    4. Node-Red
    5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
      MartyBr @mickym last edited by
      @mickym
      Okay, das ist ein Ansatzpunkt. Ich mache mir mal Gedanken.
      Danke für deine Unterstützung.
      • mickym
        mickym Most Active @MartyBr last edited by
        @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
        @mickym
        Ich habs Dir mal mit eine Flowvariable gemacht. Das heißt das Ergebnis wird in eine Variable gespeichert und dann wieder eingelesen und der neue Wert angehängt.
               "id": "a0d8740faea1647b",
               "type": "mqtt in",
               "z": "7e6af0015415146d",
               "d": true,
               "name": "ZuluftTemp",
               "topic": "vitocal/ZuluftTemp",
               "qos": "0",
               "datatype": "auto-detect",
               "broker": "bf311140.13d2b8",
               "nl": false,
               "rap": true,
               "rh": 0,
               "inputs": 0,
               "x": 260,
               "y": 6740,
               "wires": [
                       "afdcb37ccbacb06f"
               "id": "afdcb37ccbacb06f",
               "type": "change",
               "name": "Zuluft",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "zuluft",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 410,
               "y": 6800,
               "wires": [
                       "1643873aeecd8613"
               "id": "1643873aeecd8613",
               "type": "change",
               "name": "Vorhandenes Array",
               "rules": [
                       "t": "set",
                       "p": "array",
                       "pt": "msg",
                       "to": "array",
                       "tot": "flow"
                       "t": "set",
                       "p": "array",
                       "pt": "msg",
                       "to": "array ? array : []",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 610,
               "y": 6760,
               "wires": [
                       "c9d97aec2949301c",
                       "34c8064e4b5c52fa"
               "id": "34c8064e4b5c52fa",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "$append(array, payload)",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "array",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 850,
               "y": 6760,
               "wires": [
                       "5b551b24fc1bb26e"
               "id": "5b551b24fc1bb26e",
               "type": "debug",
               "name": "debug 179",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "false",
               "statusVal": "",
               "statusType": "auto",
               "x": 1070,
               "y": 6740,
               "wires": []
               "id": "c9d97aec2949301c",
               "type": "debug",
               "name": "debug 178",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 830,
               "y": 6640,
               "wires": []
               "id": "7961970716d0df25",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "20.2",
               "payloadType": "num",
               "x": 230,
               "y": 6800,
               "wires": [
                       "afdcb37ccbacb06f"
               "id": "bf311140.13d2b8",
               "type": "mqtt-broker",
               "name": "Mosquito-Server",
               "broker": "192.168.178.10",
               "port": "1883",
               "clientid": "",
               "autoConnect": true,
               "usetls": false,
               "compatmode": false,
               "protocolVersion": "4",
               "keepalive": "60",
               "cleansession": true,
               "autoUnsubscribe": true,
               "birthTopic": "",
               "birthQos": "0",
               "birthPayload": "",
               "birthMsg": {},
               "closeTopic": "",
               "closeQos": "0",
               "closePayload": "",
               "closeMsg": {},
               "willTopic": "",
               "willQos": "0",
               "willPayload": "",
               "willMsg": {},
               "userProps": "",
               "sessionExpiry": ""
          @mickym
          Der Flow funktioniert.
          Ich habe eine Objektveriable in ioBroker.
                 "type": "mqtt in",
                 "d": true,
                 "qos": "0",
                 "nl": false,
                 "rap": true,
                 "rh": 0,
                 "inputs": 0,
                 "x": 260,
                 "y": 6740,
                 "wires": [
                         "afdcb37ccbacb06f"
                 "type": "change",
                 "name": "Zuluft",
                 "rules": [
                         "t": "set",
                         "p": "topic",
                         "pt": "msg",
                         "to": "zuluft",
                         "tot": "str"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 410,
                 "y": 6800,
                 "wires": [
                         "1643873aeecd8613"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "array",
                         "pt": "msg",
                         "to": "array",
                         "tot": "flow"
                         "t": "set",
                         "p": "array",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 610,
                 "y": 6760,
                 "wires": [
                         "c9d97aec2949301c",
                         "34c8064e4b5c52fa"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "array",
                         "pt": "flow",
                         "to": "payload",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 850,
                 "y": 6760,
                 "wires": [
                         "5b551b24fc1bb26e"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1070,
                 "y": 6740,
                 "wires": []
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 830,
                 "y": 6640,
                 "wires": []
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "20.2",
                 "x": 230,
                 "y": 6800,
                 "wires": [
                         "afdcb37ccbacb06f"
                 "port": "1883",
                 "clientid": "",
                 "usetls": false,
                 "keepalive": "60",
                 "birthTopic": "",
                 "birthQos": "0",
                 "birthPayload": "",
                 "birthMsg": {},
                 "closeTopic": "",
                 "closeQos": "0",
                 "closePayload": "",
                 "closeMsg": {},
                 "willTopic": "",
                 "willQos": "0",
                 "willPayload": "",
                 "willMsg": {},
                 "userProps": "",
                 "sessionExpiry": ""
          Wie kann ich das Array persistent ablegen?
