    5. Verständnisfrage: Virtuelle Schalter und nutzen in Blockly
      paul53 @topsurfer last edited by paul53
      @topsurfer sagte: %-Zahl mitgeben
      Zum Anzeigen der Position erstelle einen Datenpunkt "0_userdata.0.OG.Rollladen.Empore.Position" vom Typ "Zahl", Einheit "%" und schreibe den mit dem Blockly:
      Zum Importieren:
       <variables>
         <variable id="ubynHLy4Dkh(Bv|X]_*t">Laufzeit</variable>
         <variable id="~Us6?lh=kFptMa4QP{$0">delta</variable>
         <variable type="interval" id="Intervall">Intervall</variable>
         <variable id="tlq{(llW7V(^GQehrm$.">Position</variable>
       </variables>
       <block type="variables_set" id="^fYO/}KqtQShj`:mjfuz" x="437" y="13">
         <field name="VAR" id="ubynHLy4Dkh(Bv|X]_*t">Laufzeit</field>
           <block type="math_number" id="oyoWG$hfc:fFIa52SAm{">
             <field name="NUM">40</field>
           <block type="on" id="HgzzbyYLT*Y!Y]+VC7}6">
             <field name="OID">alias.0.OG.Rollladen.Empore.Hoch</field>
               <block type="controls_if" id="*@@!+W{JMo1hIOX%d^n;">
                   <block type="on_source" id="t2};(y7^^wt!hO:!V.8l">
                   <block type="variables_set" id=":#R#[Quf{4thw:|N($z+">
                     <field name="VAR" id="tlq{(llW7V(^GQehrm$.">Position</field>
                       <block type="get_value" id="#PU*/$UU)B=om(D6YClL">
                         <field name="OID">0_userdata.0.OG.Rollladen.Empore.Position</field>
                       <block type="controls_if" id="$-Fd2_ANAq!C[C+iX#1m">
                           <block type="logic_compare" id="b5+P%Im-{mvrHh=VmO]a">
                             <field name="OP">LT</field>
                               <block type="variables_get" id="2Gn;!xdZpUF.q!Ksv_O/">
                               <block type="math_number" id="F+^kqZlJc0SZmlv?=V}d">
                                 <field name="NUM">100</field>
                           <block type="procedures_callnoreturn" id="{|/R)xVeWWh(/Q65()Wd" inline="true">
                             <mutation name="Bewegung">
                               <arg name="delta"></arg>
                             </mutation>
                             <value name="ARG0">
                               <block type="math_arithmetic" id="cvK!GsF-~6I_6%n7qkM|">
                                 <field name="OP">DIVIDE</field>
                                   <shadow type="math_number" id="9CRFR~Vr_lFc+g_r+g:T">
                                   <shadow type="math_number" id="`CLAP0TZNGf^#-EprpY}">
                                     <field name="NUM">1</field>
                                   <block type="variables_get" id="JEBL%(9A~5SisY46[KC_">
                 <statement name="ELSE">
                   <block type="timeouts_clearinterval" id="[TE[hW3sC8{e$;!?6]!H">
                     <field name="NAME">Intervall</field>
               <block type="on" id="5+LLXzYNqGTN})GG|+?]">
                 <field name="OID">alias.0.OG.Rollladen.Empore.Runter</field>
                   <block type="controls_if" id="6D:#Z;A;5`jlBIMju{zy">
                       <block type="on_source" id="m9]Id4L)i7efpljb7yWi">
                       <block type="variables_set" id="fW::dZfiG1nr$qR5b$({">
                           <block type="get_value" id="cMP_n^~r2N}cH${yciKi">
                           <block type="controls_if" id="C/xM@kL8sqG/0keKFGs_">
                               <block type="logic_compare" id="M%=yBvc^YNmFUKxZ7SZ^">
                                 <field name="OP">GT</field>
                                   <block type="variables_get" id="VG.=+~Fz5O21^dD1gFV;">
                                   <block type="math_number" id="T{UF~M)^tgZ7AeK~Itt?">
                                     <field name="NUM">0</field>
                               <block type="procedures_callnoreturn" id="LTx*?C8)Ay+m{qmPh;e`" inline="true">
