    4. Node-Red
    5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
      MartyBr @mickym last edited by
      @mickym
      Jetzt bin auf den Geschmack gekommen. Ich habe jetzt versucht, einen JSON-Datenpunkt anzulegen. Das sieht auf dem ersten Blick auch gut aus. In kann aber im Objektbaum ioBroker die Daten nicht öffnen bzw. bearbeiten.
      Hier mal die Infos:
      Datensatz:
      Flow:
              "id": "ae673cf6cd8433a0",
              "type": "subflow",
              "name": "Datum in Topic",
              "info": "",
              "category": "",
              "in": [
                      "x": 60,
                      "y": 80,
                      "wires": [
                              "id": "2e1ea06b2e94bf1a"
              "out": [
                      "x": 820,
                      "y": 80,
                      "wires": [
                              "id": "fc37f5f9d2b0297b",
                              "port": 0
              "env": [
                      "name": "basePath",
                      "type": "str",
                      "value": "Test1.Test2"
              "meta": {},
              "color": "#DDAA99"
              "id": "2e1ea06b2e94bf1a",
              "type": "change",
              "z": "ae673cf6cd8433a0",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "datum",
                      "pt": "msg",
                      "to": "$moment().locale('de').format('YYYY.MMMM')",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 80,
              "wires": [
                      "0e8de9437c3c420a"
              "id": "0e8de9437c3c420a",
              "type": "change",
              "name": "März zu Maerz",
              "rules": [
                      "t": "change",
                      "p": "datum",
                      "pt": "msg",
                      "from": "März",
                      "fromt": "str",
                      "to": "Maerz",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 440,
              "y": 80,
              "wires": [
                      "fc37f5f9d2b0297b"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 660,
              "y": 80,
              "wires": [
              "id": "fad92726ff7c3254",
              "type": "tab",
              "label": "JSON",
              "disabled": false,
              "info": "",
              "env": []
              "id": "29a754f2b7a96a31",
              "type": "mqtt in",
              "z": "fad92726ff7c3254",
              "name": "ZuluftTemp",
              "topic": "vitocal/ZuluftTemp",
              "qos": "0",
              "datatype": "auto-detect",
              "broker": "bf311140.13d2b8",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 100,
              "y": 120,
              "wires": [
                      "5026b4d763ed7dcc"
              "id": "535565225c8e6f99",
              "type": "subflow:ae673cf6cd8433a0",
              "env": [
                      "name": "basePath",
                      "value": "Test1.Test7",
                      "type": "str"
              "x": 780,
              "y": 180,
              "wires": [
                      "05ad3c7ae6fe582b",
                      "9c9e217c842acefc"
              "id": "05ad3c7ae6fe582b",
              "type": "ioBroker out",
              "name": "",
              "topic": "",
              "ack": "true",
              "autoCreate": "true",
              "stateName": "zuluft-neu",
              "role": "state",
              "payloadType": "object",
              "readonly": "",
              "stateUnit": "°C",
              "stateMin": "",
              "stateMax": "",
              "x": 980,
              "y": 180,
              "wires": []
              "id": "5026b4d763ed7dcc",
              "type": "change",
              "name": "Zuluft",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Zuluft-Temp",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 310,
              "y": 120,
              "wires": [
                      "766be49e74305196"
              "id": "a3c1535e1da94552",
              "type": "mqtt in",
              "name": "AbluftTemp",
              "topic": "vitocal/AbluftTemp",
              "qos": "0",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 110,
              "y": 240,
              "wires": [
                      "225419c87f910c3e"
              "id": "225419c87f910c3e",
              "type": "change",
              "name": "Abluft",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Abluft-Temp",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 310,
              "y": 240,
              "wires": [
                      "766be49e74305196"
              "id": "766be49e74305196",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "property": "payload",
