    4. Test Adapter Fronius 2.0.x
      piForscher @Thomas Braun last edited by
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: kallicube
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.4.0-186-generic
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU  N3160  @ 1.60GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:54:50 up  5:35,  2 users,  load average: 0.89, 1.09, 1.12
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2024-06-21 18:54:50 CEST
                 Universal time: Fri 2024-06-21 16:54:50 UTC
                       RTC time: Fri 2024-06-21 16:54:50
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      kalle
      HOME=/home/kalle
      GROUPS=kalle adm cdrom sudo audio dip plugdev lxd iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        2.7G        757M        0.0K        305M        820M
      Swap:          3.8G        1.4G        2.4G
      Total:         7.6G        4.1G        3.2G
      Active iob-Instances:   18
               3773 M total memory
               2711 M used memory
               2013 M active memory
                708 M inactive memory
                757 M free memory
                 46 M buffer memory
                258 M swap cache
               3798 M total swap
               1373 M used swap
               2425 M free swap
      top - 18:54:51 up  5:35,  2 users,  load average: 0.89, 1.09, 1.12
      Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 10.7 us,  4.0 sy,  0.0 ni, 85.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3774.0 total,    756.9 free,   2711.7 used,    305.4 buff/cache
      MiB Swap:   3799.0 total,   2426.0 free,   1373.0 used.    820.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                        LOAD   ACTIVE SUB    DESCRIPTION
      * influxdb.service            loaded failed failed InfluxDB is an open-source, distributed, time series database
      * snap.docker.dockerd.service loaded failed failed Service for snap application docker.dockerd
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                      Type      Size  Used Avail Use% Mounted on
      udev                            devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs                           tmpfs     378M  1.4M  377M   1% /run
      /dev/sdb2                       ext4       29G   23G  4.3G  85% /
      tmpfs                           tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs                           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      tmpfs                           tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/sdb1                       vfat      511M  6.1M  505M   2% /boot/efi
      /dev/loop0                      squashfs  106M  106M     0 100% /snap/core/16574
      /dev/loop2                      squashfs   56M   56M     0 100% /snap/core18/2812
      /dev/loop3                      squashfs   64M   64M     0 100% /snap/core20/2264
      /dev/loop5                      squashfs   56M   56M     0 100% /snap/core18/2823
      /dev/loop4                      squashfs   75M   75M     0 100% /snap/core22/1122
      /dev/loop1                      squashfs  104M  104M     0 100% /snap/core/16928
      /dev/loop6                      squashfs   64M   64M     0 100% /snap/core20/2318
      /dev/loop7                      squashfs   75M   75M     0 100% /snap/core22/1380
      /dev/loop8                      squashfs  129M  129M     0 100% /snap/docker/2904
      /dev/loop9                      squashfs   37M   37M     0 100% /snap/heroku/4092
      /dev/loop10                     squashfs  131M  131M     0 100% /snap/docker/2915
      /dev/loop11                     squashfs   39M   39M     0 100% /snap/postgresql10/47
      /dev/loop12                     squashfs   37M   37M     0 100% /snap/heroku/4087
      /dev/loop13                     squashfs   92M   92M     0 100% /snap/lxd/24061
      192.168.178.42:/volume1/Diashow nfs4      2.7T  1.6T  1.2T  58% /opt/iobroker/iobroker-data/files/vis/img/bilder_nas
      tmpfs                           tmpfs     378M     0  378M   0% /run/user/1000
      [Fri Jun 21 13:19:42 2024] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Jun 21 13:19:43 2024] EXT4-fs (sdb2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                                 SOURCE                          FSTYPE      OPTIONS
      /                                                      /dev/sdb2                       ext4        rw,relatime
      |-/sys                                                 sysfs                           sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                               securityfs                      securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                     tmpfs                           tmpfs       ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified                           cgroup2                         cgroup2     rw,nosuid,nodev,noexec,relatime
      | | |-/sys/fs/cgroup/systemd                           cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/cpu,cpuacct                       cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/cpuset                            cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/pids                              cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/blkio                             cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/freezer                           cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/devices                           cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,devices
