    4. Node-Red
    5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
      MartyBr @MartyBr last edited by
      @mickym
      Ich habe hier noch einen Fehler im Flow. Ich habe nun die dynamische Datumsablage hinzugefügt und den iobroker out entsprechend geändert. Der Datenpunkt wird auch angelegt, aber als "number" und nicht als Array (mit [Wert1, Wert2,...].
              "id": "ae673cf6cd8433a0",
              "type": "subflow",
              "name": "Datum in Topic",
              "info": "",
              "category": "",
              "in": [
                      "x": 60,
                      "y": 80,
                      "wires": [
                              "id": "2e1ea06b2e94bf1a"
              "out": [
                      "x": 820,
                      "y": 80,
                      "wires": [
                              "id": "fc37f5f9d2b0297b",
                              "port": 0
              "env": [
                      "name": "basePath",
                      "type": "str",
                      "value": "Test1.Test2"
              "meta": {},
              "color": "#DDAA99"
              "id": "2e1ea06b2e94bf1a",
              "type": "change",
              "z": "ae673cf6cd8433a0",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "datum",
                      "pt": "msg",
                      "to": "$moment().locale('de').format('YYYY.MMMM')",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 80,
              "wires": [
                      "0e8de9437c3c420a"
              "id": "0e8de9437c3c420a",
              "type": "change",
              "name": "März zu Maerz",
              "rules": [
                      "t": "change",
                      "p": "datum",
                      "pt": "msg",
                      "from": "März",
                      "fromt": "str",
                      "to": "Maerz",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 440,
              "y": 80,
              "wires": [
                      "fc37f5f9d2b0297b"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 660,
              "y": 80,
              "wires": [
              "id": "1d93ae2f970605e5",
              "type": "debug",
              "z": "5c488c180ba51f18",
              "name": "debug 184",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "statusType": "auto",
              "x": 1050,
              "y": 180,
              "wires": []
              "id": "e700e5e9b292c820",
              "type": "ioBroker out",
              "name": "",
              "topic": "",
              "ack": "true",
              "autoCreate": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "false",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1060,
              "y": 120,
              "wires": []
              "id": "5e8ce599dad4fa74",
              "type": "subflow:ae673cf6cd8433a0",
              "name": "",
              "env": [
                      "name": "basePath",
                      "value": "Test1.Test5.MonatsTabellen",
                      "type": "str"
              "x": 860,
              "y": 40,
              "wires": [
                      "e700e5e9b292c820",
                      "1d93ae2f970605e5"
              "id": "ff519a511afeb6f1",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "$append(array-bezug, payload)",
                      "tot": "jsonata"
                      "t": "set",
                      "p": "array-bezug",
                      "pt": "flow",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 670,
              "y": 40,
              "wires": [
                      "5e8ce599dad4fa74"
              "id": "c617a78f8ddaca22",
              "type": "change",
              "name": "Vorhandenes Array",
              "rules": [
                      "t": "set",
                      "p": "array-bezug",
                      "pt": "msg",
                      "to": "array-bezug",
                      "tot": "flow"
                      "t": "set",
                      "p": "array-bezug",
                      "pt": "msg",
                      "to": "array-bezug ? array-bezug : []",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 450,
              "y": 40,
              "wires": [
                      "ff519a511afeb6f1"
              "id": "53d6131492b2abed",
              "type": "change",
              "name": "Bezug",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Strombezug",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 270,
              "y": 40,
              "wires": [
                      "c617a78f8ddaca22"
              "id": "5bbdcd58332d0b96",
              "type": "ioBroker in",
              "name": "Bezug täglich",
              "attrname": "payload",
              "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "fireOnStart": "true",
              "outFormat": "MQTT",
              "x": 110,
              "y": 40,
              "wires": [
                      "53d6131492b2abed"
      • mickym
        mickym Most Active @MartyBr last edited by mickym
        @martybr Also - ich habe nun gerade Deinen Flow importiert. Wäre übrigens auch gut, wenn Du mir eine Inject Node zur Simulation dran machen würdest, da ich ja in der Regel nicht deine Datenpunkte habe.
        Dann machst Du einen gravierenden Fehler, wenn Du in JSONATA meinst, du kannst "array-bezug" schreiben. Dann versucht JSONATA von einer Nachrichteneigenschaft "array" den Betrag der Nachrichteneigenschaft "bezug" zu subtrahieren, was natürlich beides nicht definiert bzw. exisitiert.
