    4. Node-Red
    5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
    • mickym
      mickym Most Active @MartyBr last edited by mickym
      @martybr
      Wie kann ich das Array persistent ablegen?
      Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
        MartyBr @mickym last edited by MartyBr
        @mickym
        Ich habe das mal so gemacht:
                "id": "99d066d4bbe5dca9",
                "type": "inject",
                "z": "5c488c180ba51f18",
                "name": "",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "20.2",
                "payloadType": "num",
                "x": 350,
                "y": 700,
                "wires": [
                        "994a1a0b6d25cef4"
                "id": "82d5f1b2aa875c35",
                "type": "mqtt in",
                "name": "ZuluftTemp",
                "topic": "vitocal/ZuluftTemp",
                "qos": "0",
                "datatype": "auto-detect",
                "broker": "bf311140.13d2b8",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 420,
                "y": 620,
                "wires": [
                        "994a1a0b6d25cef4"
                "id": "994a1a0b6d25cef4",
                "type": "change",
                "name": "Zuluft",
                "rules": [
                        "t": "set",
                        "p": "topic",
                        "pt": "msg",
                        "to": "zuluft",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 530,
                "y": 700,
                "wires": [
                        "4a49f7b7cb1d35d2"
                "id": "de7a183e542f367e",
                "type": "ioBroker get object",
                "name": "Test.Test-JSON",
                "topic": "0_userdata.0.Test.Test-JSON",
                "attrname": "array",
                "x": 620,
                "y": 580,
                "wires": [
                "id": "4a49f7b7cb1d35d2",
                "type": "change",
                "name": "Vorhandenes Array",
                "rules": [
                        "t": "set",
                        "p": "array",
                        "pt": "msg",
                        "to": "array",
                        "tot": "flow"
                        "t": "set",
                        "p": "array",
                        "pt": "msg",
                        "to": "array ? array : []",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 730,
                "y": 660,
                "wires": [
                        "1bf56806da8b2399",
                        "40df7a89751f5b92"
                "id": "40df7a89751f5b92",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "$append(array, payload)",
                        "tot": "jsonata"
                        "t": "set",
                        "p": "array",
                        "pt": "flow",
                        "to": "payload",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 830,
                "y": 740,
                "wires": [
                        "cb026a3b7a51d987",
                        "8d9b65f4efb22698"
                "id": "cb026a3b7a51d987",
                "type": "debug",
                "name": "debug 179",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "false",
                "statusVal": "",
                "statusType": "auto",
                "x": 890,
                "y": 800,
                "wires": []
                "id": "8d9b65f4efb22698",
                "type": "ioBroker out",
                "ack": "true",
                "autoCreate": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1000,
                "y": 660,
                "wires": []
                "id": "1bf56806da8b2399",
                "type": "debug",
                "name": "debug 178",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 950,
                "y": 540,
                "wires": []
                "id": "bf311140.13d2b8",
                "type": "mqtt-broker",
                "name": "Mosquito-Server",
                "broker": "192.168.178.10",
                "port": "1883",
                "clientid": "",
                "autoConnect": true,
                "usetls": false,
                "compatmode": false,
                "protocolVersion": "4",
                "keepalive": "60",
                "cleansession": true,
                "autoUnsubscribe": true,
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
        Die Werte kommen auch richtig im Datenpunkt an.
        Jetzt noch eine letzte Frage für Heute 😇
        Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
        Edit:
        Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
        • mickym
          @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
          Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
            @mickym
            Ich habe es noch nicht so ganz verstanden. Ich habe es nun so gebaut, wie ich es verstanden habe. Exemplarisch für zwei Flows / Arrays:
                    "id": "5bbdcd58332d0b96",
                    "type": "ioBroker in",
                    "name": "Bezug täglich",
                    "attrname": "payload",
                    "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
                    "payloadType": "value",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "fireOnStart": "true",
                    "outFormat": "MQTT",
                    "x": 110,
                    "y": 40,
                    "wires": [
                            "53d6131492b2abed"
                    "id": "4bb406f8dd2161dd",
                    "name": "Einspeisung täglich",
                    "topic": "0_userdata.0.Zaehler.Stromeinspeisung.Verbrauch.täglich",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 130,
                    "y": 120,
                    "wires": [
                            "c4e24a8d35d070ae"
                    "id": "c4e24a8d35d070ae",
                    "type": "change",
                    "name": "Einspeisung",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "to": "einspeisung",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 330,
                    "y": 120,
                    "wires": [
                            "278bac26e6737147"
                    "id": "53d6131492b2abed",
                    "type": "change",
                    "name": "Bezug",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "to": "bezug",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 270,
                    "y": 40,
                    "wires": [
                            "c617a78f8ddaca22"
                    "id": "c617a78f8ddaca22",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "array-bezug",
                            "pt": "msg",
                            "to": "array-bezug",
                            "tot": "flow"
                            "t": "set",
                            "p": "array-bezug",
                            "pt": "msg",
                            "to": "array-bezug ? array-bezug : []",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 450,
                    "y": 40,
                    "wires": [
                            "ff519a511afeb6f1"
                    "id": "ff519a511afeb6f1",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "$append(array-bezug, payload)",
                            "tot": "jsonata"
                            "t": "set",
                            "p": "array-bezug",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 670,
                    "y": 40,
                    "wires": [
                            "3274ac485bf96d56"
                    "id": "3274ac485bf96d56",
                    "name": "Test.Bezug-JSON",
                    "topic": "0_userdata.0.Test.Bezug-JSON",
                    "ack": "true",
                    "autoCreate": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "false",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 890,
                    "y": 40,
                    "wires": []
                    "id": "278bac26e6737147",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "array-einspeisung",
                            "pt": "msg",
                            "to": "array-einspeisung",
                            "tot": "flow"
                            "t": "set",
                            "pt": "msg",
                            "to": "array-einspeisung ? array-einspeisung : []",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 530,
                    "y": 120,
                    "wires": [
                            "27eb027a108b6b2a"
                    "id": "27eb027a108b6b2a",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "$append(array-einspeisung, payload)",
                            "tot": "jsonata"
                            "t": "set",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 750,
                    "y": 120,
                    "wires": [
                            "8c3a9cbe90f64091"
                    "id": "8c3a9cbe90f64091",
                    "name": "Test.Einspeisung-JSON",
                    "topic": "0_userdata.0.Test.Einspeisung-JSON",
                    "ack": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 990,
                    "y": 120,
                    "wires": []
            Die Daten aktualisieren sich täglich. Wenn das in Ordnung ist, dann gehe ich an die Zeitsteuerung.
