    4. Test Adapter flexcharts - Stapeldiagramme und mehr
    • U
      UlliJ @jrbwh last edited by
      @jrbwh
      jepp, die funktionieren wie gehabt. Installiere den Adapter morgen mal neu…kriegen wir schon. Danke
      • SMS
        SMS @jrbwh last edited by
        @jrbwh Dann würde ich sagen funktioniert es nicht! Das hier steht im Skript:
        // Create chart for Tibber hourly data to be used with flexcharts
        const ID_TIBBER_HOURLY = '0_userdata.0.flexcharts.tibberLink.tibberHourly';       // State id containing tibber data (json format)
        const ID_CHART_HOURLY  = '0_userdata.0.flexcharts.tibberLink.chartHourly';        // State id containing template for chart data (json format)
        const TITLE_HOURLY     = 'Tibber hourly';
        evalTibberData(ID_TIBBER_HOURLY, ID_CHART_HOURLY, TITLE_HOURLY);    // Convert data on start of script
        on({id: ID_TIBBER_HOURLY, change: "any"}, function (obj) {
        function evalTibberData(idTibber, idChart, title) {
            const tibber = JSON.parse(getState(idTibber).val);  // Read tibber data
            const chart = JSON.parse(getState(idChart).val);    // Read chart template
            const xAxis  = [];
            const yAxis0 = [];
            const yAxis1 = [];
            for (const data of Object.values(tibber)) {
                const isHourly = (new Date(data.from).getHours() != new Date(data.to).getHours());  // Hourly data?
                const xValue = (isHourly ? new Date(data.from).toLocaleTimeString() : new Date(data.from).toLocaleDateString());
                xAxis.push(xValue);
                yAxis0.push((data.consumption ? data.consumption.toFixed(2) : 0));  // push 0 on null values
                yAxis1.push((data.cost ? data.cost.toFixed(2) : 0));                // push 0 on null values
            chart.title.text = title;           // Set chart title
            chart.xAxis[0].data  = xAxis;       // Set chart x-axis data
            chart.series[0].data = yAxis0;      // Set chart y-values consumption
            chart.series[1].data = yAxis1;      // Set chart y-values cost
            setState(idChart, JSON.stringify(chart), true); // Write changed chart data to state
            console.log('Evaluation of tibber hourly data done. Title: '+title);
        Das hier ist die ID vom tibberHourly:
        Und hier vom chartHourly:
        Muss noch irgendwo die ID von tibberlink rein?
        jrbwh 1 Reply Last reply Reply Quote 0
        • jrbwh
          jrbwh @SMS last edited by
          @sms Was steht im Log? Und wie kommen die Daten von tibberLink.0.Homes.... nach 0_userdata.0.flexcharts.tibberHourly? Denke, Du solltest im Skript direkt die tibberLink.0.Homes...-ID verwenden.
            legro last edited by legro
            @sms
            Aller Anfang ist schwer. Am Ende hilft jedoch nur, sich selbst in die Materie einzuarbeiten. Meine Leidens- und vor allem Erfolgsgeschichten kannst du hier in Teilen nachlesen. Dort findest du viele Ideen und Techniken, wie du dein Vorhaben weitestgehend selbst in die Tat umsetzen kannst.
            Nicht erschrecken! Aber ohne sich durch derartige Gedanken hindurch zu kämpfen, wirst du mit FlexCharts nicht glücklich. Aber sei versichert: Es lohnt sich.
            • U
              @jrbwh sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
              Ich habe eine Version im Branch develop erstellt, kann im Moment aber nur eingeschränkt testen. Bei mir sieht's gut aus. Falls Du es ausprobieren möchtest:
              nach Neuinstallation sieht das so aus👍
              jrbwh 1 Reply Last reply Reply Quote 1
              • jrbwh
                jrbwh @UlliJ last edited by
                @ullij Super. Danke fürs Testen!
                • jrbwh
                  @sms Ich habe eine "Variante 2" des Skripts erstellt. Das benötigt keine zusätzlichen Datenpunkte und kann stündliche, tägliche, wöchentliche und monatliche Daten direkt verarbeiten. Man muss lediglich die IDs der tibberLink-Datenpunkte ("tibberLink.0.Homes...") im Skript bei "IDS" korrekt eintragen, dann sollte es funktioniert. Die Auswahl der Daten erfolgt dann im http-Aufruf.