        Ich habe also in Deinem ganzen Flow - "array-bezug" durch "array_bezug" ersetzt.
        Dann haben wir doch besprochen, dass der iobroker KEINE Objekte bearbeiten kann. Also müssen wir bevor wir einen Datenpunkt beschreiben, diesen erst in einen String umwandeln.
        Also lösche Deinen Datenpunkt nochmals und setze eine JSON Node vor die iobroker-Out Node, so wie besprochen.
        Und zuletzt - speicherst Du zwar direkt in die Flow variable - aber Du wolltest doch persistent machen und Du liest ja nirgend Dein Array aus dem iobroker wieder ein?
        Also hören wir doch mal auf, das Ergebnis - also das neue Array direkt abzuspeichern:
        So nun muss man also wieder was aus dem Datenpunkt einlesen, den man in iobroker geschrieben hat. das ist aber kompliziert, da der Datenpunkt ja dynamisch sich dauernd ändert. Ich überlege mir mal was.
        Inzwischen kannst Du Dir ja den modifizierten Flow - als Basis schon mal abspeichern - dann auf der Basis machen wir weiter.
               "type": "subflow",
               "info": "",
               "category": "",
               "in": [
                       "x": 60,
                       "y": 80,
                       "wires": [
               "out": [
                       "x": 820,
                       "y": 80,
                       "wires": [
                               "port": 0
               "env": [
                       "name": "basePath",
                       "type": "str",
               "meta": {},
               "color": "#DDAA99"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "datum",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 230,
               "y": 80,
               "wires": [
                       "0e8de9437c3c420a"
               "type": "change",
               "rules": [
                       "t": "change",
                       "p": "datum",
                       "pt": "msg",
                       "from": "März",
                       "fromt": "str",
                       "to": "Maerz",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 440,
               "y": 80,
               "wires": [
                       "fc37f5f9d2b0297b"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 660,
               "y": 80,
               "wires": [
               "id": "5073270521431406",
               "type": "debug",
               "z": "5dbdd0fd840b4eee",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1170,
               "y": 300,
               "wires": []
               "id": "10bd7990f72c7776",
               "name": "",
               "topic": "",
               "ack": "true",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 1340,
               "y": 220,
               "wires": []
               "id": "147888cb9d8dbd57",
               "name": "",
               "env": [
                       "name": "basePath",
                       "type": "str"
               "x": 1000,
               "y": 160,
               "wires": [
                       "5073270521431406",
                       "c097566fbf70cacc"
               "id": "9226f70990baa228",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "$append(array_bezug, payload)",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 790,
               "y": 160,
               "wires": [
                       "147888cb9d8dbd57"
               "id": "102ed68150c3074f",
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "array_bezug",
                       "pt": "msg",
                       "to": "array_bezug",
                       "tot": "flow"
                       "t": "set",
                       "p": "array_bezug",
                       "pt": "msg",
                       "to": "array_bezug ? array_bezug : []",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 570,
               "y": 160,
               "wires": [
                       "9226f70990baa228"
               "id": "fbcf46d8f94203aa",
               "type": "change",
               "name": "Bezug",
               "rules": [
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "Strombezug",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 350,
               "y": 120,
               "wires": [
                       "102ed68150c3074f"
               "id": "a435b3ce1f53ba74",
               "d": true,
               "onlyack": "",
               "func": "all",
               "gap": "",
               "x": 110,
               "y": 160,
               "wires": [
                       "fbcf46d8f94203aa"
               "id": "779ae42084de3e0c",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "Bezug täglich",
               "payload": "20.1",
               "payloadType": "num",
               "x": 110,
               "y": 120,
               "wires": [
                       "fbcf46d8f94203aa"
               "id": "c097566fbf70cacc",
               "type": "json",
               "name": "",
               "property": "payload",
               "action": "",
               "pretty": false,
               "x": 1170,
               "y": 220,
               "wires": [
                       "10bd7990f72c7776"
        Ich denke, ich muss den ganzen Flow etwas umstellen, damit es auch einigermaßen effizient wird. Also vergiß Deinen/Meinen bisherigen Flow.
          MartyBr @mickym last edited by
          @mickym
          Konntest du dir den Flow zur Monatslänge (von 9:48 Uhr) mal anschauen? Ich habe da eine globale Variable "Monatstage" definiert.
          • mickym
            @martybr Warum das nun wieder - ich habe den Flow nun fertig und wenn der Monat wechselt wird automatisch ein neuer Datenpunkt durch Deinen Subflow angelegt und auch eingelesen.
