    4. Test Adapter Hoymiles-wifi
      Schorsch @Michael 6 last edited by
      @michael-6 Hey, ich habe mir auch deine Seiten in github angesehen und die gleiche Fehlermeldung "externally-managed-environment" erhalten. Soweit ich es überblicke, muss bei bookworm nicht pip install sondern pipx install verwendet werden. Ebenso habe ich die Installation als User "iobroker" durchgeführt.
      sudo -H -u iobroker pipx install hoymiles-wifi
      Vielleicht willst du es einmal überprüfen und dein github ggf. aktualisieren.
      Vielen Dank für den Adapter.
      • I
        iobrokerle @Schorsch last edited by
        ich bekommen den nicht installiert. Siehe Clipboard:
        admin@iobroker:~ $ sudo -H -u iobroker pipx install hoymiles-wifi
        sudo: pipx: command not found
        admin@iobroker:~ $ sudo -H -u iobroker pip install hoymiles-wifi
        error: externally-managed-environment
        × This environment is externally managed
        ╰─> To install Python packages system-wide, try apt install
            python3-xyz, where xyz is the package you are trying to
            install.
            If you wish to install a non-Debian-packaged Python package,
            create a virtual environment using python3 -m venv path/to/venv.
            Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
            sure you have python3-full installed.
            For more information visit http://rptl.io/venv
        note: If you believe this is a mistake, please contact your Python installation                        or OS distribution provider. You can override this, at the risk of breaking your                        Python installation or OS, by passing --break-system-packages.
        hint: See PEP 668 for the detailed specification.
        admin@iobroker:~ $ sudo -H -u iobroker pip install hoymiles-wifi --break-system-                       package
        Defaulting to user installation because normal site-packages is not writeable
        Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
        Requirement already satisfied: hoymiles-wifi in /usr/local/lib/python3.11/dist-p                       ackages (0.3.2)
        Requirement already satisfied: protobuf in /usr/local/lib/python3.11/dist-packag                       es (from hoymiles-wifi) (5.29.3)
        Requirement already satisfied: crcmod in /usr/local/lib/python3.11/dist-packages                        (from hoymiles-wifi) (1.7)
        admin@iobroker:~ $ sudo pipx install hoymiles-wifi --break-system-packages
        Was mache ich falsch?
          Thomas Braun Most Active @iobrokerle last edited by Thomas Braun
          @iobrokerle sagte in Hoymiles hms-800w-2t:
          Wohl nicht installiert.
          apt policy pipx
          sagt? Wenn nicht installiert, nachinstallieren.
          • I
            iobrokerle @Thomas Braun last edited by
            @thomas-braun sagte in Hoymiles hms-800w-2t:
            apt policy pipx
            ja, fehlt 😨
            installieren mit: pip install --user pipx oder pip install pipx
              Weder noch.
              sudo apt update
              sudo apt install pipx
              • I
                iobrokerle @Thomas Braun last edited by iobrokerle
                ok danke. ist durchgelaufen. anschließend auch: pipx install hoymiles-wifi
                was aber immer noch im iobroker protkoll kommt:
                stderr: /bin/sh: 1: hoymiles-wifi: Permission denied
                Gibts hierfür auch noch einen fix ☺
                  @iobrokerle
                  Da musst du mal sagen wann genau die Meldung kommt und wie dir Rechte da nun genau aussehen.
                  • I
                    @thomas-braun immer wenn er versucht den adapter abzufragen, nehme ich an.
                    Das der WR aktuell aus ist, ist mir bewusst. Das kam aber auch schon heute Mittag bevor ich das alles richtig installiert habe.
                    • mcm1957
                      mcm1957 last edited by
                      Da dieses Topic NICHT im Testerbereich ist eine WARNUNG an alle "Standardnutzer":
                      Da dieser Adapter zumindest derzeit noch nicht in die Repositories aufgenommen wurde und auch noch kein Review angeregt wurde bitte beachten:
                      Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                      GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                      Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                      Adapter die nur via GitHub installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                        Michael 6 @mcm1957 last edited by
                        @mcm1957 Ja, das Grundproblem mit diesem Adapter ist, dass https://github.com/suaveolent/hoymiles-wifi (Python) installiert und für den User iobroker verfügbar (PATH) gemacht werden darf.
                        Der Adapter führt 'lediglich' hoymiles-wifi per bash aus und sichert die JSON-Ergebnisse als Objekte.
                        Das ist auch bei Version 0.2.0 geblieben.
                          Michael 6 @Michael 6 last edited by
                          Es gibt nun ein Update auf Version 0.2.0: https://github.com/MicHi07i/ioBroker.hoymiles-wifi/
                          Änderung 1:
                          Es gibt nun 3 Optionen bzgl. Pausieren der Abfragen:
                          a) dauerhaft (auch nachts , wenn das Gerät ohne IP-Adresse ist),
                          b) nachts pausiert, wenn System-Befehl PING erfolglos bleibt (braucht Befehl PING),
                          c) nachts pausiert, wenn ioBroker Adapter PING erfolglos bleibt (braucht Objekt aus Adapter PING).
