    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      RISSN last edited by RISSN
      so iob diag, endlich geschafft
                              v.2024-10-19
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-33-amd64
            Architecture: x86-64
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1002
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs 20.18.2 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             11G        3.8G        6.9G        0.0K        1.0G        7.6G
      Swap:           974M          0B        974M
      Total:           12G        3.8G        7.8G
      Active iob-Instances:   57
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.10
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      Objects:                38188
      States:                 28996
      Size of iob-Database:
      55M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/objects.json.migrated
      19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      34M     /opt/iobroker/iobroker-data/states.jsonl
      6.2M    /opt/iobroker/iobroker-data/states.json.migrated
      6.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        A Former User @RISSN last edited by
        @rissn
        Ja oder mobaxterm alles besser als die Proxmox console
          MarshmallowsLike @Guest last edited by MarshmallowsLike
          @ilovegym
          hmm okay, funktioniert bei mir nicht oder geht der wert über 1 hinaus?
            A Former User @MarshmallowsLike last edited by
            @marshmallowslike
            Du setzt im Ordner set die Werte und dann startest du die Clima
              @ilovegym ja das verstehe ich. danke.
              aber außenspiegel/Heckscheibe geht nicht? wert 0 ist Lenkrad, 1 scheint nur heizung und defrost ist frontscheibe
                @marshmallowslike meine mit defrost geht alles an..?
                Nutze ich selten, da ichin der App mehr Optionen habe
                  also irgendwie haut der Adapter in teilen bei dem ioniq 5 nicht so wirklich hin.
                  Eine Aktualisierung über Force_refresh_from_car oder force_login kann bis zu 30 sek oder länger dauern. bei der Bluelink app geht das hintereinander weg, ohne das man großartig warten muss. Ist ja an sich nicht sooo tragisch, jedoch kommt des öfteren einen Errorcount, weil man angeblich zwei abfragen startet - was nicht der fall ist.
                  Dann funktioniert die Lenkradheizung irgendwie nicht oder nicht mehr? Ich war der Meinung, es hatte mal funktioniert. Einige Optionen fehlen -> Außenspiegel und Heckscheibenheizung.
                  eig. find ich das recht smart über einen tablet an der wand eben das auto anzuheizen, ohne ständig das handy rausholen zu müssen und anschließend ein feedback zu bekommen, was jetzt genau an. vllt teste ich nochmal die stable version. ggf. läuft die ja besser.
                    arteck Developer Most Active @MarshmallowsLike last edited by arteck
                    @marshmallowslike sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                    doch ist es..du musst ALLE aktivitäten betrachten nicht nur von dem adapter also
                    app handy
                    adapter
                    evcc
                    wallbox
                    und und und
                    für wünsche bitte ein issue auf GIT machen..
                      RISSN @arteck last edited by
                      @arteck selbst wenn ich die App stoppe und den Adapter dann starte, bekomme ich den Fehler:
                      bluelink.0
                      2025-02-04 07:54:20.004	error	@EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/60ec4243-0aa3-4d7d-ba8f-a8af03588609/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"dbbcddf0-e2c4-11ef-97fe-af123ae934e0"}
                      Ich verstehe es nicht, außer der Typ vom Auto kommt halt nichts
                        arteck Developer Most Active @RISSN last edited by arteck
                        @rissn
                        das kann keiner .. .. ausser KIA oder Hyundai in der Zentrale.. also nicht auf die Idee kommen die Werkstatt damit zu konfrontieren
                        ausserdem musst du bedenken dass der Adapter die Daten IMMER abholt.. in der App hast du andere Techniken (interne Daten haltung)
                        R ? 2 Replies Last reply Reply Quote 0
                          @arteck ich meine, ich sehe in den Datenpunkten nur die VIN und den Typ vom Auto, nichts anderes, kommt halt gleich der Alarm
                            @rissn
                            Hast du mal dein System neu und vor allem richtig aufgesetzt?
                            Solange du mit dem geschossenen Root debian bullseye dich rum plagst, wird hier keiner helfen können..