            Nein Sorry - Du hast Recht, wenn sich das Topic ändert, dann muss die Flowvariable noch gelöscht werden. Habe ich vergessen.
              @mickym
              Vielleicht irre ich mich auch. Ich habe von einem lieben Bekannten ein JavaScript, welches über die Werte iteriert. Hier werden die Zahl der Tage im Monat benötigt. Ich versuche hier mit deiner Hilfe Node-Red zu verstehen, da mich Javascript nicht angesprochen hat. Da gibt es mit async etc. genügend Fallstricke.
              Daher kommen manche meiner Fragen, die für die bestimmt selbstverständlich sind. Ich fange ja gerade erst mit Node-Red an. Das Buch das ich mir gekauft habe war nicht so toll.
              Einges habe ich schon in Node-Red umsetzen können:
              Meine Bewegungsmelder mit Zeitsteuerung und Sperre bei manuellem Auslösen und mit deiner Hilfe die Speicherung von Strombezug und Einspeisung.
              Ich konnte mit den Flows das ganze und weitere Anwendungen umsetzen, z.B. Wasserverbrauch, Gartenwasser, Solareinspeisung. Dadurch habe ich das Potential von Node-Red erkannt. Nun habe ich Zeit und versuche mich tiefer einzuarbeiten 😇
              • mickym
                @martybr Ja ich schau mir das gleich an -
                Aber zu deinem Flow mit den dynamischen Monatsarrays habe ich eine andere Lösung, da brauchst du die Zahl nicht. Sprich wenn sich das topic ändert, dann wird die bisherige flow Variable gelöscht und eine neue erstellt. Schau Dir erst mal den neuen Flow an:
                       "type": "subflow",
                       "info": "",
                       "category": "",
                       "in": [
                               "x": 60,
                               "y": 80,
                               "wires": [
                       "out": [
                               "x": 820,
                               "y": 80,
                               "wires": [
                                       "port": 0
                       "env": [
                               "name": "basePath",
                               "type": "str",
                       "meta": {},
                       "color": "#DDAA99"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "datum",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 230,
                       "y": 80,
                       "wires": [
                               "0e8de9437c3c420a"
                       "type": "change",
                       "rules": [
                               "t": "change",
                               "p": "datum",
                               "pt": "msg",
                               "from": "März",
                               "fromt": "str",
                               "to": "Maerz",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 440,
                       "y": 80,
                       "wires": [
                               "fc37f5f9d2b0297b"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 660,
                       "y": 80,
                       "wires": [
                       "name": "",
                       "topic": "",
                       "ack": "true",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2560,
                       "y": 160,
                       "wires": []
                       "type": "change",
                       "name": "Bezug",
                       "rules": [
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "Strombezug",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 350,
                       "y": 120,
                       "wires": [
                               "147888cb9d8dbd57"
                       "d": true,
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 170,
                       "y": 160,
                       "wires": [
                               "fbcf46d8f94203aa"
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "payload": "19.1",
                       "x": 170,
                       "y": 120,
                       "wires": [
                               "fbcf46d8f94203aa"
                       "type": "json",
                       "name": "",
                       "action": "",
                       "pretty": false,
                       "x": 2390,
                       "y": 160,
                       "wires": [
                               "10bd7990f72c7776"
                       "id": "6ece1ca957375987",
                       "type": "switch",
                       "name": "topic geändert?",
                       "property": "topic",
                       "propertyType": "msg",
                       "rules": [
                               "t": "neq",
                               "v": "",
                               "vt": "prev"
                               "t": "eq",
                               "v": "",
                               "vt": "prev"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 720,
                       "y": 120,
                       "wires": [
                               "eaac747b9c1b37da"
                               "102ed68150c3074f"
                       "name": "",
                       "env": [
                               "name": "basePath",
                               "type": "str"
                       "x": 520,
                       "y": 120,
                       "wires": [
                               "6ece1ca957375987"
                       "id": "82c856dec8c7af8d",
                       "type": "ioBroker get",
                       "name": "",
                       "topic": "",
                       "errOnInvalidState": "false",
                       "x": 1260,
                       "y": 80,
                       "wires": [
                               "95d876ec9e825008"
                       "id": "2672eebe41c3d35a",
                       "type": "json",
                       "name": "",
                       "action": "",
                       "pretty": false,
                       "x": 1650,
                       "y": 100,
                       "wires": [
                               "e7b2c3dba88f7574"
                       "id": "95d876ec9e825008",
                       "type": "switch",
                       "name": "IoB read ?",
                       "rules": [
