    3. Einsteigerfragen
    4. iobroker Absturz
    iobroker Absturz
      PB74 last edited by
      Mit Maus / Tastatur / Monitor direkt angeschlossen ließ sich der Raspberry nicht neustarten.
      Ich hab ihn also hart runtergefahren... die SSD ist jetzt an einem USB2-Anschluss dran und iob_diag wurde (vollständig) ausgeführt. Hier das Ergebnis...bitte schaut nochmal drüber.
      Script v.2024-12-09 Raspbian+zigbee diag+masking
      *** BASE SYSTEM ***
       Static hostname: iobroker001
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:04:51 up 3 min,  1 user,  load average: 5.45, 2.11, 0.80
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-01-24 20:04:51 CET
                 Universal time: Fri 2025-01-24 19:04:51 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      peter
      HOME=/home/peter
      GROUPS=peter adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        2.4G        189M        167K        1.5G        1.6G
      Swap:           209M        1.3M        208M
      Total:          4.2G        2.4G        397M
      Active iob-Instances:   17
               3790 M total memory
               2285 M used memory
                807 M active memory
               2683 M inactive memory
                177 M free memory
                 24 M buffer memory
               1379 M swap cache
                199 M total swap
                  1 M used swap
                198 M free swap
      top - 20:04:52 up 3 min,  1 user,  load average: 5.45, 2.11, 0.80
      Tasks: 202 total,   8 running, 194 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 85.7 us,  7.1 sy,  0.0 ni,  0.0 id,  7.1 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3790.9 total,    173.8 free,   2288.5 used,   1404.7 buff/cache
      MiB Swap:    200.0 total,    198.7 free,      1.2 used.   1502.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  378M   1% /run
      /dev/sda2      ext4      235G   14G  209G   7% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Fri Jan 24 20:01:43 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:7F:7D:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=2edada06-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Jan 24 20:01:51 2025] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Fri Jan 24 20:01:52 2025] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      6.0G    /var/
      4.0G    /var/log/journal/a8a92d47c12b42b58df1e1120bb26229
      4.0G    /var/log
      1.3G    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      6.0M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/states.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.5
      /usr/bin/node           v18.20.5
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 18.20.5-1nodesource1
        Candidate: 18.20.5-1nodesource1
        Version table:
       *** 18.20.5-1nodesource1 600
              100 /var/lib/dpkg/status
           18.20.4-1nodesource1 600
           18.20.3-1nodesource1 600
           18.20.2-1nodesource1 600
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker001         iobroker001 (version: 7.0.6, hostname: iobroker001   , alive, uptime: 225)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker001                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker001                              -  enabled
        system.adapter.discovery.0              : discovery             : iobroker001                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker001                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker001                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker001                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker001                              -  enabled, port: 0
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker001                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker001                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker001                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker001                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker001                              - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker001                              -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker001                              -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker001                              -  enabled
      + system.adapter.mytime.0                 : mytime                : iobroker001                              -  enabled
      + system.adapter.opendtu.0                : opendtu               : iobroker001                              -  enabled
        system.adapter.pvforecast.0             : pvforecast            : iobroker001                              -  enabled
        system.adapter.pvforecast.1             : pvforecast            : iobroker001                              -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker001                              -  enabled
        system.adapter.s7.0                     : s7                    : iobroker001                              -  enabled
        system.adapter.s7.1                     : s7                    : iobroker001                              -  enabled
        system.adapter.s7.2                     : s7                    : iobroker001                              -  enabled
        system.adapter.socketio.0               : socketio              : iobroker001                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker001                              -  enabled, port: 1883, bind: 192.168.1.141
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker001                              -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker001                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobroker001                              -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
      + system.adapter.time-switch.0            : time-switch           : iobroker001                              -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker001                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker001                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker001                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker001                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker001                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker001                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker001                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker001                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker001                              - disabled
