Massive Performance Probleme beim GUI Zugriff
Servus,
hab seit ca. 1 Woche ( letztes Update von Debian) gefühlt immer schlimmer werdende Zugriffsprobleme auf die GUI ( egal welcher Tab)
Sei es über die IP:Port oder über die DNS Adresse.
Teilweise braucht der Zugriff Minuten, teilweise überhaupt nicht möglich.....
Maßnahmen bissher :
reboot
iob fix
iob diag full ( nachfolgend)========== Start marking the full check here =========== ```bash Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: IOBROKER-MASTER Icon name: computer-vm Chassis: vm 🖴 Virtualization: vmware Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-30-amd64 Architecture: x86-64 Hardware Vendor: VMware, Inc. Hardware Model: VMware Virtual Platform Firmware Version: 6.00 OS is similar to: model name : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz Docker : false Virtualization : vmware Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 12:44:47 up 3 days, 2:39, 1 user, load average: 3.08, 1.51, 1.00 CPU threads: 16 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** TIME AND TIMEZONES *** Local time: Tue 2025-01-21 12:44:47 CET Universal time: Tue 2025-01-21 11:44:47 UTC RTC time: Tue 2025-01-21 11:44:47 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': debian HOME=/home/debian GROUPS=debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth redis *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 12G 5.3G 2.1G 1.4M 5.5G 7.2G Swap: 2.1G 0B 2.1G Total: 14G 5.3G 4.2G Active iob-Instances: 26 11926 M total memory 5059 M used memory 1760 M active memory 6261 M inactive memory 1987 M free memory 954 M buffer memory 4304 M swap cache 2043 M total swap 0 M used swap 2043 M free swap *** top - Table Of Processes *** top - 12:44:47 up 3 days, 2:39, 1 user, load average: 3.08, 1.51, 1.00 Tasks: 325 total, 3 running, 322 sleeping, 0 stopped, 0 zombie %Cpu(s): 9.5 us, 4.8 sy, 0.0 ni, 81.0 id, 0.0 wa, 0.0 hi, 4.8 si, 0.0 st MiB Mem : 11926.6 total, 1984.6 free, 5062.4 used, 5258.6 buff/cache MiB Swap: 2044.0 total, 2044.0 free, 0.0 used. 6864.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 5.8G 0 5.8G 0% /dev tmpfs tmpfs 1.2G 1.3M 1.2G 1% /run /dev/mapper/debian10--vg-root ext4 107G 40G 62G 39% / tmpfs tmpfs 5.9G 0 5.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda1 ext2 234M 186M 36M 84% /boot /dev/mapper/debian10--vg-home ext4 70G 11G 57G 16% /home /dev/mapper/debian10--vg-tmp ext4 1.2G 328K 1.1G 1% /tmp /dev/mapper/debian10--vg-var ext4 6.4G 2.4G 3.6G 40% /var 192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4 1.9T 672G 1.3T 35% /mnt/photosyno 192.168.10.47:/volume1/IOBROKER nfs4 2.7T 1.6T 1.1T 60% /mnt/IOBROKERDATA 192.168.10.47:/volume2/Backup nfs4 1.9T 672G 1.3T 35% /mnt/BACKUP tmpfs tmpfs 1.2G 60K 1.2G 1% /run/user/1000 //192.168.10.47/Backup/IOBROKER/iobroker cifs 1.9T 672G 1.3T 35% /opt/iobroker/backups Messages concerning ext4 filesystem in dmesg: [Sat Jan 18 10:04:53 2025] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none. [Sat Jan 18 10:04:54 2025] EXT4-fs (dm-0): re-mounted. Quota mode: none. [Sat Jan 18 10:04:55 2025] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem [Sat Jan 18 10:04:55 2025] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none. [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none. [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none. [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/debian10--vg-root ext4 rw,relatime,errors=remount-ro |-/boot /dev/sda1 ext2 rw,relatime |-/home /dev/mapper/debian10--vg-home ext4 rw,relatime |-/tmp /dev/mapper/debian10--vg-tmp ext4 rw,relatime |-/var /dev/mapper/debian10--vg-var ext4 rw,relatime |-/opt/iobroker/backups //192.168.10.47/Backup/IOBROKER/iobroker cifs rw,relatime,vers=3.1.1,cache=strict,username=IOBROKER,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.10.47,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1 |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 |-/mnt/photosyno 192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 `-/mnt/BACKUP 192.168.10.47:/volume2/Backup nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 Files in neuralgic directories: /var: 2.4G /var/ 2.0G /var/lib 680M /var/lib/redis 537M /var/lib/grafana 532M /var/lib/grafana/plugins Archived and active journals take up 320.1M in the file system. /opt/iobroker/backups: 23G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 27G /opt/iobroker/iobroker-data/ 26G /opt/iobroker/iobroker-data/history 947M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/backup-objects 176M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 46M /opt/iobroker/iobroker-data/objects.jsonl 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' HINT: Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting: tcp HINT: Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting: tcp *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Hosts: IOBROKER-MASTER IOBROKER-MASTER (version: 7.0.6, hostname: IOBROKER-MASTER, alive, uptime: 137) IOBROKER-SLAVE IOBROKER-SLAVE (version: 7.0.6, hostname: IOBROKER-SLAVE, alive, uptime: 706164) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: 8.8.3 nodejs modules from github: 17 +-- iobroker.dreame@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#beda212e3313d3477707fb5a8f52c7eefed9bfd7) +-- iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#9ec12d2f39898351be9ff6105043a408251e6174) +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#384363b87eaf0fa0b66ad2b54f2f51427dbc738d) +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606) +-- iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954) +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409) | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103) +-- iobroker.notificationforandroidtv@3.0.1 (git+ssh://git@github.com/DNAngelX/ioBroker.notificationforandroidtv.git#4f5ec5635498f83f87b68fd6d5e8371b1414b764) +-- iobroker.oasecontrol@0.0.2 (git+ssh://git@github.com/mr-suw/ioBroker.oasecontrol.git#d8f1584259393298b214d605c6934579860276b3) +-- iobroker.ocpp@0.12.5 (git+ssh://git@github.com/foxriver76/ioBroker.ocpp.git#6f0316acb6d3bacb9cfd82293590a9dd307d3d9d) | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550) +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#6b9894252659ebf564221d3119361a20c8f82d1d) +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#d201c1d92bbf728f16420c85804151b7dce29157) | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#221464afaa7db4eff676ab588786c40d35e8bad6) +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#be2791c1dfe1467e21e081ac1a6de1d36eac0e41) `-- paesslerag-node-red-contrib-prtg@0.0.0-development (git+ssh://git@github.com/PaesslerAG/node-red-contrib-prtg.git#8c7a526e6975caef38d3b3f384ba5125d888b103) Adapter State system.adapter.adb.0 : adb : IOBROKER-MASTER - enabled + system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : IOBROKER-MASTER - enabled system.adapter.alexa2.0 : alexa2 : IOBROKER-MASTER - enabled system.adapter.alias-manager.0 : alias-manager : IOBROKER-MASTER - enabled system.adapter.asterisk.0 : asterisk : IOBROKER-MASTER - enabled, port: 5038 system.adapter.backitup.0 : backitup : IOBROKER-MASTER - enabled + system.adapter.backitup.1 : backitup : IOBROKER-SLAVE - enabled system.adapter.chromecast.0 : chromecast : IOBROKER-MASTER - enabled system.adapter.daswetter.0 : daswetter : IOBROKER-MASTER - enabled system.adapter.device-watcher.0 : device-watcher : IOBROKER-MASTER - disabled system.adapter.devices.0 : devices : IOBROKER-MASTER - enabled system.adapter.discovery.0 : discovery : IOBROKER-MASTER - enabled system.adapter.dreame.0 : dreame : IOBROKER-MASTER - enabled system.adapter.dwd.0 : dwd : IOBROKER-MASTER - enabled system.adapter.echarts.0 : echarts : IOBROKER-MASTER - enabled + system.adapter.email.0 : email : IOBROKER-MASTER - enabled system.adapter.feiertage.0 : feiertage : IOBROKER-MASTER - enabled system.adapter.flot.0 : flot : IOBROKER-MASTER - enabled system.adapter.fullybrowser.0 : fullybrowser : IOBROKER-MASTER - enabled system.adapter.gartenbewaesserung.0 : gartenbewaesserung : IOBROKER-MASTER - enabled system.adapter.govee-app.0 : govee-app : IOBROKER-MASTER - enabled system.adapter.ham.0 : ham : IOBROKER-MASTER - disabled system.adapter.hass.0 : hass : IOBROKER-MASTER - disabled, port: 8123 system.adapter.heatingcontrol.0 : heatingcontrol : IOBROKER-MASTER - disabled system.adapter.hiob.0 : hiob : IOBROKER-MASTER - disabled, port: 8090 + system.adapter.history.0 : history : IOBROKER-MASTER - enabled system.adapter.hm-rega.0 : hm-rega : IOBROKER-MASTER - enabled system.adapter.hm-rpc.0 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 system.adapter.hm-rpc.2 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hue.0 : hue : IOBROKER-MASTER - enabled, port: 80 system.adapter.husq-automower.0 : husq-automower : IOBROKER-MASTER - disabled system.adapter.ical.0 : ical : IOBROKER-MASTER - enabled system.adapter.ical.1 : ical : IOBROKER-MASTER - enabled system.adapter.ical.2 : ical : IOBROKER-MASTER - enabled system.adapter.icons-material-png.0 : icons-material-png : IOBROKER-MASTER - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : IOBROKER-MASTER - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : IOBROKER-MASTER - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : IOBROKER-MASTER - enabled + system.adapter.influxdb.0 : influxdb : IOBROKER-MASTER - enabled, port: 8086 + system.adapter.javascript.0 : javascript : IOBROKER-MASTER - enabled system.adapter.kodi.0 : kodi : IOBROKER-MASTER - disabled, port: 9090 system.adapter.linkeddevices.0 : linkeddevices : IOBROKER-MASTER - enabled system.adapter.linktap.0 : linktap : IOBROKER-MASTER - disabled system.adapter.linux-control.0 : linux-control : IOBROKER-MASTER - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : IOBROKER-MASTER - disabled, port: 54321 system.adapter.mqtt-client.0 : mqtt-client : IOBROKER-MASTER - disabled, port: 1884, bind: 0.0.0.0 system.adapter.mqtt.0 : mqtt : IOBROKER-MASTER - enabled, port: 1883, bind: 0.0.0.0 system.adapter.mytime.0 : mytime : IOBROKER-MASTER - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : IOBROKER-MASTER - disabled + system.adapter.node-red.0 : node-red : IOBROKER-MASTER - enabled, port: 1880, bind: 0.0.0.0 system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER - enabled system.adapter.nuki-extended.0 : nuki-extended : IOBROKER-MASTER - disabled + system.adapter.nuki.0 : nuki : IOBROKER-MASTER - enabled system.adapter.oasecontrol.0 : oasecontrol : IOBROKER-MASTER - enabled system.adapter.ocpp.0 : ocpp : IOBROKER-MASTER - enabled, port: 9220 system.adapter.onkyo.0 : onkyo : IOBROKER-MASTER - enabled system.adapter.onvif.0 : onvif : IOBROKER-MASTER - disabled, port: 80, 7575, 8000, 8080, 8081, 8899 system.adapter.ping.0 : ping : IOBROKER-MASTER - enabled + system.adapter.pushover.0 : pushover : IOBROKER-MASTER - enabled system.adapter.reolink.0 : reolink : IOBROKER-MASTER - disabled system.adapter.robonect.0 : robonect : IOBROKER-MASTER - disabled system.adapter.samsung.0 : samsung : IOBROKER-MASTER - disabled + system.adapter.samsung_tizen.0 : samsung_tizen : IOBROKER-MASTER - enabled, port: 8002 system.adapter.sayit.0 : sayit : IOBROKER-MASTER - enabled + system.adapter.scenes.0 : scenes : IOBROKER-MASTER - enabled + system.adapter.scheduler.0 : scheduler : IOBROKER-MASTER - enabled + system.adapter.shelly.0 : shelly : IOBROKER-MASTER - enabled, port: 1882, bind: 0.0.0.0 system.adapter.shuttercontrol.0 : shuttercontrol : IOBROKER-MASTER - disabled system.adapter.simple-api.0 : simple-api : IOBROKER-MASTER - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.smartcontrol.0 : smartcontrol : IOBROKER-MASTER - enabled system.adapter.smartmeter.0 : smartmeter : IOBROKER-SLAVE - disabled system.adapter.smartthings.0 : smartthings : IOBROKER-MASTER - enabled system.adapter.sonoff.0 : sonoff : IOBROKER-MASTER - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : IOBROKER-MASTER - enabled system.adapter.sourceanalytix.0 : sourceanalytix : IOBROKER-MASTER - enabled system.adapter.synology.0 : synology : IOBROKER-MASTER - enabled, port: 5000 + system.adapter.tahoma.0 : tahoma : IOBROKER-MASTER - enabled system.adapter.tankerkoenig.0 : tankerkoenig : IOBROKER-MASTER - enabled + system.adapter.telegram.0 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 system.adapter.telegram.2 : telegram : IOBROKER-MASTER - disabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : IOBROKER-MASTER - enabled system.adapter.text2command.1 : text2command : IOBROKER-MASTER - enabled system.adapter.time-switch.0 : time-switch : IOBROKER-MASTER - enabled system.adapter.trashschedule.0 : trashschedule : IOBROKER-MASTER - enabled system.adapter.trashschedule.1 : trashschedule : IOBROKER-MASTER - enabled + system.adapter.unifi.0 : unifi : IOBROKER-MASTER - enabled system.adapter.upnp.0 : upnp : IOBROKER-MASTER - disabled system.adapter.vaillant.0 : vaillant : IOBROKER-MASTER - enabled system.adapter.vis-2.0 : vis-2 : IOBROKER-MASTER - enabled system.adapter.vis-bars.0 : vis-bars : IOBROKER-MASTER - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : IOBROKER-MASTER - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : IOBROKER-MASTER - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : IOBROKER-MASTER - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : IOBROKER-MASTER - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : IOBROKER-MASTER - enabled system.adapter.vis-icontwo.0 : vis-icontwo : IOBROKER-MASTER - enabled system.adapter.vis-inventwo.0 : vis-inventwo : IOBROKER-MASTER - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : IOBROKER-MASTER - enabled system.adapter.vis-justgage.0 : vis-justgage : IOBROKER-MASTER - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : IOBROKER-MASTER - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : IOBROKER-MASTER - enabled system.adapter.vis-metro.0 : vis-metro : IOBROKER-MASTER - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : IOBROKER-MASTER - enabled system.adapter.vis-weather.0 : vis-weather : IOBROKER-MASTER - enabled system.adapter.vis.0 : vis : IOBROKER-MASTER - enabled system.adapter.vw-connect.0 : vw-connect : IOBROKER-MASTER - enabled + system.adapter.weatherunderground.0 : weatherunderground : IOBROKER-MASTER - enabled system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : IOBROKER-MASTER - enabled + system.adapter.whatsapp-cmb.1 : whatsapp-cmb : IOBROKER-MASTER - enabled system.adapter.yahka.0 : yahka : IOBROKER-MASTER - enabled system.adapter.zigbee.1 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.24:6638 + system.adapter.zigbee.2 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.39:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.asterisk.0 : asterisk : IOBROKER-MASTER - enabled, port: 5038 system.adapter.hm-rpc.0 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 system.adapter.hm-rpc.2 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hue.0 : hue : IOBROKER-MASTER - enabled, port: 80 + system.adapter.influxdb.0 : influxdb : IOBROKER-MASTER - enabled, port: 8086 system.adapter.mqtt.0 : mqtt : IOBROKER-MASTER - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : IOBROKER-MASTER - enabled, port: 1880, bind: 0.0.0.0 system.adapter.ocpp.0 : ocpp : IOBROKER-MASTER - enabled, port: 9220 + system.adapter.samsung_tizen.0 : samsung_tizen : IOBROKER-MASTER - enabled, port: 8002 + system.adapter.shelly.0 : shelly : IOBROKER-MASTER - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : IOBROKER-MASTER - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : IOBROKER-MASTER - enabled, port: 1885, bind: 0.0.0.0 system.adapter.synology.0 : synology : IOBROKER-MASTER - enabled, port: 5000 + system.adapter.telegram.0 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.1 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.24:6638 + system.adapter.zigbee.2 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.39:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "adb" : 0.0.7 , installed 0.0.7 Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "alarm" : 3.6.7 , installed 3.6.7 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "alias-manager": 2.0.0 , installed 2.0.0 Adapter "apcups" : 4.0.2 , installed 4.0.2 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "birthdays" : 3.1.0 , installed 3.1.0 Adapter "chromecast" : 4.0.0 , installed 4.0.0 Adapter "daswetter" : 3.2.2 , installed 3.2.2 Adapter "device-watcher": 2.12.1 , installed 2.12.1 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "doorio" : 2.1.5 , installed 2.1.5 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "email" : 1.3.1 , installed 1.3.1 Adapter "feiertage" : 1.2.1 , installed 1.2.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "ham" : 5.3.1 , installed 5.3.1 Adapter "hass" : 1.4.0 , installed 1.4.0 Adapter "heatingcontrol": 2.12.13 , installed 2.12.13 Adapter "hiob" : 0.1.6 , installed 0.1.6 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "hue" : 3.13.1 , installed 3.13.1 Adapter "ical" : 1.16.1 , installed 1.16.1 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "kodi" : 3.1.0 , installed 3.1.0 Adapter "linkeddevices": 1.5.5 , installed 1.5.5 Adapter "linktap" : 1.0.1 , installed 1.0.1 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "mihome-vacuum": 4.2.0 , installed 4.2.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mpd" : 2.2.0 , installed 2.2.0 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "mqtt-client" : 2.1.0 , installed 2.1.0 Adapter "mytime" : 1.2.2 , installed 1.2.2 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "node-red" : 5.2.1 , installed 5.2.1 Adapter "nuki" : 2.0.0 , installed 2.0.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "ocpp" : 0.12.5 , installed 0.12.5 Adapter "onkyo" : 2.1.2 , installed 2.1.2 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 4.1.0 , installed 4.1.0 Adapter "reolink" : 1.1.2 , installed 1.1.2 Adapter "robonect" : 1.4.2 , installed 1.4.2 Adapter "samsung" : 0.6.1 , installed 0.6.1 Adapter "samsung_tizen": 1.1.0 , installed 1.1.0 Adapter "sayit" : 5.0.0 , installed 5.0.0 Adapter "scenes" : 3.2.3 , installed 3.2.3 Adapter "scheduler" : 1.4.1 , installed 1.4.1 Adapter "shelly" : 8.5.1 , installed 8.5.1 Adapter "shuttercontrol": 1.8.5 , installed 1.8.5 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "tahoma" : 0.10.4 , installed 0.10.4 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.9.64 , installed 2.9.64 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "volumio" : 0.2.0 , installed 0.2.0 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "webcal" : 1.3.10 , installed 1.3.10 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.0.3 , installed 1.0.3 Adapter "zigbee" : 1.10.14 , installed 1.10.14 Objects and States Please stand by - This may take a while Objects: 63662 States: 52903 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 24 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 3772413 1309329/cupsd tcp 0 0 192.168.10.16:2001 0.0.0.0:* LISTEN 1001 4570060 1579527/io.hm-rpc.0 tcp 0 0 192.168.10.16:2010 0.0.0.0:* LISTEN 1001 4567920 1578389/io.hm-rpc.1 tcp 0 0 192.168.10.16:9292 0.0.0.0:* LISTEN 1001 4574739 1579932/io.hm-rpc.2 tcp 0 0 192.168.10.16:9092 0.0.0.0:* LISTEN 1001 4567030 1578552/io.nuki.0 tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 121 18163 983/asterisk tcp 0 0 0.0.0.0:6379 0.0.0.0:* LISTEN 118 27853 951/redis-server 0. tcp 0 0 127.0.0.1:36819 0.0.0.0:* LISTEN 122 28078 1398/plugin_start_l tcp 0 0 0.0.0.0:1080 0.0.0.0:* LISTEN 1000 4571119 1579931/nc tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 4567887 1578300/node-red tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 4573412 1578852/io.shelly.