    4. ESPHome kein Webinterface
      AndreasE112 @Ralf 2 last edited by
      @ralf-2 sagte in ESPHome kein Webinterface:
      IOB
      was ist denn IOB Diag
        Ralf 2 @AndreasE112 last edited by
        @andrease112
        Das führt man auf der Console aus und kann daraus vieles entdecken was im IOBroker nicht korrekt ist oder Probleme verursachen kann.
        Ich kann aber nicht sagen, ob hier darüber tatsächlich jemand dem Fehler auf die Spur kommen kann.
          @ralf-2
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
          Static hostname: iobroker
                Icon name: computer
                   Kernel: Linux 6.6.62+rpt-rpi-v8
             Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
          18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          *** TIME AND TIMEZONES ***
                        Local time: Thu 2025-01-30 18:02:11 CET
                    Universal time: Thu 2025-01-30 17:02:11 UTC
                          RTC time: n/a
                       NTP service: active
                   RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.2G        1.9G        4.8G        1.3M        1.5G        6.3G
          Swap:           536M          0B        536M
          Total:          8.7G        1.9G        5.4G
          Active iob-Instances:   22
                  7808 M total memory
                  1831 M used memory
                  2648 M active memory
                   355 M inactive memory
                  4624 M free memory
                    79 M buffer memory
                  1396 M swap cache
                   511 M total swap
                     0 M used swap
                   511 M free swap
          top - 18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
          Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7808.9 total,   4622.7 free,   1832.6 used,   1477.1 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5976.3 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          31 CRITICAL ERRORS DETECTED!
          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     781M  1.3M  780M   1% /run
          /dev/sda2      ext4      110G   15G   91G  14% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
          tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
          [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Thu Jan 30 17:33:35 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
          [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          5.6G    /var/
          4.3G    /var/lib
          4.2G    /var/lib/docker/overlay2
          1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/usr
          Archived and active journals take up 308.1M in the file system.
          /opt/iobroker/backups:
          130M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.5G    /opt/iobroker/iobroker-data/
          1.2G    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          32M     /opt/iobroker/iobroker-data/history/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
           Installed: 20.18.1-1nodesource1
           Candidate: 20.18.2-1nodesource1
           Version table:
              20.18.2-1nodesource1 1001
                 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
          *** 20.18.1-1nodesource1 1001
                 100 /var/lib/dpkg/status
              20.18.0-1nodesource1 1001
              20.17.0-1nodesource1 1001
              20.16.0-1nodesource1 1001
              20.15.1-1nodesource1 1001
              20.15.0-1nodesource1 1001
              20.14.0-1nodesource1 1001
              20.13.1-1nodesource1 1001
              20.13.0-1nodesource1 1001
              20.12.2-1nodesource1 1001
              20.12.1-1nodesource1 1001
              20.12.0-1nodesource1 1001
              20.11.1-1nodesource1 1001
              20.11.0-1nodesource1 1001
              20.10.0-1nodesource1 1001
              20.9.0-1nodesource1 1001
              20.8.1-1nodesource1 1001
              20.8.0-1nodesource1 1001
              20.7.0-1nodesource1 1001
              20.6.1-1nodesource1 1001
              20.6.0-1nodesource1 1001
              20.5.1-1nodesource1 1001
              20.5.0-1nodesource1 1001
              20.4.0-1nodesource1 1001
              20.3.1-1nodesource1 1001
              20.3.0-1nodesource1 1001
              20.2.0-1nodesource1 1001
              20.1.0-1nodesource1 1001
              20.0.0-1nodesource1 1001
              18.19.0+dfsg-6~deb12u2 500
              18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1708)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.4.10
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
           system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
           system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
           system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
           system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
           system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 0.0.0.0
           system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
           system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
           system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
           system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
           system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
           system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
           system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
           system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
           system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 7.4.19   , installed 7.4.10 [Updatable]
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
          Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fullybrowser" : 3.0.13   , installed 3.0.12 [Updatable]
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "modbus"       : 6.4.0    , installed 6.3.2  [Updatable]
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "notification-manager": 1.3.0, installed 1.2.1 [Updatable]
          Adapter    "scenes"       : 4.0.1    , installed 3.2.3  [Updatable]
          Adapter    "shuttercontrol": 1.8.8   , installed 1.8.5  [Updatable]
