    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Shelly Dimmer 3
    Shelly Dimmer 3
      Fortune95 @mickym last edited by
      @mickym
      Ja, ok macht auch Sinn. Würde die andere Variante denn auch funktionieren?
              "id": "9520830343183a7b",
              "type": "mqtt out",
              "z": "c42a8af9409498b7",
              "name": "",
              "topic": "shellydimmerg3-e4b3233bd910/rpc",
              "qos": "",
              "retain": "",
              "respTopic": "",
              "contentType": "",
              "userProps": "",
              "correl": "",
              "expiry": "",
              "broker": "fa5ea2376fbca76f",
              "x": 1220,
              "y": 160,
              "wires": []
              "id": "984d6edb0bbf92f8",
              "type": "inject",
              "name": "Turn On",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "{\"method\":\"Light.Set\",\"params\":{\"id\":0,\"brightness\":100,\"on\":true}}",
              "payloadType": "json",
              "x": 660,
              "y": 200,
              "wires": [
                      "9520830343183a7b"
              "id": "145b5aed5c8b3c82",
              "type": "inject",
              "name": "Turn Off",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "{\"method\":\"Light.Set\",\"params\":{\"id\":0,\"brightness\":100,\"on\":false}}",
              "x": 660,
              "y": 240,
              "wires": [
                      "9520830343183a7b"
              "id": "aa6f2ad025c0fe01",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "{\t    \"method\": \"Light.Set\",\t    \"params\": {\t        \"id\": 0,\t        \"brightness\": msg.brightness,\t        \"on\": msg.on\t    }\t}",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 650,
              "y": 140,
              "wires": [
                      "9520830343183a7b",
                      "8f181f3c9f097ee4"
              "id": "fbe0bef3fe942771",
              "type": "ui_slider",
              "name": "",
              "label": "slider-Test",
              "tooltip": "",
              "group": "83ef0ec331014e99",
              "order": 0,
              "width": 0,
              "height": 0,
              "passthru": true,
              "outs": "all",
              "topic": "brightnes",
              "topicType": "msg",
              "min": 0,
              "max": "100",
              "step": 1,
              "className": "",
              "x": 310,
              "y": 160,
              "wires": [
                      "aa6f2ad025c0fe01"
              "id": "8f181f3c9f097ee4",
              "type": "debug",
              "name": "debug 5",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "statusType": "auto",
              "x": 1140,
              "y": 100,
              "wires": []
              "id": "c3d65c893c712b8d",
              "type": "ui_switch",
              "name": "",
              "label": "switch",
              "tooltip": "",
              "order": 2,
              "width": 0,
              "height": 0,
              "passthru": true,
              "decouple": "false",
              "topic": "on",
              "topicType": "msg",
              "style": "",
              "onvalue": "true",
              "onvalueType": "bool",
              "onicon": "",
              "oncolor": "",
              "offvalue": "false",
              "offvalueType": "bool",
              "officon": "",
              "offcolor": "",
              "animate": false,
              "className": "",
              "x": 310,
              "y": 100,
              "wires": [
                      "aa6f2ad025c0fe01",
                      "9fd710ddbcfe1e87"
              "id": "9fd710ddbcfe1e87",
              "type": "debug",
              "name": "debug 6",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 620,
              "y": 80,
              "wires": []
              "id": "fa5ea2376fbca76f",
              "type": "mqtt-broker",
              "name": "",
              "broker": "192.168.12.219",
              "port": 1883,
              "clientid": "",
              "autoConnect": true,
              "usetls": false,
              "protocolVersion": 4,
              "keepalive": 60,
              "cleansession": true,
              "autoUnsubscribe": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthRetain": "false",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closeRetain": "false",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willRetain": "false",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
              "id": "83ef0ec331014e99",
              "type": "ui_group",
              "name": "Standard",
              "tab": "a4b9375e3589475e",
              "order": 1,
              "disp": true,
              "width": 6,
              "collapse": false,
              "className": ""
              "id": "a4b9375e3589475e",
              "type": "ui_tab",
              "name": "Home",
              "icon": "dashboard",
              "disabled": false,
              "hidden": false
        Fortune95 @Fortune95 last edited by
        @mickym
        Der Jeweilige payload wird für das Objekt "brightness" oder "on" gesetzt?
