    4. über Port 8081 und 8082 kann ich ioBroker nicht aufrufen
      Thorsten4-71 @Thomas Braun last edited by
      Your system is booting into 'graphical.target', which means that a user interfac e or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      877 iobroker.js-con
      1360 io.history.0
      1673 io.javascript.0
      2073 io.telegram.0
      2088 io.ping.0
      2124 io.shelly.0
      2147 io.deyeidc.0
      2164 io.mqtt.0
      2183 io.chromecast.0
      2203 io.echarts.0
      2222 io.cloud.0
      2244 io.hm-rpc.0
      2262 io.hm-rega.0
      2277 io.hm-rpc.2
      2313 io.rpi2.0
      2334 io.accuweather.
      2335 io.tr-064.0
      2341 io.tankerkoenig
      2352 io.fritzbox.0
      2353 io.broadlink2.0
      2392 io.discovery.0
      2489 io.fritzdect.0
      2506 io.web.0
      2526 io.iqontrol.0
      2543 io.vis-2.0
      2561 io.growatt.0
      2578 io.vis-inventwo
      2593 io.openligadb.0
      2608 io.yahoo-stock-
      2623 io.parser.0
      Please stop them first and try again!
        curl https://raw.githubusercontent.com/Grothesk242/io Broker/refs/reads/Paspgian/diag.sh > iob_diag.sh
        % Total % Received % Xferd Average Speed Time Time Time Current
        Dload Upload Total Spent Left Speed
        100 14 100 14 0 0 48 0 --:--:-- --:--:-- --:--:-- 48
        xx@raspberrypi:~ $ chmod 744 iob_diag.sh
        xx@raspberrypi:~ $ ./iob:diag.sh
        -bash: ./iob:diag.sh: Datei oder Verzeichnis nicht gefunden
        mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @Thorsten4-71 last edited by
          @thorsten4-71
          Keinen Doppelpunkt beim Aufruf sondern auch dort _
          ./iob:diag.sh
            Thomas Braun Most Active @Thorsten4-71 last edited by
            @thorsten4-71
            Du musst es auch schon so eingeben oder kopieren wie es angegeben ist.
            Und bitte CodeTags verwenden.
              Thorsten4-71 @mcm1957 last edited by
              @mcm1957
              ./iob_diag.sh: Zeile 1: 404:: Kommando nicht gefunden.
                @thorsten4-71
                Lade es nochmal...
                  meinst Du diesen Befehl? ./iob_diag.sh
                  kommt die gleiche Fehlermeldung
                  Thomas Braun T 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Thorsten4-71 last edited by Thomas Braun
                    @thorsten4-71
                    Nein, ich meine EXAKT diese drei Zeilen:
                    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
                    ./iob_diag.sh
                    Vorher vielleicht
                    rm iob_diag.sh
                      Thorsten4-71 @Thorsten4-71 last edited by
                      @thorsten4-71
                      Es gibt eine Befehlszeile, die anzeigt welche Adapter/Port aktiviert oder deaktiviert ist. Kann mir jemand sagen, wie der heißt? Ich habe erst seit Oktober eine Raspberry. Sorry
                        @thomas-braun Habe jetzt diese Meldung erhalten:
                        *** ioBroker Diagnosis ***
                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                        https://forum.iobroker.net
                        Just copy and paste the Summary Page, including the ``` characters at start and end.
                        It helps us to help you!
                        • Some output is masked. For full results please use 'iob diag --unmask' *
                        Press any key to continue
                          @thorsten4-71 sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
                          Jo.
                          sollte doch klar sein...
                            @thomas-braun Das ist mir schon klar aber dann habe ich keine weiter Meldung mehr erhalten. steht bei xx@raspberrypi:~ $
                              Zeigen...
                              Genaue und vollständige Kopie von dem was da in deinem Terminal steht.
                              In CodeTags.
                                xx@raspberrypi:~ $
                                mehr steht da leider nicht, was vorher alles war, ist weg.
                                  @thorsten4-71
                                  Und dein user heißt 'xx'? Du sollst das VOLLSTÄNDIG und UNVERÄNDERT und UNGEKÜRZT kopieren.
                                  Und IN CODETAGS setzen.
                                    @thomas-braun Sorry
                                    shthorsten@raspberrypi:~ $
                                      @thorsten4-71
                                      Keine CodeTags...
                                        @thomas-braun Mehr steht da nicht, habe alles kopiert. Was ist Code Tag. Sorry, ich habe keine große Erfahrung mit Raspberry
                                        Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                                          @thorsten4-71
                                          Hat auch mit dem Raspberry nix zu tun.
                                          https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                          • Asgothian
                                            Asgothian Developer @Thorsten4-71 last edited by Asgothian
                                            Das ist fast ausgeschlossen. Diese Meldung steht mitten im output des diag Skriptes. Bitte poste doch einmal den gesamten Text der Konsole, wenn die 'summary' angezeigt wird.. Bitte ache auch darauf das du die Aufforderung press any key to continue ausführst, bis du zur 'summary' kommst.
                                            Am ende sollte das in etwa so aussehen:
                                            			v.2024-10-19
                                             Static hostname: stormbroker
                                                   Icon name: computer
                                                      Kernel: Linux 6.6.51+rpt-rpi-2712
                                                Architecture: arm64
                                            Installation: 		native
                                            Kernel: 		aarch64
                                            Userland: 		64 bit
                                            Timezone: 		Europe/Berlin (CET, +0100)
                                            User-ID: 		1000
                                            Display-Server: 	false
                                            Boot Target: 		multi-user.target
                                            Pending OS-Updates: 	10
                                            Pending iob updates: 	0
                                            Nodejs-Installation:
                                            /usr/bin/nodejs 	v20.18.2
                                            /usr/bin/node 		v20.18.2
                                            /usr/bin/npm 		10.8.2
                                            /usr/bin/npx 		10.8.2
                                            /usr/bin/corepack 	0.29.4
                                            Recommended versions are nodejs  and npm
                                            nodeJS installation is correct
                                            MEMORY:
                                            Mem:            8.4G        2.6G        3.1G        5.5M        2.8G        5.8G
                                            Swap:           536M          0B        536M
                                            Total:          9.0G        2.6G        3.7G
                                            Active iob-Instances: 	13
                                            Upgrade policy: none
                                            ioBroker Core: 		js-controller 		7.0.6
                                            			admin 			7.4.17
                                            ioBroker Status: 	iobroker is running on this host.
                                            At least one iobroker host is running.
                                            Objects type: redis
                                            States  type: redis
                                            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                                              system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8080, bind: 0.0.0.0, run as: admin
                                            Objects: 		3927
                                            States: 		3142
                                            Size of iob-Database:
                                            5.0M	/opt/iobroker/iobroker-data/objects.jsonl
                                            204K	/opt/iobroker/iobroker-data/states.jsonl
                                            Operating System is the current Debian stable version codenamed 'bookworm'!
                                            2261
