    4. Node-Red
    5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
      MartyBr @mickym last edited by
      @mickym
      Ich habe es mal so gemacht:
              "id": "7e0364b0b8f9043e",
              "type": "mqtt in",
              "z": "71de45f27137890c",
              "name": "Vitovent ZuluftTemp",
              "topic": "vitocal/ZuluftTemp",
              "qos": "0",
              "datatype": "auto-detect",
              "broker": "bf311140.13d2b8",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 110,
              "y": 80,
              "wires": [
                      "f9c4e37a0e08b272"
              "id": "f9c4e37a0e08b272",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "datum",
                      "pt": "msg",
                      "to": "$moment().locale('de').format('YYYY.MMMM')",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 330,
              "y": 80,
              "wires": [
                      "4b7e157254dd9a42"
              "id": "4b7e157254dd9a42",
              "type": "change",
              "name": "März zu Maerz",
              "rules": [
                      "t": "change",
                      "p": "datum",
                      "pt": "msg",
                      "from": "März",
                      "fromt": "str",
                      "to": "Maerz",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 540,
              "y": 80,
              "wires": [
                      "db5352ef5569bd02"
              "id": "db5352ef5569bd02",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "\"0_userdata.0.Test1.Test2.\" & datum & \".\"",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 740,
              "y": 80,
              "wires": [
                      "5f919db0295bc25c",
                      "9795ea0c497cd9c7"
              "id": "5f919db0295bc25c",
              "type": "debug",
              "name": "topic",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 730,
              "y": 20,
              "wires": []
              "id": "9795ea0c497cd9c7",
              "type": "change",
              "name": "Variable",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "topic & \"zuluft-ganzneu\"",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 920,
              "y": 80,
              "wires": [
                      "f0dd9b6950d71727",
                      "5ce63ee6255c1fd2"
              "id": "5ce63ee6255c1fd2",
              "type": "debug",
              "name": "topic2",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1110,
              "y": 20,
              "wires": []
              "id": "f0dd9b6950d71727",
              "type": "ioBroker out",
              "name": "",
              "topic": "",
              "ack": "true",
              "autoCreate": "true",
              "stateName": "zuluft-neu",
              "role": "state",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "°C",
              "stateMin": "",
              "stateMax": "",
              "x": 1140,
              "y": 80,
              "wires": []
              "id": "bf311140.13d2b8",
              "type": "mqtt-broker",
              "name": "Mosquito-Server",
              "broker": "192.168.178.10",
              "port": "1883",
              "clientid": "",
              "autoConnect": true,
              "usetls": false,
              "compatmode": false,
              "protocolVersion": "4",
              "keepalive": "60",
              "cleansession": true,
              "autoUnsubscribe": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Die würde dann die ersten drei Chane Nodes in den Subflow speichern.
      Besteht eine Möglichkeit, den Change Node Variable irgendwo nachvollziehbar abzulegen?
      • mickym
        mickym Most Active @MartyBr last edited by
        @martybr Ich habe Dir doch gerade einen neuen Subflow geschickt - schau Dir den lieber mal an - das was Du gemacht hast, das funktioniert nicht. - Wie gesagt ich habe jetzt das Originaltopic genommen und einen variablen Basispfad über eine Variable, um es Dir zu zeigen. Du kannst natürlich auch noch weitere Variablen im Subflow nutzen - aber wie gesagt, das Originaltopic ist besser - weil Du dann auch mit EINER Subflow-Node viele Datenpunkte schreiben kannst.
          @mickym
          Habe ich zu spät gesehen. Dein Flow funktioniert perfekt, ich habe nur einen Change nach dem MQTT gesetzt, da dieser einen hierarchischen DP erzeugt (..virocal/zuluft)
          Nun funktioniert es perfekt. Vielen Dank. Jetzt habe ich das System der Variablen verstanden. Ich muss mir trotzdem das Konzept hinter env(basePath) anschauen.
