    4. Node-Red
    5. Zwei Strings zusammenführen
      peterfido @JU_ last edited by
      @ju_ ja, bei mir geht es auch. Ich frage mich, mit welchem KNX sich die Node standardmäßig verbindet.
      Exportieren geht über das Menü oben rechts in Node-Red.
        JU_ @peterfido last edited by JU_
        @peterfido und dann als JSON?
          @ju_ ja. Per JSON in die Zwischenablage und dann hier in Code-Tags posten.
            @peterfido ist drin, musste ihn nochmal fix bearbeiten.
              @ju_ probiere es mal als Code. So lässt es sich nicht importieren. Code-Symbol ist </>
                @peterfido ```
                [{"id":"90489d5f43af09b5","type":"knxUltimate","z":"de15a47dbea6c285","server":"98b73fada3be00aa","topic":"8/1/0","setTopicType":"str","outputtopic":"","dpt":"16.001","initialread":"1","notifyreadrequest":false,"notifyresponse":true,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","name":"Gelbe Tonne Datum","outputtype":"write","outputRBE":"true","inputRBE":"false","formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","sendMsgToKNXCode":"","receiveMsgFromKNXCode":"","listenallga":false,"x":130,"y":100,"wires":[["02034f10ed38c317"]]},{"id":"a2dbe9c2f590573a","type":"knxUltimate","z":"de15a47dbea6c285","server":"98b73fada3be00aa","topic":"8/2/0","setTopicType":"str","outputtopic":"","dpt":"16.001","initialread":"1","notifyreadrequest":false,"notifyresponse":true,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","name":"Gelbe Tonne Tage","outputtype":"write","outputRBE":"true","inputRBE":"false","formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","sendMsgToKNXCode":"","receiveMsgFromKNXCode":"","listenallga":false,"x":130,"y":160,"wires":[["4ea9b5ca4631e2ce"]]},{"id":"02034f10ed38c317","type":"change","z":"de15a47dbea6c285","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Datum","tot":"str"},{"t":"set","p":"GelbDatum","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":100,"wires":[["5b74298a9d871858"]]},{"id":"4ea9b5ca4631e2ce","type":"change","z":"de15a47dbea6c285","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Tage","tot":"str"},{"t":"set","p":"GelbTage","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":160,"wires":[["5b74298a9d871858"]]},{"id":"58a426e6d74f6020","type":"knxUltimate","z":"de15a47dbea6c285","server":"98b73fada3be00aa","topic":"8/3/0","setTopicType":"str","outputtopic":"","dpt":"16.001","initialread":0,"notifyreadrequest":false,"notifyresponse":false,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","name":"Zusammengesetztes Datum Gelb","outputtype":"write","outputRBE":"true","inputRBE":"false","formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","sendMsgToKNXCode":"","receiveMsgFromKNXCode":"","listenallga":false,"x":1230,"y":100,"wires":[[]]},{"id":"2861740aaba0f1c9","type":"inject","z":"de15a47dbea6c285","name":"Manuelle Betätigung","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"27.01.25 (10d)","payloadType":"str","x":890,"y":20,"wires":[["58a426e6d74f6020"]]},{"id":"d22d4525c542b4d0","type":"debug","z":"de15a47dbea6c285","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1140,"y":180,"wires":[]},{"id":"cccfb4eb94a27733","type":"change","z":"de15a47dbea6c285","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"8/3/0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":100,"wires":[["58a426e6d74f6020","d22d4525c542b4d0"]]},{"id":"5b74298a9d871858","type":"function","z":"de15a47dbea6c285","name":"function 3","func":"msg.payload = flow.get("GelbDatum") + " (" + flow.get("GelbTage") + "d)";\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":100,"wires":[["cccfb4eb94a27733"]]},{"id":"141076626e9e6cf8","type":"inject","z":"de15a47dbea6c285","name":"Manuelle Betätigung","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":40,"wires":[["5b74298a9d871858"]]},{"id":"98b73fada3be00aa","type":"knxUltimate-config","host":"10.0.0.2","port":"3671","physAddr":"1.1.64","hostProtocol":"TunnelUDP","suppressACKRequest":false,"csv":"","KNXEthInterface":"Auto","KNXEthInterfaceManuallyInput":"","stopETSImportIfNoDatapoint":"fake","loglevel":"error","name":"KNX Gateway","localEchoInTunneling":true,"delaybetweentelegrams":"50","ignoreTelegramsWithRepeatedFlag":false,"autoReconnect":"yes"}]
                  @ju_ Das Symbol anklicken und dann zwischen den '' einfügen.
