    4. Node-Red
    5. Node Red Optimierung PV Überschuss für Anfänger
      Harry_vlbg @mickym last edited by
      @mickym
             "id": "0be53785c72fb931",
             "type": "tab",
             "label": "Flow 1",
             "disabled": false,
             "info": "",
             "env": []
             "id": "cf09bc5276f7be79",
             "type": "shelly-gen2",
             "z": "0be53785c72fb931",
             "hostname": "192.168.178.54",
             "description": "Boiler_Bad",
             "mode": "polling",
             "verbose": false,
             "server": "",
             "outputmode": "event",
             "uploadretryinterval": 5000,
             "pollinginterval": "6000",
             "pollstatus": false,
             "getstatusoncommand": true,
             "devicetype": "SNSW-001P16EU",
             "devicetypemustmatchexactly": true,
             "captureblutooth": false,
             "outputs": 1,
             "x": 950,
             "y": 240,
             "wires": [
                     "aa58cc0f316c4f70"
             "inputLabels": [
                 "payload.switch0.id"
             "outputLabels": [
                 "1"
             "id": "8fab423dfb34e072",
             "type": "switch",
             "name": "Ladezustand Batterie > 95%",
             "property": "payload",
             "propertyType": "msg",
             "rules": [
                     "t": "gte",
                     "v": "95",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 160,
             "y": 240,
             "wires": [
                     "93e2aa46a4a02ee0"
             "id": "0b247bc8d9ca735e",
             "type": "victron-input-battery",
             "service": "com.victronenergy.battery/512",
             "path": "/Capacity",
             "serviceObj": {
                 "name": "Pytes battery"
             "pathObj": {
                 "type": "float",
                 "name": "Capacity (Ah)"
             "name": "",
             "onlyChanges": true,
             "roundValues": "no",
             "x": 140,
             "y": 60,
             "wires": [
                     "8fab423dfb34e072"
             "id": "b2a7ee2ce7767b6b",
             "type": "http request",
             "name": "Shelly Befehl Boiler ein",
             "method": "GET",
             "ret": "txt",
             "paytoqs": "ignore",
             "url": "http://192.168.178.54/relay/0?turn=on",
             "tls": "",
             "persist": false,
             "proxy": "",
             "insecureHTTPParser": false,
             "authType": "",
             "senderr": false,
             "headers": [],
             "x": 670,
             "y": 140,
             "wires": [
                     "cf09bc5276f7be79",
                     "bc55c22dbd242ea5"
             "id": "bc55c22dbd242ea5",
             "type": "delay",
             "name": "",
             "pauseType": "delay",
             "timeout": "45",
             "timeoutUnits": "minutes",
             "rate": "1",
             "nbRateUnits": "1",
             "rateUnits": "second",
             "randomFirst": "1",
             "randomLast": "5",
             "randomUnits": "seconds",
             "drop": false,
             "allowrate": false,
             "outputs": 1,
             "x": 490,
             "y": 240,
             "wires": [
                     "a8814585a8e2257f"
             "id": "a8814585a8e2257f",
             "name": "Boiler aus nach 45 Min",
             "method": "GET",
             "ret": "txt",
             "url": "http://192.168.178.54/relay/0?turn=off",
             "tls": "",
             "persist": false,
             "proxy": "",
             "authType": "",
             "senderr": false,
             "headers": [],
             "x": 720,
             "y": 240,
             "wires": [
                     "cf09bc5276f7be79"
             "id": "93e2aa46a4a02ee0",
             "type": "delay",
             "name": "1 Message pro 12 H",
             "pauseType": "rate",
             "timeout": "5",
             "timeoutUnits": "seconds",
             "rate": "1",
             "nbRateUnits": "12",
             "rateUnits": "hour",
             "randomFirst": "1",
             "randomLast": "5",
             "drop": false,
             "allowrate": false,
             "outputs": 1,
             "x": 380,
             "y": 140,
             "wires": [
                     "b2a7ee2ce7767b6b"
             "info": "1 Message pro 12 Stunden um dem Boiler nicht mehrmals im tag einzuschalten.\n"
             "id": "aa58cc0f316c4f70",
             "type": "change",
             "name": "Boiler geheizt",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "boiler geheizt",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1200,
             "y": 240,
             "wires": [
        @mickym hat das jetzt so geklappt?
        funktioniert aber hervorragend mit http
        Ist halte ein Gen2
        • mickym
          mickym Most Active @Harry_vlbg last edited by
          @harry_vlbg Ja der import hat soweit funktioniert.
