    4. Tuya. 3.17.0
    Tuya. 3.17.0
    • O
      oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
      @apollon77
      Keine Netzwerksegmentierung. Ich brauche die nicht, sodass das kein Priorität hat.
        apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 naja kannst am Ende mal Debug log an machen dann siehst Du ob er die geräte findet oder ob er was findet aber nicht zuordnen kann ...
        • O
          @apollon77
          Hoffe, das reicht:
          2025-01-09 09:58:35.866  - debug: tuya.0 (6579) bf37eczusfmpzprl: Init device with data (after merge): {"data":{"accessType":1,"activeTime":1733524097,"baseAttribute":128,"cloudOnline":false,"communication":{"communicationModes":[{"pv":"","type":8},{"pv":"","type":0}],"connectionStatus":0,"dataModel":1,"mqttTopicAttr":1},"dataPointInfo":{"dpMaxTime":1733524097194,"dpName":{},"dps":{"1":false},"dpsTime":{"1":1733524097194}},"devAttribute":0,"devId":"bf37eczusfmpzprl","devKey":"","deviceTopo":{},"iconUrl":"https://images.tuyaeu.com/smart/icon/ay1553676862206wvxjp/88217e1500025e67acc2007d12d53e93.png","lat":"52.04","localKey":"1/9?*[<agEIafXVL","lon":"10.31","mac":"","meta":{},"name":"Sengled Wi-Fi Plug","otaInfo":{"otaModuleMap":{},"otaUpgradeModes":[0],"supportAuto":true},"ownerId":"151918892","productId":"pwogbugv2zhvbvv9","runtimeEnv":"prod","timezoneId":"Europe/Berlin","uuid":"bf37eczusfmpzprl","virtual":false,"virtualExperience":false,"dpName":{},"groudId":151918892,"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"productKey":"pwogbugv2zhvbvv9","schemaExt":[],"version":"","dpCodes":{"switch_1":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}},"errorcount":0}
          2025-01-09 09:58:35.892  - debug: tuya.0 (6579) bf37eczusfmpzprl: Create device objects if not exist
          2025-01-09 09:58:35.893  - debug: tuya.0 (6579) bf37eczusfmpzprl: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch","native":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}]
          2025-01-09 09:58:35.893  - debug: tuya.0 (6579) bf37eczusfmpzprl Register onChange for 1
          2025-01-09 09:58:36.190  - info: tuya.0 (6579) bf37eczusfmpzprl: Connect locally to device
          2025-01-09 09:58:36.192  - debug: tuya.0 (6579) bf37eczusfmpzprl: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=1/9?*[<agEIafXVL
          2025-01-09 09:58:36.193  - debug: tuya.0 (6579) bf37eczusfmpzprl: None of the discovered devices matches :-(
            @ofbeqnpolkkl6mby5e13 Neeeee ... Weil das der start ist wo er noch nichts discovered hat ... von daher ... bissl später meistens
            • O
              @apollon77
              2025-01-09 09:58:41.122  - debug: tuya.0 (6579) bf37eczusfmpzprl: Use following Schema for pwogbugv2zhvbvv9: {"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"schemaExt":[]}
              2025-01-09 09:58:41.124  - debug: tuya.0 (6579) bf37eczusfmpzprl: Init device with data (after merge): {"data":{"accessType":1,"activeTime":1733524097,"baseAttribute":128,"cloudOnline":false,"communication":{"communicationModes":[{"pv":"","type":8},{"pv":"","type":0}],"connectionStatus":0,"dataModel":1,"mqttTopicAttr":1},"dataPointInfo":{"dpMaxTime":1733524097194,"dpName":{},"dps":{"1":false},"dpsTime":{"1":1733524097194}},"devAttribute":0,"devId":"bf37eczusfmpzprl","devKey":"","deviceTopo":{},"iconUrl":"https://images.tuyaeu.com/smart/icon/ay1553676862206wvxjp/88217e1500025e67acc2007d12d53e93.png","lat":"52.04","localKey":"1/9?*[<agEIafXVL","lon":"10.31","mac":"","meta":{},"name":"Sengled Wi-Fi Plug","otaInfo":{"otaModuleMap":{},"otaUpgradeModes":[0],"supportAuto":true},"ownerId":"151918892","productId":"pwogbugv2zhvbvv9","runtimeEnv":"prod","timezoneId":"Europe/Berlin","uuid":"bf37eczusfmpzprl","virtual":false,"virtualExperience":false,"dpName":{},"groudId":151918892,"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"productKey":"pwogbugv2zhvbvv9","schemaExt":[],"version":"","dpCodes":{"switch_1":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}},"errorcount":0,"localKey":"1/9?*[<agEIafXVL","name":"Sengled Wi-Fi Plug","dpIdList":[1],"objectsInitialized":true,"noLocalConnection":false}
              2025-01-09 09:58:41.135  - debug: tuya.0 (6579) bf37eczusfmpzprl: Create device objects if not exist
              2025-01-09 09:58:41.137  - debug: tuya.0 (6579) bf37eczusfmpzprl: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch","native":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}]
              2025-01-09 09:58:41.139  - debug: tuya.0 (6579) bf37eczusfmpzprl Register onChange for 1
              2025-01-09 09:58:41.140  - debug: tuya.0 (6579) Initial cloud device sync done
                @ofbeqnpolkkl6mby5e13 Was soll mir das Log zeigen?