                  Wäre super, wenn Du das mal ausprobieren könntest. Ich kann es selber nicht gut testen, da ich keine tibberLink-Daten habe.
                  SMS 1 Reply Last reply Reply Quote 0
                  • jrbwh
                    jrbwh @Merlin123 last edited by
                    @merlin123 Ich habe ein Skript erstellt, um ein einfaches Chart für Verbrauch und Kosten zu generieren. Passt für Dich vermutlich nicht, aber es wäre klasse, wenn Du "Variante 2" mal ausprobieren könntest. Mein Problem ist, dass ich ohne Tibber-Daten nur sehr grob testen kann.
                    • SMS
                      @jrbwh Hi! Läuft seit heute morgen ca. 8Uhr! Scheint zu funktionieren. 🙂
                      • jrbwh
                        @sms Sehr schön! Du benutzt "Variante 2", richtig?
                        • SMS
                          @jrbwh JA, vielen Dank dafür!
                          Wo kann ich denn die Balkenfarbe ändern?
                          Das hier ändert mir nur die seitlichen Achsen:
                          xAxis: [{ type: "category", axisTick: { alignWithLabel: true }, data: []}],
                                              yAxis: [{ type: "value", position: "left",  alignTicks: true, axisLine: { show: true, lineStyle: { color: "#5470C6" }}, axisLabel: { formatter: "{value} kWh" }},
                                                      { type: "value", position: "right", alignTicks: true, axisLine: { show: true, lineStyle: { color: "#91CC75" }}, axisLabel: { formatter: "{value} €" }}],
                                              series: [{ name: "Consumption", type: "bar", yAxisIndex: 0, data: []},
                                                       { name: "Cost",        type: "bar", yAxisIndex: 1, data: []}]
                          Die Schriftfarbe müsste ich auch ändern, da ich einen dunklen Hintergrund habe. Eine Veränderung hier ändert abernichts:
                          } else {
                                  console.log('Invalid chart type >>'+myChart+'<<');
                                  callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "INVALID
                          • jrbwh
                            @sms Wenn Du die Farben der Balken ändern möchtest, musst auch in deren Definition was ändern. Z.B. so:
                                                series: [{ name: "Consumption", type: "bar", color: "#ff0000", yAxisIndex: 0, data: []},
                                                         { name: "Cost",        type: "bar", color: "#00ff00", yAxisIndex: 1, data: []}]
                            Der "else"-Zweig sorgt nur dafür, dass eine Fehlermeldung angezeigt wird, wenn Du einen ungültigen Chart-Type anforderst, z.B. mit &chart=Käse. Das hat mit dem eigentlichen Chart überhaupt nichts zu tun.
                            Generell solltest Du - wie auch schon von @legro empfohlen - versuchen, zu verstehen was du tust. Da helfen Readme, Dokus, Tutorials, Youtube-Videos wirklich weiter. Probier's mal!
                            Die Referenz zu Chart-Definitionen findest Du übrigens hier. Wenn Du da die Option "series" aufklappst, findest Du den Parameter "color".
                            • Merlin123
                              Merlin123 @jrbwh last edited by Merlin123
                              @jrbwh Script funktioniert super! Gefällt mir sehr gut 🙂 Mal schauen, wie ich das in meiner VIS einbauen kann.
                              Kleiner Verbesserungsvorschlag:
                              Statt die 4 einzelnen DPs im Script eintragen zu müssen könnte man eine Variable mit der HomeID machen und die 4 anderen DPs daraus automatisch erzeugen.
                              Und blöde Frage: Werden die Charts automatisch aktualisiert? Ich sehe im Scrips nichts, aber meine JS Fähigkeiten sind "limitiert" 😉
                              SMS jrbwh 2 Replies Last reply Reply Quote 0
                              • SMS
                                SMS @Merlin123 last edited by
                                @merlin123 Bei mir nur wenn ich die Seite aktualisiere
                                • jrbwh
                                  @merlin123 Das ist eine gute Idee. Die DPs sehen so aus:
                                  tibberLink.0.Homes.xxx.Consumption.jsonHourly
                                  tibberLink.0.Homes.xxx.Consumption.jsonDaily
                                  tibberLink.0.Homes.xxx.Consumption.jsonWeekly
                                  tibberLink.0.Homes.xxx.Consumption.jsonMonthly
                                  Ist das korrekt? Man könnte also tibberLink.0.Homes.xxx.Consumption also Konstante machen.
