    4. [Test] Adapter ioBroker.mihome-vacuum v5.x
    • haselchen
      haselchen Most Active @dirkhe last edited by
      @dirkhe
      mihome-vacuum.1
      	2025-01-22 18:32:34.392	info	select standard vacuum protocol....
      mihome-vacuum.1
      	2025-01-22 18:32:34.390	warn	No Answer for DeviceModel use old one
      mihome-vacuum.1
      	2025-01-22 18:32:34.384	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
      mihome-vacuum.1
      	2025-01-22 18:32:26.359	info	IOT disabled, delete state
      Ich weiss nicht ob das gut oder schlecht ist
        dirkhe Developer last edited by
        @haselchen da bräuchte ich doch etwas mehr debug log. Aber die meldung mit den 10 minuten kommt ab und zu,dann ist er blockiert, kommt, wenn man öfter hintereinander startet..
        Wäre aber mal interessant, ob er jetzt das richtige model und den manager auswählt
          dirkhe Developer @D3ltoroxp last edited by
          @d3ltoroxp für deinen fall sollte 5.1 und 5.2 egal sein, einfach mal in die einstellungen gehen un den tokenneu abrufen, speichern und gut
          • haselchen
            haselchen Most Active @dirkhe last edited by haselchen
            @dirkhe
            mihome-vacuum.1
            	2025-01-22 21:55:32.710	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 21:55:22.707	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 21:55:21.640	debug	Startup: setGetConsumable Answer: false
            mihome-vacuum.1
            	2025-01-22 21:55:21.639	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:19.638	debug	Message= {"id":10,"method":"get_consumable"}
            mihome-vacuum.1
            	2025-01-22 21:55:19.637	debug	Startup: setGetCleanSummary Answer: false
            mihome-vacuum.1
            	2025-01-22 21:55:19.636	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:17.635	debug	Message= {"id":9,"method":"get_clean_summary"}
            mihome-vacuum.1
            	2025-01-22 21:55:17.634	debug	Startup: Delete getMultiMapsList
            mihome-vacuum.1
            	2025-01-22 21:55:17.634	debug	Startup: getMultiMapsList Answer: true
            mihome-vacuum.1
            	2025-01-22 21:55:17.632	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:15.631	debug	Message= {"id":8,"method":"get_multi_maps_list"}
            mihome-vacuum.1
            	2025-01-22 21:55:15.630	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:13.628	debug	Message= {"id":7,"method":"get_sound_volume"}
            mihome-vacuum.1
            	2025-01-22 21:55:13.627	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:11.627	debug	Message= {"id":6,"method":"get_network_info"}
            mihome-vacuum.1
            	2025-01-22 21:55:11.626	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:11.397	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 21:55:10.120	info	settest next timer: not available
            mihome-vacuum.1
            	2025-01-22 21:55:09.625	debug	Message= {"id":5,"method":"get_status"}
            mihome-vacuum.1
            	2025-01-22 21:55:09.625	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 21:55:09.624	debug	Create State done!
            mihome-vacuum.1
            	2025-01-22 21:55:09.623	debug	Create State for map: loadMap
            mihome-vacuum.1
            	2025-01-22 21:55:09.623	debug	Create State for map: mapURL
            mihome-vacuum.1
            	2025-01-22 21:55:09.623	debug	Create State for map: mapStatus
            mihome-vacuum.1
            	2025-01-22 21:55:09.623	debug	Create State for map: actualMap
            mihome-vacuum.1
            	2025-01-22 21:55:09.622	debug	Create State for map: map64
            mihome-vacuum.1
            mihome-vacuum.1
            	2025-01-22 21:55:09.611	debug	Create State for Queue: queue
            mihome-vacuum.1
            	2025-01-22 21:55:09.403	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            mihome-vacuum.1
            	2025-01-22 21:55:09.382	info	select standard vacuum protocol....