                            Und dann bitte ein log vom Adapter start an, und nicht immer nur eine Zeile..
                              A Former User @arteck last edited by A Former User
                              @arteck
                              Und da kommt n update der app mit allen zu erwartenden Sachen…
                              Edit:
                              Funktioniert bei mir auch schon, die Bilder werden wohl in der App gespeichert..
                              hab in den raw daten nix neues gefunden… 😢
                                baeckerman83 last edited by
                                welches ist die aktuelle Funktionierende Version des Adapters?
                                Ich habe Version 3.1.2 installiert und bekomme immer wieder die Meldung: "Restart loop detected" und der Adapter geht nicht.
                                  A Former User @baeckerman83 last edited by
                                  @baeckerman83
                                  genau die funktioniert einwandfrei bei mir.
                                  Ursache kann da alles und nix sein, vom Fahrzeug bis zum Betriebssystem.. zeig mal die Ausgabe von "iob diag" und welches Fahrzeug hast du denn ueberhaupt?
                                    baeckerman83 @Guest last edited by
                                    Hi!
                                    Ich habe einen EV6 von Kia. Lief die ganze Zeit super mit dem Adapter. Dann kam das Update in der KIA App vor einer Woche etwa. Daher habe ich dann Version 3.1.2 versucht.
                                    iob diag kennt meine iobroker installation irgendwie nicht.
                                    Wenn ich die Starte steht im Log:
                                    Error: The state contains the forbidden properties day, time! at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:209:13) at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:3842:21) at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:3820:17) at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:133:30) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21) at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21) at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
                                      @baeckerman83
                                      Wenn iob diag nicht geht, stimmt was ganz gewaltig mit deiner iobroker Installation nicht.
                                      Am besten hierzu einen neuen Thread eröffnen, und sich helfen lassen.
                                      Klar, dass dann der Adapter nicht funktioniert..
                                        baeckerman83 @Guest last edited by baeckerman83
                                        @neuschwansteini
                                        Das lag an meiner Docker Installation. Ich habe das Image mal aktuallisiert, jetzt gibt es iob diag.
                                        Die Version 3.1.2 wirft aber weiterhin den Fehler. Ich dachte erst nicht, der Fehler kommt aber sobald er versucht das Auto zu laden.
                                        2025-02-19 20:52:57.906 - info: bluelink.0 (3085) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.18.2, js-controller: 6.0.11
                                        2025-02-19 20:52:57.938 - info: bluelink.0 (3085) Login to api
                                        2025-02-19 20:52:59.672 - info: bluelink.0 (3085) 1 Vehicles found
                                        2025-02-19 20:53:00.063 - info: bluelink.0 (3085) Read new update for VIN from the server
                                        2025-02-19 20:53:03.015 - error: bluelink.0 (3085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-02-19 20:53:03.016 - error: bluelink.0 (3085) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.018 - error: bluelink.0 (3085) Error: The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.018 - error: bluelink.0 (3085) The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.030 - info: bluelink.0 (3085) Adapter bluelink cleaned up everything...
                                        2025-02-19 20:53:03.038 - info: bluelink.0 (3085) terminating
                                        2025-02-19 20:53:03.039 - warn: bluelink.0 (3085) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2025-02-19 20:53:03.048 - error: bluelink.0 (3085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-02-19 20:53:03.049 - error: bluelink.0 (3085) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.050 - error: bluelink.0 (3085) Error: The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.050 - error: bluelink.0 (3085) The state contains the forbidden properties day, time!
                                        2025-02-19 20:53:03.542 - info: bluelink.0 (3085) terminating
                                        2025-02-19 20:53:03.551 - warn: bluelink.0 (3085) get state error: Connection is closed.
                                        2025-02-19 20:53:03.563 - error: bluelink.0 (3085) Cannot check object existence of "bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning": DB closed
                                        2025-02-19 20:53:03.569 - warn: bluelink.0 (3085) Could not perform strict object check of state bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.plugType: DB closed
                                        2025-02-19 20:53:03.570 - warn: bluelink.0 (3085) get state error: Connection is closed.
