    4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
      Homoran Global Moderator Administrators @SKB last edited by
      @skb erledigt!
      SKB 1 Reply Last reply Reply Quote 1
      • Elektrofix-OL
        Elektrofix-OL @SKB last edited by
        @skb said in Test Adapter Energiefluss-erweitert v0.6.x GitHub/Latest:
        Nehme die Daten-Quelle für das SVG mal mit auf die Liste.
        Danke, ist nicht so dringend, habe es jetzt im den iob über die configuration gelöst und es funktioniert:
            "elements": {
                "194": {
                    "position": 0,
                    "id": 194,
                    "pos_x": 122.5,
                    "pos_y": 273,
                    "source": 65,
                    "threshold": 0,
                    "frame": "_overlay",
                    "url": "",
                    "action": "none",
                    "shadow": "",
                    "svg_content": "<path d=\"M8.5,38.9c-2.2,0-3.9,1.8-3.9,3.9c0,2.2,1.8,3.9,3.9,3.9c2.2,0,3.9-1.8,3.9-3.9 C12.4,40.7,10.6,38.9,8.5,38.9z M8.5,45.1c-1.3,0-2.3-1-2.3-2.3c0-1.3,1-2.3,2.3-2.3s2.3,1,2.3,2.3C10.8,44.1,9.8,45.1,8.5,45.1z M55.7,38.9c-2.2,0-3.9,1.8-3.9,3.9c0,2.2,1.8,3.9,3.9,3.9c2.2,0,3.9-1.8,3.9-3.9C59.7,40.7,57.9,38.9,55.7,38.9z M55.7,45.1 c-1.3,0-2.3-1-2.3-2.3c0-1.3,1-2.3,2.3-2.3c1.3,0,2.3,1,2.3,2.3C58.1,44.1,57,45.1,55.7,45.1z M60.3,31.2c-0.1-2.5-1.3-5.5-7.9-5.9 L51,25.3c-0.5-0.5-12.6-11.5-20.1-12.1c-1.8-0.1-3.4-0.2-5.1-0.2v0c-0.1,0-0.1,0-0.2,0c-0.9,0-1.9,0-3,0.1 c-3.8,0.2-9.4,0.5-14.7,1.1l-0.1,0c-0.3,0-0.6,0.3-0.7,0.6c0,0-2.4,11-3.5,15.6C-0.8,33.9-0.4,41.7,0.7,45l0,0 c1,3.4,4.1,5.8,7.7,5.8c3.4,0,6.4-2.2,7.5-5.2h32.2c1.2,3,4.1,5.2,7.5,5.2c4.4,0,8-3.6,8.1-8C64.8,34.4,61.7,31.9,60.3,31.2z M23.2,15.1v8.7l-6.4-0.3c0.6-1.7,1.6-3.7,3.1-5.8C20.5,16.9,21.5,15.7,23.2,15.1z M8.6,15.8c0.5-0.1,1.1-0.1,1.6-0.2L8.5,23 c0,0.1-0.4,1.6-1.6,1.6H6.6C7.4,20.9,8.3,17.1,8.6,15.8z M8.5,49.3c-3.6,0-6.5-2.9-6.5-6.5s2.9-6.5,6.5-6.5s6.5,2.9,6.5,6.5 S12,49.3,8.5,49.3z M16.4,44.1c0.1-0.4,0.1-0.8,0.1-1.3c0-4.4-3.6-8.1-8.1-8.1c-2.9,0-5.4,1.6-6.9,3.9c0.2-2.8,1.1-5.6,3.3-7.1 c0,0,0-0.1,0.1-0.1c0.6,0.3,1.4,0.7,2.3,1.4c0.4,0,0.8-0.1,1.2-0.1c0.3,0,0.6,0,0.9,0c0.1,0,0.2,0,0.2,0c0,0-0.1-0.1-0.2-0.2 c-1.5-1.5-3-2.3-4-2.7c0.2-1.1,0.5-2.4,0.8-3.7h0.7c2,0,2.9-1.8,3.2-2.8l1.7-7.9c3.1-0.3,6.1-0.5,8.6-0.6c-0.9,0.7-1.5,1.4-1.8,1.9 c-3.3,4.8-4.6,8.9-3.7,12c0.5,1.6,5,9.6,9.4,12.4c0.5,0.3,1.5,0.8,2.8,0.9c6.5,0.3,18.1,0.5,20.5,0.6c0,0.1,0,0.2,0,0.2 c0,0.4,0,0.9,0.1,1.3H16.4z M55.7,49.3c-3.6,0-6.5-2.9-6.5-6.5s2.9-6.5,6.5-6.5c3.6,0,6.5,2.9,6.5,6.5S59.3,49.3,55.7,49.3z M55.7,34.8c-3.8,0-7,2.7-7.8,6.2c-2,0-14-0.2-20.6-0.6c-1-0.1-1.7-0.4-2.1-0.6c-4-2.5-8.4-10.1-8.8-11.5c-0.3-0.9-0.3-2,0-3.2 l24.2,1.3l-0.1,1.3l1.6,0.1l0.3-5.4l-1.6-0.1l-0.2,2.4l-15.9-0.8v-9.2c0.2,0,0.5,0,0.7-0.1c1.8,0,3.4,0,5.3,0.2 c5.5,0.4,14.1,7.4,17.6,10.3l-4-0.2l-0.1,1.6l8,0.4c5.6,0.3,6.3,2.5,6.4,4.9c0,0.4,0.3,0.7,0.6,0.8c0,0,2.5,0.8,3,5.6 C60.8,36.1,58.5,34.8,55.7,34.8z\" fill=rgb(215,215,215)></path>",
                    "subType": "svg",
                    "type": "svg",
                    "width": 115,
                    "height": 100,
                    "viewBox": "0 0 75 65",
                    "override": {
                        "0": {
                            "display": "none"
                        "1": {
                            "display": "block"
        Zeile 7, 19-26 geändert
        • SKB
          SKB Developer Most Active @Homoran last edited by
          @homoran perfekt. Danke! Habe den Titel wie @mcm1957 meinte, angepasst 😉
          Elektrofix-OL 1 Reply Last reply Reply Quote 1
          • Elektrofix-OL
            Elektrofix-OL @SKB last edited by Elektrofix-OL
            Ich habe da vielleicht einen Bug, und hoffe das er in diesem Verlauf reingehört.