          Das Victron Teil habe ich nicht, aber das kann ich mit Inject Nodes simulieren.
            @mickym bin ich schon froh das ich das soweit geschafft habe 😉
            wäre einfacher auf meinem PC.
            also du machst jetzt diesen Change Note mit der Variable Boiler geheizt und startest um 1 Uhr morgens am nächsten Tag den Boiler wenn er die letzten 12 Stunden nicht geheizt hat?
            • mickym
              mickym Most Active @Harry_vlbg last edited by mickym
              @harry_vlbg sagte in Node Red Optimierung PV Überschuss für Anfänger:
              Ist halte ein Gen2
              Ja aber es macht keinen Sinn. Schau mal die Shelly Nodes bringen Beispiele mit. Als erstes probiere mal die Beispiele.
              Also erstes gehst Du unter import
              und unter Beispiele siehst Du die Beispiele, die Shelly mitliefert.
              Dann importierst Du mal das Beispiel mit dem switch:
              Als Hostname gibst mal Deinen Boiler IP-Adresse ein und schaust mal - ob Du mit dem Flow den Boiler schalten und auslesen kannst.
              Mit diesen Inject Nodes kannst Du ein- und ausschalten bzw. den Status abrufen.
              Schau mal ob das klappt.
              Ansonsten, wenn Du lieber über Http schalten willst - dann kannst Dir die Shelly Nodes wieder deinstallieren - weil die sonst überflüssig sind. Da kann man dann später auch Http nehmen.
              Er schaltet den Boiler aber nur für 2 Sekunden. Schau einfach mal, ob Du die Config auslesen kannst.
              Wir werden das ohne function Nodes machen
              und dieses toggle ausschalten. Aber wie gesagt wir können auch einfach anfangen - aber dann lösche die Shelly Nodes aus Deinem Flow - die dürfen NICHT dazwischenfunken. Wenn Du rein über HTTP schalten willst, dann verwende die erst mal nicht in Deinem Flow.
              H 3 Replies Last reply Reply Quote 0
                @mickym
                also ich bekomme fehlermeldungen
                20.1.2025, 20:12:02node: 4ec3bc22e66b23bf
                msg : string[39]
                "Wrong node type. Please use shelly-gen2"
                kann aber auch den shelly plus nicht auswählen. allerdings hat er eingeschaltet
                  @mickym der richtige wäre shelly plus 1 PM also bleiben wir beim alten
                  • mickym
                    @harry_vlbg
                    Wie gesagt, dann stelle mal in der Node - auf Deinen Typ um:
                    Also wie gesagt, wir können ja erstmal bei Deinem Schalten bleiben - ABER dann mach den Shelly Node aus Deinem Flow.
                      @mickym ich verwende eh nur den normalen http request.
                      heißt nur bei mir shelly befehl das ich mich auskenne.
                      bin hier ganz neu und auch nicht vom fach
                      • mickym
                        @harry_vlbg Ja wir machen es nur mit den HTTP Request Nodes erst mal.
                        Deine Shelly Node würde ich dann löschen
                        In der 1. Change Node setzen wird die Flow Variable boiler auf true und dann nach dem Ausschalten auf false.
