    3. Cloud Dienste
    4. Sammelthread : Cloud (free), Cloud.Pro und Alexa-Abbrüche
    • eric2905
      eric2905 last edited by
      Steht im Log.
      Gruß,
      Eric
      Von unterwegs getippert
        bernd-freundorfer last edited by
        zur Info… aktueller Status (bei mir)
        • seit 12:39:36 Uhr keine Fehlermeldungen mehr.
        • Alexa führt die Befehle richtig aus
        • mobile deaktiviert heute vormittag (da eh nicht benutzt)
        host.raspberrypi	2018-01-16 16:49:39.179	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        admin.0	2018-01-16 14:46:59.339	info	Repository received successfully.
        host.raspberrypi	2018-01-16 14:46:58.400	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        admin.0	2018-01-16 14:46:58.213	info	Request actual repository...
        cloud.0	2018-01-16 12:40:16.167	info	Connection changed: CONNECTED4
        cloud.0	2018-01-16 12:40:03.050	info	Connection changed: CONNECTED2
        cloud.0	2018-01-16 12:39:36.695	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:39:26.662	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:39:16.623	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:39:06.583	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:56.542	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:46.504	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:36.471	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:26.430	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:16.395	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:38:06.351	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:37:56.718	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:37:53.858	error	Error while connecting to cloud: Error: xhr poll error
        cloud.0	2018-01-16 12:37:53.836	info	2018-01-16T11:37:53.836Z Connected system.user.admin
        cloud.0	2018-01-16 12:37:53.671	info	Connecting with https://iobroker.net:10555 with "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        cloud.0	2018-01-16 12:37:53.634	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.8.4
        host.raspberrypi	2018-01-16 12:37:50.896	info	instance system.adapter.cloud.0 started with pid 8361
        host.raspberrypi	2018-01-16 12:37:20.878	info	Restart adapter system.adapter.cloud.0 because enabled
        host.raspberrypi	2018-01-16 12:37:20.877	error	instance system.adapter.cloud.0 terminated with code 156 ()
        cloud.0	2018-01-16 12:37:10.836	info	Connection changed: DISCONNECTED4
        cloud.0	2018-01-16 12:37:10.833	info	Connection changed: DISCONNECTED3
        cloud.0	2018-01-16 12:37:10.830	error	Connection error: Error: xhr poll error
        cloud.0	2018-01-16 12:37:03.653	info	Connection changed: CONNECTED1
          mado6470 last edited by
          @eric2905:
          Steht im Log.
          Gruß,
          Eric
          Von unterwegs getippert ` Da hab ich heute morgen nur Fehler …time out...und hxr oder so gesehen....dann werde ich wohl nicht dabei sein....hoffe ich....
          Gesendet von meinem SM-G950F mit Tapatalk
            Balu0127 last edited by
            Hallo
            Kann man schon was sagen?
            Gibt´s Neuigkeiten?
              Grove last edited by
              Hi
              Bei mir ist auch die cloud am spinnen…
              Habe seid eben einen neuen Fehler im log:
              cloud.0	2018-01-16 21:38:02.176	info	Connection changed: DISCONNECTED3
              cloud.0	2018-01-16 21:38:02.103	error	Cloud says: Unknown api-key
              cloud.0	2018-01-16 21:38:02.075	error	Cloud says: Unknown api-key
              cloud.0	2018-01-16 21:38:01.761	info	Connection changed: CONNECTED1
              cloud.0	2018-01-16 21:38:01.254	info	2018-01-16T20:38:01.253Z Connected system.user.admin
              cloud.0	2018-01-16 21:38:01.133	info	Connecting with https://iobroker.net:10555 with "xxxxxxxxxxxxxxxxx"
              cloud.0	2018-01-16 21:38:01.095	info	starting. Version 2.0.4 in C:/ioBroker/node_modules/iobroker.cloud, node: v4.5.0
              Api key= siehe oben xxxxxxxxxxxxxxxxx oder? weil den habe ich kontroliert…
              Alexa neu gestartet;iobroker neugestartet, iobroker skill deaktiviert/aktiviert; ccu neugestartet keine Besserung...
              LG
              MOD-Edit by eric2905; Code-Tags gesetzt
              • BuZZy
                BuZZy last edited by
                @Grove:
                Hi
                Api key= siehe oben xxxxxxxxxxxxxxxxx oder? weil den habe ich kontroliert... ` Hast du den Key nochmal aus deinem Account auf https://iobroker.net/ kopiert?
                Ansonsten kannst du auf der Homepage auch in deinem Account den Key löschen und einen neuen generieren lassen..
                (Free Cloud = https://iobroker.net/ - Pro Cloud = https://iobroker.pro)
                • BBTown
                  BBTown last edited by
                  @Bluefox
                  @eric2905
                  bezüglich des besonders hohen Lastaufkommens beim cloud-Adapter:
                  es gab in letzter Zeit einige Firmware Updates für die HomeMatic CCU
                  Vielleicht gibt es einen Zusammenhang zwischen dem CCU-Firmwarestand und dem hohen Aufkommen in Richtung cloud-Adapter
                  Ich kam nur drauf, da ich beim Querlesen des Themas verstanden habe dass wohl das erhöhte aufkommen mit dem hm-rega und hm-rpc Adpater zu tun haben könnte.
                  Vielleicht hilft es zu verfizieren welchen Frimwarestand welcher "gesperrte" User hat?
                  Ist nur ne Idee und ich hoffe es paßt hier hin, weil das hier wohl der einzig verbliebene (offene) Thread zu dem Thema ist 8-)
                    Wir sind dran.
                    Sind auch guter Hoffnung es schnell hinzubekommen.
