    4. Installieren zigbee 2mqtt [mit workaround vorläufig gelöst]
    • mickym
      mickym Most Active last edited by mickym
      @geschild sagte in Installieren zigbee 2mqtt:
      Starting Zigbee2MQTT without watchdog.
      [2025-02-01 03:05:59] info: z2m: Logging to console, file (filename: log.log)
      [2025-02-01 03:05:59] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #060ae99)
      [2025-02-01 03:05:59] info: z2m: Starting zigbee-herdsman (3.2.1)
      [2025-02-01 03:05:59] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","pnpId":"usb-Texas_Instruments_CC2538_USB_CDC-if00","vendorId":"0451","productId":"16c8"} => zstack: path=/dev/ttyACM0, score=4
      [2025-02-01 03:05:59] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyACM0","baudRate":115200,"rtscts":false,"autoOpen":false}
      [2025-02-01 03:05:59] info: zh:zstack:znp: Serialport opened
      [2025-02-01 03:05:59] info: z2m: zigbee-herdsman started (resumed)
      [2025-02-01 03:05:59] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":2,"majorrel":2,"minorrel":7,"product":2,"revision":20200211,"transportrev":2},"type":"zStack30x"}'
      [2025-02-01 03:05:59] info: z2m: Currently 0 devices are joined.
      [2025-02-01 03:05:59] info: z2m: Connecting to MQTT server at mqtt://localhost:1885
      [2025-02-01 03:05:59] error: z2m: MQTT failed to connect, exiting... (connect ECONNREFUSED ::1:1885)
      [2025-02-01 03:05:59] info: z2m: Stopping zigbee-herdsman...
      [2025-02-01 03:06:00] info: zh:controller: Wrote coordinator backup to '/opt/zigbee2mqtt/data/coordinator_backup.json'
      [2025-02-01 03:06:00] info: zh:zstack:znp: closing
      [2025-02-01 03:06:00] info: zh:zstack:znp: Port closed
      [2025-02-01 03:06:00] info: z2m: Stopped zigbee-herdsman
       ELIFECYCLE  Command failed with exit code 1.
      Also im Moment sind
      1. Keine Geräte mit dem Koordinator verbunden - sprich Du wirst die später anlernen müssen - aber egal
      2. Der Fehler warum Dein Service nicht startet ist, dass die Verbindung zu deinem mqtt Broker nicht klappt. Also überprüfe das als erstes.
      Wenn Du in der configuration.yaml unter data im /opt/zigbee2mqtt Verzeichnis frontend auf true stellst.
      frontend:
        enabled: true
      stellst, dann kannst Du über die GUI arbeiten, dass ist erst mal viel einfacher und dann brauchst erst mal keine Adapter bis das zigbee gescheit läuft. Allerdings läuft auch die GUI erst, wenn der Service läuft - also die mqtt Verbindung muss funktionieren.
      Als erstmal Verbindung mit dem mqtt Broker herstellen. Was für einen Broker nutzt Du usw.
        crunchip Forum Testing Most Active @geschild last edited by crunchip
        Warum antwortest du
        der war gut
        ansonsten, gibt es auch noch den offiziellen Thread dazu
        • 1Topf
          1Topf @geschild last edited by
          In der Configuratio.yaml steht:
          mqtt:
          base_topic: zigbee2mqtt
          server: mqtt://localhost:1885
          Steht das exakt so da drin? Woher soll die yaml denn wissen, was dein localhost ist? Da sollte schon die IP-Adresse stehen.
          geschild 1 Reply Last reply Reply Quote 0
            https://github.com/Koenkk/zigbee2mqtt/discussions/24198
            @mickym sagte in Installieren zigbee 2mqtt:
            • mickym
              mickym Most Active @crunchip last edited by
              @crunchip Ja auch wenn der Adapter einen Mqtt Simuliert braucht muss man dann halt die IP Adresse des iobrokers und des Adapters angeben, der den Broker bereitstellt. Fakt ist, dass das anscheinend nicht funktioniert.
                crunchip Forum Testing Most Active @mickym last edited by
                richtig und das ganze funktioniert auch nur mit einer korrekt befüllten yaml
                • geschild
                  geschild @1Topf last edited by Homoran
                  @1topf @Mickym @crunchip
                  Der Hinweis von 1topf zu einer wesentliche Verbesserung geführt.