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
          Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
          Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
          Adapter    "tuya"         : 3.17.0   , installed 3.16.0 [Updatable]
          Adapter    "vis-2"        : 2.11.2   , installed 2.9.64 [Updatable]
          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "weather-warnings": 0.7.3 , installed 0.6.11 [Updatable]
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 6.3.1    , installed 6.2.5  [Updatable]
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        9057
          States:         8038
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://download.docker.com/linux/debian bookworm InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 11
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6006       589/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1888       589/iobroker.js-con
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8172       1968/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8173       1968/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       11029      2042/io.sonoff.0
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8557       1043/python
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5674       614/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          9339       1043/python
          tcp        0      0 0.0.0.0:12101           0.0.0.0:*               LISTEN      0          959        915/docker-proxy
          tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       7255       453/Agent
          tcp6       0      0 :::22                   :::*                    LISTEN      0          5676       614/sshd: /usr/sbin
          tcp6       0      0 :::12101                :::*                    LISTEN      0          964        928/docker-proxy
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12580      2133/io.web.0
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       11470      1248/io.admin.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14977      3056/io.esphome.0
          udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       7341       453/Agent
          udp        0      0 192.168.178.54:5353     0.0.0.0:*                           1000       7340       453/Agent
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7339       453/Agent
          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           0          9338       1043/python
          udp        0      0 192.168.178.54:5353     0.0.0.0:*                           0          9337       1043/python
          udp        0      0 172.17.0.1:5353         0.0.0.0:*                           0          9336       1043/python
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          9330       1043/python
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5547       455/avahi-daemon: r
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       12292      1992/io.mihome.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          7287       1043/python
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11123      2014/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11124      2014/io.tuya.0
          udp        0      0 0.0.0.0:44125           0.0.0.0:*                           0          8514       1043/python
          udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1000       6267       453/Agent
          udp        0      0 0.0.0.0:52788           0.0.0.0:*                           104        5549       455/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        5548       455/avahi-daemon: r
          udp6       0      0 :::43249                :::*                                104        5550       455/avahi-daemon: r
          udp6       0      0 fe80::34bb:d917:52c:546 :::*                                0          5735       537/NetworkManager
          2025-01-30 18:03:22.529  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
          2025-01-30 18:03:22.531  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
          2025-01-30 18:03:22.721  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.723  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.724  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.725  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.727  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.728  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.729  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.733  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:22.734  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
          2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
           Time: '2025-01-30T18:03:25',
           DS18B20: { Id: '02131692A9AA', Temperature: 4.6 },
           TempUnit: 'C'
          2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
          2025-01-30 18:03:29.171  - info: javascript.0 (1387) script.js.Heizung.ATMOS_Steuerung: TSV received
          2025-01-30 18:03:35.367  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
           Time: '2025-01-30T18:03:35',
           TempUnit: 'C'
          2025-01-30 18:03:35.369  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
          iob diag has finished.
          A R 2 Replies Last reply Reply Quote 0
            AndreasE112 @AndreasE112 last edited by
            @andrease112
            ich sehe dass der ESPShome Adapter keinen Port offen hat.
            Und NPM Version 10.8.2 hört sich alt an
              @andrease112
              @andrease112
              Nein, 10.8.2 sollte OK sein. Aber ich sehe da viele Errors.
              Aber um das zu checken bin ich hier der falsche, das sollte sich einmal kurz jemand von den Linux-Könnern ansehen um erst mal das System fit zu bekommen. Scheinbar liest hier keiner von denen mit.
              Und ja, einen Port muß das schon auf machen, aber der ist ja bei dir offen:
              @thomas-braun kannst du dir das diag mal ansehen?
              Thomas Braun R 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Ralf 2 last edited by
                @ralf-2
                Da ist die Spannungsversorgung zu wackelig.