                               "t": "null"
                               "t": "nnull"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 1450,
                       "y": 80,
                       "wires": [
                               "d2e703aaee60b32c"
                               "2672eebe41c3d35a"
                       "id": "d2e703aaee60b32c",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "[]",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1650,
                       "y": 60,
                       "wires": [
                               "e7b2c3dba88f7574"
                       "id": "eaac747b9c1b37da",
                       "type": "change",
                       "name": "payload sichern und flow var löschen",
                       "rules": [
                               "t": "move",
                               "p": "payload",
                               "pt": "msg",
                               "to": "payload_bak",
                               "tot": "msg"
                               "t": "delete",
                               "p": "array_bezug",
                               "pt": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 990,
                       "y": 80,
                       "wires": [
                               "82c856dec8c7af8d"
                       "id": "a89ae99abd8609c0",
                       "type": "change",
                       "name": "payload anhängen und sichern",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "jsonata"
                               "t": "set",
                               "p": "array_bezug",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 2170,
                       "y": 160,
                       "wires": [
                               "c097566fbf70cacc"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "array_bezug",
                               "pt": "msg",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 950,
                       "y": 160,
                       "wires": [
                               "a89ae99abd8609c0"
                       "id": "e7b2c3dba88f7574",
                       "type": "change",
                       "name": "payload wiederherstellen",
                       "rules": [
                               "t": "move",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "msg"
                               "t": "move",
                               "p": "payload_bak",
                               "pt": "msg",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1890,
                       "y": 80,
                       "wires": [
                               "a89ae99abd8609c0"
                und schau, ob Du den verstehst. Ansonsten schaun ich mir Deinen Flow gerne an - aber ich verstehe immer nicht, warum mit JS in NodeRed arbeitet - ich rate Dir immer, die function Nodes wenn möglich immer zu meiden. Für Deine dynamischen Datenpunkte solltest Du es nicht brauchen. Ich habe übrigens mal einen Flow gemacht, den Du Dir auch mal anschauen solltest.
                • mickym
                  @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
                  @mickym
                  Ich habe hier noch ein Problem, die Zahl der Tage im Monat in eine globale Variable zu schreiben. Statt der 28 Tage aus der Funktion liefert mir der Change Node nur payload == 5
                          "id": "f6ed836d74798c7f",
                          "type": "inject",
                          "z": "3ebdbbcf49e0ac40",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "",
                          "payloadType": "date",
                          "x": 100,
                          "y": 400,
                          "wires": [
                                  "a3434007e702fcdc"
                          "id": "7a09df47bef16411",
                          "type": "function",
                          "name": "function 1",
                          "func": "// Eingabe: msg.payload sollte ein Datum im Format 'YYYY-MM-DD' sein\nlet inputDate = new Date(msg.payload);\n\n// Hole den Monat und das Jahr\nlet month = inputDate.getMonth(); // 0-11\nlet year = inputDate.getFullYear();\n\n// Berechne die Anzahl der Tage im Monat\nlet daysInMonth = new Date(year, month + 1, 0).getDate();\n\n// Setze das Ergebnis in msg.payload\nmsg.payload = daysInMonth;\n\nreturn msg;",
                          "outputs": 1,
                          "timeout": 0,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 480,
                          "y": 400,
                          "wires": [
                                  "599b66169127c12d",
                                  "185c42081279a5e0"
                          "id": "a3434007e702fcdc",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "$moment().locale('de').format('YYYY.MM.DD')",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 290,
                          "y": 400,
                          "wires": [
                                  "7a09df47bef16411"
                          "id": "d8d647f4ae028cb8",
                          "type": "debug",
                          "name": "debug 182",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 670,
                          "y": 320,
                          "wires": []
                          "id": "599b66169127c12d",
                          "type": "change",
                          "name": "Monatstage",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "monatstage",
                                  "tot": "global"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 650,
                          "y": 400,
                          "wires": [
                                  "d8d647f4ae028cb8"
                          "id": "185c42081279a5e0",
                          "type": "debug",
                          "name": "debug 183",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 590,
                          "y": 480,
                          "wires": []
                  Das kann ich leider nicht nachvollziehen, bei mir funktioniert der Flow einwandfrei:
                  Ich schau trotzdem mal kurz, ob man das mit $moments direkt erledigen kann.
                    @mickym
                    Stimmt, bei mir liefert er nun die richtige Anzahl der Tage.