                                        2025-02-19 20:53:03.571 - error: bluelink.0 (3085) Error extract objectKeys: KNAC381AFR5176980.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                                        2025-02-19 20:53:03.572 - error: bluelink.0 (3085) Error: Could not check object existence of bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning: Cannot check object existence of "bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning": DB closed
                                        2025-02-19 20:53:03.688 - error: host.iobrokerMaster instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2025-02-19 20:53:03.689 - info: host.iobrokerMaster Restart adapter system.adapter.bluelink.0 because enabled
                                        2025-02-19 20:53:03.689 - warn: host.iobrokerMaster Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                                        Script v.2025-02-02
                                        *** BASE SYSTEM ***
                                        Hardware Vendor : Synology
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Docker          : v10.0.0
                                        Virtualization  : docker
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         20:37:08 up 147 days,  3:11,  0 user,  load average: 2.27, 5.05, 5.91
                                        CPU threads: 2
                                        *** LIFE CYCLE STATUS ***
                                        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                        *** TIME AND TIMEZONES ***
                                        Wed Feb 19 19:37:09 UTC 2025
                                        Wed Feb 19 20:37:09 CET 2025
                                        CET +0100
                                        Etc/UTC
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        root
                                        HOME=/root
                                        GROUPS=root
                                        iobroker
                                        HOME=/opt/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev
                                        *** DISPLAY-SERVER SETUP ***
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Mem:             10G        7.0G        537M        2.2G        5.3G        3.3G
                                        Swap:           8.3G        868M        7.4G
                                        Total:           18G        7.9G        8.0G
                                        Active iob-Instances:   34
                                                 9806 M total memory
                                                 6702 M used memory
                                                 3592 M active memory
                                                 2193 M inactive memory
                                                  511 M free memory
                                                    8 M buffer memory
                                                 5018 M swap cache
                                                 7931 M total swap
                                                  827 M used swap
                                                 7104 M free swap
                                        top - 20:37:09 up 147 days,  3:11,  0 user,  load average: 2.41, 5.03, 5.90
                                        Tasks:  41 total,   2 running,  39 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   9806.5 total,    509.5 free,   6704.0 used,   5027.5 buff/cache
                                        MiB Swap:   7931.9 total,   7104.1 free,    827.9 used.   3102.5 avail Mem
                                        *** DMESG CRITICAL ERRORS ***
                                        1 CRITICAL ERRORS DETECTED!
                                        Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                        *** FILESYSTEM ***
                                        Filesystem     Type   Size  Used Avail Use% Mounted on
                                        /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /
                                        tmpfs          tmpfs   64M     0   64M   0% /dev
                                        tmpfs          tmpfs  4.8G     0  4.8G   0% /sys/fs/cgroup
                                        /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /opt/iobroker
                                        /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /etc/hosts
                                        shm            tmpfs   64M     0   64M   0% /dev/shm
                                        tmpfs          tmpfs  4.8G     0  4.8G   0% /proc/acpi
                                        tmpfs          tmpfs  4.8G     0  4.8G   0% /proc/scsi
                                        tmpfs          tmpfs  4.8G     0  4.8G   0% /sys/firmware
                                        [Wed Sep 25 18:26:53 2024] EXT4-fs (md0): barriers disabled
                                        [Wed Sep 25 18:26:53 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
                                        [Wed Sep 25 18:26:55 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
                                        [Wed Sep 25 18:26:55 2024] EXT4-fs (md0): re-mounted. Opts: (null)
                                        [Wed Sep 25 18:27:58 2024] EXT4-fs (sdq1): barriers disabled
                                        [Wed Sep 25 18:27:59 2024] EXT4-fs (sdq1): recovery complete
                                        [Wed Sep 25 18:27:59 2024] EXT4-fs (sdq1): mounted filesystem with ordered data mode. Opts: nodelalloc,synoacl,data=ordered
                                        Show mounted filesystems:
                                        TARGET             SOURCE        FSTYPE OPTIONS
                                        /                  /dev/vg1000/lv[/@syno/@docker/btrfs/subvolumes/81b1a4500d67ee19fc85084d0a4b18e9fc4d636a867707593d6b88ac22298438]       btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=2870,subvol=/@syno/@docker/btrfs/subvolumes/81b1a4500d67ee19fc85084d0a4b18e9fc4d636a867707593d6b88ac22298438