                Da mal genauer schauen:
                Updaten:
                Pending Updates: 11
                Gilt auch für die ganzen ioBroker-Adapter. UPDATEN!
                  Ralf 2 @Ralf 2 last edited by
                  @AndreasE112
                  Ich muß für heute Schluß machen, ich versuche mich für morgen noch einmal zu erinnern wie ich das damals ans laufen bekommen habe.
                  Die Ratschläge von Thomas bitte beachten, das was er vorschlägt hat immer Hand und Fuß.
                  Im übrigen: Der Adapter sollte auch ohne Weboberfläche laufen.
                  Bis morgen...
                    AndreasE112 @Ralf 2 last edited by AndreasE112
                    @ralf-2 hab alle updates gemacht, die 31 crticals waren nur die Spannungsversorgung.
                    Aber das versteh ich nicht da ist eine Powerbank dran und dann Netzgerät.
                    Das soll zum Schutz dienen falls der Strom ausfällt. Dann geht das FS nicht kaputt.
                    Das läuft schon Jahre so... also ich glaub nicht das es ein Problem ist. Eher eine HW Auffälligkeit die wie bekannt ist, auf der Leiterbahn bei dem Strom schon mal 0,1-0,2V abfallen und man dann kurz in den kritischen Bereich kommt (kritisch ist nicht tot) .
                    Bei dem Adapter hatte ich noch den Issue gefunden dass die ESPHome view hardcodiert war. Aber nach dem Update hat sich nichts geändert.
                    Mit den Updates ist schon krass... hab den IObroker erst vor 14 Tagen neu installiert.
                      Thomas Braun Most Active @AndreasE112 last edited by
                      @andrease112 sagte in ESPHome kein Webinterface:
                      Aber das versteh ich nicht da ist eine Powerbank drank und dann Netzgerät.
                      Das hört sich nach einer schrägen Konstellation an. Der Pi braucht dringend was ordentliches an der Stelle.
                        AndreasE112 @Thomas Braun last edited by AndreasE112
                        ich habe im IOBrokerlog noch folgendes gefunden:
                        esphome.0
                        	2025-01-30 23:19:24.219	info	Bonjour service started, new devices will be detected automatically
                        esphome.0
                        	2025-01-30 23:19:19.621	error	Error in function sendSentry: TypeError: Cannot read properties of undefined (reading 'captureException')
                        esphome.0
                        	2025-01-30 23:19:19.619	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:110:19) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:78:5)
                        Pip wird ist aber installiert und zeigt auf das richtige python:
                        pi@iobroker:/usr/bin $ pip -V
                        pip 25.0 from /home/pi/.local/lib/python3.11/site-packages/pip (python 3.11)
                        pi@iobroker:/usr/bin $ pip3 -V
                          @andrease112
                          Ich hatte nicht erwartet, das durch die Massnahmen ESPHome ans rennen kommt, aber Probleme die man erkennt sollte man schon irgendwie angehen. 😊
                          Mir ist da tatsächlich noch etwas eingefallen: Das Dashboard wird ja über ein IFrame eingeblendet das Dashboard funktioniert nur, wenn das über HTTP aufgerufen wird. Hast du deine Web-Instanz auf HTTPS eingestellt?
                          Teste mal ob du das Dashboard so aufrufen kannst:
                          http://deineIP:6052/
                          Vorrausgesetzt du hast ESPHome auf 6052 konfiguriert
                            AndreasE112 last edited by AndreasE112
                            moin, nee ich hab keine Authentifizierung an, und mit der IP-Adresse:6052 kommt keine Antwort.