              "propertyType": "msg",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": true,
              "timeout": "60",
              "count": "2",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 430,
              "y": 180,
              "wires": [
                      "dd61fc92c8961b14",
                      "457c8ae43cf33de1"
              "id": "224380ff0709c559",
              "type": "json",
              "name": "",
              "action": "",
              "pretty": true,
              "x": 610,
              "y": 180,
              "wires": [
                      "c828c8f4b32a9c0c",
                      "535565225c8e6f99"
              "id": "dd61fc92c8961b14",
              "type": "debug",
              "name": "debug 174",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "statusType": "auto",
              "x": 510,
              "y": 80,
              "wires": []
              "id": "c828c8f4b32a9c0c",
              "type": "debug",
              "name": "debug 175",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 710,
              "y": 100,
              "wires": []
              "id": "9c9e217c842acefc",
              "type": "debug",
              "name": "debug 176",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 950,
              "y": 100,
              "wires": []
              "id": "457c8ae43cf33de1",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "vitovent300",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 540,
              "y": 300,
              "wires": [
                      "224380ff0709c559",
                      "f92533e2c4de9cf4"
              "id": "f92533e2c4de9cf4",
              "type": "debug",
              "name": "debug 177",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 730,
              "y": 360,
              "wires": []
              "id": "bf311140.13d2b8",
              "type": "mqtt-broker",
              "name": "Mosquito-Server",
              "broker": "192.168.178.10",
              "port": "1883",
              "clientid": "",
              "autoConnect": true,
              "usetls": false,
              "compatmode": false,
              "protocolVersion": "4",
              "keepalive": "60",
              "cleansession": true,
              "autoUnsubscribe": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Müssen evtl eckige Klammern um den Jason gesetzt werden (also [json]?
      • mickym
        mickym Most Active @MartyBr last edited by mickym
        @martybr Na den Datenpunkt hast Du wahrscheinlich schreibgeschützt angelegt - siehst Du doch an dem Schloss. Musst Du wahrscheinlich beschreibbar machen, in der iobroker-Out Node. Oder im Nachhinein in den Objekteigenschaften des Datenpunktes.
        Ausserdem empfehle ich Dir - keinen Datentyp festzulegen - das macht die NOde selbst und wie gesagt musst Du es beschreibbar anlegen.
        Ja und wie gesagt - Objekte muss man als Strings - also JSON Strings schreiben und auch wieder in Objekte wandeln.
        iobroker kann nur Strings in den States verarbeiten.
        • mickym
          @martybr Es geht auch als Objekt zu öffnen - aber muss halt beschreibbar sein.
          Und wenn Du es nicht als Objekt, sondern richtig als String festlegst (wie gesagt normalerweise legt man nichts fest, dann wird automatisch der richtige Typ festgelegt), dann macht er auch einen JSON daraus:
          Grundsätzlich würde ich mir übrigens angewöhnen, die JSON Node immer direkt vor die Ausgabe in die iobroker-out -Node zu machen, damit man solange wie möglich mit Objekten arbeiten kann.
            @mickym
            Okay, setze ich um.
              @mickym
              Funktioniert jetzt.
              Hast du noch eine Idee wie ich die eckigen Klammern um den Datensatz setzen kann? Mit einem Change-Node?
              • mickym
                @martybr Eckige Klammern sind ein Array oder in Blockly Chargon eine Liste - Ja Du kannst einfach ein Array mit eckigen Klammern daraus machen - macht aber nur Sinn, wenn Du dann mehrere Objekte im Array hast.
                Selbstverstöndlich kannst Du ein Objekt in ein Array stellen. Wenn Du aber mehrere Objekte in ein Array machen mächtest, dann nutze die $append Funktion.
                Du solltest Dir angewöhnen - nie KLammern zu bezeichen, sondern was für Objekte Du erstellen möchtest.
                  @mickym
                  Okay. das ist mein Ziel. Ich möchte Tageswerte in ein Monatsarray speichern. Das mit den Klammern hat funktioniert.
                  Über Arrays muss ich mich erst kundig machen.
                  Ziel ist, um 00:00 Uhr generierte Werte in ein Monatsarray zu speichern.
                  Ich bereite mal einen Versuch vor.