                                        |-/opt/iobroker    /dev/vg1000/lv[/@syno/docker/iobroker_data]        btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=919,subvol=/@syno/docker/iobroker_data
                                        |-/etc/resolv.conf /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/resolv.conf] btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/resolv.conf
                                        |-/etc/hostname    /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hostname]    btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hostname
                                        `-/etc/hosts       /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hosts]       btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hosts
                                        /var:
                                        16M     /var/
                                        14M     /var/lib
                                        13M     /var/lib/dpkg/info
                                        13M     /var/lib/dpkg
                                        1.9M    /var/cache
                                        /opt/iobroker/backups:
                                        45M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        1016M   /opt/iobroker/iobroker-data/
                                        780M    /opt/iobroker/iobroker-data/files
                                        616M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        21M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                        9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Installed: 20.18.2-1nodesource1
                                          Candidate: 20.18.2-1nodesource1
                                          Version table:
                                         *** 20.18.2-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobrokerMaster      iobrokerMaster (version: 6.0.11, hostname: iobrokerMaster, alive, uptime: 568)
                                        iobrokerslave       iobrokerslave (version: 6.0.11, hostname: iobrokerslave , alive, uptime: 534)
                                        Core adapters versions
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobrokerMaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : iobrokerMaster                           -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobrokerMaster                           -  enabled
                                        + system.adapter.ble.0                    : ble                   : iobrokerslave                            -  enabled
                                        + system.adapter.bluelink.0               : bluelink              : iobrokerMaster                           -  enabled
                                        + system.adapter.bmw.0                    : bmw                   : iobrokerMaster                           -  enabled
                                        + system.adapter.chromecast.0             : chromecast            : iobrokerMaster                           -  enabled
                                        + system.adapter.deconz.0                 : deconz                : iobrokerMaster                           -  enabled, port: 8088
                                        + system.adapter.denon.0                  : denon                 : iobrokerMaster                           -  enabled
                                        + system.adapter.device-reminder.0        : device-reminder       : iobrokerMaster                           -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobrokerMaster                           -  enabled
                                        + system.adapter.fritzbox.0               : fritzbox              : iobrokerMaster                           -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : iobrokerMaster                           -  enabled
                                        + system.adapter.growatt.0                : growatt               : iobrokerMaster                           -  enabled
                                        + system.adapter.ham.0                    : ham                   : iobrokerMaster                           -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : iobrokerMaster                           -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
                                        + system.adapter.hm-rpc.2                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
                                          system.adapter.ical.0                   : ical                  : iobrokerMaster                           -  enabled
                                          system.adapter.influxdb.0               : influxdb              : iobrokerMaster                           - disabled, port: 8086
                                        + system.adapter.javascript.0             : javascript            : iobrokerMaster                           -  enabled
                                        + system.adapter.node-red.0               : node-red              : iobrokerMaster                           -  enabled, port: 1880, bind: 0.0.0.0
                                        + system.adapter.ocpp.1                   : ocpp                  : iobrokerMaster                           -  enabled, port: 9022
                                        + system.adapter.pi-hole.0                : pi-hole               : iobrokerMaster                           -  enabled
                                        + system.adapter.sayit.0                  : sayit                 : iobrokerMaster                           -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobrokerMaster                           -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.simple-api.0             : simple-api            : iobrokerMaster                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.sonoff.0                 : sonoff                : iobrokerMaster                           -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.sonos.0                  : sonos                 : iobrokerMaster                           -  enabled