              @mickym
              Ich habe hier noch ein Problem, die Zahl der Tage im Monat in eine globale Variable zu schreiben. Statt der 28 Tage aus der Funktion liefert mir der Change Node nur payload == 5
                      "id": "f6ed836d74798c7f",
                      "type": "inject",
                      "z": "3ebdbbcf49e0ac40",
                      "name": "",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "",
                      "payloadType": "date",
                      "x": 100,
                      "y": 400,
                      "wires": [
                              "a3434007e702fcdc"
                      "id": "7a09df47bef16411",
                      "type": "function",
                      "name": "function 1",
                      "func": "// Eingabe: msg.payload sollte ein Datum im Format 'YYYY-MM-DD' sein\nlet inputDate = new Date(msg.payload);\n\n// Hole den Monat und das Jahr\nlet month = inputDate.getMonth(); // 0-11\nlet year = inputDate.getFullYear();\n\n// Berechne die Anzahl der Tage im Monat\nlet daysInMonth = new Date(year, month + 1, 0).getDate();\n\n// Setze das Ergebnis in msg.payload\nmsg.payload = daysInMonth;\n\nreturn msg;",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "initialize": "",
                      "finalize": "",
                      "libs": [],
                      "x": 480,
                      "y": 400,
                      "wires": [
                              "599b66169127c12d",
                              "185c42081279a5e0"
                      "id": "a3434007e702fcdc",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "$moment().locale('de').format('YYYY.MM.DD')",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 290,
                      "y": 400,
                      "wires": [
                              "7a09df47bef16411"
                      "id": "d8d647f4ae028cb8",
                      "type": "debug",
                      "name": "debug 182",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 670,
                      "y": 320,
                      "wires": []
                      "id": "599b66169127c12d",
                      "type": "change",
                      "name": "Monatstage",
                      "rules": [
                              "t": "move",
                              "p": "payload",
                              "pt": "msg",
                              "to": "monatstage",
                              "tot": "global"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 650,
                      "y": 400,
                      "wires": [
                              "d8d647f4ae028cb8"
                      "id": "185c42081279a5e0",
                      "type": "debug",
                      "name": "debug 183",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 590,
                      "y": 480,
                      "wires": []
              M mickym 2 Replies Last reply Reply Quote 0
                MartyBr @MartyBr last edited by
                @mickym
                Ich glaube, dass ich das Problem gelöst habe:
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "",
                        "x": 100,
                        "y": 400,
                        "wires": [
                                "a3434007e702fcdc"
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 480,
                        "y": 400,
                        "wires": [
                                "599b66169127c12d"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 290,
                        "y": 400,
                        "wires": [
                                "7a09df47bef16411"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 650,
                        "y": 340,
                        "wires": []
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "payload",
                                "tot": "msg"
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "monatstage",
                                "tot": "global"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 650,
                        "y": 400,
                        "wires": [
                                "d8d647f4ae028cb8"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 450,
                        "y": 460,
                        "wires": []
                        "id": "5f695a4b2b007db0",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "monatstage",
                                "tot": "global"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 270,
                        "y": 460,
                        "wires": [
                                "185c42081279a5e0"
                        "id": "0191af1c60e06008",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "",
                        "x": 100,
                        "y": 460,
                        "wires": [
                                "5f695a4b2b007db0"
                Kannst du bitte mal darüber schauen?
                  @mickym
                  Ich habe hier noch einen Fehler im Flow. Ich habe nun die dynamische Datumsablage hinzugefügt und den iobroker out entsprechend geändert. Der Datenpunkt wird auch angelegt, aber als "number" und nicht als Array (mit [Wert1, Wert2,...].