                    • mickym
                      @mickym
                      Ok - dann passt ja alles - ich bin dann erst mal weg - schau dann am Abend nochmal vorbei. Schau Dir mal den neuen Flow - für Deine Arrays und dynam. Datenpunkte derweil an.
                        @mickym
                        Es sieht alles gut aus. Ich werde mir das genau anschauen und danke dir für deine Hilfe.
                          Ich habe den Flow für die Mittelwertbildung auf den Node aggregate umgestellt.
                          Die Delays dienen der richtigen Reihenfolge der drei Werte min, mean und max im Json. Das ganze wird in einem fortlaufenden Array unter Jahr.Monat abgelegt.
                          Hier der Flow, der zumindest bei mir ohne Fehler erfolgreich läuft.
                                  "type": "subflow",
                                  "info": "",
                                  "category": "",
                                  "in": [
                                          "x": 60,
                                          "y": 80,
                                          "wires": [
                                  "out": [
                                          "x": 820,
                                          "y": 80,
                                          "wires": [
                                                  "port": 0
                                  "env": [
                                          "name": "basePath",
                                          "type": "str",
                                  "meta": {},
                                  "color": "#DDAA99"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "datum",
                                          "pt": "msg",
                                          "tot": "jsonata"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 230,
                                  "y": 80,
                                  "wires": [
                                          "0e8de9437c3c420a"
                                  "type": "change",
                                  "rules": [
                                          "t": "change",
                                          "p": "datum",
                                          "pt": "msg",
                                          "from": "März",
                                          "fromt": "str",
                                          "to": "Maerz",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 440,
                                  "y": 80,
                                  "wires": [
                                          "fc37f5f9d2b0297b"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "tot": "jsonata"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 660,
                                  "y": 80,
                                  "wires": [
                                  "id": "8c459eb88d1bf5f1",
                                  "type": "tab",
                                  "label": "Mittelwert",
                                  "disabled": false,
                                  "info": "",
                                  "env": []
                                  "id": "9b11db08a1cca5b3",
                                  "type": "aggregator",
                                  "z": "8c459eb88d1bf5f1",
                                  "name": "Mean",
                                  "topic": "mean",
                                  "intervalCount": "1",
                                  "intervalUnits": "d",
                                  "submitIncompleteInterval": true,
                                  "submitPerTopic": false,
                                  "aggregationType": "mean",
                                  "x": 290,
                                  "y": 260,
                                  "wires": [
                                          "0290eb1787934b73"
                                  "id": "f33e1d253e22a2dd",
                                  "name": "Aussentemperatur",
                                  "topic": "mqtt.0.vitocal.outside_temperature",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "fireOnStart": "false",
                                  "x": 110,
                                  "y": 260,
                                  "wires": [
                                          "5a18bba8160e8e94",
                                          "9b11db08a1cca5b3",
                                          "32753fd69085ce71"
                                  "id": "5a18bba8160e8e94",
                                  "name": "Min",
                                  "topic": "min",
                                  "aggregationType": "min",
                                  "x": 290,
                                  "y": 200,
                                  "wires": [
                                          "15a56c790ce29f8d"
                                  "id": "32753fd69085ce71",
                                  "name": "Max",
                                  "topic": "max",
                                  "aggregationType": "max",
                                  "x": 290,
                                  "y": 320,
                                  "wires": [
                                          "7a8c3b56e65b5059"
                                  "id": "15a56c790ce29f8d",
                                  "type": "join",
                                  "name": "",
                                  "mode": "custom",
                                  "build": "object",
                                  "key": "topic",
                                  "joiner": "\\n",
                                  "joinerType": "str",
                                  "accumulate": true,
                                  "timeout": "60",
                                  "count": "3",
                                  "reduceRight": false,
                                  "reduceExp": "",
                                  "reduceInit": "",
                                  "reduceInitType": "",
                                  "reduceFixup": "",
                                  "x": 670,
                                  "y": 200,
                                  "wires": [
                                          "8ef8ee85844f2bb2"
                                  "id": "8ef8ee85844f2bb2",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "meanTmp",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 840,
                                  "y": 200,
                                  "wires": [
                                          "5d3e4f7dea0efe7c"
                                  "id": "5d3e4f7dea0efe7c",
                                  "env": [
                                          "name": "basePath",
                                          "value": "Heizung1.MonatsTabellen",
                                          "type": "str"
                                  "x": 1040,
                                  "y": 200,
                                  "wires": [
                                          "9aa634789fccf445"
                                  "id": "e44c746b92947c39",
                                  "name": "",
                                  "topic": "",
                                  "ack": "true",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "stateUnit": "°C",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 2920,
