    4. ESPHome kein Webinterface
      AndreasE112 @Ralf 2 last edited by
      @ralf-2
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
      Static hostname: iobroker
            Icon name: computer
               Kernel: Linux 6.6.62+rpt-rpi-v8
         Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
      18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** TIME AND TIMEZONES ***
                    Local time: Thu 2025-01-30 18:02:11 CET
                Universal time: Thu 2025-01-30 17:02:11 UTC
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        1.9G        4.8G        1.3M        1.5G        6.3G
      Swap:           536M          0B        536M
      Total:          8.7G        1.9G        5.4G
      Active iob-Instances:   22
              7808 M total memory
              1831 M used memory
              2648 M active memory
               355 M inactive memory
              4624 M free memory
                79 M buffer memory
              1396 M swap cache
               511 M total swap
                 0 M used swap
               511 M free swap
      top - 18:02:11 up 28 min,  3 users,  load average: 0.98, 0.82, 0.94
      Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7808.9 total,   4622.7 free,   1832.6 used,   1477.1 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5976.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      31 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     781M  1.3M  780M   1% /run
      /dev/sda2      ext4      110G   15G   91G  14% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
      [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Thu Jan 30 17:33:35 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.6G    /var/
      4.3G    /var/lib
      4.2G    /var/lib/docker/overlay2
      1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/usr
      Archived and active journals take up 308.1M in the file system.
      /opt/iobroker/backups:
      130M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.5G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      32M     /opt/iobroker/iobroker-data/history/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
       Installed: 20.18.1-1nodesource1
       Candidate: 20.18.2-1nodesource1
       Version table:
          20.18.2-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
      *** 20.18.1-1nodesource1 1001
             100 /var/lib/dpkg/status
          20.18.0-1nodesource1 1001
          20.17.0-1nodesource1 1001
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
          18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1708)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
       system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
       system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
       system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
       system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 0.0.0.0
       system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
       system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
       system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
       system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
       system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
       system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.4.19   , installed 7.4.10 [Updatable]
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullybrowser" : 3.0.13   , installed 3.0.12 [Updatable]
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "modbus"       : 6.4.0    , installed 6.3.2  [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "notification-manager": 1.3.0, installed 1.2.1 [Updatable]
      Adapter    "scenes"       : 4.0.1    , installed 3.2.3  [Updatable]
      Adapter    "shuttercontrol": 1.8.8   , installed 1.8.5  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
      Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
      Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
      Adapter    "tuya"         : 3.17.0   , installed 3.16.0 [Updatable]
      Adapter    "vis-2"        : 2.11.2   , installed 2.9.64 [Updatable]
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weather-warnings": 0.7.3 , installed 0.6.11 [Updatable]
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.3.1    , installed 6.2.5  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        9057
      States:         8038
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://download.docker.com/linux/debian bookworm InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 11
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6006       589/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1888       589/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8172       1968/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8173       1968/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       11029      2042/io.sonoff.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8557       1043/python
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5674       614/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          9339       1043/python
      tcp        0      0 0.0.0.0:12101           0.0.0.0:*               LISTEN      0          959        915/docker-proxy
      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       7255       453/Agent
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5676       614/sshd: /usr/sbin
      tcp6       0      0 :::12101                :::*                    LISTEN      0          964        928/docker-proxy
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12580      2133/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       11470      1248/io.admin.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14977      3056/io.esphome.0
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       7341       453/Agent
      udp        0      0 192.168.178.54:5353     0.0.0.0:*                           1000       7340       453/Agent
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7339       453/Agent
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           0          9338       1043/python
      udp        0      0 192.168.178.54:5353     0.0.0.0:*                           0          9337       1043/python
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           0          9336       1043/python
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          9330       1043/python
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5547       455/avahi-daemon: r
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       12292      1992/io.mihome.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          7287       1043/python
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11123      2014/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11124      2014/io.tuya.0
      udp        0      0 0.0.0.0:44125           0.0.0.0:*                           0          8514       1043/python
      udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1000       6267       453/Agent
      udp        0      0 0.0.0.0:52788           0.0.0.0:*                           104        5549       455/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5548       455/avahi-daemon: r
      udp6       0      0 :::43249                :::*                                104        5550       455/avahi-daemon: r
      udp6       0      0 fe80::34bb:d917:52c:546 :::*                                0          5735       537/NetworkManager
      2025-01-30 18:03:22.529  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
      2025-01-30 18:03:22.531  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
      2025-01-30 18:03:22.721  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.723  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.724  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.725  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.727  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.728  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.729  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.733  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:22.734  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
       Time: '2025-01-30T18:03:25',
       DS18B20: { Id: '02131692A9AA', Temperature: 4.6 },
       TempUnit: 'C'
      2025-01-30 18:03:25.263  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
      2025-01-30 18:03:29.171  - info: javascript.0 (1387) script.js.Heizung.ATMOS_Steuerung: TSV received
      2025-01-30 18:03:35.367  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: {
       Time: '2025-01-30T18:03:35',
       TempUnit: 'C'
      2025-01-30 18:03:35.369  - info: javascript.0 (1387) script.js.Heizung.Aussentemperaturfühler: 4.6
      iob diag has finished.
