    4. ESPHome kein Webinterface
      AndreasE112 last edited by AndreasE112
      moin, nee ich hab keine Authentifizierung an, und mit der IP-Adresse:6052 kommt keine Antwort.
      hier noch der neueste IOB diag log
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       08:22:15 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-01-31 08:22:15 CET
                 Universal time: Fri 2025-01-31 07:22:15 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi i        obroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        2.3G        2.2G        1.3M        3.8G        5.9G
      Swap:           536M          0B        536M
      Total:          8.7G        2.3G        2.7G
      Active iob-Instances:   22
               7808 M total memory
               2198 M used memory
               2993 M active memory
               2294 M inactive memory
               2087 M free memory
                220 M buffer memory
               3424 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 08:22:16 up 14:48,  3 users,  load average: 1.54, 1.00, 0.76
      Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7808.9 total,   2087.1 free,   2199.4 used,   3645.6 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5609.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      540 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     781M  1.3M  780M   1% /run
      /dev/sda2      ext4      110G   14G   92G  14% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/sda1      vfat      510M   55M  456M  11% /boot/firmware
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
      [Thu Jan 30 17:33:32 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headph        ones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:84:F0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_si        ze=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=76923411-02 rootfstype=ext4 fsck.repair=yes        rootwait cfg80211.ieee80211_regdom=DE
      [Thu Jan 30 17:33:35 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with        ordered data mode. Quota mode: none.
      [Thu Jan 30 17:33:37 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode        : none.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname        =mixed,errors=remount-ro
      /var:
      5.6G    /var/
      4.3G    /var/lib
      4.2G    /var/lib/docker/overlay2
      1.7G    /var/lib/docker/overlay2/0249de1e2b018f45e8e966d3ff11bdb185c5c9c91d17d2519ac33136f88f41bc/merged/u        sr
      Archived and active journals take up 316.1M in the file system.
      /opt/iobroker/backups:
      130M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      906M    /opt/iobroker/iobroker-data/
      529M    /opt/iobroker/iobroker-data/files
      236M    /opt/iobroker/iobroker-data/history
      158M    /opt/iobroker/iobroker-data/files/admin.admin
      157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      45M     /opt/iobroker/iobroker-data/objects.jsonl
      32M     /opt/iobroker/iobroker-data/history/objects.jsonl
      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
      16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-i        d':
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
           20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
       *** 20.18.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 53301)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.19
      javascript:     8.9.1
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mihome.0                 : mihome                : iobroker                                 -  enabled, port: 9898, bind: 0.0.0.0
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.weatherunderground.1     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.4.19   , installed 7.4.19
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "javascript"   : 8.9.1    , installed 8.9.1
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "notification-manager": 1.3.0, installed 1.3.0
      Adapter    "scenes"       : 4.0.1    , installed 4.0.1
      Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "telegram"     : 4.0.0    , installed 4.0.0
      Adapter    "trashschedule": 4.0.0    , installed 4.0.0
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.3.1    , installed 6.3.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        9068
      States:         8048
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://download.docker.com/linux/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 11
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6006       589/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1888       589/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8172       1968/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8173       1968/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       33089      5976/io.sonoff.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8557       1043/python
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5674       614/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          9339       1043/python
      tcp        0      0 0.0.0.0:12101           0.0.0.0:*               LISTEN      0          959        915/docker-proxy
      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       7255       453/Agent
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5676       614/sshd: /usr/sbin
      tcp6       0      0 :::12101                :::*                    LISTEN      0          964        928/docker-proxy