        system.adapter.vis.0                    : vis                   : iobroker001                              -  enabled
      + system.adapter.web.0                    : web                   : iobroker001                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mytime"       : 1.4.0    , installed 0.7.12 [Updatable]
      Adapter    "opendtu"      : 3.1.0    , installed 2.0.0  [Updatable]
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "rpi2"         : 2.3.1    , installed 2.2.1  [Updatable]
      Adapter    "s7"           : 1.4.3    , installed 1.4.3
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.5.0  [Updatable]
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        5625
      States:         4802
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 https://repos.influxdata.com/debian stable InRelease
      Hit:3 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
      Hit:5 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5759       890/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4768       890/iobroker.js-con
      tcp        0      0 192.168.1.141:8701      0.0.0.0:*               LISTEN      1001       7489       1280/io.hm-rpc.2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5640       694/sshd: /usr/sbin
      tcp        0      0 192.168.1.141:1883      0.0.0.0:*               LISTEN      1001       9199       1654/io.sonoff.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6787       789/influxd
      tcp        0      0 192.168.1.141:2001      0.0.0.0:*               LISTEN      1001       9311       1240/io.hm-rpc.0
      tcp        0      0 192.168.1.141:2010      0.0.0.0:*               LISTEN      1001       10300      1257/io.hm-rpc.1
      tcp6       0      0 :::3000                 :::*                    LISTEN      106        6922       889/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5642       694/sshd: /usr/sbin
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       8057       1832/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        5746       789/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7218       1042/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12696      1925/io.web.0
      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       11909      1851/io.terminal.0
      udp        0      0 0.0.0.0:59105           0.0.0.0:*                           104        4551       562/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4549       562/avahi-daemon: r
      udp6       0      0 fe80::9948:b004:76b:546 :::*                                0          1865       632/NetworkManager
      udp6       0      0 :::57898                :::*                                104        4552       562/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4550       562/avahi-daemon: r
      2025-01-24 20:07:00.183  - warn: javascript.0 (1101)     at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-24 20:07:00.183  - warn: javascript.0 (1101)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2148:29)
      2025-01-24 20:07:00.183  - warn: javascript.0 (1101)     at listOnTimeout (node:internal/timers:571:11)
      2025-01-24 20:07:00.183  - warn: javascript.0 (1101)     at processTimers (node:internal/timers:512:7)
      2025-01-24 20:07:00.208  - warn: javascript.0 (1101) You are assigning a number to the state "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil3_bool_in_string" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2025-01-24 20:07:00.209  - warn: javascript.0 (1101)     at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-24 20:07:00.210  - warn: javascript.0 (1101)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2148:29)
      2025-01-24 20:07:00.210  - warn: javascript.0 (1101)     at listOnTimeout (node:internal/timers:571:11)
      2025-01-24 20:07:00.210  - warn: javascript.0 (1101)     at processTimers (node:internal/timers:512:7)
      2025-01-24 20:07:00.213  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.openDTU_Erreichbarkeit" has to be type "string" but received type "number"
      2025-01-24 20:07:00.214  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.WR_Sued_AC_Produktion" has to be type "string" but received type "number"
      2025-01-24 20:07:00.214  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.WR_Sued_Netz_verbunden" has to be type "string" but received type "number"
      2025-01-24 20:07:00.221  - warn: javascript.0 (1101) You are assigning a number to the state "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil2_bool_in_string" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2025-01-24 20:07:00.222  - warn: javascript.0 (1101)     at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-24 20:07:00.222  - warn: javascript.0 (1101)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2148:29)
      2025-01-24 20:07:00.222  - warn: javascript.0 (1101)     at listOnTimeout (node:internal/timers:571:11)
      2025-01-24 20:07:00.222  - warn: javascript.0 (1101)     at processTimers (node:internal/timers:512:7)
      2025-01-24 20:07:00.223  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil3_bool_in_string" has to be type "string" but received type "number"
      2025-01-24 20:07:00.237  - warn: javascript.0 (1101) You are assigning a number to the state "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil1_bool_in_string" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
      2025-01-24 20:07:00.238  - warn: javascript.0 (1101)     at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      2025-01-24 20:07:00.238  - warn: javascript.0 (1101)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2148:29)
      2025-01-24 20:07:00.239  - warn: javascript.0 (1101)     at listOnTimeout (node:internal/timers:571:11)
      2025-01-24 20:07:00.239  - warn: javascript.0 (1101)     at processTimers (node:internal/timers:512:7)
      2025-01-24 20:07:00.243  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil2_bool_in_string" has to be type "string" but received type "number"
      2025-01-24 20:07:00.286  - info: javascript.0 (1101) State value to set for "0_userdata.0.eig_Datenpunkte.Bewaess_Ventil1_bool_in_string" has to be type "string" but received type "number"
        Homoran Global Moderator Administrators @PB74 last edited by
        @pb74 sagte in iobroker Absturz:
        load average: 5.45,
        da knallts bald wieder
        aber warum?
