    4. Matter: Devices und Bridges
      RISSN last edited by RISSN
      Hallo, eine Frage zu dem dem Shelly Plug, ich kann diesen schalten, aber ich sehe keinen Verbrauch, liegt das an Shelly oder am Adapter?
      matter.0
      2025-01-27 18:08:19.375	debug	Unsubscribe from 1737997482826-system.adapter.admin.0-gui
      matter.0
      2025-01-27 18:08:19.375	debug	Client "1737997482826-system.adapter.admin.0-gui: disconnect
      matter.0
      matter.0
      matter.0
      matter.0
      matter.0
      matter.0
      matter.0
      2025-01-27 18:06:52.705	debug	Get details 7398579136186651997-1
      matter.0
      2025-01-27 18:06:52.705	debug	DeviceManagement received: {"command":"dm:deviceDetails","message":"7398579136186651997-1","from":"system.adapter.admin.0","callback":{"message":"7398579136186651997-1","id":955,"ack":false,"time":1737997612704},"_id":71949642}
      matter.0
      2025-01-27 18:05:08.082	debug	Get details 7398579136186651997-1
      matter.0
      2025-01-27 18:05:08.082	debug	DeviceManagement received: {"command":"dm:deviceDetails","message":"7398579136186651997-1","from":"system.adapter.admin.0","callback":{"message":"7398579136186651997-1","id":953,"ack":false,"time":1737997508081},"_id":71949640}
      matter.0
      2025-01-27 18:05:00.398	debug	Get details 7398579136186651997-1
      matter.0
      2025-01-27 18:05:00.398	debug	DeviceManagement received: {"command":"dm:deviceDetails","message":"7398579136186651997-1","from":"system.adapter.admin.0","callback":{"message":"7398579136186651997-1","id":952,"ack":false,"time":1737997500396},"_id":71949639}
      matter.0
      2025-01-27 18:04:54.871	debug	DeviceManagement received: {"command":"dm:listDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":951,"ack":false,"time":1737997494870},"_id":71949638}
      matter.0
      2025-01-27 18:04:54.675	debug	Send to GUI: {"command":"updateController"}
      matter.0
      2025-01-27 18:04:54.614	debug	DeviceManagement received: {"command":"dm:listDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":950,"ack":false,"time":1737997494581},"_id":71949637}
      matter.0
      2025-01-27 18:04:54.562	debug	DeviceManagement received: {"command":"dm:instanceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":949,"ack":false,"time":1737997494561},"_id":71949636}
      matter.0
      2025-01-27 18:04:54.315	debug	Send to GUI: {"command":"bridgeStates","states":{}}
      matter.0
      2025-01-27 18:04:54.215	debug	Start GUI
      matter.0
      2025-01-27 18:04:54.214	debug	Subscribe from 1737997482826-system.adapter.admin.0-gui
      matter.0
      2025-01-27 17:56:06.577	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.ACTUAL to true (ack = true)
      matter.0
      2025-01-27 17:56:06.530	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.SET to true (ack = true)
      matter.0
      2025-01-27 17:56:06.521	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.ACTUAL to true (ack = true)
      matter.0
      2025-01-27 17:56:06.521	debug	handleChangedAttribute "7398579136186651997": Attribute undefined/1/0x0006/onOff changed to true
      matter.0
      2025-01-27 17:56:06.477	debug	Handle change event for power with value true
      matter.0
      2025-01-27 17:56:06.477	debug	Received state change for matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.SET: true (ack=false) --> true (triggerUpdate=true)
      matter.0
      2025-01-27 17:56:00.975	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.ACTUAL to false (ack = true)
      matter.0
      2025-01-27 17:56:00.922	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.SET to false (ack = true)
      matter.0
      2025-01-27 17:56:00.873	debug	Set matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.ACTUAL to false (ack = true)
      matter.0
      2025-01-27 17:56:00.873	debug	handleChangedAttribute "7398579136186651997": Attribute undefined/1/0x0006/onOff changed to false
      matter.0
      2025-01-27 17:56:00.830	debug	Handle change event for power with value false
      matter.0
      2025-01-27 17:56:00.830	debug	Received state change for matter.0.controller.7398579136186651997.OnOffPlugInUnit-1.SET: false (ack=false) --> false (triggerUpdate=true)
      Ob das Log etwas bringt?, ich habe keine Ahnung
        apollon77 @RISSN last edited by
        @rissn bei der Shelly node gibt es einen debug info Button. Poste mal die Infos. Wenn da keine measurements dabei sind liefert Shelly es noch nicht. Kannst auch schauen was behindert Mode und den Infos unter „specification“ und da bei der version steht. Alles <1.3 kann das nicht übertragen. Denke da braucht es ein Firmware Update.