                                        + system.adapter.sql.0                    : sql                   : iobrokerMaster                           -  enabled, port: 3306
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerMaster                           -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : iobrokerMaster                           -  enabled
                                        + system.adapter.tradfri.0                : tradfri               : iobrokerMaster                           -  enabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : iobrokerMaster                           - disabled
                                        + system.adapter.web.0                    : web                   : iobrokerMaster                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        │ (index) │ name               │ url                                                     │ auto upgrade │
                                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                        Active repo(s): Beta (latest)
                                        Installed ioBroker-Instances
                                        Used repository: Beta (latest)
                                        Adapter    "admin"        : 7.4.21   , installed 7.1.5  [Updatable]
                                        Adapter    "alexa2"       : 3.26.7   , installed 3.25.5 [Updatable]
                                        Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
                                        Adapter    "ble"          : 0.14.1   , installed 0.14.0 [Updatable]
                                        Adapter    "bluelink"     : 3.1.1    , installed 3.1.0  [Updatable]
                                        Adapter    "bmw"          : 2.9.3    , installed 2.9.3
                                        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                                        Adapter    "deconz"       : 1.6.4    , installed 1.4.1  [Updatable]
                                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                                        Adapter    "fritzdect"    : 2.5.13   , installed 2.5.11 [Updatable]
                                        Adapter    "growatt"      : 3.3.1    , installed 3.3.1
                                        Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                        Adapter    "ical"         : 1.16.1   , installed 1.15.0 [Updatable]
                                        Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
                                        Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
                                        Adapter    "node-red"     : 6.0.5    , installed 5.2.1  [Updatable]
                                        Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                        Adapter    "shelly"       : 9.0.0    , installed 8.2.1  [Updatable]
                                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                        Adapter    "socketio"     : 7.0.1    , installed 6.7.1  [Updatable]
                                        Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
                                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                        Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                        Adapter    "web"          : 6.3.1    , installed 6.2.5  [Updatable]
                                        Adapter    "ws"           : 3.0.5    , installed 2.6.2  [Updatable]
                                        Objects and States
                                        Objects:        14029
                                        States:         11607
                                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 4
                                        *** Listening Ports ***
                                        tcp        0      0 10.0.3.22:2001          0.0.0.0:*               LISTEN      1000       1501233678 -
                                        tcp        0      0 127.0.0.11:44114        0.0.0.0:*               LISTEN      0          1501197598 -
                                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1501225397 -
                                        tcp        0      0 10.0.3.22:2010          0.0.0.0:*               LISTEN      1000       1501229505 -
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1501230419 -
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1501209631 -
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1501209333 -
                                        tcp        0      0 10.0.3.22:9292          0.0.0.0:*               LISTEN      1000       1501234686 -
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1501210119 -
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1501237860 -
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1501234010 -
                                        tcp6       0      0 :::9022                 :::*                    LISTEN      1000       1501236578 -
                                        tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1501233265 -
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1501217435 -
                                        udp        0      0 0.0.0.0:43135           0.0.0.0:*                           1000       1501234123 -
                                        udp        0      0 127.0.0.11:44075        0.0.0.0:*                           0          1501197597 -
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1501233862 -
                                        udp        0      0 10.0.3.22:5353          0.0.0.0:*                           1000       1501232924 -
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1501239355 -
                                        2025-02-19 20:33:27.020  - info: alexa2.0 (972) Initialization Done ...