          Hier mein/unser Ergebnis:
                  "id": "ae673cf6cd8433a0",
                  "type": "subflow",
                  "name": "Datum in Topic",
                  "info": "",
                  "category": "",
                  "in": [
                          "x": 60,
                          "y": 80,
                          "wires": [
                                  "id": "2e1ea06b2e94bf1a"
                  "out": [
                          "x": 820,
                          "y": 80,
                          "wires": [
                                  "id": "fc37f5f9d2b0297b",
                                  "port": 0
                  "env": [
                          "name": "basePath",
                          "type": "str",
                          "value": "Test1.Test2"
                  "meta": {},
                  "color": "#DDAA99"
                  "id": "2e1ea06b2e94bf1a",
                  "type": "change",
                  "z": "ae673cf6cd8433a0",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "datum",
                          "pt": "msg",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 230,
                  "y": 80,
                  "wires": [
                          "0e8de9437c3c420a"
                  "id": "0e8de9437c3c420a",
                  "type": "change",
                  "rules": [
                          "t": "change",
                          "p": "datum",
                          "pt": "msg",
                          "from": "März",
                          "fromt": "str",
                          "to": "Maerz",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 440,
                  "y": 80,
                  "wires": [
                          "fc37f5f9d2b0297b"
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 660,
                  "y": 80,
                  "wires": [
                  "id": "71de45f27137890c",
                  "type": "tab",
                  "label": "Datum",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "name": "",
                  "topic": "",
                  "ack": "true",
                  "role": "state",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "°C",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 720,
                  "y": 80,
                  "wires": []
                  "type": "mqtt in",
                  "qos": "0",
                  "nl": false,
                  "rap": true,
                  "rh": 0,
                  "inputs": 0,
                  "x": 110,
                  "y": 80,
                  "wires": [
                          "90912a5dffeb17cc"
                  "id": "e4826cebe9af4d64",
                  "type": "debug",
                  "name": "payload und topic",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 510,
                  "y": 20,
                  "wires": []
                  "id": "5267d5edc8abe331",
                  "type": "subflow:ae673cf6cd8433a0",
                  "env": [
                          "name": "basePath",
                          "value": "Test1.Test5",
                          "type": "str"
                  "x": 520,
                  "y": 80,
                  "wires": [
                          "e4826cebe9af4d64",
                          "f0dd9b6950d71727"
                  "id": "90912a5dffeb17cc",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "to": "Zuluft-Temp",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 320,
                  "y": 80,
                  "wires": [
                          "5267d5edc8abe331",
                          "527e1cef1285c117"
                  "id": "527e1cef1285c117",
                  "type": "debug",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 270,
                  "y": 20,
                  "wires": []
                  "port": "1883",
                  "clientid": "",
                  "usetls": false,
                  "keepalive": "60",
                  "birthTopic": "",
                  "birthQos": "0",
                  "birthPayload": "",
                  "birthMsg": {},
                  "closeTopic": "",
                  "closeQos": "0",
                  "closePayload": "",
                  "closeMsg": {},
                  "willTopic": "",
                  "willQos": "0",
                  "willPayload": "",
                  "willMsg": {},
                  "userProps": "",
                  "sessionExpiry": ""
          mickym 1 Reply Last reply Reply Quote 1
          • mickym
            @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
            Wie gesagt - hast Du ja super gemacht - kannst Du nun mit dem topic mehrere datenpunkte und oder sogar Hierarchien erzeugen.
            So habe ich ja auch meinen Subflow erzeugt mit dem Du ganze JSONS oder Bäume in iobroker Einzelwerte zerlegen kannst.
            Die Variablen in einer Subflow - gelten nur für diese Instanz - so kannst Du also eine ganze Menge in einer Instanz eines Subflows parametrisieren.
            Schau Dir mal meinen Subflow an, der JSONS oder ganze Bäume in Einzelwerte zerlegt:
            https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
              @mickym
              Jetzt bin auf den Geschmack gekommen. Ich habe jetzt versucht, einen JSON-Datenpunkt anzulegen. Das sieht auf dem ersten Blick auch gut aus. In kann aber im Objektbaum ioBroker die Daten nicht öffnen bzw. bearbeiten.