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 4577469 1579579/io.mqtt.0 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 4577470 1579579/io.mqtt.0 tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 4575614 1579963/io.sonoff.0 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 14491 1/init tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13275 958/sshd: /usr/sbin tcp6 0 0 :::8081 :::* LISTEN 1001 4569565 1577776/io.admin.0 tcp6 0 0 :::8086 :::* LISTEN 998 14644 989/influxd tcp6 0 0 :::9220 :::* LISTEN 1001 4574765 1580000/io.ocpp.0 tcp6 0 0 :::111 :::* LISTEN 0 18446 1/init tcp6 0 0 :::22 :::* LISTEN 0 13277 958/sshd: /usr/sbin tcp6 0 0 ::1:631 :::* LISTEN 0 3772412 1309329/cupsd tcp6 0 0 :::3000 :::* LISTEN 122 14713 1295/grafana udp 0 0 0.0.0.0:1905 0.0.0.0:* 1001 4579617 1578337/io.sonos.0 udp 0 0 0.0.0.0:4569 0.0.0.0:* 121 18180 983/asterisk udp 0 0 0.0.0.0:5060 0.0.0.0:* 121 18181 983/asterisk udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 4578392 1579434/io.chromeca udp 0 0 0.0.0.0:5353 0.0.0.0:* 111 25796 857/avahi-daemon: r udp 0 0 0.0.0.0:55448 0.0.0.0:* 111 25798 857/avahi-daemon: r udp 0 0 0.0.0.0:40505 0.0.0.0:* 121 15598 983/asterisk udp 0 1536 0.0.0.0:49055 0.0.0.0:* 1001 4576756 1579356/io.onkyo.0 udp 0 0 0.0.0.0:111 0.0.0.0:* 0 26678 1/init udp6 0 0 :::34917 :::* 111 25799 857/avahi-daemon: r udp6 0 0 :::5353 :::* 111 25797 857/avahi-daemon: r udp6 0 0 :::111 :::* 0 25624 1/init udp6 0 0 :::33604 :::* 121 15599 983/asterisk *** Log File - Last 25 Lines *** 2025-01-21 12:45:04.799 - info: alexa2.0 (1578990) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2025-01-21 12:45:04.799 - info: alexa2.0 (1578990) Device-type:A2ZOTUOF1IBEYI - Markus's Plantronics Voyager 5200 Series (Plantronics Voyager 5200 Series) (Plantronics Voyager 5200 Series) (Plantronics Voyager 5200 Series) (KINDLE_BOOKS,DREAM_TRAINING,I_HEART_RADIO,SLEEP,AUDIBLE,APPLE_MUSIC,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,AMAZON_MUSIC,SIRIUSXM,ADAPTIVE_LISTENING,DEEZER,TOUCH_INITIATED,PERSISTENT_CONNECTION,TIDAL,CHANGE_NAME,VOLUME_SETTING,TUNE_IN,MUSIC_SKILL,DEREGISTER_DEVICE,AUDIO_PLAYER,GOLDFISH,TIMERS_AND_ALARMS,MICROPHONE) 2025-01-21 12:45:06.832 - error: chromecast.0 (1579434) Gewaechshaus- Cannot get status: Error: Could not connect after 10 seconds 2025-01-21 12:45:07.005 - info: host.IOBROKER-MASTER instance system.adapter.mqtt.0 in version "6.1.2" started with pid 1579579 2025-01-21 12:45:07.030 - error: chromecast.0 (1579434) Gewächshaus- Cannot get status: Error: Could not connect after 10 seconds 2025-01-21 12:45:08.212 - info: mqtt.0 (1579579) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.1, js-controller: 7.0.6 2025-01-21 12:45:08.574 - info: mqtt.0 (1579579) Starting MQTT authenticated server on 0.0.0.0:1883 2025-01-21 12:45:08.575 - info: mqtt.0 (1579579) Starting MQTT-WebSocket authenticated server on 0.0.0.0:1884 2025-01-21 12:45:09.449 - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] connected with secret 1737459909442_5060 2025-01-21 12:45:11.224 - info: host.IOBROKER-MASTER instance system.adapter.hm-rpc.2 in version "2.0.2" started with pid 1579932 2025-01-21 12:45:14.215 - info: synology.0 (1579484) DSM 7 2025-01-21 12:45:14.216 - info: synology.0 (1579484) DSM 7 detected, set all to true 2025-01-21 12:45:14.469 - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] subscribes on "mqtt.0.linktap.up_cmd_ack" 2025-01-21 12:45:14.470 - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] subscribes on "mqtt.0.linktap.down_cmd" 2025-01-21 12:45:15.026 - info: host.IOBROKER-MASTER instance system.adapter.sonoff.0 in version "3.1.2" started with pid 1579963 2025-01-21 12:45:16.304 - info: sonoff.0 (1579963) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v20.18.1, js-controller: 7.0.6 2025-01-21 12:45:16.328 - info: sonoff.0 (1579963) Starting MQTT authenticated server on port 1885 2025-01-21 12:45:18.347 - info: alexa2.0 (1578990) Unknown Device, but enabling commands, Try it and report back if commands work. 2025-01-21 12:45:18.347 - info: alexa2.0 (1578990) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2025-01-21 12:45:18.348 - info: alexa2.0 (1578990) Device-type:A2N49KXGVA18AR - Markus' 7. Fire (REMINDERS,SPEECH_RECOGNIZER_USS,FIND_MY_TABLET,SUPPORTS_LOCALE,NO_TIME_ZONE_SETTING,CUSTOM_ALARM_TONE,ADAPTIVE_LISTENING,PERSISTENT_CONNECTION,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,ASX_TIME_ZONE,EARCONS,MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,SOUND_SETTINGS) 2025-01-21 12:45:19.500 - info: host.IOBROKER-MASTER instance system.adapter.ocpp.0 in version "0.12.5" (non-npm: foxriver76/ioBroker.ocpp) started with pid 1580000 2025-01-21 12:45:22.863 - info: sonoff.0 (1579963) Client [KUECHE] connected with secret 1737459922859_7118 2025-01-21 12:45:23.048 - info: host.IOBROKER-MASTER instance system.adapter.vis-2.0 in version "2.9.64" started with pid 1580385 2025-01-21 12:45:24.291 - info: vis-2.0 (1580385) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6 2025-01-21 12:45:24.507 - info: vis-2.0 (1580385) vis-2 license is OK.
Jemand ne Idee wo ich ansetzen soll ?
Danke & Grüße
Sunny -
@sunny9999
und noch die Summary :```bash ======================= SUMMARY ======================= v.2024-10-19 Static hostname: IOBROKER-MASTER Icon name: computer-vm Chassis: vm 🖴 Virtualization: vmware Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-30-amd64 Architecture: x86-64 Hardware Vendor: VMware, Inc. Hardware Model: VMware Virtual Platform Firmware Version: 6.00 Installation: vmware Kernel: x86_64 Userland: 64 bit Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 Display-Server: false Boot Target: multi-user.target Pending OS-Updates: 24 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 Recommended versions are nodejs 20.18.1 and npm 10.8.2 nodeJS installation is correct MEMORY: total used free shared buff/cache available Mem: 12G 6.6G 937M 1.4M 5.3G 5.9G Swap: 2.1G 524K 2.1G Total: 14G 6.6G 3.1G Active iob-Instances: 66 Upgrade policy: none ioBroker Core: js-controller 7.0.6 admin 7.4.10 ioBroker Status: iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Status admin and web instance: + system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 63205 States: 52733 Size of iob-Database: 46M /opt/iobroker/iobroker-data/objects.jsonl 22M /opt/iobroker/iobroker-data/objects.json.migrated 22M /opt/iobroker/iobroker-data/objects.json.bak.migrated 612K /opt/iobroker/iobroker-data/states.json 260K /opt/iobroker/iobroker-data/states.json.bak Operating System is the current Debian stable version codenamed 'bookworm'! =================== END OF SUMMARY ====================
=== Mark text until here for copying ===
Bring die Kiste insgesamt auf Stand. Da stehen noch Updates aus.