      A R 2 Replies Last reply Reply Quote 0
        AndreasE112 @AndreasE112 last edited by
        @andrease112
        ich sehe dass der ESPShome Adapter keinen Port offen hat.
        Und NPM Version 10.8.2 hört sich alt an
          Ralf 2 @AndreasE112 last edited by
          @andrease112
          @andrease112
          Nein, 10.8.2 sollte OK sein. Aber ich sehe da viele Errors.
          Aber um das zu checken bin ich hier der falsche, das sollte sich einmal kurz jemand von den Linux-Könnern ansehen um erst mal das System fit zu bekommen. Scheinbar liest hier keiner von denen mit.
          Und ja, einen Port muß das schon auf machen, aber der ist ja bei dir offen:
          @thomas-braun kannst du dir das diag mal ansehen?
          Thomas Braun R 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Ralf 2 last edited by
            @ralf-2
            Da ist die Spannungsversorgung zu wackelig.
            Da mal genauer schauen:
            Updaten:
            Pending Updates: 11
            Gilt auch für die ganzen ioBroker-Adapter. UPDATEN!
              Ralf 2 @Ralf 2 last edited by
              @AndreasE112
              Ich muß für heute Schluß machen, ich versuche mich für morgen noch einmal zu erinnern wie ich das damals ans laufen bekommen habe.
              Die Ratschläge von Thomas bitte beachten, das was er vorschlägt hat immer Hand und Fuß.
              Im übrigen: Der Adapter sollte auch ohne Weboberfläche laufen.
              Bis morgen...
                AndreasE112 @Ralf 2 last edited by AndreasE112
                @ralf-2 hab alle updates gemacht, die 31 crticals waren nur die Spannungsversorgung.
                Aber das versteh ich nicht da ist eine Powerbank dran und dann Netzgerät.
                Das soll zum Schutz dienen falls der Strom ausfällt. Dann geht das FS nicht kaputt.
                Das läuft schon Jahre so... also ich glaub nicht das es ein Problem ist. Eher eine HW Auffälligkeit die wie bekannt ist, auf der Leiterbahn bei dem Strom schon mal 0,1-0,2V abfallen und man dann kurz in den kritischen Bereich kommt (kritisch ist nicht tot) .
                Bei dem Adapter hatte ich noch den Issue gefunden dass die ESPHome view hardcodiert war. Aber nach dem Update hat sich nichts geändert.
                Mit den Updates ist schon krass... hab den IObroker erst vor 14 Tagen neu installiert.
                  Thomas Braun Most Active @AndreasE112 last edited by
                  @andrease112 sagte in ESPHome kein Webinterface:
                  Aber das versteh ich nicht da ist eine Powerbank drank und dann Netzgerät.
                  Das hört sich nach einer schrägen Konstellation an. Der Pi braucht dringend was ordentliches an der Stelle.
                    AndreasE112 @Thomas Braun last edited by AndreasE112
                    ich habe im IOBrokerlog noch folgendes gefunden:
                    esphome.0
                    	2025-01-30 23:19:24.219	info	Bonjour service started, new devices will be detected automatically
                    esphome.0
                    	2025-01-30 23:19:19.621	error	Error in function sendSentry: TypeError: Cannot read properties of undefined (reading 'captureException')
                    esphome.0
                    	2025-01-30 23:19:19.619	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:110:19) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:78:5)
                    Pip wird ist aber installiert und zeigt auf das richtige python:
                    pi@iobroker:/usr/bin $ pip -V
                    pip 25.0 from /home/pi/.local/lib/python3.11/site-packages/pip (python 3.11)
                    pi@iobroker:/usr/bin $ pip3 -V
                      @andrease112
                      Ich hatte nicht erwartet, das durch die Massnahmen ESPHome ans rennen kommt, aber Probleme die man erkennt sollte man schon irgendwie angehen. 😊
                      Mir ist da tatsächlich noch etwas eingefallen: Das Dashboard wird ja über ein IFrame eingeblendet das Dashboard funktioniert nur, wenn das über HTTP aufgerufen wird. Hast du deine Web-Instanz auf HTTPS eingestellt?
                      Teste mal ob du das Dashboard so aufrufen kannst:
                      http://deineIP:6052/
                      Vorrausgesetzt du hast ESPHome auf 6052 konfiguriert
                        AndreasE112 last edited by AndreasE112
                        moin, nee ich hab keine Authentifizierung an, und mit der IP-Adresse:6052 kommt keine Antwort.
