    4. Zigbee 1.10.14 no Pairing no control of the devices
    • poppele
      poppele @haselchen last edited by
      @haselchen
      pi@raspberrypi-04:~ $ ls -l /dev/serial/by-id/
      insgesamt 0
      lrwxrwxrwx 1 root root 13 18. Jan 11:52 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
      • poppele
        poppele @dimaiv last edited by Samson71
        @dimaiv
        Auch nach neustart keinen Erfolg
        zigbee.0
        2025-01-19 17:07:33.369	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyAMA10"}]
        zigbee.0
        2025-01-19 17:07:25.985	warn	DeviceAvailability:Failed to ping 0xbc026efffe850b20 VINDSTYRKA
        zigbee.0
        2025-01-19 17:07:14.528	info	debug devices set to []
        zigbee.0
        2025-01-19 17:07:14.418	info	Zigbee started
        zigbee.0
        2025-01-19 17:07:14.417	info	0xa4c138e8320de095 (addr 43108): TS0503B - Tuya Zigbee RGB light (Router)
        zigbee.0
        2025-01-19 17:07:14.416	info	0x8cf681fffeb0f48b (addr 19076): TS0601_thermostat - Tuya Radiator valve with thermostat (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.413	info	0xa4c138c444889c7d (addr 25636): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
        zigbee.0
        2025-01-19 17:07:14.413	info	0x00124b002a5d4bd8 (addr 3271): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.412	info	0x00124b002a5cacef (addr 4421): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.412	info	0xa4c1381d3cadb737 (addr 42097): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
        zigbee.0
        2025-01-19 17:07:14.411	info	0xe0798dfffed4b158 (addr 64334): TS0207_repeater - Tuya Repeater (Router)
        zigbee.0
        2025-01-19 17:07:14.411	info	0x2c1165fffe69bd24 (addr 43213): 14153806L - Lidl Livarno smart LED ceiling light (Router)
        zigbee.0
        2025-01-19 17:07:14.410	info	0x2c1165fffec7468d (addr 6522): HG08164 - Lidl Silvercrest smart button (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.409	info	0x2c1165fffebfb714 (addr 50721): HG08164 - Lidl Silvercrest smart button (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.408	info	0xa4c13844b6e3e0c6 (addr 43625): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.405	info	0x00124b00072ad8f1 (addr 33891): AV2010/25 - SMaBiT (Bitron Video) Wireless socket with metering (Router)
        zigbee.0
        2025-01-19 17:07:14.404	info	0xa4c1388015e41ffa (addr 60416): WHD02 - Tuya Wall switch module (Router)
        zigbee.0
        2025-01-19 17:07:14.403	info	0xa4c1383e4a505202 (addr 56181): TS0601_smoke_6 - Tuya Smoke sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.401	info	0xa4c1389c9f663594 (addr 15617): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.399	info	0xa4c138ae97142823 (addr 13832): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.388	info	0x0c4314fffe5c4e96 (addr 21169): 368308_2010 - Lidl Silvercrest radiator valve with thermostat (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.385	info	0xec1bbdfffeb07aff (addr 39416): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.384	info	0x0c4314fffe6181c6 (addr 58097): 368308_2010 - Lidl Silvercrest radiator valve with thermostat (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.381	info	0x00158d00067cf51d (addr 46588): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.380	info	0xa4c138a02ad7f749 (addr 1640): SC500ZB - LoraTap Roller Shutter Blind Module (Router)
        zigbee.0
        2025-01-19 17:07:14.380	info	0xa4c138cc6b5909b1 (addr 55708): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
        zigbee.0
        2025-01-19 17:07:14.379	info	0xa4c138571d93a578 (addr 18420): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.377	info	0x00158d00068b3e96 (addr 16812): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.376	info	0xa4c138ca1122401b (addr 45988): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.374	info	0x00158d00046015bb (addr 3178): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.373	info	0xa4c138d8dd8c16ed (addr 3526): ERS-10TZBVK-AA - Tuya Smart knob (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.371	info	0x0c4314fffe65cd4d (addr 23097): 368308_2010 - Lidl Silvercrest radiator valve with thermostat (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.361	info	0x842e14fffe51c1a3 (addr 16668): FB20-002 - Lidl Livarno Lux switch and dimming light remote control (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.360	info	0x00158d00067cebf5 (addr 30670): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.358	info	0x00124b002fac0341 (addr 54359): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.357	info	0xec1bbdfffebccf20 (addr 31807): LED1837R5 - IKEA TRADFRI bulb GU10, warm white, 400 lm (Router)
        zigbee.0
        2025-01-19 17:07:14.357	info	0xec1bbdfffea2d411 (addr 62213): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
        zigbee.0
        2025-01-19 17:07:14.355	info	0xec1bbdfffefd2aef (addr 50158): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.353	info	0xbc026efffe850b20 (addr 22251): E2112 - IKEA VINDSTYRKA air quality and humidity sensor (Router)
        zigbee.0
        2025-01-19 17:07:14.352	info	0x00158d00067d9a2b (addr 28260): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.351	info	0x00158d000668eaee (addr 54198): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.351	info	0x842e14fffedb8eb9 (addr 64517): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.350	info	0xbc33acfffe16fa32 (addr 9798): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.349	info	0x00158d0002d77eca (addr 36776): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.348	info	0x00158d00044f569a (addr 21912): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.348	info	0xa4c138d6c581a236 (addr 33598): TH01Z - Tuya Temperature and humidity sensor with clock (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.343	info	0x00158d0002d77ed1 (addr 49863): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.342	info	0x00158d0004600d60 (addr 64340): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.342	info	0x003c84fffe85befd (addr 17832): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
        zigbee.0
        2025-01-19 17:07:14.340	info	0xec1bbdfffefb206a (addr 5299): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.339	info	0x00158d00045cb3ce (addr 63299): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.338	info	0x00158d00067d9483 (addr 58843): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.338	info	0xbc33acfffe0c1456 (addr 15239): HG06335/HG07310 - Lidl Silvercrest smart motion sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.337	info	0xec1bbdfffe843856 (addr 25196): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
        zigbee.0
        2025-01-19 17:07:14.336	info	0x842e14fffefa0ba8 (addr 22905): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
        zigbee.0
        2025-01-19 17:07:14.332	info	0x00158d00045c2c6b (addr 21366): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
        zigbee.0
        2025-01-19 17:07:14.202	info	Currently 52 devices are joined:
        zigbee.0
        2025-01-19 17:07:14.084	info	--> transmitPower : high
        zigbee.0
        2025-01-19 17:07:14.077	info	Unable to disable LED, unsupported function.
