    3. Einsteigerfragen
    4. Parser / Regex
    Parser / Regex
      Diamand2k22 last edited by
      @OliverIO
      Hallo Oliver,
      kannst du mir bitte helfen, das Abfrage Skript der Forecast Werte funktioniert leider nicht mehr.
      Skript:
      // Definition Variablen
      const axios = require('axios').default;
      const url = "https://www.solarweb.com/PublicDisplay?token=";
      const displayToken = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
      const path = '0_userdata.0.Datenpunkte.PV_Anlage.Solarforecast.Solarweb.';
      const data_solarweb = path + 'JSON_Data_Solarweb';
      const datapoint_forecast_today = path + 'Forecast_Today';
      const datapoint_forecast_tomorrow = path + 'Forecast_Tomorrow';
      const datapoint_energy_remaining_today = path + 'Energy_remaining_today';
      const datapoint_current_energy_generated_today = path + 'Current_energy_generated_today';
       //Create Datenpunkte
      createState(path + 'JSON_Data_Solarweb', {type: 'json', name: 'JSON_Data', role: 'state'});
      createState(path + 'Forecast_Today', {name: 'Forecast_Today',role: 'state',type: 'number',read: true,write: true, desc: 'Manuell erzeugt',def:0,unit: 'kWh'}, function () {});
      createState(path + 'Forecast_Tomorrow', {name: 'Forecast_Tomorrow',role: 'state',type: 'number',read: true,write: true, desc: 'Manuell erzeugt',def:0,unit: 'kWh'}, function () {});
      createState(path + 'Current_energy_generated_today', {name: 'Current_energy_generated_today',role: 'state',type: 'number',read: true,write: true, desc: 'Manuell erzeugt',def:0,unit: 'kWh'}, function () {});
      createState(path + 'Energy_remaining_today', {name: 'Energy_remaining_today',role: 'state',type: 'number',read: true,write: true, desc: 'Manuell erzeugt',def:0,unit: 'kWh'}, function () {});
      async function  getWebContent(url,displayToken) {
          const response = await axios.get(url+displayToken);
          return response.data;
      async function main() {
          const content=await getWebContent(url,displayToken);
          setState(data_solarweb,content.data), true;
      let data = JSON.parse(JSON.stringify(getState(data_solarweb).val));
      console.log(data.Forecast.find(el=>el.ExpectedYieldDayLabel=="Today").ExpectedEnergyYield.Value);
      setState(datapoint_forecast_today,parseFloat(data.Forecast.find(el=>el.ExpectedYieldDayLabel=="Today").ExpectedEnergyYield.Value), true);
      console.log(data.Forecast.find(el=>el.ExpectedYieldDayLabel=="Tomorrow").ExpectedEnergyYield.Value);
      setState(datapoint_forecast_tomorrow,parseFloat(data.Forecast.find(el=>el.ExpectedYieldDayLabel=="Tomorrow").ExpectedEnergyYield.Value), true);
      setState(datapoint_current_energy_generated_today, (getState("0_userdata.0.Datenpunkte.PV_Anlage.Solarweb.Current.01_Day.Energy.EnergyProductionTotal").val), true);
      setState(datapoint_energy_remaining_today, Math.min(Math.max(getState(datapoint_forecast_today).val - getState(datapoint_current_energy_generated_today).val, 0), 200), true);
      main();
      // jede Stunde 6 neu berechnen
      schedule("6,16,26,36,46,56 * * * *", async function () {
        await main();
      Zu dem kommt noch folgender Fehler beim Abruf der Daten.
      javascript.0
      2023-12-10 10:56:00.171	error	Error: read ECONNRESET at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at TLSSocket.socketErrorListener (node:_http_client:501:9) at TLSSocket.emit (node:events:517:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at processTicksAndRejections (node:internal/process/task_queues:82:21)
      javascript.0
      javascript.0
      2023-12-10 10:56:00.170	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      Danke dir!
      • OliverIO
        OliverIO last edited by OliverIO
        @diamand2k22
        Kannst du mir wieder so einen gastzugang einrichten?
        Ok erledigt. Hast mir per pn geschickt
          Diamand2k22 @OliverIO last edited by Diamand2k22
          @oliverio
          was auch seltsam ist, das axios Modul kann nicht gefunden werden!