            mihome-vacuum.1
            	2025-01-22 21:55:09.381	debug	DeviceModel set to: rockrobo.vacuum.v1
            mihome-vacuum.1
            	2025-01-22 21:55:09.381	warn	No Answer for DeviceModel use model from Config
            mihome-vacuum.1
            	2025-01-22 21:55:09.381	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
            mihome-vacuum.1
            	2025-01-22 21:55:09.380	debug	Get Device data..4
            mihome-vacuum.1
            	2025-01-22 21:55:09.380	debug	GETMODELFROMAPI:Data: {}
            mihome-vacuum.1
            	2025-01-22 21:55:09.379	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:07.379	debug	Message= {"id":4,"method":"miIO.info"}
            mihome-vacuum.1
            	2025-01-22 21:55:07.378	debug	Get Device data..3
            mihome-vacuum.1
            	2025-01-22 21:55:07.378	debug	GETMODELFROMAPI:Data: {}
            mihome-vacuum.1
            	2025-01-22 21:55:07.377	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:05.376	debug	Message= {"id":3,"method":"miIO.info"}
            mihome-vacuum.1
            	2025-01-22 21:55:05.376	debug	Get Device data..2
            mihome-vacuum.1
            	2025-01-22 21:55:05.376	debug	GETMODELFROMAPI:Data: {}
            mihome-vacuum.1
            	2025-01-22 21:55:05.375	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:03.375	debug	Message= {"id":2,"method":"miIO.info"}
            mihome-vacuum.1
            	2025-01-22 21:55:03.374	debug	Get Device data..1
            mihome-vacuum.1
            	2025-01-22 21:55:03.374	debug	GETMODELFROMAPI:Data: {}
            mihome-vacuum.1
            	2025-01-22 21:55:03.373	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
            mihome-vacuum.1
            	2025-01-22 21:55:01.371	debug	Message= {"id":1,"method":"miIO.info"}
            mihome-vacuum.1
            	2025-01-22 21:55:01.367	debug	Get Device data..0
            mihome-vacuum.1
            	2025-01-22 21:55:01.367	debug	GETMODELFROMAPI:Data: {}
            mihome-vacuum.1
            	2025-01-22 21:55:01.366	debug	Time difference between Mihome Vacuum and ioBroker: -2 sec
            mihome-vacuum.1
            	2025-01-22 21:55:01.365	debug	your device is not connected, but this could be temporary
            mihome-vacuum.1
            	2025-01-22 21:55:01.364	debug	MAIN: Connected to device, try to get model..
            mihome-vacuum.1
            	2025-01-22 21:55:01.363	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 21:55:01.345	debug	server started on 0.0.0.0:53422
            mihome-vacuum.1
            	2025-01-22 21:55:01.342	info	IOT disabled, delete state
            mihome-vacuum.1
            	2025-01-22 21:55:01.338	debug	MIIO: Config: ip:192.168.2.54 token: XXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 21:55:01.337	debug	Create State for deviceInfounsupported
            mihome-vacuum.1
            	2025-01-22 21:55:01.337	debug	Create State for deviceInfowifi_signal
            mihome-vacuum.1
            	2025-01-22 21:55:01.337	debug	Create State for deviceInfofw_ver
            mihome-vacuum.1
            	2025-01-22 21:55:01.336	debug	Create State for deviceInfomodel
            mihome-vacuum.1
            	2025-01-22 21:55:01.336	debug	Create State for deviceInfomac
            mihome-vacuum.1
            	2025-01-22 21:55:01.335	debug	Create State for deviceInfo
            mihome-vacuum.1
            	2025-01-22 21:55:01.297	debug	load Map creator... true
            mihome-vacuum.1
            	2025-01-22 21:55:01.242	info	starting. Version 5.2.0 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.2, js-controller: 7.0.6
            smartmeter.0
            	2025-01-22 21:55:00.928	info	Received 5 values, 2 updated
            mihome-vacuum.1
            	2025-01-22 21:55:00.904	debug	Plugin sentry Do not initialize Plugin (enabled=false)
            host.IOBroker
            	2025-01-22 21:54:58.284	info	instance system.adapter.mihome-vacuum.1 in version "5.2.0" (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) started with pid 11508
            host.IOBroker
            	2025-01-22 21:54:54.780	info	instance system.adapter.mihome-vacuum.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            mihome-vacuum.1