        gib mal die Ausgabe von top
          PB74 @Homoran last edited by
          top - 20:21:54 up 20 min,  1 user,  load average: 2.39, 1.47, 1.43
          Tasks: 193 total,   3 running, 190 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  6.2 us,  1.2 sy,  0.0 ni, 92.1 id,  0.1 wa,  0.0 hi,  0.4 si,  0.0 st
          MiB Mem :   3790.9 total,    501.2 free,   2280.6 used,   1085.0 buff/cache
          MiB Swap:    200.0 total,     82.3 free,    117.7 used.   1510.3 avail Mem
            PB74 last edited by
            top - 20:23:41 up 21 min,  1 user,  load average: 1.23, 1.41, 1.42
            Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  4.8 us,  0.8 sy,  0.0 ni, 94.0 id,  0.0 wa,  0.0 hi,  0.4 si,  0.0 st
            MiB Mem :   3790.9 total,    460.5 free,   2318.1 used,   1088.1 buff/cache
            MiB Swap:    200.0 total,     83.6 free,    116.4 used.   1472.8 avail Mem
              Homoran Global Moderator Administrators @PB74 last edited by Homoran
              @pb74 die Tabelle darunter ist genauso wichtig
              Der Raspi beruhigt sich gerade, aber eine load average 1min von >2 bei 6% CPU deutet auf Probleme mit dem I/O
                @homoran said in iobroker Absturz:
                Tut mir leid, dafür fehlt mir das Wissen. Kannst Du mir das bitte erklären?
                Danke schon mal...
                  PB74 last edited by
                  top - 20:29:31 up 27 min,  1 user,  load average: 0.42, 0.74, 1.12
                  %Cpu(s):  3.4 us,  1.2 sy,  0.0 ni, 95.2 id,  0.1 wa,  0.0 hi,  0.1 si,  0.0 st
                  MiB Mem :   3790.9 total,    416.3 free,   2352.6 used,   1097.8 buff/cache
                  MiB Swap:    200.0 total,     84.7 free,    115.3 used.   1438.3 avail Mem
                    PB74 last edited by
                    top - 20:32:23 up 30 min,  1 user,  load average: 0.71, 0.76, 1.06
                    Tasks: 194 total,   3 running, 191 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  4.2 us,  0.7 sy,  0.0 ni, 94.9 id,  0.0 wa,  0.0 hi,  0.2 si,  0.0 st
                    MiB Mem :   3790.9 total,    408.6 free,   2347.7 used,   1110.4 buff/cache
                    MiB Swap:    200.0 total,     84.8 free,    115.2 used.   1443.2 avail Mem
                      @pb74 bitte die darunter befindliche Table of Processes zeigen.
                      Das ist nur der Header.
                        Aha, das war mir so nicht klar.