                          "id": "ae673cf6cd8433a0",
                          "type": "subflow",
                          "name": "Datum in Topic",
                          "info": "",
                          "category": "",
                          "in": [
                                  "x": 60,
                                  "y": 80,
                                  "wires": [
                                          "id": "2e1ea06b2e94bf1a"
                          "out": [
                                  "x": 820,
                                  "y": 80,
                                  "wires": [
                                          "id": "fc37f5f9d2b0297b",
                                          "port": 0
                          "env": [
                                  "name": "basePath",
                                  "type": "str",
                                  "value": "Test1.Test2"
                          "meta": {},
                          "color": "#DDAA99"
                          "id": "2e1ea06b2e94bf1a",
                          "type": "change",
                          "z": "ae673cf6cd8433a0",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "datum",
                                  "pt": "msg",
                                  "to": "$moment().locale('de').format('YYYY.MMMM')",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 230,
                          "y": 80,
                          "wires": [
                                  "0e8de9437c3c420a"
                          "id": "0e8de9437c3c420a",
                          "type": "change",
                          "name": "März zu Maerz",
                          "rules": [
                                  "t": "change",
                                  "p": "datum",
                                  "pt": "msg",
                                  "from": "März",
                                  "fromt": "str",
                                  "to": "Maerz",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 440,
                          "y": 80,
                          "wires": [
                                  "fc37f5f9d2b0297b"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "topic",
                                  "pt": "msg",
                                  "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 660,
                          "y": 80,
                          "wires": [
                          "id": "1d93ae2f970605e5",
                          "type": "debug",
                          "name": "debug 184",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1050,
                          "y": 180,
                          "wires": []
                          "id": "e700e5e9b292c820",
                          "name": "",
                          "topic": "",
                          "ack": "true",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1060,
                          "y": 120,
                          "wires": []
                          "id": "5e8ce599dad4fa74",
                          "type": "subflow:ae673cf6cd8433a0",
                          "name": "",
                          "env": [
                                  "name": "basePath",
                                  "value": "Test1.Test5.MonatsTabellen",
                                  "type": "str"
                          "x": 860,
                          "y": 40,
                          "wires": [
                                  "e700e5e9b292c820",
                                  "1d93ae2f970605e5"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "flow",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 670,
                          "y": 40,
                          "wires": [
                                  "5e8ce599dad4fa74"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "msg",
                                  "tot": "flow"
                                  "t": "set",
                                  "p": "array-bezug",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 450,
                          "y": 40,
                          "wires": [
                                  "ff519a511afeb6f1"
                          "type": "change",
                          "name": "Bezug",
                          "rules": [
                                  "t": "set",
                                  "p": "topic",
                                  "pt": "msg",
                                  "to": "Strombezug",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 270,
                          "y": 40,
                          "wires": [
                                  "c617a78f8ddaca22"
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 110,
                          "y": 40,
                          "wires": [
                                  "53d6131492b2abed"
                  • mickym
                    @martybr Also - ich habe nun gerade Deinen Flow importiert. Wäre übrigens auch gut, wenn Du mir eine Inject Node zur Simulation dran machen würdest, da ich ja in der Regel nicht deine Datenpunkte habe.
                    Dann machst Du einen gravierenden Fehler, wenn Du in JSONATA meinst, du kannst "array-bezug" schreiben. Dann versucht JSONATA von einer Nachrichteneigenschaft "array" den Betrag der Nachrichteneigenschaft "bezug" zu subtrahieren, was natürlich beides nicht definiert bzw. exisitiert.
                    Ich habe also in Deinem ganzen Flow - "array-bezug" durch "array_bezug" ersetzt.
                    Dann haben wir doch besprochen, dass der iobroker KEINE Objekte bearbeiten kann. Also müssen wir bevor wir einen Datenpunkt beschreiben, diesen erst in einen String umwandeln.
                    Also lösche Deinen Datenpunkt nochmals und setze eine JSON Node vor die iobroker-Out Node, so wie besprochen.
                    Und zuletzt - speicherst Du zwar direkt in die Flow variable - aber Du wolltest doch persistent machen und Du liest ja nirgend Dein Array aus dem iobroker wieder ein?
                    Also hören wir doch mal auf, das Ergebnis - also das neue Array direkt abzuspeichern:
                    So nun muss man also wieder was aus dem Datenpunkt einlesen, den man in iobroker geschrieben hat. das ist aber kompliziert, da der Datenpunkt ja dynamisch sich dauernd ändert. Ich überlege mir mal was.
                    Inzwischen kannst Du Dir ja den modifizierten Flow - als Basis schon mal abspeichern - dann auf der Basis machen wir weiter.
                           "type": "subflow",
                           "info": "",
                           "category": "",
                           "in": [
                                   "x": 60,
                                   "y": 80,
                                   "wires": [
                           "out": [
                                   "x": 820,
                                   "y": 80,
                                   "wires": [
                                           "port": 0
                           "env": [
                                   "name": "basePath",
                                   "type": "str",
                           "meta": {},
                           "color": "#DDAA99"
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "datum",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 230,
                           "y": 80,
                           "wires": [
                                   "0e8de9437c3c420a"
                           "type": "change",
                           "rules": [
                                   "t": "change",
                                   "p": "datum",
                                   "pt": "msg",
                                   "from": "März",
                                   "fromt": "str",
                                   "to": "Maerz",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 440,
                           "y": 80,
                           "wires": [
                                   "fc37f5f9d2b0297b"
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 660,
                           "y": 80,
                           "wires": [
                           "id": "5073270521431406",
                           "type": "debug",
                           "z": "5dbdd0fd840b4eee",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1170,
                           "y": 300,
                           "wires": []
                           "id": "10bd7990f72c7776",
                           "name": "",
                           "topic": "",
                           "ack": "true",
                           "stateName": "",
                           "role": "",
                           "payloadType": "",
                           "stateUnit": "",
                           "stateMin": "",
                           "stateMax": "",
                           "x": 1340,
                           "y": 220,
                           "wires": []
                           "id": "147888cb9d8dbd57",
                           "name": "",
                           "env": [
                                   "name": "basePath",
                                   "type": "str"
                           "x": 1000,