                          Änderung2:
                          Es können Werte geschrieben werden, dazu sollte die Option "get-real-data-new" verwendet werden.
                          a) get_real_data_new.sgsData.0.powerLimit - zum Begrenzen (ganze Zahlen, 2-100)
                          b) hoymiles-wifi.0.DtuRestart - Button zum Neustart der DTU
                          c) hoymiles-wifi.0.InverterOn bzw InverterOff - schaltet Inverter an und aus.
                          Bitte mit Vorsicht genießen.
                          Ich freue mich auf Rückmeldungen.
                            Michael 6 @iobrokerle last edited by
                            @iobrokerle
                            das Logfile sagt mir, dass entweder https://github.com/suaveolent/hoymiles-wifi nicht installiert wurde oder zumindest vom user iobroker ($PATH-Problem -> sudo -H -u iobroker pipx install hoymiles-wifi; Pfad /etc/profile in der Path-Variable einzutragen) nicht gefunden wird.
                            • mcm1957
                              mcm1957 @Michael 6 last edited by mcm1957
                              Da dieser Adapter zumindest derzeit noch nicht in die Repositories aufgenommen wurde, einige stanadardmäßig erfroderlichen Teile (z.B. Tests) fehlen und auch noch kein Review angeregt wurde bitte beachten:
                                @mcm1957
                                Wie können wir dieses Topic in den Testerbereich verschieben?
                                  Homoran Global Moderator Administrators @Michael 6 last edited by
                                  @michael-6 warum?
                                  der Eröffnungspost dieses Threads zeigt für mich keinerlei Hinweise, dass hier ein Adapter getestet werden soll.
                                  um welchen Adapter geht es denn?
                                    Michael 6 @Homoran last edited by
                                    hoymiles-wifi (https://github.com/MicHi07i/ioBroker.hoymiles-wifi/)
                                    Der Adapter steuert lediglich per bash ein gleichnamiges Pythonprogramm (https://github.com/suaveolent/hoymiles-wifi) und schreibt Werte als Objekte in den ioBroker, kann nun auch angesteuert werden, zum Beispiel um den Inverter der Fa. Hoymiles neu zu starten.
                                    Ja, es gibt für Hoymiles bereits einen Adapter, aber nicht für die Serie mit internem Wifi; daher dieser Workaround.
                                    Sorry, das war mein Erstlingswerk, daher wusste ich nicht wo/wie darüber geschrieben werden könnte/sollte.
                                    Homoran mcm1957 2 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @Michael 6 last edited by Homoran
                                      @michael-6 ok, dann versuchen wir das Ganze mal "professionell" anzugehen.
                                      Ab welchem Post geht es denn um den Adapter.
                                      Das trenne ich dann ab und schiebe das nach "Tester"
                                      Der erste Post sollte dabei von dir sein, weil...
                                      • im ersten Post eines Tests gewisse Informationen stehen sollten
                                        • und du daher den "neuen" Eröffnungspost entsprechend modifizieren müsstest
                                      Ich würde anschließend unter dem letzten verbleibenden Post einen Link zum "neuen" Thread posten
                                      • mcm1957
                                        @michael-6 said in Hoymiles hms-800w-2t:
                                        Am besten eröffne im TESTER Bereich ein Topic. Da wird dir dann eh ein Template angezeigt.
                                        Titel sollte (in etwa) sein: Test Adapter xxxxx. Drunter dann die übliche Tabelle wie im Template un in zig anderen Beiträgen.
                                        Als Text reicht mal so was
                                        "Topic betreffend test des Adapters xxxx." Das kannst dann später immer wieder editieren,. Typisch steht im ersten Betrag die aktuelle Version und die Releasenotes jeweils aktualisisert wenn sich was tut
                                        Homoran kann dann die hier leigenden Beiträge dort rüberschieben
                                        mcm1957 Homoran 2 Replies Last reply Reply Quote 0
                                        • mcm1957
                                          mcm1957 @mcm1957 last edited by mcm1957
                                          Und danke dass dunbisher noch rudimentären Adapter offensichtlich "reporeif" machen willst und vor allem dass du Zeit und WIssen für einen ioBroker Adapter aufwendest.
                                          Bei Fragen dazu jederzeit melden. Diskussion zur Adapterentwicklung bitte primär in unseren Telegramm / Discord channels. Invites dazu auf https:// www.iobroker.dev.
                                            Homoran Global Moderator Administrators @mcm1957 last edited by
                                            @mcm1957 sagte in Hoymiles hms-800w-2t:
                                            eben nicht!
                                            wenn der neue Starpodt jünger als die zu schiebenden Posts ist, geht das nicht.
                                            85
                                            27822