                        top - 20:37:11 up 35 min,  1 user,  load average: 0.12, 0.48, 0.86
                        %Cpu(s):  4.2 us,  1.2 sy,  0.0 ni, 94.5 id,  0.1 wa,  0.0 hi,  0.1 si,  0.0 st
                        MiB Mem :   3790.9 total,    378.2 free,   2371.7 used,   1116.9 buff/cache
                        MiB Swap:    200.0 total,     85.1 free,    114.8 used.   1419.2 avail Mem
                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                            890 iobroker  20   0 9474412 392520  38912 R   7.6  10.1   5:54.60 iobroker.js-con
                           1056 iobroker  20   0 9378436 119260  38912 S   2.7   3.1   1:29.99 io.influxdb.0
                           1101 iobroker  20   0 9641008 362132  40704 S   2.7   9.3   2:03.87 io.javascript.0
                           1654 iobroker  20   0 9096716 105024  38656 S   2.0   2.7   1:17.80 io.sonoff.0
                           1681 iobroker  20   0 9085944  95300  38784 S   1.7   2.5   0:23.08 io.tr-064.0
                            789 influxdb  20   0 2665996 146712   9684 S   1.0   3.8   0:29.06 influxd
                           1613 iobroker  20   0 9071608  79240  39168 S   1.0   2.0   0:14.64 io.s7.2
                           1783 iobroker  20   0 9074016  81808  38912 S   1.0   2.1   0:10.75 io.modbus.0
                           1257 iobroker  20   0 9079240  90204  38912 S   0.7   2.3   0:16.65 io.hm-rpc.1
                             17 root      20   0       0      0      0 I   0.3   0.0   0:01.54 rcu_preempt
                            565 message+  20   0    8792   3072   2432 S   0.3   0.1   0:00.44 dbus-daemon
                            632 root      20   0  262564   7808   6528 S   0.3   0.2   0:00.73 NetworkManager
                            644 root      20   0   17160   4352   3968 S   0.3   0.1   0:00.34 wpa_supplicant
                            889 grafana   20   0 1598204  75140  41856 S   0.3   1.9   0:08.36 grafana
                           1280 iobroker  20   0 9082348  90944  38784 S   0.3   2.3   0:17.25 io.hm-rpc.2
                           1379 iobroker  20   0 9076332  89020  38912 S   0.3   2.3   0:15.40 io.opendtu.0
                           1513 iobroker  20   0 9071972  79808  39168 S   0.3   2.1   0:14.67 io.s7.0
                           1536 iobroker  20   0 9071744  80584  39168 S   0.3   2.1   0:14.64 io.s7.1
                           1805 iobroker  20   0 9059084  87284  43904 R   0.3   2.2   0:09.73 io.pvforecast.0
                           1857 iobroker  20   0 9052620  76880  38912 S   0.3   2.0   0:06.70 io.time-switch.
                           1872 iobroker  20   0 9050672  73640  38912 S   0.3   1.9   0:06.36 io.vis-inventwo
                           3826 root      20   0       0      0      0 I   0.3   0.0   0:00.11 kworker/0:1-mm_percpu_wq
                           4210 peter     20   0   11756   4992   2816 R   0.3   0.1   0:00.06 top
                              1 root      20   0  168468   8152   6208 S   0.0   0.2   0:01.91 systemd
                              2 root      20   0       0      0      0 S   0.0   0.0   0:00.01 kthreadd
                              3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
                              4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_g
                              5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_p
                              6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_
                              7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
                              9 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
                             11 root      20   0       0      0      0 I   0.0   0.0   0:00.16 kworker/u8:0-ext4-rsv-conversion
                             12 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_pe
                             13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                             14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                             15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                             16 root      20   0       0      0      0 S   0.0   0.0   0:00.25 ksoftirqd/0
                             18 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/0
                             19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                             20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                             21 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/1
                             22 root      20   0       0      0      0 S   0.0   0.0   0:00.13 ksoftirqd/1
                             24 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
                             25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                             26 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/2
                             27 root      20   0       0      0      0 S   0.0   0.0   0:00.12 ksoftirqd/2
                             29 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-events_highpri
                             30 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                             31 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/3
                             32 root      20   0       0      0      0 S   0.0   0.0   0:00.11 ksoftirqd/3
                             34 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/3:0H-events_highpri
                             35 root      20   0       0      0      0 I   0.0   0.0   0:00.68 kworker/u9:0-writeback
                             36 root      20   0       0      0      0 I   0.0   0.0   0:00.05 kworker/u10:0-events_unbound
                             38 root      20   0       0      0      0 I   0.0   0.0   0:00.00 kworker/u12:0-events_unbound
                             39 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
                             40 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-inet_
                          @homoran sagte in iobroker Absturz:
                          die load average betrachtet diverse Parameter zur Systemlast, und der Wert sollte grob gesagt die Anzahl Kerne nicht überschreiten.