                    @peterfido habe ich verstanden, ist oben geändert. Sorry 😄
                      @ju_ Fast 🙂
                      Sollte so aussehen:
                              "id": "076b7140f384fc31",
                              "type": "tab",
                              "label": "Flow 2",
                              "disabled": false,
                              "info": "",
                              "env": []
                              "id": "4be12d8e923cd33b",
                              "type": "knxUltimate",
                              "z": "076b7140f384fc31",
                              "server": "2e5af07acfd111fe",
                              "topic": "8/3/0",
                              "setTopicType": "str",
                              "outputtopic": "",
                              "dpt": "16.000",
                              "initialread": 0,
                              "notifyreadrequest": false,
                              "notifyresponse": false,
                              "notifywrite": true,
                              "notifyreadrequestalsorespondtobus": false,
                              "notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized": "0",
                              "name": "",
                              "outputtype": "write",
                              "outputRBE": "true",
                              "inputRBE": "false",
                              "formatmultiplyvalue": 1,
                              "formatnegativevalue": "leave",
                              "formatdecimalsvalue": 999,
                              "passthrough": "yes",
                              "sendMsgToKNXCode": "",
                              "receiveMsgFromKNXCode": "",
                              "listenallga": false,
                              "x": 360,
                              "y": 100,
                              "wires": [
                                      "2d3c593b7f85b176"
                              "id": "b0b348a7ad1db526",
                              "type": "inject",
                              "name": "",
                              "props": [
                                      "p": "payload"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "topic": "",
                              "payload": "30.01.25 (13d)",
                              "payloadType": "str",
                              "x": 170,
                              "y": 100,
                              "wires": [
                                      "4be12d8e923cd33b"
                              "id": "2d3c593b7f85b176",
                              "type": "debug",
                              "name": "debug 2",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "targetType": "full",
                              "statusVal": "",
                              "statusType": "auto",
                              "x": 560,
                              "y": 100,
                              "wires": []
                              "id": "2e5af07acfd111fe",
                              "type": "knxUltimate-config",
                              "host": "224.0.23.12",
                              "port": "3671",
                              "physAddr": "15.15.22",
                              "hostProtocol": "Auto",
                              "suppressACKRequest": false,
                              "csv": "",
                              "KNXEthInterface": "Auto",
                              "KNXEthInterfaceManuallyInput": "",
                              "stopETSImportIfNoDatapoint": "fake",
                              "loglevel": "error",
                              "name": "KNX Gateway",
                              "localEchoInTunneling": true,
                              "delaybetweentelegrams": "25",
                              "ignoreTelegramsWithRepeatedFlag": false,
                              "autoReconnect": "yes"
                        @peterfido jetzt 😄
                                "id": "90489d5f43af09b5",
                                "z": "de15a47dbea6c285",
                                "server": "98b73fada3be00aa",
                                "topic": "8/1/0",
                                "outputtopic": "",
                                "dpt": "16.001",
                                "initialread": "1",
                                "notifyresponse": true,
                                "name": "Gelbe Tonne Datum",
                                "passthrough": "no",
                                "x": 130,
                                "y": 100,
                                "wires": [
                                        "02034f10ed38c317"
                                "id": "a2dbe9c2f590573a",
                                "topic": "8/2/0",
                                "outputtopic": "",
                                "dpt": "16.001",
                                "initialread": "1",
                                "name": "Gelbe Tonne Tage",
                                "x": 130,
                                "y": 160,
                                "wires": [
                                        "4ea9b5ca4631e2ce"
                                "id": "02034f10ed38c317",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "topic",
                                        "pt": "msg",
                                        "to": "Datum",
                                        "tot": "str"
                                        "t": "set",
                                        "p": "GelbDatum",
                                        "pt": "flow",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 360,
                                "y": 100,
                                "wires": [
                                        "5b74298a9d871858"
                                "id": "4ea9b5ca4631e2ce",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "topic",
                                        "pt": "msg",
                                        "to": "Tage",
                                        "tot": "str"
                                        "t": "set",
                                        "p": "GelbTage",
                                        "pt": "flow",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 360,
                                "y": 160,