                • O
                  @apollon77
                  Keine Ahnung, mehr gibt das Log für das Gerät halt nicht her. Vergessen wir das.
                    @ofbeqnpolkkl6mby5e13 Da sollte mehr kommen ... sonst hast du ein DNS problem 🙂 Aber ggf sind das generellere logs ohne die Devcie ID
                    padrino 1 Reply Last reply Reply Quote 0
                    • padrino
                      padrino Most Active @apollon77 last edited by padrino
                      also, ich kann nur sagen, dass ich eine recht alte Hama "Birne" habe, die heute Nacht einfach aufgehört hat über den 20/switch_led DP zu funktionieren.🤷
                      Neustart und neue Synchronisation mit Cloud und DP/Baum löschen hat nix gebracht.
                      Hab' nun die Beta gefunden und installiert, und taddaa, läuft wieder - auch einfach so. 😌
                      Ich sag da mal danke. 😃
                      Neuschwansteini 1 Reply Last reply Reply Quote 1
                      • Neuschwansteini
                        Neuschwansteini @padrino last edited by
                        @padrino
                        Ja, hatte ich auch schon, und seit Anfang des Jahres gehen viele Devices auch einfach so offline..
                        Fazit: im laufe des Jahres fliegt der Tuya Kram raus..
                        • padrino
                          padrino Most Active @Neuschwansteini last edited by
                          @ilovegym sagte in Tuya. 3.17.0:
                          @padrino
                          Ist doch irgendwie seltsam, dass die offline gehen, wenn sie von der Cloud entkoppelt sind, da kann doch "von außen" keiner Schuld sein, gibt ja auch kein Firmware Update...
                            apollon77 @padrino last edited by
                            @padrino Naja oder auch nicht ... es gab einige Geräte die ständig abgestürzt sind wenn Cloud weg war. Am Ende wissen die das ja nicht und versuchen ständig in die Cloud zu verbinden ... denke das sowas ggf auch issues triggert weil die glaube ich in so einem Umfeld nicht getstet werden 🙂
                            • Neuschwansteini
                              Neuschwansteini @apollon77 last edited by
                              @apollon77
                              das kann gut sein, seitdem ich meine wieder der Cloud zugaenglich gemacht habe, sind sie oefters online.. oder funktionieren sogar, wenn sie als offline angezeigt werden... versteh das manchmal nicht.. aber ich muss ja nicht alles wissen .. "D
                                michihorn @apollon77 last edited by
                                @apollon77 Hallöchen ich habe eine Installation bei der wird das TUYA Kennwort immer wieder vergessen.
                                Also das Feld "Kennwort" ist dann einfach leer.
                                Michael
                                Neuschwansteini 1 Reply Last reply Reply Quote 0
                                • Neuschwansteini
                                  Neuschwansteini @michihorn last edited by
                                  @michihorn
                                  Hello, prima, meine Glaskugel sagt, dass da dann was nicht stimmt.
                                  Fuer mal in der Console "iob diag" aus, und poste die Ausgabe in Code-Tags, bitte.
                                    michihorn @Neuschwansteini last edited by
                                    @ilovegym 😉 da hat die Glaskugel recht, leider kann ich den Fehler aktuell nicht präsentieren. Seit Samstag läuft der Adapter. Das bedeutet nicht, das alle OK ist, kann sein, dass in ein Paar Tagen ohne Hinweis, das Kennwort wieder weg ist. Hatte ich nun schon ein paar mal. Ich habe jetzt erstmal im LOG "silly" eingestellt. Mal schauen ob das was zu shen ist.