      | | |-/sys/fs/cgroup/hugetlb                           cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
      | | |-/sys/fs/cgroup/perf_event                        cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/net_cls,net_prio                  cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/memory                            cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,memory
      | | `-/sys/fs/cgroup/rdma                              cgroup                          cgroup      rw,nosuid,nodev,noexec,relatime,rdma
      | |-/sys/fs/pstore                                     pstore                          pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/firmware/efi/efivars                          efivarfs                        efivarfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                        none                            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                  debugfs                         debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                tracefs                         tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                           fusectl                         fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                 configfs                        configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                proc                            proc        rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                           systemd-1                       autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=17334
      |   `-/proc/sys/fs/binfmt_misc                         binfmt_misc                     binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                 udev                            devtmpfs    rw,nosuid,noexec,relatime,size=1885544k,nr_inodes=471386,mode=755
      | |-/dev/pts                                           devpts                          devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                           tmpfs                           tmpfs       rw,nosuid,nodev
      | |-/dev/hugepages                                     hugetlbfs                       hugetlbfs   rw,relatime,pagesize=2M
      | `-/dev/mqueue                                        mqueue                          mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                 tmpfs                           tmpfs       rw,nosuid,nodev,noexec,relatime,size=386456k,mode=755
      | |-/run/lock                                          tmpfs                           tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                                    sunrpc                          rpc_pipefs  rw,relatime
      | |-/run/snapd/ns                                      tmpfs[/snapd/ns]                tmpfs       rw,nosuid,nodev,noexec,relatime,size=386456k,mode=755
      | | |-/run/snapd/ns/lxd.mnt                            nsfs[mnt:[4026532450]]          nsfs        rw
      | | `-/run/snapd/ns/docker.mnt                         nsfs[mnt:[4026532449]]          nsfs        rw
      | `-/run/user/1000                                     tmpfs                           tmpfs       rw,nosuid,nodev,relatime,size=386452k,mode=700,uid=1000,gid=1000
      |-/boot/efi                                            /dev/sdb1                       vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      |-/snap/core/16574                                     /dev/loop0                      squashfs    ro,nodev,relatime
      |-/snap/core18/2812                                    /dev/loop2                      squashfs    ro,nodev,relatime
      |-/snap/core20/2264                                    /dev/loop3                      squashfs    ro,nodev,relatime
      |-/snap/core18/2823                                    /dev/loop5                      squashfs    ro,nodev,relatime
      |-/snap/core22/1122                                    /dev/loop4                      squashfs    ro,nodev,relatime
      |-/snap/core/16928                                     /dev/loop1                      squashfs    ro,nodev,relatime
      |-/snap/core20/2318                                    /dev/loop6                      squashfs    ro,nodev,relatime
      |-/snap/core22/1380                                    /dev/loop7                      squashfs    ro,nodev,relatime
      |-/snap/docker/2904                                    /dev/loop8                      squashfs    ro,nodev,relatime
      |-/snap/heroku/4092                                    /dev/loop9                      squashfs    ro,nodev,relatime
      |-/snap/docker/2915                                    /dev/loop10                     squashfs    ro,nodev,relatime
      |-/snap/postgresql10/47                                /dev/loop11                     squashfs    ro,nodev,relatime
      |-/snap/heroku/4087                                    /dev/loop12                     squashfs    ro,nodev,relatime
      |-/snap/lxd/24061                                      /dev/loop13                     squashfs    ro,nodev,relatime
      |-/var/lib/lxcfs                                       lxcfs                           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/opt/iobroker/iobroker-data/files/vis/img/bilder_nas 192.168.178.42:/volume1/Diashow nfs4        rw,relatime,vers=4.0,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.178.64,local_lock=none,addr=192.168.178.42
      /var:
      3.8G    /var/
      1.9G    /var/lib
      1.8G    /var/log/journal/715d8eb78de6413b8a3b89c9cd36af8d
      1.8G    /var/log
      Archived and active journals take up 1.7G in the file system.