Danke für Feedback
Hab ich nun gemacht, keine Veränderung*** BASE SYSTEM *** Static hostname: IOBROKER-MASTER Icon name: computer-vm Chassis: vm 🖴 Virtualization: vmware Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-30-amd64 Architecture: x86-64 Hardware Vendor: VMware, Inc. Hardware Model: VMware Virtual Platform Firmware Version: 6.00 OS is similar to: model name : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz Docker : false Virtualization : vmware Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 13:33:43 up 26 min, 1 user, load average: 1.00, 0.92, 0.74 CPU threads: 16 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** TIME AND TIMEZONES *** Local time: Tue 2025-01-21 13:33:43 CET Universal time: Tue 2025-01-21 12:33:43 UTC RTC time: Tue 2025-01-21 12:33:43 Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': debian HOME=/home/debian GROUPS=debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth redis *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 12G 6.6G 3.4G 1.4M 2.8G 5.9G Swap: 2.1G 0B 2.1G Total: 14G 6.6G 5.6G Active iob-Instances: 66 11926 M total memory 6264 M used memory 705 M active memory 7311 M inactive memory 3276 M free memory 234 M buffer memory 2474 M swap cache 2043 M total swap 0 M used swap 2043 M free swap *** top - Table Of Processes *** top - 13:33:43 up 26 min, 1 user, load average: 1.00, 0.92, 0.74 Tasks: 370 total, 1 running, 369 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.0 us, 4.0 sy, 0.0 ni, 88.0 id, 0.0 wa, 0.0 hi, 4.0 si, 0.0 st MiB Mem : 11926.6 total, 3276.1 free, 6264.9 used, 2708.9 buff/cache MiB Swap: 2044.0 total, 2044.0 free, 0.0 used. 5661.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 5.8G 0 5.8G 0% /dev tmpfs tmpfs 1.2G 1.3M 1.2G 1% /run /dev/mapper/debian10--vg-root ext4 107G 40G 62G 39% / tmpfs tmpfs 5.9G 0 5.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda1 ext2 234M 186M 36M 84% /boot /dev/mapper/debian10--vg-tmp ext4 1.2G 328K 1.1G 1% /tmp /dev/mapper/debian10--vg-var ext4 6.4G 2.5G 3.5G 42% /var /dev/mapper/debian10--vg-home ext4 70G 11G 57G 16% /home 192.168.10.47:/volume1/IOBROKER nfs4 2.7T 1.6T 1.1T 60% /mnt/IOBROKERDATA 192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4 1.9T 672G 1.3T 35% /mnt/photosyno 192.168.10.47:/volume2/Backup nfs4 1.9T 672G 1.3T 35% /mnt/BACKUP tmpfs tmpfs 1.2G 60K 1.2G 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Jan 21 13:06:58 2025] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none. [Tue Jan 21 13:06:59 2025] EXT4-fs (dm-0): re-mounted. Quota mode: none. [Tue Jan 21 13:07:00 2025] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem [Tue Jan 21 13:07:00 2025] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none. [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none. [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none. [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/debian10--vg-root ext4 rw,relatime,errors=remount-ro |-/boot /dev/sda1 ext2 rw,relatime |-/tmp /dev/mapper/debian10--vg-tmp ext4 rw,relatime |-/var /dev/mapper/debian10--vg-var ext4 rw,relatime |-/home /dev/mapper/debian10--vg-home ext4 rw,relatime |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 |-/mnt/photosyno 192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 `-/mnt/BACKUP 192.168.10.47:/volume2/Backup nfs4 rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47 Files in neuralgic directories: /var: 2.5G /var/ 2.0G /var/lib 676M /var/lib/redis 537M /var/lib/grafana 532M /var/lib/grafana/plugins Archived and active journals take up 320.1M in the file system. /opt/iobroker/backups: 1.9G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 27G /opt/iobroker/iobroker-data/ 26G /opt/iobroker/iobroker-data/history 947M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/backup-objects 176M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 46M /opt/iobroker/iobroker-data/objects.jsonl 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' HINT: Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting: tcp HINT: Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting: tcp *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Hosts: IOBROKER-MASTER IOBROKER-MASTER (version: 7.0.6, hostname: IOBROKER-MASTER, alive, uptime: 1593) IOBROKER-SLAVE IOBROKER-SLAVE (version: 7.0.6, hostname: IOBROKER-SLAVE, alive, uptime: 709104) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: 8.8.3 nodejs modules from github: 17 +-- iobroker.dreame@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#beda212e3313d3477707fb5a8f52c7eefed9bfd7) +-- iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#9ec12d2f39898351be9ff6105043a408251e6174) +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#384363b87eaf0fa0b66ad2b54f2f51427dbc738d) +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606) +-- iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954) +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409) | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103) +-- iobroker.notificationforandroidtv@3.0.1 (git+ssh://git@github.com/DNAngelX/ioBroker.notificationforandroidtv.git#4f5ec5635498f83f87b68fd6d5e8371b1414b764) +-- iobroker.oasecontrol@0.0.2 (git+ssh://git@github.com/mr-suw/ioBroker.oasecontrol.git#d8f1584259393298b214d605c6934579860276b3) +-- iobroker.ocpp@0.12.5 (git+ssh://git@github.com/foxriver76/ioBroker.ocpp.git#6f0316acb6d3bacb9cfd82293590a9dd307d3d9d) | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550) +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#6b9894252659ebf564221d3119361a20c8f82d1d) +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#d201c1d92bbf728f16420c85804151b7dce29157) | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#221464afaa7db4eff676ab588786c40d35e8bad6) +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#be2791c1dfe1467e21e081ac1a6de1d36eac0e41) `-- paesslerag-node-red-contrib-prtg@0.0.0-development (git+ssh://git@github.com/PaesslerAG/node-red-contrib-prtg.git#8c7a526e6975caef38d3b3f384ba5125d888b103) Adapter State + system.adapter.adb.0 : adb : IOBROKER-MASTER - enabled + system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : IOBROKER-MASTER - enabled system.adapter.alexa2.0 : alexa2 : IOBROKER-MASTER - disabled system.adapter.alias-manager.0 : alias-manager : IOBROKER-MASTER - enabled + system.adapter.asterisk.0 : asterisk : IOBROKER-MASTER - enabled, port: 5038 + system.adapter.backitup.0 : backitup : IOBROKER-MASTER - enabled + system.adapter.backitup.1 : backitup : IOBROKER-SLAVE - enabled + system.adapter.chromecast.0 : chromecast : IOBROKER-MASTER - enabled system.adapter.daswetter.0 : daswetter : IOBROKER-MASTER - enabled system.adapter.device-watcher.0 : device-watcher : IOBROKER-MASTER - disabled system.adapter.devices.0 : devices : IOBROKER-MASTER - enabled + system.adapter.discovery.0 : discovery : IOBROKER-MASTER - enabled + system.adapter.dreame.0 : dreame : IOBROKER-MASTER - enabled system.adapter.dwd.0 : dwd : IOBROKER-MASTER - enabled + system.adapter.echarts.0 : echarts : IOBROKER-MASTER - enabled + system.adapter.email.0 : email : IOBROKER-MASTER - enabled system.adapter.feiertage.0 : feiertage : IOBROKER-MASTER - enabled system.adapter.flot.0 : flot : IOBROKER-MASTER - enabled + system.adapter.fullybrowser.0 : fullybrowser : IOBROKER-MASTER - enabled + system.adapter.gartenbewaesserung.0 : gartenbewaesserung : IOBROKER-MASTER - enabled + system.adapter.govee-app.0 : govee-app : IOBROKER-MASTER - enabled system.adapter.hass.0 : hass : IOBROKER-MASTER - disabled, port: 8123 system.adapter.heatingcontrol.0 : heatingcontrol : IOBROKER-MASTER - disabled + system.adapter.history.0 : history : IOBROKER-MASTER - enabled + system.adapter.hm-rega.0 : hm-rega : IOBROKER-MASTER - enabled + system.adapter.hm-rpc.0 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hue.0 : hue : IOBROKER-MASTER - enabled, port: 80 system.adapter.husq-automower.0 : husq-automower : IOBROKER-MASTER - disabled system.adapter.ical.0 : ical : IOBROKER-MASTER - enabled system.adapter.ical.1 : ical : IOBROKER-MASTER - enabled system.adapter.ical.2 : ical : IOBROKER-MASTER - enabled system.adapter.icons-material-png.0 : icons-material-png : IOBROKER-MASTER - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : IOBROKER-MASTER - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : IOBROKER-MASTER - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : IOBROKER-MASTER - enabled + system.adapter.influxdb.0 : influxdb : IOBROKER-MASTER - enabled, port: 8086 + system.adapter.javascript.0 : javascript : IOBROKER-MASTER - enabled system.adapter.kodi.0 : kodi : IOBROKER-MASTER - disabled, port: 9090 + system.adapter.linkeddevices.0 : linkeddevices : IOBROKER-MASTER - enabled system.adapter.linktap.0 : linktap : IOBROKER-MASTER - disabled system.adapter.linux-control.0 : linux-control : IOBROKER-MASTER - disabled system.adapter.mihome-vacuum.0 : mihome-vacuum : IOBROKER-MASTER - disabled, port: 54321 system.adapter.mqtt-client.0 : mqtt-client : IOBROKER-MASTER - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.mqtt.0 : mqtt : IOBROKER-MASTER - enabled, port: 1883, bind: 0.0.0.0 system.adapter.mytime.0 : mytime : IOBROKER-MASTER - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : IOBROKER-MASTER - disabled + system.adapter.node-red.0 : node-red : IOBROKER-MASTER - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER - enabled system.adapter.nuki-extended.0 : nuki-extended : IOBROKER-MASTER - disabled + system.adapter.nuki.0 : nuki : IOBROKER-MASTER - enabled + system.adapter.oasecontrol.0 : oasecontrol : IOBROKER-MASTER - enabled + system.adapter.ocpp.0 : ocpp : IOBROKER-MASTER - enabled, port: 9220 + system.adapter.onkyo.0 : onkyo : IOBROKER-MASTER - enabled system.adapter.onvif.0 : onvif : IOBROKER-MASTER - disabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.ping.0 : ping : IOBROKER-MASTER - enabled + system.adapter.pushover.0 : pushover : IOBROKER-MASTER - enabled system.adapter.reolink.0 : reolink : IOBROKER-MASTER - disabled system.adapter.robonect.0 : robonect : IOBROKER-MASTER - disabled system.adapter.samsung.0 : samsung : IOBROKER-MASTER - disabled + system.adapter.samsung_tizen.0 : samsung_tizen : IOBROKER-MASTER - enabled, port: 8002 + system.adapter.sayit.0 : sayit : IOBROKER-MASTER - enabled + system.adapter.scenes.0 : scenes : IOBROKER-MASTER - enabled + system.adapter.scheduler.0 : scheduler : IOBROKER-MASTER - enabled + system.adapter.shelly.0 : shelly : IOBROKER-MASTER - enabled, port: 1882, bind: 0.0.0.0 system.adapter.shuttercontrol.0 : shuttercontrol : IOBROKER-MASTER - disabled + system.adapter.simple-api.0 : simple-api : IOBROKER-MASTER - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.smartcontrol.0 : smartcontrol : IOBROKER-MASTER - enabled system.adapter.smartmeter.0 : smartmeter : IOBROKER-SLAVE - disabled + system.adapter.smartthings.0 : smartthings : IOBROKER-MASTER - enabled + system.adapter.sonoff.0 : sonoff : IOBROKER-MASTER - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : IOBROKER-MASTER - enabled + system.adapter.sourceanalytix.0 : sourceanalytix : IOBROKER-MASTER - enabled + system.adapter.synology.0 : synology : IOBROKER-MASTER - enabled, port: 5000 + system.adapter.tahoma.0 : tahoma : IOBROKER-MASTER - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : IOBROKER-MASTER - enabled + system.adapter.telegram.0 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 system.adapter.telegram.2 : telegram : IOBROKER-MASTER - disabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : IOBROKER-MASTER - enabled + system.adapter.text2command.1 : text2command : IOBROKER-MASTER - enabled + system.adapter.time-switch.0 : time-switch : IOBROKER-MASTER - enabled + system.adapter.trashschedule.0 : trashschedule : IOBROKER-MASTER - enabled + system.adapter.trashschedule.1 : trashschedule : IOBROKER-MASTER - enabled + system.adapter.unifi.0 : unifi : IOBROKER-MASTER - enabled system.adapter.upnp.0 : upnp : IOBROKER-MASTER - disabled + system.adapter.vaillant.0 : vaillant : IOBROKER-MASTER - enabled + system.adapter.vis-2.0 : vis-2 : IOBROKER-MASTER - enabled system.adapter.vis-bars.0 : vis-bars : IOBROKER-MASTER - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : IOBROKER-MASTER - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : IOBROKER-MASTER - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : IOBROKER-MASTER - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : IOBROKER-MASTER - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : IOBROKER-MASTER - enabled system.adapter.vis-icontwo.0 : vis-icontwo : IOBROKER-MASTER - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : IOBROKER-MASTER - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : IOBROKER-MASTER - enabled system.adapter.vis-justgage.0 : vis-justgage : IOBROKER-MASTER - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : IOBROKER-MASTER - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : IOBROKER-MASTER - enabled system.adapter.vis-metro.0 : vis-metro : IOBROKER-MASTER - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : IOBROKER-MASTER - enabled system.adapter.vis-weather.0 : vis-weather : IOBROKER-MASTER - enabled system.adapter.vis.0 : vis : IOBROKER-MASTER - enabled + system.adapter.vw-connect.0 : vw-connect : IOBROKER-MASTER - enabled system.adapter.weatherunderground.0 : weatherunderground : IOBROKER-MASTER - enabled + system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : IOBROKER-MASTER - enabled + system.adapter.whatsapp-cmb.1 : whatsapp-cmb : IOBROKER-MASTER - enabled + system.adapter.yahka.0 : yahka : IOBROKER-MASTER - enabled + system.adapter.zigbee.1 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.24:6638 + system.adapter.zigbee.2 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.39:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.asterisk.0 : asterisk : IOBROKER-MASTER - enabled, port: 5038 + system.adapter.hm-rpc.0 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : IOBROKER-MASTER - enabled, port: 0 + system.adapter.hue.0 : hue : IOBROKER-MASTER - enabled, port: 80 + system.adapter.influxdb.0 : influxdb : IOBROKER-MASTER - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : IOBROKER-MASTER - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : IOBROKER-MASTER - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.ocpp.0 : ocpp : IOBROKER-MASTER - enabled, port: 9220 + system.adapter.samsung_tizen.0 : samsung_tizen : IOBROKER-MASTER - enabled, port: 8002 + system.adapter.shelly.0 : shelly : IOBROKER-MASTER - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : IOBROKER-MASTER - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : IOBROKER-MASTER - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.synology.0 : synology : IOBROKER-MASTER - enabled, port: 5000 + system.adapter.telegram.0 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : IOBROKER-MASTER - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.1 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.24:6638 + system.adapter.zigbee.2 : zigbee : IOBROKER-MASTER - enabled, port: tcp://192.168.10.39:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "adb" : 0.0.7 , installed 0.0.7 Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "alarm" : 3.6.7 , installed 3.6.7 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "alias-manager": 2.0.0 , installed 2.0.0 Adapter "apcups" : 4.0.2 , installed 4.0.2 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "birthdays" : 3.1.0 , installed 3.1.0 Adapter "chromecast" : 4.0.0 , installed 4.0.0 Adapter "daswetter" : 3.2.2 , installed 3.2.2 Adapter "device-watcher": 2.12.1 , installed 2.12.1 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "doorio" : 2.1.5 , installed 2.1.5 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "email" : 1.3.1 , installed 1.3.1 Adapter "feiertage" : 1.2.1 , installed 1.2.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 3.0.12 , installed 3.0.12 Adapter "hass" : 1.4.0 , installed 1.4.0 Adapter "heatingcontrol": 2.12.13 , installed 2.12.13 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "hue" : 3.13.1 , installed 3.13.1 Adapter "ical" : 1.16.1 , installed 1.16.1 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "kodi" : 3.1.0 , installed 3.1.0 Adapter "linkeddevices": 1.5.5 , installed 1.5.5 Adapter "linktap" : 1.0.1 , installed 1.0.1 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "mihome-vacuum": 4.2.0 , installed 4.2.0 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "mpd" : 2.2.0 , installed 2.2.0 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "mqtt-client" : 2.1.0 , installed 2.1.0 Adapter "mytime" : 1.2.2 , installed 1.2.2 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "node-red" : 5.2.1 , installed 5.2.1 Adapter "nuki" : 2.0.0 , installed 2.0.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "ocpp" : 0.12.5 , installed 0.12.5 Adapter "onkyo" : 2.1.2 , installed 2.1.2 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 4.1.0 , installed 4.1.0 Adapter "reolink" : 1.1.2 , installed 1.1.2 Adapter "robonect" : 1.4.2 , installed 1.4.2 Adapter "samsung" : 0.6.1 , installed 0.6.1 Adapter "samsung_tizen": 1.1.0 , installed 1.1.0 Adapter "sayit" : 5.0.0 , installed 5.0.0 Adapter "scenes" : 3.2.3 , installed 3.2.3 Adapter "scheduler" : 1.4.1 , installed 1.4.1 Adapter "shelly" : 8.5.1 , installed 8.5.1 Adapter "shuttercontrol": 1.8.5 , installed 1.8.5 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "tahoma" : 0.10.4 , installed 0.10.4 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.9.64 , installed 2.9.64 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "volumio" : 0.2.0 , installed 0.2.0 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "webcal" : 1.3.10 , installed 1.3.10 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.0.3 , installed 1.0.3 Adapter "zigbee" : 1.10.14 , installed 1.10.14 Objects and States Please stand by - This may take a while Objects: 63205 States: 52732 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:33323 0.0.0.0:* LISTEN 1001 24277 2442/io.yahka.0 tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 17057 930/cupsd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15141 939/sshd: /usr/sbin tcp 0 0 127.0.0.1:33131 0.0.0.0:* LISTEN 122 17241 1292/plugin_start_l tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 18444 1/init tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 27194 2128/io.mqtt.0 tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 28460 2053/io.sonoff.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 13844 2038/io.shelly.