    4. Matter – IPv6, Hubs und sonstige Vorbedingungen
      denjo @Dragon last edited by denjo
      Sorry für die fragen, habs aber wohl geschnallt. ich habe jetzt mein nuki schloss mit dem Aeotec Hub über Matter verbunden. habe dann in der Smartthings app einen Freischaltcode gemacht fürs Nuki Schloss und hab versucht über den Tab Controller das Schloss hinzuzufügen. Bekomme dann aber diese meldung
      matter.0
      2025-02-01 00:57:11.467	warn	Error while executing command "controllerCommissionDevice": Failed to connect on any discovered server at Function.iterateServerAddresses (/opt/iobroker/node_modules/@matter/protocol/src/peer/ControllerDiscovery.ts:231:23) at ControllerCommissioner.commissionWithDiscovery (/opt/iobroker/node_modules/@matter/protocol/src/peer/ControllerCommissioner.ts:238:32) at MatterController.commission (/opt/iobroker/node_modules/@project-chip/matter.js/src/MatterController.ts:402:25) at CommissioningController.commissionNode (/opt/iobroker/node_modules/@project-chip/matter.js/src/CommissioningController.ts:252:24) at Controller.commissionDevice (/opt/iobroker/node_modules/iobroker.matter/src/matter/ControllerNode.ts:451:24) at Controller.handleCommand (/opt/iobroker/node_modules/iobroker.matter/src/matter/ControllerNode.ts:166:28) at /opt/iobroker/node_modules/iobroker.matter/src/main.ts:229:40 at MatterAdapter.#onMessage (/opt/iobroker/node_modules/iobroker.matter/src/main.ts:226:13)
      matter.0
      2025-02-01 00:56:42.373	debug	2025-02-01 00:56:42.372 INFO PeerCommissioner Commissioning device SII: 2300 SAI: 2060 SAT: 1500 T: 0 PH: 36 ICD: 0 VP: 4957+161 PI:
      matter.0
      2025-02-01 00:56:42.372	debug	2025-02-01 00:56:42.372 INFO ControllerDiscovery Found 1 devices using identifier {"longDiscriminator":1122}
      matter.0
      2025-02-01 00:56:42.371	debug	2025-02-01 00:56:42.371 INFO ControllerDiscovery Start Discovering devices using identifier {"longDiscriminator":1122} ...
      matter.0
      2025-02-01 00:56:42.371	debug	2025-02-01 00:56:42.370 INFO PeerCommissioner Commissioning device with identifier {"longDiscriminator":1122} and 1 scanners and knownAddress "undefined"
      matter.0
      2025-02-01 00:56:42.370	debug	Registering Commissioning over BLE with WiFi: FRITZ!Box Denjo
      matter.0
      2025-02-01 00:56:42.369	debug	Handle message controllerCommissionDevice {"command":"controllerCommissionDevice","message":{"qrCode":"MT:OKAA0XC112INQ95ET10","manualCode":""},"from":"system.adapter.admin.0","callback":{"message":{"qrCode":"MT:OKAA0XC112INQ95ET10","manualCode":""},"id":798,"ack":false,"time":1738367802367},"_id":40218677}
      ich habe es jetzt nochmal anders herum Probiert also ein object von iobroker über matter in samsung smarthings. Das klappt Problemlos
      • JackDaniel
        JackDaniel last edited by JackDaniel
        @denjo
        Ich hatte damals beim Alpha Test das selbe Thema, den Teil IPV6 Kommunikation für Nutzung von Thread Geräten unter Troubleshooting befolgen, und schon klappt es mit Matter over Thread Geräten wie dem Nuki Schloss
        D J 3 Replies Last reply Reply Quote 1
          denjo @JackDaniel last edited by denjo
          @jackdaniel also ich habe iobroker als VM. wie hast du die umstellung auf ipv6 slaac gemacht, finde die option nicht? oder hast du den VM neu gemacht?
          • Feuersturm
            Feuersturm @denjo last edited by
            @denjo slaac ist bei LXCs relevant .
            Es geht um diesen Abschnitt https://github.com/ioBroker/ioBroker.matter/wiki/Troubleshooting#ipv6-kommunikation-für-nutzung-von-thread-geräten
              @jackdaniel Dankeeeeeee
              habs am laufen.
              damit:
              /etc/sysctl.conf
              net.ipv6.conf.all.forwarding=0
              net.ipv6.conf.wlp0s20f3.forwarding=0
              net.ipv6.conf.wlp0s20f3.accept_ra=1
              net.ipv6.conf.wlp0s20f3.accept_ra_rt_info_max_plen=64
              /etc/network/interfaces
              iface wlp0s20f3 inet6 auto
              -- accept_ra 2
                apollon77 @Dragon last edited by
                @dragon Hast du in eden App einstellungen beim ersten Visu projekt deine ioBroker.pro credentials eingetragen? und iot Adapter ist gründ und verbunden?
                  apollon77 @denjo last edited by apollon77
                  @denjo naja das Lock ist Thread ... daher Thread Border Router ... Hast DU auf dem ioBroker Host die nötigen IPv6 Einstellungen gemacht? Siehe Troubleshooting und Infos im ersten Post?