      /opt/iobroker/backups:
      144M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      701M    /opt/iobroker/iobroker-data/backup-objects
      537M    /opt/iobroker/iobroker-data/files
      187M    /opt/iobroker/iobroker-data/files/vis
      146M    /opt/iobroker/iobroker-data/files/vis/img
      75M     /opt/iobroker/iobroker-data/backup-objects/2024-06-21_02-30_states.jsonl.gz
      70M     /opt/iobroker/iobroker-data/states.jsonl
      44M     /opt/iobroker/iobroker-data/objects.jsonl
      44M     /opt/iobroker/iobroker-data/backup-objects/2024-06-19_18-30_states.jsonl.gz
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
           18.20.3-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
       *** 18.20.2-1nodesource1 600
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           10.19.0~dfsg-3ubuntu1.6 500
              500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      nodejs modules from github:     1
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      Adapter State
      + system.adapter.admin.0                  : admin                 : kallicube                                -  enabled, port: 8081, bind: 192.168.178.64, run as: admin
        system.adapter.admin.1                  : admin                 : Pi2                                      - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : kallicube                                -  enabled
        system.adapter.awattar.0                : awattar               : kallicube                                -  enabled
      + system.adapter.backitup.0               : backitup              : kallicube                                -  enabled
        system.adapter.backitup.2               : backitup              : iobroker-pi                              - disabled
        system.adapter.cleveron.0               : cleveron              : kallicube                                - disabled
        system.adapter.daswetter.0              : daswetter             : kallicube                                -  enabled
        system.adapter.discovery.0              : discovery             : kallicube                                - disabled
        system.adapter.energiefluss.0           : energiefluss          : Pi3                                      - disabled
        system.adapter.flot.0                   : flot                  : kallicube                                -  enabled
        system.adapter.followthesun.1           : followthesun          : kallicube                                - disabled
        system.adapter.fritzbox.0               : fritzbox              : Pi3                                      - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : Pi3                                      - disabled
      + system.adapter.g-homa.0                 : g-homa                : kallicube                                -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : kallicube                                - disabled
      + system.adapter.hm-rega.0                : hm-rega               : kallicube                                -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : kallicube                                -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : kallicube                                -  enabled
        system.adapter.ical.1                   : ical                  : kallicube                                -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : kallicube                                -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: kallicube                                -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : kallicube                                -  enabled
        system.adapter.info.0                   : info                  : kallicube                                - disabled
      + system.adapter.javascript.0             : javascript            : kallicube                                -  enabled
        system.adapter.javascript.1             : javascript            : iobroker-pi                              - disabled
        system.adapter.linux-control.0          : linux-control         : Pi2                                      - disabled
        system.adapter.meteoalarm.0             : meteoalarm            : kallicube                                - disabled
        system.adapter.node-red.0               : node-red              : kallicube                                - disabled, port: 1880, bind: 192.168.178.64
        system.adapter.ping.0                   : ping                  : Pi3                                      - disabled
      + system.adapter.pvforecast.0             : pvforecast            : kallicube                                -  enabled
        system.adapter.rpi2.1                   : rpi2                  : Pi3                                      - disabled
      + system.adapter.sayit.0                  : sayit                 : kallicube                                -  enabled
      + system.adapter.shelly.0                 : shelly                : kallicube                                -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.slideshow.0              : slideshow             : iobroker-pi                              - disabled
      + system.adapter.slideshow.1              : slideshow             : kallicube                                -  enabled
        system.adapter.smartmeter.0             : smartmeter            : kallicube                                - disabled
      + system.adapter.sql.0                    : sql                   : kallicube                                -  enabled, port: 3307
      + system.adapter.statistics.0             : statistics            : kallicube                                -  enabled
        system.adapter.telegram.0               : telegram              : kallicube                                - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : Pi2                                      - disabled
      + system.adapter.trashschedule.0          : trashschedule         : kallicube                                -  enabled
        system.adapter.upnp.0                   : upnp                  : Pi2                                      - disabled
      + system.adapter.viessmannapi.0           : viessmannapi          : kallicube                                -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : kallicube                                -  enabled
        system.adapter.vis-bars.0               : vis-bars              : kallicube                                -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : kallicube                                -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : kallicube                                -  enabled
        system.adapter.vis-history.0            : vis-history           : kallicube                                -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : kallicube                                -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : kallicube                                -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : kallicube                                -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : kallicube                                -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : kallicube                                -  enabled
        system.adapter.vis-metro.0              : vis-metro             : kallicube                                -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : kallicube                                -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : kallicube                                -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : kallicube                                -  enabled
        system.adapter.vis-weather.0            : vis-weather           : kallicube                                -  enabled
        system.adapter.vis.0                    : vis                   : kallicube                                -  enabled
      + system.adapter.web.0                    : web                   : kallicube                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : iobroker-pi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : Pi2                                      - disabled
      + system.adapter.ws.0                     : ws                    : kallicube                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.ws.1                     : ws                    : Pi2                                      - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : kallicube                                -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "cleveron"     : 0.1.0    , installed 0.1.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
      Adapter    "discovery"    : 4.5.0    , installed 4.2.0  [Updatable]
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.5.0  [Updatable]
      Adapter    "fronius"      : 2.1.0    , installed 2.1.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
      Adapter    "heatingcontrol": 2.12.8  , installed 2.12.5 [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "javascript"   : 8.3.1    , installed 7.8.0  [Updatable]
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
      Adapter    "node-red"     : 5.2.1    , installed 5.1.0  [Updatable]
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
      Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
      Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.9 [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
      Adapter    "weatherunderground": 3.7.0, installed 3.6.0 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
      Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        34466
      States:         29732
      Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
      Reading package lists...
