    4. Wir Empfehlen: Node.js 20.x :-)
      Thomas Braun Most Active @LastActionHero last edited by
      @lastactionhero sagte in Wir Empfehlen: Node.js 20.x 🙂:
      Please stop them first and try again!
      iob stop
      iob fix
      iob start
      iob diag
        LastActionHero @Thomas Braun last edited by
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.8.12-1-pve
              Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         21:17:03 up 16 min,  2 users,  load average: 1.52, 0.86, 0.59
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2024-12-03 21:17:03 CET
                   Universal time: Tue 2024-12-03 20:17:03 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        ioadmin
        HOME=/home/ioadmin
        GROUPS=ioadmin adm sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.1G        1.3G        1.3G        0.0K        447M        1.8G
        Swap:           1.0G          0B        1.0G
        Total:          4.1G        1.3G        2.4G
        Active iob-Instances:   5
                 3072 M total memory
                 1294 M used memory
                 1274 M active memory
                  319 M inactive memory
                 1330 M free memory
                    0 M buffer memory
                  447 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        top - 21:17:04 up 16 min,  2 users,  load average: 1.52, 0.86, 0.59
        Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 75.0 us,  9.4 sy,  0.0 ni, 15.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3072.0 total,   1335.6 free,   1288.7 used,    447.7 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1783.1 avail Mem
        *** FAILED SERVICES ***
          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
        * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--102--disk--0 ext4      9.8G  5.9G  3.5G  64% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     772M     0  772M   0% /run/user/1001
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
        /var:
        896M    /var/
        518M    /var/cache
        513M    /var/cache/apt
        446M    /var/cache/apt/archives
        242M    /var/log
        Archived and active journals take up 240.0M in the file system.
        /opt/iobroker/backups:
        64M     /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        989M    /opt/iobroker/iobroker-data/
        808M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 77)
        Core adapters versions
        js-controller:  7.0.3
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
          system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hue"          : 3.13.1   , installed 3.13.1
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.3    , installed 7.0.3
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        Objects:        7327
        States:         5987
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org bullseye-security InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          119584219  1/init
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       119618342  2467/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       119618337  2467/iobroker.js-co
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       119619961  2798/io.mqtt.0
        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        119584462  107/systemd-resolve
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          119585851  292/master
        tcp        0      0 192.168.5.152:2010      0.0.0.0:*               LISTEN      1000       119619867  2753/io.hm-rpc.1
        tcp        0      0 192.168.5.152:2001      0.0.0.0:*               LISTEN      1000       119621983  2708/io.hm-rpc.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        119584468  107/systemd-resolve
        tcp6       0      0 :::22                   :::*                    LISTEN      0          119584381  1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          119584221  1/init
        tcp6       0      0 :::5355                 :::*                    LISTEN      104        119584465  107/systemd-resolve
        tcp6       0      0 :::33895                :::*                    LISTEN      1000       119623804  3100/io.yahka.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          119585852  292/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       119622413  2843/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       119618409  2485/io.admin.0
        tcp6       0      0 :::8091                 :::*                    LISTEN      1000       119622449  2858/io.lovelace.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       119622086  2768/io.sonos.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        119584467  107/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          119584220  1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       119623805  3100/io.yahka.0
        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        119584461  107/systemd-resolve
        udp6       0      0 :::111                  :::*                                0          119584222  1/init
        udp6       0      0 :::5355                 :::*                                104        119584464  107/systemd-resolve