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32565      6322/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29004      5128/io.admin.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       49519      9110/io.esphome.0
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       7341       453/Agent
      udp        0      0 192.168.178.54:5353     0.0.0.0:*                           1000       7340       453/Agent
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7339       453/Agent
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           0          9338       1043/python
      udp        0      0 192.168.178.54:5353     0.0.0.0:*                           0          9337       1043/python
      udp        0      0 172.17.0.1:5353         0.0.0.0:*                           0          9336       1043/python
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          9330       1043/python
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5547       455/avahi-daemon: r
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       12292      1992/io.mihome.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          7287       1043/python
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       31288      6181/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       31289      6181/io.tuya.0
      udp        0      0 0.0.0.0:44125           0.0.0.0:*                           0          8514       1043/python
      udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1000       6267       453/Agent
      udp        0      0 0.0.0.0:52788           0.0.0.0:*                           104        5549       455/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5548       455/avahi-daemon: r
      udp6       0      0 :::43249                :::*                                104        5550       455/avahi-daemon: r
      udp6       0      0 fe80::34bb:d917:52c:546 :::*                                0          5735       537/NetworkManager
      2025-01-31 08:23:17.122  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.System.heartbeat"
      2025-01-31 08:23:17.123  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.ratio_Raum_zu_Speicherabgabe"
      2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.spezifischerBedarf"
      2025-01-31 08:23:17.124  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Vorlauf"
      2025-01-31 08:23:17.125  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Adresse_Sensor_Ruecklauf"
      2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Pumpe_literMin"
      2025-01-31 08:23:17.126  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_gesamt"
      2025-01-31 08:23:17.127  - info: mqtt.0 (1968) Client [Arduino_Ofen] subscribes on "mqtt.0.Arduino_Ofen.Parameter.Wohnfläche_Etage_mit_ofen"
      2025-01-31 08:23:17.322  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.323  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.324  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.328  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.338  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.339  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:17.340  - info: mqtt.0 (1968) Client [Arduino_Ofen] publishOnSubscribe
      2025-01-31 08:23:23.391  - info: javascript.0 (5666) script.js.Heizung.ATMOS_Steuerung: TSV received
      2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: {
        Time: '2025-01-31T08:23:24',
        DS18B20: { Id: '02131692A9AA', Temperature: 3.7 },
        TempUnit: 'C'
      2025-01-31 08:23:24.869  - info: javascript.0 (5666) script.js.Heizung.Aussentemperaturfühler: 3.7
      -> ESPhome hat kein Binding
      -> ESPhome zeigt keinen PORT an
      und dieses ist mir noch aufgefallen:
      schaut der jetzt auf Portz 5353. Da kommt aber auch nix im Browser.
        Thomas Braun Most Active @AndreasE112 last edited by Thomas Braun
        @andrease112 sagte in ESPHome kein Webinterface:
        Pending Updates: 11
        Öh...
          AndreasE112 @Thomas Braun last edited by
          @thomas-braun Also ja öh ... aber mir erscheint das logisch wenn ich das development repository drin hab. Jetzt hab ich viele Adapter in der beta installiert. toll. Und ich glaube nicht dass die Spannungsvesorgung etwas mit dem Dashbord von ESPHome zu tun hat.
          Wie gesagt das läuft schon jahre so und das raspi läuft ohne Fehler.
          A R Thomas Braun 3 Replies Last reply Reply Quote 0
            AndreasE112 @AndreasE112 last edited by
            Ich hab's ESP home jetzt mal im Docker installiert.
            klappt aber auch nicht :
            pi@iobroker:/usr/bin $ docker run esphome/esphome
            Creating cache directory /config/.esphome/platformio
            You can change this behavior by mounting a directory to the container's /cache directory.
            2025-01-31 08:07:27,472 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /config...
            2025-01-31 08:07:53,186 INFO 200 GET /version (127.0.0.1) 1.75ms
            2025-01-31 08:08:23,301 INFO 200 GET /version (127.0.0.1) 1.06ms
            2025-01-31 08:08:53,547 INFO 200 GET /version (127.0.0.1) 2.39ms
              Ralf 2 @AndreasE112 last edited by
              @andrease112
              Nun, nachdem man etwas aus Beta installiert hat stellt man eigentlich wieder auf stable um 😊
              Du kannst auf Stable zurück stellen und dann die aus dem Beta hier wieder auf die stable bringen:
              Expertenmodus muss dazu aktiviert sein:
              Der Port auf dem ESPHome läuft ist von phyton geöffnet. Vielleicht hat auch das damit zu tuen, bei mir steht dort phyton3, bei dir phyton. Auch hier hatte ich mal ein Problem gehabt, ist aber alles sooo lange her.
