    4. Wir Empfehlen: Node.js 20.x :-)
      LastActionHero @Thomas Braun last edited by
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.8.12-1-pve
            Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       21:17:03 up 16 min,  2 users,  load average: 1.52, 0.86, 0.59
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2024-12-03 21:17:03 CET
                 Universal time: Tue 2024-12-03 20:17:03 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      ioadmin
      HOME=/home/ioadmin
      GROUPS=ioadmin adm sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            3.1G        1.3G        1.3G        0.0K        447M        1.8G
      Swap:           1.0G          0B        1.0G
      Total:          4.1G        1.3G        2.4G
      Active iob-Instances:   5
               3072 M total memory
               1294 M used memory
               1274 M active memory
                319 M inactive memory
               1330 M free memory
                  0 M buffer memory
                447 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      top - 21:17:04 up 16 min,  2 users,  load average: 1.52, 0.86, 0.59
      Tasks:  46 total,   1 running,  45 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 75.0 us,  9.4 sy,  0.0 ni, 15.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3072.0 total,   1335.6 free,   1288.7 used,    447.7 buff/cache
      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1783.1 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--102--disk--0 ext4      9.8G  5.9G  3.5G  64% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     772M     0  772M   0% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
      /var:
      896M    /var/
      518M    /var/cache
      513M    /var/cache/apt
      446M    /var/cache/apt/archives
      242M    /var/log
      Archived and active journals take up 240.0M in the file system.
      /opt/iobroker/backups:
      64M     /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      989M    /opt/iobroker/iobroker-data/
      808M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 http://security.debian.org bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 77)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
        system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.13.1   , installed 3.13.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects:        7327
      States:         5987
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org bullseye-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          119584219  1/init
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       119618342  2467/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       119618337  2467/iobroker.js-co
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       119619961  2798/io.mqtt.0
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        119584462  107/systemd-resolve
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          119585851  292/master
      tcp        0      0 192.168.5.152:2010      0.0.0.0:*               LISTEN      1000       119619867  2753/io.hm-rpc.1
      tcp        0      0 192.168.5.152:2001      0.0.0.0:*               LISTEN      1000       119621983  2708/io.hm-rpc.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        119584468  107/systemd-resolve
      tcp6       0      0 :::22                   :::*                    LISTEN      0          119584381  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          119584221  1/init
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        119584465  107/systemd-resolve
      tcp6       0      0 :::33895                :::*                    LISTEN      1000       119623804  3100/io.yahka.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          119585852  292/master
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       119622413  2843/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       119618409  2485/io.admin.0
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       119622449  2858/io.lovelace.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       119622086  2768/io.sonos.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        119584467  107/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          119584220  1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       119623805  3100/io.yahka.0
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        119584461  107/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          119584222  1/init
      udp6       0      0 :::5355                 :::*                                104        119584464  107/systemd-resolve
      2024-12-03 21:16:54.868  - info: mqtt.0 (2798) Client [Zisterne_2_1B6875] publishOnSubscribe send all known states
      2024-12-03 21:16:54.871  - info: mqtt.0 (2798) Client [Zisterne_2_1B6875] publishOnSubscribe send all known states
      2024-12-03 21:16:55.717  - info: web.0 (2843) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.1, js-controller: 7.0.3