        2024-12-03 21:16:54.868  - info: mqtt.0 (2798) Client [Zisterne_2_1B6875] publishOnSubscribe send all known states
        2024-12-03 21:16:54.871  - info: mqtt.0 (2798) Client [Zisterne_2_1B6875] publishOnSubscribe send all known states
        2024-12-03 21:16:55.717  - info: web.0 (2843) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.3
        2024-12-03 21:16:55.836  - info: web.0 (2843) socket.io server listening on port 8082
        2024-12-03 21:16:55.840  - info: web.0 (2843) http server listening on port 8082
        2024-12-03 21:16:58.174  - info: host.iobroker instance system.adapter.lovelace.0 in version "4.1.10" started with pid 2858
        2024-12-03 21:17:00.157  - info: lovelace.0 (2858) starting. Version 4.1.10 in /opt/iobroker/node_modules/iobroker.lovelace, node: v20.18.1, js-controller: 7.0.3
        2024-12-03 21:17:00.203  - info: lovelace.0 (2858) http server listening on port 8091
        2024-12-03 21:17:02.203  - info: host.iobroker instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 2873
        2024-12-03 21:17:03.637  - info: trashschedule.0 (2873) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v20.18.1, js-controller: 7.0.3
        2024-12-03 21:17:03.838  - info: trashschedule.0 (2873) [onReady] starting with source "ical" -> ical
        2024-12-03 21:17:03.845  - info: trashschedule.0 (2873) [ical] configured ical preview is 45 days (until 17.01.2025) - increase this value to find more events in the future
        2024-12-03 21:17:03.846  - info: trashschedule.0 (2873) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
        2024-12-03 21:17:07.700  - info: vis.0 (3071) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.3
        2024-12-03 21:17:08.325  - info: vis.0 (3071) Terminated (NO_ERROR): Without reason
        2024-12-03 21:17:08.882  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
        2024-12-03 21:17:10.144  - info: host.iobroker instance system.adapter.yahka.0 in version "1.0.3" started with pid 3100
        2024-12-03 21:17:12.024  - info: yahka.0 (3100) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v20.18.1, js-controller: 7.0.3
        2024-12-03 21:17:12.039  - info: yahka.0 (3100) adapter ready, checking config
        2024-12-03 21:17:12.048  - info: yahka.0 (3100) adding Weihnachtsbaum with UUID: 5e60d7d4-355c-4836-8517-c5a84ea95a56
        2024-12-03 21:17:12.053  - info: yahka.0 (3100) adding Garagentor with UUID: eb975574-a3b2-4c0a-9953-c3aa23b9d845
        2024-12-03 21:17:12.057  - info: yahka.0 (3100) publishing bridge ioBroker Bridge on 0.0.0.0 using avahi
        2024-12-03 21:17:14.220  - info: host.iobroker instance system.adapter.smartgarden.0 in version "2.0.1" started with pid 3144
        2024-12-03 21:17:15.960  - info: smartgarden.0 (3144) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v20.18.1, js-controller: 7.0.3
          Kannste direkt schon mal auf 12 (bookworm) bringen. Debian 11 ist EndOfLife und wird nicht mehr aktiv unterstützt.
          Stell das wie vom Fixer angeboten auf multi-user um.
          • Alexander Hauser
            Alexander Hauser @Feuersturm last edited by
            @feuersturm super dankeschön. hat ganz easy ohne Problem funktioniert.
              shellyrulestheworld @Alexander Hauser last edited by
              bei mir kommt leider ne Fehlermeldung: Screenshot 2025-02-01 081108.png
              Hat jemand eine Idee, wie ich auf nodejs 20 komme?
                Thomas Braun Most Active @shellyrulestheworld last edited by Thomas Braun
                @shellyrulestheworld sagte in Wir Empfehlen: Node.js 20.x 🙂:
                Text aus einem Terminal immer auch als Text in CodeTags eingebettet posten, nicht als Screenshot.
                  shellyrulestheworld @Thomas Braun last edited by
                  @thomas-braun OK, immerhin kein Handy Foto 😜
                  Nächstes Mal kommt wieder Code 😃
                    Dann kann ich ja beim nächsten Mal antworten.
                      @thomas-braun das Angebot nehme ich an. Irgendwie scheint es jetzt geklappt zu haben, oder?
                      ioBroker nodejs fixer 2024-10-10
                      You requested to install latest version from nodejs v20 tree.
                      Your current setup is:
                      /usr/bin/nodejs         v18.20.6
                      /usr/bin/node           v18.20.6
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      We found these nodejs versions available for installation:
                      nodejs:
                        Installed: 18.20.6-1nodesource1
                        Candidate: 18.20.6-1nodesource1
                        Version table:
                       *** 18.20.6-1nodesource1 100
                           18.19.0+dfsg-6~deb12u2 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                      Nothing to do - Your installation is using the correct paths.
                      You are running nodejs v18.20.6. Do you want to install latest version from nodejs v.20 tree?
                      Press <y> to continue or any other key to quit
                      Trying to fix your installation now. Please be patient.
                      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
                      Virtualization: lxc
                      Waiting for ioBroker to shut down - Give me a minute...