        • mickym
          mickym Most Active @Fortune95 last edited by mickym
          @fortune95 sagte in Shelly Dimmer 3:
          @mickym
          In meinem Flow schon - bei Dir hast Du aber ein Verständnisfehler. Am Besten du lässt Dir mal das ganze Nachrichtenobjekt ausgeben in debug 6.
          Da siehst Du dass weder einen Eigenschaft on noch brightness in Deinem Nachrichtenobjekt sind, das liegt daran, dass Du in Deinen Dashboard Nodes das topic auf eine EINGEHENDE Nachrichteneigenschaft setzt die es aber nicht gibt.
          In Deiner switch Node setzt du das topic auf
          eine eingehende Nachricht mit msg.topic - es kommt aber gar keine Nachricht in die Switch Node. Deswegen ist das topic nicht definiert.
          Wenn Du hingegen das topic als String erst NEU in der switch/slider Node definierst, dann sieht die Nachricht schon anders aus.
          in diesem Fall sieht dann das Nachrichtenobjekt schon anders aus:
          Nun kannst Du die Nachrichten in einem Objekt verwenden:
              "method": "Light.Set",
              "params": {
                  "id": 0,
                  topic: payload
          Somit ist das topic variabel. Beides zu setzen macht so erst mal keinen Sinn, da immer eine Nachricht entweder kein topic brightness oder on enthält.
          Wenn müsstest Du wenn Du beides auf einmal setzen willst, macht aber mE keinen Sinn, über eine JOIN Node das ganze in ein Objekt zusammenfassen. Also beide Eigenschaft wie bei Deinem turn off mit einer brightness von 100% und off macht keinen Sinn.
          Hier die überarbeitete Fassung Deines Flows:
                 "type": "mqtt out",
                 "z": "7e6af0015415146d",
                 "d": true,
                 "name": "",
                 "qos": "",
                 "retain": "",
                 "respTopic": "",
                 "contentType": "",
                 "userProps": "",
                 "correl": "",
                 "expiry": "",
                 "x": 1100,
                 "y": 7420,
                 "wires": []
                 "type": "inject",
                 "name": "Turn On",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 540,
                 "y": 7460,
                 "wires": [
                         "9520830343183a7b"
                 "type": "inject",
                 "name": "Turn Off",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 540,
                 "y": 7500,
                 "wires": [
                         "9520830343183a7b"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "{\t    \"method\": \"Light.Set\",\t    \"params\": {\t        \"id\": 0,\t        topic: payload\t    }\t}",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 530,
                 "y": 7400,
                 "wires": [
                         "9520830343183a7b",
                         "8f181f3c9f097ee4"
                 "name": "",
                 "tooltip": "",
                 "order": 0,
                 "width": 0,
                 "height": 0,
                 "passthru": true,
                 "outs": "all",
                 "topic": "brightness",
                 "topicType": "str",
                 "min": 0,
                 "max": "100",
                 "step": 1,
                 "className": "",
                 "x": 190,
                 "y": 7420,
                 "wires": [
                         "aa6f2ad025c0fe01"
                 "type": "debug",
                 "name": "debug 5",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1020,
                 "y": 7360,
                 "wires": []
                 "name": "",
                 "label": "switch",
                 "tooltip": "",
                 "order": 2,
                 "width": 0,
                 "height": 0,
                 "passthru": true,
                 "topic": "on",
                 "topicType": "str",
                 "style": "",
                 "onvalue": "true",
                 "onicon": "",
                 "oncolor": "",
                 "officon": "",
                 "offcolor": "",
                 "animate": false,
                 "className": "",
                 "x": 190,
                 "y": 7360,
                 "wires": [
                         "aa6f2ad025c0fe01",
                         "9fd710ddbcfe1e87"
                 "type": "debug",
                 "name": "debug 6",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "true",
                 "targetType": "full",
                 "statusVal": "",
                 "x": 500,
                 "y": 7340,
                 "wires": []
                 "name": "",
                 "port": 1883,
                 "clientid": "",
                 "usetls": false,
                 "keepalive": 60,
                 "birthTopic": "",
                 "birthQos": "0",
                 "birthPayload": "",
                 "birthMsg": {},
                 "closeTopic": "",
                 "closeQos": "0",
                 "closePayload": "",
                 "closeMsg": {},
                 "willTopic": "",
                 "willQos": "0",
                 "willPayload": "",
                 "willMsg": {},
                 "userProps": "",
                 "sessionExpiry": ""
                 "type": "ui_group",
                 "name": "Standard",
                 "order": 1,
                 "disp": true,
                 "width": 6,
                 "collapse": false,
                 "className": ""
                 "type": "ui_tab",
                 "name": "Home",
                 "disabled": false,
                 "hidden": false
          Wenn Du unbedingt beides zusammenfassen willst, dann musst Du beide Parameter in EINEM Nachrichtenobjekt sammeln. Das ist wichtig dass Du das verstehst.