                                    • Neuschwansteini
                                      @michihorn
                                      Hi, nein, von silly hat keiner was gesagt.
                                      Erstmal ein iob diag, damit man mal weiss, um was es ueberhaupt geht.
                                      Wenn der Adapter geht, muss das pw ja gespeichert sein, sofern du ihn auch neu gestartet hast.
                                      Vielleicht wird es nur nicht im Admin angezeigt. Aber dazu braucht man erstmal ein iob diag.
                                        michihorn @Neuschwansteini last edited by michihorn
                                        @ilovegym Aktuell habe ich keine Probleme, der IOB steht in meinem Ferienhaus, wenn ich Freitag dorthin fahre, werden über GEOFANCY einige Aktionen von TUYA Geräten erwartet. Letzten Freitag war es auch so, IOB hat meine Anreise erkannt, Tuya-Thermostat sollte hochregeln, Auf dem Parkplatz angekommen, sollte die Gartenbeleuchtung und Flurbeleuchtung angehen. IOB hat auch die entsprechenden Tuya Geräte angesprochen, aber es erfolgte keine Auslösung weil das Cloud-Passwort verschwunden war. Anbei ein Bild so wie es gerade aussieht.
                                        ```bash
                                        Script v.2025-02-02
                                        *** BASE SYSTEM ***
                                           Static hostname: iobroker-pi
                                                 Icon name: computer
                                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        OS is similar to: debian
                                        Model           : Raspberry Pi 4 Model B Rev 1.5
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 32 bit
                                        Systemuptime and Load:
                                         13:02:09 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        ~ Under-voltage has occurred
                                        ~ Arm frequency capping has occurred
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Mon 2025-02-10 13:02:09 CET
                                                   Universal time: Mon 2025-02-10 12:02:09 UTC
                                                         RTC time: n/a
                                                        Time zone: Europe/Amsterdam (CET, +0100)
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        gthrn
                                        HOME=/home/gthrn
                                        GROUPS=gthrn adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            7.9G        1.6G        4.5G        1.0M        1.8G        6.2G
                                        Swap:            99M          0B         99M
                                        Total:          8.0G        1.6G        4.6G
                                        Active iob-Instances:   21
                                                 7862 M total memory
                                                 1566 M used memory
                                                 1658 M active memory
                                                 1521 M inactive memory
                                                 4482 M free memory
                                                  147 M buffer memory
                                                 1665 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        top - 13:02:10 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                                        Tasks: 166 total,   1 running, 165 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   7862.2 total,   4482.4 free,   1566.7 used,   1813.1 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6164.5 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        140 CRITICAL ERRORS DETECTED!
                                        Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G   11G   46G  19% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                                        /dev/sda1      vfat      255M   51M  205M  20% /boot
                                        tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
                                        [Fri Jan 24 21:30:22 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DE:B0:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7239adf-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                        [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): write access will be enabled during recovery
                                        [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): orphan cleanup on readonly fs
                                        [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): 3 orphan inodes deleted
                                        [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): recovery complete
                                        [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Fri Jan 24 21:30:26 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Fri Jan 24 21:30:30 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET  SOURCE    FSTYPE OPTIONS
                                        /       /dev/sda2 ext4   rw,noatime
                                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        1.4G    /var/
                                        763M    /var/log
                                        761M    /var/log/journal/3f7e426fbacf414fbfbc4f1541fa25b4
                                        451M    /var/cache
                                        Archived and active journals take up 760.2M in the file system.