          • OliverIO
            OliverIO @Diamand2k22 last edited by
            @diamand2k22
            Das ist nur visuell.
            Das zeigt es bei mir auch an. Das hat damit zu tun, wie der Editor diese Überprüfung durchführt. Da fehlen für ihn noch typbibliotheken,
            Aber bei der Ausführung klappt axios ja
            • OliverIO
              OliverIO @Diamand2k22 last edited by OliverIO
              @diamand2k22
              so, hier müsste es wieder funktionieren. das ist halt das risiko bei reverse engineerten Schnittstellen.
              Wenn der Anbieter irgendwas ändert, dann tut es nicht mehr.
              Hier hat er jetzt den Endpunkt geändert und verlangt noch, das der user-agent mit angegeben sein muss und wahrscheinlich, das das auch irgendein browser ist.
              d.h. der Anbieter hat bemerkt, das seine website von anderen tools als von browsern gelesen wird und hat mal dezente Gegenmaßnahmen ergriffen.
              Generell kann man jegliche Abfrage, die mit einem browser gemacht wird auch mit node nachbilden. allerdings gibt es auch gegenmaßnahmen, bei denen es dann so aufwändig wird, das man dann mit pupeteer oder einem ähnlichen browser simulationstool arbeitet (wobei bei pupeteer ja wirklich ein browser auch arbeitet), welches dann ordentlich ressourcen verbraucht.
              daher immer den Hinweis, die abfragerei bei solchen typen nicht überreitzen.
              alle 10 Minuten dürfte jetzt kein riesenproblem darstellen, der Anbieter kann aber durchaus pro nutzer herausfinden, wie oft pro tag abgerufen wird und wenn das gewisse limits überschreitet, er uU dann weitere Gegenmaßnahmen ergreift. dem anbieter kostet das nun auch reales geld, wenn er für seine kunden 1 server oder 10 server hinstellen muss, die die menge an abfragen bewältigt.
              So etwas gar minütlich abfragen und das dann einige leute machen, da kann man dann darauf warten, bis es nicht mehr tut (siehe finanz/börsen-kurse)
              const url = "http://www.solarweb.com/PvSystems/GetWeatherWidgetDataForPublicDisplay?publicDisplayToken=";
              const displayToken = "xxxxx";
                  try {
                      log("Request solarweb data")
                      const response = await axios.get(url+displayToken,{
                          timeout:5000,
                          headers:{
                              "User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36"
                  } catch (error) {
                      log(error,"error");
                  const data=content.data;
                  setState(data_solarweb, JSON.stringify(data), true);
                  setState(datapoint_forecast_today, parseFloat(data.Forecast.find(el=>el.ExpectedYieldDayLabel=="Today").ExpectedEnergyYield.Value), true);
              main();
                await main();
              da ich für meinen test die ganzen iobroker relevanten anweisungen kommentiert habe, habe ich das nicht getestet. nur den abruf der daten und herausfinden der forecasts.
              noch ein hinweis. der anbieter bietet explizit einen api zugang an, der bestellt werden muss
              https://www.fronius.com/de/solarweb-query-api/zugang-zur-api
              ob das was kostet kannst du ja mal fragen. evtl bekommt man da was offiziell geduldetes hin. weiß ja nicht wieviele leute das hier bei iobroker nutzen
                @oliverio
                vielen Dank Oliverio, jetzt funktioniert es wieder!
                ich habe bereist den kostenpflichtigen Pro Zugang im Einsatz, jedoch nutze ich dieses Script lieber wie den Fronius Solarweb Adapter! Der hat ca. 6000 Datenpunkte, nutze aber aktuell nur 3 Datenpunkte. Deswegen doch lieber das Skript, schont auch die Resourcen meinen Raspberry PI 😉
                Danke nochmal!
                • OliverIO
                  @diamand2k22
                  ja, aber gem. der beschreibung hast du dann offiziellen zugang zu einer api
                  die dann wahrscheinlich auch stabil bleibt und nicht diese methode.
                  ich denke die offizielle api wird nicht viel anders funktionieren. wahrscheinlich nur endpoint anpassen.
                  frag mal nach wo man di dokumentation dazu findet, wenn du schon was mit premium nutzt
                    @oliverio
                    ich mach mich mal schlau über die api und melde mich hier nochmal.
                    soweit ich weiß schickt fronius die forecastwerte einzelwerte im 15 Min Takt über die Schnittstelle, aber das muss ich erst noch abklären.