                                 </mutation>
                                 <value name="ARG0">
                                   <block type="math_arithmetic" id="a1^%,)KgrSTF=lNlSSgg">
                                       <shadow type="math_number" id="7nDX?;s[Jtc`K/uG1P_W">
                                         <field name="NUM">-100</field>
                                       <block type="variables_get" id="x?5?m+!X;a;-(^I:?oDZ">
                       <block type="timeouts_clearinterval" id="P%Y=s@Y,?vdFdBHnEfo$">
       <block type="procedures_defnoreturn" id="rRQ$1-2OAn]gR1,}{`hW" x="888" y="12">
         <mutation>
           <arg name="delta" varid="~Us6?lh=kFptMa4QP{$0"></arg>
         </mutation>
         <field name="NAME">Bewegung</field>
         <statement name="STACK">
           <block type="timeouts_setinterval" id="ke{vOu8S.$kqCsW7+FCJ">
             <field name="INTERVAL">1</field>
               <block type="math_change" id="L}5!UMn{D8dWO:tLLs5b">
                 <value name="DELTA">
                   <shadow type="math_number" id="|?d1vQ;3K8WuO!?u]4W}">
                   <block type="variables_get" id="qq}B*ow4|l_lBvAq_iKG">
                     <field name="VAR" id="~Us6?lh=kFptMa4QP{$0">delta</field>
                   <block type="update" id="Y4[C4U/~g#ZvET]J}mS#">
                       <block type="math_round" id="cCw=+n-f:9Ot)PoaD)Pl">
                         <field name="OP">ROUND</field>
                         <value name="NUM">
                           <shadow type="math_number" id=";f@o4zD`5B6DpL,ul_P$">
                             <field name="NUM">3.1</field>
                           <block type="variables_get" id="]}P0X,zGiS#N_N?l5;!h">
       <block type="on" id="xRIy,@2?.mn!S^I*(NP@" x="1062" y="238">
         <field name="OID">alias.0.OG.Rollladen.Empore.unten</field>
         <field name="CONDITION">gt</field>
           <block type="update" id="1%WA2;XDWkAD#Y.%d~BQ">
               <block type="math_number" id="OHRPH%DUaWI9!q_@[fig">
           <block type="on" id="aT^xEv1={`IA|m,gvx/V">
             <field name="OID">alias.0.OG.Rollladen.Empore.oben</field>
               <block type="update" id="k*.tp(r/NAab3tGRTZ%s">
                   <block type="math_number" id="JRbL!!N%TjnL-DkGo|qJ">
        topsurfer @paul53 last edited by topsurfer
        @paul53 said in Verständnisfrage: Virtuelle Schalter und nutzen in Blockly:
        Und schon wieder ein "Hänger" 😞
        Datenpunkt angelegt, aber wo kann ich da eine Einheit vergeben? Manuellin den "Objektdaten"?
          @topsurfer sagte: Manuellin den "Objektdaten"?
          Ja, im Tab "COMMON" ganz unten.
            OK, verstanden, in diesem DP sollte dann immer der aktuelle Standd es Rollladen sabfragbar sein.
            (Blockly importiert, läuft ...; Thx!)
            Aber wie erfolgt die eigentliche Steuerung des Rollladens, die Objekt-ID vom DT (0_userdata.0.OG.Rollladen.Empore.Position) steuert ja nicht_)
            Und im "Icon" vom Rollladen unter "Alggmeien" kann ich doch nur eine Objekt-ID angeben, und bei "CMD" müßte ich ja noch irgendwo angeben, welches CMD er ausführen soll ...
            paul53 3 Replies Last reply Reply Quote 0
              @topsurfer sagte: bei "CMD" müßte ich ja noch irgendwo angeben, welches CMD er ausführen soll ...
              Dafür kann man ein weiteres Widget mit "ValueList" im Namen nehmen. "ValueList" kann mehr als nur zwei Werte steuern. Im alten Vis gab es z.B. "Radiobuttons ValueList", die man beschriften konnte (z.B. "hoch;stop;runter").
                @topsurfer
                In Vis-2 gibt es "Radioliste mit Werten":
                EDIT: Man kann auch Symbole verwenden:
                Reihenfolge der Werte: 1 - 0 - 2
                  topsurfer last edited by topsurfer
                  Ja, das kommt mir aus OpenHab bekannt vor ... Valuelisten etc.