                                        /opt/iobroker/backups:
                                        1.3G    /opt/iobroker/backups/
                                        4.0K    /opt/iobroker/backups/zigbee_0
                                        /opt/iobroker/iobroker-data:
                                        588M    /opt/iobroker/iobroker-data/
                                        424M    /opt/iobroker/iobroker-data/files
                                        158M    /opt/iobroker/iobroker-data/files/admin.admin
                                        157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                                        15M     /opt/iobroker/iobroker-data/objects.jsonl
                                        14M     /opt/iobroker/iobroker-data/states.jsonl
                                        7.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js
                                        7.4M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.3514cab0.chunk.js.map
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        HINT:
                                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.18.1
                                        /usr/bin/node           v20.18.1
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.4
                                        nodejs:
                                          Installed: 20.18.1-1nodesource1
                                          Candidate: 20.18.1-1nodesource1
                                          Version table:
                                         *** 20.18.1-1nodesource1 600
                                                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             20.18.0-1nodesource1 600
                                             20.17.0-1nodesource1 600
                                             20.16.0-1nodesource1 600
                                             20.15.1-1nodesource1 600
                                             20.15.0-1nodesource1 600
                                             20.14.0-1nodesource1 600
                                             20.13.1-1nodesource1 600
                                             20.13.0-1nodesource1 600
                                             20.12.2-1nodesource1 600
                                             20.12.1-1nodesource1 600
                                             20.12.0-1nodesource1 600
                                             20.11.1-1nodesource1 600
                                             20.11.0-1nodesource1 600
                                             20.10.0-1nodesource1 600
                                             20.9.0-1nodesource1 600
                                             20.8.1-1nodesource1 600
                                             20.8.0-1nodesource1 600
                                             20.7.0-1nodesource1 600
                                             20.6.1-1nodesource1 600
                                             20.6.0-1nodesource1 600
                                             20.5.1-1nodesource1 600
                                             20.5.0-1nodesource1 600
                                             20.4.0-1nodesource1 600
                                             20.3.1-1nodesource1 600
                                             20.3.0-1nodesource1 600
                                             20.2.0-1nodesource1 600
                                             20.1.0-1nodesource1 600
                                             20.0.0-1nodesource1 600
                                             12.22.12~dfsg-1~deb11u5 500
                                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        GTHRN-pi            GTHRN-pi (version: 7.0.6, hostname: GTHRN-pi      , alive, uptime: 1438305)
                                        Core adapters versions
                                        js-controller:  7.0.6
                                        admin:          7.4.21
                                        javascript:     8.9.1
                                        nodejs modules from github:     4
                                        +-- iobroker.device-watcher@2.12.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#fb49d0b7d1af160318904a143bcea7cab85764c4)
                                        +-- iobroker.telegram@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#b4cfff1fa1dadc8a33905f86208d3b5319c1e585)
                                        +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#007d61f5c03c1150dcf67d40f5967e651caf776c)
                                        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : GTHRN-pi                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.backitup.0               : backitup              : GTHRN-pi                                 -  enabled, compact disabled
                                          system.adapter.daikin.0                 : daikin                : GTHRN-pi                                 - disabled, compact disabled
                                          system.adapter.daswetter.0              : daswetter             : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.device-watcher.0         : device-watcher        : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.espresense.0             : espresense            : GTHRN-pi                                 -  enabled, compact disabled
                                          system.adapter.feiertage.0              : feiertage             : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.history.0                : history               : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.hue.0                    : hue                   : GTHRN-pi                                 -  enabled, compact disabled, port: 443
                                          system.adapter.icons-material-png.0     : icons-material-png    : GTHRN-pi                                 - disabled
                                          system.adapter.icons-material-svg.0     : icons-material-svg    : GTHRN-pi                                 - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : GTHRN-pi                                 - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : GTHRN-pi                                 - disabled
                                        + system.adapter.iot.0                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.iot.1                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.iot.2                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.javascript.0             : javascript            : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.mqtt-client.2            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3075
                                        + system.adapter.mqtt.2                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3075, bind: 0.0.0.0
                                        + system.adapter.ping.0                   : ping                  : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.ring.0                   : ring                  : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.telegram.0               : telegram              : GTHRN-pi                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.tuya.0                   : tuya                  : GTHRN-pi                                 -  enabled, compact disabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GTHRN-pi                                 - disabled
                                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : GTHRN-pi                                 -  enabled, compact disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GTHRN-pi                                 - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : GTHRN-pi                                 - disabled, compact disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : GTHRN-pi                                 -  enabled, compact disabled
                                          system.adapter.vis-keyboard.0           : vis-keyboard          : GTHRN-pi                                 - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : GTHRN-pi                                 - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : GTHRN-pi                                 - disabled
                                          system.adapter.vis.0                    : vis                   : GTHRN-pi                                 -  enabled, compact disabled
                                        + system.adapter.web.0                    : web                   : GTHRN-pi                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.zigbee.0                 : zigbee                : GTHRN-pi                                 -  enabled, compact disabled, port: tcp://192.168.188.120:6638
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): beta
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Used repository: beta
                                        Adapter    "admin"        : 7.4.21   , installed 7.4.21
                                        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
                                        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                        Adapter    "espresense"   : 0.6.3    , installed 0.6.3
                                        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                        Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                                        Adapter    "hue"          : 3.14.1   , installed 3.14.1
                                        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                        Adapter    "iot"          : 3.4.5    , installed 3.4.5
                                        Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                                        Controller "js-controller": 7.0.6    , installed 7.0.6
                                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                        Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
                                        Adapter    "ping"         : 1.7.9    , installed 1.7.9
                                        Adapter    "ring"         : 6.3.0    , installed 6.3.0
                                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                        Adapter    "socketio"     : 7.0.0    , installed 6.7.1  [Updatable]
                                        Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                                        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                                        Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                        Adapter    "web"          : 6.3.1    , installed 6.3.1
                                        Adapter    "ws"           : 3.0.1    , installed 2.6.2  [Updatable]
                                        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                                        Objects and States
                                        Objects:        6671
                                        States:         5793
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 25
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:3075            0.0.0.0:*               LISTEN      1001       15868      1189/io.mqtt.2
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14125      489/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12785      489/iobroker.js-con
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1889       517/sshd: /usr/sbin
                                        tcp6       0      0 :::3001                 :::*                    LISTEN      1001       16749      1222/io.fullybrowse
                                        tcp6       0      0 :::3030                 :::*                    LISTEN      1001       2653440    9688/io.espresense.