                          Passiert das, staut sich die Abarbeitung was im schlimmsten Fall zur Lähmung des Systems führt.
                          Es wäre vielleicht sinnvoll auf den entsprechenden Wert unter system.host.xyz zu triggern, beim Erreichen einer Schwelle eine WARN ins log schreiben, damit man später im Log sehen kann was da etwa passiert ist.
                          dazu gehören natürlich die CPU Last, aber auch due Geschwindigkeit von In/Out (Lese/Schreib) Vorgängen.
                          Da bei dir die CPU nur mäßig ausgelastet ist, die load aber relativ hoch, muss die Ursache nicht in der CPU-Last liegen
                            @pb74 Danke!
                            Jetzt hat sich "leider" die load normalisiert und passt zur CPU-Last
                            daher ist auch der Prozess mit der höchsten Last auch absolut unauffällig
                            EDIT
                            der controller belastet zwar nur einen Kern mit 7.6%, braucht aber 10% des Speichers.
                            Das kann ich jetzt nicht bewerten.
                            Der zweitgrößte Speicherfresser ist javascript.0
                              Wenn Du keine anderen Vorgaben hast, würde ich das System jetzt erst mal so laufen lassen und demnächst in den Scripten auf Fehlersuche gehen...
                                @pb74 ja!
                                und vergleiche immer mal wieder die Werte von top
                                • BananaJoe
                                  BananaJoe Most Active @Homoran last edited by
                                  Alternative ggf.
                                  htop
                                  das ist top mit etwas mehr "Schnickschnack" was es aus meiner Sicht lesbarer macht:
                                  Als "Windows Benutzer" ist insbesondere die prozentuale Anzeige oben für die CPU vertrauter, htop ist bunt und bei beiden gibt es mit h eine Hilfe
                                    PB74 @BananaJoe last edited by
                                    @bananajoe
                                    Guter Tipp, ich lass es grade mal durchlaufen.
                                      PB74 last edited by
                                      Ich hab heute mal die Variablen entsprechend korrigiert, damit die Warnmeldungen verschwinden.
                                      Hier die derzeitige Ausgabe von top (ich konnte die Ausgabe von htop leider nicht kopieren 😊 )
                                      Weiter unten noch der Langtext von iob_diag.
                                      Die dort noch angezeigte Warnung "hm-rega.0(6801)" tritt nun auch nicht mehr auf; der max-Wert wurde entsprechend angepasst.
                                      top - 18:49:53 up 22:48,  1 user,  load average: 0.15, 0.34, 0.41
                                      Tasks: 192 total,   1 running, 191 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  5.1 us,  1.3 sy,  0.0 ni, 93.2 id,  0.0 wa,  0.0 hi,  0.4 si,  0.0 st
                                      MiB Mem :   3790.9 total,    376.0 free,   2649.7 used,    838.7 buff/cache
                                      MiB Swap:    200.0 total,      0.4 free,    199.6 used.   1141.2 avail Mem
                                         6672 iobroker  20   0 9708496 370072  14080 S  10.3   9.5 163:48.76 iobroker.js-con
                                         7024 iobroker  20   0 9142568 126288  11392 S   4.3   3.3  48:14.52 io.sonoff.0
                                         6705 iobroker  20   0 9390044 107320  11136 S   3.7   2.8  50:19.08 io.influxdb.0
                                         6732 iobroker  20   0 9639256 352964  16640 S   3.7   9.1  49:20.98 io.javascript.0
                                         7043 iobroker  20   0 9088432  74536  11648 S   1.3   1.9   7:55.73 io.tr-064.0
                                          789 influxdb  20   0 2734792 192696  13236 S   0.7   5.0  15:18.77 influxd
                                         6801 iobroker  20   0 9084128  61792  11136 S   0.7   1.6   2:42.33 io.hm-rega.0
                                           56 root       0 -20       0      0      0 I   0.3   0.0   0:08.71 kworker/0:1H-kblockd
                                           89 root     -51   0       0      0      0 S   0.3   0.0   2:14.46 irq/37-mmc0
                                          200 root      20   0       0      0      0 S   0.3   0.0   0:45.18 jbd2/sda2-8
                                          259 root      20   0  115780  47092  46708 S   0.3   1.2   1:50.74 systemd-journal
                                         6782 iobroker  20   0 9355772  71336  11392 S   0.3   1.8   2:24.99 io.backitup.0
                                         6839 iobroker  20   0 9092588  64508  11008 S   0.3   1.7   3:48.31 io.hm-rpc.1
                                         6994 iobroker  20   0 9080908  60140  11392 S   0.3   1.5   4:39.15 io.s7.1
                                         7009 iobroker  20   0 9078792  59536  11136 S   0.3   1.5   4:37.34 io.s7.2
                                         7208 iobroker  20   0 9072548  51920  11008 S   0.3   1.3   1:26.47 io.mytime.0