                                "wires": [
                                        "5b74298a9d871858"
                                "id": "58a426e6d74f6020",
                                "topic": "8/3/0",
                                "outputtopic": "",
                                "dpt": "16.001",
                                "initialread": 0,
                                "name": "Zusammengesetztes Datum Gelb",
                                "x": 1230,
                                "y": 100,
                                "wires": [
                                "id": "2861740aaba0f1c9",
                                "type": "inject",
                                "name": "Manuelle Betätigung",
                                "props": [
                                        "p": "payload"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "payload": "27.01.25 (10d)",
                                "x": 890,
                                "y": 20,
                                "wires": [
                                        "58a426e6d74f6020"
                                "id": "d22d4525c542b4d0",
                                "type": "debug",
                                "name": "debug 1",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 1140,
                                "y": 180,
                                "wires": []
                                "id": "cccfb4eb94a27733",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "topic",
                                        "pt": "msg",
                                        "to": "8/3/0",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 850,
                                "y": 100,
                                "wires": [
                                        "58a426e6d74f6020",
                                        "d22d4525c542b4d0"
                                "id": "5b74298a9d871858",
                                "type": "function",
                                "name": "function 3",
                                "func": "msg.payload = flow.get(\"GelbDatum\") + \" (\" + flow.get(\"GelbTage\") + \"d)\";\nreturn msg;",
                                "outputs": 1,
                                "timeout": 0,
                                "noerr": 0,
                                "initialize": "",
                                "finalize": "",
                                "libs": [],
                                "x": 620,
                                "y": 100,
                                "wires": [
                                        "cccfb4eb94a27733"
                                "id": "141076626e9e6cf8",
                                "type": "inject",
                                "props": [
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "x": 350,
                                "y": 40,
                                "wires": [
                                        "5b74298a9d871858"
                                "id": "98b73fada3be00aa",
                                "host": "10.0.0.2",
                                "port": "3671",
                                "physAddr": "1.1.64",
                                "hostProtocol": "TunnelUDP",
                                "csv": "",
                                "delaybetweentelegrams": "50",
                          peterfido @JU_ last edited by peterfido
                          @ju_ probiere mal:
                                  "type": "function",
                                  "z": "e85adb77025ff03d",
                                  "func": "if(msg.topic==\"Datum\"){\n    flow.set(\"GelbDatum\", msg.payload.slice(0,8));\n}\nif(msg.topic==\"Tage\"){\n    var s = msg.payload;\n    for(var i=1;i<s.length;i++){\n        var x = s.slice(i,i+1);\n        if(isNaN(x)){\n            flow.set(\"GelbTage\", s.slice(0,i-1));\n            break;\n        }\n    }\n}\nnode.status({ text: flow.get(\"GelbDatum\") + flow.get(\"GelbTage\") + \" \" + x });\n\nif(flow.get(\"GelbDatum\").length > 0  && flow.get(\"GelbTage\").length > 0) {\n    msg.payload = flow.get(\"GelbDatum\").slice(0,8) + \" (\" + flow.get(\"GelbTage\") + \"d)\";\n    node.status({text: msg.payload});\n    return msg;\n}",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"GelbDatum\",\"\");\nflow.set(\"GelbTage\", \"\");\n",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 620,
                                  "y": 200,
                                  "wires": [
                                          "cccfb4eb94a27733"
                          Ich habe die Strings jetzt nach der erwarteten Länge abgeschnitten.
                          Im Prinzip nur die Function Node:
                          if(msg.topic=="Datum"){
                              flow.set("GelbDatum", msg.payload.slice(0,8));
                          if(msg.topic=="Tage"){
                                  if(isNaN(x)){
                                      flow.set("GelbTage", s.slice(0,i-1));
                                      break;
                          node.status({ text: flow.get("GelbDatum") + flow.get("GelbTage") + " " + x });
                          if(flow.get("GelbDatum").length > 0  && flow.get("GelbTage").length > 0) {
                              msg.payload = flow.get("GelbDatum").slice(0,8) + " (" + flow.get("GelbTage") + "d)";
                              return msg;
                          Ich habe es nochmal editiert.
                          Im Start-Bereich der Function die Variablen zurücksetzen. Sonst bleiben die alten Werte.
                          flow.set("GelbDatum","");
                          flow.set("GelbTage", "");
                            @peterfido vielen Dank, probiere es gleich morgen früh aus! Melde mich. 🙂
                              @peterfido Es funktioniert! Vielen lieben Dank für deine Hilfe und deine Gedult!! ❤
                                @ju_ Prima. Danke für die Rückmeldung.
                                Edit: In den beiden Change-Nodes kann die Regel, wo die Werte nach flow.Datum und flow.Tage geschrieben werden, raus. Da brauchts nur das Topic. Den Rest macht die Function.
                                Die nimmt vom Datum die ersten 8 Stellen und vom Tage sucht die sich nur die Ziffern am Anfang raus. Wenn beides gefunden wurde, wird es weitergeleitet.
                                81.1k
                                1389
