    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      RISSN @Guest last edited by
      @ilovegym ich habe den nicht neu gestartet, der Adapter startet immer wieder neu, habe mal komplett deinstalliert und wieder neu installiert, jetzt kommen folgenden Meldungen
      bluelink.0
      2025-01-30 17:38:19.339	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"9cbde030-df28-11ef-97fe-478cdb2f7086"}
      bluelink.0
      2025-01-30 17:38:19.339	error	Error on API-Request Status, ErrorCount:1
      bluelink.0
      2025-01-30 17:37:37.044	error	next auto login attempt in 1 hour or restart adapter manual
      bluelink.0
      2025-01-30 17:37:37.044	error	Server is not available or login credentials are wrong
      bluelink.0
      2025-01-30 17:37:37.043	error	ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"4348244a-6453-4f79-a23c-8a28fdcab57a","errCode":"4003","errMsg":"Invalid values"}
      bluelink.0
      2025-01-30 17:37:01.979	error	Check Settings. No Username set
      bluelink.0
      2025-01-30 17:36:37.387	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"5ff91520-df28-11ef-97fe-7890ef7ac1ec"}
      bluelink.0
      2025-01-30 17:36:37.387	error	Error on API-Request Status, ErrorCount:1
      bluelink.0
      2025-01-30 17:36:02.793	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"4b5a26e0-df28-11ef-97fe-398e624ebd88"}
      bluelink.0
      2025-01-30 17:36:02.793	error	Error on API-Request Status, ErrorCount:1
      bluelink.0
      2025-01-30 17:35:23.103	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"33b1c930-df28-11ef-97fe-7126e08a9ffa"}
      bluelink.0
      2025-01-30 17:35:23.102	error	Error on API-Request Status, ErrorCount:1
      Gargano Meister Mopper 2 Replies Last reply Reply Quote 0
      • Gargano
        Gargano @RISSN last edited by
        @rissn das mit den credentials hatte ich auch. Da war das Passwort nicht richtig.
        • Meister Mopper
          Meister Mopper @RISSN last edited by
          @rissn
          Dann mal das große Besteck ausgepackt, wie bist du da unterwegs?
          iob diag
            wenn ich den Adapter neu starte um Daten zu holen, sonst ja ne Stunde warten, dann kommen wieder mehr Fehler.
            bluelink.0
            2025-01-30 17:44:24.385	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"76537990-df29-11ef-97fe-9e32767baa93"}
            bluelink.0
            2025-01-30 17:44:24.385	error	Error on API-Request Status, ErrorCount:1
            bluelink.0
            2025-01-30 17:44:24.307	info	Error on API-Full-Status - Fallback GetNormalStatus
            bluelink.0
            2025-01-30 17:44:23.862	info	Read new update for KMHHE8111RU054970 directly from the car
            bluelink.0
            2025-01-30 17:44:23.483	info	1 Vehicles found
            bluelink.0
            2025-01-30 17:44:21.689	info	Login to api
            bluelink.0
            2025-01-30 17:44:21.677	info	starting. Version 2.3.6 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.18.1, js-controller: 7.0.6
            bluelink.0
            2025-01-30 17:44:17.355	info	terminating
            bluelink.0
            2025-01-30 17:44:16.854	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            bluelink.0
            2025-01-30 17:44:16.853	info	terminating
            bluelink.0
            2025-01-30 17:44:16.853	info	Adapter bluelink cleaned up everything...
            bluelink.0
            2025-01-30 17:44:16.852	info	Got terminate signal TERMINATE_YOURSELF
            bluelink.0
            2025-01-30 17:41:47.422	info	Update method for KMHHE8111RU054970 changed to "directly from the car"
              RISSN @Meister Mopper last edited by
              @meister-mopper iob diag geht nicht, muss erst iob fix machen
              • Meister Mopper
                @rissn sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                Was hast du da für eine Hardware am Start?
                  @meister-mopper proxmox Version 8.3.2 auf einem Intel Nuc I7 mit 32GB etc. also schon ganz nett
                    was bedeutet das und kann ich das beeinflussen?
                    • Meister Mopper
                      @rissn
                      Ok, dann hau den Fixer drüber und zeige bitte iob diag.
                      Und wahrscheinlich stromhungrig 😊
                      • Meister Mopper
                        Eines nach dem anderen.
                          RISSN last edited by RISSN
                          @rissn geht nicht, soll mich nicht als root anmelden, habe aber keinen anderen Nutzer, das macht irgendwie auch keinen Sinn - das habe ich soweit hinbekommen, aber jetzt das Ergebnis von iob diag mittels strg+c zu kopieren, geht auch nicht, ein Problem jagt das nächste
                            A Former User @RISSN last edited by
                            @rissn
                            Argh Root tut nicht gut!
                            Mit dem arbeitet man nicht.
                            User anlegen und iobroker richtig installieren und fixen.
                              @ilovegym habe ich gemacht, jetzt muss ich es nur noch raus kopieren können, bisher habe ich das noch nicht hinbekommen
                                MarshmallowsLike last edited by
                                Moin,
                                ich fahre einen Ioniq 5 und nutzen den Adapter in Version 3.1.0.
                                Unter controls finde ich z.b. nicht das set für Lenkradheizung, Außenspiegel/Heckscheibenheizung.
                                Ist defrost Frontscheibenheizung?
                                und was genau macht heating?
                                  @rissn
                                  Loggst du dich mit Putty oder was auch immer ein, oder gehst du über die Proxmox console ?
                                    @ilovegym ich habe die Proxmox Konsole genutzt, ich kann ja mal Putty nehmen
                                      A Former User @MarshmallowsLike last edited by
                                      @marshmallowslike
                                      Ja und heating Lenkrad Heizung
                                        so iob diag, endlich geschafft
        v.2024-10-19
                                           Static hostname: iobroker
                                                 Icon name: computer-vm
                                                   Chassis: vm
                                            Virtualization: kvm
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 5.10.0-33-amd64
                                              Architecture: x86-64
                                        Installation:           kvm
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1002
                                        Display-Server:         false
                                        Boot Target:            graphical.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:
                                        /usr/bin/nodejs         v20.18.2
                                        /usr/bin/node           v20.18.2
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.4
                                        Recommended versions are nodejs 20.18.2 and npm 10.8.2
                                        nodeJS installation is correct
                                        MEMORY:
                                        Mem:             11G        3.8G        6.9G        0.0K        1.0G        7.6G
                                        Swap:           974M          0B        974M
                                        Total:           12G        3.8G        7.8G
                                        Active iob-Instances:   57
                                        Upgrade policy: none
                                        ioBroker Core:          js-controller           7.0.6
        admin                   7.4.10
                                        Objects type: jsonl
                                        States  type: jsonl
                                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                        Objects:                38188
                                        States:                 28996
                                        Size of iob-Database:
                                        55M     /opt/iobroker/iobroker-data/objects.jsonl
                                        19M     /opt/iobroker/iobroker-data/objects.json.migrated
                                        19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        34M     /opt/iobroker/iobroker-data/states.jsonl
                                        6.2M    /opt/iobroker/iobroker-data/states.json.migrated
                                        6.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                          @rissn
                                          Ja oder mobaxterm alles besser als die Proxmox console
                                            MarshmallowsLike @Guest last edited by MarshmallowsLike
                                            @ilovegym
                                            hmm okay, funktioniert bei mir nicht oder geht der wert über 1 hinaus?
                                            2314
                                            863229