              Hier mal die Infos:
              Datensatz:
              Flow:
                      "type": "subflow",
                      "info": "",
                      "category": "",
                      "in": [
                              "x": 60,
                              "y": 80,
                              "wires": [
                      "out": [
                              "x": 820,
                              "y": 80,
                              "wires": [
                                      "port": 0
                      "env": [
                              "name": "basePath",
                              "type": "str",
                      "meta": {},
                      "color": "#DDAA99"
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "datum",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 230,
                      "y": 80,
                      "wires": [
                              "0e8de9437c3c420a"
                      "type": "change",
                      "rules": [
                              "t": "change",
                              "p": "datum",
                              "pt": "msg",
                              "from": "März",
                              "fromt": "str",
                              "to": "Maerz",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 440,
                      "y": 80,
                      "wires": [
                              "fc37f5f9d2b0297b"
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 660,
                      "y": 80,
                      "wires": [
                      "id": "fad92726ff7c3254",
                      "type": "tab",
                      "label": "JSON",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "id": "29a754f2b7a96a31",
                      "type": "mqtt in",
                      "z": "fad92726ff7c3254",
                      "name": "ZuluftTemp",
                      "qos": "0",
                      "nl": false,
                      "rap": true,
                      "rh": 0,
                      "inputs": 0,
                      "x": 100,
                      "y": 120,
                      "wires": [
                              "5026b4d763ed7dcc"
                      "id": "535565225c8e6f99",
                      "env": [
                              "name": "basePath",
                              "value": "Test1.Test7",
                              "type": "str"
                      "x": 780,
                      "y": 180,
                      "wires": [
                              "05ad3c7ae6fe582b",
                              "9c9e217c842acefc"
                      "id": "05ad3c7ae6fe582b",
                      "name": "",
                      "topic": "",
                      "ack": "true",
                      "role": "state",
                      "payloadType": "object",
                      "readonly": "",
                      "stateUnit": "°C",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 980,
                      "y": 180,
                      "wires": []
                      "id": "5026b4d763ed7dcc",
                      "type": "change",
                      "name": "Zuluft",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 310,
                      "y": 120,
                      "wires": [
                              "766be49e74305196"
                      "id": "a3c1535e1da94552",
                      "type": "mqtt in",
                      "name": "AbluftTemp",
                      "topic": "vitocal/AbluftTemp",
                      "qos": "0",
                      "nl": false,
                      "rap": true,
                      "rh": 0,
                      "inputs": 0,
                      "x": 110,
                      "y": 240,
                      "wires": [
                              "225419c87f910c3e"
                      "id": "225419c87f910c3e",
                      "type": "change",
                      "name": "Abluft",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "to": "Abluft-Temp",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 310,
                      "y": 240,
                      "wires": [
                              "766be49e74305196"
                      "id": "766be49e74305196",
                      "type": "join",
                      "name": "",
                      "mode": "custom",
                      "build": "object",
                      "property": "payload",
                      "propertyType": "msg",
                      "key": "topic",
                      "joiner": "\\n",
                      "joinerType": "str",
                      "accumulate": true,
                      "timeout": "60",
                      "count": "2",
                      "reduceRight": false,
                      "reduceExp": "",
                      "reduceInit": "",
                      "reduceInitType": "",
                      "reduceFixup": "",
                      "x": 430,
                      "y": 180,
                      "wires": [
                              "dd61fc92c8961b14",
                              "457c8ae43cf33de1"
                      "id": "224380ff0709c559",
                      "type": "json",
                      "name": "",
                      "action": "",
                      "pretty": true,
                      "x": 610,
                      "y": 180,
                      "wires": [
                              "c828c8f4b32a9c0c",
                              "535565225c8e6f99"
                      "id": "dd61fc92c8961b14",
                      "type": "debug",
                      "name": "debug 174",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "false",
                      "statusVal": "",
                      "x": 510,
                      "y": 80,
                      "wires": []
                      "id": "c828c8f4b32a9c0c",
                      "type": "debug",
                      "name": "debug 175",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 710,
                      "y": 100,
                      "wires": []
                      "id": "9c9e217c842acefc",
                      "type": "debug",
                      "name": "debug 176",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 950,
                      "y": 100,
                      "wires": []
                      "id": "457c8ae43cf33de1",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "to": "vitovent300",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 540,
                      "y": 300,
                      "wires": [
                              "224380ff0709c559",
                              "f92533e2c4de9cf4"
                      "id": "f92533e2c4de9cf4",
                      "type": "debug",
                      "name": "debug 177",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 730,
                      "y": 360,
                      "wires": []
                      "port": "1883",
                      "clientid": "",
                      "usetls": false,
                      "keepalive": "60",
                      "birthTopic": "",
                      "birthQos": "0",
                      "birthPayload": "",
                      "birthMsg": {},
                      "closeTopic": "",
                      "closeQos": "0",
                      "closePayload": "",
                      "closeMsg": {},
                      "willTopic": "",
                      "willQos": "0",
                      "willPayload": "",
                      "willMsg": {},
                      "userProps": "",
                      "sessionExpiry": ""
              Müssen evtl eckige Klammern um den Jason gesetzt werden (also [json]?