                  • mickym
                    @martybr Dann nimm die $append Funktion
                    Hier zum Ausprobieren:
                           "id": "1db807e2530b5198",
                           "type": "change",
                           "z": "7e6af0015415146d",
                           "name": "Vorhandenes Array",
                           "rules": [
                                   "t": "set",
                                   "p": "array",
                                   "pt": "msg",
                                   "to": "[{\"Zuluft-Temp\":20.1,\"Abluft-Temp\":20.9},{\"Zuluft-Temp\":21.1,\"Abluft-Temp\":22.9}]",
                                   "tot": "json"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 410,
                           "y": 6500,
                           "wires": [
                                   "16c668ac241e55c4"
                           "id": "86b4268438857773",
                           "type": "inject",
                           "name": "Einzelnes Objekt",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "{     \"Zuluft-Temp\": 20.1,     \"Abluft-Temp\": 20.9 }",
                           "payloadType": "json",
                           "x": 180,
                           "y": 6500,
                           "wires": [
                                   "1db807e2530b5198"
                           "id": "16c668ac241e55c4",
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "$append(array, payload)",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 630,
                           "y": 6500,
                           "wires": [
                                   "c9cfdb97d8474804"
                           "id": "c9cfdb97d8474804",
                           "type": "debug",
                           "name": "Neues Array",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "complete": "payload",
                           "targetType": "msg",
                           "statusVal": "",
                           "x": 850,
                           "y": 6500,
                           "wires": []
                      MartyBr @mickym last edited by MartyBr
                      @mickym
                      das Array wird nach meinem Test nicht aufgefüllt, es bleibt immer nur ein Wert im Array.
                      Die $append scheint nicht zu wirken.
                              "id": "a0d8740faea1647b",
                              "type": "mqtt in",
                              "z": "5c488c180ba51f18",
                              "qos": "0",
                              "nl": false,
                              "rap": true,
                              "rh": 0,
                              "inputs": 0,
                              "x": 140,
                              "y": 260,
                              "wires": [
                                      "afdcb37ccbacb06f"
                              "id": "afdcb37ccbacb06f",
                              "type": "change",
                              "name": "Zuluft",
                              "rules": [
                                      "t": "set",
                                      "p": "topic",
                                      "pt": "msg",
                                      "to": "zuluft",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 290,
                              "y": 320,
                              "wires": [
                                      "1643873aeecd8613"
                              "id": "1643873aeecd8613",
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "array",
                                      "pt": "msg",
                                      "to": "[]",
                                      "tot": "json"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 280,
                              "wires": [
                                      "c9d97aec2949301c",
                                      "34c8064e4b5c52fa"
                              "id": "34c8064e4b5c52fa",
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "jsonata"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 610,
                              "y": 340,
                              "wires": [
                                      "5b551b24fc1bb26e"
                              "id": "5b551b24fc1bb26e",
                              "type": "debug",
                              "name": "debug 179",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 750,
                              "y": 280,
                              "wires": []
                              "id": "c9d97aec2949301c",
                              "type": "debug",
                              "name": "debug 178",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 710,
                              "y": 160,
                              "wires": []
                              "port": "1883",
                              "clientid": "",
                              "usetls": false,
                              "keepalive": "60",
                              "birthTopic": "",
                              "birthQos": "0",
                              "birthPayload": "",
                              "birthMsg": {},
                              "closeTopic": "",
                              "closeQos": "0",
                              "closePayload": "",
                              "closeMsg": {},
                              "willTopic": "",
                              "willQos": "0",
                              "willPayload": "",
                              "willMsg": {},
                              "userProps": "",
                              "sessionExpiry": ""
                      Was mache ich falsch?
                      Edit:
                      Als Ziel benötige ich für die 4 Werte jeweils ein Array mit
                      Wert1,
                      Wert2,
                      Wert3,
                      Wert28
                      Anzahl der Werte entspricht der Zahl der Tage im laufenden Monat.
                      • mickym
                        @martybr Na Du mergst ein leeres Array mit einem skalaren Wert. Dann ist es doch richtig, dass nur ein Wert in dem Array ist. Du musst das Array ja speichern und dann den nächsten Wert anhängen.
                        So hängst Du doch immer wieder nur EIN Wert an ein leeres Array. Du musst doch das Array irgendwo abspeichern und dann das neu erstellte Array mit einem neuen Wert ergänzen.