          • mickym
            mickym Most Active @MartyBr last edited by mickym
            @martybr
            Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
              MartyBr @mickym last edited by MartyBr
              @mickym
              Ich habe das mal so gemacht:
                      "id": "99d066d4bbe5dca9",
                      "type": "inject",
                      "z": "5c488c180ba51f18",
                      "name": "",
                      "props": [
                              "p": "payload"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "20.2",
                      "x": 350,
                      "y": 700,
                      "wires": [
                              "994a1a0b6d25cef4"
                      "id": "82d5f1b2aa875c35",
                      "type": "mqtt in",
                      "qos": "0",
                      "nl": false,
                      "rap": true,
                      "rh": 0,
                      "inputs": 0,
                      "x": 420,
                      "y": 620,
                      "wires": [
                              "994a1a0b6d25cef4"
                      "id": "994a1a0b6d25cef4",
                      "type": "change",
                      "name": "Zuluft",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "to": "zuluft",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 530,
                      "y": 700,
                      "wires": [
                              "4a49f7b7cb1d35d2"
                      "id": "de7a183e542f367e",
                      "type": "ioBroker get object",
                      "name": "Test.Test-JSON",
                      "topic": "0_userdata.0.Test.Test-JSON",
                      "attrname": "array",
                      "x": 620,
                      "y": 580,
                      "wires": [
                      "id": "4a49f7b7cb1d35d2",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "array",
                              "pt": "msg",
                              "to": "array",
                              "tot": "flow"
                              "t": "set",
                              "p": "array",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 730,
                      "y": 660,
                      "wires": [
                              "1bf56806da8b2399",
                              "40df7a89751f5b92"
                      "id": "40df7a89751f5b92",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                              "t": "set",
                              "p": "array",
                              "pt": "flow",
                              "to": "payload",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 830,
                      "y": 740,
                      "wires": [
                              "cb026a3b7a51d987",
                              "8d9b65f4efb22698"
                      "id": "cb026a3b7a51d987",
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 890,
                      "y": 800,
                      "wires": []
                      "id": "8d9b65f4efb22698",
                      "type": "ioBroker out",
                      "ack": "true",
                      "autoCreate": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1000,
                      "y": 660,
                      "wires": []
                      "id": "1bf56806da8b2399",
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 950,
                      "y": 540,
                      "wires": []
                      "port": "1883",
                      "clientid": "",
                      "usetls": false,
                      "keepalive": "60",
                      "birthTopic": "",
                      "birthQos": "0",
                      "birthPayload": "",
                      "birthMsg": {},
                      "closeTopic": "",
                      "closeQos": "0",
                      "closePayload": "",
                      "closeMsg": {},
                      "willTopic": "",
                      "willQos": "0",
                      "willPayload": "",
                      "willMsg": {},
                      "userProps": "",
                      "sessionExpiry": ""
              Die Werte kommen auch richtig im Datenpunkt an.
              Jetzt noch eine letzte Frage für Heute 😇
              Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
              Edit:
              Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
              • mickym
                Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
                  @mickym
                  Ich habe es noch nicht so ganz verstanden. Ich habe es nun so gebaut, wie ich es verstanden habe. Exemplarisch für zwei Flows / Arrays:
                          "id": "5bbdcd58332d0b96",
                          "type": "ioBroker in",
                          "name": "Bezug täglich",
                          "attrname": "payload",
                          "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
                          "payloadType": "value",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "fireOnStart": "true",
                          "outFormat": "MQTT",
                          "x": 110,
                          "y": 40,
                          "wires": [
                                  "53d6131492b2abed"
                          "id": "4bb406f8dd2161dd",
                          "name": "Einspeisung täglich",
                          "topic": "0_userdata.0.Zaehler.Stromeinspeisung.Verbrauch.täglich",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 130,
                          "y": 120,
                          "wires": [
                                  "c4e24a8d35d070ae"
                          "id": "c4e24a8d35d070ae",
                          "type": "change",
                          "name": "Einspeisung",
                          "rules": [
                                  "t": "set",
                                  "p": "topic",
                                  "pt": "msg",
                                  "to": "einspeisung",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 330,
                          "y": 120,
                          "wires": [
                                  "278bac26e6737147"
                          "id": "53d6131492b2abed",
                          "type": "change",
                          "name": "Bezug",
                          "rules": [
                                  "t": "set",
                                  "p": "topic",
                                  "pt": "msg",
                                  "to": "bezug",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 270,
                          "y": 40,
                          "wires": [
                                  "c617a78f8ddaca22"
                          "id": "c617a78f8ddaca22",
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "msg",
                                  "to": "array-bezug",
                                  "tot": "flow"
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "msg",
                                  "to": "array-bezug ? array-bezug : []",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 450,
                          "y": 40,
                          "wires": [
                                  "ff519a511afeb6f1"
                          "id": "ff519a511afeb6f1",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "$append(array-bezug, payload)",
                                  "tot": "jsonata"
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "flow",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 670,
                          "y": 40,
                          "wires": [
                                  "3274ac485bf96d56"
                          "id": "3274ac485bf96d56",
                          "name": "Test.Bezug-JSON",
                          "topic": "0_userdata.0.Test.Bezug-JSON",
                          "ack": "true",
                          "autoCreate": "true",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "false",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 890,
                          "y": 40,
                          "wires": []
                          "id": "278bac26e6737147",
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "array-einspeisung",
                                  "pt": "msg",
                                  "to": "array-einspeisung",
                                  "tot": "flow"
                                  "t": "set",
                                  "pt": "msg",
                                  "to": "array-einspeisung ? array-einspeisung : []",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 530,
                          "y": 120,
                          "wires": [
                                  "27eb027a108b6b2a"
                          "id": "27eb027a108b6b2a",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "$append(array-einspeisung, payload)",
                                  "tot": "jsonata"
                                  "t": "set",
                                  "pt": "flow",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 750,
                          "y": 120,
                          "wires": [
                                  "8c3a9cbe90f64091"
                          "id": "8c3a9cbe90f64091",
                          "name": "Test.Einspeisung-JSON",
                          "topic": "0_userdata.0.Test.Einspeisung-JSON",
                          "ack": "true",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 990,
                          "y": 120,
                          "wires": []
                  Die Daten aktualisieren sich täglich. Wenn das in Ordnung ist, dann gehe ich an die Zeitsteuerung.
