    4. source does not exist for "read" function
      Homoran Global Moderator Administrators @paul53 last edited by Homoran
      @paul53 sagte in source does not exist for "read" function:
      nicht (mehr) gibt.
      das hatte ich etwas differenzierter interpretiert, da die Meldung noch mit 'for read' weiterging.
      Dachte daher dass der read=false sei, was er nicht ist.
      Möglich aber, dass es nur um den in der Lesekonvertierung angegebenen DP geht
        Leider nix. Mein Log wird immer noch geflutet:
        2025-02-01 15:44:53.948  - warn: javascript.0 (888) You are assigning a string to the state "0_userdata.0.solix.solarbank_info.total_battery_power" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
        2025-02-01 15:44:53.949  - warn: javascript.0 (888)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at createObjectsRecursively (script.js.solix2mqtt:74:11)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at createObjectsRecursively (script.js.solix2mqtt:38:9)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at Object.<anonymous> (script.js.solix2mqtt:84:4)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-02-01 15:44:53.950  - warn: javascript.0 (888)     at processImmediate (node:internal/timers:483:21)
        2025-02-01 15:44:54.003  - info: javascript.0 (888) State value to set for "0_userdata.0.solix.solarbank_info.total_battery_power" has to be type "number" but received type "string"
        2025-02-01 15:44:54.066  - error: history.0 (857) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "val*100"
        2025-02-01 15:44:54.066  - error: javascript.0 (888) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "val*100"
        2025-02-01 15:45:53.952  - warn: javascript.0 (888) You are assigning a string to the state "0_userdata.0.solix.solarbank_info.total_battery_power" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
        2025-02-01 15:45:53.954  - warn: javascript.0 (888)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
        2025-02-01 15:45:53.954  - warn: javascript.0 (888)     at createObjectsRecursively (script.js.solix2mqtt:74:11)
        2025-02-01 15:45:53.954  - warn: javascript.0 (888)     at createObjectsRecursively (script.js.solix2mqtt:38:9)
        2025-02-01 15:45:53.954  - warn: javascript.0 (888)     at Object.<anonymous> (script.js.solix2mqtt:84:4)
        2025-02-01 15:45:53.955  - warn: javascript.0 (888)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-02-01 15:45:53.955  - warn: javascript.0 (888)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-02-01 15:45:53.955  - warn: javascript.0 (888)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-02-01 15:45:53.955  - warn: javascript.0 (888)     at processImmediate (node:internal/timers:483:21)
        2025-02-01 15:45:54.007  - info: javascript.0 (888) State value to set for "0_userdata.0.solix.solarbank_info.total_battery_power" has to be type "number" but received type "string"
        2025-02-01 15:45:54.074  - error: history.0 (857) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "val*100"
        2025-02-01 15:45:54.074  - error: javascript.0 (888) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "val*100"
        mickym Homoran 2 Replies Last reply Reply Quote 0
        • mickym
          mickym Most Active @Thomas Braun last edited by
          @thomas-braun na wenn du aber auf mixed umstellst, dann sollte der Fehler nicht mehr kommen
            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
            @thomas-braun sagte in source does not exist for "read" function:
            woher bekommt der DP seinen Wert
            wie sehen denn die beiden angemeckerten alias-Konfigurationen aus?
              @homoran sagte in source does not exist for "read" function:
              Aus einem JSON, das zuvor aber noch über ein enstprechendes Skript läuft und dann dort in Einzelwerte zerlegt wird.
              Homoran mickym 2 Replies Last reply Reply Quote 0
                zei gen!
                • mickym
                  mickym Most Active @Thomas Braun last edited by mickym
                  Na dann ist es doch das Skript - und wenn Du schon mit Alias arbeitest, dann würde ich es auch nicht über Einzelwerte vorher zerlegen, sondern direkt im Alias auseinandernehmen.
                  Von einem Skript hast Du vorher ja gar nichts gesagt.
                  Ausser Du nimmst meinen NodeRed Flow - der zerlegt auch in die richtigen Datentypen. 😉
                  Aber Spaß beiseite - ich würde nichts auseinander nehmen sondern das Objekt speichern und im Alias auseinandernehmen.