                        Also überleg Dir wohin Du Dein Array Ergebnis des Anhänges abspeichern willst. In einer Variable oder in einem Datenpunkt.
                        Oder mit anderen Worten: Ein Wert an ein leeres Array angehängt, gibt immer nur ein Array mit einem Wert.
                          @mickym
                          Okay, das ist ein Ansatzpunkt. Ich mache mir mal Gedanken.
                          Danke für deine Unterstützung.
                          • mickym
                            @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
                            @mickym
                            Ich habs Dir mal mit eine Flowvariable gemacht. Das heißt das Ergebnis wird in eine Variable gespeichert und dann wieder eingelesen und der neue Wert angehängt.
                                   "type": "mqtt in",
                                   "d": true,
                                   "qos": "0",
                                   "nl": false,
                                   "rap": true,
                                   "rh": 0,
                                   "inputs": 0,
                                   "x": 260,
                                   "y": 6740,
                                   "wires": [
                                           "afdcb37ccbacb06f"
                                   "type": "change",
                                   "name": "Zuluft",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "to": "zuluft",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 410,
                                   "y": 6800,
                                   "wires": [
                                           "1643873aeecd8613"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "array",
                                           "pt": "msg",
                                           "to": "array",
                                           "tot": "flow"
                                           "t": "set",
                                           "p": "array",
                                           "pt": "msg",
                                           "to": "array ? array : []",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 610,
                                   "y": 6760,
                                   "wires": [
                                           "c9d97aec2949301c",
                                           "34c8064e4b5c52fa"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                           "t": "set",
                                           "p": "array",
                                           "pt": "flow",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 6760,
                                   "wires": [
                                           "5b551b24fc1bb26e"
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1070,
                                   "y": 6740,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 830,
                                   "y": 6640,
                                   "wires": []
                                   "id": "7961970716d0df25",
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "20.2",
                                   "payloadType": "num",
                                   "x": 230,
                                   "y": 6800,
                                   "wires": [
                                           "afdcb37ccbacb06f"
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "birthTopic": "",
                                   "birthQos": "0",
                                   "birthPayload": "",
                                   "birthMsg": {},
                                   "closeTopic": "",
                                   "closeQos": "0",
                                   "closePayload": "",
                                   "closeMsg": {},
                                   "willTopic": "",
                                   "willQos": "0",
                                   "willPayload": "",
                                   "willMsg": {},
                                   "userProps": "",
                                   "sessionExpiry": ""
                              @mickym
                              Der Flow funktioniert.
                              Ich habe eine Objektveriable in ioBroker.
                                     "type": "mqtt in",
                                     "d": true,
                                     "qos": "0",
                                     "nl": false,
                                     "rap": true,
                                     "rh": 0,
                                     "inputs": 0,
                                     "x": 260,
                                     "y": 6740,
                                     "wires": [
                                             "afdcb37ccbacb06f"
                                     "type": "change",
                                     "name": "Zuluft",
                                     "rules": [
                                             "t": "set",
                                             "p": "topic",
                                             "pt": "msg",
                                             "to": "zuluft",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 410,
                                     "y": 6800,
                                     "wires": [
                                             "1643873aeecd8613"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "array",
                                             "pt": "msg",
                                             "to": "array",
                                             "tot": "flow"
                                             "t": "set",
                                             "p": "array",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 610,
                                     "y": 6760,
                                     "wires": [
                                             "c9d97aec2949301c",
                                             "34c8064e4b5c52fa"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                             "t": "set",
                                             "p": "array",
                                             "pt": "flow",
                                             "to": "payload",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 850,
                                     "y": 6760,
                                     "wires": [
                                             "5b551b24fc1bb26e"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1070,
                                     "y": 6740,
                                     "wires": []
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 830,
                                     "y": 6640,
                                     "wires": []
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "20.2",
                                     "x": 230,
                                     "y": 6800,
                                     "wires": [
                                             "afdcb37ccbacb06f"
                                     "port": "1883",
                                     "clientid": "",
                                     "usetls": false,
                                     "keepalive": "60",
                                     "birthTopic": "",
                                     "birthQos": "0",
                                     "birthPayload": "",
                                     "birthMsg": {},
                                     "closeTopic": "",
                                     "closeQos": "0",
                                     "closePayload": "",
                                     "closeMsg": {},
                                     "willTopic": "",
                                     "willQos": "0",
                                     "willPayload": "",
                                     "willMsg": {},
                                     "userProps": "",
                                     "sessionExpiry": ""
                              Wie kann ich das Array persistent ablegen?