                  Der zigbee2mqtt-Adapter ging auf Grün. Aaaaaaber nach 3 Minuten (siehe 18:59.17) war die Freude dahin.
                  Um den Post übersichtlich zu halten habe ich .txt Dateien eingefügt.
                  Nachdem ich localhost in die IP geändert habe ich über putty: "/opt/zigbee2mqtt $ sudo pnpm start" eingegeben. Ausgabe des Pi:
                  echoPi.txt
                  Ich verwende fogenden mqtt-Broker:
                  kein Passwort /kein username.
                  Hier noch mal die .yaml wie sie jetzt aussieht, die Originalversion mit Kommentaren etc. wird beim Start wohl modifiziert. Entstanden ist aus der configuration.example.yaml. Lediglich den mqtt: Bereich angepasst.
                  configuration.yaml
                  Die Konfiguration meines zigbee2mqtt-Adapters. Soweit ich ihn bearbeitet habe.
                  Ich muss zugeben, dass ich die Installation zur Zeit ausführe ohne Hintergründe/Zusammenhänge zu verstehen. Vielleicht erbarmt sich jemand, meldet sich bei mir xxxxxxx, ich gebe ihm dann meine Handy-Nummer und wir könnten telefonieren und du könntest mir online via dwagent oder Ähnlichem helfen. Ich könnte dann auch evtl. besser erklären "was ich da so treibe".
                  MOD-EDIT: private Daten entfernt
                  mickym Homoran 1Topf 3 Replies Last reply Reply Quote 0
                  • mickym
                    mickym Most Active @geschild last edited by mickym
                    @geschild Also - Support muss auch hier im Thread langen. Wenn Du den mqtt Adapter als Broker verwendest, dann brauchst Du nicht auch noch einen Broker im zigbee2mqtt Adapter.
                    Ich würde an Deiner Stelle erst mal zigbee2mqtt zum Laufen bringen - dazu brauchst den zigbee2mqtt Adapter nämlich nicht, wenn Du den mqtt Adapter verwenden willst.
                    Also lass mal Deinen mqtt Adapter alleine an und deaktviere den zigbee2mqtt Adapter.
                    Wenn Du Dein Konfiguration postest, dann bitte den Text einfach in CodeTags hier kopieren:
                    Also so:
                    version: 4
                    homeassistant:
                      enabled: false
                    frontend:
                      enabled: true
                    mqtt:
                      server: mqtt://192.168.178.46:1885
                    advanced:
                      network_key:
                        - 199
                    so der Port kann ja nicht stimmen, wenn Dein mqtt Broker auf 1886 läuft.
                    So wenn Du das alles bereinigt hast und der Zigbee2mqtt Adapter deaktiviert ist, der Service läuft, dann probierst Du ob Du auf das Interface kommst.
                    Wenn alles gut geht, solltest Du auf das Zigbee2Mqtt Interface kommen, wenn Du im Browser
                    http://192.168.178.46:8080
                    eingibst
                      Homoran Global Moderator Administrators @geschild last edited by
                      code und ähnliches bitte immer als Text in code-tags posten.
                        Thomas Braun Most Active @geschild last edited by
                        Der Zigbee Stick wurde erkannt, dessen "alte" Firmware
                        Das der Stick 'erkannt' wurde heißt ja nix. Die alte Firmware hat aber Fehler, die in akutelleren Versionen behoben worden sind. Von daher ist es natürlich eine gute Idee die auf den letzten Stand zu bringen.
                        • mickym
                          Wenn das alles klappt, dann kannst Du über die zigbee2mqtt Interface mal 1,2 Geräte anlernen. In dem zigbee2mqtt Interfache kann man auch angeben, dass man einzelne Werte und kein JSON haben will. Dann kannst Du Dir immer noch überlegen, ob Du den zigbee2mqtt Adapter überhaupt brauchst oder nicht.
                          Ich persönlich arbeite ohne.