          Nach Deiner Methode willst Du ja brightness und on gleichzeitig setzen.
          Wenn Du aber den Switch betätigst, dann ist in diesem Nachrichtenobjekt was Du auf die Reise schickst, kein topic brightness drin und auch kein Wert und umgekehrt wenn Du auf slider gehst ist auch kein Wert oder Zustand deines Switches in dem Nachrichtenobjekt enthalten.
          Im Übrigen empfehle ich Dir
          bei dem slider einzustellen, dass erst nachdem die Maus stoppt Nachrichten gesendet werden:
          Ansonsten wird jede Mausbewegung in einen Befehl umgesetzt und das macht keinen Sinn, weil Du 1% Werte gar nicht siehst, Du flutest Deinen Shelly also nur
          Wenn Du also mit einer JOIN Node den State des jeweilg anderen Nodes speicherst und die payload als Objekt machst.
          Dann hast Du in Deiner payload BEIDE Nachrichtenparameter.
          Siehe Debug Node 6 des Gesamtflows mit der JOIN Node:
          Damit ist die payload also selbst ein Objekt und die JOIN Node bastelt die Objekteigenschaften aus dem topic.
          {"on":true,"brightness":63}
          Das passiert deshalb, weil wir in der JOIN Node sagen, welche Nachrichteneigenschaft als Schlüssel oder Eigenschaft für das zusammengesetzte payload Objekt genutzt werden soll:
          In Deinem JSONATA der ChangeNode greifst Du dann auf die payload Eigenschaften on und brightness direkt zu.
              "params": {
                  "id": 0,
                  "on" : payload.on,
                  "brightness" : payload.brightness
          Hier wieder den modifizierten Flow als Import:
                 "type": "mqtt out",
                 "d": true,
                 "name": "",
                 "qos": "",
                 "retain": "",
                 "respTopic": "",
                 "contentType": "",
                 "userProps": "",
                 "correl": "",
                 "expiry": "",
                 "x": 1100,
                 "y": 7420,
                 "wires": []
                 "type": "inject",
                 "name": "Turn On",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 780,
                 "y": 7460,
                 "wires": [
                         "9520830343183a7b"
                 "type": "inject",
                 "name": "Turn Off",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 780,
                 "y": 7500,
                 "wires": [
                         "9520830343183a7b"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "{\t    \"method\": \"Light.Set\",\t    \"params\": {\t        \"id\": 0,\t        \"on\" : payload.on,\t        \"brightness\" : payload.brightness\t    }\t}",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 630,
                 "y": 7400,
                 "wires": [
                         "9520830343183a7b",
                         "8f181f3c9f097ee4"
                 "name": "",
                 "tooltip": "",
                 "order": 0,
                 "width": 0,
                 "height": 0,
                 "passthru": true,
                 "outs": "end",
                 "topicType": "str",
                 "min": 0,
                 "max": "100",
                 "step": 1,
                 "className": "",
                 "x": 190,
                 "y": 7420,
                 "wires": [
                         "4dbe5273f228faab"
                 "type": "debug",
                 "name": "debug 5",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1020,
                 "y": 7360,
                 "wires": []
                 "name": "",
                 "label": "switch",
                 "tooltip": "",
                 "order": 2,
                 "width": 0,
                 "height": 0,
                 "passthru": true,
                 "topic": "on",
                 "topicType": "str",
                 "style": "",
                 "onvalue": "true",
                 "onicon": "",
                 "oncolor": "",
                 "officon": "",
                 "offcolor": "",
                 "animate": false,
                 "className": "",
                 "x": 190,
                 "y": 7360,
                 "wires": [
                         "4dbe5273f228faab"
                 "type": "debug",