                           "y": 160,
                           "wires": [
                                   "5073270521431406",
                                   "c097566fbf70cacc"
                           "id": "9226f70990baa228",
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "$append(array_bezug, payload)",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 790,
                           "y": 160,
                           "wires": [
                                   "147888cb9d8dbd57"
                           "id": "102ed68150c3074f",
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "array_bezug",
                                   "pt": "msg",
                                   "to": "array_bezug",
                                   "tot": "flow"
                                   "t": "set",
                                   "p": "array_bezug",
                                   "pt": "msg",
                                   "to": "array_bezug ? array_bezug : []",
                                   "tot": "jsonata"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 570,
                           "y": 160,
                           "wires": [
                                   "9226f70990baa228"
                           "id": "fbcf46d8f94203aa",
                           "type": "change",
                           "name": "Bezug",
                           "rules": [
                                   "t": "set",
                                   "p": "topic",
                                   "pt": "msg",
                                   "to": "Strombezug",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 350,
                           "y": 120,
                           "wires": [
                                   "102ed68150c3074f"
                           "id": "a435b3ce1f53ba74",
                           "d": true,
                           "onlyack": "",
                           "func": "all",
                           "gap": "",
                           "x": 110,
                           "y": 160,
                           "wires": [
                                   "fbcf46d8f94203aa"
                           "id": "779ae42084de3e0c",
                           "type": "inject",
                           "name": "",
                           "props": [
                                   "p": "payload"
                                   "p": "topic",
                                   "vt": "str"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "Bezug täglich",
                           "payload": "20.1",
                           "x": 110,
                           "y": 120,
                           "wires": [
                                   "fbcf46d8f94203aa"
                           "id": "c097566fbf70cacc",
                           "type": "json",
                           "name": "",
                           "property": "payload",
                           "action": "",
                           "pretty": false,
                           "x": 1170,
                           "y": 220,
                           "wires": [
                                   "10bd7990f72c7776"
                    Ich denke, ich muss den ganzen Flow etwas umstellen, damit es auch einigermaßen effizient wird. Also vergiß Deinen/Meinen bisherigen Flow.
                      @mickym
                      Konntest du dir den Flow zur Monatslänge (von 9:48 Uhr) mal anschauen? Ich habe da eine globale Variable "Monatstage" definiert.
                      • mickym
                        @martybr Warum das nun wieder - ich habe den Flow nun fertig und wenn der Monat wechselt wird automatisch ein neuer Datenpunkt durch Deinen Subflow angelegt und auch eingelesen.
                        Nein Sorry - Du hast Recht, wenn sich das Topic ändert, dann muss die Flowvariable noch gelöscht werden. Habe ich vergessen.
                          @mickym
                          Vielleicht irre ich mich auch. Ich habe von einem lieben Bekannten ein JavaScript, welches über die Werte iteriert. Hier werden die Zahl der Tage im Monat benötigt. Ich versuche hier mit deiner Hilfe Node-Red zu verstehen, da mich Javascript nicht angesprochen hat. Da gibt es mit async etc. genügend Fallstricke.
                          Daher kommen manche meiner Fragen, die für die bestimmt selbstverständlich sind. Ich fange ja gerade erst mit Node-Red an. Das Buch das ich mir gekauft habe war nicht so toll.
                          Einges habe ich schon in Node-Red umsetzen können:
                          Meine Bewegungsmelder mit Zeitsteuerung und Sperre bei manuellem Auslösen und mit deiner Hilfe die Speicherung von Strombezug und Einspeisung.
                          Ich konnte mit den Flows das ganze und weitere Anwendungen umsetzen, z.B. Wasserverbrauch, Gartenwasser, Solareinspeisung. Dadurch habe ich das Potential von Node-Red erkannt. Nun habe ich Zeit und versuche mich tiefer einzuarbeiten 😇
                          • mickym
                            @martybr Ja ich schau mir das gleich an -
                            Aber zu deinem Flow mit den dynamischen Monatsarrays habe ich eine andere Lösung, da brauchst du die Zahl nicht. Sprich wenn sich das topic ändert, dann wird die bisherige flow Variable gelöscht und eine neue erstellt. Schau Dir erst mal den neuen Flow an:
                                   "type": "subflow",
                                   "info": "",
                                   "category": "",
                                   "in": [
                                           "x": 60,
                                           "y": 80,
                                           "wires": [
                                   "out": [
                                           "x": 820,
                                           "y": 80,
                                           "wires": [
                                                   "port": 0
                                   "env": [
                                           "name": "basePath",
                                           "type": "str",
                                   "meta": {},
                                   "color": "#DDAA99"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "datum",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 230,
                                   "y": 80,
                                   "wires": [
                                           "0e8de9437c3c420a"
                                   "type": "change",
                                   "rules": [
                                           "t": "change",
                                           "p": "datum",
                                           "pt": "msg",
                                           "from": "März",
                                           "fromt": "str",
                                           "to": "Maerz",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 440,
                                   "y": 80,
                                   "wires": [
                                           "fc37f5f9d2b0297b"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 660,
                                   "y": 80,
                                   "wires": [
                                   "name": "",
                                   "topic": "",
                                   "ack": "true",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 2560,
                                   "y": 160,
                                   "wires": []
                                   "type": "change",
                                   "name": "Bezug",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "to": "Strombezug",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 350,
                                   "y": 120,
                                   "wires": [
                                           "147888cb9d8dbd57"
                                   "d": true,
                                   "onlyack": "",
                                   "func": "all",
                                   "gap": "",
                                   "x": 170,
                                   "y": 160,
                                   "wires": [
                                           "fbcf46d8f94203aa"
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "payload": "19.1",
                                   "x": 170,
                                   "y": 120,
                                   "wires": [
                                           "fbcf46d8f94203aa"
                                   "type": "json",
                                   "name": "",
                                   "action": "",
                                   "pretty": false,
                                   "x": 2390,
                                   "y": 160,
                                   "wires": [
                                           "10bd7990f72c7776"
                                   "id": "6ece1ca957375987",
                                   "type": "switch",
                                   "name": "topic geändert?",
                                   "property": "topic",
                                   "propertyType": "msg",