                    @mickym
                    Ich habe hier noch ein Problem, die Zahl der Tage im Monat in eine globale Variable zu schreiben. Statt der 28 Tage aus der Funktion liefert mir der Change Node nur payload == 5
                            "id": "f6ed836d74798c7f",
                            "type": "inject",
                            "z": "3ebdbbcf49e0ac40",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "",
                            "payloadType": "date",
                            "x": 100,
                            "y": 400,
                            "wires": [
                                    "a3434007e702fcdc"
                            "id": "7a09df47bef16411",
                            "type": "function",
                            "name": "function 1",
                            "func": "// Eingabe: msg.payload sollte ein Datum im Format 'YYYY-MM-DD' sein\nlet inputDate = new Date(msg.payload);\n\n// Hole den Monat und das Jahr\nlet month = inputDate.getMonth(); // 0-11\nlet year = inputDate.getFullYear();\n\n// Berechne die Anzahl der Tage im Monat\nlet daysInMonth = new Date(year, month + 1, 0).getDate();\n\n// Setze das Ergebnis in msg.payload\nmsg.payload = daysInMonth;\n\nreturn msg;",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "libs": [],
                            "x": 480,
                            "y": 400,
                            "wires": [
                                    "599b66169127c12d",
                                    "185c42081279a5e0"
                            "id": "a3434007e702fcdc",
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "$moment().locale('de').format('YYYY.MM.DD')",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 290,
                            "y": 400,
                            "wires": [
                                    "7a09df47bef16411"
                            "id": "d8d647f4ae028cb8",
                            "type": "debug",
                            "name": "debug 182",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 670,
                            "y": 320,
                            "wires": []
                            "id": "599b66169127c12d",
                            "type": "change",
                            "name": "Monatstage",
                            "rules": [
                                    "t": "move",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "monatstage",
                                    "tot": "global"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 650,
                            "y": 400,
                            "wires": [
                                    "d8d647f4ae028cb8"
                            "id": "185c42081279a5e0",
                            "type": "debug",
                            "name": "debug 183",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 590,
                            "y": 480,
                            "wires": []
                    M mickym 2 Replies Last reply Reply Quote 0
                      MartyBr @MartyBr last edited by
                      @mickym
                      Ich glaube, dass ich das Problem gelöst habe:
                              "type": "inject",
                              "name": "",
                              "props": [
                                      "p": "payload"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "topic": "",
                              "payload": "",
                              "x": 100,
                              "y": 400,
                              "wires": [
                                      "a3434007e702fcdc"
                              "type": "function",
                              "outputs": 1,
                              "timeout": 0,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 480,
                              "y": 400,
                              "wires": [
                                      "599b66169127c12d"
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "tot": "jsonata"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 290,
                              "y": 400,
                              "wires": [
                                      "7a09df47bef16411"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 650,
                              "y": 340,
                              "wires": []
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "monatstage",
                                      "tot": "global"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 650,
                              "y": 400,
                              "wires": [
                                      "d8d647f4ae028cb8"
                              "type": "debug",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 450,
                              "y": 460,
                              "wires": []
                              "id": "5f695a4b2b007db0",
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "monatstage",
                                      "tot": "global"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 270,
                              "y": 460,
                              "wires": [
                                      "185c42081279a5e0"
                              "id": "0191af1c60e06008",
                              "type": "inject",
                              "name": "",
                              "props": [
                                      "p": "payload"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "topic": "",
                              "payload": "",
                              "x": 100,
                              "y": 460,
                              "wires": [
                                      "5f695a4b2b007db0"
                      Kannst du bitte mal darüber schauen?
                        @mickym
                        Ich habe hier noch einen Fehler im Flow. Ich habe nun die dynamische Datumsablage hinzugefügt und den iobroker out entsprechend geändert. Der Datenpunkt wird auch angelegt, aber als "number" und nicht als Array (mit [Wert1, Wert2,...].