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18441      1239/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2652026    9576/io.admin.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1891       517/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1906       695/dhcpcd
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13907      373/avahi-daemon: r
                                        udp        0      0 0.0.0.0:50523           0.0.0.0:*                           108        13909      373/avahi-daemon: r
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2659021    10456/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2659022    10456/io.tuya.0
                                        udp6       0      0 :::546                  :::*                                0          115745     695/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        13908      373/avahi-daemon: r
                                        udp6       0      0 :::39322                :::*                                108        13910      373/avahi-daemon: r
                                        2025-02-10 13:00:53.082  - info: daswetter.0 (18166) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                        2025-02-10 13:01:07.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:01:11.150  - info: daswetter.0 (18166) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2025-02-10 13:01:11.670  - info: daswetter.0 (18166) cleaned everything up...
                                        2025-02-10 13:01:11.689  - info: host.GTHRN-pi instance system.adapter.daswetter.0 having pid 18166 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-02-10 13:01:22.032  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:01:37.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:01:52.034  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:02:00.052  - info: javascript.0 (28533) script.js.SYSTEM.Temp_CPU: 38.4°C
                                        2025-02-10 13:02:07.035  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:02:22.037  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:02:37.042  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:02:56.454  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:03:07.041  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:03:07.163  - info: admin.0 (9576) <== Disconnect system.user.admin from ::ffff:192.168.178.196 admin
                                        2025-02-10 13:03:16.659  - info: admin.0 (9576) ==> Connected system.user.admin from ::ffff:192.168.178.196
                                        2025-02-10 13:03:22.044  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                        2025-02-10 13:03:24.803  - warn: host.GTHRN-pi Could not check for new OS updates: Command failed: sudo apt list --upgradeable
                                        WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                        E: Problem renaming the file /var/cache/apt/pkgcache.bin.2vsJAl to /var/cache/apt/pkgcache.bin - rename (2: No such file or directory)
                                        W: You may want to run apt-get update to correct these problems
                                        E: The package cache file is corrupted
                                        Latzi Neuschwansteini Thomas Braun U 4 Replies Last reply Reply Quote 0
                                        • Latzi
                                          Latzi @michihorn last edited by
                                          @michihorn
                                          du hast da einige Adapter von github installiert (unter anderem tuya), den gibt es auch im lastest:
                                          github:	3.17.0
                                          latest:	3.17.0 for 32 days
                                          stable:	3.16.0 for 5 months
                                          Von github nur nach Absprache mit dem Entwickler installieren 😉
                                          • Neuschwansteini
                                            @michihorn
                                            Danke, jetzt kann man Hilfe leisten. Ich vermute mal zu 90% liegt das am aktuell von dir installierten Admin-Adapter V7.4.21, der hat seit ner Zeit n Bug bei der Eingabe in die Felder.. gibt auch n Issue zu.
                                            Bei Einsatz von Beta Versionen besser immer die Issues dazu lesen, oder, in der Gartenhuette, erst gar nicht einsetzen.
                                            Da lieber mit den Versionen auf Stable bleiben, die heissen ja nicht zufaellig Stable..
                                            31.7k
                                            79.8k
                                            47
                                            2310