                              • mickym
                                @martybr
                                Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
                                  @mickym
                                  Ich habe das mal so gemacht:
                                          "id": "99d066d4bbe5dca9",
                                          "type": "inject",
                                          "name": "",
                                          "props": [
                                                  "p": "payload"
                                          "repeat": "",
                                          "crontab": "",
                                          "once": false,
                                          "onceDelay": 0.1,
                                          "topic": "",
                                          "payload": "20.2",
                                          "x": 350,
                                          "y": 700,
                                          "wires": [
                                                  "994a1a0b6d25cef4"
                                          "id": "82d5f1b2aa875c35",
                                          "type": "mqtt in",
                                          "qos": "0",
                                          "nl": false,
                                          "rap": true,
                                          "rh": 0,
                                          "inputs": 0,
                                          "x": 420,
                                          "y": 620,
                                          "wires": [
                                                  "994a1a0b6d25cef4"
                                          "id": "994a1a0b6d25cef4",
                                          "type": "change",
                                          "name": "Zuluft",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "topic",
                                                  "pt": "msg",
                                                  "to": "zuluft",
                                                  "tot": "str"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 530,
                                          "y": 700,
                                          "wires": [
                                                  "4a49f7b7cb1d35d2"
                                          "id": "de7a183e542f367e",
                                          "type": "ioBroker get object",
                                          "name": "Test.Test-JSON",
                                          "topic": "0_userdata.0.Test.Test-JSON",
                                          "attrname": "array",
                                          "x": 620,
                                          "y": 580,
                                          "wires": [
                                          "id": "4a49f7b7cb1d35d2",
                                          "type": "change",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "array",
                                                  "pt": "msg",
                                                  "to": "array",
                                                  "tot": "flow"
                                                  "t": "set",
                                                  "p": "array",
                                                  "pt": "msg",
                                                  "tot": "jsonata"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 730,
                                          "y": 660,
                                          "wires": [
                                                  "1bf56806da8b2399",
                                                  "40df7a89751f5b92"
                                          "id": "40df7a89751f5b92",
                                          "type": "change",
                                          "name": "",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "payload",
                                                  "pt": "msg",
                                                  "tot": "jsonata"
                                                  "t": "set",
                                                  "p": "array",
                                                  "pt": "flow",
                                                  "to": "payload",
                                                  "tot": "msg"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 830,
                                          "y": 740,
                                          "wires": [
                                                  "cb026a3b7a51d987",
                                                  "8d9b65f4efb22698"
                                          "id": "cb026a3b7a51d987",
                                          "type": "debug",
                                          "active": true,
                                          "tosidebar": true,
                                          "console": false,
                                          "tostatus": false,
                                          "statusVal": "",
                                          "x": 890,
                                          "y": 800,
                                          "wires": []
                                          "id": "8d9b65f4efb22698",
                                          "ack": "true",
                                          "autoCreate": "false",
                                          "stateName": "",
                                          "role": "",
                                          "payloadType": "",
                                          "readonly": "",
                                          "stateUnit": "",
                                          "stateMin": "",
                                          "stateMax": "",
                                          "x": 1000,
                                          "y": 660,
                                          "wires": []
                                          "id": "1bf56806da8b2399",
                                          "type": "debug",
                                          "active": true,
                                          "tosidebar": true,
                                          "console": false,
                                          "tostatus": false,
                                          "statusVal": "",
                                          "x": 950,
                                          "y": 540,
                                          "wires": []
                                          "port": "1883",
                                          "clientid": "",
                                          "usetls": false,
                                          "keepalive": "60",
                                          "birthTopic": "",
                                          "birthQos": "0",
                                          "birthPayload": "",
                                          "birthMsg": {},
                                          "closeTopic": "",
                                          "closeQos": "0",
                                          "closePayload": "",
                                          "closeMsg": {},
                                          "willTopic": "",
                                          "willQos": "0",
                                          "willPayload": "",
                                          "willMsg": {},
                                          "userProps": "",
                                          "sessionExpiry": ""
                                  Die Werte kommen auch richtig im Datenpunkt an.