              • mickym
                mickym Most Active @MartyBr last edited by mickym
                @martybr Na den Datenpunkt hast Du wahrscheinlich schreibgeschützt angelegt - siehst Du doch an dem Schloss. Musst Du wahrscheinlich beschreibbar machen, in der iobroker-Out Node. Oder im Nachhinein in den Objekteigenschaften des Datenpunktes.
                Ausserdem empfehle ich Dir - keinen Datentyp festzulegen - das macht die NOde selbst und wie gesagt musst Du es beschreibbar anlegen.
                Ja und wie gesagt - Objekte muss man als Strings - also JSON Strings schreiben und auch wieder in Objekte wandeln.
                iobroker kann nur Strings in den States verarbeiten.
                • mickym
                  @martybr Es geht auch als Objekt zu öffnen - aber muss halt beschreibbar sein.
                  Und wenn Du es nicht als Objekt, sondern richtig als String festlegst (wie gesagt normalerweise legt man nichts fest, dann wird automatisch der richtige Typ festgelegt), dann macht er auch einen JSON daraus:
                  Grundsätzlich würde ich mir übrigens angewöhnen, die JSON Node immer direkt vor die Ausgabe in die iobroker-out -Node zu machen, damit man solange wie möglich mit Objekten arbeiten kann.
                    @mickym
                    Okay, setze ich um.
                      @mickym
                      Funktioniert jetzt.
                      Hast du noch eine Idee wie ich die eckigen Klammern um den Datensatz setzen kann? Mit einem Change-Node?
                      • mickym
                        @martybr Eckige Klammern sind ein Array oder in Blockly Chargon eine Liste - Ja Du kannst einfach ein Array mit eckigen Klammern daraus machen - macht aber nur Sinn, wenn Du dann mehrere Objekte im Array hast.
                        Selbstverstöndlich kannst Du ein Objekt in ein Array stellen. Wenn Du aber mehrere Objekte in ein Array machen mächtest, dann nutze die $append Funktion.
                        Du solltest Dir angewöhnen - nie KLammern zu bezeichen, sondern was für Objekte Du erstellen möchtest.
                          @mickym
                          Okay. das ist mein Ziel. Ich möchte Tageswerte in ein Monatsarray speichern. Das mit den Klammern hat funktioniert.
                          Über Arrays muss ich mich erst kundig machen.
                          Ziel ist, um 00:00 Uhr generierte Werte in ein Monatsarray zu speichern.
                          Ich bereite mal einen Versuch vor.
