io Broker startet nicht mehr
@mrnight
Bitte setze Protokolle und Logs in Code-Tags </>.
Lang genug bist Du dabei und solltest das kennen. -
code_text
iobroker fix
Execute the installation fixer script, this updates your ioBroker installation
Options:
--help Show help [boolean]Das kommt bei iobroker update:
code_text Used repository: beta Adapter "admin" : 7.4.19 , installed 5.4.9 [Updatable] Adapter "alexa2" : 3.26.7 , installed 3.19.7 [Updatable] Adapter "backitup" : 3.0.31 , installed 2.4.12 [Updatable] Adapter "cloud" : 5.0.1 , installed 4.2.2 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "email" : 1.3.1 , installed 1.1.3 [Updatable] Adapter "harmony" : 1.5.0 , installed 1.2.2 [Updatable] Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 1.15.15 [Updatable] Adapter "hmip" : 1.26.5 , installed 1.20.0 [Updatable] Adapter "hue" : 3.14.1 , installed 3.14.1 Adapter "iot" : 3.4.5 , installed 3.4.5 Adapter "javascript" : 8.9.1 , installed 6.0.1 [Updatable] Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "musiccast" : 1.1.4 , installed 1.1.4 Adapter "owntracks" : 1.1.0 , installed 1.0.3 [Updatable] Adapter "pushover" : 4.1.0 , installed 2.1.0 [Updatable] Adapter "sayit" : 5.0.0 , installed 1.12.6 [Updatable] Adapter "scenes" : 4.0.1 , installed 4.0.1 Adapter "simple-api" : 2.8.0 , installed 2.7.1 [Updatable] Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "telegram" : 4.0.0 , installed 1.14.1 [Updatable] Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "vis" : 1.5.6 , installed 1.4.15 [Updatable] Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "web" : 6.3.1 , installed 3.4.16 [Updatable] Adapter "yahka" : 1.0.9 , installed 0.11.0 [Updatable]
@mrnight sagte in io Broker startet nicht mehr:
ernsthaft?
soooo alte Versionen?
und dann node so neu?
das passt nicht.bring mal alles auf Stand
ich weiß nicht ob der fixer aus meiner Signatur besser läuft.
probiers mal -
@homoran sagte in io Broker startet nicht mehr:
Das ist so alt und verstrubbelt, da würde wohl eher 'ne Neuinstallation Sinn machen
das system ist die ganze zeit vernünftig gelaufen.- wie kann ich das nun auf Stand bringen?
2.wie funktioniert das mit deinem Installationsfixer?
This post is deleted! -
@mrnight stell erst mal das Repo auf stable
dann machst du nochmsliob update
das system ist die ganze zeit vernünftig gelaufen.trotzdem alle 4 Wochen updates machen. Normalerweise haette da der grosse schwarze Boxhandschuh aus'm Monitor kommen muessen..
Dein Betriebssystem muss doch auch updates bekommen...
wie kann ich das auf Repo auf stable setzen? wenn ich doch nicht mehr auf die Oberfläche komme?
Bitte nicht schlagen. -
ja da der Mac mini nur für IObroker im Einsatz ist ..... und ich nicht Updates machen wollte vom Mac und dann was nicht mehr Kompatibel ist.... habe ich es gelassen.
Nun ist der Rechner auch auf den neusten Stand. Nochmals passiert das mir nicht.
@mrnight Nach etwas wühlen im Forum
iob repo list iob repo unset UNGEWÜNSCHTES_REPO iob repo set GEWÜNSCHTES_REPO
Der erste Befehl zeigt dir von dir vergebenen Namen der Repos an
der nächste deaktiviert das aktuelle, müsste bei dirbeta
heissen.
der letzte aktiviert dann das, was stable sein müsste -
@mrnight ok, alles gut.. das naechste Mal weisste bescheid.. ist immer hinterher mehr arbeit, was altes up to daten als alle eck mal rum zu schauen..
Beim Mac sowieso wieder n Thema.. ganz speziell.. -
So sieht es nun aus.
MAX11905:~ MAX$ ./iobroker repo set 0 Repository "stable" set as active.
Nun habe ich versucht zb. den Admin adapter mit
./iobroker upgrade admin
die Adapter einzeln zu Updaten
max11905:~ max$ ./iobroker upgrade admin This upgrade of "admin" will at least introduce the following changes: ========================================================================== -> 7.4.10: Corrected JSON-Config tables Corrected translation on the update adapter dialog -> 7.4.8: Show latest/stable labels by updating/downgrading of adapters Corrected selection of chinese language -> 7.4.7: Corrected the rendering of custom JSON config components Corrected the news dialog for multi-line messages -> 7.4.4: Showed value in object edit dialog -> 7.4.3: Changed information box on the hosts tab Corrected some errors in JsonConfig library Added flag expertMode to hide JSON config controls for non-experts Corrected cloud icon for admin Added old dialog names to adapter-react-v5 again -> 7.4.2: Made improvement for JSONConfig components Added clear button to text area JSON config component -> 7.4.1: Made improvement for JSONConfig components ========================================================================== BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES! Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
wenn ich dann auf "Y" startet er auch den Installationsprozess .
Nur wenn ich dann "iobroker Update" mache. Kommt wieder das die Version 5.4.9 Installiert ist .
Und dann fällt dir auf einmal ein: "Heute qualm ich mal n Update rein, oder was?!"
@warp735
Echt hilfreich so ein sinnloses Nachtreten an 34er Stelle. -
zeigen!
ggf. stimmen irgendwelche Abhängigkeiten nicht.