                                "id": "ae673cf6cd8433a0",
                                "type": "subflow",
                                "name": "Datum in Topic",
                                "info": "",
                                "category": "",
                                "in": [
                                        "x": 60,
                                        "y": 80,
                                        "wires": [
                                                "id": "2e1ea06b2e94bf1a"
                                "out": [
                                        "x": 820,
                                        "y": 80,
                                        "wires": [
                                                "id": "fc37f5f9d2b0297b",
                                                "port": 0
                                "env": [
                                        "name": "basePath",
                                        "type": "str",
                                        "value": "Test1.Test2"
                                "meta": {},
                                "color": "#DDAA99"
                                "id": "2e1ea06b2e94bf1a",
                                "type": "change",
                                "z": "ae673cf6cd8433a0",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "datum",
                                        "pt": "msg",
                                        "to": "$moment().locale('de').format('YYYY.MMMM')",
                                        "tot": "jsonata"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 230,
                                "y": 80,
                                "wires": [
                                        "0e8de9437c3c420a"
                                "id": "0e8de9437c3c420a",
                                "type": "change",
                                "name": "März zu Maerz",
                                "rules": [
                                        "t": "change",
                                        "p": "datum",
                                        "pt": "msg",
                                        "from": "März",
                                        "fromt": "str",
                                        "to": "Maerz",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 440,
                                "y": 80,
                                "wires": [
                                        "fc37f5f9d2b0297b"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "topic",
                                        "pt": "msg",
                                        "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                                        "tot": "jsonata"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 660,
                                "y": 80,
                                "wires": [
                                "id": "1d93ae2f970605e5",
                                "type": "debug",
                                "name": "debug 184",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1050,
                                "y": 180,
                                "wires": []
                                "id": "e700e5e9b292c820",
                                "name": "",
                                "topic": "",
                                "ack": "true",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1060,
                                "y": 120,
                                "wires": []
                                "id": "5e8ce599dad4fa74",
                                "type": "subflow:ae673cf6cd8433a0",
                                "name": "",
                                "env": [
                                        "name": "basePath",
                                        "value": "Test1.Test5.MonatsTabellen",
                                        "type": "str"
                                "x": 860,
                                "y": 40,
                                "wires": [
                                        "e700e5e9b292c820",
                                        "1d93ae2f970605e5"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "tot": "jsonata"
                                        "t": "set",
                                        "p": "array-bezug",
                                        "pt": "flow",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 670,
                                "y": 40,
                                "wires": [
                                        "5e8ce599dad4fa74"
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "array-bezug",
                                        "pt": "msg",
                                        "tot": "flow"
                                        "t": "set",
                                        "p": "array-bezug",
                                        "pt": "msg",
                                        "tot": "jsonata"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 450,
                                "y": 40,
                                "wires": [
                                        "ff519a511afeb6f1"
                                "type": "change",
                                "name": "Bezug",
                                "rules": [
                                        "t": "set",
                                        "p": "topic",
                                        "pt": "msg",
                                        "to": "Strombezug",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 270,
                                "y": 40,
                                "wires": [
                                        "c617a78f8ddaca22"
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 110,
                                "y": 40,
                                "wires": [
                                        "53d6131492b2abed"
                        • mickym
                          @martybr Also - ich habe nun gerade Deinen Flow importiert. Wäre übrigens auch gut, wenn Du mir eine Inject Node zur Simulation dran machen würdest, da ich ja in der Regel nicht deine Datenpunkte habe.
                          Dann machst Du einen gravierenden Fehler, wenn Du in JSONATA meinst, du kannst "array-bezug" schreiben. Dann versucht JSONATA von einer Nachrichteneigenschaft "array" den Betrag der Nachrichteneigenschaft "bezug" zu subtrahieren, was natürlich beides nicht definiert bzw. exisitiert.
                          Ich habe also in Deinem ganzen Flow - "array-bezug" durch "array_bezug" ersetzt.
                          Dann haben wir doch besprochen, dass der iobroker KEINE Objekte bearbeiten kann. Also müssen wir bevor wir einen Datenpunkt beschreiben, diesen erst in einen String umwandeln.
                          Also lösche Deinen Datenpunkt nochmals und setze eine JSON Node vor die iobroker-Out Node, so wie besprochen.
                          Und zuletzt - speicherst Du zwar direkt in die Flow variable - aber Du wolltest doch persistent machen und Du liest ja nirgend Dein Array aus dem iobroker wieder ein?
                          Also hören wir doch mal auf, das Ergebnis - also das neue Array direkt abzuspeichern:
                          So nun muss man also wieder was aus dem Datenpunkt einlesen, den man in iobroker geschrieben hat. das ist aber kompliziert, da der Datenpunkt ja dynamisch sich dauernd ändert. Ich überlege mir mal was.
                          Inzwischen kannst Du Dir ja den modifizierten Flow - als Basis schon mal abspeichern - dann auf der Basis machen wir weiter.
