    4. ioBroker offline/Installation broken-nach Adapter
    • 1
      13patrick37 last edited by 13patrick37
      So, da ist der Log:
      Copy text starting here:
      ```bash
                              v.2024-12-09 Raspbian+zigbee diag+masking
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.6.72-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               32 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     192
      Installation broken or unknown states type: file configured.
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v21.7.3
      /usr/bin/node           v21.7.3
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      Recommended versions are nodejs  and npm
      nodeJS installation is correct
      MEMORY:
      Mem:            1.8G        103M        1.0G        0.0K        697M        1.7G
      Swap:            99M          0B         99M
      Total:          1.9G        103M        1.1G
      Active iob-Instances:   0
      ioBroker Core:          js-controller           3.3.22
                              admin                   6.3.5
      ioBroker Status:
      Objects:                0
      States:                 0
      Size of iob-Database:
      12M     /opt/iobroker/iobroker-data/objects.json.bak
      0       /opt/iobroker/iobroker-data/objects.json.broken
      1.6M    /opt/iobroker/iobroker-data/states.json.bak
      0       /opt/iobroker/iobroker-data/states.json.broken
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
      Macht für mich den Eindruck ob wäre alles weg ..
        Homoran Global Moderator Administrators @13patrick37 last edited by Homoran
        @13patrick37 sagte in ioBroker offline/Installation broken-nach Adapter:
        da ist der Log:
        Aber nur das
        SUMMARY
        bitte die Langfassung
        EDIT:
        ist nicht unterstützt
        und das Betriebssystem ist versumpft
        • 1
          Hast du Lösungsansätze oder hilft nur die Neu-Installation?
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-12-09 Raspbian+zigbee diag+masking
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to: debian
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 32 bit
          Systemuptime and Load:
           11:07:02 up  1:32,  1 user,  load average: 0.24, 0.22, 0.27
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be upda        ted to the latest stable release '' NOW!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Sun 2025-01-19 11:07:02 CET
                     Universal time: Sun 2025-01-19 10:07:02 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gp        io i2c spi iobroker
          js-controller is not running
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            1.8G        109M        1.0G        0.0K        706M        1.7G
          Swap:            99M          0B         99M
          Total:          1.9G        109M        1.1G
                   1846 M total memory
                    110 M used memory
                    234 M active memory
                    345 M inactive memory
                   1029 M free memory
                    147 M buffer memory
                    558 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 11:07:03 up  1:32,  1 user,  load average: 0.24, 0.22, 0.27
          Tasks: 171 total,   2 running, 169 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 27.3 us,  1.5 sy,  0.0 ni, 71.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   1846.8 total,   1029.2 free,    110.9 used,    706.8 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1667.0 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4       29G  6.2G   22G  22% /
          devtmpfs       devtmpfs  666M     0  666M   0% /dev
          tmpfs          tmpfs     924M     0  924M   0% /dev/shm
          tmpfs          tmpfs     370M  868K  369M   1% /run
          /dev/mmcblk0p1 vfat      253M   54M  199M  22% /boot
          tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
          [Sun Jan 19 09:34:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave sn        d_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=        0  smsc95xx.macaddr=E4:5F:01:7F:44:7B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size        =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7479d47b-02 rootfst        ype=ext4 fsck.repair=yes rootwait
          [Sun Jan 19 09:34:57 2025] EXT4-fs (mmcblk0p2): mounted filesystem 568caafd-bab1        -46cb-921b-cd257b61f505 ro with ordered data mode. Quota mode: none.
          [Sun Jan 19 09:34:57 2025] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
          [Sun Jan 19 09:34:59 2025] EXT4-fs (mmcblk0p2): re-mounted 568caafd-bab1-46cb-92        1b-cd257b61f505 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
          /var:
          2.4G    /var/
          1.6G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
          1.6G    /var/log
          580M    /var/cache
          Archived and active journals take up 1.5G in the file system.