                          • mickym
                            @martybr Dann nimm die $append Funktion
                            Hier zum Ausprobieren:
                                   "id": "1db807e2530b5198",
                                   "type": "change",
                                   "z": "7e6af0015415146d",
                                   "name": "Vorhandenes Array",
                                   "rules": [
                                           "t": "set",
                                           "p": "array",
                                           "pt": "msg",
                                           "to": "[{\"Zuluft-Temp\":20.1,\"Abluft-Temp\":20.9},{\"Zuluft-Temp\":21.1,\"Abluft-Temp\":22.9}]",
                                           "tot": "json"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 410,
                                   "y": 6500,
                                   "wires": [
                                           "16c668ac241e55c4"
                                   "id": "86b4268438857773",
                                   "type": "inject",
                                   "name": "Einzelnes Objekt",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "{     \"Zuluft-Temp\": 20.1,     \"Abluft-Temp\": 20.9 }",
                                   "payloadType": "json",
                                   "x": 180,
                                   "y": 6500,
                                   "wires": [
                                           "1db807e2530b5198"
                                   "id": "16c668ac241e55c4",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "$append(array, payload)",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 630,
                                   "y": 6500,
                                   "wires": [
                                           "c9cfdb97d8474804"
                                   "id": "c9cfdb97d8474804",
                                   "type": "debug",
                                   "name": "Neues Array",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 850,
                                   "y": 6500,
                                   "wires": []
                              MartyBr @mickym last edited by MartyBr
                              @mickym
                              das Array wird nach meinem Test nicht aufgefüllt, es bleibt immer nur ein Wert im Array.
                              Die $append scheint nicht zu wirken.
                                      "id": "a0d8740faea1647b",
                                      "type": "mqtt in",
                                      "z": "5c488c180ba51f18",
                                      "qos": "0",
                                      "nl": false,
                                      "rap": true,
                                      "rh": 0,
                                      "inputs": 0,
                                      "x": 140,
                                      "y": 260,
                                      "wires": [
                                              "afdcb37ccbacb06f"
                                      "id": "afdcb37ccbacb06f",
                                      "type": "change",
                                      "name": "Zuluft",
                                      "rules": [
                                              "t": "set",
                                              "p": "topic",
                                              "pt": "msg",
                                              "to": "zuluft",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 290,
                                      "y": 320,
                                      "wires": [
                                              "1643873aeecd8613"
                                      "id": "1643873aeecd8613",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "array",
                                              "pt": "msg",
                                              "to": "[]",
                                              "tot": "json"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 490,
                                      "y": 280,
                                      "wires": [
                                              "c9d97aec2949301c",
                                              "34c8064e4b5c52fa"
                                      "id": "34c8064e4b5c52fa",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 610,
                                      "y": 340,
                                      "wires": [
                                              "5b551b24fc1bb26e"
                                      "id": "5b551b24fc1bb26e",
                                      "type": "debug",
                                      "name": "debug 179",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 750,
                                      "y": 280,
                                      "wires": []
                                      "id": "c9d97aec2949301c",
                                      "type": "debug",
                                      "name": "debug 178",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 710,
                                      "y": 160,
                                      "wires": []
                                      "port": "1883",
                                      "clientid": "",
                                      "usetls": false,
                                      "keepalive": "60",
                                      "birthTopic": "",
                                      "birthQos": "0",
                                      "birthPayload": "",
                                      "birthMsg": {},
                                      "closeTopic": "",
                                      "closeQos": "0",
                                      "closePayload": "",
                                      "closeMsg": {},
                                      "willTopic": "",
                                      "willQos": "0",
                                      "willPayload": "",
                                      "willMsg": {},
                                      "userProps": "",
                                      "sessionExpiry": ""
                              Was mache ich falsch?
                              Edit:
                              Als Ziel benötige ich für die 4 Werte jeweils ein Array mit
                              Wert1,
                              Wert2,
                              Wert3,
                              Wert28
                              Anzahl der Werte entspricht der Zahl der Tage im laufenden Monat.
                              • mickym
                                @martybr Na Du mergst ein leeres Array mit einem skalaren Wert. Dann ist es doch richtig, dass nur ein Wert in dem Array ist. Du musst das Array ja speichern und dann den nächsten Wert anhängen.
                                So hängst Du doch immer wieder nur EIN Wert an ein leeres Array. Du musst doch das Array irgendwo abspeichern und dann das neu erstellte Array mit einem neuen Wert ergänzen.
                                Also überleg Dir wohin Du Dein Array Ergebnis des Anhänges abspeichern willst. In einer Variable oder in einem Datenpunkt.