                                 "type": "subflow",
                                 "info": "",
                                 "category": "",
                                 "in": [
                                         "x": 60,
                                         "y": 80,
                                         "wires": [
                                 "out": [
                                         "x": 820,
                                         "y": 80,
                                         "wires": [
                                                 "port": 0
                                 "env": [
                                         "name": "basePath",
                                         "type": "str",
                                 "meta": {},
                                 "color": "#DDAA99"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "datum",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 230,
                                 "y": 80,
                                 "wires": [
                                         "0e8de9437c3c420a"
                                 "type": "change",
                                 "rules": [
                                         "t": "change",
                                         "p": "datum",
                                         "pt": "msg",
                                         "from": "März",
                                         "fromt": "str",
                                         "to": "Maerz",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 440,
                                 "y": 80,
                                 "wires": [
                                         "fc37f5f9d2b0297b"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 660,
                                 "y": 80,
                                 "wires": [
                                 "id": "5073270521431406",
                                 "type": "debug",
                                 "z": "5dbdd0fd840b4eee",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1170,
                                 "y": 300,
                                 "wires": []
                                 "id": "10bd7990f72c7776",
                                 "name": "",
                                 "topic": "",
                                 "ack": "true",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 1340,
                                 "y": 220,
                                 "wires": []
                                 "id": "147888cb9d8dbd57",
                                 "name": "",
                                 "env": [
                                         "name": "basePath",
                                         "type": "str"
                                 "x": 1000,
                                 "y": 160,
                                 "wires": [
                                         "5073270521431406",
                                         "c097566fbf70cacc"
                                 "id": "9226f70990baa228",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "$append(array_bezug, payload)",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 790,
                                 "y": 160,
                                 "wires": [
                                         "147888cb9d8dbd57"
                                 "id": "102ed68150c3074f",
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "array_bezug",
                                         "pt": "msg",
                                         "to": "array_bezug",
                                         "tot": "flow"
                                         "t": "set",
                                         "p": "array_bezug",
                                         "pt": "msg",
                                         "to": "array_bezug ? array_bezug : []",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 570,
                                 "y": 160,
                                 "wires": [
                                         "9226f70990baa228"
                                 "id": "fbcf46d8f94203aa",
                                 "type": "change",
                                 "name": "Bezug",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "Strombezug",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 350,
                                 "y": 120,
                                 "wires": [
                                         "102ed68150c3074f"
                                 "id": "a435b3ce1f53ba74",
                                 "d": true,
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 110,
                                 "y": 160,
                                 "wires": [
                                         "fbcf46d8f94203aa"
                                 "id": "779ae42084de3e0c",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "Bezug täglich",
                                 "payload": "20.1",
                                 "x": 110,
                                 "y": 120,
                                 "wires": [
                                         "fbcf46d8f94203aa"
                                 "id": "c097566fbf70cacc",
                                 "type": "json",
                                 "name": "",
                                 "property": "payload",
                                 "action": "",
                                 "pretty": false,
                                 "x": 1170,
                                 "y": 220,
                                 "wires": [
                                         "10bd7990f72c7776"
                          Ich denke, ich muss den ganzen Flow etwas umstellen, damit es auch einigermaßen effizient wird. Also vergiß Deinen/Meinen bisherigen Flow.
                            @mickym
                            Konntest du dir den Flow zur Monatslänge (von 9:48 Uhr) mal anschauen? Ich habe da eine globale Variable "Monatstage" definiert.
                            • mickym
                              @martybr Warum das nun wieder - ich habe den Flow nun fertig und wenn der Monat wechselt wird automatisch ein neuer Datenpunkt durch Deinen Subflow angelegt und auch eingelesen.
                              Nein Sorry - Du hast Recht, wenn sich das Topic ändert, dann muss die Flowvariable noch gelöscht werden. Habe ich vergessen.
                                @mickym
                                Vielleicht irre ich mich auch. Ich habe von einem lieben Bekannten ein JavaScript, welches über die Werte iteriert. Hier werden die Zahl der Tage im Monat benötigt. Ich versuche hier mit deiner Hilfe Node-Red zu verstehen, da mich Javascript nicht angesprochen hat. Da gibt es mit async etc. genügend Fallstricke.
                                Daher kommen manche meiner Fragen, die für die bestimmt selbstverständlich sind. Ich fange ja gerade erst mit Node-Red an. Das Buch das ich mir gekauft habe war nicht so toll.
                                Einges habe ich schon in Node-Red umsetzen können:
                                Meine Bewegungsmelder mit Zeitsteuerung und Sperre bei manuellem Auslösen und mit deiner Hilfe die Speicherung von Strombezug und Einspeisung.
                                Ich konnte mit den Flows das ganze und weitere Anwendungen umsetzen, z.B. Wasserverbrauch, Gartenwasser, Solareinspeisung. Dadurch habe ich das Potential von Node-Red erkannt. Nun habe ich Zeit und versuche mich tiefer einzuarbeiten 😇
                                • mickym
                                  @martybr Ja ich schau mir das gleich an -
                                  Aber zu deinem Flow mit den dynamischen Monatsarrays habe ich eine andere Lösung, da brauchst du die Zahl nicht. Sprich wenn sich das topic ändert, dann wird die bisherige flow Variable gelöscht und eine neue erstellt. Schau Dir erst mal den neuen Flow an:
                                         "type": "subflow",
                                         "info": "",
                                         "category": "",
                                         "in": [
                                                 "x": 60,
                                                 "y": 80,
                                                 "wires": [
                                         "out": [
                                                 "x": 820,
                                                 "y": 80,
                                                 "wires": [
                                                         "port": 0
                                         "env": [
                                                 "name": "basePath",
                                                 "type": "str",
                                         "meta": {},
                                         "color": "#DDAA99"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "datum",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 230,
                                         "y": 80,
                                         "wires": [
                                                 "0e8de9437c3c420a"
                                         "type": "change",
                                         "rules": [
                                                 "t": "change",
                                                 "p": "datum",
                                                 "pt": "msg",
                                                 "from": "März",
                                                 "fromt": "str",
                                                 "to": "Maerz",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 440,
                                         "y": 80,
                                         "wires": [
                                                 "fc37f5f9d2b0297b"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 660,
                                         "y": 80,
                                         "wires": [
                                         "name": "",
                                         "topic": "",
                                         "ack": "true",
                                         "stateName": "",
                                         "role": "",
                                         "payloadType": "",
                                         "stateUnit": "",
                                         "stateMin": "",
                                         "stateMax": "",
                                         "x": 2560,
                                         "y": 160,
                                         "wires": []
                                         "type": "change",
                                         "name": "Bezug",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "Strombezug",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 350,
                                         "y": 120,
                                         "wires": [
                                                 "147888cb9d8dbd57"
                                         "d": true,
                                         "onlyack": "",
                                         "func": "all",
                                         "gap": "",
                                         "x": 170,
                                         "y": 160,
                                         "wires": [