                            hier noch der neueste IOB diag log
                            ```bash
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             08:22:15 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                            CPU threads: 4
                            Current issues:
                                           Local time: Fri 2025-01-31 08:22:15 CET
                                       Universal time: Fri 2025-01-31 07:22:15 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi i        obroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        2.3G        2.2G        1.3M        3.8G        5.9G
                            Swap:           536M          0B        536M
                            Total:          8.7G        2.3G        2.7G
                                     7808 M total memory
                                     2198 M used memory
                                     2993 M active memory
                                     2294 M inactive memory
                                     2087 M free memory
                                      220 M buffer memory
                                     3424 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            top - 08:22:16 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                            Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   7808.9 total,   2087.1 free,   2199.4 used,   3645.6 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5609.5 avail Mem
                            540 CRITICAL ERRORS DETECTED!
                            *** FILESYSTEM ***
                            /dev/sda2      ext4      110G   14G   92G  14% /
                            [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headph        ones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_si        ze=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes        rootwait cfg80211.ieee80211_regdom=DE
                            [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode        : none.
                            `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname        =mixed,errors=remount-ro
                            /var:
                            5.6G    /var/
                            4.3G    /var/lib
                            1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/u        sr
                            Archived and active journals take up 316.1M in the file system.
                            906M    /opt/iobroker/iobroker-data/
                            529M    /opt/iobroker/iobroker-data/files
                            236M    /opt/iobroker/iobroker-data/history
                            158M    /opt/iobroker/iobroker-data/files/admin.admin
                            157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            45M     /opt/iobroker/iobroker-data/objects.jsonl
                            30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                            19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                            16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
                            USB-Devices by-id:
                            USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-i        d':
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 53301)
                            admin:          7.4.19
                            javascript:     8.9.1
                            Adapter State
                            + instance is alive
                            Adapter    "admin"        : 7.4.19   , installed 7.4.19
                            Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                            Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                            Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                            Adapter    "notification-manager": 1.3.0, installed 1.3.0
                            Adapter    "scenes"       : 4.0.1    , installed 4.0.1
                            Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
                            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                            Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                            Adapter    "trashschedule": 4.0.0    , installed 4.0.0
                            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                            Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
                            Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
                            Adapter    "web"          : 6.3.1    , installed 6.3.1
                            Objects and States
                            Objects:        9068
                            States:         8048
                            Hit:4 https://download.docker.com/linux/debian bookworm InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
                            Pending Updates: 11
                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       33089      5976/io.sonoff.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32565      6322/io.web.0
                            tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29004      5128/io.admin.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       49519      9110/io.esphome.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       31288      6181/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       31289      6181/io.tuya.0
                            2025-01-31 08:23:17.122  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.System.heartbeat"
                            2025-01-31 08:23:17.123  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.ratio_Raum_zu_Speicherabgabe"
                            2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.spezifischerBedarf"
                            2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Vorlauf"
                            2025-01-31 08:23:17.125  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Ruecklauf"
                            2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Pumpe_literMin"
                            2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
                            2025-01-31 08:23:17.127  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
                            2025-01-31 08:23:17.322  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.323  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.324  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.328  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.338  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.339  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:17.340  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                            2025-01-31 08:23:23.391  - info: javascript.0 (5666) script.js.Heizung.ATMOS_Steuerung: TSV received
                            2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: {
                              Time: '2025-01-31T08:23:24',
                              DS18B20: { Id: '02131692A9AA', Temperature: 3.7 },
                              TempUnit: 'C'
                            2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: 3.7
                            -> ESPhome hat kein Binding
                            -> ESPhome zeigt keinen PORT an
                            und dieses ist mir noch aufgefallen:
                            schaut der jetzt auf Portz 5353. Da kommt aber auch nix im Browser.
                              Thomas Braun Most Active @AndreasE112 last edited by Thomas Braun
                              Pending Updates: 11
                              Öh...
                                @thomas-braun Also ja öh ... aber mir erscheint das logisch wenn ich das development repository drin hab. Jetzt hab ich viele Adapter in der beta installiert. toll. Und ich glaube nicht dass die Spannungsvesorgung etwas mit dem Dashbord von ESPHome zu tun hat.
                                Wie gesagt das läuft schon jahre so und das raspi läuft ohne Fehler.
                                A R Thomas Braun 3 Replies Last reply Reply Quote 0
                                  Ich hab's ESP home jetzt mal im Docker installiert.
                                  klappt aber auch nicht :
                                  pi@iobroker:/usr/bin $ docker run esphome/esphome
                                  Creating cache directory /config/.esphome/platformio
                                  You can change this behavior by mounting a directory to the container's /cache directory.