                      Removing dfsg-nodejs
                      *** These repos are active on your system:
                      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                      Reading package lists... Done
                      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                      Package: nodejs
                      Pin: origin deb.nodesource.com
                      Pin-Priority: 1001
                      *** These repos are active after the adjustments:
                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                      Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                      Get:6 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [10.4 kB]
                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                      Fetched 22.5 kB in 1s (18.6 kB/s)
                      Installing nodejs now!
                      (Reading database ... 43850 files and directories currently installed.)
                      Preparing to unpack .../nodejs_20.18.2-1nodesource1_amd64.deb ...
                      Detected old npm client, removing...
                      Unpacking nodejs (20.18.2-1nodesource1) over (18.20.6-1nodesource1) ...
                      Setting up nodejs (20.18.2-1nodesource1) ...
                      Processing triggers for man-db (2.11.2-2) ...
                      *** You need to manually restart your container/virtual machine now! ***
                      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                      peter@iobroker:~$
                        Vermutlich. Container neugestartet?
                        Dann nochmal
                        iob nodejs-update
                        Da sollte dann auch was passendes stehen.
                          @thomas-braun genau. Ich habe den Container neu gestartet. jetzt kommt folgdendes:
                          Recommended nodejs-version is: 20.18.2
                          Checking your installation now. Please be patient!
                          /usr/bin/nodejs         v20.18.2
                          /usr/bin/node           v20.18.2
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Installed: 20.18.2-1nodesource1
                            Candidate: 20.18.2-1nodesource1
                            Version table:
                           *** 20.18.2-1nodesource1 1001
                          Nothing to do - Your version is the recommended one.
                          ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
                          *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
                           *** DO NOT use 'nodejs-update' as part of a regular update process! ***
                          peter@iobroker:~$
                          Komischerweise steht im IOB folgendes:
                          CPU: 14,58 %
                          RAM: 28 %
                          Betriebszeit: 0h
                          Verfügbar: 7.0.6
                          Installiert: 7.0.6
                          Ereignisse: ⇥40 / ↦13
                          Plattform: linux
                          Betriebssystem: linux
                          Architektur: x64
                          CPUs: 4
                          Geschwindigkeit: 2799 MHz
                          Modell: Intel(R) Celeron(R) N5105 @ 2.00GHz
                          RAM: 8 GB
                          System-Betriebszeit: 00:00:48
                          Node.js: v18.20.6
                          time: 1738393951080
                          timeOffset: -60
                          NPM: 10.8.2
                          Adapter-Anzahl: 559
                          Datenträgergröße: 13.7 GB
                          Freier Festplattenspeicher: 5.3 GB
                          Aktive Instanzen: 7
                          Pfad: /opt/iobroker/
                          Betriebszeit: 00:00:43
                            Alles richtig. ioBroker-GUI neuladen.
                              @thomas-braun perfekt. Wie immer: herzlichen Dank für deinen Support 🙂
                                Maddin77 last edited by
                                Servus zusammen
                                hoffe ich darf hier bissi Fragen
                                ich bin ziemlich neu in der Welt
                                und IOB möchte gerne das ich Node update, allerdings habe ich ziemlich keine Ahnung davon
                                bei mir läuft IOB auf einem Synology NAS als Container
                                soll ich im NAS Terminal updaten oder im IOB
                                was wäre zu bevorzugen?
                                danke schon mal für eure hilfe
                                  Thomas Braun Most Active @Maddin77 last edited by
                                  @maddin77
                                  Von welcher Version auf welche neue Version?
                                    Maddin77 @Thomas Braun last edited by
                                    @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                    @maddin77
                                    im Terminal wird mir das angezeigt
                                    /opt/iobroker$ node -v
                                    v18.20.3
                                    /opt/iobroker$
                                    manche Adapter schreiben einfach >20
                                      @maddin77
                                      Dann roll einen aktuellen Container drüber.
                                        @maddin77
                                        ist das dann mit
                                        sudo apt-get install -y nodejs
                                          @maddin77
                                          Nein. Du nimmst das aktuelle Container-Image und tauschst die Umgebung für den ioBroker aus.
                                            o-Gott
                                            da bin ich aktuell etwas überfordert damit, sorry
                                            Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                                            237
                                            71432
