    4. Zigbee, keine Aktion und keinerlei Verbindungen
      alexzi @Asgothian last edited by
      @asgothian
      2025-02-06 15:14:24.682 - info: zigbee.0 (3396) Zigbee started
      2025-02-06 15:14:25.136 - info: zigbee.0 (3396) debug devices set to ["84ba20fffe77b850"]
      2025-02-06 15:14:25.890 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"available":true}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated 'true' from device 84ba20fffe77b850 for 'Available'
      2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":10}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:14:25.891 - warn: zigbee.0 (3396) ELEVATED I2: value generated '10' from device 84ba20fffe77b850 for 'Link quality'
      2025-02-06 15:15:07.510 - warn: zigbee.0 (3396) ELEVATED O1: User state change of state zigbee.0.84ba20fffe77b850.state with value false (ack: false) from system.adapter.admin.0
      2025-02-06 15:15:07.517 - warn: zigbee.0 (3396) ELEVATED O2: Change state 'state' at device 0x84ba20fffe77b850 type 'TS011F_plug_3'
      2025-02-06 15:15:07.524 - warn: zigbee.0 (3396) ELEVATED O3C: Setting' converter to converter with key(s)'["state","on_time","off_wait_time"]}
      2025-02-06 15:15:07.526 - warn: zigbee.0 (3396) ELEVATED O4: convert state, "OFF", {} for device 0x84ba20fffe77b850 with Endpoint state
        alexzi @alexzi last edited by
        2025-02-06 15:15:59.296 - info: zigbee.0 (3396) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
        2025-02-06 15:16:00.674 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":51,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:00.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":51}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:00.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '51' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:00.875 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:00.887 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:01.077 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:01.091 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:01.271 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:01.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:01.470 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:01.482 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:01.676 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:01.687 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:01.688 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:01.876 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:01.889 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:02.070 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:02.082 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:02.272 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:02.284 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:02.285 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:02.468 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":58,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:02.480 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":58}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:02.481 - warn: zigbee.0 (3396) ELEVATED I2: value generated '58' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:02.669 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:02.681 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:02.866 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:02.878 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:02.879 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:03.068 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:03.123 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:03.124 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:03.265 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:03.319 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:03.477 - warn: zigbee.0 (3396) ELEVATED I0: Zigbee Event of Type attributeReport from device "0x84ba20fffe77b850", incoming event: {"type":"attributeReport","device":"0x84ba20fffe77b850","endpoint":1,"data":{"65506":31,"65508":0,"appVersion":69},"linkquality":54,"groupID":0,"cluster":"genBasic"}
        2025-02-06 15:16:03.490 - warn: zigbee.0 (3396) ELEVATED I1: message received '{"linkquality":54}' from device 84ba20fffe77b850 type 'TS011F_plug_3'
        2025-02-06 15:16:03.491 - warn: zigbee.0 (3396) ELEVATED I2: value generated '54' from device 84ba20fffe77b850 for 'Link quality'
        2025-02-06 15:16:26.028 - info: admin.0 (909) <== Disconnect system.user.admin from ::ffff:10.100.200.45
        • Asgothian
          Asgothian Developer @alexzi last edited by
          @alexzi Dann sehe ich aktuell nur die Möglichkeit das du auf den Adapter Version 1.10.3 zurück gehst.
          A.
            @asgothian
            ich heul.
            hab jetzt mit npm install iobroker.zigbee@1.10.3 ein Downgrade gemacht.
            Jetzt geht gar nichts mehr.
            iobroker fix schon gemacht
            diag sag 1.10.3 installiert
            uffff
            tut mir echt leid, dass ich nicht weiterkomme und euch auf den Nerv gehe
            2025-02-06 18:07:18.159 - error: zigbee.0 (3168) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
            2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Failed to start Zigbee
            2025-02-06 18:07:18.161 - error: zigbee.0 (3168) Error herdsman start
            Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @alexzi last edited by
              @alexzi sagte in Zigbee, keine Aktion und keinerlei Verbindungen:
              Macht man ja auch nicht so...
              iob upgrade adapter@ziel.vers.ion
              ist der bessere Weg.
              • Asgothian
                uffff
                Such mal bitte die korrekte Fehlermeldung. Die die du gepostet hast ist eine Folgemeldung, die beim 2. oder 3. Startversuch entsteht.
                A.
                  oh Mann, wieder Layer 8, grrr
                  gemacht, Meldung kam, sauber installiert. geht aber immer noch nicht
                    @asgothian
                    meinst du das?
                    2025-02-06 18:45:11.091 - info: zigbee.0 (6526) Starting Zigbee npm ...
                    2025-02-06 18:45:11.449 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                    2025-02-06 18:45:12.127 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                    2025-02-06 18:45:12.128 - error: zigbee.0 (6526) Failed to start Zigbee
                    2025-02-06 18:45:12.129 - error: zigbee.0 (6526) Error herdsman start
                    2025-02-06 18:45:22.133 - info: zigbee.0 (6526) Try to reconnect. 1 attempts left
                    2025-02-06 18:45:22.136 - info: zigbee.0 (6526) Starting Zigbee npm ...
                    2025-02-06 18:45:22.175 - info: zigbee.0 (6526) Installed Version: iobroker.zigbee@1.10.3
                    2025-02-06 18:45:22.337 - error: zigbee.0 (6526) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                    2025-02-06 18:45:22.338 - error: zigbee.0 (6526) Failed to start Zigbee
                    2025-02-06 18:45:22.339 - error: zigbee.0 (6526) Error herdsman start
                    • Asgothian
                      @alexzi bitte nochmal
                      • adapter anhalten
                      • stick abziehen
                      • 30 sekunden warten
                      • stick anstecken
                      • die nvbackup.json Datei löschen
                      • adapter starten
                      Dann sollte es gehen
                        @asgothian HALLELUJA Adapter läuft, Testschaltung hat auch funktioniert. DANKE
                        ich warte noch bis morgen, wenn es soweit ok aussieht, dann setze ich den Thread auf Gelöst
                        @Thomas-Braun Dir auch vielen Dank
                        • Asgothian
                          @alexzi kannst du mit die shepherd.db hier zukommen lassen ? ich will nach etwas schauen
                          A.
                          1306