      Pending Updates: 10
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34866      908/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       237164     11197/io.shelly.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       236884     11011/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       236877     11011/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17773      1/init
      tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1001       237807     11151/io.hm-rpc.0
      tcp        0      0 192.168.178.64:8081     0.0.0.0:*               LISTEN      1001       236225     11090/io.admin.0
      tcp        0      0 0.0.0.0:35347           0.0.0.0:*               LISTEN      0          35032      -
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        29576      797/systemd-resolve
      tcp6       0      0 :::22                   :::*                    LISTEN      0          34868      908/sshd: /usr/sbin
      tcp6       0      0 :::46017                :::*                    LISTEN      0          35033      -
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12015      1/init
      tcp6       0      0 :::50000                :::*                    LISTEN      1001       238839     11257/io.g-homa.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       237152     11204/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       238857     11322/io.ws.0
      udp        0      0 0.0.0.0:55916           0.0.0.0:*                           111        30073      813/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        30071      813/avahi-daemon: r
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        29575      797/systemd-resolve
      udp        0      0 192.168.178.64:68       0.0.0.0:*                           100        28197      794/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12012      1/init
      udp6       0      0 fe80::4ecc:6aff:fe4:546 :::*                                100        29582      794/systemd-network
      udp6       0      0 :::5353                 :::*                                111        30072      813/avahi-daemon: r
      udp6       0      0 :::57129                :::*                                111        30074      813/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          17776      1/init
      2024-06-21 18:41:56.706  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:41:56.712  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:42:57.433  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:42:57.439  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:43:56.653  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:43:56.660  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:44:56.846  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:44:56.853  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:45:56.787  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:45:56.793  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:46:56.852  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:46:56.858  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:47:48.389  - debug: host.kallicube Incoming Host message addNotification
      2024-06-21 18:47:50.535  - debug: host.kallicube Incoming Host message getNotifications
      2024-06-21 18:47:50.569  - debug: host.kallicube Incoming Host message getNotifications
      2024-06-21 18:47:56.699  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:47:56.706  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:48:56.790  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:48:56.799  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:49:56.669  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:49:56.675  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:50:56.845  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.lastSevenDays.value" has to be type "number" but received type "string"
      2024-06-21 18:50:56.852  - info: viessmannapi.0 (11353) State value to set for "viessmannapi.0.2476945.0.features.heating.power.consumption.summary.dhw.properties.currentYear.value" has to be type "string" but received type "number"
      2024-06-21 18:55:03.024  - info: host.kallicube instance system.adapter.yr.0 started with pid 12367
      2024-06-21 18:55:44.250  - info: host.kallicube instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Thomas Braun Most Active @piForscher last edited by
        @piforscher sagte in Test Adapter Fronius 2.0.x:
        Langsam mal upgraden. Die Version ist im Auslauf.
        Du brauchst keine zwei Admins. Lösch den auf dem Pi2.
        (Wie viele hosts laufen denn da durch die Gegend?
        kallicube, Pi2, Pi3, iobroker-pi
        Leben die alle?)
        iob del admin.1
        Dann schmeiß alles raus, was nicht benötigt wird.
        Pending Updates: 10
        System up-to-date bringen. Also Betriebsystem wie den ioBroker.
          @thomas-braun Super, das Löschen von admin.1 hat den Knoten gelöst!
          Jetzt konnte ich den Fronius-Adapter wieder zum Laufen bringen.
          Dafür schonmal vielen Dank!!
          Die anderen Hosts sind von vorigen verzweifelten Versuchen mit abgestürtzten Slave-Images. Wie kann ich die loswerden ?
          Und ich nehme die Ermutigung an, mal ein Ubuntu-Update zu wagen 😉
            Da sind halt die Auswirkungen von so einem strubbeligen Setup...
