    4. Frigate Adapter für ioBroker
      denjo last edited by
      @juergi habe auch ein ähnliches Problem
      frigate.0
      2025-01-02 15:43:07.978	error	Error: ENOENT: no such file or directory, unlink '/tmp/7340aa6d-7072-445f-a302-0918ff174a5d.mp4'
      frigate.0
      2025-01-02 15:43:07.961	warn	AxiosError: Request failed with status code 500
      frigate.0
      2025-01-02 15:43:07.960	warn	Cannot reach server. You can ignore this after restarting the frigate server.
      frigate.0
      2025-01-02 15:43:07.960	warn	prepareEventNotification error from http://192.168.178.125:5000/api/events/1735828977.316611-bdkh4u/clip.mp4
      frigate.0
      2025-01-02 15:43:01.984	error	Error: ENOENT: no such file or directory, unlink '/tmp/97d5dbc4-aaa0-421a-b851-4b0562f093af.mp4'
      frigate.0
      2025-01-02 15:43:01.923	warn	AxiosError: Request failed with status code 500
      frigate.0
      2025-01-02 15:43:01.923	warn	Cannot reach server. You can ignore this after restarting the frigate server.
      frigate.0
      2025-01-02 15:43:01.907	warn	prepareEventNotification error from http://192.168.178.125:5000/api/events/1735828975.047765-w2kc93/clip.mp4
        tombox @juergi last edited by
        @juergi bitte api port 5000 anstatt ui port 8971 verwenden
          ExMatador @tritor last edited by
          @tritor
          Das sieht bei mir in JavaScript so aus
          var fs = require('fs');
          // strip off the data: url prefix to get just the base64-encoded bytes
          var data = img.replace(/^data:image\/\w+;base64,/, "");
          var buf = Buffer.from(data, 'base64');
          var file = 'c:/tmp/' + cam + '.jpg';
          fs.writeFile(file, buf, function(err) {
              if (err) { console.error(err); }
              else {
                   sendTo("pushover", {
                   message: cam + ': Person erkannt', // mandatory - your text message
                   title: 'ioBroker', // optional - your message's title, otherwise your app's name is used
                   sound: 'Magic', // optional - the name of one of the sounds supported by device clients to override the user's default sound choice
                   // pushover, bike, bugle, cashregister, classical, cosmic, falling,
                   // gamelan, incoming, intermission, magic, mechanical, pianobar, siren,
                   // spacealarm, tugboat, alien, climb, persistent, echo, updown, none
                   priority: 0, // optional (-2, -1, 0, 1, 2)
                   // -2 to always send as a quiet notification,
                   // 1 to display as high-priority and bypass the user's quiet hours, or
                   // 2 to also require confirmation from the user
                   file: file, // optional - attachment
                   // token: 'API/KEY token', // optional - add other than configurated token to the call
                   // url: , // optional - a supplementary URL to show with your message
                   // url_title: , // optional - a title for your supplementary URL, otherwise just the URL is shown
                   // device: , // optional - your user's device name to send the message directly to that device, rather than all of the user's devices
                   // timestamp // optional - a Unix timestamp of your message's date and time to display to the user, rather than the time your message is received by our API
          img ist der Inhalt vom snapshot.
          Gruß ExMatador
          • wendy2702
            wendy2702 last edited by
            Ich lasse mir per Frigate schon länger die Snapshots bei Personen/PKW Erkennung senden.
            Seit 2 Tagen auch die Clips.
            Jetzt kommen die Snapshots an wie erwartet mit dem richtigen "format, will heissen rechteckig. Die Clips allerdings werden in die höhe gezogen und in der breite gestaucht so dass es quadratisch ist.
            Oben der Clip, unten der Snapshot
            Kommt das aus dem Adapter oder von Frigate selber?
            Wenn ich mir die passende Aufzeichnung am PC anschaue ist die nicht quadratisch.
              tombox @wendy2702 last edited by
              @wendy2702 Ist das Telegram? Was ist wenn du sie auf das Handy runterlädst
              • wendy2702
                wendy2702 @tombox last edited by wendy2702
                @tombox hi,
                Ja ist Telegram.
                Habe mal eins gespeichert, da sieht es normal aus. Was ich merkwürdig finde: hatte vorher ein einfaches Script laufen das mit den Clip nach Bewegungsmelder Aktivität erstellt und sendet. Das wird in Telegram immer richtig dargestellt. Nur das aus Frigate nicht.
                Ne Idee ob man das irgendwie beeinflussen kann?
                  @wendy2702 wie hast du es in dem Skript gesendet
                  • wendy2702
                    @tombox Ist ein Blockly:
                    Mit dem Befehl zum Umwandeln in ein File:
                    ffmpeg -rtsp_transport tcp -y -i rtsp://mxe:ixr18@192.168.178.209:554/h264Preview_01_sub -t 10 -f mp4 -vcodec libx264 -pix_fmt yuvj420p -an -vf scale=w=672:h=384:force_original_aspect_ratio=decrease -r 20 /opt/iobroker/out2.mp4
                      @wendy2702 Die Datei erzeugt ja frigate in den Optionen kannst du dort ffmpeg Optionen mitgeben aber bei mir sieht es soweit gut aus
                      • wendy2702
                        @tombox Werde mal schauen was ich in Frigate anpassen kann. Wie geschrieben hat es mich nur gewundert das die Aufzeichnung nöch das richtige format hat.