                                  "y": 280,
                                  "wires": []
                                  "id": "0290eb1787934b73",
                                  "type": "delay",
                                  "name": "",
                                  "pauseType": "delay",
                                  "timeout": "5",
                                  "timeoutUnits": "seconds",
                                  "rate": "1",
                                  "nbRateUnits": "1",
                                  "rateUnits": "second",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "randomUnits": "seconds",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 460,
                                  "y": 260,
                                  "wires": [
                                          "15a56c790ce29f8d"
                                  "id": "7a8c3b56e65b5059",
                                  "type": "delay",
                                  "name": "",
                                  "timeout": "10",
                                  "rate": "1",
                                  "nbRateUnits": "1",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 470,
                                  "y": 320,
                                  "wires": [
                                          "15a56c790ce29f8d"
                                  "id": "9aa634789fccf445",
                                  "type": "switch",
                                  "rules": [
                                          "t": "neq",
                                          "v": "",
                                          "vt": "prev"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "prev"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 1240,
                                  "y": 200,
                                  "wires": [
                                          "c7fa49ea854690ed"
                                          "edaece611a7db6d5"
                                  "id": "c7fa49ea854690ed",
                                  "type": "change",
                                  "rules": [
                                          "t": "move",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "payload_bak_mean",
                                          "tot": "msg"
                                          "t": "delete",
                                          "p": "array_mean",
                                          "pt": "flow"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1530,
                                  "y": 180,
                                  "wires": [
                                          "7fd2bba1daf6d9f3"
                                  "id": "edaece611a7db6d5",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "array_bezug",
                                          "pt": "msg",
                                          "tot": "flow"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1490,
                                  "y": 280,
                                  "wires": [
                                          "515ae9918126f535"
                                  "id": "7fd2bba1daf6d9f3",
                                  "name": "",
                                  "topic": "",
                                  "x": 1800,
                                  "y": 180,
                                  "wires": [
                                          "6e576a4e6d33f548"
                                  "id": "6e576a4e6d33f548",
                                  "type": "switch",
                                  "rules": [
                                          "t": "null"
                                          "t": "nnull"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 2010,
                                  "y": 180,
                                  "wires": [
                                          "ba58ec451fbfa53e"
                                          "ae2e0346dd5f3824"
                                  "id": "ba58ec451fbfa53e",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "[]",
                                          "tot": "json"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 2250,
                                  "y": 160,
                                  "wires": [
                                          "db03a4ed74093df5"
                                  "id": "ae2e0346dd5f3824",
                                  "type": "json",
                                  "name": "",
                                  "action": "",
                                  "pretty": false,
                                  "x": 2230,
                                  "y": 220,
                                  "wires": [
                                          "db03a4ed74093df5"
                                  "id": "db03a4ed74093df5",
                                  "type": "change",
                                  "rules": [
                                          "t": "move",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "array_mean",
                                          "tot": "msg"
                                          "t": "move",
                                          "p": "payload_bak_mean",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 2490,
                                  "y": 160,
                                  "wires": [
                                          "515ae9918126f535"
                                  "id": "515ae9918126f535",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "$append(array_mean, payload)",
                                          "tot": "jsonata"
                                          "t": "set",
                                          "p": "array_mean",
                                          "pt": "flow",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 2510,
                                  "y": 280,
                                  "wires": [
                                          "0427391d23dcb6ad"
                                  "id": "0427391d23dcb6ad",
                                  "type": "json",
                                  "name": "",
                                  "action": "",
                                  "pretty": false,
                                  "x": 2750,
                                  "y": 280,
                                  "wires": [
                                          "e44c746b92947c39"
                            MartyBr @MartyBr last edited by MartyBr
                            @mickym
                            Ich habe noch eine Frage zu dem u.a. Flow. Ich würde gerne den Payload min, mean und max
                            an die Tagesposition schieben.
                            Also das bedeutet heute (09.02.2025) die 9 Position, das das Element 8.
                            Man könnte doch mit einem Function Node den Code
                            let i ===global.monatstage
                            i = i-1
                            msg.payload[i] = msg.payload[i].state
                            schreiben. Ich habe Monatstage als globale Variable definiert.
                            Mein Problem ist aber im Change node das append. Das widerspricht ja die Nutzung der Function Node.
                            Hast du einen Tipp für mich?
