    4. Hilfe beim Programmieren mit Arduino
    • Thisoft
      Thisoft last edited by
      hmm - sollten wir hinbekommen. Ich hab paar so Dinger laufen 😉
      Wo genau ist dein Problem?
        HauptstadtRocker last edited by
        guck mal ich habe diesen Sketch hier und da würde ich gerne MQTT einbinden um das letzendlich über den ioBroker zu steuern und es im VIS anzeigen zu lassen.
        das ist der code:
           Code for controlling RGB Strip using Amazon Echo and NodeMCU
           Written by Sid for Sid's E Classroom
           https://www.youtube.com/c/SidsEClassroom
        #include <arduino.h>
        #include <esp8266wifi.h>
        #include "fauxmoESP.h"
        #include <adafruit_neopixel.h>
        #define WIFI_SSID "***********"//Set your Wifi name
        #define WIFI_PASS "**********"//Set your Wifi Password
        #define SERIAL_BAUDRATE                 115200
        fauxmoESP fauxmo;
        //declare switching pins
        #define RGBCTL D7 //Change pins according to your NodeMCU/ESP pinouts
        int numPixels = 41;
        int i;
        //Pixel initialization for Google's Colours
        //Divide the total number of pixels in the stip by 4 and set pixel increments starting from zero
        //If num of Pixels is not perfectly divisible by 4, consider the nearest multiple of 4
        //eg: 28 in case of 29,30 and 31 pixels, 32 in case of 33,34 and 35 pixels.
        int start1 = 0;
        int start2 = 3;
        int start3 = 6;
        int start4 = 9;
        // Parameter 1 = number of pixels in strip
        // Parameter 2 = Arduino pin number (most are valid)
        // Parameter 3 = pixel type flags, add together as needed:
        //   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
        //   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
        //   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
        //   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
        //   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
        Adafruit_NeoPixel strip = Adafruit_NeoPixel(numPixels, RGBCTL,NEO_RGB + NEO_KHZ800);
        // Wifi Setup
        void wifiSetup() {
          // Set WIFI module to STA mode
          WiFi.mode(WIFI_STA);
          // Connect
          Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
          WiFi.begin(WIFI_SSID, WIFI_PASS);
          // Wait
          while (WiFi.status() != WL_CONNECTED) {
            Serial.print(".");
            delay(100);
          Serial.println();
          // Connected!
          Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
          Serial.println("Nach der Verbindung mit %s, sag Alexa 'Schalte <devicename> An' oder 'Aus'");
        // Device callback and printing response in serial monitor
        void callback(uint8_t device_id, const char * device_name, bool state) {
          Serial.print("Device "); Serial.print(device_name);
          Serial.print(" state: ");
          if (state) {
            Serial.println("ON");
          } else {
            Serial.println("OFF");
          //Switching action on detection of device name
          //Turns strip RED
          if ( (strcmp(device_name, "Rot") == 0) ) {
            if (state) {
              i = 1;
            else {
              allOff();
              i = 0;
          //Turns strip GREEN
          if ( (strcmp(device_name, "Grün") == 0) ) {
            if (state) {
              i = 2;
            else {
              allOff();
              i = 0;
          //Turns strip BLUE
          if ( (strcmp(device_name, "Blau") == 0) ) {
            if (state) {
              i = 3;
            else {
              allOff();
              i = 0;
          //RAINBOW pattern on the strip
          if ( (strcmp(device_name, "Regenbogen") == 0) ) {
            if (state) {
              i = 8;
            else {
              allOff();
              i = 0;
          //Turns strip WHITE
          if ( (strcmp(device_name, "STRIPE") == 0) ) {
            if (state) {
              i = 4;
            else {
              allOff();