            	2025-01-22 21:54:54.629	info	terminating
            host.IOBroker
            	2025-01-22 21:54:54.165	info	stopInstance system.adapter.mihome-vacuum.1 send kill signal
            mihome-vacuum.1
            	2025-01-22 21:54:54.131	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            mihome-vacuum.1
            	2025-01-22 21:54:54.130	info	terminating
            mihome-vacuum.1
            	2025-01-22 21:54:54.128	error	Socket Close
            mihome-vacuum.1
            	2025-01-22 21:54:54.126	info	Got terminate signal TERMINATE_YOURSELF
            host.IOBroker
            	2025-01-22 21:54:54.119	info	stopInstance system.adapter.mihome-vacuum.1 (force=false, process=true)
            mihome-vacuum.1
            	2025-01-22 21:54:05.345	info	create state for carpet_mode
            mihome-vacuum.1
            	2025-01-22 21:54:04.847	info	settest next timer: not available
            mihome-vacuum.1
            	2025-01-22 21:54:03.677	info	select standard vacuum protocol....
            mihome-vacuum.1
            	2025-01-22 21:54:03.452	info	IOT disabled, delete state
            mihome-vacuum.1
            	2025-01-22 21:54:03.271	info	starting. Version 5.2.0 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.2, js-controller: 7.0.6
            mihome-vacuum.1
            	2025-01-22 22:06:24.738	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 22:06:22.983	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:06:12.929	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:06:04.562	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":48}
            mihome-vacuum.1
            	2025-01-22 22:06:04.561	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":48}
            mihome-vacuum.1
            	2025-01-22 22:06:04.552	debug	Message= {"id":48,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:06:04.552	debug	MIIO RECIVE: {"result":[100],"id":47}
            mihome-vacuum.1
            	2025-01-22 22:06:04.551	debug	MIIO MESSAGE TESTING: {"result":[100],"id":47}
            mihome-vacuum.1
            	2025-01-22 22:06:04.542	debug	Message= {"id":47,"method":"get_sound_volume"}
            mihome-vacuum.1
            	2025-01-22 22:06:04.541	debug	MIIO RECIVE: {"result":"unknown_method","id":46}
            mihome-vacuum.1
            	2025-01-22 22:06:04.541	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":46}
            mihome-vacuum.1
            	2025-01-22 22:06:04.519	debug	Message= {"id":46,"method":"get_network_info"}
            mihome-vacuum.1
            	2025-01-22 22:06:04.519	debug	setGetStatus {"msg_ver":8,"msg_seq":4306,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":100,"dnd_enabled":false,"error_text":"No error"}
            mihome-vacuum.1
            	2025-01-22 22:06:04.518	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":4306,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":45}
            mihome-vacuum.1
            	2025-01-22 22:06:04.517	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":8,"msg_seq":4306,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":45}
            mihome-vacuum.1
            	2025-01-22 22:06:04.511	debug	Message= {"id":45,"method":"get_status"}
            mihome-vacuum.1
            	2025-01-22 22:06:04.511	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 22:06:02.896	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:52.778	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:44.410	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":44}
            mihome-vacuum.1
            	2025-01-22 22:05:44.409	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":44}
            mihome-vacuum.1
            	2025-01-22 22:05:44.401	debug	Message= {"id":44,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:05:44.400	debug	MIIO RECIVE: {"result":[100],"id":43}
            mihome-vacuum.1
            	2025-01-22 22:05:44.400	debug	MIIO MESSAGE TESTING: {"result":[100],"id":43}
            mihome-vacuum.1
            	2025-01-22 22:05:44.392	debug	Message= {"id":43,"method":"get_sound_volume"}
            mihome-vacuum.1
            	2025-01-22 22:05:44.392	debug	MIIO RECIVE: {"result":"unknown_method","id":42}
            mihome-vacuum.1