                                   "rules": [
                                           "t": "neq",
                                           "v": "",
                                           "vt": "prev"
                                           "t": "eq",
                                           "v": "",
                                           "vt": "prev"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 720,
                                   "y": 120,
                                   "wires": [
                                           "eaac747b9c1b37da"
                                           "102ed68150c3074f"
                                   "name": "",
                                   "env": [
                                           "name": "basePath",
                                           "type": "str"
                                   "x": 520,
                                   "y": 120,
                                   "wires": [
                                           "6ece1ca957375987"
                                   "id": "82c856dec8c7af8d",
                                   "type": "ioBroker get",
                                   "name": "",
                                   "topic": "",
                                   "errOnInvalidState": "false",
                                   "x": 1260,
                                   "y": 80,
                                   "wires": [
                                           "95d876ec9e825008"
                                   "id": "2672eebe41c3d35a",
                                   "type": "json",
                                   "name": "",
                                   "action": "",
                                   "pretty": false,
                                   "x": 1650,
                                   "y": 100,
                                   "wires": [
                                           "e7b2c3dba88f7574"
                                   "id": "95d876ec9e825008",
                                   "type": "switch",
                                   "name": "IoB read ?",
                                   "rules": [
                                           "t": "null"
                                           "t": "nnull"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 1450,
                                   "y": 80,
                                   "wires": [
                                           "d2e703aaee60b32c"
                                           "2672eebe41c3d35a"
                                   "id": "d2e703aaee60b32c",
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "[]",
                                           "tot": "json"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1650,
                                   "y": 60,
                                   "wires": [
                                           "e7b2c3dba88f7574"
                                   "id": "eaac747b9c1b37da",
                                   "type": "change",
                                   "name": "payload sichern und flow var löschen",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "payload_bak",
                                           "tot": "msg"
                                           "t": "delete",
                                           "p": "array_bezug",
                                           "pt": "flow"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 990,
                                   "y": 80,
                                   "wires": [
                                           "82c856dec8c7af8d"
                                   "id": "a89ae99abd8609c0",
                                   "type": "change",
                                   "name": "payload anhängen und sichern",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                           "t": "set",
                                           "p": "array_bezug",
                                           "pt": "flow",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 2170,
                                   "y": 160,
                                   "wires": [
                                           "c097566fbf70cacc"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "array_bezug",
                                           "pt": "msg",
                                           "tot": "flow"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 950,
                                   "y": 160,
                                   "wires": [
                                           "a89ae99abd8609c0"
                                   "id": "e7b2c3dba88f7574",
                                   "type": "change",
                                   "name": "payload wiederherstellen",
                                   "rules": [
                                           "t": "move",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                           "t": "move",
                                           "p": "payload_bak",
                                           "pt": "msg",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1890,
                                   "y": 80,
                                   "wires": [
                                           "a89ae99abd8609c0"
                            und schau, ob Du den verstehst. Ansonsten schaun ich mir Deinen Flow gerne an - aber ich verstehe immer nicht, warum mit JS in NodeRed arbeitet - ich rate Dir immer, die function Nodes wenn möglich immer zu meiden. Für Deine dynamischen Datenpunkte solltest Du es nicht brauchen. Ich habe übrigens mal einen Flow gemacht, den Du Dir auch mal anschauen solltest.
                            • mickym
                              @mickym
                                      "type": "inject",
                                      "name": "",
                                      "props": [
                                              "p": "payload"
                                              "p": "topic",
                                              "vt": "str"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "payload": "",
                                      "x": 100,
                                      "y": 400,
                                      "wires": [
                                              "a3434007e702fcdc"
                                      "type": "function",
                                      "outputs": 1,
                                      "timeout": 0,
                                      "noerr": 0,
                                      "initialize": "",
                                      "finalize": "",
                                      "libs": [],
                                      "x": 480,
                                      "y": 400,
                                      "wires": [
                                              "599b66169127c12d",
                                              "185c42081279a5e0"
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 290,
                                      "y": 400,
                                      "wires": [
                                              "7a09df47bef16411"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 670,
                                      "y": 320,
                                      "wires": []
                                      "type": "change",
                                      "rules": [
                                              "t": "move",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "monatstage",
                                              "tot": "global"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 650,
                                      "y": 400,
                                      "wires": [
                                              "d8d647f4ae028cb8"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 590,
                                      "y": 480,
                                      "wires": []
                              Das kann ich leider nicht nachvollziehen, bei mir funktioniert der Flow einwandfrei:
                              Ich schau trotzdem mal kurz, ob man das mit $moments direkt erledigen kann.
                                @mickym
                                Stimmt, bei mir liefert er nun die richtige Anzahl der Tage.
                                • mickym
                                  @mickym
                                  Ok - dann passt ja alles - ich bin dann erst mal weg - schau dann am Abend nochmal vorbei. Schau Dir mal den neuen Flow - für Deine Arrays und dynam. Datenpunkte derweil an.
                                    @mickym
                                    Es sieht alles gut aus. Ich werde mir das genau anschauen und danke dir für deine Hilfe.
                                      Ich habe den Flow für die Mittelwertbildung auf den Node aggregate umgestellt.
                                      Die Delays dienen der richtigen Reihenfolge der drei Werte min, mean und max im Json. Das ganze wird in einem fortlaufenden Array unter Jahr.Monat abgelegt.
                                      Hier der Flow, der zumindest bei mir ohne Fehler erfolgreich läuft.