          RISSN @apollon77 last edited by RISSN
          @apollon77
          das steht bei den Infos zu Node
            Endpoint 0 (MA-rootnode):
              Cluster-Servers:
                Cluster-Server "Descriptor" (0x1d)
                  Global-Attributes:
                    "clusterRevision" (0xfffd): value = 2
                    "featureMap" (0xfffc): value = {}
                    "attributeList" (0xfffb): value = [0,1,2,3,65528,65529,65531,65532,65533]
                    "acceptedCommandList" (0xfff9): value = []
                    "generatedCommandList" (0xfff8): value = []
                  Attributes:
                    "deviceTypeList" (0x0): value = [{"deviceType":22,"revision":2}]
                    "serverList" (0x1): value = [29,41]
                    "clientList" (0x2): value = [29,31,40,42,48,49,51,54,60,62,63]
                    "partsList" (0x3): value = []
                  Commands:
                  Events:
                Cluster-Server "OtaSoftwareUpdateProvider" (0x29)
                  Global-Attributes:
                    "clusterRevision" (0xfffd): value = 1
                    "attributeList" (0xfffb): value = [65528,65529,65531,65532,65533]
                  Attributes:
                  Commands:
                  Events:
              Cluster-Clients:
                Cluster-Client "Descriptor" (0x1d)
                  Global-Attributes:
                  Attributes:
                    "serverList" (0x1)
                    "clientList" (0x2)
                    "partsList" (0x3)
                    "unknownAttribute_0xfffa" (0xfffa) (Unknown)
                  Commands:
                  Events:
                Cluster-Client "AccessControl" (0x1f)
                  Global-Attributes:
                  Attributes:
                    "acl" (0x0)
                    "extension" (0x1)
                    "subjectsPerAccessControlEntry" (0x2)
                    "targetsPerAccessControlEntry" (0x3)
                    "accessControlEntriesPerFabric" (0x4)
                  Commands:
                  Events:
                    "accessControlEntryChanged" (0x0)
                    "accessControlExtensionChanged" (0x1)
                Cluster-Client "BasicInformation" (0x28)
                  Global-Attributes:
                  Attributes:
                    "dataModelRevision" (0x0)
                    "vendorName" (0x1)
                    "vendorId" (0x2)
                    "productName" (0x3)
                    "productId" (0x4)
                    "nodeLabel" (0x5)
                    "location" (0x6)
                    "hardwareVersion" (0x7)
                    "hardwareVersionString" (0x8)
                    "softwareVersion" (0x9)
                    "softwareVersionString" (0xa)
                    "manufacturingDate" (0xb)
                    "partNumber" (0xc)
                    "productUrl" (0xd)
                    "productLabel" (0xe)
                    "serialNumber" (0xf)
                    "localConfigDisabled" (0x10)
                    "uniqueId" (0x12)
                    "capabilityMinima" (0x13)
                  Commands:
                  Events:
                    "startUp" (0x0)
                    "shutDown" (0x1)
                    "leave" (0x2)
                    "reachableChanged" (0x3)
                Cluster-Client "OtaSoftwareUpdateRequestor" (0x2a)
                  Global-Attributes:
                  Attributes:
                    "defaultOtaProviders" (0x0)
                    "updatePossible" (0x1)
                    "updateState" (0x2)
                    "updateStateProgress" (0x3)
                  Commands:
                    "announceOtaProvider"
                  Events:
                    "stateTransition" (0x0)
                    "versionApplied" (0x1)
                    "downloadError" (0x2)
                Cluster-Client "GeneralCommissioning" (0x30)
                  Global-Attributes:
                  Attributes:
                    "breadcrumb" (0x0)
                    "basicCommissioningInfo" (0x1)
                    "regulatoryConfig" (0x2)
                    "locationCapability" (0x3)
                    "supportsConcurrentConnection" (0x4)
                  Commands:
                    "armFailSafe"
                    "setRegulatoryConfig"
                    "commissioningComplete"
                  Events:
                Cluster-Client "NetworkCommissioning" (0x31) (Features: wiFiNetworkInterface)
                  Global-Attributes:
                  Attributes:
                    "maxNetworks" (0x0)
                    "networks" (0x1)
                    "interfaceEnabled" (0x4)
                    "lastNetworkingStatus" (0x5)
                    "lastNetworkId" (0x6)
                    "lastConnectErrorValue" (0x7)
                    "scanMaxTimeSeconds" (0x2)
                    "connectMaxTimeSeconds" (0x3)
                  Commands:
                    "scanNetworks"
                    "addOrUpdateWiFiNetwork"
                    "removeNetwork"
                    "connectNetwork"
                    "reorderNetwork"
                  Events:
                Cluster-Client "GeneralDiagnostics" (0x33)
                  Global-Attributes:
                  Attributes:
                    "networkInterfaces" (0x0)
                    "rebootCount" (0x1)
                    "upTime" (0x2)
                    "bootReason" (0x4)
                    "testEventTriggersEnabled" (0x8)
                  Commands:
                    "testEventTrigger"
                  Events:
                    "hardwareFaultChange" (0x0)
                    "radioFaultChange" (0x1)
                    "networkFaultChange" (0x2)
                    "bootReason" (0x3)
                Cluster-Client "WiFiNetworkDiagnostics" (0x36)
                  Global-Attributes:
                  Attributes:
                    "bssid" (0x0)
                    "securityType" (0x1)
                    "wiFiVersion" (0x2)
                    "channelNumber" (0x3)
                    "rssi" (0x4)
                  Commands:
                  Events:
                    "disconnection" (0x0)
                    "associationFailure" (0x1)
                    "connectionStatus" (0x2)
                Cluster-Client "AdministratorCommissioning" (0x3c)
                  Global-Attributes:
                  Attributes:
                    "windowStatus" (0x0)
                    "adminFabricIndex" (0x1)
                    "adminVendorId" (0x2)
                  Commands:
                    "openCommissioningWindow"
                    "revokeCommissioning"
                    "openBasicCommissioningWindow"
                  Events:
                Cluster-Client "OperationalCredentials" (0x3e)
                  Global-Attributes:
                  Attributes:
                    "nocs" (0x0)
                    "fabrics" (0x1)
                    "supportedFabrics" (0x2)
                    "commissionedFabrics" (0x3)
                    "trustedRootCertificates" (0x4)
                    "currentFabricIndex" (0x5)
                  Commands:
                    "attestationRequest"
                    "certificateChainRequest"
                    "csrRequest"
                    "addNoc"
                    "updateNoc"
                    "updateFabricLabel"
                    "removeFabric"
                    "addTrustedRootCertificate"
                  Events:
                Cluster-Client "GroupKeyManagement" (0x3f)
                  Global-Attributes:
                  Attributes:
                    "groupKeyMap" (0x0)
                    "groupTable" (0x1)
                    "maxGroupsPerFabric" (0x2)
                    "maxGroupKeysPerFabric" (0x3)
                  Commands:
                    "keySetWrite"
                    "keySetRead"
                    "keySetRemove"
                    "keySetReadAllIndices"
                  Events:
              Child-Endpoints:
                Endpoint 1 (MA-onoffpluginunit):
              Cluster-Servers:
                  Global-Attributes:
                  Attributes:
                    "deviceTypeList" (0x0): value = [{"deviceType":266,"revision":3}]
                    "serverList" (0x1): value = [29]
                    "clientList" (0x2): value = [3,4,5,6,29]
                  Commands:
                  Events:
              Cluster-Clients:
                Cluster-Client "Identify" (0x3)
                  Global-Attributes:
                  Attributes:
                    "identifyTime" (0x0)
                    "identifyType" (0x1)
                  Commands:
                    "identify"
                    "triggerEffect"
                  Events:
                Cluster-Client "Groups" (0x4) (Features: groupNames)
                  Global-Attributes:
                  Attributes:
                    "nameSupport" (0x0)
                  Commands:
                    "addGroup"
                    "viewGroup"
                    "getGroupMembership"
                    "removeGroup"
                    "removeAllGroups"
                    "addGroupIfIdentifying"
                  Events:
                Cluster-Client "Unknown cluster 0x5" (0x5)
                  Global-Attributes:
                  Attributes:
                    "unknownAttribute_0x0" (0x0) (Unknown)
                    "unknownAttribute_0x1" (0x1) (Unknown)
                    "unknownAttribute_0x2" (0x2) (Unknown)
                    "unknownAttribute_0x3" (0x3) (Unknown)
                    "unknownAttribute_0x4" (0x4) (Unknown)
                    "unknownAttribute_0x6" (0x6) (Unknown)
                    "unknownAttribute_0x7" (0x7) (Unknown)
                  Commands:
                  Events:
                Cluster-Client "OnOff" (0x6)
                  Global-Attributes:
                  Attributes:
                    "onOff" (0x0)
                  Commands:
                    "off"
                    "on"
                    "toggle"
                  Events:
                  Global-Attributes:
                  Attributes:
                    "serverList" (0x1)
                    "clientList" (0x2)
                    "partsList" (0x3)
                  Commands:
                  Events:
              Child-Endpoints:
            @rissn re screenshot … Tab specification 😉
            Aber nope. Nix drin. Da muss Shelly ein matter Update machen.
              @apollon77
              Ok, dann wäre Version 1.2.0 die Matter Version und die kann noch keine Verbrauchsdaten, vielen Dank, dass war eine nützliche Info
              Feuersturm 1 Reply Last reply Reply Quote 1
              • Feuersturm
                Feuersturm @RISSN last edited by Feuersturm
                @rissn Geh mal im Netz etwas auf die Suche nach deinem Shelly Plug S Gen3 und dem Stichwort "matter 1.3".
                Ich hab bei meiner Meross Steckdose im Homeassistant Forum die Info bekommen, das Meross einem auch Beta Firmware auf die Geräte spielen kann. Dies hat bei mir innerhalb von 2-3 Tagen funktioniert und jetzt kann ich schon einmal vorab mit der neuen Beta-Firmware neben an/aus auch die Energiedaten der Steckdose in ioBroker sichtbar machen.
                Hab gerade für Shelly z.B. diesen Thread gefunden https://community.shelly.cloud/topic/3893-firmware-updates-für-shelly-gen3/
                • JackDaniel
                  JackDaniel last edited by JackDaniel
                  die hmip wandthermostate funktionieren schon mal im ansatz, leider sind noch ein paar fehler feststellbar
                  1. modus wird falsch angezeigt
                  2. luftfeuchtigkeit fehlt
                  3. boost unterstützung wäre noch super
                  in gh per iob
                  in gh per matter
                    apollon77 @JackDaniel last edited by apollon77
                    @jackdaniel naja jetzt müsen wir mal schauen ...