                                        2025-02-19 20:33:32.386  - info: alexa2.0 (972) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2025-02-19 20:37:27.607  - info: host.iobrokerMaster stopInstance system.adapter.bmw.0 (force=false, process=true)
                                        2025-02-19 20:37:27.612  - info: bmw.0 (581) Got terminate signal TERMINATE_YOURSELF
                                        2025-02-19 20:37:27.615  - info: bmw.0 (581) terminating
                                        2025-02-19 20:37:27.629  - info: bmw.0 (581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-02-19 20:37:27.650  - info: host.iobrokerMaster stopInstance system.adapter.bmw.0 send kill signal
                                        2025-02-19 20:37:28.130  - info: bmw.0 (581) terminating
                                        2025-02-19 20:37:28.568  - info: host.iobrokerMaster instance system.adapter.bmw.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-02-19 20:37:32.669  - info: host.iobrokerMaster instance system.adapter.bmw.0 in version "2.9.3" started with pid 1574
                                        2025-02-19 20:37:40.602  - info: bmw.0 (1574) starting. Version 2.9.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.18.2, js-controller: 6.0.11
                                        2025-02-19 20:37:40.659  - info: bmw.0 (1574) Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                                        2025-02-19 20:37:40.907  - info: bmw.0 (1574) Start getting bmw vehicles
                                        2025-02-19 20:37:41.265  - info: bmw.0 (1574) Found 3 bmw vehicles
                                        2025-02-19 20:37:51.598  - info: bmw.0 (1574) Initial first update of the vehicles
                                        2025-02-19 20:38:40.138  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
                                        2025-02-19 20:38:40.140  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                        2025-02-19 20:38:40.140  - info: alexa2.0 (972)     Device-type:A3M81UGFDWTUWE - Benjamin's Magenta Mini (Magenta Mini) (TIMERS_AND_ALARMS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MULTI_WAKEWORDS_SUPPORTED,EQUALIZER_CONTROLLER_MIDRANGE,SIRIUSXM,SET_TIME_ZONE,SLEEP,EQUALIZER_CONTROLLER_TREBLE,EARCONS,SUPPORTS_LOCALE,CUSTOM_ALARM_TONE,AUDIBLE,MUSIC_SKILL,TIDAL,SPEECH_RECOGNIZER_USS,ADAPTIVE_LISTENING,AUDIO_CONTROLS,DEEZER,PERSISTENT_CONNECTION,SET_LOCALE,APPLE_MUSIC,REMINDERS,VOLUME_SETTING,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,EQUALIZER_CONTROLLER_BASS,AMAZON_MUSIC,GOLDFISH,DREAM_TRAINING,ASCENDING_ALARM_VOLUME,MICROPHONE,KINDLE_BOOKS,AUDIO_PLAYER,CHANGE_NAME,I_HEART_RADIO,SOUND_SETTINGS,DEREGISTER_DEVICE,TUNE_IN,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,FAR_FIELD)
                                        2025-02-19 20:38:40.594  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
                                        2025-02-19 20:38:40.594  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                        2025-02-19 20:38:40.595  - info: alexa2.0 (972)     Device-type:A3BW5ZVFHRCQPO - Benjamin's BMW Group – Amazon Alexa Car Integration (BMW Group – Amazon Alexa Car Integration) (TIMERS_AND_ALARMS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,SLEEP,AUDIBLE,MUSIC_SKILL,TIDAL,ADAPTIVE_LISTENING,DEEZER,PERSISTENT_CONNECTION,APPLE_MUSIC,REMINDERS,VOLUME_SETTING,AMAZON_MUSIC,GOLDFISH,DREAM_TRAINING,MICROPHONE,HANDS_FREE,PEONY,KINDLE_BOOKS,AUDIO_PLAYER,CHANGE_NAME,I_HEART_RADIO,DEREGISTER_DEVICE,TUNE_IN)
                                        2025-02-19 20:38:40.897  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
                                        2025-02-19 20:38:40.897  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                        2025-02-19 20:38:40.897  - info: alexa2.0 (972)     Device-type:A1Q6UGEXJZWJQ0 - Benjamin's 2nd Fire TV (SHARKNADO,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,FLASH_BRIEFING,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,REMINDERS,MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,EARCONS,SUPPORTS_LOCALE,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,MICROPHONE,CHANGE_NAME,SOUND_SETTINGS,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,SPEECH_RECOGNIZER_USS,ADAPTIVE_LISTENING,ACTIVE_AFTER_FRO,ARTHUR_TARGET)
                                        2025-02-19 20:38:54.895  - info: bmw.0 (1574) First update of Trips and Demands in 10 minutes
                                          @baeckerman83 installier nochmal bitte
                                          da sollte jetzt ein warning kommen.. den mal posten bitte
                                            @baeckerman83
                                            und mach bitte die iobroker updates.. das ist ja n Sack voll... js-controller v6.x
                                            auf beiden, du hast ja Master/Slave..
                                            2314
                                            863783