            Siehst du die denn noch im Admin? Muss man sich vermutlich im Einzelnen anschauen wie die da angebunden sind. Offenbar hängen die ja nur noch in einer Angel...
            Da kommst du eh nicht drum herum.
            • mcm1957
              mcm1957 @Thomas Braun last edited by
              Release 2.1.1 ist ab morgen im LATEST zum Test verfügbar
              zu den Releasenotes:
              https://github.com/iobroker-community-adapters/ioBroker.fronius#211-2024-07-24
              DANKE @nkleber für den Fix betreffend leerer Objekte.
                Martin 5 last edited by
                Hallo, eine kleine Frage.
                Der Fronius-Adapter bezieht die Daten per API-Abfrage als Json-Daten (ist das richtig?). Ich benötige alle 5 Sekunden die aktuell erzeugte und die eingespeiste Leistung.
                Kann ich das Abfrageintervall auf 5 Sekunden stellen oder ist es effizienter die zwei Werte direkt per ModbusTCP abzufragen?
                Grüße Martin
                • mcm1957
                  mcm1957 @Martin 5 last edited by
                  @martin-5
                  Wenn du schon Zugriff via modbus hast, würde ich diesen Weg vorziehen da
                  • er lokal ist
                  • zumindest mir nicht bekannt ist wie oft der Inverter die Daten in der Cloud überhaupt aktualisiert
                  • ob Fronius eine so häufige Datenabfrage gerne sieht oder überhaupt zulässt und dann ggF mit Sperrmaßnahmen reagiert.
                    legro @mcm1957 last edited by legro
                    @mcm1957
                    Ich dachte, dass der http-Request ebenfalls lokal vom Wechselrichter beantwortet wird. Liege ich damit (voll) daneben? Jedenfalls enthält doch die API des Wechselrichters eine derartige Möglichkeit.
                    • mcm1957
                      mcm1957 @legro last edited by
                      @legro said in Test Adapter Fronius 2.0.x:
                      @mcm1957
                      Du hast vollkommen recht. Ich hatt das anders im Kopf.
                      Der Adapter benutzt das lokale Api.
                      In diesem Fall sollten häufige Zugriffe kein Problem sein. Ob in diesem Fall modbus oder http das System mehr belasten kann ich leider nicht sagen.
                        topsurfer @mcm1957 last edited by
                        hab den Fronius-Adapter auch installiert, bekomme auch wohl alle Daten.
                        Danke für den Adapter, hat auf Anhieb funktioniert!
                        In der App sieht man ja auch "Stromerzeugung heute", "Verbrauch heute" und auch den Autarkiegrad.
                        In den Datenpunkten (sind ja ca. 100) sehe ich diese Werte so nicht, ist das korrekt?
                        Muss ich diese Werte selbst errechnen, wenn ja, welche DP nehmt ihr da?
                        jmeister79 Negalein 2 Replies Last reply Reply Quote 0
                        • jmeister79
                          jmeister79 @topsurfer last edited by
                          @topsurfer
                          das muss man sich natürlich selber errechnen.
                          Gibt es adapter für die das automatisch machen oder du bastelst dir n script.
                          Ist recht simpel.
                          • Negalein
                            Negalein Global Moderator @topsurfer last edited by
                            @topsurfer sagte in Test Adapter Fronius 2.0.x:
                            das kann glaube ich der fronius-solarweb Adapter
                              legro @Negalein last edited by
                              @negalein @topsurfer
                              All dies habe ich in unserer Visualisierung selbst umgesetzt. Meine Absicht: Ich möchte ausschließlich die echten Werte auf der Wechselstromseite haben, denn nur diese finden sich nachher auch in unserem Portemonnaie wieder.🙂
                              Wer wissen will, wie wir‘s gelöst haben, findet in diesem Thread die Dokumentation.
                                Man kann den PV Ertrag auch selbst mit einem Script aus den Stringleistungen integrieren.
                                Datenpunkte:
                                fronius.0.site.P_PV
                                fronius.0.inverter.1.PDC
                                fronius.0.inverter.1.PDC_2
                                  klassisch Most Active @legro last edited by
                                  @legro sagte in Test Adapter Fronius 2.0.x:
                                  Wenn es ums Geld geht, ist der Smartmeter-Adapter, der die Daten aus dem offiziellen Zähler ausliest, hilreich. Ersatzweise die Energiewerte des Fronius-Smartmeters.