              i = 0;
          //Turns strip into Google's colours
          if ( (strcmp(device_name, "GOOGLE LIGHTS") == 0) ) {
            if (state) {
              i = 9;
            else {
              allOff();
              i = 0;
          //Turns strip into Pink colours
          if ( (strcmp(device_name, "Pink") == 0) ) {
            if (state) {
              i = 11;
            else {
              allOff();
              i = 0;
          if ( (strcmp(device_name, "Violet") == 0) ) {
            if (state) {
              i = 12;
            else {
              allOff();
              i = 0;
          if ( (strcmp(device_name, "50") == 0) ) {
            if (state) {
              i = 13;
            else {
              allOff();
              i = 0;
        void setup() {
          //Initialize pins to Low on device start
          pinMode(RGBCTL, OUTPUT);
          digitalWrite(RGBCTL, LOW);
          // Init serial port and clean garbage
          Serial.begin(SERIAL_BAUDRATE);
          Serial.println("FauxMo demo sketch");
          // Wifi
          wifiSetup();
          // Device Names for RGB Patterns
          i = 0;
          fauxmo.addDevice("Rot");
          fauxmo.addDevice("Grün");
          fauxmo.addDevice("Blau");
          fauxmo.addDevice("Regenbogen");
          fauxmo.addDevice("STRIPE");
          fauxmo.addDevice("GOOGLE LIGHTS");
          fauxmo.addDevice("Pink");
          fauxmo.addDevice("Violet");
          fauxmo.addDevice("50");
          fauxmo.onMessage(callback);
          strip.begin();
          strip.show();
          strip.setBrightness(100);
        void loop() {
          fauxmo.handle();
          startShow(i);
        //Case for strip patterns. Add a new case or pattern if you wish
        void startShow(int i) {
          switch (i) {
            case 0: colorWipe(strip.Color(0, 0, 0), 50);          // Black/Off
              break;
            case 1: colorWipe(strip.Color(255, 0, 0), 50);        // Red
              break;
            case 2: colorWipe(strip.Color(0, 255, 0), 50);        // Green
              break;
            case 3: colorWipe(strip.Color(0, 0, 255), 50);        // Blue
              break;
            case 4: colorWipe(strip.Color(255, 255, 255), 20);    // White
              break;
            case 5: theaterChase(strip.Color(127, 127, 127), 50); // White Chase
              break;
            case 6: theaterChase(strip.Color(127,   0,   0), 50); // Red Chase
              break;
            case 7: theaterChase(strip.Color(  0,   0, 127), 50); // Blue Chase
              break;
            case 8: rainbow(20);
              break;
            case 9: google();
              break;
            case 10: theaterChaseRainbow(50);
              break;
            case 11: colorWipe(strip.Color(  199, 21, 133), 50); // Pink
              break;
            case 12: colorWipe(strip.Color( 255, 0, 255), 50); // Violett
              break;
            case 13: strip.setBrightness(50); // Violett
              break;
        // Fill the dots one after the other with a color
        void colorWipe(uint32_t c, uint8_t wait) {
          for (uint16_t i = 0; i < strip.numPixels(); i++) {
            strip.setPixelColor(i, c);
            strip.show();
            delay(wait);
        //Rainbow pattern
        void rainbow(uint8_t wait) {
          uint16_t i, j;
          for (j = 0; j < 256; j++) {
            for (i = 0; i < strip.numPixels(); i++) {
              strip.setPixelColor(i, Wheel((i + j) & 255));
            strip.show();
            delay(wait);
        //Rainbow equally distributed throughout
        void rainbowCycle(uint8_t wait) {
          uint16_t i, j;
          for (j = 0; j < 256 * 5; j++) { // 5 cycles of all colors on wheel
              strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
            strip.show();
            delay(wait);
        //Theatre-style crawling lights
        void theaterChase(uint32_t c, uint8_t wait) {
          for (int j = 0; j < 10; j++) { //do 10 cycles of chasing
            for (int q = 0; q < 3; q++) {