                                  Jetzt noch eine letzte Frage für Heute 😇
                                  Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
                                  Edit:
                                  Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
                                  • mickym
                                    Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
                                      @mickym
                                      Ich habe es noch nicht so ganz verstanden. Ich habe es nun so gebaut, wie ich es verstanden habe. Exemplarisch für zwei Flows / Arrays:
                                              "id": "5bbdcd58332d0b96",
                                              "type": "ioBroker in",
                                              "name": "Bezug täglich",
                                              "attrname": "payload",
                                              "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
                                              "payloadType": "value",
                                              "onlyack": "",
                                              "func": "all",
                                              "gap": "",
                                              "fireOnStart": "true",
                                              "outFormat": "MQTT",
                                              "x": 110,
                                              "y": 40,
                                              "wires": [
                                                      "53d6131492b2abed"
                                              "id": "4bb406f8dd2161dd",
                                              "name": "Einspeisung täglich",
                                              "topic": "0_userdata.0.Zaehler.Stromeinspeisung.Verbrauch.täglich",
                                              "onlyack": "",
                                              "func": "all",
                                              "gap": "",
                                              "x": 130,
                                              "y": 120,
                                              "wires": [
                                                      "c4e24a8d35d070ae"
                                              "id": "c4e24a8d35d070ae",
                                              "type": "change",
                                              "name": "Einspeisung",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "einspeisung",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 330,
                                              "y": 120,
                                              "wires": [
                                                      "278bac26e6737147"
                                              "id": "53d6131492b2abed",
                                              "type": "change",
                                              "name": "Bezug",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "bezug",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 270,
                                              "y": 40,
                                              "wires": [
                                                      "c617a78f8ddaca22"
                                              "id": "c617a78f8ddaca22",
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "array-bezug",
                                                      "pt": "msg",
                                                      "to": "array-bezug",
                                                      "tot": "flow"
                                                      "t": "set",
                                                      "p": "array-bezug",
                                                      "pt": "msg",
                                                      "to": "array-bezug ? array-bezug : []",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 450,
                                              "y": 40,
                                              "wires": [
                                                      "ff519a511afeb6f1"
                                              "id": "ff519a511afeb6f1",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "$append(array-bezug, payload)",
                                                      "tot": "jsonata"
                                                      "t": "set",
                                                      "p": "array-bezug",
                                                      "pt": "flow",
                                                      "to": "payload",
                                                      "tot": "msg"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 670,
                                              "y": 40,
                                              "wires": [
                                                      "3274ac485bf96d56"
                                              "id": "3274ac485bf96d56",
                                              "name": "Test.Bezug-JSON",
                                              "topic": "0_userdata.0.Test.Bezug-JSON",
                                              "ack": "true",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "readonly": "false",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 890,
                                              "y": 40,
                                              "wires": []
                                              "id": "278bac26e6737147",
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "array-einspeisung",
                                                      "pt": "msg",
                                                      "to": "array-einspeisung",
                                                      "tot": "flow"
                                                      "t": "set",
                                                      "pt": "msg",
                                                      "to": "array-einspeisung ? array-einspeisung : []",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 530,
                                              "y": 120,
                                              "wires": [
                                                      "27eb027a108b6b2a"
                                              "id": "27eb027a108b6b2a",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "$append(array-einspeisung, payload)",
                                                      "tot": "jsonata"
                                                      "t": "set",
                                                      "pt": "flow",
                                                      "to": "payload",
                                                      "tot": "msg"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 750,
                                              "y": 120,
                                              "wires": [
                                                      "8c3a9cbe90f64091"
                                              "id": "8c3a9cbe90f64091",
                                              "name": "Test.Einspeisung-JSON",
                                              "topic": "0_userdata.0.Test.Einspeisung-JSON",
                                              "ack": "true",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 990,
                                              "y": 120,
                                              "wires": []
                                      Die Daten aktualisieren sich täglich. Wenn das in Ordnung ist, dann gehe ich an die Zeitsteuerung.