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 27193 2128/io.mqtt.0 tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 21901 1529/node-red tcp 0 0 127.0.0.1:34661 0.0.0.0:* LISTEN 1001 24273 2442/io.yahka.0 tcp 0 0 0.0.0.0:1080 0.0.0.0:* LISTEN 1000 68725 11916/nc tcp 0 0 127.0.0.1:43911 0.0.0.0:* LISTEN 1001 24285 2442/io.yahka.0 tcp 0 0 127.0.0.1:43205 0.0.0.0:* LISTEN 1001 24294 2442/io.yahka.0 tcp 0 0 127.0.0.1:36455 0.0.0.0:* LISTEN 1001 24289 2442/io.yahka.0 tcp 0 0 127.0.0.1:44151 0.0.0.0:* LISTEN 1001 24303 2442/io.yahka.0 tcp 0 0 127.0.0.1:36207 0.0.0.0:* LISTEN 1001 24281 2442/io.yahka.0 tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 121 28146 963/asterisk tcp 0 0 127.0.0.1:5037 0.0.0.0:* LISTEN 1001 19169 2707/adb tcp 0 0 192.168.10.16:9092 0.0.0.0:* LISTEN 1001 19901 1914/io.nuki.0 tcp 0 0 192.168.10.16:9292 0.0.0.0:* LISTEN 1001 25115 1869/io.hm-rpc.2 tcp 0 0 192.168.10.16:2001 0.0.0.0:* LISTEN 1001 13710 1727/io.hm-rpc.0 tcp 0 0 192.168.10.16:2010 0.0.0.0:* LISTEN 1001 37946 1787/io.hm-rpc.1 tcp 0 0 0.0.0.0:6379 0.0.0.0:* LISTEN 118 19670 931/redis-server 0. tcp6 0 0 :::41519 :::* LISTEN 1001 40486 2442/io.yahka.0 tcp6 0 0 :::22 :::* LISTEN 0 15143 939/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 17428 1/init tcp6 0 0 :::9220 :::* LISTEN 1001 36385 2502/io.ocpp.0 tcp6 0 0 :::3000 :::* LISTEN 122 24918 1258/grafana tcp6 0 0 ::1:631 :::* LISTEN 0 17056 930/cupsd tcp6 0 0 :::35335 :::* LISTEN 1001 40478 2442/io.yahka.0 tcp6 0 0 :::43197 :::* LISTEN 1001 40480 2442/io.yahka.0 tcp6 0 0 :::44713 :::* LISTEN 1001 40482 2442/io.yahka.0 tcp6 0 0 :::45939 :::* LISTEN 1001 40476 2442/io.yahka.0 tcp6 0 0 :::37833 :::* LISTEN 1001 40484 2442/io.yahka.0 tcp6 0 0 :::46697 :::* LISTEN 1001 40488 2442/io.yahka.0 tcp6 0 0 :::8086 :::* LISTEN 998 17110 971/influxd tcp6 0 0 :::8087 :::* LISTEN 1001 38247 2729/io.simple-api. tcp6 0 0 :::8082 :::* LISTEN 1001 34203 2412/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 36917 1374/io.admin.0 tcp6 0 0 :::40845 :::* LISTEN 1001 40474 2442/io.yahka.0 udp 0 0 0.0.0.0:111 0.0.0.0:* 0 16891 1/init udp 0 0 0.0.0.0:51051 0.0.0.0:* 121 13469 963/asterisk udp 0 0 192.168.10.16:1905 0.0.0.0:* 1001 63040 1895/io.sonos.0 udp 0 0 0.0.0.0:52826 0.0.0.0:* 111 18587 851/avahi-daemon: r udp 0 0 0.0.0.0:4569 0.0.0.0:* 121 28163 963/asterisk udp 0 0 0.0.0.0:5060 0.0.0.0:* 121 28164 963/asterisk udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 25088 1802/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 111 18585 851/avahi-daemon: r udp6 0 0 :::111 :::* 0 26635 1/init udp6 0 0 :::35104 :::* 121 13470 963/asterisk udp6 0 0 :::59932 :::* 111 18588 851/avahi-daemon: r udp6 0 0 :::5353 :::* 111 18586 851/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-01-21 13:20:51.628 - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 6309 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-01-21 13:25:49.011 - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 in version "2.8.5" started with pid 7985 2025-01-21 13:25:51.730 - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 7985 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-01-21 13:30:00.031 - info: host.IOBROKER-MASTER instance system.adapter.ical.2 in version "1.16.1" started with pid 9704 2025-01-21 13:30:04.038 - info: host.IOBROKER-MASTER instance system.adapter.ical.1 in version "1.16.1" started with pid 9721 2025-01-21 13:30:07.722 - info: host.IOBROKER-MASTER instance system.adapter.ical.2 having pid 9704 terminated with code 0 (NO_ERROR) 2025-01-21 13:30:08.047 - info: host.IOBROKER-MASTER instance system.adapter.ical.0 in version "1.16.1" started with pid 9736 2025-01-21 13:30:12.063 - info: host.IOBROKER-MASTER instance system.adapter.ical.1 having pid 9721 terminated with code 0 (NO_ERROR) 2025-01-21 13:30:15.573 - info: host.IOBROKER-MASTER instance system.adapter.ical.0 having pid 9736 terminated with code 0 (NO_ERROR) 2025-01-21 13:30:38.014 - info: host.IOBROKER-MASTER instance system.adapter.daswetter.0 in version "3.2.2" started with pid 9763 2025-01-21 13:30:44.182 - info: host.IOBROKER-MASTER instance system.adapter.daswetter.0 having pid 9763 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-01-21 13:30:44.183 - info: javascript.0 (1455) script.js.common.Wetterstation.Wetterdatengraph: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.0.alive' 2025-01-21 13:30:49.012 - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 in version "2.8.5" started with pid 9778 2025-01-21 13:30:52.031 - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 9778 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-01-21 13:31:59.859 - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252 2025-01-21 13:32:12.356 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin 2025-01-21 13:32:14.080 - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252 2025-01-21 13:32:19.539 - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252 2025-01-21 13:32:30.923 - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252 2025-01-21 13:32:57.848 - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252 2025-01-21 13:33:27.904 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin 2025-01-21 13:33:30.434 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 javascript 2025-01-21 13:33:30.436 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin 2025-01-21 13:33:33.790 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin 2025-01-21 13:33:35.331 - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
v.2024-10-19Static hostname: IOBROKER-MASTER
Chassis: vm 🖴
Firmware Version: 6.00Installation: vmware
Kernel: x86_64
Userland: 64 bit
User-ID: 1000
Boot Target: multi-user.targetPending OS-Updates: 0
Pending iob updates: 0Nodejs-Installation:
/usr/bin/npm 10.8.2
/usr/bin/npx 10.8.2
/usr/bin/corepack 0.29.4Recommended versions are nodejs 20.18.1 and npm 10.8.2
nodeJS installation is correctMEMORY:
Mem: 12G 6.6G 3.0G 1.4M 3.3G 5.9G
Swap: 2.1G 0B 2.1G
Total: 14G 6.6G 5.1GActive iob-Instances: 66
Upgrade policy: noneioBroker Core: js-controller 7.0.6
admin 7.4.10ioBroker Status: iobroker is running on this host.
Objects type: redis
States type: redisStatus admin and web instance:
- system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin
- system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin
- system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin
Objects: 63205
States: 52732Size of iob-Database:
260K /opt/iobroker/iobroker-data/states.json.bakOperating System is the current Debian stable version codenamed 'bookworm'!
Was immer mörderlange dauert sind den Objekt Tab zu laden....aber der Rest auch, mindestens ne Minute oder zwei pro tab, wenn er überhaupt aufgeht.....
Noch ne Idee ?
GrüßeSunny
@sunny9999 sagte in Massive Performance Probleme beim GUI Zugriff:
dann hast du zu viele Nodes geöffnet.
Pass auf, dass dir die Ansicht nicht einfriert.@sunny9999 sagte in Massive Performance Probleme beim GUI Zugriff:
was zeigt denn die Browser Konsole?
Browser Console zeigt nur :iobroker.admin@7.0.25 socket.io.js:1 [2025-01-21T13:49:43.058Z] Try to connect
Was für nen Slave schleppst Du mit rum?
Welche Hardware?Web und Webcal benutzen den gleichen Port .
Da mal verschiedene auswählen. -
@haselchen
@haselchen
Danke für den Hinweis...
Sag mal bitte wo ich den Port für Webcal ändern kann ? In der Instanz steht nichts ....
Danke für nen Tip !
Sunny