                    Das 'Konvertier'-Skript:
                    // where the mqtt messages arrive
                    const mqttDatenpunktObjectId = 'mqtt.0.solix.site.Stromstausee.scenInfo';
                    // where the states should appear
                    const userDataFolder = '0_userdata.0.solix';
                    // ############## end user config
                    // receive
                    on(mqttDatenpunktObjectId, (obj) => {
                      // log(JSON.stringify(obj.state.val))
                      const jsonString = obj.state.val;
                      const jsonData = JSON.parse(jsonString);
                      function createObjectsRecursively(parent, data) {
                        for (const key in data) {
                          const obj = data[key];
                          const stateName = `${parent}.${key}`;
                          if (typeof obj === 'object') {
                            createObjectsRecursively(stateName, obj);
                          } else {
                           let value = obj;
                            // Check if the state already exists. If it does, just update the value.
                            // If it does not exist create the states.
                            if (!existsState(stateName)) {
                              // If the state does not exist, create it and set the value
                              createState(stateName, value, {
                                type: typeof value,
                                role: "value",
                                read: true,
                                write: true
                              log(`Created state ${stateName}`);
                            } else {
                              // log(stateName + ': ' + value)
                              setState(stateName, value, true);
                       createObjectsRecursively(userDataFolder, jsonData);
                    • mickym
                              type: typeof value,
                      das stellt das immer wieder zurück. Es kann ja sein, dass im Objekt ein Komma anstelle eines Dezimalpunktes steht und schon kann dieses Skript nicht funktionieren.
                      Wie gesagt ich würde als schnelle Massnahme - ohne hier lange im Script rumzusuchen oder warum das Skript immer wieder umstellt, im Alias direkt das Objekt aus
                      auslesen. Das sind ja alles Infos, die vorher nicht da waren und ich bin davon ausgegangen, dass das so direkt aus mosquitto kommt, was es aber nicht tut.
                      Also poste lieber mal das Objekt und dann extrahieren wir das im Alias.
                        Thomas Braun Most Active @mickym last edited by
                        @mickym
                        Danke, hab da keinen Bock mehr drauf dran herumzufrickeln.
                        Das bleibt jetzt so. Steht halt im echart statt xy% 0,xy%
                        • mickym
                          @thomas-braun Was ist den schlimm dieses Objekt zu posten, also den Wert von
                          Aber wenn Du keine Lust hast, dann halt nicht.
                            @mickym sagte in source does not exist for "read" function:
                            Das könnte sogar sein. Im rohen JSON steht der Wert mit Dezimalpunkt drin, nicht mit Komma.
                            Möglich, das es von Anker bei einem Update geändert wurde. Bis vor ein paar Tagen hat das nämlich so funktioniert und ich habe da selber nix verändert.
                            • mickym
                              Na also war doch meine Vermutung richtig. Also musst du das Komma durch einen Punkt ersetzen und dann kann man es im Alias richtig verwenden. Deswegen poste halt das Objekt - das Skript wird Dir das niemals lösen, da eine Zahl mit einem Dezimalkomma immer als String erkannt wird.
                                Thomas Braun Most Active @mickym last edited by Thomas Braun
                                Nix.
                                {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"289.00","unit":"kwh"},{"type":"2","total":"288.13","unit":"kg"},{"type":"3","total":"115.60","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZB6Y60D40400300","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"71","bind_site_status":"","charging_power":"61","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"61","output_power":"61","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"0.71","updated_time":"2025-02-01 16:17:55","total_photovoltaic_power":"61","total_output_power":"61.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"61","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"a26d801a-afc6-45c0-bb93-ab80ab3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1}
                                "total_battery_power":"0.71" dürfte die Ursache sein.