              for (int i = 0; i < strip.numPixels(); i = i + 3) {
                strip.setPixelColor(i + q, c);  //turn every third pixel on
              strip.show();
              delay(wait);
                strip.setPixelColor(i + q, 0);      //turn every third pixel off
        //Theatre-style crawling lights with rainbow effect
        void theaterChaseRainbow(uint8_t wait) {
          for (int j = 0; j < 256; j++) {   // cycle all 256 colors in the wheel
                strip.setPixelColor(i + q, Wheel( (i + j) % 255)); //turn every third pixel on
              strip.show();
              delay(wait);
        //Fill strip with Google's Colour
        void google() {
          //Set initial couple of pixels to match Google Blue
          for ( int i = 0; i < 0 + 10; i++ ) {
            strip.setPixelColor(i, 66, 133, 244 );
          //Set initial couple of pixels to match Google Red
          // next 3 pixels = color set #2
          for ( int i = 10; i < 10 + 10 ; i++ ) {
            strip.setPixelColor(i, 234, 67, 53 );
          //Set initial couple of pixels to match Google Orange
          // next 3 pixels = color set #3
          for ( int i = 20; i < 20 + 10; i++ ) {
            strip.setPixelColor(i, 251, 188, 5 );
          //Set initial couple of pixels to match Google Green
          // last 3 pixels = color set #3
          for ( int i = 30; i < 30 + 10; i++ ) {
            strip.setPixelColor(i, 52, 168, 83 );
          strip.show();
        //Turns all pixels OFF
        void allOff() {
          for ( int i = 0; i < numPixels; i++ ) {
            strip.setPixelColor(i, 0, 0, 0 );
          strip.show();
        // Input a value 0 to 255 to get a color value.
        // The colours are a transition r - g - b - back to r.
        uint32_t Wheel(byte WheelPos) {
          WheelPos = 255 - WheelPos;
          if (WheelPos < 85) {
            return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
          if (WheelPos < 170) {
            WheelPos -= 85;
            return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
          WheelPos -= 170;
          return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
        }</devicename></adafruit_neopixel.h></esp8266wifi.h></arduino.h>
        • Thisoft
          so, ich hab mal das Grundgerüst in deinen Sketch eingebaut. Damit sollte sich dein ESP erstmal beim ioBroker anmelden und einen State "Color" anlegen.
          Kommst du mit der Arduino-Programmierung soweit zurecht um da selber noch das ein oder andere anzupassen etc.? Weil - ich hab das ja sozusagen "blind" geschrieben, könnte mal noch ein Tippfehler drin sein. Und wenn das Anmelden klappt dann muss das ja noch weiter ausgebaut werden, sinnvolle Werte in den States übertragen, Callback-Funktion einbauen für die Steuerung ioBroker->ESP usw. und da wird's dann langsam kritisch wenn ich nichts testen kann…
          #include <pubsubclient.h>
          ! #define WIFI_SSID "
          #define WIFI_PASS "
          ! //// MQTT-Settings
          IPAddress mqtt_server(192, 168, xxx, xxx); // IP-MQTT-Broker
          const char
          mqtt_username = "ioBroker"; // MQTT-User
          const char
          mqtt_key = "iobroker"; // MQTT-Password
          PubSubClient mqttClient(mqtt_server,1883);
          ! #define BASE "RGBbyESP" // <---------------!!Entsprechend f�r jeden Sensor anpassen!!
          #define mqtt_client_id BASE
          #define mqtt_topics_ip BASE "/IP"
          #define mqtt_topics_color BASE "/Color"
          ! char message_color[20];
          ///// End MQTT-Settings
          ! fauxmoESP fauxmo;
          ! int numPixels = 41;
          int i;
          int start1 = 0;
          int start2 = 3;
          int start3 = 6;
          int start4 = 9;
          ! // Parameter 1 = number of pixels in strip
          // Wifi Setup
          ! void wifiSetup() {
          !   // Set WIFI module to STA mode
          !   // Connect
          !   // Wait
              Serial.print(".");
              delay(100);
            Serial.println();
          !   // Connected!