                                  2025-01-31 08:07:27,472 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /config...
                                  2025-01-31 08:07:53,186 INFO 200 GET /version (127.0.0.1) 1.75ms
                                  2025-01-31 08:08:23,301 INFO 200 GET /version (127.0.0.1) 1.06ms
                                  2025-01-31 08:08:53,547 INFO 200 GET /version (127.0.0.1) 2.39ms
                                    @andrease112
                                    Nun, nachdem man etwas aus Beta installiert hat stellt man eigentlich wieder auf stable um 😊
                                    Du kannst auf Stable zurück stellen und dann die aus dem Beta hier wieder auf die stable bringen:
                                    Expertenmodus muss dazu aktiviert sein:
                                    Der Port auf dem ESPHome läuft ist von phyton geöffnet. Vielleicht hat auch das damit zu tuen, bei mir steht dort phyton3, bei dir phyton. Auch hier hatte ich mal ein Problem gehabt, ist aber alles sooo lange her.
                                    Schau mal was als Port bei dir im ESPHome konfiguriert ist.
                                    versuche mal auf port 80 und 443 zu verbinden, die stehen bei dir auf Listen - seltsam, bei mir ist es nur ein Port. Kann aber sein, das du noch etwas anderes phytonbasiertes laufen hast, es sind ja noch zwei weitere Ports angegeben.
                                    Welchen Port hast du denn im Adapter angegeben?
                                    Port 5353 ist der Port, wo die Sensoren die Daten hin schicken.
                                    Das sind deine Ports auf denen Phyton lauscht:
                                    Das hier sind meine Ports, wobei das Dashboard auf 6052 aufgeht, auf 5353 gehen die Signale ein:
                                    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       46729      2188/python3
                                    udp        0      0 192.168.176.98:5353     0.0.0.0:*                           1000       47752      2188/python3
                                    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       47751      2188/python3
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       47747      2188/python3
                                      Nein, er läuft eben nicht ohne Fehler. Steht ja auch so im Log.
                                        @ralf-2
                                        Ja die beiden anderen Ports sind von : DIY HUE Bridge auf Port 80
                                        und Agent DVR auf PORT 5353
                                        Auf 443 kommt nix zurück.... ich glaube das ist die Verbindung IObrokerMII adapter zur MII brigde. zwischen Agent DVR und IP CAM
                                          @andrease112
                                          Ich habe mir gerade einen neuen Raspberry hochgezogen und das aus dem Latest installiert. Nein, es klappt nicht, dazu gibt es auch schon länger ein Issue. Das Problem ist mit der 0.5.0-beta.10 behoben, aber das ist nicht im Beta (Latest) vorhanden.
                                          Das Issue dazu hier hier dort steht auch die Lösung, dazu muß man etwas tuen, wo hier immer absolut abgeraten wird nämlich mit der bösen Katze direkt von GitHub zu installieren.
                                          Dazu muss man einen Branch von dem Adapter von dieser Adresse installieren.
                                          (Thomas wird mich für den Rat jetzt hauen 🙄 )
                                          Der Adapter ist von Dutchman, ich hoffe es geht ihm gut und er wird irgendwann noch mal dazu kommen den Adapter weiter zu pflegen. Ich möchte ihn nicht missen.
                                          Die Installation direkt von GitHub ist absolut auf eigene Gefahr und sollte eine ganz ganz seltene Ausnahme bleiben.
                                          Aber eine bitte noch von mir: Reparier dein System!
                                          "Das Auto ist jahrelang ohne Probleme mit der roten Lampe gefahren" sagte der Autofahrer mit Motorschaden zum gelben Engel ...
                                            Hi ja das ist mir auch schon in den sinn gekommen.
                                            Ich hatte es runtergeladen unzipped und dann konnte ich es nicht mit ./configure und make bauen.
                                            hat hier noch jemand nen tip ?
                                            Habs nun auch hinbekommen über die Katze 🙂 : ist aber immernoch der gleiche Fehler da.
                                            Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)```
                                            1497