                                                 "fbcf46d8f94203aa"
                                         "type": "inject",
                                         "name": "",
                                         "props": [
                                                 "p": "payload"
                                                 "p": "topic",
                                                 "vt": "str"
                                         "repeat": "",
                                         "crontab": "",
                                         "once": false,
                                         "onceDelay": 0.1,
                                         "payload": "19.1",
                                         "x": 170,
                                         "y": 120,
                                         "wires": [
                                                 "fbcf46d8f94203aa"
                                         "type": "json",
                                         "name": "",
                                         "action": "",
                                         "pretty": false,
                                         "x": 2390,
                                         "y": 160,
                                         "wires": [
                                                 "10bd7990f72c7776"
                                         "id": "6ece1ca957375987",
                                         "type": "switch",
                                         "name": "topic geändert?",
                                         "property": "topic",
                                         "propertyType": "msg",
                                         "rules": [
                                                 "t": "neq",
                                                 "v": "",
                                                 "vt": "prev"
                                                 "t": "eq",
                                                 "v": "",
                                                 "vt": "prev"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 2,
                                         "x": 720,
                                         "y": 120,
                                         "wires": [
                                                 "eaac747b9c1b37da"
                                                 "102ed68150c3074f"
                                         "name": "",
                                         "env": [
                                                 "name": "basePath",
                                                 "type": "str"
                                         "x": 520,
                                         "y": 120,
                                         "wires": [
                                                 "6ece1ca957375987"
                                         "id": "82c856dec8c7af8d",
                                         "type": "ioBroker get",
                                         "name": "",
                                         "topic": "",
                                         "errOnInvalidState": "false",
                                         "x": 1260,
                                         "y": 80,
                                         "wires": [
                                                 "95d876ec9e825008"
                                         "id": "2672eebe41c3d35a",
                                         "type": "json",
                                         "name": "",
                                         "action": "",
                                         "pretty": false,
                                         "x": 1650,
                                         "y": 100,
                                         "wires": [
                                                 "e7b2c3dba88f7574"
                                         "id": "95d876ec9e825008",
                                         "type": "switch",
                                         "name": "IoB read ?",
                                         "rules": [
                                                 "t": "null"
                                                 "t": "nnull"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 2,
                                         "x": 1450,
                                         "y": 80,
                                         "wires": [
                                                 "d2e703aaee60b32c"
                                                 "2672eebe41c3d35a"
                                         "id": "d2e703aaee60b32c",
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "[]",
                                                 "tot": "json"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 1650,
                                         "y": 60,
                                         "wires": [
                                                 "e7b2c3dba88f7574"
                                         "id": "eaac747b9c1b37da",
                                         "type": "change",
                                         "name": "payload sichern und flow var löschen",
                                         "rules": [
                                                 "t": "move",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "payload_bak",
                                                 "tot": "msg"
                                                 "t": "delete",
                                                 "p": "array_bezug",
                                                 "pt": "flow"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 990,
                                         "y": 80,
                                         "wires": [
                                                 "82c856dec8c7af8d"
                                         "id": "a89ae99abd8609c0",
                                         "type": "change",
                                         "name": "payload anhängen und sichern",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "array_bezug",
                                                 "pt": "flow",
                                                 "to": "payload",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2170,
                                         "y": 160,
                                         "wires": [
                                                 "c097566fbf70cacc"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "array_bezug",
                                                 "pt": "msg",
                                                 "tot": "flow"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 950,
                                         "y": 160,
                                         "wires": [
                                                 "a89ae99abd8609c0"
                                         "id": "e7b2c3dba88f7574",
                                         "type": "change",
                                         "name": "payload wiederherstellen",
                                         "rules": [
                                                 "t": "move",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "tot": "msg"
                                                 "t": "move",
                                                 "p": "payload_bak",
                                                 "pt": "msg",
                                                 "to": "payload",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 1890,
                                         "y": 80,
                                         "wires": [
                                                 "a89ae99abd8609c0"
                                  und schau, ob Du den verstehst. Ansonsten schaun ich mir Deinen Flow gerne an - aber ich verstehe immer nicht, warum mit JS in NodeRed arbeitet - ich rate Dir immer, die function Nodes wenn möglich immer zu meiden. Für Deine dynamischen Datenpunkte solltest Du es nicht brauchen. Ich habe übrigens mal einen Flow gemacht, den Du Dir auch mal anschauen solltest.
                                  • mickym
                                    @mickym
                                            "type": "inject",
                                            "name": "",
                                            "props": [
                                                    "p": "payload"
                                                    "p": "topic",
                                                    "vt": "str"
                                            "repeat": "",
                                            "crontab": "",
                                            "once": false,
                                            "onceDelay": 0.1,
                                            "topic": "",
                                            "payload": "",
                                            "x": 100,
                                            "y": 400,
                                            "wires": [
                                                    "a3434007e702fcdc"
                                            "type": "function",
                                            "outputs": 1,
                                            "timeout": 0,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 480,
                                            "y": 400,
                                            "wires": [
                                                    "599b66169127c12d",
                                                    "185c42081279a5e0"
                                            "type": "change",
                                            "name": "",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "tot": "jsonata"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 290,
                                            "y": 400,
                                            "wires": [
                                                    "7a09df47bef16411"
                                            "type": "debug",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "statusVal": "",
                                            "x": 670,
                                            "y": 320,
                                            "wires": []
                                            "type": "change",
                                            "rules": [
                                                    "t": "move",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "monatstage",
                                                    "tot": "global"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 650,
                                            "y": 400,
                                            "wires": [
                                                    "d8d647f4ae028cb8"
                                            "type": "debug",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "statusVal": "",
                                            "x": 590,
                                            "y": 480,
                                            "wires": []
                                    Das kann ich leider nicht nachvollziehen, bei mir funktioniert der Flow einwandfrei:
                                    Ich schau trotzdem mal kurz, ob man das mit $moments direkt erledigen kann.