            if (state) {
            } else {
          !   //Turns strip RED
              if (state) {
                i = 1;
              else {
                allOff();
                i = 0;
            //Turns strip GREEN
              if (state) {
                i = 2;
              else {
                allOff();
                i = 0;
            //Turns strip BLUE
              if (state) {
                i = 3;
              else {
                allOff();
                i = 0;
              if (state) {
                i = 8;
              else {
                allOff();
                i = 0;
            //Turns strip WHITE
              if (state) {
                i = 4;
              else {
                allOff();
                i = 0;
              if (state) {
                i = 9;
              else {
                allOff();
                i = 0;
              if (state) {
                i = 11;
              else {
                allOff();
                i = 0;
              if (state) {
                i = 12;
              else {
                allOff();
                i = 0;
              if (state) {
                i = 13;
              else {
                allOff();
                i = 0;
          ! void connect_MQTT() {
          Serial.print("Attempting MQTT connection...");
          // Attempt to connect
          if (mqttClient.connect(mqtt_client_id,mqtt_username,mqtt_key)) {
          Serial.println("MQTT connected");
          // IP-Adresse umwandeln und publish
          IPAddress localAddr = ip;
          char s[16];
          sprintf(s, "%d.%d.%d.%d", localAddr[0], localAddr[1], localAddr[2], localAddr[3]);
          Serial.println("MQTT publish: " + String(s));
          mqttClient.publish(mqtt_topics_ip,s);
          } else {
          Serial.print("failed, rc=");
          Serial.println(mqttClient.state());
          ! void setup() {
          !   // Init serial port and clean garbage
          !   // Wifi
            wifiSetup();
          ! //MQTT
          mqttClient.setServer(mqtt_server, 1883);
          mqttClient.setCallback(callback);
          if (!mqttClient.connected()) {
          connect_MQTT();
          String Null_String = "0";
          Null_String.toCharArray(message_red, Null_String.length()+1);
          mqttClient.subscribe("#/"+BASE+"/#");
          mqttClient.publish(mqtt_topics_color,message_color);
          !   // Device Names for RGB Patterns
          i = 0;
          strip.begin();
            strip.show();
          ! void loop() {
          mqttClient.loop();//MQTT
            fauxmo.handle();
            startShow(i);
          ! //Case for strip patterns. Add a new case or pattern if you wish
            switch (i) {
                break;
                break;
                break;
                break;
                break;
                break;
                break;
                break;
                break;
              case 9: google();
                break;
                break;
                break;
                break;
                break;
          ! // Fill the dots one after the other with a color
              strip.show();
              delay(wait);
          //Rainbow pattern
            uint16_t i, j;
          !   for (j = 0; j < 256; j++) {
              strip.show();
              delay(wait);
            uint16_t i, j;
          !   for (j = 0; j < 256 * 5; j++) { // 5 cycles of all colors on wheel
              strip.show();
              delay(wait);
                strip.show();
          !       delay(wait);
          !       for (int i = 0; i < strip.numPixels(); i = i + 3) {
                strip.show();
          !       delay(wait);
          void google() {
          !   strip.show();
          void allOff() {
            strip.show();
          ! // Input a value 0 to 255 to get a color value.
              WheelPos -= 85;
            WheelPos -= 170;
          }</devicename></pubsubclient.h></adafruit_neopixel.h></esp8266wifi.h></arduino.h>
            Hallo Thisoft,
            leider hatte ich noch nicht die zeit das zu testen. ich habe gestern Abend mal schnell meine Daten eingegeben und den Sketch versucht zu kompilieren und leider lag da schon ein Fehler vor. Mir fehlen bis jetzt auch die Kenntnisse um das alleine zu Programmieren. Meine bisherigen Projekte habe ich immer mehr mit glück zusammen bekommen als können. Damit möchte ich sagen das ich wahrscheinlich nicht alleine klar komme.
            Wenn ich es heute abend schaffe kann ich gerne mal den Fehler posten. Ich selber werde parallel versuchen den Fehler zu verstehen.
            Ich danke Dir trotzdem sehr das du mir hilfst. das ist leider nicht mehr so normal sonder eher eine seltenheit…..
            NOCHMALS FETTES DANKESCHÖN
            • Thisoft
              kannst ja einfach mal den Kompilierfehler posten. Bei mir ist zumindest die Syntaxprüfung ohne Fehler durchgelaufen, deshalb sagt meine Glaskugel dass der Fehler deshalb kommen könnte weil du die Library für den MQTT-Client nicht in deiner Arduino-IDE installiert hast. Würde dann die Codezeile
              #include
              betreffen. Wenn das so sein sollte musst du einfach mal noch mit Hilfe von Tante Google diese Library installieren 😉 Keine Angst - das ist nur beim ersten Mal ein Problem :lol:
                Soo ich habe es mal schnell kompiliert und das ist der Fehler.