                    Evtl. könnte @Strobelix hier was dazu beitragen.
                    • OliverIO
                      @diamand2k22
                      frag nach der api dokumentation
                        @oliverio
                        Hallo Oliver, du hast mir doch damals bei der Erstellung des Skripts zur Abfrage der Solarweb Prognose Daten geholfen und mir dieses Skript zusammen gebaut.
                            try {
                                    timeout:5000,
                                    headers:{
                            } catch (error) {
                                log(error,"error");
                        main();
                          await main();
                        könntest du mir nochmal behilflich sein, das Skript auf httpGet umzustellen?
                        Danke Dir und
                        Diamand2k22
                          Diamand2k22 @Diamand2k22 last edited by
                          @OliverIO
                          hab doch hinbekommen, falls es noch jemand gebrauchen kann.
                          const http = require('https');
                          const url = "https://www.solarweb.com/PvSystems/GetWeatherWidgetDataForPublicDisplay?publicDisplayToken=";
                          const displayToken = "xxxxxx-xxxxxxx-xxxxxxx-xxxxxx";
                          // Create Datenpunkte
                          createState(path + 'JSON_Data_Solarweb', { type: 'json', name: 'JSON_Data', role: 'state' });
                          createState(path + 'Forecast_Today', { name: 'Forecast_Today', role: 'state', type: 'number', read: true, write: true, desc: 'Manuell erzeugt', def: 0, unit: 'kWh' });
                          createState(path + 'Forecast_Tomorrow', { name: 'Forecast_Tomorrow', role: 'state', type: 'number', read: true, write: true, desc: 'Manuell erzeugt', def: 0, unit: 'kWh' });
                          createState(path + 'Current_energy_generated_today', { name: 'Current_energy_generated_today', role: 'state', type: 'number', read: true, write: true, desc: 'Manuell erzeugt', def: 0, unit: 'kWh' });
                          createState(path + 'Energy_remaining_today', { name: 'Energy_remaining_today', role: 'state', type: 'number', read: true, write: true, desc: 'Manuell erzeugt', def: 0, unit: 'kWh' });
                          async function getWebContent(url, displayToken) {
                              return new Promise((resolve, reject) => {
                                  const requestUrl = url + displayToken;
                                  http.get(requestUrl, { headers: { "User-Agent": "Mozilla/5.0" } }, (response) => {
                                      let data = '';
                                      // Daten aus dem Stream sammeln
                                      response.on('data', chunk => {
                                          data += chunk;
                                      response.on('end', () => {
                                          try {
                                              const parsedData = JSON.parse(data);
                                              resolve(parsedData);
                                          } catch (error) {
                                              reject('Fehler beim Parsen der Antwort: ' + error);
                                      response.on('error', (error) => {
                                          reject('Fehler bei der Anfrage: ' + error);
                                  }).on('error', (error) => {
                                      reject('Fehler bei der HTTP-Anfrage: ' + error);
                              try {
                                  const content = await getWebContent(url, displayToken);
                                  const data = content.data;
                                  console.log(data.Forecast.find(el => el.ExpectedYieldDayLabel == "Today").ExpectedEnergyYield.Value);
                                  setState(datapoint_forecast_today, parseFloat(data.Forecast.find(el => el.ExpectedYieldDayLabel == "Today").ExpectedEnergyYield.Value), true);
                                  console.log(data.Forecast.find(el => el.ExpectedYieldDayLabel == "Tomorrow").ExpectedEnergyYield.Value);
                                  setState(datapoint_forecast_tomorrow, parseFloat(data.Forecast.find(el => el.ExpectedYieldDayLabel == "Tomorrow").ExpectedEnergyYield.Value), true);
                                  setState(datapoint_current_energy_generated_today, getState("0_userdata.0.Datenpunkte.PV_Anlage.Solarweb.Current.01_Day.Energy.EnergyProductionTotal").val, true);
                              } catch (error) {
                                  log("Fehler im Hauptprozess: " + error, "error");
                          main();
                          // Jede Stunde 6 neu berechnen
                              await main();
                          4641