            	2025-01-22 22:05:44.391	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":42}
            mihome-vacuum.1
            	2025-01-22 22:05:44.383	debug	Message= {"id":42,"method":"get_network_info"}
            mihome-vacuum.1
            	2025-01-22 22:05:44.383	debug	setGetStatus {"msg_ver":8,"msg_seq":4305,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":100,"dnd_enabled":false,"error_text":"No error"}
            mihome-vacuum.1
            	2025-01-22 22:05:44.382	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":4305,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":41}
            mihome-vacuum.1
            	2025-01-22 22:05:44.381	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":8,"msg_seq":4305,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":41}
            mihome-vacuum.1
            	2025-01-22 22:05:44.351	debug	Message= {"id":41,"method":"get_status"}
            mihome-vacuum.1
            	2025-01-22 22:05:44.351	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 22:05:42.770	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:32.766	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:24.258	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":40}
            mihome-vacuum.1
            	2025-01-22 22:05:24.257	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":40}
            mihome-vacuum.1
            	2025-01-22 22:05:24.245	debug	Message= {"id":40,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:05:24.244	debug	MIIO RECIVE: {"result":[100],"id":39}
            mihome-vacuum.1
            	2025-01-22 22:05:24.242	debug	MIIO MESSAGE TESTING: {"result":[100],"id":39}
            mihome-vacuum.1
            	2025-01-22 22:05:24.227	debug	Message= {"id":39,"method":"get_sound_volume"}
            mihome-vacuum.1
            	2025-01-22 22:05:24.227	debug	MIIO RECIVE: {"result":"unknown_method","id":38}
            mihome-vacuum.1
            	2025-01-22 22:05:24.226	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":38}
            mihome-vacuum.1
            	2025-01-22 22:05:24.219	debug	Message= {"id":38,"method":"get_network_info"}
            mihome-vacuum.1
            	2025-01-22 22:05:24.214	debug	setGetStatus {"msg_ver":8,"msg_seq":4303,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":100,"dnd_enabled":false,"error_text":"No error"}
            mihome-vacuum.1
            	2025-01-22 22:05:24.212	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":4303,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":37}
            mihome-vacuum.1
            	2025-01-22 22:05:24.210	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":8,"msg_seq":4303,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":37}
            mihome-vacuum.1
            	2025-01-22 22:05:24.201	debug	Message= {"id":37,"method":"get_status"}
            mihome-vacuum.1
            	2025-01-22 22:05:24.201	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 22:05:22.761	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:12.756	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:05:04.108	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":36}
            mihome-vacuum.1
            	2025-01-22 22:05:04.107	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":36}
            mihome-vacuum.1
            	2025-01-22 22:05:04.102	debug	Message= {"id":36,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:05:04.101	debug	MIIO RECIVE: {"result":[100],"id":35}
            mihome-vacuum.1
            	2025-01-22 22:05:04.100	debug	MIIO MESSAGE TESTING: {"result":[100],"id":35}
            mihome-vacuum.1
            	2025-01-22 22:05:04.094	debug	Message= {"id":35,"method":"get_sound_volume"}
            mihome-vacuum.1
            	2025-01-22 22:05:04.094	debug	MIIO RECIVE: {"result":"unknown_method","id":34}
            mihome-vacuum.1
            	2025-01-22 22:05:04.093	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":34}
            mihome-vacuum.1
            	2025-01-22 22:05:04.086	debug	Message= {"id":34,"method":"get_network_info"}
            mihome-vacuum.1
            	2025-01-22 22:05:04.085	debug	setGetStatus {"msg_ver":8,"msg_seq":4302,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":100,"dnd_enabled":false,"error_text":"No error"}