                  Edit, ok hatte sich dann ja schon erledigt 🙂 Super
                    denjo @apollon77 last edited by
                    @apollon77 yes, trotzdem danke
                      TheNeon @denjo last edited by
                      @denjo said in Matter Beta – IPv6, Hubs und sonstige Vorbedingungen:
                      habs am laufen.
                      damit:
                      /etc/sysctl.conf
                      -- accept_ra 2
                      .. sorry, aber ich blicke das alles noch gar nicht.
                      Wo trage ich das denn ein?
                      Wie bekomme ich meinen HomePod Mini denn als Border Router hinzugefügt?
                      Adapter ist grün. Mehr hab ich bis jetzt nicht hinbekommen.
                      D Feuersturm 2 Replies Last reply Reply Quote 0
                        denjo @TheNeon last edited by
                        @theneon was hast du denn für ein system?
                          @denjo
                          Oh… sorry … alles läuft direkt auf einem Raspy … ohne Container / Docker etc.
                          Alle Adapter / Sytemdatein sind aktuell …
                          • Feuersturm
                            Feuersturm @TheNeon last edited by
                            @theneon sagte in Matter Beta – IPv6, Hubs und sonstige Vorbedingungen:
                            Dein HomePad Mini als Border Router wird in dem Sinne nicht zum Matter Adapter hinzugefügt so dass du ihn nacher sehen kannst, sondern erst ist das Verbindungsglied von deinem ioBroker zum Thread Gerät. Dein ioBroker kann über WLAN / LAN kommunizieren, aber nicht über die Funktechnologie "Thread". Wenn du ein Thread fähgies Matter Gerät hast (z.B. NUKI Türschloss, Rauchmelder, Fensterkontaktsensor) so spricht dieses Gerät nur "Thread" und kann nicht direkt über das WLAN mit deinem ioBroker kommunizieren. Hierfür dient dann der Thread Border Router als Übersetzer. Hier ist ein Artikel der einen Thread Border Router beschreibt https://matter-smarthome.de/wissen/was-ist-ein-thread-border-router/
                              denjo @Feuersturm last edited by
                              @feuersturm eine frage noch, ich habe jetzt eine Lampe zum test über den matter adapter in den aeotec hub freigegeben und kann sie auch über die smartthings app steuern. jetzt wollte ich diese Lampe in google home weitergeben. bin also in die smartthings app und auf freigeben für anderen dienst. Da kommt aber immer die Fehler Meldung "Gerät konnte nicht freigegeben werden". Eigentlich muss das aber doch so funktionieren oder?
                              • Feuersturm
                                @denjo Hast du die Lampe mit dem ioBroker Matter Controller gepaired oder hast du die Lampe als ioBroker Matter Device bereitgestellt?
                                Mir ist gerade nicht klar, mit welchem Ökosystem die Lampe schon verknüpft ist.
                                  • Feuersturm
                                    Feuersturm @denjo last edited by Feuersturm
                                    @denjo Wenn du in der Zeile mit dem blauen Balken wieder auf das QR Code Icon klickst bekommst du wieder den QR-Code zum koppeln bzw. den manuellen Kopplungscode angezeigt. Diesen scannst du jetzt mit Google Home und dann ist die Lampe dort auch verfügbar.
                                    Wenn du auf das grüne WLan Symbol klickst, siehst du mit welchen Ökosystemen die Lampe dann verbunden ist.
                                      @feuersturm Screenshot_20250202_212055_Google Play services.jpg hatte ich auch schon probiert
                                      • Feuersturm
                                        @denjo Hast du nur die Google Home App installiert oder hast du auch einen Matter Hub aus dem Google Ökosystem?
                                          @feuersturm ich habe auf mein handy nur die google app und habe den aeotec "smartthings" hub
                                          • Feuersturm
                                            @denjo Das wird nach meinem Verständnis nicht funktionieren. Wenn du die Google Home App nutzen möchtest, musst du auch einen entsprechenden Google Hub haben, sowie du auch zu deiner Smartthing App deinen entsprechenden Matter Hub hast.
                                            @apollon77 Bitte korrigieren, wenn ich hier falsch liege.
                                            177
                                            26078