                          • mickym
                            mickym Most Active @Thomas Braun last edited by mickym
                            @thomas-braun sagte in Installieren zigbee 2mqtt:
                            Das mag ja richtig sein, aber das war nicht die Fehlerursache - deswegen lass ihn halt erst mal ein funktionierendes System bauen, bevor er gleich an der Firmware rumfrickelt. Ich ändere die Firmware auch nicht mehr (meine Tasmota Steckdosen laufen immer noch unter 8.x und werde mich hüten das upzudaten, da ich mir damit schon mal eine ganze Steckdosenleiste geschrottet habe) - denn anders als bei Betriebssystemen kann das bei Hardware dicke ins Auge gehen.
                              Thomas Braun Most Active @mickym last edited by
                              Wie grundsätzlich auch in anderen Konstellationen bringt man den ganzen Sums immer auf einen aktuellen Stand vor weiteren Experimenten.
                              Könnte ja durchaus sein, das zigbett2mqtt (oder irgendwas anderes) eine aktuellere Version einer Library, einer Firmware oder eines OS bedingt.
                              • mickym
                                @thomas-braun Sorry - wenn ich in einem Protokoll lese:
                                dann empfehle ich kein Firmwareupdate!
                                  @mickym
                                  Es geht um grundsätzliche Herangehensweisen. Und da ist der Hinweis auf eine 5 Jahre alte FW vollkommen angebracht.
                                  • mickym
                                    @thomas-braun In manchen Dingen sind wir einfach unterschiedlicher Meinung - ich weiß Du schaltest auch erst den Desktop aus bevor Du Dir einen Fehler anschaust. Aber gut - das kann der TE ja immer noch machen mit dem Firmwareupdate NACHDEM das System erst mal grundsätzlich läuft.
                                      Wegen der grundsätzlichen Herangehensweise...
                                      Um ein Thema ordentlich anzugehen brauchst du zunächst mal eine stabile, aktuelle Basis.
                                      Wenn die steht kannste dir die darauf aufsetzenden Dinge anschauen.
                                      Ist jetzt aber etwas OT und ich troll mich.
                                      • 1Topf
                                        1Topf @geschild last edited by 1Topf
                                        Welchen MQTT-Adapter Du nun nutzt ist egal, Hauptsache die IP und der Port stimmen. Ich habe auch beide laufen (also MQTT und Zigbee2MQTT), natürlich für verschiedene Sachen.
                                        Versuche mal weiter nach Anleitung vorzugehen. Eventuell wirst Du automatisch nach 3 Minuten rausgeschmissen:
                                        https://www.zigbee2mqtt.io/guide/installation/01_linux.html#optional-running-as-a-daemon-with-systemctl
                                        Du müßtest ja sonst bei jedem Neustart des Pi zigbee2mqtt manuell starten.
                                        geschild 2 Replies Last reply Reply Quote 0
                                        • geschild
                                          geschild @1Topf last edited by geschild
                                          @1topf @Mickym @Thomas-Braun
                                          Erstmal vielen Dank für eure Beiträge. Ich werde mir alles in Ruhe anschauen.
                                          Noch eine kleine Anmerkung:
                                          Bei Themen, bei denen ich mehr Ahnung hatte (Hardware, C++), habe ich sehr gute Erfahrungen mit Telefon/Teamviewer Hilfe gemacht.
                                          Dann war die Kuh meist in ein paar Minuten vom Eis.
                                          Ich glaube das miteinander Sprechen ist vielleicht auch eine Generationenfrage, stelle ich auch bei meinen Kindern fest, ich bin Baujahr 1955.
                                          • geschild
                                            @1topf
                                            Läuft !!!!!
                                            Port 1886 und den 'dummy server' abzuschalten hat es gebracht.
                                            Ich war der Meinung der zigbee2mqtt Adapter müssten einen eigenen Broker aufmachen.
                                            Noch einen Verständnisfrage zum Websocket: Den stellt der Adapter auch zur Verfügung ?
                                            Das Anlernen von Geräten geht ruckzuck, viel schneller als mit den reinen Zigbee-Adapter.
                                            Jetzt noch zu meinem "Uralt-Stick". An vielen Stellen wird der Sonoff Zigbee3.0 Stick erwähnt. Empfehlenswert ?
                                            Ist es richtig nur die -P Version zu verwenden, nicht die -E Version. Hast du eine andere Empfehlung.
                                            mickym crunchip T 3 Replies Last reply Reply Quote 0
                                            53
                                            3661