            So sollte im normalfall die Seite aussehen
            aber von Zeit zu Zeit werden mir die Elemente angezeigt, die jetzt ausgeblendet sein sollen, oder eine Farbe bekommen. Es scheint so, als ob die Überschreibungen vom Broser nicht umgesetzt werden.
            Dabei ist es egal ob die Überschreibung ein "display": "block" oder ein "fontSize": 11 und "fill": "#D7D7D7" beinhaltet.
            Das Phänomen tritt seit der 0.6.2 mehrfach auf und ist bei Chrome, iOS und Android vorhanden. Ein Neuladen der Seite lässt die Anzeige wieder wie gewünscht erscheinen. Die Seite läuft in einem iFrame von Grafana.
            • SKB
              SKB Developer Most Active @Elektrofix-OL last edited by
              @elektrofix-ol Und, was genau soll auf der Seite ausgeblendet sein? Es wäre schon sehr hilfreich, wenn die Daten zu den Elementen vorliegen bzw. diese markiert sind.
              Elektrofix-OL 1 Reply Last reply Reply Quote 0
              • Elektrofix-OL
                @skb Es soll ausgeblendet werden, wird es jedoch nicht. Die obere Grafik zeigt den Soll, die unter den Fehlerfall an, der regelmäßig von den Browsern angezeigt wird, bis ich die Seite neu lade.
                Bei Fehlerfall werden folgendes nicht verändert:
                • ID60+ID61 die unteren Werte der PV-Garage die -2147483648W
                • ID128+IS129 die Texte geladen in / entladen in bei der Batterie
                • das blaue Feld (ID171) mit dem Auto(ID23), der 0W (ID172) und L1, L2, L3 (ID173-175)
                • das weiße Feld (ID185) hinter der 0.00 bei dem roten Kreise (Waschen, Trockner, Spülmaschine)
                • die grünen und blauen User-Ikon (ID178-180+ID183), in den rechteckigen Bahn, Straße und Baum hätte hier ausgeblendet werden müssen (aber auch ID181+182 sind mal an der Reihe, je nach dem wer Anwesen ist)
                • das SVG-Element (ID194) vom Smart, wo die 98% sind
                • Das Rechteck (ID28) mit Garage und Palme
                • die Kreise Waschen (ID95), Trockner(ID99), Spülmaschine (ID90)
                  LOG-Protokollausgabe.txt
                Ich bin mir unsicher, ob ich die Grenzen des Adapters erreicht habe, oder ich nur was pfuschig programmiert habe und es eine bessere Herangehensweise gibt, um diese Dinge zu verändern.
                Du hast einen echt geilen Adapter geschaffen, den ich nicht mehr missen möchte! Vielen Dank dafür!!
                • SKB
                  SKB Developer Most Active @Elektrofix-OL last edited by SKB
                  @elektrofix-ol Können wir uns vielleicht auf ein Element beschränken? Das wird die Sache ziemlich vereinfachen - denn die anderen Elemente werden ja ähnlich "falsch" sein.
                  Also, such dir ein Element aus, was nicht funktioniert und stelle die Daten dazu ein.
                  Der Adapter selbst kennt keine Grenzen - nur das Endgerät, welches den EF anzeigt.
                  • Elektrofix-OL
                    Das Rechteck (ID28) mit Garage und Palme, weil es ohne Override ist
                    Die Daten hatte ich im Post schon eingestellt LOG-Protokollausgabe.txt oder brauchst Du etwas anderes?