                    Es müssen noch ein paar Tests gemacht werden, dann melden wir uns
                    Rainer
                      Fabian last edited by
                      Homematic-Befehle aus der Cloud werden bei mir auch mehrfach (ca. 7x) ausgeführt.
                      Hatte ich in einem anderen Thread schon geschrieben, wo es generell um Probleme mit dem HM-RPC-Adapter geht.
                      Ich sehe das sehr deutlich, wenn ich den Heizungsboost über Alexa auslöse, dann zählt der erstmal x-Mal 300-299-300-299 usw. bis er tatsächlich weiter runterzählt. Ausgelöst über "Objects-Tab" passiert das nicht.
                      Im Log erscheinen auch Fehler, dass das HM-Device angeblich nicht geantwortet hätte. Eventuell tut es das auch nicht, wenn durch das Befehls-Stakkato der Duty Cycle erreicht wird o.ä.
                      Gefühlt passiert das bei über Javascript-Adapter ausgelöste Befehle auch.
                        andyb last edited by
                        Gibt es aktuell irgendwelche Einschränkungen oder müsste iobroker.pro gehen?
                        Ich habe vom Handy Zugriff über die App auf Vis und auch Get-Request geht -> IOB zuhause also erreichbar.
                        Am PC über den Browser kann ich mich zwar mit pro einloggen, ein weiterer Klick aber auf Admin oder Vis endet damit das ich nur das drehende Zahnrad von IOB im Browser zu sehen kriege…..
                        • eric2905
                          Pro-Cloud läuft und der Zugriff geht auch (Admin und VIS gerade probiert).
                          Gruß,
                          Eric
                            Mr_MOS last edited by
                            @Fabian:
                            Gefühlt passiert das bei über Javascript-Adapter ausgelöste Befehle auch. `
                            Die Mehrfachauslösung habe ich auch des öfteren. Wenn ich mein Garagentor über einen virtuellen Taster per Cloud aktiviere, schaltet er gerne zwei Mal und das Tor bleibt sofort wieder stehen.
                            Gruß,
                            MOS
                              @Mr_MOS:
                              @Fabian:
                              Gruß,
                              MOS `
                              Bei mir lag es daran, dass der HM-RPC Adapter im BIN-RPC aus den Antwortdaten kein res-Objekt machen konnte und dies null war. Dadurch hatte sich der Adapter im BIN-RPC direkt beim Hochfahren aufgemault. Der XML-RPC fuhr zwar hoch, aber hatte angeblich keine Antwort von den Devices bekommen. (Oder ähnlich wie beim BIN-RPC: Antwort zwar schon, aber konnte nicht korrekt verarbeitet werden.) Keine Ahnung, ob das dann zur Mehrfachsendung führte?!
                              Auf jeden Fall habe ich den Bug für den BIN-RPC gefixt, so dass der wieder sauber hochfährt und seitdem auch keine Mehrfachausführungen mehr.
                              Siehe http://forum.iobroker.net/viewtopic.php?f=20&t=10629
                              • eric2905
                                Auch hier ein wichtiger Hinweis!
                                http://forum.iobroker.net/viewtopic.php?f=20&t=10811
                                • BBTown
                                  hmm … gemäß Adapterübersicht habe ich die v.3.0.0 des cloud-Adapters installiert :shock: 8-)
                                  • eric2905
                                    Dann hast Du die aber direkt per URL von Github geholt.
                                      Buhu91 last edited by
                                      Hey,
                                      Ich blick inzwischen bei den Aktuellen Problemen mit der Cloud nicht mehr durch.
                                      Ich hab mich jetzt durch zig Threads gewühlt, unter anderem dass manche User aktuell gesperrt sind und, dass es Probleme
                                      mit zu vielen anfragen durch den HM Adapter gibt.
                                      Bei mir verbindet sich die Cloud schon seit tagen nicht mehr, hab auch schon nen neuen Key erstellt und eingetragen, nichts.
                                      es kommt dauerhaft der fehler:
                                      cloud.0 2018-01-21 11:02:21.181 error Error while connecting to cloud: Error: xhr poll error
                                      jedoch ohne die Meldung dass ich gesperrt bin.
                                      Beim durchlesen der Threads heißt es aber von den einzelnen Usern dass diese immer wieder mal trotzdem ne Verbindung haben.
                                      Bei mir eben nicht mehr.
                                      Hab auch den Adapter schon deaktiviert wenn ich nicht gerade am basteln vom IO Broker bin, um nicht die cloud mit meinen Anfragen zu belasten.
                                      Nun die frage, kann ich überhaupt aktuell etwas machen, bzw ist das immoment normal?
                                      • eric2905
                                        Poste bitte erst mal die Versionen von
                                        • Cloud
                                        • Web
                                        • Socket.io
                                        Dann kriegen wir das schon ans fliegen.
                                        Gruß,
                                        Eric
                                          @eric2905:
                                          • Cloud
                                          • Web
                                          • Socket.io
                                          Gruß,
                                          Eric
                                          Hey Eric,
                                          Cloud hat die Version 2.0.5
                                          -Web 2.1.8
                                          -Soket IO 1.8.6
                                          Danke schon mal für deine Hilfe 🙂
                                          • eric2905
                                            Ok.
                                            Cloud 2.0.5 ist nicht Stable Release. Du kannst Dir mal die 2.4.4 aus dem Latest Repository installieren.
                                            Auch Web v2.1.8 ist nicht Stable. Also auch hier mal bitte aus Latest auf die 2.1.9 updaten.
                                            Auch socket.io ist nicht Stable, sondern Latest - aber da aktuell.
                                            Ist Dein Reiter Adapter im Admin grün?
                                            Das bedeutet, das Updates zur Installation anstehen.
                                            Gruß,
                                            Eric
                                            318
                                            53518