            mihome-vacuum.1
            	2025-01-22 22:05:04.085	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":4302,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":33}
            mihome-vacuum.1
            	2025-01-22 22:05:04.084	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":8,"msg_seq":4302,"state":8,"battery":100,"clean_time":2563,"clean_area":39122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":33}
            mihome-vacuum.1
            	2025-01-22 22:05:04.075	debug	Message= {"id":33,"method":"get_status"}
            mihome-vacuum.1
            	2025-01-22 22:05:04.075	debug	get params for stock Vacuum
            mihome-vacuum.1
            	2025-01-22 22:05:02.752	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:04:52.739	debug	Receive <<< Helo <<< XXXXXXXXXXXXXXXXXXXXXXXX
            mihome-vacuum.1
            	2025-01-22 22:04:44.068	debug	MIIO RECIVE: {"result":[490025,7159347500,247,[1736598090,1736018814,1735965366,1735746583,1734718562,1734282135,1733656267,1733121809,1732517220,1732361436,1731839286,1731244422,1731239693,1730481150,1730029564,1729430057,1728824048,1728222781,1727621652,1727006656]],"id":32}
            mihome-vacuum.1
            	2025-01-22 22:04:44.067	debug	MIIO MESSAGE TESTING: {"result":[490025,7159347500,247,[1736598090,1736018814,1735965366,1735746583,1734718562,1734282135,1733656267,1733121809,1732517220,1732361436,1731839286,1731244422,1731239693,1730481150,1730029564,1729430057,1728824048,1728222781,1727621652,1727006656]],"id":32}
            mihome-vacuum.1
            	2025-01-22 22:04:44.057	debug	Message= {"id":32,"method":"get_clean_summary"}
            mihome-vacuum.1
            	2025-01-22 22:04:43.941	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":31}
            mihome-vacuum.1
            	2025-01-22 22:04:43.940	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":31}
            mihome-vacuum.1
            	2025-01-22 22:04:43.921	debug	Message= {"id":31,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:04:43.921	info	create state for carpet_mode
            mihome-vacuum.1
            	2025-01-22 22:04:43.920	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":30}
            mihome-vacuum.1
            	2025-01-22 22:04:43.919	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":30}
            mihome-vacuum.1
            	2025-01-22 22:04:43.916	info	settest next timer: not available
            mihome-vacuum.1
            	2025-01-22 22:04:43.908	debug	Message= {"id":30,"method":"get_carpet_mode"}
            mihome-vacuum.1
            	2025-01-22 22:04:43.907	debug	Startup: Delete setGetConsumable
            mihome-vacuum.1
            	2025-01-22 22:04:43.907	debug	Startup: setGetConsumable Answer: true
            mihome-vacuum.1
            	2025-01-22 22:04:43.906	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":490051,"side_brush_work_time":490051,"filter_work_time":490051,"sensor_dirty_time":490025}],"id":29}
            mihome-vacuum.1
            	2025-01-22 22:04:43.900	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":490051,"side_brush_work_time":490051,"filter_work_time":490051,"sensor_dirty_time":490025}],"id":29}
            mihome-vacuum.1
            	2025-01-22 22:04:43.883	debug	Message= {"id":29,"method":"get_consumable"}
            mihome-vacuum.1
            	2025-01-22 22:04:43.883	debug	Startup: Delete setGetCleanSummary
            mihome-vacuum.1
            	2025-01-22 22:04:43.882	debug	Startup: setGetCleanSummary Answer: true
              dirkhe Developer @haselchen last edited by
              @haselchen der ist jetzt aber connected. Als Hintergrund (daran habe ich übrigens nichts geändert), er verbindet sich mit dem sauger, da nach fragt der adapter den sauger, was ef denn für einer ist. Da wartet er auf eine Antwort, das macht er bis zu 5 mal. Wenn der robbi da nicht antwortet, was durchaus al vorkommt, nimmt er die daten, die er vorher mal ausgelesen hat.
              • haselchen
                @dirkhe
                Der Hinweis bezüglich des manuellen Hinzufügen des Models kommt nur in V5.10.
                In V5.2.0 , haste ja gesehen, kommt dieser Hinweis nicht mehr.