                        hier noch der neueste IOB diag log
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         08:22:15 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                        CPU threads: 4
                        Current issues:
                                       Local time: Fri 2025-01-31 08:22:15 CET
                                   Universal time: Fri 2025-01-31 07:22:15 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi i        obroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.2G        2.3G        2.2G        1.3M        3.8G        5.9G
                        Swap:           536M          0B        536M
                        Total:          8.7G        2.3G        2.7G
                                 7808 M total memory
                                 2198 M used memory
                                 2993 M active memory
                                 2294 M inactive memory
                                 2087 M free memory
                                  220 M buffer memory
                                 3424 M swap cache
                                  511 M total swap
                                    0 M used swap
                                  511 M free swap
                        top - 08:22:16 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
                        Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   7808.9 total,   2087.1 free,   2199.4 used,   3645.6 buff/cache
                        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5609.5 avail Mem
                        540 CRITICAL ERRORS DETECTED!
                        *** FILESYSTEM ***
                        /dev/sda2      ext4      110G   14G   92G  14% /
                        [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headph        ones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_si        ze=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes        rootwait cfg80211.ieee80211_regdom=DE
                        [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode        : none.
                        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname        =mixed,errors=remount-ro
                        /var:
                        5.6G    /var/
                        4.3G    /var/lib
                        1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/u        sr
                        Archived and active journals take up 316.1M in the file system.
                        906M    /opt/iobroker/iobroker-data/
                        529M    /opt/iobroker/iobroker-data/files
                        236M    /opt/iobroker/iobroker-data/history
                        158M    /opt/iobroker/iobroker-data/files/admin.admin
                        157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        45M     /opt/iobroker/iobroker-data/objects.jsonl
                        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                        16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
                        USB-Devices by-id:
                        USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-i        d':
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 53301)
                        admin:          7.4.19
                        javascript:     8.9.1
                        Adapter State
                        + instance is alive
                        Adapter    "admin"        : 7.4.19   , installed 7.4.19
                        Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                        Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                        Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                        Adapter    "notification-manager": 1.3.0, installed 1.3.0
                        Adapter    "scenes"       : 4.0.1    , installed 4.0.1
                        Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                        Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                        Adapter    "trashschedule": 4.0.0    , installed 4.0.0
                        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                        Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
                        Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
                        Adapter    "web"          : 6.3.1    , installed 6.3.1
                        Objects and States
                        Objects:        9068
                        States:         8048
                        Hit:4 https://download.docker.com/linux/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
                        Pending Updates: 11
                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       33089      5976/io.sonoff.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32565      6322/io.web.0
                        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29004      5128/io.admin.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       49519      9110/io.esphome.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       31288      6181/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       31289      6181/io.tuya.0
                        2025-01-31 08:23:17.122  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.System.heartbeat"
                        2025-01-31 08:23:17.123  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.ratio_Raum_zu_Speicherabgabe"
                        2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.spezifischerBedarf"
                        2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Vorlauf"
                        2025-01-31 08:23:17.125  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Ruecklauf"
                        2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Pumpe_literMin"
                        2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
                        2025-01-31 08:23:17.127  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
                        2025-01-31 08:23:17.322  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.323  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.324  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.328  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.338  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.339  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:17.340  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
                        2025-01-31 08:23:23.391  - info: javascript.0 (5666) script.js.Heizung.ATMOS_Steuerung: TSV received
                        2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: {
                          Time: '2025-01-31T08:23:24',
                          DS18B20: { Id: '02131692A9AA', Temperature: 3.7 },
                          TempUnit: 'C'
                        2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: 3.7
                        -> ESPhome hat kein Binding
                        -> ESPhome zeigt keinen PORT an
                        und dieses ist mir noch aufgefallen:
                        schaut der jetzt auf Portz 5353. Da kommt aber auch nix im Browser.
                          Thomas Braun Most Active @AndreasE112 last edited by Thomas Braun
                          Pending Updates: 11
                          Öh...
                            @thomas-braun Also ja öh ... aber mir erscheint das logisch wenn ich das development repository drin hab. Jetzt hab ich viele Adapter in der beta installiert. toll. Und ich glaube nicht dass die Spannungsvesorgung etwas mit dem Dashbord von ESPHome zu tun hat.
                            Wie gesagt das läuft schon jahre so und das raspi läuft ohne Fehler.
                            A R Thomas Braun 3 Replies Last reply Reply Quote 0
                              Ich hab's ESP home jetzt mal im Docker installiert.
                              klappt aber auch nicht :
                              pi@iobroker:/usr/bin $ docker run esphome/esphome
                              Creating cache directory /config/.esphome/platformio
                              You can change this behavior by mounting a directory to the container's /cache directory.
                              2025-01-31 08:07:27,472 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /config...