                                Oder mit anderen Worten: Ein Wert an ein leeres Array angehängt, gibt immer nur ein Array mit einem Wert.
                                  @mickym
                                  Okay, das ist ein Ansatzpunkt. Ich mache mir mal Gedanken.
                                  Danke für deine Unterstützung.
                                  • mickym
                                    @mickym
                                    Ich habs Dir mal mit eine Flowvariable gemacht. Das heißt das Ergebnis wird in eine Variable gespeichert und dann wieder eingelesen und der neue Wert angehängt.
                                           "type": "mqtt in",
                                           "d": true,
                                           "qos": "0",
                                           "nl": false,
                                           "rap": true,
                                           "rh": 0,
                                           "inputs": 0,
                                           "x": 260,
                                           "y": 6740,
                                           "wires": [
                                                   "afdcb37ccbacb06f"
                                           "type": "change",
                                           "name": "Zuluft",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "to": "zuluft",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 410,
                                           "y": 6800,
                                           "wires": [
                                                   "1643873aeecd8613"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "msg",
                                                   "to": "array",
                                                   "tot": "flow"
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "msg",
                                                   "to": "array ? array : []",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 610,
                                           "y": 6760,
                                           "wires": [
                                                   "c9d97aec2949301c",
                                                   "34c8064e4b5c52fa"
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 6760,
                                           "wires": [
                                                   "5b551b24fc1bb26e"
                                           "type": "debug",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1070,
                                           "y": 6740,
                                           "wires": []
                                           "type": "debug",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 830,
                                           "y": 6640,
                                           "wires": []
                                           "id": "7961970716d0df25",
                                           "type": "inject",
                                           "name": "",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "20.2",
                                           "payloadType": "num",
                                           "x": 230,
                                           "y": 6800,
                                           "wires": [
                                                   "afdcb37ccbacb06f"
                                           "port": "1883",
                                           "clientid": "",
                                           "usetls": false,
                                           "keepalive": "60",
                                           "birthTopic": "",
                                           "birthQos": "0",
                                           "birthPayload": "",
                                           "birthMsg": {},
                                           "closeTopic": "",
                                           "closeQos": "0",
                                           "closePayload": "",
                                           "closeMsg": {},
                                           "willTopic": "",
                                           "willQos": "0",
                                           "willPayload": "",
                                           "willMsg": {},
                                           "userProps": "",
                                           "sessionExpiry": ""
                                      @mickym
                                      Der Flow funktioniert.
                                      Ich habe eine Objektveriable in ioBroker.
                                             "type": "mqtt in",
                                             "d": true,
                                             "qos": "0",
                                             "nl": false,
                                             "rap": true,
                                             "rh": 0,
                                             "inputs": 0,
                                             "x": 260,
                                             "y": 6740,
                                             "wires": [
                                                     "afdcb37ccbacb06f"
                                             "type": "change",
                                             "name": "Zuluft",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "topic",
                                                     "pt": "msg",
                                                     "to": "zuluft",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 410,
                                             "y": 6800,
                                             "wires": [
                                                     "1643873aeecd8613"
                                             "type": "change",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "array",
                                                     "pt": "msg",
                                                     "to": "array",
                                                     "tot": "flow"
                                                     "t": "set",
                                                     "p": "array",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 610,
                                             "y": 6760,
                                             "wires": [
                                                     "c9d97aec2949301c",
                                                     "34c8064e4b5c52fa"
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                                     "t": "set",
                                                     "p": "array",
                                                     "pt": "flow",
                                                     "to": "payload",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 850,
                                             "y": 6760,
                                             "wires": [
                                                     "5b551b24fc1bb26e"
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 1070,
                                             "y": 6740,
                                             "wires": []
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 830,
                                             "y": 6640,
                                             "wires": []
                                             "type": "inject",
                                             "name": "",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "20.2",
                                             "x": 230,
                                             "y": 6800,
                                             "wires": [
                                                     "afdcb37ccbacb06f"
                                             "port": "1883",
                                             "clientid": "",
                                             "usetls": false,
                                             "keepalive": "60",
                                             "birthTopic": "",
                                             "birthQos": "0",
                                             "birthPayload": "",
                                             "birthMsg": {},
                                             "closeTopic": "",
                                             "closeQos": "0",
                                             "closePayload": "",
                                             "closeMsg": {},
                                             "willTopic": "",
                                             "willQos": "0",
                                             "willPayload": "",
                                             "willMsg": {},
                                             "userProps": "",
                                             "sessionExpiry": ""
                                      Wie kann ich das Array persistent ablegen?
