    4. io Broker startet nicht mehr
      MrNight @Homoran last edited by
      Nun mache mir mal keine Angst 🥲……was aber wohl am Limit läuft ist der Arbeitsspeicher.
      Da kam schon eine Meldung.
        Homoran Global Moderator Administrators @MrNight last edited by
        @mrnight sagte in io Broker startet nicht mehr:
        das hilft ohne exakten Wortlaut nichts!
        was sagt denn top
          Bevor ich was zerschiesse….ich habe ja einen MacMini laufen. Der Befehl „Top“ kommt doch von linux.
          Oder wie finde ich es?
            und apfelware ist modifiziertes linux
              ommands:
                iobroker setup                                               Setup ioBroker
                iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                iobroker info                                                Shows the host info
                iobroker logs [<adapter>]                                    Monitor log
                iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                iobroker rebuild [<module>]                                  Rebuild all native modules or path
                iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
                iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                iobroker update [<repositoryUrl>]                            Update repository and list adapters
                iobroker upgrade                                             Upgrade management
                iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                iobroker object                                              Object management  [aliases: o]
                iobroker state                                               State management  [aliases: s]
                iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                iobroker list <type> [<filter>]                              List all entries, like objects
                iobroker chmod <mode> <file>                                 Change file rights
                iobroker chown <user> <group> <file>                         Change file ownership
                iobroker touch <file>                                        Touch file
                iobroker rm <file>                                           Remove file
                iobroker file                                                File management
                iobroker user                                                User commands
                iobroker group                                               group management
                iobroker host <hostname>                                     Set host to given hostname
                iobroker set <adapter>.<instance>                            Change settings of adapter config
                iobroker license <license.file or license.text>              Update license by given file
                iobroker cert                                                Certificate management
                iobroker clean <yes>                                         Clears all objects and states
                iobroker backup                                              Create backup
                iobroker restore <backup name or path>                       Restore a specified backup
                iobroker validate <backup name or path>                      Validate a specified backup
                iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                iobroker repo                                                Show repo information
                iobroker uuid                                                Show uuid of the installation  [aliases: id]
                iobroker unsetup                                             Reset license, installation secret and language
                iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                iobroker multihost                                           Multihost management
                iobroker compact                                             compact group management
                iobroker plugin                                              Plugin management
                iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
              Options:
                --help  Show help  [boolean]
                @mrnight bitte immer alles zeigen!
                was hast du eingegeben?
                  ./IoBroker top habe ich eingegeben.
                    Thomas Braun Most Active @MrNight last edited by
                    @mrnight
                    top
                    ist ein eigenes Programm und hat mit dem iobroker nichts zu tun.
                    Ich weiß nur nicht, ob es das bei dir gibt.
                      MrNight @Thomas Braun last edited by
                      Was ich dir so sagen kann ist…..das er in IObroker anzeigt das nur 1GB RAM zur Verfügung stehen…..wenn ich aber beim Mac so schaue hat er noch gute 5GB frei von 8GB.
                        @mrnight
                        Du solltest dir angewöhnen, weniger zu umschreiben und nachzuerzählen. Hier sind eher Fakten (Auszüge aus dem Terminal) gefragt. Da kann man auch mehr mit anfangen...
                          Das hatte ich so ja nicht geschrieben.
                          Deswegen immer alles zeigen.
                          Von der Eingabe bis zum letzten iota der Ausgabe
                          2626