                Er wird in Zeile 20 angezeigt:
                ~~![](</s><URL url=)<link_text text="http://forum.iobroker.net/download/file ... 2428fa57b1">http://forum.iobroker.net/download/file.php?mode=view&id=20077&sid=5c726fdb951608500e66292428fa57b1</link_text>" />
                Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "WeMos D1 R2 & mini, 80 MHz, 921600, 4M (3M SPIFFS)"
                ! ws2812_iobroker:20: error: no matching function for call to 'PubSubClient::PubSubClient(IPAddress&, int)'
                ! PubSubClient mqttClient(mqtt_server,1883);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:20:41: note: candidates are:
                ! In file included from C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:10:0:
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:116:4: note: PubSubClient::PubSubClient(const char*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&, Stream&)
                ! PubSubClient(const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:116:4: note: candidate expects 5 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:4: note: PubSubClient::PubSubClient(const char*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&)
                ! PubSubClient(const char*, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:115:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:4: note: PubSubClient::PubSubClient(const char*, uint16_t, Client&, Stream&)
                ! PubSubClient(const char*, uint16_t, Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:114:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:4: note: PubSubClient::PubSubClient(const char*, uint16_t, Client&)
                ! PubSubClient(const char*, uint16_t, Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:113:4: note: candidate expects 3 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:4: note: PubSubClient::PubSubClient(uint8_t*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&, Stream&)
                ! PubSubClient(uint8_t , uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:112:4: note: candidate expects 5 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:111:4: note: PubSubClient::PubSubClient(uint8_t
                ! PubSubClient(uint8_t , uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:111:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:110:4: note: PubSubClient::PubSubClient(uint8_t
                ! PubSubClient(uint8_t , uint16_t, Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:110:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:109:4: note: PubSubClient::PubSubClient(uint8_t
                ! PubSubClient(uint8_t , uint16_t, Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:109:4: note: candidate expects 3 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:108:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, std::function<void(char
                ! PubSubClient(IPAddress, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:108:4: note: candidate expects 5 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:107:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&)
                ! PubSubClient(IPAddress, uint16_t, MQTT_CALLBACK_SIGNATURE,Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:107:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:106:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, Client&, Stream&)
                ! PubSubClient(IPAddress, uint16_t, Client& client, Stream&);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:106:4: note: candidate expects 4 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:105:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, Client&)
                ! PubSubClient(IPAddress, uint16_t, Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:105:4: note: candidate expects 3 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:104:4: note: PubSubClient::PubSubClient(Client&)
                ! PubSubClient(Client& client);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:104:4: note: candidate expects 1 argument, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:103:4: note: PubSubClient::PubSubClient()
                ! PubSubClient();
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:103:4: note: candidate expects 0 arguments, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:83:7: note: PubSubClient::PubSubClient(const PubSubClient&)
                ! class PubSubClient {
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:83:7: note: candidate expects 1 argument, 2 provided
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:83:7: note: PubSubClient::PubSubClient(PubSubClient&&)
                ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino: In function 'void connect_MQTT()':
                ! ws2812_iobroker:193: error: 'ip' was not declared in this scope
                ! IPAddress localAddr = ip;
                ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino: In function 'void setup()':
                ! ws2812_iobroker:219: error: no matching function for call to 'PubSubClient::setCallback(void (&)(uint8_t, const char*, bool))'
                ! mqttClient.setCallback(callback);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:219:34: note: candidate is:
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:121:18: note: PubSubClient& PubSubClient::setCallback(std::function<void(char*, unsigned/char*,/int)="">)
                ! PubSubClient& setCallback(MQTT_CALLBACK_SIGNATURE);
                ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:121:18: note: no known conversion for argument 1 from 'void(uint8_t, const char*, bool) {aka void(unsigned char, const char*, bool)}' to 'std::function<void(char*, unsigned/char*,/int)="">'
                ! ws2812_iobroker:224: error: 'message_red' was not declared in this scope
                ! Null_String.toCharArray(message_red, Null_String.length()+1);
                ! ws2812_iobroker:22: error: invalid operands of types 'const char [3]' and 'const char [9]' to binary 'operator+'
                ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:225:29: note: in expansion of macro 'BASE'
                ! mqttClient.subscribe("#/"+BASE+"/#");
                ! exit status 1
                ! Dieser Bericht wäre detaillierter, wenn die Option
                "Ausführliche Ausgabe während der Kompilierung"
                in Datei -> Voreinstellungen aktiviert wäre.</void(char*,></void(char*,></void(char*,></void(char*,></void(char*,></void(char*,></void(char*,></void(char*,>
                PubSubClient.h ist auch vorhanden…. hmmpppfff ich verstehe nur noch Bahnhof.... auweia~~
                • Thisoft
                  Tja, ja - ein kleiner Tippfehler bzw. vergessen umzuschreiben. Du musst die folgende Zeile:
                  durch diese ersetzen:
                    Null_String.toCharArray(message_color, Null_String.length()+1);
                    soo ich habe es mal geändert leider immernoch ein fehler… bzw. denke es ist der selbe
                    ! ws2812_iobroker:21: error: no matching function for call to 'PubSubClient::PubSubClient(IPAddress&, int)'
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:21:41: note: candidates are:
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:116:4: note: PubSubClient::PubSubClient(const char*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&, Stream&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:116:4: note: candidate expects 5 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:115:4: note: PubSubClient::PubSubClient(const char*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:115:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:114:4: note: PubSubClient::PubSubClient(const char*, uint16_t, Client&, Stream&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:114:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:113:4: note: PubSubClient::PubSubClient(const char*, uint16_t, Client&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:113:4: note: candidate expects 3 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:112:4: note: PubSubClient::PubSubClient(uint8_t*, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&, Stream&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:112:4: note: candidate expects 5 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:111:4: note: PubSubClient::PubSubClient(uint8_t
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:111:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:110:4: note: PubSubClient::PubSubClient(uint8_t
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:110:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:109:4: note: PubSubClient::PubSubClient(uint8_t
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:109:4: note: candidate expects 3 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:108:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, std::function<void(char
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:108:4: note: candidate expects 5 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:107:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, std::function<void(char*, unsigned/char*,/int)="">, Client&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:107:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:106:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, Client&, Stream&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:106:4: note: candidate expects 4 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:105:4: note: PubSubClient::PubSubClient(IPAddress, uint16_t, Client&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:105:4: note: candidate expects 3 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:104:4: note: PubSubClient::PubSubClient(Client&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:104:4: note: candidate expects 1 argument, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:103:4: note: PubSubClient::PubSubClient()
                    ! PubSubClient();
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:103:4: note: candidate expects 0 arguments, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:83:7: note: PubSubClient::PubSubClient(const PubSubClient&)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:83:7: note: candidate expects 1 argument, 2 provided
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:83:7: note: PubSubClient::PubSubClient(PubSubClient&&)
                    ! ws2812_iobroker:194: error: 'ip' was not declared in this scope
                    ! ws2812_iobroker:220: error: no matching function for call to 'PubSubClient::setCallback(void (&)(uint8_t, const char*, bool))'
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:220:34: note: candidate is:
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:121:18: note: PubSubClient& PubSubClient::setCallback(std::function<void(char*, unsigned/char*,/int)="">)
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master\src/PubSubClient.h:121:18: note: no known conversion for argument 1 from 'void(uint8_t, const char*, bool) {aka void(unsigned char, const char*, bool)}' to 'std::function<void(char*, unsigned/char*,/int)="">'
                    ! ws2812_iobroker:23: error: invalid operands of types 'const char [3]' and 'const char [9]' to binary 'operator+'
                    ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:226:29: note: in expansion of macro 'BASE'
                    ! exit status 1
                    es tut mir echt leid das ich dich damit so belaste… leider kann ich es nicht alleine.... :cry:
                    • Thisoft
                      Kannst dich trösten - es ist nicht der gleiche 😉 Maßgeblich in der Fehlermeldung ist diese Zeile:
                      ersetze mal die Zeile durch:
                      IPAddress localAddr = WiFi.localIP();
                      Da bin ich mir allerdings nicht 100%ig sicher da ich immer feste IP's verwende. Falls das nicht klappt schreibe mal testweise:
                      IPAddress localAddr = { 255, 255, 255,255 };
                      btw. - hast du in der folgenden Zeile die Adresse deines MQTT-Servers eingetragen?