                  Aber das "einfache" steuern vom Rollladen ...
                  Ich spreche den DP "alias.0.OG.Rollladen.Empore_UP" (testweise) mit einem einfachen Taster an, setze auch den "Test: WAHR", aber es passiert nichts wenn ich den virt. Taster drücke (das sollte ja komplett ohne das ein Script läuft funktionieren, oder?
                  Mein Alias, den ich für den Rollladen für "Up" angelegt habe, sieht so aus:
                  So langsam verstehe ich das "Prinzip" und finde auch die entsprechenden Optionen, daher dachte ich, dass dieser angelegte einfache Schalter ein hochfahren vom Rollladen auslösen sollte (wenn Knopf gedrück, schicke den Wert "True" an den DP "Empore_up")
                    @topsurfer sagte: DP "alias.0.OG.Rollladen.Empore_UP" (testweise) mit einem einfachen Taster an
                    Der Enocean-DP "UP" ist "read only" (Schlosssymbol neben der ID). Gesteuert werden kann nur über "CMD" mit den Werten 0;1;2.
                    Was stört dich an der "Radioliste mit Werten"? Ist die Version mit den Symbolen nicht brauchbar?
                      @topsurfer sagte: Blockly importiert, läuft
                      Im Blockly habe ich diese Alias-DP verwendet:
                      Der Kommando-Alias für Vis-2 hat folgende Objektdaten:
                        "common": {
                          "name": "Rollladen Empore Kommando",
                          "desc": "Manuell erzeugt",
                          "role": "level",
                          "type": "number",
                          "read": true,
                          "write": true,
                          "def": 0,
                          "states": {
                            "0": "stop",
                            "1": "hoch",
                            "2": "runter"
                          "alias": {
                            "id": "enocean.0.fffd10a5.CMD"
                        "type": "state",
                        Nichts 😉
                        Hatte ich auch alles schon probiert, wegen misserfolg wollte ich "einfachen" Taster probieren.
                        Mit den Radiobutton und den Wert 0,1,2 und kann ich jetzt den Rollladen (wenn ich ihn direkt als Objekt enocean.0.fffd10a5.CMD eintrage, nicht über den Alias) eintrage, hoch- und runter fahren. Aber nach ca. 20cm (4s) bleibt er immer wieder stehen. Dann muss ich wieder auf "runter" drücken für die nächsten 20cm ... Was ist das jetzt wieder? Mit "0" kann ich sofort stoppen, das geht auch.
                        Bisher habe ich nur den Alias für das CMD Kommande, die anderen erstelle ich jetzt.
                        Und zum Verständis, der erstellete DP in Userdata_0.OG.Rollladen.Empore.Position, der auch in Blockly genutzt wird, ist der zum steuern des Rollladens an die gewünschte Stelle (60%) oder als Rückgabewert für die Position des Rolladens (60%) gedacht?
                          @topsurfer sagte: zum steuern des Rollladens an die gewünschte Stelle (60%) oder als Rückgabewert für die Position des Rolladens (60%) gedacht?
                          Nur als Rückgabewert zur Anzeige der Position.
                            @topsurfer sagte: Aber nach ca. 20cm (4s) bleibt er immer wieder stehen.
                            Muss man dem Aktor die Laufzeit vorgeben? Datenpunkt ("TTT"?) dafür ist vorhanden.
                            • Jey Cee
                              Jey Cee Developer @paul53 last edited by
                              @paul53 sagte in Verständnisfrage: Virtuelle Schalter und nutzen in Blockly:
                              Ja muss man.
                                topsurfer @Jey Cee last edited by topsurfer
                                @jey-cee said in Verständnisfrage: Virtuelle Schalter und nutzen in Blockly:
                                Ahhh .... sehe den DP "TTT", wie kann ich den erhöhen oder muss man dem Schalter den TTT Wert mitgeben (wie?)
                                Und auch ein Alias erstellen?
                                Apropos Alias:
                                Muss "Unterschiedliche IDs für Lesen und Schreiben" aktiviert sein,
                                und "Konvertiere beim Schreiben: val ? 1 : 0" targe ich dei allen Aliase ein, korrekt?