              Schau mal was als Port bei dir im ESPHome konfiguriert ist.
              versuche mal auf port 80 und 443 zu verbinden, die stehen bei dir auf Listen - seltsam, bei mir ist es nur ein Port. Kann aber sein, das du noch etwas anderes phytonbasiertes laufen hast, es sind ja noch zwei weitere Ports angegeben.
              Welchen Port hast du denn im Adapter angegeben?
              Port 5353 ist der Port, wo die Sensoren die Daten hin schicken.
              Das sind deine Ports auf denen Phyton lauscht:
              Das hier sind meine Ports, wobei das Dashboard auf 6052 aufgeht, auf 5353 gehen die Signale ein:
              tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       46729      2188/python3
              udp        0      0 192.168.176.98:5353     0.0.0.0:*                           1000       47752      2188/python3
              udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       47751      2188/python3
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       47747      2188/python3
                Nein, er läuft eben nicht ohne Fehler. Steht ja auch so im Log.
                  AndreasE112 @Ralf 2 last edited by AndreasE112
                  @ralf-2
                  Ja die beiden anderen Ports sind von : DIY HUE Bridge auf Port 80
                  und Agent DVR auf PORT 5353
                  Auf 443 kommt nix zurück.... ich glaube das ist die Verbindung IObrokerMII adapter zur MII brigde. zwischen Agent DVR und IP CAM
                    @andrease112
                    Ich habe mir gerade einen neuen Raspberry hochgezogen und das aus dem Latest installiert. Nein, es klappt nicht, dazu gibt es auch schon länger ein Issue. Das Problem ist mit der 0.5.0-beta.10 behoben, aber das ist nicht im Beta (Latest) vorhanden.
                    Das Issue dazu hier hier dort steht auch die Lösung, dazu muß man etwas tuen, wo hier immer absolut abgeraten wird nämlich mit der bösen Katze direkt von GitHub zu installieren.
                    Dazu muss man einen Branch von dem Adapter von dieser Adresse installieren.
                    (Thomas wird mich für den Rat jetzt hauen 🙄 )
                    Der Adapter ist von Dutchman, ich hoffe es geht ihm gut und er wird irgendwann noch mal dazu kommen den Adapter weiter zu pflegen. Ich möchte ihn nicht missen.
                    Die Installation direkt von GitHub ist absolut auf eigene Gefahr und sollte eine ganz ganz seltene Ausnahme bleiben.
                    Aber eine bitte noch von mir: Reparier dein System!
                    "Das Auto ist jahrelang ohne Probleme mit der roten Lampe gefahren" sagte der Autofahrer mit Motorschaden zum gelben Engel ...
                      Hi ja das ist mir auch schon in den sinn gekommen.
                      Ich hatte es runtergeladen unzipped und dann konnte ich es nicht mit ./configure und make bauen.
                      hat hier noch jemand nen tip ?
                      Habs nun auch hinbekommen über die Katze 🙂 : ist aber immernoch der gleiche Fehler da.
                      Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip list --local --format json/home/iobroker/.cache/autopy/venv/esphome/bin/python3: No module named pip at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/dist/index.js:157:35) at async Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at async Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)```
                          @andrease112
                          PIP gehört zu Phyton, also liegt da etwas im argen.
                          Ich habe wie gesagt nur IOBroker frisch aufgesetzt, einmal Webadapter reingehauen und dann das ESPHome installiert. Ohne mich vorher mit phyton und pip rum zu schlagen. Aus dem Branch lief es dann und ich konnte ein Testgerät anlegen.
                          Wenn ich auf der Console dann nach pip oder phyton Version frage, wird beides nicht gefunden, scheint irgendwo lokal zu liegen (noch nicht nachgeschaut). Auf meinem Produktivsystem bekomme ich für beides die korrekten Versionsnummern angezeigt.