                      //// MQTT-Settings
                        @Thisoft
                        leider hatte ich sehr wenig Zeit das nocmal zu testen. Jetzt sitze ich seit heute morgen daran und komme nicht weiter. Ich habe immer noch einen Fehler oder sogar mehrere. Ich kann verstehen wenn du mir nicht mehr helfen willst und aufgibst. Ich bedanke mich bis hierher auf jedenfall sehr bei dir. Solltest du doch noch lust haben hier mal mein Fehler den ich noch habe:
                        ! PubSubClient();
                        ! Mehrere Bibliotheken wurden für "PubSubClient.h" gefunden
                        Benutzt: C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-master
                        Nicht benutzt: C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-2.6
                        exit status 1
                          ` > ersetze mal die Zeile durch:
                        > Code:
                        > Code:
                        > IPAddress localAddr = { 255, 255, 255,255 }; <–-- 255,255,255,0 `
                        Habe ich gemacht! keine Änderung leider
                          ` > btw. - hast du in der folgenden Zeile die Adresse deines MQTT-Servers eingetragen?
                        > Code:
                        > //// MQTT-Settings
                        > IPAddress mqtt_server(192, 168, xxx, xxx); // IP-MQTT-Broker `
                        Auch das heb ich eingetragen und trotzdem keine veränderung :-(
                        Wenn Du das kompilierst geht das ohne probleme durch?
                        • Thisoft
                          Warum sollte ich dir denn nicht mehr helfen wollen? Ist doch kein Problem. KAnn nur sein dass ich zwischendurch auch mal den Überblick verliere 😉
                          Jetzt mach mal noch einen Versuch indem du den kompletten Abschnitt "////MQTT-Settings" durch das Folgende ersetzt. KAnn sein dass eigentlich nur die Zeile "WiFiClient client;" gefehlt hatte…
                          //// MQTT-Settings
                          const char* mqtt_username = "ioBroker"; // MQTT-User
                          const char* mqtt_key = "iobroker"; // MQTT-Password
                          WiFiClient client;
                          PubSubClient mqttClient(mqtt_server,1883, client);
                          Wenn das jetzt auch noch nicht hilft dann poste bitte wieder die Fehlermeldungen und dazu bitte den momentanen Code dass ich erstmal wieder "auf Stand" bin.
                            ich bin mir nicht sicher aber ich glaube es ist schon besser aber leider noch ein fehler drin
                            ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-2.6\src/PubSubClient.h:121:18: note: PubSubClient& PubSubClient::setCallback(std::function<void(char*, unsigned/char*,/int)="">)
                            ! C:\Users\HauptstadtRocker\Documents\Arduino\libraries\pubsubclient-2.6\src/PubSubClient.h:121:18: note: no known conversion for argument 1 from 'void(uint8_t, const char*, bool) {aka void(unsigned char, const char*, bool)}' to 'std::function<void(char*, unsigned/char*,/int)="">'
                            ! exit status 1
                            der dazugehörige code ist aktuell dieser hier
                            >! #define WIFI_SSID "*********"//Set your Wifi name
                            #define WIFI_PASS "*********"//Set your Wifi Password
                            IPAddress mqtt_server(192, 168, 178, 45); // IP-MQTT-Broker
                            const char* mqtt_username = "*******"; // MQTT-User
                            const char* mqtt_key = "*******"; // MQTT-Password
                            WiFiClient client;
                            >! fauxmoESP fauxmo;
                            int i;
                            int start1 = 0;
                            int start2 = 3;
                            int start3 = 6;
                            int start4 = 9;
                            // Wifi Setup
                            >!   // Connect
                            >!   // Wait
                                Serial.print(".");
                                delay(100);
                              Serial.println();
                            >!   // Connected!