                                Hab jetzt gesehen, bei dir haben die Alias Objekte anderen "Rollen" (indicator und level), beir mir immer "state".
                                Kann und muss ich das korrigieren, wenn ja wie/wo?
                                So, ich glaube das reicht für heute - 10 Stunden und zumindest gehen die Rollladen 3s hoch und runter 😉
                                Thx !!!
                                  @topsurfer sagte: Muss "Unterschiedliche IDs für Lesen und Schreiben" aktiviert sein,
                                  Zweimal: Nein. Die Alias-DP sind - wie die Enocean-DP - "read only".
                                  @topsurfer sagte in Verständnisfrage: Virtuelle Schalter und nutzen in Blockly:
                                  Du solltest es korrigieren im Tab "COMMON".
                                  Ich würde mal die Sekunden eingeben, die von geschlossen bis voll offen benötigt werden. Alias braucht man nicht, da es ein konstanter Wert ist.
                                    @paul53 👍
                                    Sieht gut aus,
                                    das mit dem Symbol ist aber auch sehr gut versteckt!
                                    Die drei Punkte habe ich bislang noch nicht gesehen bzw. erkannt! Das ist ja tricky!
                                    Wenn ich dann noch die Rückmeldung über den Rollladen hinbekomme (Bsp: 55%"),
                                    Morgen Aliase anlegen und das noch versuchen.
                                    Ich meld mich falls ich wieder hänge 😉
                                    Thx und G'Nacht
                                      Hab das Blockly Script für die Rückmeldung der Rollladenhöhe importiert und "angepasst", sieht meiner Meinung analog zu deinem richtig aus, aber es wird kein Wert "zurückgegeben".
                                      Hab einem Schieberegler den DP "0_userdata.0.OG.Rollladen.Empore.Position" gegeben, aber der steht immer auf "0"
                                      Was meine Frau mir gerade sagt, wir haben Katzen, und die Rollläden an den 2 Terrassentüren fahren wir manuell immer nur 75% herunter.
                                      Diese Position müßte man "auswählen" können, das "blöde" ist ja, unsere Rollläden keine direkten %-Werte kennen 😞
                                      Eine Schalter / Knopf mit den Optionen:
                                      OBEN
                                      STOP
                                      75%
                                      UNTEN
                                      wäre gut.
                                      Wäre wohl bei uns nur über die Laufzeit einstellbar, wobei die Laufzeit ja je nach aktuellem Stand berechnet werden müßte.
                                      Alternativ könnte man davon ausgehen, das der Rollladen nur über iobroker gesteuert wird und nur in diese drei Position "gefahren" wird.
                                        @topsurfer sagte: Rollladenhöhe importiert und "angepasst"
                                        Den "stop zyklische Ausführung" ist eine falsche Variable zu geordnet! Das passiert leider regelmäßig beim Import.
                                        Anstelle der 40 s oben solltest du die tatsächliche Laufzeit eintragen.
                                        So ist es.
                                          @topsurfer sagte: nur 75% herunter.
                                          Position 25 %?
                                          Oder ist 100 % ganz unten? Dann wäre es umgekehrt zum Skript.
                                            Die Variablen hab ich an den zwei Stellen koggrigiert, den Laufzeit auf korrekte 27s eingestellt.
                                            Was er "macht", wenn ich den Positions-Wert manuell auf 50% Stelle, und Taste hoch drücke: Nichts.
                                            Drücke ich "runter", beginnt der Wert von 50 Richtung 0 zu laufen. Auch wenn ich nach 3s "Stopp" drücke, läuft der Slider (Positions-Wert) bewegt bis auf "0" runter.
                                            Versuche das Blockly-Script zu verstehen, rechts "Um Bewegung mit delta" ist eine Funktion, der man einen Parameter mitgibt (?).
                                            Aber was ist:
                                            Falls => Wert
                                            Wert ist doch nur True" (oder: 1), oder? (von: "Rollladen Empore hoch wurde geändert").
                                            Soll hier dann der "mache ..." Teil nur Ausgeführt werden, wenn es WAHR ist, also Rollladen-hoch-Taste von False auf True gesprungen ist, nicht von: True auf false?
                                            3811