                          BenjaminCz last edited by
                          Hallo Zusammen,
                          ich habe auch den Adapter Ausporbiert verbindung ist anscheinend da Datenpunkte sind geholt allerdings bekomme ich immer diese fehler Meldungen. Was mache ich falsch ?
                          frigate.0
                          	2025-03-17 20:58:46.518	error	Error: connect ECONNREFUSED 192.168.178.12:50000
                          frigate.0
                          	2025-03-17 20:58:46.518	warn	createCameraDevices error from http://192.168.178.12:50000/api/config
                          frigate.0
                          	2025-03-17 20:58:46.516	info	Create Device information and fetch Event History
                          frigate.0
                          	2025-03-17 20:57:44.216	error	Error: connect ECONNREFUSED 192.168.178.12:50000
                          frigate.0
                          	2025-03-17 20:57:44.215	warn	createCameraDevices error from http://192.168.178.12:50000/api/config
                          frigate.0
                          	2025-03-17 20:57:44.214	info	Create Device information and fetch Event History
                          frigate.0
                          	2025-03-17 20:56:41.920	error	Error: connect ECONNREFUSED 192.168.178.12:50000
                          frigate.0
                          	2025-03-17 20:56:41.920	warn	createCameraDevices error from http://192.168.178.12:50000/api/config
                          frigate.0
                          	2025-03-17 20:56:41.917	info	Create Device information and fetch Event History
                            ewc @BenjaminCz last edited by
                            @benjamincz
                            Ändere mal den Port auf 5000 ☝
                              BenjaminCz @ewc last edited by
                              @ewc Danke. Habe ich Probiert dann kommt gleiche fehlermeldung mit 5000
                                BenjaminCz @ewc last edited by BenjaminCz
                                @ewc Mein IOBroker läuft in HTTPS liegt es evtl. daran ?
                                Das ist meine Config
                                Nachtrag:
                                und meine Frigate Config sieht so aus:
                                  crunchip Forum Testing Most Active @BenjaminCz last edited by
                                  @benjamincz sagte in Frigate Adapter für ioBroker:
                                  Sollte nicht
                                  https://forum.iobroker.net/post/1018878
                                    BenjaminCz @crunchip last edited by
                                    @crunchip ok danke. Ich bin dann Ratlos. Habe alles Probiert localhost ip adresse von iobroker.... immer der gleiche fehler
                                    • wendy2702
                                      wendy2702 @BenjaminCz last edited by
                                      @benjamincz Läuft davon etwas in einem Docker Container?
                                        BenjaminCz @wendy2702 last edited by BenjaminCz
                                        @wendy2702 Nein läuft alles auf Proxmox als LXC Container (Debian 12).
                                        Plattform: linux
                                        RAM: 32 GB
                                        Node.js: v20.19.0
                                        NPM: 10.8.2
                                        Admin 7.4.10
                                        • wendy2702
                                          @benjamincz Kann es sein das dein Port 5000 bereits belegt ist?
                                          Bekommt man z.B. mit
                                          iob diag
                                          Raus
                                            @wendy2702
                                            also anscheinend nicht. Ich habe auch schon andere Port nummer Probiert. Ich wollte eigentlich nur das ich per Gotify eine benachrichtigung mit Bild bekomme sobald eine Person oder Object erfasst wurde. Alternative wäre der MQTT adapter.
                                            Adapter State
                                            + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                            + system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
                                              system.adapter.alias-manager.0          : alias-manager         : IOBroker                                 -  enabled
                                            + system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
                                            + system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
                                              system.adapter.dwd.0                    : dwd                   : IOBroker                                 -  enabled
                                            + system.adapter.email.0                  : email                 : IOBroker                                 -  enabled
                                            + system.adapter.frigate.0                : frigate               : IOBroker                                 -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : IOBroker                                 -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
                                            + system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker                                 -  enabled, port: 18701
                                            + system.adapter.hs100.0                  : hs100                 : IOBroker                                 -  enabled
                                            + system.adapter.hue-extended.0           : hue-extended          : IOBroker                                 -  enabled
                                            + system.adapter.hue-extended.1           : hue-extended          : IOBroker                                 -  enabled
                                              system.adapter.ical.0                   : ical                  : IOBroker                                 -  enabled
                                            + system.adapter.influxdb.0               : influxdb              : IOBroker                                 -  enabled, port: 8086
                                            + system.adapter.jarvis.0                 : jarvis                : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
                                            + system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
                                            + system.adapter.node-red.0               : node-red              : IOBroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                                            + system.adapter.shelly.1                 : shelly                : IOBroker                                 -  enabled, port: 18479, bind: 192.168.178.12
                                            + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker                                 -  enabled
                                            + system.adapter.sql.0                    : sql                   : IOBroker                                 -  enabled, port: 5432
                                            + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker                                 -  enabled
                                              system.adapter.tapo.0                   : tapo                  : IOBroker                                 - disabled
                                            + system.adapter.tr-064.0                 : tr-064                : IOBroker                                 -  enabled
                                            + system.adapter.trashschedule.0          : trashschedule         : IOBroker                                 -  enabled
                                            + system.adapter.web.0                    : web                   : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
                                            + instance is alive
                                            367
                                            99030