                 "name": "debug 6",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "payload",
                 "targetType": "msg",
                 "statusVal": "",
                 "x": 600,
                 "y": 7320,
                 "wires": []
                 "id": "4dbe5273f228faab",
                 "type": "join",
                 "name": "",
                 "mode": "custom",
                 "build": "object",
                 "property": "payload",
                 "propertyType": "msg",
                 "key": "topic",
                 "joiner": "\\n",
                 "joinerType": "str",
                 "accumulate": true,
                 "timeout": "",
                 "count": "1",
                 "reduceRight": false,
                 "reduceExp": "",
                 "reduceInit": "",
                 "reduceInitType": "",
                 "reduceFixup": "",
                 "x": 430,
                 "y": 7400,
                 "wires": [
                         "aa6f2ad025c0fe01",
                         "9fd710ddbcfe1e87"
                 "name": "",
                 "port": 1883,
                 "clientid": "",
                 "usetls": false,
                 "keepalive": 60,
                 "birthTopic": "",
                 "birthQos": "0",
                 "birthPayload": "",
                 "birthMsg": {},
                 "closeTopic": "",
                 "closeQos": "0",
                 "closePayload": "",
                 "closeMsg": {},
                 "willTopic": "",
                 "willQos": "0",
                 "willPayload": "",
                 "willMsg": {},
                 "userProps": "",
                 "sessionExpiry": ""
                 "type": "ui_group",
                 "name": "Standard",
                 "order": 1,
                 "disp": true,
                 "width": 6,
                 "collapse": false,
                 "className": ""
                 "type": "ui_tab",
                 "name": "Home",
                 "disabled": false,
                 "hidden": false
            @mickym
            Oh ha, sehr lehrreich! Die Variante über 2 change ist auf jeden Fall einfacher zu verstehen und auch umzusetzen.
            Nochmals vielen Dank!!
            • mickym
              @fortune95 Na Du solltest generell nun alle 3 Szenarien verstehen, weil sie die Basis für ein grundlegendes Verständnis von NodeRed sind. Sollte also was unklar sein, frag und ich versuche das nochmals verständlich zu erklären-
                @mickym
                Gibt es irgendwo eine Übersicht über das "Wording" Topic, Payload etc. ?
                • mickym
                  @fortune95 Na ja in der Regel sind diese beiden Nachrichteneigenschaften oft die Basis - ansonsten kann man die Nachrichteneigenschaften definieren wie man will. Oft steht in der Hilfe zu den Nodes, wenn bestimmte Nachrichteneigenschaften eine bestimmte Bedeutung haben.
                  Wenn Du zum Beispiel die Hilfe zu einer Delay Node anschaust, dann
                  haben Nachrichteneigenschaften delay,flush und reset eine bestimmte Funktion.
                  Wenn Du eine E-Mail Node hast, dann gibts wieder ganz andere Eigenschaften mit anderen Funktionen.
                  Ansonsten arbeitet man in 90% der Fälle mit topic und payload.
                  payload = Die sogenannte Nutzlast - also der Wert der verarbeitet werden soll
                  topic = bezeichnet woher ein Wert stammt.
                  Beispiel ein Temperatursensor:
                  Er misst 25°C - die payload ist also 25.
                  Nur weiß man ja nun nicht was die 25 ist. Könnten ja auch Liter, Außentemperatur, Badezimmertemperatur etc. sein.
                  Das topic dient also der Beschreibung woher der Wert stammt und welche Bedeutung der Wert hat.
                  Wenn Du das Nachrichtenobjekt aus einer mqtt-IN node nimmst oder auch einer iobroker-IN Node - dann ist das topic immer mit dem mqtt-topic besetzt oder bei der iobroker-IN Node mit der ID des Datenpunktes und die payload mit dem Wert des mqtt-topics oder des iobroker Datenpunktes.
                  Also payload und topic sind die gebräuchlichsten - aber Du kannst ja selbst jede Eigenschaft definieren.