          /opt/iobroker/backups:
          57M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          260M    /opt/iobroker/iobroker-data/
          99M     /opt/iobroker/iobroker-data/files
          75M     /opt/iobroker/iobroker-data/zigbee_0
          66M     /opt/iobroker/iobroker-data/files/javascript.admin
          61M     /opt/iobroker/iobroker-data/backup-objects
          9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.        chunk.js.map
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c        9.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE24694        58-if00
          *** ZigBee Settings ***
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Installed: 21.7.3-1nodesource1
            Candidate: 21.7.3-1nodesource1
            Version table:
           *** 21.7.3-1nodesource1 600
                  500 https://deb.nodesource.com/node_21.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               21.7.2-1nodesource1 600
               21.7.1-1nodesource1 600
               21.7.0-1nodesource1 600
               21.6.2-1nodesource1 600
               21.6.1-1nodesource1 600
               21.6.0-1nodesource1 600
               21.5.0-1nodesource1 600
               21.4.0-1nodesource1 600
               21.3.0-1nodesource1 600
               21.2.0-1nodesource1 600
               21.1.0-1nodesource1 600
               21.0.0-1nodesource1 600
               12.22.12~dfsg-1~deb11u5 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Hosts:
          Core adapters versions
          js-controller:  3.3.22
          admin:          6.3.5
          javascript:     6.1.4
          nodejs modules from github:     3
          +-- iobroker.iot@1.9.2 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#4ba0b7ef61bb3fd0444dbadff54b941ccf72db15)
          | `-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          +-- iobroker.zigbee@1.6.13 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#6fff38cf64a4e4333a6df43057e79720ef7b1d3d)
          Adapter State
          ioBroker-Repositories
          Installed ioBroker-Instances
          Objects and States
          Objects:        0
          States:         0
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_21.x nodistro InRelease
          Reading package lists... Done
          Pending Updates: 192
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       6468       388/deCONZ
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       1628       388/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6442       555/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6444       555/sshd: /usr/sbin
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6471       388/deCONZ
          udp        0      0 0.0.0.0:51099           0.0.0.0:*                           108        5972       382/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6111       769/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5970       382/avahi-daemon: r
          udp6       0      0 :::39976                :::*                                108        5973       382/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        5971       382/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          80546      769/dhcpcd
          2025-01-19 08:48:32.732  - info: bshb.0 (3795) Check if client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 is already paired.
          2025-01-19 08:48:35.741  - info: bshb.0 (3795) Client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 was not paired yet.
          2025-01-19 08:48:35.742  - info: bshb.0 (3795) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
          2025-01-19 08:48:38.748  - warn: bshb.0 (3795) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: undefined
          2025-01-19 08:48:39.935  - warn: tahoma.0 (3321) error during request: Error: connect ECONNREFUSED 192.168.178.36:8443, request path: setup/gateways with payload:{}
          2025-01-19 08:48:48.749  - info: bshb.0 (3795) Check if client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 is already paired.
          2025-01-19 08:48:51.758  - info: bshb.0 (3795) Client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 was not paired yet.
          2025-01-19 08:48:51.758  - info: bshb.0 (3795) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
          2025-01-19 08:48:54.768  - warn: bshb.0 (3795) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: undefined
          2025-01-19 08:48:59.520  - info: host.raspberrypi iobroker add homeconnect --host raspberrypi
          2025-01-19 08:49:03.433  - error: host.raspberrypi iobroker (node:616) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.(Use `node --trace-deprecation ...` to show where the warning was created)
          2025-01-19 08:49:04.769  - info: bshb.0 (3795) Check if client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 is already paired.
          2025-01-19 08:49:04.924  - info: host.raspberrypi iobroker NPM version: 10.5.0
          2025-01-19 08:49:04.928  - info: host.raspberrypi iobroker npm install iobroker.homeconnect@1.4.3 --loglevel error --prefix "/opt/iobroker" (System call)
          2025-01-19 08:49:07.778  - info: bshb.0 (3795) Client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 was not paired yet.
          2025-01-19 08:49:07.778  - info: bshb.0 (3795) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
          2025-01-19 08:49:09.945  - warn: tahoma.0 (3321) error during request: Error: connect ECONNREFUSED 192.168.178.36:8443, request path: setup/gateways with payload:{}
          2025-01-19 08:49:10.782  - warn: bshb.0 (3795) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: undefined
          2025-01-19 08:49:20.782  - info: bshb.0 (3795) Check if client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 is already paired.