                                  Mittlerweile muß man die PV Leistung nicht mehr durch U*I ermiteln. Die PV Leistungen gibt es jetzt direkt in der Struktur site
                                    topsurfer @jmeister79 last edited by
                                    @jmeister79 said in Test Adapter Fronius 2.0.x:
                                    Dachte, weil es in Tasmota diese Aktuell- und Tageswerte auch automatisch gibt bzw. angeboten werden.
                                    Welche "Adapter" sind das, die diese Werte anbieten?
                                    Zusätzlich oder als komplette alternative zum Fronius 2.0 Adapter?
                                    jmeister79 1 Reply Last reply Reply Quote 0
                                    • jmeister79
                                      @topsurfer
                                      VirtualPowermeter zB.
                                      Wenn du das Fronius Smartmeter hast ist es relativ simpel:
                                      Das soltlest Du im Fronius adapter unter Site sehen.
                                      Dann kannst Du dir den Energiezähler in einen eigenen Datenpunkt ziehen und bei änderung aufaddieren oder direkt erfassen.
                                      Dann brauchst du noch n Trigger, der Täglich (bzw wie bei mir stündlich, wöchentlich etc.) die werte abspeichert und in eine etnsprechende variable schreibt, die kannst du dann via History in eine db speichern.
                                      So erfasse ich zb. Tages,Wochen, Moants, Jahreswerte für PV, Wallbox, Verbraucher, Pumpen, Gas, einspeisung etc.
                                      Nils
                                      auf Wunsch kann ich dir das Programm geben, aber ich bitte um verständnis, dass ich hier ugnerne support leiste, da ich es für mich geschrieben habe und ggf. Deine Config nicht passt, ich hab es aber gut Dokumentiert, da ich quellcode abends direkt vergesse wenn ich ins Bett gehe 😄
                                        Alex4 @jmeister79 last edited by Alex4
                                        Gibt es beim Adapter eine Möglichkeit Zeitabhängige Batteriesteuerung (sregeln) zu erstellen bzw. zu löschen?
                                        Meine Idee wäre, die Prognose für die nächten Tage anzuschauen und wenn diese wieder eine volle Batterie ergibt, ich eine Zeit x bei meinem 4 Fronius eine minimale Batterieentladung festlege.
                                        Damit kann ich in die Energiegemeinschaft einspeisen und falls diese den Strom nicht brauchen zum möglichst höchsten Strompreis verkaufen.
                                        Damit verhindere ich außerdem, dass bei einem minus Strompreis, ich fürs Einspeisen am nächsten Tag drauf zahle.
                                        Hat das jemand schon mit dem Fronius Adapter gemacht?
                                        Dabei müsste man bei erfüllten Bedingungen zb. folgende Regel im Gen24 erstellen bzw ändert die Zeiten nach dem dynamischen Stromtarifen (da wird die Leitung im Netz auch gebraucht):
                                        Wird die Bedingung nicht erfüllt, löscht man alle vorhandenen Regeln raus oder stellt sie auf inaktiv.
                                        Bei mehreren Gen24 muss man das natürlich auf allen gleich konfigurieren, sonst entlädt man eine Batterie und lädt damit die anderen.
                                        Die aktuellen Strompreise gibts über den Power Grid (APG) Info (AT+DE+CH) Adapter
                                        Für den Forcast der Sonnenstunden bzw. des zu erwartenden Ertrags hab ich noch nichts gefunden.
                                        nkleber 1 Reply Last reply Reply Quote 0
                                        • nkleber
                                          nkleber @Alex4 last edited by nkleber
                                          @alex4 Mit dem Fronius Adapter ist das nicht möglich da die API nur ein lesen der Daten zulässt. Du kannst das aber natürlich mit dem Modbus Adapter machen. Ob dort direkt die Zeitabhänige Batteriesteuerung angepasst werden kann oder ob das Script direkt auf die Batterie Ladung/Entladung eingreifen muss, kann ich dir so nicht sagen. Die direkte Batteriesteuerung für Laden/Entladen geht aber auf jeden fall mit den Modbus adapter und Scripts...
