    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • Meister Mopper
      Meister Mopper @RISSN last edited by
      @rissn
      Dann mal das große Besteck ausgepackt, wie bist du da unterwegs?
      iob diag
        wenn ich den Adapter neu starte um Daten zu holen, sonst ja ne Stunde warten, dann kommen wieder mehr Fehler.
        bluelink.0
        2025-01-30 17:44:24.385	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"76537990-df29-11ef-97fe-9e32767baa93"}
        bluelink.0
        2025-01-30 17:44:24.385	error	Error on API-Request Status, ErrorCount:1
        bluelink.0
        2025-01-30 17:44:24.307	info	Error on API-Full-Status - Fallback GetNormalStatus
        bluelink.0
        2025-01-30 17:44:23.862	info	Read new update for KMHHE8111RU054970 directly from the car
        bluelink.0
        2025-01-30 17:44:23.483	info	1 Vehicles found
        bluelink.0
        2025-01-30 17:44:21.689	info	Login to api
        bluelink.0
        2025-01-30 17:44:21.677	info	starting. Version 2.3.6 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.18.1, js-controller: 7.0.6
        bluelink.0
        2025-01-30 17:44:17.355	info	terminating
        bluelink.0
        2025-01-30 17:44:16.854	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        bluelink.0
        2025-01-30 17:44:16.853	info	terminating
        bluelink.0
        2025-01-30 17:44:16.853	info	Adapter bluelink cleaned up everything...
        bluelink.0
        2025-01-30 17:44:16.852	info	Got terminate signal TERMINATE_YOURSELF
        bluelink.0
        2025-01-30 17:41:47.422	info	Update method for KMHHE8111RU054970 changed to "directly from the car"
          RISSN @Meister Mopper last edited by
          @meister-mopper iob diag geht nicht, muss erst iob fix machen
          • Meister Mopper
            @rissn sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
            Was hast du da für eine Hardware am Start?
              @meister-mopper proxmox Version 8.3.2 auf einem Intel Nuc I7 mit 32GB etc. also schon ganz nett
                was bedeutet das und kann ich das beeinflussen?
                • Meister Mopper
                  @rissn
                  Ok, dann hau den Fixer drüber und zeige bitte iob diag.
                  Und wahrscheinlich stromhungrig 😊
                  • Meister Mopper
                    Eines nach dem anderen.
                      RISSN last edited by RISSN
                      @rissn geht nicht, soll mich nicht als root anmelden, habe aber keinen anderen Nutzer, das macht irgendwie auch keinen Sinn - das habe ich soweit hinbekommen, aber jetzt das Ergebnis von iob diag mittels strg+c zu kopieren, geht auch nicht, ein Problem jagt das nächste
                        A Former User @RISSN last edited by
                        @rissn
                        Argh Root tut nicht gut!
                        Mit dem arbeitet man nicht.
                        User anlegen und iobroker richtig installieren und fixen.
                          RISSN @Guest last edited by
                          @ilovegym habe ich gemacht, jetzt muss ich es nur noch raus kopieren können, bisher habe ich das noch nicht hinbekommen
                            MarshmallowsLike last edited by
                            Moin,
                            ich fahre einen Ioniq 5 und nutzen den Adapter in Version 3.1.0.
                            Unter controls finde ich z.b. nicht das set für Lenkradheizung, Außenspiegel/Heckscheibenheizung.
                            Ist defrost Frontscheibenheizung?
                            und was genau macht heating?
                              @rissn
                              Loggst du dich mit Putty oder was auch immer ein, oder gehst du über die Proxmox console ?
                                @ilovegym ich habe die Proxmox Konsole genutzt, ich kann ja mal Putty nehmen
                                  A Former User @MarshmallowsLike last edited by
                                  @marshmallowslike
                                  Ja und heating Lenkrad Heizung
                                    so iob diag, endlich geschafft
                                                            v.2024-10-19
                                       Static hostname: iobroker
                                             Icon name: computer-vm
                                               Chassis: vm
                                        Virtualization: kvm
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 5.10.0-33-amd64
                                          Architecture: x86-64
                                    Installation:           kvm
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    Timezone:               Europe/Berlin (CET, +0100)
                                    User-ID:                1002
                                    Display-Server:         false
                                    Boot Target:            graphical.target
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:
                                    /usr/bin/nodejs         v20.18.2
                                    /usr/bin/node           v20.18.2
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.29.4
                                    Recommended versions are nodejs 20.18.2 and npm 10.8.2
                                    nodeJS installation is correct
                                    MEMORY:
                                    Mem:             11G        3.8G        6.9G        0.0K        1.0G        7.6G
                                    Swap:           974M          0B        974M
                                    Total:           12G        3.8G        7.8G
                                    Active iob-Instances:   57
                                    Upgrade policy: none
                                    ioBroker Core:          js-controller           7.0.6
                                                            admin                   7.4.10
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                    Objects:                38188
                                    States:                 28996
                                    Size of iob-Database:
                                    55M     /opt/iobroker/iobroker-data/objects.jsonl
                                    19M     /opt/iobroker/iobroker-data/objects.json.migrated
                                    19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    34M     /opt/iobroker/iobroker-data/states.jsonl
                                    6.2M    /opt/iobroker/iobroker-data/states.json.migrated
                                    6.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                      @rissn
                                      Ja oder mobaxterm alles besser als die Proxmox console
                                        MarshmallowsLike @Guest last edited by MarshmallowsLike
                                        @ilovegym
                                        hmm okay, funktioniert bei mir nicht oder geht der wert über 1 hinaus?
                                          @marshmallowslike
                                          Du setzt im Ordner set die Werte und dann startest du die Clima
                                            @ilovegym ja das verstehe ich. danke.
                                            aber außenspiegel/Heckscheibe geht nicht? wert 0 ist Lenkrad, 1 scheint nur heizung und defrost ist frontscheibe
                                            2314
                                            863459