          2025-01-19 08:49:23.793  - info: bshb.0 (3795) Client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 was not paired yet.
          2025-01-19 08:49:23.794  - info: bshb.0 (3795) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
          2025-01-19 08:49:26.798  - warn: bshb.0 (3795) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: undefined
          2025-01-19 08:49:39.025  - info: bshb.0 (3795) Check if client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 is already paired.
          2025-01-19 08:49:43.844  - warn: tahoma.0 (3321) error during request: Error: connect ECONNREFUSED 192.168.178.36:8443, request path: setup/gateways with payload:{}
          2025-01-19 08:50:20.512  - info: bshb.0 (3795) Client with identifier: ioBroker.bshb_c035acdd-5f03-4979-ac21-4e96459271c9 was not paired yet.
            Thomas Braun Most Active @13patrick37 last edited by Thomas Braun
            @13patrick37
            Installier da NEU das aktuelle Release 'Debian 12 - Bookworm'.
            Diesmal in der 64Bit-Lite-Version.
            ioBroker leer installieren, Backup einspielen, fertig.
            Edit:
            Ernsthaft?
              ich fürchte
              es hat drine Objects und/oder states DB zerschossen.
              Dafür gibt es interne Backups.
              Die existieren aber nur noch, wenn du nicht mehr als 10x dran rumgespielt hast.
              Ist ewig her, dass es das zum letzten mal gab.
              Hab nicht mehr im Kopf wie das Vorgehen war
              • 1
                Backup habe ich über winSCP schon gesichert. War zum Glück relativ aktuell.
                Also wie @Thomas-Braun sagte, komplett neu installieren und Backup einspielen.
                  das meinte ich nicht.
                  es gibt interne Backups der Systemdatenbanken.
                  Aber ein backitup Backup ist natürlich auch sinnvoll, wenn die Objectdatenbank darin nicht schon defekt ist.
                  1 1 Reply Last reply Reply Quote 0
                  • 1
                    13patrick37 @Homoran last edited by
                    @homoran said in ioBroker offline/Installation broken-nach Adapter:
                    Hast du dazu eine Doku? Oder wie gehe ich das an? Ein Versuch ist es wert bevor ich alles neu mache.
                    Frage ist, wodurch ist mein ioBroker abgeschmiert? An der veralteten js-controller Version?
                      Das musst du ohnehin alles neu aufsetzen.
                      • mcm1957
                        mcm1957 @Thomas Braun last edited by mcm1957
                        @13patrick37
                        Ist das dein Ersnt?
                        admin:          6.3.5
                        javascript:     6.1.4
                        js-controller 3.x.x ist ja icht nur veraltet sondern schon verwest. Sorry aber der aktuelle js-controller ist 7.x.x. Wundert mich dass du da irgendwelche Updates noch reingebracht hast. Oder ziehst du immer via Github ? iot von Github? zigbee von Github?
                        Wie hast du da homeconnect installiert? Der Adapter verlangt js-controller 5.0.19. Damit kann eine Installation via adminUI und via commandline nicht funktioniert haben.
                        ODER hast du - ohne es bisher zu erwähnen - versucht den js-controller zu aktualisisern. Ev. gar von 3 auf 7 ohne Zwischenstationen ?
                        Ich glaub da ist alles andere als eine komplette Neuinstallation vergebliche Liebesmühe.
                        • 1
                          13patrick37 @mcm1957 last edited by
                          @mcm1957 said in ioBroker offline/Installation broken-nach Adapter:
                          Tatsächlich nicht, war lediglich die Adapter Installation.
                          Ich habe nun ioBroker gelöscht und neu installiert. Ist jetzt die riesen Frage ob es das Backup nimmt? Aufgrund der alten js-controller Version.
                          • mcm1957
                            mcm1957 @13patrick37 last edited by
                            @13patrick37
                            Hast du gleich auf die aktuelle O/S Version (bookworm) aktualisisert?
                            Und node auf 20 gebracht?
                            Sonst machst das in 2 Monaten wieder ...
                            485