                                        22100 iobroker  20   0 9351032  72500  12032 S   0.3   1.9   1:00.17 io.telegram.0
                                        47225 root      20   0       0      0      0 D   0.3   0.0   0:03.25 kworker/2:0+events_freezable
                                        47988 peter     20   0   11756   4992   2816 R   0.3   0.1   0:00.28 top
                                            1 root      20   0  168624   6744   4800 S   0.0   0.2   0:03.00 systemd
                                            2 root      20   0       0      0      0 S   0.0   0.0   0:00.10 kthreadd
                                           11 root      20   0       0      0      0 I   0.0   0.0   0:03.92 kworker/u8:0-ext4-rsv-conversion
                                           16 root      20   0       0      0      0 S   0.0   0.0   0:06.88 ksoftirqd/0
                                           17 root      20   0       0      0      0 I   0.0   0.0   0:37.42 rcu_preempt
                                           22 root      20   0       0      0      0 S   0.0   0.0   0:02.78 ksoftirqd/1
                                           27 root      20   0       0      0      0 S   0.0   0.0   0:02.58 ksoftirqd/2
                                           32 root      20   0       0      0      0 S   0.0   0.0   0:02.30 ksoftirqd/3
                                           42 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
                                           44 root      20   0       0      0      0 S   0.0   0.0   0:00.08 khungtaskd
                                           45 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
                                           46 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-write
                                           47 root      20   0       0      0      0 S   0.0   0.0   0:06.75 kcompactd0
                                           48 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kinte
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       18:51:37 up 22:49,  1 user,  load average: 0.52, 0.41, 0.43
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Sat 2025-01-25 18:51:38 CET
                                                 Universal time: Sat 2025-01-25 17:51:38 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      peter
                                      HOME=/home/peter
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.0G        2.8G        338M        208K        936M        1.2G
                                      Swap:           209M        208M        876K
                                      Total:          4.2G        3.0G        339M
                                      Active iob-Instances:   29
                                               3790 M total memory
                                               2649 M used memory
                                               1489 M active memory
                                               1803 M inactive memory
                                                322 M free memory
                                                 77 M buffer memory
                                                814 M swap cache
                                                199 M total swap
                                                199 M used swap
                                                  0 M free swap
                                      top - 18:51:38 up 22:49,  1 user,  load average: 0.52, 0.41, 0.43
                                      Tasks: 198 total,   2 running, 196 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us, 11.1 sy,  0.0 ni, 77.8 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3790.9 total,    322.1 free,   2649.2 used,    893.2 buff/cache
                                      MiB Swap:    200.0 total,      0.8 free,    199.2 used.   1141.7 avail Mem
                                      *** FILESYSTEM ***
                                      /var:
                                      6.1G    /var/
                                      4.0G    /var/log
                                      1.3G    /var/lib
                                      49M     /opt/iobroker/iobroker-data/states.jsonl
                                      26M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/nodejs         v18.20.6
                                      /usr/bin/node           v18.20.6
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Installed: 18.20.6-1nodesource1
                                        Candidate: 18.20.6-1nodesource1
                                        Version table:
                                       *** 18.20.6-1nodesource1 600
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker001         iobroker001 (version: 7.0.6, hostname: iobroker001   , alive, uptime: 78011)
                                      admin:          7.4.10
                                      javascript:     8.8.3
                                      Adapter State
                                      + system.adapter.discovery.0              : discovery             : iobroker001                              -  enabled
