    4. Zigbee, keine Aktion und keinerlei Verbindungen
      alexzi @Thomas Braun last edited by
      hmmmm, da habe ich nur den einen Eintrag
        alexzi @Asgothian last edited by
        @asgothian
        hier wird empfohlen mit der FW nicht höher zu gehen, ist aber schon 9 Monate her
        https://forum.iobroker.net/post/1154856
          Thomas Braun Most Active @alexzi last edited by Thomas Braun
          @alexzi sagte in Zigbee, keine Aktion und keinerlei Verbindungen:
          Den kann man überschreiben.
          Kopier da halt
          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          rein. Ohne Leerzeichen davor oder dahinter.
          • Asgothian
            Asgothian Developer @alexzi last edited by
            @alexzi Please test this:
            • stop the adapter
            • unplug the stick
            • rename the file nvbackup.json to nvbackup.old
            • plug the stick in
            • start the adapter
            • try to switch the test plug
            • post the log
            A.
              @asgothian
              2025-02-06 15:14:24.682 - info: zigbee.0 (3396) Zigbee started
              2025-02-06 15:14:25.136 - info: zigbee.0 (3396) debug devices set to ["84ba20fffe77b850"]
              2025-02-06 15:14:25.890 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"available":true}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
              2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated 'true' from device 84ba20fffe77b850 for 'Available'
              2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":10}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
              2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated '10' from device 84ba20fffe77b850 for 'Link quality'
              2025-02-06 15:15:07.510 - warn: zigbee.0 (3396) ELEVATED O1: User state change of state zigbee.0.84ba20fffe77b850.state with value false (ack: false) from system.adapter.admin.0
              2025-02-06 15:15:07.517 - warn: zigbee.0 (3396) ELEVATED O2: Change state 'state' at device 0x84ba20fffe77b850 type 'TS011F_plug_3'
              2025-02-06 15:15:07.524 - warn: zigbee.0 (3396) ELEVATED O3C: Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]}
              2025-02-06 15:15:07.526 - warn: zigbee.0 (3396) ELEVATED O4: convert state, "OFF", {} for device 0x84ba20fffe77b850 with Endpoint state
                alexzi @alexzi last edited by
                2025-02-06 15:15:59.296 - info: zigbee.0 (3396) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
                2025-02-06 15:16:00.674 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":51,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:00.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":51}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:00.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '51' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:00.875 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:01.077 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:01.271 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:01.470 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:01.676 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:01.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:01.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:01.876 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:02.070 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:02.272 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:02.284 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:02.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:02.468 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:02.480 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:02.481 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:02.669 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:02.866 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:02.878 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:02.879 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:03.068 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:03.123 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:03.124 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:03.265 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:03.477 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
                2025-02-06 15:16:03.490 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
                2025-02-06 15:16:03.491 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
                2025-02-06 15:16:26.028 - info: admin.0 (909) <== Disconnect system.user.admin from ::ffff:10.100.200.45
                • Asgothian
                  @alexzi Dann sehe ich aktuell nur die Möglichkeit das du auf den Adapter Version 1.10.3 zurück gehst.
                  A.
                    @asgothian
                    ich heul.
                    hab jetzt mit npm install iobroker.zigbee@1.10.3 ein Downgrade gemacht.
                    Jetzt geht gar nichts mehr.
                    iobroker fix schon gemacht
                    diag sag 1.10.3 installiert
                    uffff
                    tut mir echt leid, dass ich nicht weiterkomme und euch auf den Nerv gehe
                    2025-02-06 18:07:18.159 - error: zigbee.0 (3168) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Failed to start Zigbee
                    2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Error herdsman start
                    Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                      Macht man ja auch nicht so...
                      iob upgrade adapter@ziel.vers.ion
                      ist der bessere Weg.
                      • Asgothian
                        uffff
                        Such mal bitte die korrekte Fehlermeldung. Die die du gepostet hast ist eine Folgemeldung, die beim 2. oder 3. Startversuch entsteht.
                        A.
                          oh Mann, wieder Layer 8, grrr
                          gemacht, Meldung kam, sauber installiert. geht aber immer noch nicht
                            @asgothian
                            meinst du das?
                            2025-02-06 18:45:11.091 - info: zigbee.0 (6526) Starting Zigbee npm ...
                            2025-02-06 18:45:11.449 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                            2025-02-06 18:45:12.127 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                            2025-02-06 18:45:12.128 - error: zigbee.0 (6526) Failed to start Zigbee
                            2025-02-06 18:45:12.129 - error: zigbee.0 (6526) Error herdsman start
                            2025-02-06 18:45:22.133 - info: zigbee.0 (6526) Try to reconnect. 1 attempts left
                            2025-02-06 18:45:22.136 - info: zigbee.0 (6526) Starting Zigbee npm ...
                            2025-02-06 18:45:22.175 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                            2025-02-06 18:45:22.337 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                            2025-02-06 18:45:22.338 - error: zigbee.0 (6526) Failed to start Zigbee
                            2025-02-06 18:45:22.339 - error: zigbee.0 (6526) Error herdsman start
                            • Asgothian
                              @alexzi bitte nochmal
                              • adapter anhalten
                              • stick abziehen
                              • 30 sekunden warten
                              • stick anstecken
                              • die nvbackup.json Datei löschen
                              • adapter starten
                              Dann sollte es gehen
                                @asgothian HALLELUJA Adapter läuft, Testschaltung hat auch funktioniert. DANKE
                                ich warte noch bis morgen, wenn es soweit ok aussieht, dann setze ich den Thread auf Gelöst
                                @Thomas-Braun Dir auch vielen Dank
                                • Asgothian
                                  @alexzi kannst du mit die shepherd.db hier zukommen lassen ? ich will nach etwas schauen
                                  A.
                                  1306