                  @haselchen genau, das war ja auch sinn und zweck der 5.2. Wenn der robbi sich mit seinem model meldst, egal ob direkt von ihm selber, der config oder aus dem vorhandenen datenpunkt, nimmt er den ersten teil, in deinem fall rockrobo und weist es jetzt dem roborock manager zu, das hatte er in der 5.1 nicht getan
                  • D3ltoroxp
                    @dirkhe Hab jetzt mal auf die 5.2 geupdated. Aber er holt sich hier nichts automatisch. Es kommt nach wie vor
                    HTTP error when getting token cookie{}
                    Im Wiki steht, man solle sich mal auf der Webseite anmelden, hab ich getan, hat leider nichts gebracht. Muss ich meinen Token vllt neu besorgen irgendwie ? Der Token sieht auch komisch aus, lauter Rechtecke, V's, W's.
                    • haselchen
                      haselchen Most Active @D3ltoroxp last edited by
                      @d3ltoroxp
                      Ich frage es trotzdem, über Github upgedatet?
                      Screenshot mal bitte machen von der Adapterkachel.
                      • D3ltoroxp
                        D3ltoroxp @haselchen last edited by
                        @haselchen Nope, ist ja zumindest heute normal im Beta Branch.
                          @d3ltoroxp in die settings gehen, einmal geräte laden, modell auswählen, speichern
                          • D3ltoroxp
                            D3ltoroxp @dirkhe last edited by
                            @dirkhe Genau da geht es bei mir nicht weiter, wenn ich auf Get Device gehe kommt eben dieser HTTP Error.
                              @d3ltoroxp da hat sich aber nichts verändert... lösche mal den token vorher raus, obwohl das eigentlich nichts bringt. Dein passwort und der server passt alles noch?
                              • D3ltoroxp
                                D3ltoroxp @dirkhe last edited by D3ltoroxp
                                @dirkhe Habe grade noch mal Benutzer und PW eingetragen. Server -> Germany.
                                Leider kommt auch nichts nach dem löschen des Tokens.
                                  @d3ltoroxp hab jetzt auch gerade den Eintrag auf der github seite gesehen. Da scheint es probleme mit der xiaomi cloud bei dir zu geben. Ggf. Werbeblocker an?
                                  Wenn all stricke reissen, gehe in dein backup vor dem update und suche mal in der json nach dem token,der steht da im klartext drin. Den kannst du dann manuall eingeben
                                  • D3ltoroxp
                                    @dirkhe Ohej, das geht schon eine weile nicht mehr meine ich. Ist mir nur halt letztens aufgefallen, das die Instanz nicht grün ist. Uff da muss ich mal schauen. Ist ja nen Linux System, wüssten nicht das da Werbeblocker aktiv sind. Oder gilt das für den Browser den man benutzt um auf das Webinterface von io zu gelangen ?
                                      @d3ltoroxp schau mal hier https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/438
                                      florian1984 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                                      closed HTTP error when getting token cookie{} => manual Login not helps.... #438
                                      • D3ltoroxp
                                        @dirkhe Hm dann muss ich das mal probieren. Beim Anmelden über die Seite direkt, hab ich davon nichts gesehen. Muss ich eben noch mal schauen.
                                          @d3ltoroxp ich dachte, du höttest vlt pihole oder so laufen.
                                          Der token wird erst ab der 5.0 verschlüsselt, davor war er halt unverschlüsselt gespeichert. Wenn der sauger aber schon länger nicht mehr geht, nützt dir der alte token auch nichts
                                          • D3ltoroxp
                                            @dirkhe Ich weiß nicht warum, es ging jetzt. Hatte mich noch mal auf MiHome angemeldet, dann bin ich dort auf Kontoeinstellungen und dort auf eine anderen Seite gelandet, dort musste ich noch mal mein PW eingeben. Bin jetzt einfach noch mal spaßhalber auf Get Device und dann hats kurz gedauert. Hat das Token und den richtigen Robo ausgewählt. 😊
                                            31.7k
                                            79.8k
                                            921