                                mickym paul53 2 Replies Last reply Reply Quote 0
                                • mickym
                                  Um welchen Wert handelt es sich - ich hab das mal schön formatiert:
                                    "home_info": {
                                      "home_name": "Home",
                                      "home_img": "",
                                      "charging_power": "0.00",
                                      "power_unit": "W"
                                    "solar_list": [],
                                    "pps_info": {
                                      "pps_list": [],
                                      "total_charging_power": "0.00",
                                      "power_unit": "W",
                                      "total_battery_power": "0.00",
                                      "updated_time": "",
                                      "pps_status": 0
                                    "statistics": [
                                        "type": "1",
                                        "total": "289.00",
                                        "unit": "kwh"
                                        "type": "2",
                                        "total": "288.13",
                                        "unit": "kg"
                                        "type": "3",
                                        "total": "115.60",
                                        "unit": "€"
                                    "topology_type": "1",
                                    "solarbank_info": {
                                      "solarbank_list": [
                                          "device_pn": "A17C0",
                                          "device_sn": "AZV6Y60D30400300",
                                          "device_name": "Solarbank E1600",
                                          "device_img": "https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png",
                                          "battery_power": "71",
                                          "bind_site_status": "",
                                          "charging_power": "61",
                                          "power_unit": "W",
                                          "charging_status": "1",
                                          "status": "1",
                                          "wireless_type": "1",
                                          "main_version": "",
                                          "photovoltaic_power": "61",
                                          "output_power": "61",
                                          "create_time": 1721841629,
                                          "set_load_power": "",
                                          "sub_package_num": 0,
                                          "output_cutoff_data": 10,
                                          "is_display": true,
                                          "bat_charge_power": "0"
                                      "total_charging_power": "0",
                                      "power_unit": "W",
                                      "charging_status": "0",
                                      "total_battery_power": "0.71",
                                      "updated_time": "2025-02-01 16:17:55",
                                      "total_photovoltaic_power": "61",
                                      "total_output_power": "61.00",
                                      "display_set_power": false,
                                      "battery_discharge_power": "0",
                                      "ac_power": "0",
                                      "to_home_load": "0",
                                      "is_display_data": true,
                                      "solar_power_1": "0",
                                      "solar_power_2": "0",
                                      "solar_power_3": "0",
                                      "solar_power_4": "0",
                                      "other_input_power": "0",
                                      "micro_inverter_power": "61",
                                      "micro_inverter_power_limit": "0",
                                      "micro_inverter_low_power_limit": "0",
                                      "grid_to_battery_power": "0",
                                      "pei_heating_power": "0",
                                      "backup_info": {
                                        "start_time": 0,
                                        "end_time": 0,
                                        "full_time": 0
                                    "retain_load": "150W",
                                    "scene_mode": 0,
                                    "home_load_power": "0",
                                    "updated_time": "01-01-0001 00:00:00",
                                    "power_site_type": 2,
                                    "site_id": "a26d801a-afc6-45c0-bb93-cb80eb3bcc29",
                                    "powerpanel_list": [],
                                    "grid_info": null,
                                    "is_downgrade": false,
                                    "error_code": 0,
                                    "smart_plug_info": null,
                                    "feature_switch": null,
                                    "other_loads_power": "0",
                                    "priority_discharge_switch": 0,
                                    "display_priority_discharge_tips": 0,
                                    "priority_discharge_upgrade_devices": "",
                                    "style_id": 0,
                                    "is_show_priority_discharge": 1
                                  Es scheint mir das zu sein - und da sind alle Werte Strings
                                  einen Augenblick bitte.
                                  • mickym
                                    mickym Most Active last edited by mickym
                                    So dann probiere mal in der Konvertierungsfunktion für den Alias folgendes:
                                    Number(JSON.parse(val).solarbank_info.total_battery_power) *100
                                      paul53 @Thomas Braun last edited by
                                      @thomas-braun sagte: "total_battery_power":"0.71" dürfte die Ursache sein.
                                      Das ist nicht die Ursache, denn es findet bei Multiplikation eine implizite Wandlung statt:
                                      • mickym
                                        mickym Most Active @paul53 last edited by
                                        Das mag zwar richtig sein, aber der Typ wird ja über das Skript festgelegt - zumindest ist es die Ursache, dass immer wieder auf String umgeschaltet wird und das erzeugt ja die Fehlermeldung. Die Konvertierung spielt dabei ja noch keine Rolle.
                                          Das wird eher mehr als weniger...
                                          2025-02-01 16:36:56.126  - error: history.0 (857) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
                                          2025-02-01 16:36:56.129  - error: javascript.0 (888) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
                                          2025-02-01 16:36:56.126  - error: admin.0 (846) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
                                          2025-02-01 16:36:56.128  - error: awtrix-light.0 (1329) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
                                          • mickym
                                            @thomas-braun so mit der internen Konvertierung klappt es
                                            JSON.parse(val).solarbank_info.total_battery_power *100
                                            gibt das in die Lesefunktion des Alias ein
                                            Ich hab Dein ganzes Objekt in einen Datenpunkt geschrieben und dann im Alias extrahiert:
                                            2651