                    Was bedeutet "gh per iob" ? Über den Skill? Matter und Skills zu vergleichen geht nicht so easy.
                    Am besten mach mal Debug log auf Matter Instanz an und zeig mal das Log vom Start.
                    Das aktuelle "Problem" bei Thermostaten ist das folgende:
                    • Matter kennt nur Heating oder Cooling oder beides (und nur dann gibts nen "Auto"-Modus der aber ne andere bedeutung hat als "Auto" in Homematic
                    • In Deinem Fall scheinen die verfügbaren "Mode" werte alle nicht sinnvoll zu sein damit kann der Matter-Adapter Matter es nur auf Heating Mappen. Wo ist das Falsch? Warum sollte der kühlen? Wenn Dein HM Thermostat einen Cool modus hätte würde der Adapter ihn auch mappen.
                    Was man tun könnte ist - matter hat neben dem "Systemmodus" noch einen "running state". Haben die HM Geräte einen State der Besagt was Sie gerade wirklich tun? Weil dann könnte man sagen "Modus ist heizen, aber ich heize nicht weil temperatur erreicht" (und nein nur deswegen kühlt er nicht den Raum gg)
                    Luftfeuchtigkeit sollte da sein - bei Google aber ggf als getrennte Kachel weil der das gern mal trennt. Irgendwo kannst Du einstellen das Google es zusammen anzeigen soll. Im Normalfall bildet der Adapter das als als sogenanntes "Composed Device" ab ber wie gesgat Google zeigt es gern als zwei kacheln an. Schau mal. Um zu prüfen das er es so exposed hat klick mal in dem Screen oben auf "Endpoints2. Da solltest DU zwei Endpunkte sehen ...wenn dem so ist hast du eine zweite kachel.
                    Boost ... genauso wie Party kennt matter formal nicht. Da wollte ich noch Fragen was das genau bedeutet? Da ich solche Thermostate nicht so nutze hab ich da wenig "Ahnung". Weil damit ist die Frage wie man es abbildet. Entweder ich finde ein Matter Thermostat Feature was das ist oder ich kann es als "Schalter" abbilden die man dann hätte ... das wäre die Frage was wie sinn macht
                    Feuersturm JackDaniel 2 Replies Last reply Reply Quote 0
                    • Feuersturm
                      Feuersturm @apollon77 last edited by
                      @apollon77 sagte in Matter-Beta: Devices und Bridges:
                      Boost bei HMIP Thermostaten: Heizkörperventil wird für 5 min zu 80% geöffnet
                      Es gibt den Datenpunkt hm-rpc.0.00201A49978146.1.LEVEL welcher Anzeigt, zu wieviel Prozent das Ventil gerade geöffnet ist. Ob man 0% = Ventil geschlossen mit "Kühlen" gleichsetzen möchte... Klingt für mich nach einer Sonderlocke/Balkon.
                        apollon77 @Feuersturm last edited by
                        @feuersturm @JackDaniel Ok, also mit dem Wäre für mit Boost und Party am Ende nur ein "OnOff" den kann man mit exposen ...
                        Und ja den Valve Stand kann man ggf noch als State im type detector definieren, was dann aber für heating sinn macht, ist aber ok weil der meiste fall.
                        Ok legt bitte mal zwei GitHub issues an. Einmal Boost/Party als weitere Endpunkte und ein,mal das Thema "Working State". Idee wäre hir Type-Detector zu erweitern um sowas ... https://github.com/ioBroker/ioBroker.type-detector/issues/90 Dann könnte ich das zu Matter mappen.