                              2025-01-31 08:07:53,186 INFO 200 GET /version (127.0.0.1) 1.75ms
                              2025-01-31 08:08:23,301 INFO 200 GET /version (127.0.0.1) 1.06ms
                              2025-01-31 08:08:53,547 INFO 200 GET /version (127.0.0.1) 2.39ms
                                @andrease112
                                Nun, nachdem man etwas aus Beta installiert hat stellt man eigentlich wieder auf stable um 😊
                                Du kannst auf Stable zurück stellen und dann die aus dem Beta hier wieder auf die stable bringen:
                                Expertenmodus muss dazu aktiviert sein:
                                Der Port auf dem ESPHome läuft ist von phyton geöffnet. Vielleicht hat auch das damit zu tuen, bei mir steht dort phyton3, bei dir phyton. Auch hier hatte ich mal ein Problem gehabt, ist aber alles sooo lange her.
                                Schau mal was als Port bei dir im ESPHome konfiguriert ist.
                                versuche mal auf port 80 und 443 zu verbinden, die stehen bei dir auf Listen - seltsam, bei mir ist es nur ein Port. Kann aber sein, das du noch etwas anderes phytonbasiertes laufen hast, es sind ja noch zwei weitere Ports angegeben.
                                Welchen Port hast du denn im Adapter angegeben?
                                Port 5353 ist der Port, wo die Sensoren die Daten hin schicken.
                                Das sind deine Ports auf denen Phyton lauscht:
                                Das hier sind meine Ports, wobei das Dashboard auf 6052 aufgeht, auf 5353 gehen die Signale ein:
                                tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       46729      2188/python3
                                udp        0      0 192.168.176.98:5353     0.0.0.0:*                           1000       47752      2188/python3
                                udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       47751      2188/python3
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       47747      2188/python3
                                  Nein, er läuft eben nicht ohne Fehler. Steht ja auch so im Log.
                                    @ralf-2
                                    Ja die beiden anderen Ports sind von : DIY HUE Bridge auf Port 80
                                    und Agent DVR auf PORT 5353
                                    Auf 443 kommt nix zurück.... ich glaube das ist die Verbindung IObrokerMII adapter zur MII brigde. zwischen Agent DVR und IP CAM
                                      @andrease112
                                      Ich habe mir gerade einen neuen Raspberry hochgezogen und das aus dem Latest installiert. Nein, es klappt nicht, dazu gibt es auch schon länger ein Issue. Das Problem ist mit der 0.5.0-beta.10 behoben, aber das ist nicht im Beta (Latest) vorhanden.
                                      Das Issue dazu hier hier dort steht auch die Lösung, dazu muß man etwas tuen, wo hier immer absolut abgeraten wird nämlich mit der bösen Katze direkt von GitHub zu installieren.
                                      Dazu muss man einen Branch von dem Adapter von dieser Adresse installieren.
                                      (Thomas wird mich für den Rat jetzt hauen 🙄 )
                                      Der Adapter ist von Dutchman, ich hoffe es geht ihm gut und er wird irgendwann noch mal dazu kommen den Adapter weiter zu pflegen. Ich möchte ihn nicht missen.
                                      Die Installation direkt von GitHub ist absolut auf eigene Gefahr und sollte eine ganz ganz seltene Ausnahme bleiben.
                                      Aber eine bitte noch von mir: Reparier dein System!
                                      "Das Auto ist jahrelang ohne Probleme mit der roten Lampe gefahren" sagte der Autofahrer mit Motorschaden zum gelben Engel ...
                                        Hi ja das ist mir auch schon in den sinn gekommen.
                                        Ich hatte es runtergeladen unzipped und dann konnte ich es nicht mit ./configure und make bauen.
                                        hat hier noch jemand nen tip ?
                                        Habs nun auch hinbekommen über die Katze 🙂 : ist aber immernoch der gleiche Fehler da.
                                        Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)```
                                            @andrease112
                                            PIP gehört zu Phyton, also liegt da etwas im argen.
                                            Ich habe wie gesagt nur IOBroker frisch aufgesetzt, einmal Webadapter reingehauen und dann das ESPHome installiert. Ohne mich vorher mit phyton und pip rum zu schlagen. Aus dem Branch lief es dann und ich konnte ein Testgerät anlegen.
                                            Wenn ich auf der Console dann nach pip oder phyton Version frage, wird beides nicht gefunden, scheint irgendwo lokal zu liegen (noch nicht nachgeschaut). Auf meinem Produktivsystem bekomme ich für beides die korrekten Versionsnummern angezeigt.
                                            Vielleicht muß hier noch irgendwo ein Pfad bei dir gesetzt werden, aber da habe ich echt viel zu wenig Ahnung von Linux als das ich hier noch helfen könnte.
                                            1497