Ich fürchte auch, dass du den controller von einer ebenso antiken Verdion direkt auf due v7 gehoben hast, was nicht vorgesehen ist, und zu Kollateralschäden führt -
MAX11905:~ MAX$ ./iobroker update Used repositories: beta, stable Adapter "admin" : 7.4.10 , installed 5.4.9 [Updatable] Adapter "alexa2" : 3.26.5 , installed 3.19.7 [Updatable] Adapter "backitup" : 3.0.31 , installed 2.4.12 [Updatable] Adapter "cloud" : 5.0.1 , installed 4.2.2 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "email" : 1.3.1 , installed 1.1.3 [Updatable] Adapter "harmony" : 1.5.0 , installed 1.2.2 [Updatable] Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 1.15.15 [Updatable] Adapter "hmip" : 1.25.0 , installed 1.20.0 [Updatable] Adapter "hue" : 3.13.1 , installed 3.14.1 Adapter "iot" : 3.3.0 , installed 3.4.5 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "musiccast" : 1.1.4 , installed 1.1.4 Adapter "owntracks" : 1.1.0 , installed 1.0.3 [Updatable] Adapter "pushover" : 4.1.0 , installed 2.1.0 [Updatable] Adapter "sayit" : 5.0.0 , installed 1.12.6 [Updatable] Adapter "scenes" : 3.2.3 , installed 4.0.1 Adapter "simple-api" : 2.8.0 , installed 2.7.1 [Updatable] Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "telegram" : 4.0.0 , installed 1.14.1 [Updatable] Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "vis" : 1.5.6 , installed 1.4.15 [Updatable] Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "web" : 6.2.5 , installed 3.4.16 [Updatable] Adapter "yahka" : 1.0.3 , installed 0.11.0 [Updatable] MAX11905:~ MAX$
so sieht das dann immer noch aus.
Wenn ich dann nur den Admin Adapter Updaten will.
MAX11905:~ MAX$ ./iobroker upgrade admin This upgrade of "admin" will at least introduce the following changes: ========================================================================== -> 7.4.10: Corrected JSON-Config tables Corrected translation on the update adapter dialog -> 7.4.8: Show latest/stable labels by updating/downgrading of adapters Corrected selection of chinese language -> 7.4.7: Corrected the rendering of custom JSON config components Corrected the news dialog for multi-line messages -> 7.4.4: Showed value in object edit dialog -> 7.4.3: Changed information box on the hosts tab Corrected some errors in JsonConfig library Added flag expertMode to hide JSON config controls for non-experts Corrected cloud icon for admin Added old dialog names to adapter-react-v5 again -> 7.4.2: Made improvement for JSONConfig components Added clear button to text area JSON config component -> 7.4.1: Made improvement for JSONConfig components ========================================================================== BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES! Would you like to upgrade admin from @5.4.9 to @7.4.10 now? [(y)es, (n)o]:
das bestätige ich dann mit "y"
dann erscheint das:
host.E11905.fritz.box Adapter "system.adapter.admin.0" is stopped. NPM version: 10.8.2 Installing iobroker.admin@7.4.10... (System call) added 81 packages, removed 6 packages, changed 11 packages, and audited 1056 packages in 21s 98 packages are looking for funding run `npm fund` for details 88 vulnerabilities (12 low, 47 moderate, 24 high, 5 critical) To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details. Updating objects from io-package.json for adapter "admin" with version "7.4.10" Update "system.adapter.admin.0" upload [312] admin.admin /Users/e/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [300] admin.admin /Users/enricoklimczak/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json upload [250] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js custom/static/js/node_modules_mui_system_esm_useTheme_useTheme_js-_95041.7238f945.chunk.js application/javascript upload [200] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js custom/static/js/src_bootstrap_jsx.b1e4762d.chunk.js application/javascript upload [150] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.fcf5d44e.chunk.js application/javascript upload [100] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.08770d2e.chunk.js application/javascript upload [90] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f075e886.chunk.js application/javascript upload [80] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_defaultTheme_js-node_modules_mui_material_styles_ide-00a7ec.54dc30ec.chunk.js application/javascript upload [70] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js custom/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_cronstrue_locales_de_js-nod-b40f79.ee63d226.chunk.js application/javascript upload [60] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js custom/static/js/vendors-node_modules_mui_system_esm_colorManipulator_colorManipulator_js-node_modules_mui_sys-525238.332f7d66.chunk.js application/javascript upload [50] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.eed2bb86.chunk.js application/javascript upload [40] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js.1328581e.chunk.js application/javascript upload [30] admin.admin /Users/enriconode_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.98467b71.chunk.js application/javascript upload [20] admin.admin /Users/enrico/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js application/javascript upload [19] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.bfe7ef04.chunk.js.map application/json upload [18] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js application/javascript upload [17] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map custom/static/js/vendors-node_modules_react-icons_fa_index_mjs.9fe68fd5.chunk.js.map application/json upload [16] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js application/javascript upload [15] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.0471d4fd.chunk.js.map application/json upload [14] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js application/javascript upload [13] admin.admin /Users/e/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map custom/static/js/vendors-node_modules_react-qr-code_lib_index_js.38e93c56.chunk.js.map application/json upload [12] admin.admin /Users/e/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [11] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [1] admin.admin /Users/e/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [0] admin.admin /Users/e/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 host.Eini11905.fritz.box Adapter "system.adapter.admin.0" is started E11905:~ e$
wenn man dann wieder "iobroker update macht zeigt er an das es wieder nur die 5 Version ist. Hoffe habe das einigermaßen Verständlich rüber gebracht.
Danke Dir.....
was ist das?
dast du vorher nicht beta deaktiviert?
iob repo unset beta
?wenn es danach immer och so ausdieht, versuchen wir einen anderen Weg
Enricosini11905:~ enrico$ ./iobroker repo unset beta Repository "beta" deactivated. ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Esini11905:~ e$
das habe ich vorhin gemacht.
Da steht doch "stable"