                            EDIT:
                            Ich habe in der Doku gesehen, dass auch in der Change Node mit JSONata mit $sum(payload.state in die Elemente des Arrays geschrieben werden kann.
                            Array Mean:
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": -4,
                                "mean": 0.05,
                                "max": 3.3
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                                "min": 0,
                                "mean": 0,
                                "max": 0
                            code_tex[
                                    "type": "subflow",
                                    "info": "",
                                    "category": "",
                                    "in": [
                                            "x": 60,
                                            "y": 80,
                                            "wires": [
                                    "out": [
                                            "x": 820,
                                            "y": 80,
                                            "wires": [
                                                    "port": 0
                                    "env": [
                                            "name": "basePath",
                                            "type": "str",
                                    "meta": {},
                                    "color": "#DDAA99"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "datum",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 230,
                                    "y": 80,
                                    "wires": [
                                            "0e8de9437c3c420a"
                                    "type": "change",
                                    "rules": [
                                            "t": "change",
                                            "p": "datum",
                                            "pt": "msg",
                                            "from": "März",
                                            "fromt": "str",
                                            "to": "Maerz",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 440,
                                    "y": 80,
                                    "wires": [
                                            "fc37f5f9d2b0297b"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 660,
                                    "y": 80,
                                    "wires": [
                                    "name": "Mean",
                                    "topic": "mean",
                                    "intervalUnits": "h",
                                    "x": 290,
                                    "y": 260,
                                    "wires": [
                                            "0290eb1787934b73"
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 110,
                                    "y": 260,
                                    "wires": [
                                            "5a18bba8160e8e94",
                                            "9b11db08a1cca5b3",
                                            "32753fd69085ce71"
                                    "name": "Min",
                                    "topic": "min",
                                    "x": 290,
                                    "y": 200,
                                    "wires": [
                                            "15a56c790ce29f8d"
                                    "name": "Max",
                                    "topic": "max",
                                    "x": 290,
                                    "y": 320,
                                    "wires": [
                                            "7a8c3b56e65b5059"
                                    "type": "join",
                                    "name": "",
                                    "mode": "custom",
                                    "build": "object",
                                    "key": "topic",
                                    "joiner": "\\n",
                                    "accumulate": true,
                                    "timeout": "60",
                                    "count": "3",
                                    "reduceExp": "",
                                    "reduceInit": "",
                                    "reduceFixup": "",
                                    "x": 670,
                                    "y": 200,
                                    "wires": [
                                            "8ef8ee85844f2bb2"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "meanTmp",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 840,
                                    "y": 200,
                                    "wires": [
                                            "5d3e4f7dea0efe7c"
                                    "env": [
                                            "name": "basePath",
                                            "type": "str"
                                    "x": 1040,
                                    "y": 200,
                                    "wires": [
                                            "9aa634789fccf445"
                                    "name": "",
                                    "topic": "",
                                    "ack": "true",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "stateUnit": "°C",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 2920,
                                    "y": 280,
                                    "wires": []
                                    "type": "delay",
                                    "name": "",
                                    "timeout": "5",
                                    "rate": "1",
                                    "nbRateUnits": "1",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 460,
                                    "y": 260,
                                    "wires": [
                                            "15a56c790ce29f8d"
                                    "type": "delay",
                                    "name": "",
                                    "timeout": "10",
                                    "rate": "1",
                                    "nbRateUnits": "1",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 470,
                                    "y": 320,
                                    "wires": [
                                            "15a56c790ce29f8d"
                                    "type": "switch",
                                    "rules": [
                                            "t": "neq",
                                            "v": "",
                                            "vt": "prev"
                                            "t": "eq",
                                            "v": "",
                                            "vt": "prev"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 1240,
                                    "y": 200,
                                    "wires": [
                                            "c7fa49ea854690ed"
                                            "edaece611a7db6d5"
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "msg"
                                            "t": "delete",
                                            "p": "array_mean",
                                            "pt": "flow"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1530,
                                    "y": 180,
                                    "wires": [
                                            "7fd2bba1daf6d9f3"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "array_bezug",