                                        @mickym
                                        Ich habe hier noch ein Problem, die Zahl der Tage im Monat in eine globale Variable zu schreiben. Statt der 28 Tage aus der Funktion liefert mir der Change Node nur payload == 5
                                                "id": "f6ed836d74798c7f",
                                                "type": "inject",
                                                "z": "3ebdbbcf49e0ac40",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "",
                                                "payloadType": "date",
                                                "x": 100,
                                                "y": 400,
                                                "wires": [
                                                        "a3434007e702fcdc"
                                                "id": "7a09df47bef16411",
                                                "type": "function",
                                                "name": "function 1",
                                                "func": "// Eingabe: msg.payload sollte ein Datum im Format 'YYYY-MM-DD' sein\nlet inputDate = new Date(msg.payload);\n\n// Hole den Monat und das Jahr\nlet month = inputDate.getMonth(); // 0-11\nlet year = inputDate.getFullYear();\n\n// Berechne die Anzahl der Tage im Monat\nlet daysInMonth = new Date(year, month + 1, 0).getDate();\n\n// Setze das Ergebnis in msg.payload\nmsg.payload = daysInMonth;\n\nreturn msg;",
                                                "outputs": 1,
                                                "timeout": 0,
                                                "noerr": 0,
                                                "initialize": "",
                                                "finalize": "",
                                                "libs": [],
                                                "x": 480,
                                                "y": 400,
                                                "wires": [
                                                        "599b66169127c12d",
                                                        "185c42081279a5e0"
                                                "id": "a3434007e702fcdc",
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "$moment().locale('de').format('YYYY.MM.DD')",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 290,
                                                "y": 400,
                                                "wires": [
                                                        "7a09df47bef16411"
                                                "id": "d8d647f4ae028cb8",
                                                "type": "debug",
                                                "name": "debug 182",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 670,
                                                "y": 320,
                                                "wires": []
                                                "id": "599b66169127c12d",
                                                "type": "change",
                                                "name": "Monatstage",
                                                "rules": [
                                                        "t": "move",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "monatstage",
                                                        "tot": "global"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 650,
                                                "y": 400,
                                                "wires": [
                                                        "d8d647f4ae028cb8"
                                                "id": "185c42081279a5e0",
                                                "type": "debug",
                                                "name": "debug 183",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 590,
                                                "y": 480,
                                                "wires": []
                                        M mickym 2 Replies Last reply Reply Quote 0
                                          MartyBr @MartyBr last edited by
                                          @mickym
                                          Ich glaube, dass ich das Problem gelöst habe:
                                                  "type": "inject",
                                                  "name": "",
                                                  "props": [
                                                          "p": "payload"
                                                          "p": "topic",
                                                          "vt": "str"
                                                  "repeat": "",
                                                  "crontab": "",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "topic": "",
                                                  "payload": "",
                                                  "x": 100,
                                                  "y": 400,
                                                  "wires": [
                                                          "a3434007e702fcdc"
                                                  "type": "function",
                                                  "outputs": 1,
                                                  "timeout": 0,
                                                  "noerr": 0,
                                                  "initialize": "",
                                                  "finalize": "",
                                                  "libs": [],
                                                  "x": 480,
                                                  "y": 400,
                                                  "wires": [
                                                          "599b66169127c12d"
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 290,
                                                  "y": 400,
                                                  "wires": [
                                                          "7a09df47bef16411"
                                                  "type": "debug",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 650,
                                                  "y": 340,
                                                  "wires": []
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "payload",
                                                          "tot": "msg"
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "monatstage",
                                                          "tot": "global"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 650,
                                                  "y": 400,
                                                  "wires": [
                                                          "d8d647f4ae028cb8"
                                                  "type": "debug",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 450,
                                                  "y": 460,
                                                  "wires": []
                                                  "id": "5f695a4b2b007db0",
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "monatstage",
                                                          "tot": "global"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 270,
                                                  "y": 460,
                                                  "wires": [
                                                          "185c42081279a5e0"
                                                  "id": "0191af1c60e06008",
                                                  "type": "inject",
                                                  "name": "",
                                                  "props": [
                                                          "p": "payload"
                                                          "p": "topic",
                                                          "vt": "str"
                                                  "repeat": "",
                                                  "crontab": "",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "topic": "",
                                                  "payload": "",
                                                  "x": 100,
                                                  "y": 460,
                                                  "wires": [
                                                          "5f695a4b2b007db0"
                                          Kannst du bitte mal darüber schauen?