                                              "type": "subflow",
                                              "info": "",
                                              "category": "",
                                              "in": [
                                                      "x": 60,
                                                      "y": 80,
                                                      "wires": [
                                              "out": [
                                                      "x": 820,
                                                      "y": 80,
                                                      "wires": [
                                                              "port": 0
                                              "env": [
                                                      "name": "basePath",
                                                      "type": "str",
                                              "meta": {},
                                              "color": "#DDAA99"
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "datum",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 230,
                                              "y": 80,
                                              "wires": [
                                                      "0e8de9437c3c420a"
                                              "type": "change",
                                              "rules": [
                                                      "t": "change",
                                                      "p": "datum",
                                                      "pt": "msg",
                                                      "from": "März",
                                                      "fromt": "str",
                                                      "to": "Maerz",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 440,
                                              "y": 80,
                                              "wires": [
                                                      "fc37f5f9d2b0297b"
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 660,
                                              "y": 80,
                                              "wires": [
                                              "id": "8c459eb88d1bf5f1",
                                              "type": "tab",
                                              "label": "Mittelwert",
                                              "disabled": false,
                                              "info": "",
                                              "env": []
                                              "id": "9b11db08a1cca5b3",
                                              "type": "aggregator",
                                              "z": "8c459eb88d1bf5f1",
                                              "name": "Mean",
                                              "topic": "mean",
                                              "intervalCount": "1",
                                              "intervalUnits": "d",
                                              "submitIncompleteInterval": true,
                                              "submitPerTopic": false,
                                              "aggregationType": "mean",
                                              "x": 290,
                                              "y": 260,
                                              "wires": [
                                                      "0290eb1787934b73"
                                              "id": "f33e1d253e22a2dd",
                                              "name": "Aussentemperatur",
                                              "topic": "mqtt.0.vitocal.outside_temperature",
                                              "onlyack": "",
                                              "func": "all",
                                              "gap": "",
                                              "fireOnStart": "false",
                                              "x": 110,
                                              "y": 260,
                                              "wires": [
                                                      "5a18bba8160e8e94",
                                                      "9b11db08a1cca5b3",
                                                      "32753fd69085ce71"
                                              "id": "5a18bba8160e8e94",
                                              "name": "Min",
                                              "topic": "min",
                                              "aggregationType": "min",
                                              "x": 290,
                                              "y": 200,
                                              "wires": [
                                                      "15a56c790ce29f8d"
                                              "id": "32753fd69085ce71",
                                              "name": "Max",
                                              "topic": "max",
                                              "aggregationType": "max",
                                              "x": 290,
                                              "y": 320,
                                              "wires": [
                                                      "7a8c3b56e65b5059"
                                              "id": "15a56c790ce29f8d",
                                              "type": "join",
                                              "name": "",
                                              "mode": "custom",
                                              "build": "object",
                                              "key": "topic",
                                              "joiner": "\\n",
                                              "joinerType": "str",
                                              "accumulate": true,
                                              "timeout": "60",
                                              "count": "3",
                                              "reduceRight": false,
                                              "reduceExp": "",
                                              "reduceInit": "",
                                              "reduceInitType": "",
                                              "reduceFixup": "",
                                              "x": 670,
                                              "y": 200,
                                              "wires": [
                                                      "8ef8ee85844f2bb2"
                                              "id": "8ef8ee85844f2bb2",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "meanTmp",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 840,
                                              "y": 200,
                                              "wires": [
                                                      "5d3e4f7dea0efe7c"
                                              "id": "5d3e4f7dea0efe7c",
                                              "env": [
                                                      "name": "basePath",
                                                      "value": "Heizung1.MonatsTabellen",
                                                      "type": "str"
                                              "x": 1040,
                                              "y": 200,
                                              "wires": [
                                                      "9aa634789fccf445"
                                              "id": "e44c746b92947c39",
                                              "name": "",
                                              "topic": "",
                                              "ack": "true",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "stateUnit": "°C",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 2920,
                                              "y": 280,
                                              "wires": []
                                              "id": "0290eb1787934b73",
                                              "type": "delay",
                                              "name": "",
                                              "pauseType": "delay",
                                              "timeout": "5",
                                              "timeoutUnits": "seconds",
                                              "rate": "1",
                                              "nbRateUnits": "1",
                                              "rateUnits": "second",
                                              "randomFirst": "1",
                                              "randomLast": "5",
                                              "randomUnits": "seconds",
                                              "drop": false,
                                              "allowrate": false,
                                              "outputs": 1,
                                              "x": 460,
                                              "y": 260,
                                              "wires": [
                                                      "15a56c790ce29f8d"
                                              "id": "7a8c3b56e65b5059",
                                              "type": "delay",
                                              "name": "",
                                              "timeout": "10",
                                              "rate": "1",
                                              "nbRateUnits": "1",
                                              "randomFirst": "1",
                                              "randomLast": "5",
                                              "drop": false,
                                              "allowrate": false,
                                              "outputs": 1,
                                              "x": 470,
                                              "y": 320,
                                              "wires": [
                                                      "15a56c790ce29f8d"
                                              "id": "9aa634789fccf445",
                                              "type": "switch",
                                              "rules": [
                                                      "t": "neq",
                                                      "v": "",
                                                      "vt": "prev"
                                                      "t": "eq",
                                                      "v": "",
                                                      "vt": "prev"
                                              "checkall": "true",
                                              "repair": false,
                                              "outputs": 2,
                                              "x": 1240,
                                              "y": 200,
                                              "wires": [
                                                      "c7fa49ea854690ed"
                                                      "edaece611a7db6d5"
                                              "id": "c7fa49ea854690ed",
                                              "type": "change",
                                              "rules": [
                                                      "t": "move",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "payload_bak_mean",
                                                      "tot": "msg"