                              if (state) {
                              } else {
                            >!   //Turns strip RED
                                if (state) {
                                  i = 1;
                                else {
                                  allOff();
                                  i = 0;
                              //Turns strip GREEN
                                if (state) {
                                  i = 2;
                                else {
                                  allOff();
                                  i = 0;
                              //Turns strip BLUE
                                if (state) {
                                  i = 3;
                                else {
                                  allOff();
                                  i = 0;
                                if (state) {
                                  i = 8;
                                else {
                                  allOff();
                                  i = 0;
                              //Turns strip WHITE
                                if (state) {
                                  i = 4;
                                else {
                                  allOff();
                                  i = 0;
                                if (state) {
                                  i = 9;
                                else {
                                  allOff();
                                  i = 0;
                                if (state) {
                                  i = 11;
                                else {
                                  allOff();
                                  i = 0;
                                if (state) {
                                  i = 12;
                                else {
                                  allOff();
                                  i = 0;
                                if (state) {
                                  i = 13;
                                else {
                                  allOff();
                                  i = 0;
                                 IPAddress localAddr = (255, 255, 255, 0);
                                  char s[16];
                                } else {
                            >! void setup() {
                            >!   // Wifi
                              wifiSetup();
                            >!   //MQTT
                                connect_MQTT();
                              i = 0;
                              strip.begin();
                              strip.show();
                            >! void loop() {
                              fauxmo.handle();
                              startShow(i);
                              switch (i) {
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                case 9: google();
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                strip.show();
                                delay(wait);
                            //Rainbow pattern
                              uint16_t i, j;
                                strip.show();
                                delay(wait);
                              uint16_t i, j;
                                strip.show();
                                delay(wait);
                                  strip.show();
                            >!       delay(wait);
                                  strip.show();
                            >!       delay(wait);
                            void google() {
                            >!   strip.show();
                            void allOff() {
                              strip.show();
                                WheelPos -= 85;
                              WheelPos -= 170;
                            • Thisoft
                              Sieht doch schon besser aus.
                              Dann lasse vorerst mal die Zeile
                              ganz raus bzw. kommentiere die aus.
                              Weiterhin anstelle der Zeile:
                              diese
                              const char* BASE = "RGBbyESP"
                              Dann sollte die Sache erstmal laufen - allerdings ohne den Arduino steuern zu können…
                                leider immernoch ein fehler…. 😮
                                ! Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "WeMos D1 R2 & mini, 80 MHz, 921600, 4M (3M SPIFFS)" ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino: In function 'void connect_MQTT()': ! ws2812_iobroker:26: error: expected ')' before string constant ! #define mqtt_topics_ip BASE "/IP" ! ^ ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:199:26: note: in expansion of macro 'mqtt_topics_ip' ! mqttClient.publish(mqtt_topics_ip,s); ! ^ ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino: In function 'void setup()': ! ws2812_iobroker:227: error: invalid operands of types 'const char [3]' and 'const char*' to binary 'operator+' ! mqttClient.subscribe("#/"+BASE+"/#"); ! ^ ! ws2812_iobroker:27: error: expected ')' before string constant ! #define mqtt_topics_color BASE "/Color" ! ^ ! C:\Users\HauptstadtRocker\Documents\Arduino\ws2812_iobroker\ws2812_iobroker.ino:228:22: note: in expansion of macro 'mqtt_topics_color' ! mqttClient.publish(mqtt_topics_color,message_color); ! ^ ! exit status 1 expected ')' before string constant ! Dieser Bericht wäre detaillierter, wenn die Option "Ausführliche Ausgabe während der Kompilierung" in Datei -> Voreinstellungen aktiviert wäre. !
                                  tedesco last edited by
                                  läuft dein Programm jetzt?
                                  Toni
                                  2999