                                      @mickym
                                      Stimmt, bei mir liefert er nun die richtige Anzahl der Tage.
                                      • mickym
                                        @mickym
                                        Ok - dann passt ja alles - ich bin dann erst mal weg - schau dann am Abend nochmal vorbei. Schau Dir mal den neuen Flow - für Deine Arrays und dynam. Datenpunkte derweil an.
                                          @mickym
                                          Es sieht alles gut aus. Ich werde mir das genau anschauen und danke dir für deine Hilfe.
                                            Ich habe den Flow für die Mittelwertbildung auf den Node aggregate umgestellt.
                                            Die Delays dienen der richtigen Reihenfolge der drei Werte min, mean und max im Json. Das ganze wird in einem fortlaufenden Array unter Jahr.Monat abgelegt.
                                            Hier der Flow, der zumindest bei mir ohne Fehler erfolgreich läuft.
                                                    "type": "subflow",
                                                    "info": "",
                                                    "category": "",
                                                    "in": [
                                                            "x": 60,
                                                            "y": 80,
                                                            "wires": [
                                                    "out": [
                                                            "x": 820,
                                                            "y": 80,
                                                            "wires": [
        "port": 0
                                                    "env": [
                                                            "name": "basePath",
                                                            "type": "str",
                                                    "meta": {},
                                                    "color": "#DDAA99"
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "datum",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 230,
                                                    "y": 80,
                                                    "wires": [
                                                            "0e8de9437c3c420a"
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "change",
                                                            "p": "datum",
                                                            "pt": "msg",
                                                            "from": "März",
                                                            "fromt": "str",
                                                            "to": "Maerz",
                                                            "tot": "str"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 440,
                                                    "y": 80,
                                                    "wires": [
                                                            "fc37f5f9d2b0297b"
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "topic",
                                                            "pt": "msg",
                                                            "tot": "jsonata"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 660,
                                                    "y": 80,
                                                    "wires": [
                                                    "id": "8c459eb88d1bf5f1",
                                                    "type": "tab",
                                                    "label": "Mittelwert",
                                                    "disabled": false,
                                                    "info": "",
                                                    "env": []
                                                    "id": "9b11db08a1cca5b3",
                                                    "type": "aggregator",
                                                    "z": "8c459eb88d1bf5f1",
                                                    "name": "Mean",
                                                    "topic": "mean",
                                                    "intervalCount": "1",
                                                    "intervalUnits": "d",
                                                    "submitIncompleteInterval": true,
                                                    "submitPerTopic": false,
                                                    "aggregationType": "mean",
                                                    "x": 290,
                                                    "y": 260,
                                                    "wires": [
                                                            "0290eb1787934b73"
                                                    "id": "f33e1d253e22a2dd",
                                                    "name": "Aussentemperatur",
                                                    "topic": "mqtt.0.vitocal.outside_temperature",
                                                    "onlyack": "",
                                                    "func": "all",
                                                    "gap": "",
                                                    "fireOnStart": "false",
                                                    "x": 110,
                                                    "y": 260,
                                                    "wires": [
                                                            "5a18bba8160e8e94",
                                                            "9b11db08a1cca5b3",
                                                            "32753fd69085ce71"
                                                    "id": "5a18bba8160e8e94",
                                                    "name": "Min",
                                                    "topic": "min",
                                                    "aggregationType": "min",
                                                    "x": 290,
                                                    "y": 200,
                                                    "wires": [
                                                            "15a56c790ce29f8d"
                                                    "id": "32753fd69085ce71",
                                                    "name": "Max",
                                                    "topic": "max",
                                                    "aggregationType": "max",
                                                    "x": 290,
                                                    "y": 320,
                                                    "wires": [
                                                            "7a8c3b56e65b5059"
                                                    "id": "15a56c790ce29f8d",
                                                    "type": "join",
                                                    "name": "",
                                                    "mode": "custom",
                                                    "build": "object",
                                                    "key": "topic",
                                                    "joiner": "\\n",
                                                    "joinerType": "str",
                                                    "accumulate": true,
                                                    "timeout": "60",
                                                    "count": "3",
                                                    "reduceRight": false,
                                                    "reduceExp": "",
                                                    "reduceInit": "",
                                                    "reduceInitType": "",
                                                    "reduceFixup": "",
                                                    "x": 670,
                                                    "y": 200,
                                                    "wires": [
                                                            "8ef8ee85844f2bb2"
                                                    "id": "8ef8ee85844f2bb2",
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "topic",
                                                            "pt": "msg",
                                                            "to": "meanTmp",
                                                            "tot": "str"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 840,
                                                    "y": 200,
                                                    "wires": [
                                                            "5d3e4f7dea0efe7c"
                                                    "id": "5d3e4f7dea0efe7c",
                                                    "env": [
                                                            "name": "basePath",
                                                            "value": "Heizung1.MonatsTabellen",
                                                            "type": "str"
                                                    "x": 1040,
                                                    "y": 200,
                                                    "wires": [
                                                            "9aa634789fccf445"
                                                    "id": "e44c746b92947c39",
                                                    "name": "",
                                                    "topic": "",
                                                    "ack": "true",
                                                    "stateName": "",
                                                    "role": "",
                                                    "payloadType": "",
                                                    "stateUnit": "°C",
                                                    "stateMin": "",
                                                    "stateMax": "",
                                                    "x": 2920,
                                                    "y": 280,
                                                    "wires": []
                                                    "id": "0290eb1787934b73",
                                                    "type": "delay",
                                                    "name": "",