                        Apollon77 created this issue in ioBroker/ioBroker.type-detector
                        open Enhance Thermostat definition: Determine Working state #90
                        • JackDaniel
                          JackDaniel @apollon77 last edited by
                          das hmip wandthermostat (HmIP-WTH-2) wird in meinem produktiv system per iot adapter an google home übergeben, und davon ist auch der erste screenshot
                          achja wenn wir schon bei wünsch dir was sind, ganz cool wäre wenn es den fensterstatus auch anzeigen könnte (den dp window_state gibt es ja)
                            @jackdaniel https://github.com/ioBroker/ioBroker.type-detector/issues/91
                            Achja: Und haben gfestgestellt das Party Mode blöd zu exposen ist, also ggff dann nur Boost
                            open Enhance Thermostat device: Window state #91
                            • Feuersturm
                              Feuersturm @apollon77 last edited by Feuersturm
                              @apollon77 Wie besprochen zum Thema Party Modus bei HMIP Thermostaten
                              Das sind die Objekte für den Partymodus im hm-rpc Adapter
                              Es ist also kein einfaches ein/aus vom Party Modus.
                              In der Raspberrymatic WebUI heißt es "Urlaubsmodus" wo man die Werte für diesen Modus setzen muss
                              Man müsste dieses alles über Matter nachbilden, wenn man den Partymodus bereistellen möchte.
                              Boost Modus
                              Issue kann ich anlegen
                              Edit: https://github.com/ioBroker/ioBroker.matter/issues/373
                              Feuer-sturm created this issue in ioBroker/ioBroker.matter
                              closed expose Boost_Mode for thermostat #373
                              • JackDaniel
                                ich versuche gerade meine hmip rollos per matter in google home zu bringen, was ja auch grundsätzlich schon mal geht
                                schön wäre es natürlich wenn man in google home einen slider hätte um die position anzufahren, die rolls-royce lösung wäre natürlich beides (öffnen/schließen und position)
                                mach ich da was falsch, oder geht das im moment nur so?
                                ergibt in gh
                                Feuersturm 3 Replies Last reply Reply Quote 0
                                • Feuersturm
                                  Feuersturm @JackDaniel last edited by
                                  @jackdaniel Vor ein paar Tagen hatte ich in Google Home noch ein Rolladen Icon wo ich die Behanghöhe entsprechend ziehen konnte. Bei mir sieht es heute auf einmal genau so aus wie bei dir. Ich schaue gerade mit @apollon77 ob wir die Ursache finden können.
                                  • Feuersturm
                                    @jackdaniel Das sieht nach einem Google Home Problem aus. Ich hab vorhin einmal meine beiden Rolläden aus Google Home entfernt und diese dann neu hinzugefügt. Danach hatte ich bei beiden Rolläden einen Slider den ich für die Behanghöhe ziehen konnte. Einige Minuten später hab ich nochmal in der App nachgesehen und auf einmal war es nur noch ein Button mit "öffnen / schließen"
                                    Kurz nach dem Pairing in Google Home
                                    Einige Minuten später:
                                    • JackDaniel
                                      ja alles ziemlich komisch in der angelegenheit
                                      hier wenn ich den selben db per iot zu gh hinzufüge
                                      • Feuersturm
                                        @jackdaniel es hat ja auch mal über matter -> google home funktioniert. Hatte damit am 25.01 gespielt.
                                        Mein Appstore sagt, dass es am 14.01.2025 eine neue Version von Google Home veröffentlicht wurde. Wenn ich es aus dem Augenwinkel vor 1-2 Tagen richtig gesehen habe, wurde diese App bei mir auch kürzlich aktualisiert. Aus meiner Sicht ist die Wahrscheinlichkeit gerade recht hoch, dass es mit dieser neuen Google Home Version (3.28.1.7) zusammenhängt.
                                          Also Matter-Seiotig kannst du schauen wenn du beim "Device" auf die Debug Infos klickst wenn dort "PositionAware" als Feature steht geben wir es mal mindestens an. Wenn Google es dann nicht anzeigt ists Problem bei denen.
                                          • JackDaniel
                                            PositionAware
                                            hmm finde nur "positionAwareLift"
                                            Feuersturm apollon77 2 Replies Last reply Reply Quote 0
                                            184
                                            27827