        zigbee.0
        2025-01-19 17:07:14.076	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20211217}}
        zigbee.0
        2025-01-19 17:07:02.860	info	Installed Version: iobroker.zigbee@1.10.14
        zigbee.0
        2025-01-19 17:07:02.662	info	Starting Zigbee npm ...
        zigbee.0
        2025-01-19 17:07:02.661	info	delete old Backup files. keep only last 10
        zigbee.0
        2025-01-19 17:07:02.622	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.5, js-controller: 7.0.6
        zigbee.0
        2025-01-19 17:05:53.392	info	Terminated (NO_ERROR): Without reason
        zigbee.0
        2025-01-19 17:05:53.391	info	terminating
        zigbee.0
        2025-01-19 17:05:53.160	info	Got terminate signal TERMINATE_YOURSELF
        zigbee.0
        2025-01-19 17:05:52.901	info	Zigbee: disabling joining new devices.
        zigbee.0
        2025-01-19 17:05:52.879	info	cleaned everything up...
        zigbee.0
        2025-01-19 15:58:40.964	info	debug devices set to []
        zigbee.0
        2025-01-19 15:58:40.808	info	Zigbee started
        MOD-EDIT: BITTE CODETAGES BENUTZEN!!!
        haselchen 1 Reply Last reply Reply Quote 1
        • haselchen
          haselchen Most Active @poppele last edited by
          @poppele sagte in Zigbee 1.10.14 no Pairing no control of the devices:
          zStack3x0
          Pack das Ganze mal bitte in Codetags!
          Und aktualisiere Deinen Stick
          https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0/bin
          Deine FW ist von 2021.
          Dann setz mal Deine Sendeleistung Einstellung im Adapter zurück.
          Die bringt nichts.
          Und änder Deine erweiterte PAN ID
          D Samson71 2 Replies Last reply Reply Quote 1
            dimaiv @haselchen last edited by
            @haselchen
            Wenn er das alles macht, startet sein Zigbee Adapter gar nicht mehr, und es kann sein das er alle seine Geräte verliert und muss alles neu einrichten.
            • haselchen
              haselchen Most Active @dimaiv last edited by
              @dimaiv
              Gegenfrage, was passiert in der Zukunft, wenn er so lässt?
              • Samson71
                Samson71 Global Moderator @haselchen last edited by
                @haselchen sagte in Zigbee 1.10.14 no Pairing no control of the devices:
                Habe ich für ihn gemacht, aber am Handy ist das nur Semi-spassig.
                @poppele
                Bitte in Zukunft bei beim Posten von Protokollen/Logs beachten!
                  @haselchen
                  Sagen wir so, default Einstellungen würde ich natürlich auch sofort ändern. Das bedeutet - komplette Netz neu aufbauen.
                  Als erstes muss man natürlich die Firmware auf dem Stick aktualisieren.
                  • Asgothian
                    Asgothian Developer @poppele last edited by
                    Nach Update auf Zigbee 1.10.14 startet Pairing nicht mehr und Steuerung der Geräte nicht mehr, Gerätedaten werden aber noch alle empfangen.
                    • Was für einen Koordinator setzt du ein ?
                    • gibt es einen Grund warum du auf die 1.10.14 setzen musst, oder kannst du deine Geräte auch mit der 1.10.3 kontrollieren ? Wenn ja empfehle ich aktuell auf der 1.10.3 zu bleiben bis die 1.11 / 2.0 des Adapters raus ist - dann sollte das Problem vom Tisch sein.
                    A,
                    poppele 1 Reply Last reply Reply Quote 1
                    • poppele
                      poppele @Asgothian last edited by
                      @asgothian
                      Ich bleibe jetzt auf 1.10.3 und warte auf 1.11 Wann wird 1.11.x erscheinen?
                      Danke,
                      E
                      • Asgothian
                        @asgothian
                        Danke,
                        E
                        was ist das für ein Koordinator ? Diem Kachel sagt das nicht.
                        A.
                        poppele 1 Reply Last reply Reply Quote 0
                        • poppele
                          @asgothian
                          Der Koordinator wurde als =>USB Stick CC2652P AutoBSL ZigBee 3.0, Coordinator Firmware, 10 dBi Antenne<= verkauft.
                          lrwxrwxrwx 1 root root 13 20. Jan 08:17 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
                          Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                          • Meister Mopper
                            Meister Mopper @poppele last edited by
                            @poppele
                            Dreh mal die Kachel und zeig das Bild, dann sieht man's.
                              Thomas Braun Most Active @poppele last edited by
                              Tipp am Rande:
                              Trag den Stick mit dem Pfad
                              /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                              ein, nicht mit ttyUSB0. Es ist nicht garantiert, dass der Stick immer auf ttyUSB0 landet.
                              update problem zigbee zigbee
                              1037