                                                    "pauseType": "delay",
                                                    "timeout": "5",
                                                    "timeoutUnits": "seconds",
                                                    "rate": "1",
                                                    "nbRateUnits": "1",
                                                    "rateUnits": "second",
                                                    "randomFirst": "1",
                                                    "randomLast": "5",
                                                    "randomUnits": "seconds",
                                                    "drop": false,
                                                    "allowrate": false,
                                                    "outputs": 1,
                                                    "x": 460,
                                                    "y": 260,
                                                    "wires": [
                                                            "15a56c790ce29f8d"
                                                    "id": "7a8c3b56e65b5059",
                                                    "type": "delay",
                                                    "name": "",
                                                    "timeout": "10",
                                                    "rate": "1",
                                                    "nbRateUnits": "1",
                                                    "randomFirst": "1",
                                                    "randomLast": "5",
                                                    "drop": false,
                                                    "allowrate": false,
                                                    "outputs": 1,
                                                    "x": 470,
                                                    "y": 320,
                                                    "wires": [
                                                            "15a56c790ce29f8d"
                                                    "id": "9aa634789fccf445",
                                                    "type": "switch",
                                                    "rules": [
                                                            "t": "neq",
                                                            "v": "",
                                                            "vt": "prev"
                                                            "t": "eq",
                                                            "v": "",
                                                            "vt": "prev"
                                                    "checkall": "true",
                                                    "repair": false,
                                                    "outputs": 2,
                                                    "x": 1240,
                                                    "y": 200,
                                                    "wires": [
                                                            "c7fa49ea854690ed"
                                                            "edaece611a7db6d5"
                                                    "id": "c7fa49ea854690ed",
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "move",
                                                            "p": "payload",
                                                            "pt": "msg",
                                                            "to": "payload_bak_mean",
                                                            "tot": "msg"
                                                            "t": "delete",
                                                            "p": "array_mean",
                                                            "pt": "flow"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 1530,
                                                    "y": 180,
                                                    "wires": [
                                                            "7fd2bba1daf6d9f3"
                                                    "id": "edaece611a7db6d5",
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "array_bezug",
                                                            "pt": "msg",
                                                            "tot": "flow"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 1490,
                                                    "y": 280,
                                                    "wires": [
                                                            "515ae9918126f535"
                                                    "id": "7fd2bba1daf6d9f3",
                                                    "name": "",
                                                    "topic": "",
                                                    "x": 1800,
                                                    "y": 180,
                                                    "wires": [
                                                            "6e576a4e6d33f548"
                                                    "id": "6e576a4e6d33f548",
                                                    "type": "switch",
                                                    "rules": [
                                                            "t": "null"
                                                            "t": "nnull"
                                                    "checkall": "true",
                                                    "repair": false,
                                                    "outputs": 2,
                                                    "x": 2010,
                                                    "y": 180,
                                                    "wires": [
                                                            "ba58ec451fbfa53e"
                                                            "ae2e0346dd5f3824"
                                                    "id": "ba58ec451fbfa53e",
                                                    "type": "change",
                                                    "name": "",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "payload",
                                                            "pt": "msg",
                                                            "to": "[]",
                                                            "tot": "json"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 2250,
                                                    "y": 160,
                                                    "wires": [
                                                            "db03a4ed74093df5"
                                                    "id": "ae2e0346dd5f3824",
                                                    "type": "json",
                                                    "name": "",
                                                    "action": "",
                                                    "pretty": false,
                                                    "x": 2230,
                                                    "y": 220,
                                                    "wires": [
                                                            "db03a4ed74093df5"
                                                    "id": "db03a4ed74093df5",
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "move",
                                                            "p": "payload",
                                                            "pt": "msg",
                                                            "to": "array_mean",
                                                            "tot": "msg"
                                                            "t": "move",
                                                            "p": "payload_bak_mean",
                                                            "pt": "msg",
                                                            "to": "payload",
                                                            "tot": "msg"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 2490,
                                                    "y": 160,
                                                    "wires": [
                                                            "515ae9918126f535"
                                                    "id": "515ae9918126f535",
                                                    "type": "change",
                                                    "rules": [
                                                            "t": "set",
                                                            "p": "payload",
                                                            "pt": "msg",
                                                            "to": "$append(array_mean, payload)",
                                                            "tot": "jsonata"
                                                            "t": "set",
                                                            "p": "array_mean",
                                                            "pt": "flow",
                                                            "to": "payload",
                                                            "tot": "msg"
                                                    "action": "",
                                                    "property": "",
                                                    "from": "",
                                                    "to": "",
                                                    "reg": false,
                                                    "x": 2510,
                                                    "y": 280,
                                                    "wires": [
                                                            "0427391d23dcb6ad"
                                                    "id": "0427391d23dcb6ad",
                                                    "type": "json",
                                                    "name": "",
                                                    "action": "",
                                                    "pretty": false,
                                                    "x": 2750,
                                                    "y": 280,
                                                    "wires": [
                                                            "e44c746b92947c39"
                                            1.2k
                                            8935