                                      + system.adapter.modbus.0                 : modbus                : iobroker001                              -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : iobroker001                              -  enabled
                                      + system.adapter.pvforecast.1             : pvforecast            : iobroker001                              -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : iobroker001                              -  enabled
                                      + system.adapter.s7.0                     : s7                    : iobroker001                              -  enabled
                                      + system.adapter.s7.1                     : s7                    : iobroker001                              -  enabled
                                      + system.adapter.s7.2                     : s7                    : iobroker001                              -  enabled
                                      + system.adapter.socketio.0               : socketio              : iobroker001                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker001                              -  enabled, port: 1883, bind: 192.168.1.141
                                      + system.adapter.terminal.0               : terminal              : iobroker001                              -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
                                      + system.adapter.tr-064.0                 : tr-064                : iobroker001                              -  enabled
                                      + instance is alive
                                      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                      Adapter    "mytime"       : 1.4.0    , installed 1.4.0
                                      Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                                      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                                      Objects and States
                                      Objects:        5621
                                      States:         4770
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Hit:3 https://repos.influxdata.com/debian stable InRelease
                                      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Hit:7 http://deb.debian.org/debian bookworm-updates InRelease
                                      Pending Updates: 1
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       101269     6672/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       101276     6672/iobroker.js-co
                                      tcp        0      0 192.168.1.141:8701      0.0.0.0:*               LISTEN      1001       103794     6857/io.hm-rpc.2
                                      tcp        0      0 192.168.1.141:1883      0.0.0.0:*               LISTEN      1001       103010     7024/io.sonoff.0
                                      tcp        0      0 192.168.1.141:2001      0.0.0.0:*               LISTEN      1001       104570     6824/io.hm-rpc.0
                                      tcp        0      0 192.168.1.141:2010      0.0.0.0:*               LISTEN      1001       104679     6839/io.hm-rpc.1
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       104037     7103/io.socketio.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       102581     6694/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       104198     7193/io.web.0
                                      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       104056     7114/io.terminal.0
                                      2025-01-25 15:31:20.283  - info: javascript.0 (6732) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2025-01-25 16:00:00.125  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 6] | [nächster Tag: 7] | [Aktualisiert: 1] | Aktuelle Tageszeit: früher Abend | Kommende Tageszeit: Abend
                                      2025-01-25 16:00:22.485  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10478.884942" greater than max "8800"
                                      2025-01-25 16:30:00.106  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 6] | [nächster Tag: 8] | [Aktualisiert: 0] | Aktuelle Tageszeit: früher Abend | Kommende Tageszeit: Abend
                                      2025-01-25 16:30:22.508  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10479.301609" greater than max "8800"
                                      2025-01-25 17:00:00.104  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 4] | [nächster Tag: 8] | [Aktualisiert: 2] | Aktuelle Tageszeit: Sonnenuntergang | Kommende Tageszeit: Abenddämmerung
                                      2025-01-25 17:00:22.532  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10479.718276" greater than max "8800"
                                      2025-01-25 17:30:00.095  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 3] | [nächster Tag: 10] | [Aktualisiert: 1] | Aktuelle Tageszeit: Abenddämmerung | Kommende Tageszeit: später Abend