                                                      "t": "delete",
                                                      "p": "array_mean",
                                                      "pt": "flow"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1530,
                                              "y": 180,
                                              "wires": [
                                                      "7fd2bba1daf6d9f3"
                                              "id": "edaece611a7db6d5",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "array_bezug",
                                                      "pt": "msg",
                                                      "tot": "flow"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1490,
                                              "y": 280,
                                              "wires": [
                                                      "515ae9918126f535"
                                              "id": "7fd2bba1daf6d9f3",
                                              "name": "",
                                              "topic": "",
                                              "x": 1800,
                                              "y": 180,
                                              "wires": [
                                                      "6e576a4e6d33f548"
                                              "id": "6e576a4e6d33f548",
                                              "type": "switch",
                                              "rules": [
                                                      "t": "null"
                                                      "t": "nnull"
                                              "checkall": "true",
                                              "repair": false,
                                              "outputs": 2,
                                              "x": 2010,
                                              "y": 180,
                                              "wires": [
                                                      "ba58ec451fbfa53e"
                                                      "ae2e0346dd5f3824"
                                              "id": "ba58ec451fbfa53e",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "[]",
                                                      "tot": "json"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 2250,
                                              "y": 160,
                                              "wires": [
                                                      "db03a4ed74093df5"
                                              "id": "ae2e0346dd5f3824",
                                              "type": "json",
                                              "name": "",
                                              "action": "",
                                              "pretty": false,
                                              "x": 2230,
                                              "y": 220,
                                              "wires": [
                                                      "db03a4ed74093df5"
                                              "id": "db03a4ed74093df5",
                                              "type": "change",
                                              "rules": [
                                                      "t": "move",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "array_mean",
                                                      "tot": "msg"
                                                      "t": "move",
                                                      "p": "payload_bak_mean",
                                                      "pt": "msg",
                                                      "to": "payload",
                                                      "tot": "msg"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 2490,
                                              "y": 160,
                                              "wires": [
                                                      "515ae9918126f535"
                                              "id": "515ae9918126f535",
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "$append(array_mean, payload)",
                                                      "tot": "jsonata"
                                                      "t": "set",
                                                      "p": "array_mean",
                                                      "pt": "flow",
                                                      "to": "payload",
                                                      "tot": "msg"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 2510,
                                              "y": 280,
                                              "wires": [
                                                      "0427391d23dcb6ad"
                                              "id": "0427391d23dcb6ad",
                                              "type": "json",
                                              "name": "",
                                              "action": "",
                                              "pretty": false,
                                              "x": 2750,
                                              "y": 280,
                                              "wires": [
                                                      "e44c746b92947c39"
                                        MartyBr @MartyBr last edited by MartyBr
                                        @mickym
                                        Ich habe noch eine Frage zu dem u.a. Flow. Ich würde gerne den Payload min, mean und max
                                        an die Tagesposition schieben.
                                        Also das bedeutet heute (09.02.2025) die 9 Position, das das Element 8.
                                        Man könnte doch mit einem Function Node den Code
                                        let i ===global.monatstage
                                        i = i-1
                                        msg.payload[i] = msg.payload[i].state
                                        schreiben. Ich habe Monatstage als globale Variable definiert.
                                        Mein Problem ist aber im Change node das append. Das widerspricht ja die Nutzung der Function Node.
                                        Hast du einen Tipp für mich?
                                        EDIT:
                                        Ich habe in der Doku gesehen, dass auch in der Change Node mit JSONata mit $sum(payload.state in die Elemente des Arrays geschrieben werden kann.
                                        Array Mean:
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": -4,
                                            "mean": 0.05,
                                            "max": 3.3
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                            "min": 0,
                                            "mean": 0,
                                            "max": 0
                                        code_tex[
                                                "type": "subflow",
                                                "info": "",
                                                "category": "",
                                                "in": [
                                                        "x": 60,
                                                        "y": 80,
                                                        "wires": [
                                                "out": [
                                                        "x": 820,
                                                        "y": 80,
                                                        "wires": [
        "port": 0
                                                "env": [
                                                        "name": "basePath",
                                                        "type": "str",
                                                "meta": {},
                                                "color": "#DDAA99"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "datum",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 230,
                                                "y": 80,
                                                "wires": [
                                                        "0e8de9437c3c420a"
                                                "type": "change",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "datum",
                                                        "pt": "msg",
                                                        "from": "März",
                                                        "fromt": "str",
                                                        "to": "Maerz",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 440,
                                                "y": 80,
                                                "wires": [
                                                        "fc37f5f9d2b0297b"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "topic",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 660,
                                                "y": 80,
                                                "wires": [
                                                "name": "Mean",
                                                "topic": "mean",
                                                "intervalUnits": "h",
                                                "x": 290,
                                                "y": 260,
                                                "wires": [
                                                        "0290eb1787934b73"
                                                "onlyack": "",
                                                "func": "all",
                                                "gap": "",
                                                "x": 110,
                                                "y": 260,
                                                "wires": [
                                                        "5a18bba8160e8e94",
                                                        "9b11db08a1cca5b3",
                                                        "32753fd69085ce71"
                                                "name": "Min",
                                                "topic": "min",
                                                "x": 290,
                                                "y": 200,
                                                "wires": [
                                                        "15a56c790ce29f8d"
                                                "name": "Max",
                                                "topic": "max",
                                                "x": 290,
                                                "y": 320,
                                                "wires": [
                                                        "7a8c3b56e65b5059"
                                                "type": "join",
                                                "name": "",
                                                "mode": "custom",
                                                "build": "object",
                                                "key": "topic",
                                                "joiner": "\\n",
                                                "accumulate": true,
                                                "timeout": "60",
                                                "count": "3",
                                                "reduceExp": "",