      2024-12-03 21:16:55.836  - info: web.0 (2843) socket.io server listening on port 8082
      2024-12-03 21:16:55.840  - info: web.0 (2843) http server listening on port 8082
      2024-12-03 21:16:58.174  - info: host.iobroker instance system.adapter.lovelace.0 in version "4.1.10" started with pid 2858
      2024-12-03 21:17:00.157  - info: lovelace.0 (2858) starting. Version 4.1.10 in /opt/iobroker/node_modules/iobroker.lovelace, node: v20.18.1, js-controller: 7.0.3
      2024-12-03 21:17:00.203  - info: lovelace.0 (2858) http server listening on port 8091
      2024-12-03 21:17:02.203  - info: host.iobroker instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 2873
      2024-12-03 21:17:03.637  - info: trashschedule.0 (2873) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v20.18.1, js-controller: 7.0.3
      2024-12-03 21:17:03.838  - info: trashschedule.0 (2873) [onReady] starting with source "ical" -> ical
      2024-12-03 21:17:03.845  - info: trashschedule.0 (2873) [ical] configured ical preview is 45 days (until 17.01.2025) - increase this value to find more events in the future
      2024-12-03 21:17:03.846  - info: trashschedule.0 (2873) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
      2024-12-03 21:17:07.700  - info: vis.0 (3071) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.3
      2024-12-03 21:17:08.325  - info: vis.0 (3071) Terminated (NO_ERROR): Without reason
      2024-12-03 21:17:08.882  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
      2024-12-03 21:17:10.144  - info: host.iobroker instance system.adapter.yahka.0 in version "1.0.3" started with pid 3100
      2024-12-03 21:17:12.024  - info: yahka.0 (3100) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v20.18.1, js-controller: 7.0.3
      2024-12-03 21:17:12.039  - info: yahka.0 (3100) adapter ready, checking config
      2024-12-03 21:17:12.048  - info: yahka.0 (3100) adding Weihnachtsbaum with UUID: 5e60d7d4-355c-4836-8517-c5a84ea95a56
      2024-12-03 21:17:12.053  - info: yahka.0 (3100) adding Garagentor with UUID: eb975574-a3b2-4c0a-9953-c3aa23b9d845
      2024-12-03 21:17:12.057  - info: yahka.0 (3100) publishing bridge ioBroker Bridge on 0.0.0.0 using avahi
      2024-12-03 21:17:14.220  - info: host.iobroker instance system.adapter.smartgarden.0 in version "2.0.1" started with pid 3144
      2024-12-03 21:17:15.960  - info: smartgarden.0 (3144) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v20.18.1, js-controller: 7.0.3
        Thomas Braun Most Active @LastActionHero last edited by
        @lastactionhero sagte in Wir Empfehlen: Node.js 20.x 🙂:
        Kannste direkt schon mal auf 12 (bookworm) bringen. Debian 11 ist EndOfLife und wird nicht mehr aktiv unterstützt.
        Stell das wie vom Fixer angeboten auf multi-user um.
        • Alexander Hauser
          Alexander Hauser @Feuersturm last edited by
          @feuersturm super dankeschön. hat ganz easy ohne Problem funktioniert.
            shellyrulestheworld @Alexander Hauser last edited by
            bei mir kommt leider ne Fehlermeldung: Screenshot 2025-02-01 081108.png
            Hat jemand eine Idee, wie ich auf nodejs 20 komme?
              Thomas Braun Most Active @shellyrulestheworld last edited by Thomas Braun
              @shellyrulestheworld sagte in Wir Empfehlen: Node.js 20.x 🙂:
              Text aus einem Terminal immer auch als Text in CodeTags eingebettet posten, nicht als Screenshot.
                shellyrulestheworld @Thomas Braun last edited by
                @thomas-braun OK, immerhin kein Handy Foto 😜
                Nächstes Mal kommt wieder Code 😃
                  Dann kann ich ja beim nächsten Mal antworten.
                    @thomas-braun das Angebot nehme ich an. Irgendwie scheint es jetzt geklappt zu haben, oder?
                    ioBroker nodejs fixer 2024-10-10
                    You requested to install latest version from nodejs v20 tree.
                    Your current setup is:
                    /usr/bin/nodejs         v18.20.6
                    /usr/bin/node           v18.20.6
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    We found these nodejs versions available for installation:
                    nodejs:
                      Installed: 18.20.6-1nodesource1
                      Candidate: 18.20.6-1nodesource1
                      Version table:
                     *** 18.20.6-1nodesource1 100
                         18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                    Nothing to do - Your installation is using the correct paths.
                    You are running nodejs v18.20.6. Do you want to install latest version from nodejs v.20 tree?
                    Press <y> to continue or any other key to quit
                    Trying to fix your installation now. Please be patient.
                    rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
                    Virtualization: lxc
                    Waiting for ioBroker to shut down - Give me a minute...