                                            "pt": "msg",
                                            "tot": "flow"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1490,
                                    "y": 280,
                                    "wires": [
                                            "515ae9918126f535"
                                    "name": "",
                                    "topic": "",
                                    "x": 1800,
                                    "y": 180,
                                    "wires": [
                                            "6e576a4e6d33f548"
                                    "type": "switch",
                                    "rules": [
                                            "t": "null"
                                            "t": "nnull"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 2010,
                                    "y": 180,
                                    "wires": [
                                            "ba58ec451fbfa53e"
                                            "ae2e0346dd5f3824"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "[]",
                                            "tot": "json"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 2250,
                                    "y": 160,
                                    "wires": [
                                            "db03a4ed74093df5"
                                    "type": "json",
                                    "name": "",
                                    "action": "",
                                    "pretty": false,
                                    "x": 2230,
                                    "y": 220,
                                    "wires": [
                                            "db03a4ed74093df5"
                                    "type": "change",
                                    "rules": [
                                            "t": "move",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "array_mean",
                                            "tot": "msg"
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 2490,
                                    "y": 160,
                                    "wires": [
                                            "515ae9918126f535"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                            "t": "set",
                                            "p": "array_mean",
                                            "pt": "flow",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 2510,
                                    "y": 280,
                                    "wires": [
                                            "0427391d23dcb6ad"
                                    "type": "json",
                                    "name": "",
                                    "action": "",
                                    "pretty": false,
                                    "x": 2750,
                                    "y": 280,
                                    "wires": [
                                            "e44c746b92947c39"
                                    "id": "809efb6124c3639c",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "$moment().date()",
                                            "tot": "jsonata"
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "monatstage",
                                            "tot": "global"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 290,
                                    "y": 460,
                                    "wires": [
                                            "a27f09da64977051"
                                    "id": "02c66f19b70ff804",
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                            "p": "payload"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "300",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 110,
                                    "y": 460,
                                    "wires": [
                                            "809efb6124c3639c"
                                    "id": "a27f09da64977051",
                                    "type": "debug",
                                    "name": "Datum",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "payload",
                                    "targetType": "msg",
                                    "statusVal": "",
                                    "x": 470,
                                    "y": 460,
                                    "wires": []
                                    "id": "be82df1e7a1f3571",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                            "t": "set",
                                            "p": "array_mean",
                                            "pt": "flow",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 2470,
                                    "y": 380,
                                    "wires": [
                            ]t
                            • mickym
                              du brauchst keine monatstage etc. du hast doch ein Array und da bildest du einfach den durchschnitt der werte. das Array wid doch jeden monat neu geschrieben
                                @mickym
                                Ich dachte mir das nur als Fallback, wenn iobroker / Node-red mal steht und ein Tag übersprungen wird.
                                So klappt es wunderbar und ich fuchse mich so langsam in die Materie ein.
                                M mickym 2 Replies Last reply Reply Quote 0
                                  @mickym
                                  Ich sehe gerade den Read IOB Baustein. Liesst dieser die Anzahl der Elemente im Array ein? Ich sehe hier keine Einstellungen oder Code.
                                  • mickym
                                    @martybr aber gerade wenn ein Tag übersprungen wird, ist es doch sinnvoller den Durschnitt der real gemessenen Werte zu nehmen.
                                      @mickym
                                      In meinem Anwendungsfall setze ich die täglichen Temperaturen im Verhältnis zu den Heizungsverbräuchen, also mehr Stromverbrauch der Wärmepumpe bei niedrigeren Außentemperaturen.
                                      Das dient daher zur Einschätzung der Effektivität der Wärmepumpe.
                                      Ich hoffe, ich habe hier meinen Ansatz erklären können 🤓
                                      • mickym
                                        @mickym
                                        na eben, dann ist es doch sinnvoller, wenn deine Arrays sich aus Tageswerten zusammensetzt, davon den Durchschnitt zu nehmen, als durch eine fixe theoretische Anzahl an Tagen. Sprich Dein Array enthält nur 26 Werte im Februar- dann ist es doch sinnvoller den Durchschnitt aus 26 Werten zu nehmen, als die Summe durch 28 zu teilen.
                                        • mickym
                                          mickym Most Active last edited by mickym
                                          ja aner mach wie du denkst. ja mit Jsonata kannst du Durchnitt, Summen etc. über Arrays bilden.
                                          am einfachsten ist es dann wenn du das Array in einen Datenpunkt schreibst auch gleich die aggregierten Werte in entsprechende Datenpunkte zu schreiben
                                            @mickym
                                            Kannst du mir die Syntax nennen? Wie schreibe ich mit JSONata in ein Element des Array?
                                            Ich mache mich dann an die Arbeit.
                                            Die täglichen Temperaturwerte habe ich ja im Flow. Ich muss sie dann mit save payload.state [i] an die richtige Stelle schreiben.
                                            8935