                                          Siehe https://forum.iobroker.net/topic/65047/fronius-symo-gen24-minsoc-einstellen wo ein ähnliches Thema diskutiert wurde
                                            Alex4 @nkleber last edited by Alex4
                                            @nkleber Das Problem ist, dass ich zb. mit einer gewissen Leistung entladen will und wenn man von der Batterie eine Zwangsladung veranlasst, macht das der Gen24 mit 500Watt. Ich muss hier die Leistung mitgeben können. Das hätte ich beim Modbus nicht gefunden bis dato.
                                            Was ich rausgefunden habe ist, dass man die Requests den Webinterfaces vielleicht benutzen kann:
                                            http post http://xxx.xxx.xxx.xxx/config/timeofuse
                                            Content: {"timeofuse":[{"Active":true,"Power":3000,"ScheduleType":"DISCHARGE_MIN","TimeTable":{"Start":"20:00","End":"21:00"},"Weekdays":{"Mon":true,"Tue":true,"Wed":true,"Thu":true,"Fri":true,"Sat":true,"Sun":true}}]}
                                            result:
                                            	"errors" : [],
                                            	"permissionFailure" : [],
                                            	"unknownNodes" : [],
                                            	"validationErrors" : [],
                                            	"writeFailure" : [],
                                            	"writeSuccess" :
                                            		"timeofuse"
                                            Löschen geht dann:
                                            Content:
                                            {"timeofuse":[]}
                                            result:
                                            	"errors" : [],
                                            	"writeSuccess" :
                                            		"timeofuse"
                                            Um die Werte abzufragen gibts folgendes http get http://10.10.13.211/config/timeofuse, dort kommt dann das array zurück, sofern die authentifzierung passt.
                                            Die Authentifzierung wird im Header unter
                                            authorization: Digest username="technician", realm="Webinterface area", nonce="xxxxxxxxxxx", uri="/config/timeofuse", response="xxxxxxxxxxx", qop=auth, nc=00000042, cnonce="xxxxxxxxxxx"
                                            Die Werte response und cnonce ändern sich bei jedem request dabei, der Wert nonce bleibt für einige Zeit gleich. Der Wert nc wird hochgezählt bei jeder Abfrage, sobald dieser bei mir gerade 61 erreicht hat, wird der counter resettet und gebinnt wieder bei 01 und nonce hat einen neuen tokken oder hash.
                                            im main.js am gen24 findet man auch die authentication berechnung.
                                                           key: "digestAuthHeader",
                                                            value: function(p, g, w, b) {
        for (var B = !(arguments.length > 4 && void 0 !== arguments[4]) || arguments[4], y = w.split(","), T = {}, L = 0; L < y.length; L++) {
        var S = y[L].match(this.AUTH_KEY_VALUE_RE);
        S && (T[S[1]] = S[2].replace(/["']/g, ""))
        if (!T.realm || !T.nonce)
        return "";
        var k = T.qop || ""
        , R = _.splitCredentials(b)
        , Y = String(++this.NC);
        Y = this.NC_PAD.substring(Y.length) + Y;
        var U = this.randomBytes(8).join("")
        , X = B ? o.V8.hashStr(R.username + ":" + T.realm + ":" + R.password) : R.password
        , z = o.V8.hashStr(p.toUpperCase() + ":" + g)
        , H = X + ":" + T.nonce;
        k && (H += ":" + Y + ":" + U + ":" + (k = k.split(",")[0]));
        var se = o.V8.hashStr(H += ":" + z)
        , te = 'Digest username="' + R.username + '", realm="' + T.realm + '", nonce="' + T.nonce + '", uri="' + g + '", response="' + se + '"';
        return T.opaque && (te += ', opaque="' + T.opaque + '"'),
        k && (te += ", qop=" + k + ", nc=" + Y + ', cnonce="' + U + '"'),
        te
                                            Die funktion calcHash(User, realm, password)
                                                     key: "calcHash",
                                                            value: function(p, g, w) {
        return o.V8.hashStr(p + ":" + g + ":" + w)
                                                          key: "hashStr",
                                                            value: function(s) {
        var p = arguments.length > 1 && void 0 !== arguments[1] && arguments[1];
        return this.onePassHasher.start().appendStr(s).end(p)
                                            Wenn ich den Code richtig verstehe, wird in der respone der Username, realm und das Passwort per hash übertragen. Mittels einen ,,onePassHasher", dieser dürfte aus diesem Github Projekt stammen: https://github.com/cotag/ts-md5/tree/master/src
                                            ste_glei nkleber 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            164
                                            15447