                    Removing dfsg-nodejs
                    *** These repos are active on your system:
                    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                    Reading package lists... Done
                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                    Package: nodejs
                    Pin: origin deb.nodesource.com
                    Pin-Priority: 1001
                    *** These repos are active after the adjustments:
                    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                    Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                    Get:6 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [10.4 kB]
                    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                    Fetched 22.5 kB in 1s (18.6 kB/s)
                    Installing nodejs now!
                    (Reading database ... 43850 files and directories currently installed.)
                    Preparing to unpack .../nodejs_20.18.2-1nodesource1_amd64.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (20.18.2-1nodesource1) over (18.20.6-1nodesource1) ...
                    Setting up nodejs (20.18.2-1nodesource1) ...
                    Processing triggers for man-db (2.11.2-2) ...
                    *** You need to manually restart your container/virtual machine now! ***
                    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                    peter@iobroker:~$
                      Vermutlich. Container neugestartet?
                      Dann nochmal
                      iob nodejs-update
                      Da sollte dann auch was passendes stehen.
                        @thomas-braun genau. Ich habe den Container neu gestartet. jetzt kommt folgdendes:
                        Recommended nodejs-version is: 20.18.2
                        Checking your installation now. Please be patient!
                        /usr/bin/nodejs         v20.18.2
                        /usr/bin/node           v20.18.2
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Installed: 20.18.2-1nodesource1
                          Candidate: 20.18.2-1nodesource1
                          Version table:
                         *** 20.18.2-1nodesource1 1001
                        Nothing to do - Your version is the recommended one.
                        ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
                        *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
                         *** DO NOT use 'nodejs-update' as part of a regular update process! ***
                        peter@iobroker:~$
                        Komischerweise steht im IOB folgendes:
                        CPU: 14,58 %
                        RAM: 28 %
                        Betriebszeit: 0h
                        Verfügbar: 7.0.6
                        Installiert: 7.0.6
                        Ereignisse: ⇥40 / ↦13
                        Plattform: linux
                        Betriebssystem: linux
                        Architektur: x64
                        CPUs: 4
                        Geschwindigkeit: 2799 MHz
                        Modell: Intel(R) Celeron(R) N5105 @ 2.00GHz
                        RAM: 8 GB
                        System-Betriebszeit: 00:00:48
                        Node.js: v18.20.6
                        time: 1738393951080
                        timeOffset: -60
                        NPM: 10.8.2
                        Adapter-Anzahl: 559
                        Datenträgergröße: 13.7 GB
                        Freier Festplattenspeicher: 5.3 GB
                        Aktive Instanzen: 7
                        Pfad: /opt/iobroker/
                        Betriebszeit: 00:00:43
                          Alles richtig. ioBroker-GUI neuladen.
                            @thomas-braun perfekt. Wie immer: herzlichen Dank für deinen Support 🙂
                              Maddin77 last edited by
                              Servus zusammen
                              hoffe ich darf hier bissi Fragen
                              ich bin ziemlich neu in der Welt
                              und IOB möchte gerne das ich Node update, allerdings habe ich ziemlich keine Ahnung davon
                              bei mir läuft IOB auf einem Synology NAS als Container
                              soll ich im NAS Terminal updaten oder im IOB
                              was wäre zu bevorzugen?
                              danke schon mal für eure hilfe
                                Thomas Braun Most Active @Maddin77 last edited by
                                @maddin77
                                Von welcher Version auf welche neue Version?
                                  Maddin77 @Thomas Braun last edited by
                                  @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                  @maddin77
                                  im Terminal wird mir das angezeigt
                                  /opt/iobroker$ node -v
                                  v18.20.3
                                  /opt/iobroker$
                                  manche Adapter schreiben einfach >20
                                    @maddin77
                                    Dann roll einen aktuellen Container drüber.
                                      @maddin77
                                      ist das dann mit
                                      sudo apt-get install -y nodejs
                                        @maddin77
                                        Nein. Du nimmst das aktuelle Container-Image und tauschst die Umgebung für den ioBroker aus.
                                          o-Gott
                                          da bin ich aktuell etwas überfordert damit, sorry
                                          Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                                            @maddin77
                                            Gibt Anleitungen dazu.
                                            Du musst deine Kiste ja verwalten und pflegen können.
                                            237
                                            44102