                                      • mickym
                                        @martybr
                                        Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
                                          @mickym
                                          Ich habe das mal so gemacht:
                                                  "id": "99d066d4bbe5dca9",
                                                  "type": "inject",
                                                  "name": "",
                                                  "props": [
                                                          "p": "payload"
                                                  "repeat": "",
                                                  "crontab": "",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "topic": "",
                                                  "payload": "20.2",
                                                  "x": 350,
                                                  "y": 700,
                                                  "wires": [
                                                          "994a1a0b6d25cef4"
                                                  "id": "82d5f1b2aa875c35",
                                                  "type": "mqtt in",
                                                  "qos": "0",
                                                  "nl": false,
                                                  "rap": true,
                                                  "rh": 0,
                                                  "inputs": 0,
                                                  "x": 420,
                                                  "y": 620,
                                                  "wires": [
                                                          "994a1a0b6d25cef4"
                                                  "id": "994a1a0b6d25cef4",
                                                  "type": "change",
                                                  "name": "Zuluft",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "topic",
                                                          "pt": "msg",
                                                          "to": "zuluft",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 530,
                                                  "y": 700,
                                                  "wires": [
                                                          "4a49f7b7cb1d35d2"
                                                  "id": "de7a183e542f367e",
                                                  "type": "ioBroker get object",
                                                  "name": "Test.Test-JSON",
                                                  "topic": "0_userdata.0.Test.Test-JSON",
                                                  "attrname": "array",
                                                  "x": 620,
                                                  "y": 580,
                                                  "wires": [
                                                  "id": "4a49f7b7cb1d35d2",
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "array",
                                                          "pt": "msg",
                                                          "to": "array",
                                                          "tot": "flow"
                                                          "t": "set",
                                                          "p": "array",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 730,
                                                  "y": 660,
                                                  "wires": [
                                                          "1bf56806da8b2399",
                                                          "40df7a89751f5b92"
                                                  "id": "40df7a89751f5b92",
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                          "t": "set",
                                                          "p": "array",
                                                          "pt": "flow",
                                                          "to": "payload",
                                                          "tot": "msg"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 830,
                                                  "y": 740,
                                                  "wires": [
                                                          "cb026a3b7a51d987",
                                                          "8d9b65f4efb22698"
                                                  "id": "cb026a3b7a51d987",
                                                  "type": "debug",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 890,
                                                  "y": 800,
                                                  "wires": []
                                                  "id": "8d9b65f4efb22698",
                                                  "ack": "true",
                                                  "autoCreate": "false",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1000,
                                                  "y": 660,
                                                  "wires": []
                                                  "id": "1bf56806da8b2399",
                                                  "type": "debug",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 950,
                                                  "y": 540,
                                                  "wires": []
                                                  "port": "1883",
                                                  "clientid": "",
                                                  "usetls": false,
                                                  "keepalive": "60",
                                                  "birthTopic": "",
                                                  "birthQos": "0",
                                                  "birthPayload": "",
                                                  "birthMsg": {},
                                                  "closeTopic": "",
                                                  "closeQos": "0",
                                                  "closePayload": "",
                                                  "closeMsg": {},
                                                  "willTopic": "",
                                                  "willQos": "0",
                                                  "willPayload": "",
                                                  "willMsg": {},
                                                  "userProps": "",
                                                  "sessionExpiry": ""
                                          Die Werte kommen auch richtig im Datenpunkt an.
                                          Jetzt noch eine letzte Frage für Heute 😇
                                          Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
                                          Edit:
                                          Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
                                          • mickym
                                            Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
                                            1.2k
                                            8935