                                            @mickym
                                            Ich habe hier noch einen Fehler im Flow. Ich habe nun die dynamische Datumsablage hinzugefügt und den iobroker out entsprechend geändert. Der Datenpunkt wird auch angelegt, aber als "number" und nicht als Array (mit [Wert1, Wert2,...].
                                                    "type": "subflow",
                                                    "info": "",
                                                    "category": "",
                                                    "in": [
                                                            "x": 60,
                                                            "y": 80,
                                                            "wires": [
                                                    "out": [
                                                            "x": 820,
                                                            "y": 80,
                                                            "wires": [
        "port": 0
                                                    "env": [
                                                            "name": "basePath",
                                                            "type": "str",
                                                    "meta": {},
                                                    "color": "#DDAA99"
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "datum",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 230,
                                                    "y": 80,
                                                    "wires": [
                                                            "0e8de9437c3c420a"
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "change",
                                                            "p": "datum",
                                                            "pt": "msg",
                                                            "from": "März",
                                                            "fromt": "str",
                                                            "to": "Maerz",
                                                            "tot": "str"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 440,
                                                    "y": 80,
                                                    "wires": [
                                                            "fc37f5f9d2b0297b"
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "topic",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 660,
                                                    "y": 80,
                                                    "wires": [
                                                    "id": "1d93ae2f970605e5",
                                                    "type": "debug",
                                                    "name": "debug 184",
                                                    "active": true,
                                                    "tosidebar": true,
                                                    "console": false,
                                                    "tostatus": false,
                                                    "statusVal": "",
                                                    "x": 1050,
                                                    "y": 180,
                                                    "wires": []
                                                    "id": "e700e5e9b292c820",
                                                    "name": "",
                                                    "topic": "",
                                                    "ack": "true",
                                                    "stateName": "",
                                                    "role": "",
                                                    "payloadType": "",
                                                    "stateUnit": "",
                                                    "stateMin": "",
                                                    "stateMax": "",
                                                    "x": 1060,
                                                    "y": 120,
                                                    "wires": []
                                                    "id": "5e8ce599dad4fa74",
                                                    "name": "",
                                                    "env": [
                                                            "name": "basePath",
                                                            "value": "Test1.Test5.MonatsTabellen",
                                                            "type": "str"
                                                    "x": 860,
                                                    "y": 40,
                                                    "wires": [
                                                            "e700e5e9b292c820",
                                                            "1d93ae2f970605e5"
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "payload",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                            "t": "set",
                                                            "p": "array-bezug",
                                                            "pt": "flow",
                                                            "to": "payload",
                                                            "tot": "msg"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 670,
                                                    "y": 40,
                                                    "wires": [
                                                            "5e8ce599dad4fa74"
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "array-bezug",
                                                            "pt": "msg",
                                                            "tot": "flow"
                                                            "t": "set",
                                                            "p": "array-bezug",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 450,
                                                    "y": 40,
                                                    "wires": [
                                                            "ff519a511afeb6f1"
                                                    "type": "change",
                                                    "name": "Bezug",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "topic",
                                                            "pt": "msg",
                                                            "to": "Strombezug",
                                                            "tot": "str"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 270,
                                                    "y": 40,
                                                    "wires": [
                                                            "c617a78f8ddaca22"
                                                    "onlyack": "",
                                                    "func": "all",
                                                    "gap": "",
                                                    "x": 110,
                                                    "y": 40,
                                                    "wires": [
                                                            "53d6131492b2abed"
                                            8935