                    Ist das Endgerät der Browser oder Grafana, weil es den iFrame macht?
                    • SKB
                      SKB Developer Most Active last edited by
                      @elektrofix-ol Also, ich durchforste jetzt nicht deine gesamte Konfiguration 😉
                      Bitte nur die Daten zu dem entsprechenden Element - dies macht Vieles einfacher.
                      • Elektrofix-OL
                        @skb Wollte nur sichergehen das Dir zur Analyse nichts fehlt, daher hatte ich alles kopiert 😉
                        Hatte gerade wieder diese Fehlerfall in Chrome, aber nur die Objekte mit Override waren betroffen. 🙄 Villeicht hilft Dir die Information.
                        Habe Dir jetzt zwei Objekte in die Datei kopiert mit den Datenquellen, eine mit und die andere ohne Override
                        28-180.txt
                        • I
                          Int17 @Elektrofix-OL last edited by
                          @SKB
                          Löscht man den Wert eines Feldes, wird kurz danach die 1. Zahl selbständig wieder hergestellt.
                          Ist das gewollt?
                          Siehe Video auf magentacloud
                          • SKB
                            SKB Developer Most Active @Int17 last edited by
                            @int17 natürlich. Ein Feld kann keine Höhe von 0 oder nichts haben. Dann wird der letzte gültige Wert wiederhergestellt.
                            • I
                              Int17 @SKB last edited by
                              @skb wie zu sehen gehe ich mit Backspace zurück und muss mich sputen, sonst setzt du den alten Wert wieder rein. Wenn das aber gewollt ist, auch ok.
                              • SKB
                                @int17 Hier muss sich keiner sputen - man kann die Zahlen markieren und dann "drüber" tippen oder man nutzt die Pfeile des Nummernfeldes, um dieses zu erhöhen oder zu verringern.
                                • I
                                  Int17 @SKB last edited by Int17
                                  @skb Üblicherweise prüft man die Eingabe erst dann, wenn das Feld verlassen wird. Aber es ist dein Programm und wenn du die Prüfung so besser findest, ist es auch ok.
                                  Aufgefallen ist mir auch, dass nach der (Neu-)Installation des Adapters, du das Backupverz. nicht einließt.
                                  Erst wenn man die Grundkonfiguration gespeichert hat, wird es korrekt angezeigt.
                                  Ist aber vielleicht auch gewollt.
                                  Bei dem Schwellwert lässt du nur ganze Zahlen zu. ich habe einen Aktor, der verbraucht
                                  Um die Animation korrekt starten zu lassen, klappt das so nicht.
                                  Darf ich als Laie noch fragen, wie man den Hintergrund farblich gestalten kann? Hätte gerne was dunkleres.
                                  • SKB
                                    @int17 sagte in Test Adapter Energiefluss-erweitert v0.6.x GitHub/Latest:
                                    "Üblicherweise" wird die Eingabe eines Feldes dem Anwendungsfall nach geprüft. Hier macht eine Prüfung nach dem Verlassen des Feldes keinen Sinn - wenn der Wert leer ist, ist das Element "verschwunden". Somit wird der letzte gültige Wert wiederhergestellt.
                                    Das ist dir gut aufgefallen - werde ich korrigieren.
                                    Der Schwellenwert unterstützt ganze Wattwerte - wenn du allerdings 0,25 eintragen möchtest, geht dies mit einem Punkt . -> 0.25. Das Feld wird zwar rot - jedoch wird der Wert passend übernommen.
                                    In den Einstellungen lässt sich eine Hintergrundfarbe festlegen. Sollten hier andere Dinge (Bilder, o.ä.) gewünscht sein - so ist der Tab "Stile" zu benutzen und mit CSS zu arbeiten.
                                    • I
                                      @skb Schwellwert: Der Wert wird rot wie du sagst, aber er wird nicht gespeichert. Nach erneutem Öffnen steht wieder eine 0 drin.
                                      • SKB
                                        @int17 Mir ist zwar schleierhaft, wieso man einen Wert von unter 1 Watt grafisch darstellen möchte - aber gut, ich kann den Schwellenwert in der nächsten Version auch niedriger setzen.
                                        • I
                                          @skb Dies ist der Ruheverbrauch eines Homematic Relais, womit ich die Waschmaschine ein/ausschalte. Ich will erreichen, dass der Verbinder diesen Verbrauch nicht anzeigt. Die Waschmaschine braucht in Standby 1 Watt. Somit fände ich deine Änderung hilfreich. Danke.
                                          • SKB
                                            SKB Developer Most Active @Int17 last edited by SKB
                                            @int17 Und, wieso setzt du dann den Schwellenwert nicht auf 1?
                                            Dann ist alles unter 1 aus bzw. nicht animiert/aktiv und über oder gleich 1 eben aktiv/animiert.
                                            81.1k
                                            diagramm energiefluss energiefluss-erweitert vis visualisierung visualization
                                            65
                                            1412
                                            740961