                          Vielleicht muß hier noch irgendwo ein Pfad bei dir gesetzt werden, aber da habe ich echt viel zu wenig Ahnung von Linux als das ich hier noch helfen könnte.
                            ja und zwar glaub ich hier liegt das Problem:
                            pi@iobroker:/usr/local/bin/esphome $ python -m ensurepip
                            Defaulting to user installation because normal site-packages is not writeable
                            Looking in links: /tmp/tmplhmx8v86
                            Requirement already satisfied: setuptools in /usr/local/lib/python3.9/site-packages (58.1.0)
                            Requirement already satisfied: pip in /usr/local/lib/python3.9/site-packages (23.0.1)
                            Mal schauen wie sich das ändern lässt...
                            deinstallieren und neu installiert: Pfade zu pip sind nun scheinbar korrekt
                            pi@iobroker:/usr/local/lib $ pip -V
                            pip 25.0 from /home/pi/.local/lib/python3.11/site-packages/pip (python 3.11)
                            pi@iobroker:/usr/local/lib $ pip3 -V
                              @Ralf Meinst du das es funktionieren könnte wenn ich das Raspi in einer VDI neu installiere mit iob und esphome und und und .... und nachher das image auf die festplatte schiebe ?
                                ok das geht so nicht
                                  @andrease112
                                  Erst in eine Vituelle Maschine und danach auf den Raspi?
                                  Würde ich nicht machen, wenn den Raspi direkt aufsetzen.
                                  Hast du auf einer Karte installiert oder in einer SSD?
                                  Man könnte ein neues Medium nehmen und hätte dann ein weiteres Backup mit dem jetzigen Stand.
                                  Was hast du auf dem Raspi denn sonst noch drauf?
                                  Du benutzt den History-Adapter, IMHO muß man da nicht extra eine Datenbank installieren...
                                  Sonst etwas, was du da extra installieren mußt?
                                  Ich würde die Kiste eher neu aufsetzen. Aktuelles Backup vorher auf einen externen Datenträger sichern, damit du das zurück spielen kannst. Die Kiste wäre dann sauber. BackItUp wird automatisch mit installiert, nach dem Backup werden dann auch die Adapter wieder sauber installiert. Ändert jedoch alles nichts an deinen Problemen mit der Spannungsversorgung.
                                  Wie ein neu aufsetzen geht steht hier beschrieben: https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                  Ich muß gleich jedoch wieder weg, kann heute nicht mehr helfen.
                                    Ich muss sagen ich war jetzt echt verzweifelt, ich das raspi neu aufgesetzt mit bookworm. Habe das Backup reingespielt und dann ESPHome. Sonst nix. ging nicht.... kommt der Fehler mit der Pillow lib, downgrade hat auf beta 8 hat auch nichts gebracht.
                                    Während ich docker installiert habe ist mir dann aufgefallen, dass pip nicht installiert war.
                                    -> "sudo apt install python3-pip"
                                    und plötzlich läuft es mit der beta 8. was kann die 10er mehr ?
                                      @andrease112
                                      Nichts, da ist nur der Fehler mit der Pillow behoben worden.
                                      Wenn es jetzt läuft, einfach so lassen. Mein Produktivsystem läuft auch auf der 8er.
                                        ok also dann nochmal danke an alle !👏 👍
                                          kann man neben der Device Config auch die virtuelle Oberfläche generieren so wie bei HA ? Ich habe jetzt einen Voice Assistent mit dem ESP32-S3 gebaut. Scheint laut log zu laufen. Aber wie kann ich jetzt die Device Parammeter andern /sehen ( also Button schalten , oder sehen ob das Wake word erkannt wird ).
                                            @andrease112
                                            Ich kenne HA nicht.
                                            Du kannst die Datenpunkte in deiner Visualisierung dastellen.
                                            Du kannst den ESP einfach besuchen (IP-Adresse) oder über die ESPHome-Oberfläche auf Visit.
                                            Dann geht die Weboberfläche vom ESP auf, da sieht man auch das Log:
                                            1497