                                  Nein. Das gibt das Konzept nicht her. Wie ich auch in der Beschreibung geschrieben habe:
                                  "Das Chart kann per Hand oder regelmäßig mit der Option refresh (siehe Readme) neu geladen werden. Oder über entsprechende Einstellungen des iFrames."
                                  Mit &refresh=30 wird automatisch alle 30 Sekunden aktualisiert. Oder Du konfigurierst den iFrame so, dass regelmäßig aktualisiert wird.
                                  • Merlin123
                                    @jrbwh Jup... sehen bei mir auch so aus:
                                    const IDS = { hourly:  'tibberlink.0.Homes.xxx.Consumption.jsonHourly',  // hourly data
                                                  daily:   'tibberlink.0.Homes.xxx.Consumption.jsonDaily',  // daily data
                                                  weekly:  'tibberlink.0.Homes.xxx.Consumption.jsonWeekly',  // weekly data
                                                  monthly: 'tibberlink.0.Homes.xxx.Consumption.jsonMonthly'   // monthly data
                                    Aktualisierung:
                                    Das hab ich überlesen.
                                    Wenn die aber beim Laden des Frames aktualisiert werden, reicht mir das auch 🙂
                                    jrbwh M-A Hueb 2 Replies Last reply Reply Quote 0
                                    • jrbwh
                                      @merlin123 Gut. Hier mal ein Skript zum Testen:
                                      // Create chart for Tibber data. To be used with flexcharts.
                                      // Sample http request for hourly data chart:
                                      // http://localhost:8082/flexcharts/echarts.html?source=script&message=tibber&chart=hourly
                                      // Replace 'MY-TOKEN' with your own token:
                                      const ID_TIBBER = 'tibberLink.0.Homes.MY-TOKEN.Consumption';
                                      const IDS = { hourly:  '.jsonHourly',  // hourly data
                                                    daily:   '.jsonDaily',   // daily data
                                                    weekly:  '.jsonWeekly',  // weekly data
                                                    monthly: '.jsonMonthly'  // monthly data
                                      onMessage('tibber', (httpParams, callback) => {
                                          // Use hourly data in case of invalid chart type
                                          const id = (httpParams.chart && httpParams.chart in IDS ? ID_TIBBER+IDS[httpParams.chart] : ID_TIBBER+IDS['hourly']);
                                          if (existsState(id)) {
                                              evalTibberData(httpParams.chart, id, result => callback(result));
                                          } else {
                                              console.log('Requested state is not available >>'+id+'<<');
                                              callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "REQUESTED STATE IS NOT AVAILABLE: >>" + id +"<<" }});
                                      function evalTibberData(myChart, id, callback) {
                                          const tibber = JSON.parse(getState(id).val);  // Read tibber data
                                          const chart = {
                                                          tooltip: { trigger: "axis", axisPointer: { type: "cross" }},
                                                          legend: { show: true, orient: "horizontal", left: "center", top: 25 },
                                                          title: { left: "center", text: "Tibber " },
                                                          grid: { right: "20%" },
                                                          toolbox: { feature: { dataView: { show: true, readOnly: false }, restore: { show: true }, saveAsImage: { show: true }}},
                                          const xAxis  = [];
                                          const yAxis0 = [];
                                          const yAxis1 = [];
                                              const isHourly = (myChart == 'hourly');  // Hourly data?
                                              xAxis.push(xValue);
                                          chart.title.text += myChart;             // Add type of chart to title
                                          console.log('Evaluation of tibber '+myChart+' data done.');
                                          callback(chart);
                                      • Merlin123
                                        @jrbwh nope...
                                        der Name des DPs sieht aber richtig aus....
                                        • jrbwh
                                          @merlin123 Ups, es muss tibberlink heißen und nicht tibberLink (mit großem L). Bitte nochmal mit kleinem l probieren.
                                          • Merlin123
                                            @jrbwh Geht 🙂 Das hab ich jetzt auch nicht gesehen 😛
                                            chart charts diagramme echarts visualisierung visualization
                                            19
                                            262
                                            46100