                  Nimm eine Inject Node und hänge dahinter eine Debug Node mit dem kompletten NAchrichtenobjekt.
                  Du siehst also Topic, Payload - hat meist eine Inject Node wenn Du sie auf die Arbeitsfläche ziehst und kannst aber beliebige weitere Eigenschaften definieren - wie hier Feuchtigkeit
                  Hier mal die Definition einer Inject Node und Ausgabe des gesamten Nachrichtenobjektes. Eing _msgid hat jede Nachricht - damit NodeRed die einzelnen Nachrichtenobjekte identifizieren kann.
                  Hier der Import:
                         "id": "892ace0514454c37",
                         "type": "inject",
                         "name": "",
                         "props": [
                                 "p": "payload"
                                 "p": "topic",
                                 "vt": "str"
                                 "p": "feuchtigkeit",
                                 "v": "60",
                                 "vt": "num"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "Badtemperatur",
                         "payload": "25",
                         "payloadType": "num",
                         "x": 170,
                         "y": 7680,
                         "wires": [
                                 "139bd52494e0452b"
                         "id": "139bd52494e0452b",
                         "type": "debug",
                         "name": "Nachricht",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "statusVal": "",
                         "x": 380,
                         "y": 7680,
                         "wires": []
                  In der Regel definiert man eben halt nicht willkürlich Nachrichteneigenschaften, sondern verwendet die payload - für die Nutzdaten (sprich der Wert des Datenpunktes) und das topic - als Beschreibung woher oder für was der Wert, die payload steht. - Das ist halt eine Art Standard, sodass sich die meisten dann sofort zurechtfinden - auch wenn jede Nachrichteneigenschaft definiert werden dürfte.
                  • fuzzy1955
                    fuzzy1955 @Dragon133 last edited by
                    @dragon133
                    Hallo Dragon,
                    es gäbe auch die Möglichkeit, diese Dinger ohne Shelly-Adapter zu steuern. Ich habe recht gute Erfahrungen damit gemacht. Aber es ist halt in JScript:
                    //VentRegler(80);
                    function VentRegler (intBright) {
                        let data;
                        let strHTTP;
                        if (intBright != 0) {
                                strHTTP = "http://192.168.0.xxx/light/0?turn=on&brightness=" + intBright; 	// hier Shelly-IP-Adresse einsetzen
                        else {
                                strHTTP = "http://192.168.0.xxx/light/0?turn=off&brightness=0"; 		// hier Shelly-IP-Adresse einsetzen
                        httpGet(strHTTP, {timeout: 2000, responseType: 'text' }, async (err, response) => { data = (() => {
                            try {
                                return JSON.parse(response.data); }
                            catch (e) {
                                console.info(e);
                                return {};
                    Oder das Auslesen von Temperaturwerten mit Shelly plus 1 mit AddOn:
                    httpGet('http://192.168.0.xxx/rpc/temperature.getstatus?id=100', { 			// hier Shelly-IP-Adresse einsetzen
                            let data = (() => {
                            try {
                                setState('alias.0.Klimatisierung.ShellyPlus1_01.Aussentemperatur', getAttr(JSON.parse(response.data), 'tC'), true);
                            catch (e) {
                                return {};
                    Kannst du dich damit anfreunden?
                    Schöne Grüße aus dem Mühlviertel (A), hf
                      Dragon133 @mickym last edited by
                      @mickym
                      ich verstehe leider nicht wie ich den Dimmer über mqtt geschalten bekommen.
                      Er ist wohl mal verbunden aber wie muss ich da jetzt den Datenpunkt anlegen um ihn schalten zu können?
                      • mickym
                        mickym Most Active @Dragon133 last edited by mickym
                        @dragon133 In dem grünen topic bekommst du die Rückmeldungen von Deinem Dimmer in dem rosa topic musst du die Befehle eintragen.
                            "params": {
                                "id": 0,
                                "on" : true
                        Also mit diesem Objekt kannst Du mit der Eigenschaft on=true einschalten bzw. on=false ausschalten.
                        Kann auch sein, dass noch eine id oder einen user mitgeben musst.
                            "id": 1,
                            "params": {
                                "id": 0,
                                "on" : true
                        1.5k
                        2562