                                      2025-01-25 17:30:22.578  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.134943" greater than max "8800"
                                      2025-01-25 18:00:00.106  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 1] | [nächster Tag: 12] | [Aktualisiert: 1] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
                                      2025-01-25 18:00:22.621  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.55161" greater than max "8800"
                                      2025-01-25 18:30:00.101  - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 1] | [nächster Tag: 13] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
                                      2025-01-25 18:30:20.093  - info: admin.0 (6694) failed connection to socket.io from ::ffff:192.168.1.60: Passport was not initialized
                                      2025-01-25 18:30:20.174  - info: admin.0 (6694) failed connection to socket.io from ::ffff:192.168.1.60: Passport was not initialized
                                      2025-01-25 18:30:22.631  - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.968277" greater than max "8800"
                                      2025-01-25 18:30:34.092  - info: admin.0 (6694) ==> Connected system.user.admin from ::ffff:192.168.1.60
                                      2025-01-25 18:31:32.179  - info: javascript.0 (6732) Stopping script script.js.common.Gerate_Zaehlen_V1
                                      2025-01-25 18:31:32.230  - info: javascript.0 (6732) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                                      2025-01-25 18:31:32.300  - info: javascript.0 (6732) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2025-01-25 18:34:07.573  - info: admin.0 (6694) ==> Connected system.user.admin from ::ffff:192.168.1.60
                                      2025-01-25 18:35:44.149  - info: admin.0 (6694) <== Disconnect system.user.admin from ::ffff:192.168.1.60 javascript
                                      2025-01-25 18:38:10.320  - info: web.0 (7193) ==> Connected system.user.admin from ::ffff:192.168.1.180
                                      2025-01-25 18:40:35.697  - info: web.0 (7193) <== Disconnect system.user.admin from ::ffff:192.168.1.180 vis.0
                                      2025-01-25 18:52:33.831  - info: web.0 (7193) ==> Connected system.user.admin from ::ffff:192.168.1.180
                                      2025-01-25 18:53:10.078  - info: web.0 (7193) <== Disconnect system.user.admin from ::ffff:192.168.1.180 vis.0
                                        PB74 last edited by
                                        Sollte ich eigentlich meinen Swap vergrößern?
                                        top - 19:12:20 up 23:10,  1 user,  load average: 0.22, 0.42, 0.62
                                        %Cpu(s):  8.3 us,  2.2 sy,  0.0 ni, 89.1 id,  0.1 wa,  0.0 hi,  0.2 si,  0.0 st
                                        MiB Mem :   3790.9 total,    442.0 free,   2595.2 used,    827.2 buff/cache
                                        MiB Swap:    200.0 total,      0.6 free,    199.4 used.   1195.7 avail Mem
                                          ich halte das für Blödsinn bei
                                          1195.7 avail Mem
                                          sieht richtig gut aus!
                                            PB74 last edited by
                                            ich war schon euphorisch und wollte sagen "Problem gelöst", aber am Donnerstag 30.01. gegen Abend blieb das System wieder hängen.
                                            Bis dato hatte ich mehrfach auch von Arbeit aus per VPN und SSH die Werte per top kontrolliert, es war alles i.O.
                                            Um 18:54 Uhr wurde das automatische Update des Repositorys gestartet; danach gibt es keine Protokolleinträge mehr.
                                            Am 31.01. finden sich ab ca. 05:30 Uhr wieder Einträge im Protokoll, jede Menge Fehler und Warnmeldungen. Ab ca. 05:35 Uhr gibt es keine Fehler mehr, nur noch zwei Warnungen:
                                            a)
                                            hm-rega.0 (275505) State value to set for "hm-rega.0.10636" has value "10600.135039" greater than max "8800"
                                            (der Max-Wert wurde inzwischen angepasst)
                                            b)
                                            javascript.0 (275428) script.js.common.DWD_Radarbild_holen: Fehler bei https://www.dwd.de/DWD/wetter/sat/satwetter/njob_satrad.png : AxiosError: stream has been aborted
                                            Nun läuft alles wieder als wäre nichts gewesen ....
                                            Hab grade noch das OS und auf Nodejs 20 geupdatet, mal schauen....
                                            Habt ihr vielleicht noch einen Ansatzpunkt für mich?
                                            Danke schon mal !
                                            absturz
                                            11
                                            78
                                            6741
