffy00007
                            Stell dich NICHT in /var/lib rein.
                            Du musst in deinem home stehen....
                            Grundsätzlich hast du da eh nix verloren.
                              @thomas-braun Super, alles sauber durchgelaufen und aufm neusten Stand!
                              Aber es gibt ein Problem:
                              Ich nutze VIS (1.5.6), darin habe ich auf der Hauptpage ein iFrame und als Quelle eine der URL aus Grafana, um die Visualisierung darzustellen.
                              Der weigert sich den Inhalt zu zeigen. KATASTROPHE
                              Was ist hier anders?
                              Homoran 1 Reply Last reply Reply Quote -1
                                Homoran Global Moderator Administrators @puffy00007 last edited by
                                KATASTROPHE
                                das hat nichts mit diesem Thread zu tun.
                                Bitte neuen Thread in der richtigen Kategorie aufmachen, oder an einen der zu diesem Thema bestehenden anhängen
                                  puffy00007 @Homoran last edited by
                                  @homoran Habs gelöst, sorry und DANKE!
                                  sudo apt update pubkey
                                  986