                                                "reduceInit": "",
                                                "reduceFixup": "",
                                                "x": 670,
                                                "y": 200,
                                                "wires": [
                                                        "8ef8ee85844f2bb2"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "topic",
                                                        "pt": "msg",
                                                        "to": "meanTmp",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 840,
                                                "y": 200,
                                                "wires": [
                                                        "5d3e4f7dea0efe7c"
                                                "env": [
                                                        "name": "basePath",
                                                        "type": "str"
                                                "x": 1040,
                                                "y": 200,
                                                "wires": [
                                                        "9aa634789fccf445"
                                                "name": "",
                                                "topic": "",
                                                "ack": "true",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "stateUnit": "°C",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 2920,
                                                "y": 280,
                                                "wires": []
                                                "type": "delay",
                                                "name": "",
                                                "timeout": "5",
                                                "rate": "1",
                                                "nbRateUnits": "1",
                                                "randomFirst": "1",
                                                "randomLast": "5",
                                                "drop": false,
                                                "allowrate": false,
                                                "outputs": 1,
                                                "x": 460,
                                                "y": 260,
                                                "wires": [
                                                        "15a56c790ce29f8d"
                                                "type": "delay",
                                                "name": "",
                                                "timeout": "10",
                                                "rate": "1",
                                                "nbRateUnits": "1",
                                                "randomFirst": "1",
                                                "randomLast": "5",
                                                "drop": false,
                                                "allowrate": false,
                                                "outputs": 1,
                                                "x": 470,
                                                "y": 320,
                                                "wires": [
                                                        "15a56c790ce29f8d"
                                                "type": "switch",
                                                "rules": [
                                                        "t": "neq",
                                                        "v": "",
                                                        "vt": "prev"
                                                        "t": "eq",
                                                        "v": "",
                                                        "vt": "prev"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 1240,
                                                "y": 200,
                                                "wires": [
                                                        "c7fa49ea854690ed"
                                                        "edaece611a7db6d5"
                                                "type": "change",
                                                "rules": [
                                                        "t": "move",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "msg"
                                                        "t": "delete",
                                                        "p": "array_mean",
                                                        "pt": "flow"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 1530,
                                                "y": 180,
                                                "wires": [
                                                        "7fd2bba1daf6d9f3"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "array_bezug",
                                                        "pt": "msg",
                                                        "tot": "flow"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 1490,
                                                "y": 280,
                                                "wires": [
                                                        "515ae9918126f535"
                                                "name": "",
                                                "topic": "",
                                                "x": 1800,
                                                "y": 180,
                                                "wires": [
                                                        "6e576a4e6d33f548"
                                                "type": "switch",
                                                "rules": [
                                                        "t": "null"
                                                        "t": "nnull"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 2010,
                                                "y": 180,
                                                "wires": [
                                                        "ba58ec451fbfa53e"
                                                        "ae2e0346dd5f3824"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "[]",
                                                        "tot": "json"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 2250,
                                                "y": 160,
                                                "wires": [
                                                        "db03a4ed74093df5"
                                                "type": "json",
                                                "name": "",
                                                "action": "",
                                                "pretty": false,
                                                "x": 2230,
                                                "y": 220,
                                                "wires": [
                                                        "db03a4ed74093df5"
                                                "type": "change",
                                                "rules": [
                                                        "t": "move",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "array_mean",
                                                        "tot": "msg"
                                                        "t": "move",
                                                        "pt": "msg",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 2490,
                                                "y": 160,
                                                "wires": [
                                                        "515ae9918126f535"
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                        "t": "set",
                                                        "p": "array_mean",
                                                        "pt": "flow",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 2510,
                                                "y": 280,
                                                "wires": [
                                                        "0427391d23dcb6ad"
                                                "type": "json",
                                                "name": "",
                                                "action": "",
                                                "pretty": false,
                                                "x": 2750,
                                                "y": 280,
                                                "wires": [
                                                        "e44c746b92947c39"
                                                "id": "809efb6124c3639c",
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "$moment().date()",
                                                        "tot": "jsonata"
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "monatstage",
                                                        "tot": "global"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 290,
                                                "y": 460,
                                                "wires": [
                                                        "a27f09da64977051"
                                                "id": "02c66f19b70ff804",
                                                "type": "inject",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "300",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "",
                                                "x": 110,
                                                "y": 460,
                                                "wires": [
                                                        "809efb6124c3639c"
                                                "id": "a27f09da64977051",
                                                "type": "debug",
                                                "name": "Datum",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "complete": "payload",
                                                "targetType": "msg",
                                                "statusVal": "",
                                                "x": 470,
                                                "y": 460,
                                                "wires": []
                                                "id": "be82df1e7a1f3571",
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                        "t": "set",
                                                        "p": "array_mean",
                                                        "pt": "flow",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 2470,
                                                "y": 380,
                                                "wires": [
                                        ]t
                                        • mickym
                                          du brauchst keine monatstage etc. du hast doch ein Array und da bildest du einfach den durchschnitt der werte. das Array wid doch jeden monat neu geschrieben
                                            @mickym
                                            Ich dachte mir das nur als Fallback, wenn iobroker / Node-red mal steht und ein Tag übersprungen wird.
                                            So klappt es wunderbar und ich fuchse mich so langsam in die Materie ein.
                                            8935