                               "method": "GET",
                               "ret": "txt",
                               "tls": "",
                               "persist": false,
                               "proxy": "",
                               "authType": "",
                               "senderr": false,
                               "headers": [],
                               "x": 630,
                               "y": 140,
                               "wires": [
                                       "bc55c22dbd242ea5",
                                       "e2954a89ed9e7e6e"
                               "type": "delay",
                               "name": "",
                               "timeout": "45",
                               "rate": "1",
                               "nbRateUnits": "1",
                               "randomFirst": "1",
                               "randomLast": "5",
                               "drop": false,
                               "allowrate": false,
                               "outputs": 1,
                               "x": 930,
                               "y": 140,
                               "wires": [
                                       "a8814585a8e2257f"
                               "method": "GET",
                               "ret": "txt",
                               "tls": "",
                               "persist": false,
                               "proxy": "",
                               "authType": "",
                               "senderr": false,
                               "headers": [],
                               "x": 1160,
                               "y": 140,
                               "wires": [
                               "id": "e2954a89ed9e7e6e",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "boiler",
                                       "pt": "flow",
                                       "to": "true",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 860,
                               "y": 200,
                               "wires": [
                        Wenn Du dann in das Kontextmenu gehst, solltest Du unter Flow eine Variable boiler haben, der signalisiert dass der Boiler angeschaltet wurde.
                          @mickym soweit so gut - habe ich
                          • mickym
                            Ja diese 2. Change Node kannst wieder löschen, weil wir wollen ja nur einmal prüfen, ob der Boiler eingeschaltet wurde.
                            • mickym
                              So nun müssen wir also jede Nacht um 1:00 Uhr prüfen, ob der Boiler eingeschaltet wurde.
                              Wir nehmen einfach eine InjectNode:
                              H mickym 2 Replies Last reply Reply Quote 0
                                @mickym also boiler hat eingeschaltet - musste noch zuerst den Ladeszustand ändern aber geht.
                                Kontektmenü finde ich keines
                                  @mickym gefunden - flow boiler true
                                  • mickym
                                    Das Kontextmenü
                                    gut 🙂
                                    • mickym
                                      mickym Most Active @mickym last edited by mickym
                                      @mickym sagte in Node Red Optimierung PV Überschuss für Anfänger:
                                      Dann mach wie gesagt eine Inject Node wie abgebildet, die jede Nacht um 1:00 Uhr triggert, aber Du kannst zum Test auch manuell die Inject Node auslösen.
                                      In der Switch Node überprüfen, wir nun ob die Variable blow auf true steht oder false.
                                      damit wenn Du NodeRed neu startest, setzen wir die boiler Variable erst mal auf false, damit diese initialisiert ist.
                                             "id": "aaa0ed39edb3edd4",
                                             "type": "inject",
                                             "name": "Um 1:00 Uhr",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "crontab": "00 01 * * *",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "true",
                                             "payloadType": "bool",
                                             "x": 500,
                                             "y": 420,
                                             "wires": [
                                                     "9e4761a142f09e81"
                                             "id": "9e4761a142f09e81",
                                             "type": "switch",
                                             "name": "",
                                             "property": "boiler",
                                             "propertyType": "flow",
                                             "rules": [
                                                     "t": "true"
                                                     "t": "false"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 2,
                                             "x": 670,
                                             "y": 420,
                                             "wires": [
                                             "id": "1ab25cdf4774aba9",
                                             "type": "inject",
                                             "name": "",
                                             "props": [
                                                     "p": "payload"
                                                     "p": "topic",
                                                     "vt": "str"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": true,
                                             "onceDelay": 0.1,
                                             "topic": "boiler",
                                             "payload": "false",
                                             "x": 450,
                                             "y": 340,
                                             "wires": [
                                                     "64867f8e8ebed7e4"
                                             "id": "64867f8e8ebed7e4",
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "boiler",
                                                     "pt": "flow",
                                                     "to": "payload",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 640,
                                             "y": 340,
                                             "wires": [
                                        @mickym kann ich das importieren und brauche ich hier auch wieder augen und so?
                                        • mickym
                                          @harry_vlbg
                                          nein kannst du direkt importieren
                                          einfach den Spoiler aufmachen und dann den Flow mit der Schaltfläche Copy to clipboard in die Zwischenablage kopieren und dann in das rosa Importfenster
                                            @mickym ok - status ist jetzt false - somit wieder löschen?
                                            1.0k
                                            5353
