    4. Test Adapter OpenLigaDB
    • OliverIO
      OliverIO @hsjan last edited by
      @hsjan ok
      Und jetzt bitte das Widget w02808 exportieren und hier reinstellen.
        hsjan @OliverIO last edited by
        @oliverio meinst du so?
        [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"264px","top":"344px"},"widgetSet":"openligadb"},{"tpl":"tplOLiDBGoalGetters","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","sort":"goal","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"goalgetters_oid":"openligadb.0.bl1.2024.goalgetters","maxcount":"18","showonlyhighlight":false,"highlight":"Thuram"},"style":{"left":"574px","top":"111px","z-index":"4","width":"248px","height":"440px","border-width":"2px","border-style":"solid","border-color":"#060505","border-radius":"10px"},"widgetSet":"openligadb"}]
        H OliverIO 2 Replies Last reply Reply Quote 0
          hsjan @hsjan last edited by
          @oliverio 2808 habe ich nicht gefunden
          • OliverIO
            @hsjan
            welche adapter version nutzt du? v1.8.0
            der export verweist auf eine alte widget definition von goalgetters, die heute schon lang nicht mehr im adapter enthalten ist.
            bitte aktualisiere auf v1.8.0
            und erstelle die widgets neu
            das widget Gameday ist gar nicht konfiguriert. da stehen gar keine datenpunkte drin.
            daher weiß das widget auch nicht was es anzeigen soll. muss mal das als fehler ausweisen.
              @oliverio ich habe die Version 1.8 im Einsatz.
              Ich werde die Version löschen und neu installieren.
              Wie kann ich die Widgets in der Vis aktualisieren?
              • OliverIO
                OliverIO @hsjan last edited by OliverIO
                @hsjan
                Neu installieren reicht eigentlich.
                Auf der browserkonsole sollte die Version ausgegeben werden.
                Ist die nicht 1.8, dann kannst du auf deiner betriebssystemkonsole mit
                iob upload all
                Nachhelfen.
                Dann am besten die Widgets entfernen und wieder hinzufügen. Wie gesagt, am Export habe ich gesehen das da was nicht so stimmt.
                • OliverIO
                  Neu Version
                  • ein workaround für einen kleinen glitch durch die Aktualisierung der table Komponente des admins
                    @oliverio Adapter neu installiert jetzt sind die widget in der VIS weg.
                    • OliverIO
                      @hsjan
                      Dann auf der Konsole
                      iobroker upload all
                        Sorry für die verspätete Rückmeldung.
                        Jetzt hat es geklappt.
                        Danke für die Hilfe
                        • OliverIO
                          @hsjan
                          Sehr gut
                          • OliverIO
                            OliverIO @OliverIO last edited by
                            Diese Version befindet sich auf dem Weg ins stable repository
                            @oliverio sagte in Test Adapter OpenLigaDB:
                            Neu Version 1.8.1
                              Daniel81 last edited by
                              anscheinend stehe ich gerade auf dem Schlauch. Könnte mir jemand kurz erklären, wie ich den Adapter zum Laufen bekomme?
                              Unter dem Punkt Objekte wird mir nichts angezeigt, und in den Protokollen erhalte ich eine Fehlermeldung, dass etwas mit der API nicht stimmt. In der Beschreibung habe ich zwar etwas über eine API gelesen, aber ich kann leider nicht finden, wo ich diese eingeben kann.
                              Ich hoffe, ihr könnt mir weiterhelfen. Vielen Dank im Voraus! Falls ich etwas übersehen habe, bitte ich um Entschuldigung.
                              • OliverIO
                                OliverIO @Daniel81 last edited by
                                @daniel81
                                Lese bitte nochmal die Dokumentation
                                Wo hast du das her das Fußball-Bundesliga und 2024/2025 eine gültige Bezeichnung ist?
                                • Meister Mopper
                                  Meister Mopper @OliverIO last edited by Meister Mopper
                                  @oliverio
                                  Aktuell können keine Daten vom Server geholt werden:
                                  openligadb.0	2025-02-17 13:31:28.901	error	Request Failed. Status Code: 500 api.openligadb.de/getgoalgetters/bl1/2024
                                  openligadb.0	2025-02-17 13:31:28.900	error	Request Failed. Status Code: 500 api.openligadb.de/getmatchdata/bl1/2024
                                  openligadb.0	2025-02-17 13:31:28.899	error	Request Failed. Status Code: 500 api.openligadb.de/getcurrentgroup/bl1
                                  openligadb.0	2025-02-17 13:31:28.898	error	Request Failed. Status Code: 500 api.openligadb.de/getbltable/bl1/2024
                                  Im Browser komme ich drauf. Kann das wer bestätigen?
                                  • OliverIO
                                    OliverIO @Meister Mopper last edited by
                                    @meister-mopper
                                    1430 war die letzte Fehlermeldung.
                                    Seither wieder gut.
                                      Daniel81 @OliverIO last edited by
                                      @oliverio Danke für den Hinweis. Wie gesagt, ich stand wirklich auf dem Schlauch – dabei war es so einfach... Nun läuft es. Vielen Dank fürs Drauf-Aufmerksam-Machen!
                                      • OliverIO
                                        @daniel81
                                        Alles gut
                                        • Meister Mopper
                                          😁 Ui, da hat sich jemand beim Datentypisieren offenbar vertan:
                                          • OliverIO
                                            OliverIO @Meister Mopper last edited by OliverIO
                                            @meister-mopper
                                            Probiere mal nochmal. Bei mir zeigt es ordentlich an.
                                            Evtl. Waren die gerade bei der Eingabe?
                                            adapter openligadb test
                                            56
                                            687
                                            122394
