    4. Motion Blinds Adapter
    • VBen 0
      VBen 0 @biker1602 last edited by
      @biker1602 said in Motion Blinds Adapter:
      Kann man den nicht über die Konsole installieren?
      Was mich wundert wenn ich über die Konsole iobroker update -i
      eingebe, erscheint der Adapter garnicht.
      automatische updates werden nicht gehen
      was kommt denn in dem Fenster für eine Fehlermeldung wenn man den Adatper übers Webinterface von github installiert?
        biker1602 @VBen 0 last edited by
        @vben-0
        2024-08-13 11:37:39.988 - error: host.iobroker iobroker npm error code 127npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > core-js-pure@3.9.0 postinstallnpm error > node -e "try{require('./postinstall')}catch(e){}"npm errornpm error Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!npm errornpm error The project needs your help! Please consider supporting of core-js on Open Collective or Patreon: npm error > https://opencollective.com/core-js npm error > https://www.patreon.com/zloirock npm errornpm error Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)npm errornpm errornpm error > husky@5.1.1 postinstallnpm error > npm run build && node lib/bin installnpm errornpm errornpm error > husky@5.1.1 prebuildnpm error > del-cli libnpm error npm warn using --force Recommended protections disabled.npm error npm warn ERESOLVE overriding peer dependencynpm error npm warn While resolving: tsdx@0.14.1npm error npm warn Found: peer @typescript-eslint/parser@"^4.0.0" from @typescript-eslint/eslint-plugin@4.15.2npm error npm warn node_modules/tsdx/node_modules/@typescript-eslint/eslint-pluginnpm error npm warnnpm error npm warn Could not resolve dependency:npm error npm warn peer @typescript-eslint/parser@"^4.0.0" from @typescript-eslint/eslint-plugin@4.15.2npm error npm warn node_modules/tsdx/node_modules/@typescript-eslint/eslint-pluginnpm error npm warn deprecated is-data-descriptor@0.1.4: Please upgrade to v0.1.5npm error npm warn deprecated is-accessor-descriptor@0.1.6: Please upgrade to v0.1.7npm error npm warn deprecated is-data-descriptor@0.1.4: Please upgrade to v0.1.5npm error npm warn deprecated is-accessor-descriptor@0.1.6: Please upgrade to v0.1.7npm error npm warn deprecated is-accessor-descriptor@0.1.6: Please upgrade to v0.1.7npm error npm warn deprecated is-data-descriptor@0.1.4: Please upgrade to v0.1.5npm error npm warn deprecated is-data-descriptor@0.1.4: Please upgrade to v0.1.5npm error npm warn deprecated is-accessor-descriptor@0.1.6: Please upgrade to v0.1.7npm error npm warn deprecated is-data-descriptor@1.0.0: Please upgrade to v1.0.1npm error npm warn deprecated is-accessor-descriptor@1.0.0: Please upgrade to v1.0.1npm error npm warn deprecated is-data-descriptor@0.1.4: Please upgrade to v0.1.5npm error npm warn deprecated is-accessor-descriptor@0.1.6: Please upgrade to v0.1.7npm error npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.npm error npm warn deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecatednpm error npm warn deprecated @babel/plugin-proposal-unicode-property-regex@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-unicode-property-regex instead.npm error npm warn deprecated @babel/plugin-proposal-private-methods@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-private-methods instead.npm error npm warn deprecated @babel/plugin-proposal-optional-catch-binding@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-optional-catch-binding instead.npm error npm warn deprecated @babel/plugin-proposal-nullish-coalescing-operator@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-nullish-coalescing-operator instead.npm error npm warn deprecated @babel/plugin-proposal-logical-assignment-operators@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-logical-assignment-operators instead.npm error npm warn deprecated @babel/plugin-proposal-export-namespace-from@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-export-namespace-from instead.npm error npm warn deprecated @babel/plugin-proposal-numeric-separator@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-numeric-separator instead.npm error npm warn deprecated @babel/plugin-proposal-dynamic-import@7.12.17: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-dynamic-import instead.npm error npm warn deprecated @babel/plugin-proposal-json-strings@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-json-strings instead.npm error npm warn deprecated @babel/plugin-proposal-class-properties@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-class-properties instead.npm error npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142npm error npm warn deprecated rimraf@2.6.3: Rimraf versions prior to v4 are no longer supportednpm error npm warn deprecated @babel/plugin-proposal-async-generator-functions@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-async-generator-functions instead.npm error npm warn deprecated rollup-plugin-terser@5.3.1: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-tersernpm error npm warn deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecatednpm error npm warn deprecated source-map-resolve@0.6.0: See https://github.com/lydell/source-map-resolve#deprecatednpm error npm warn deprecated har-validator@5.1.5: this library is no longer supportednpm error npm warn deprecated @babel/plugin-proposal-object-rest-spread@7.12.13: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-object-rest-spread instead.npm error npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supportednpm error npm warn deprecated @babel/plugin-proposal-optional-chaining@7.12.17: This proposal has been merged to the ECMAScript standard and thus this plugin is no longer maintained. Please use @babel/plugin-transform-optional-chaining instead.npm error npm warn deprecated domexception@1.0.1: Use your platform's native DOMException insteadnpm error npm warn deprecated abab@2.0.5: Use your platform's native atob() and btoa() methods insteadnpm error npm warn deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecatednpm error npm warn deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecatednpm error npm warn deprecated glob@7.1.6: Glob versions prior to v9 are no longer supportednpm error npm warn deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.npm error npm warn deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec insteadnpm error npm warn deprecated sane@4.1.0: some dependency vulnerabilities fixed, support for node < 10 dropped, and newer ECMAScript syntax/features addednpm error npm warn deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.npm error npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.npm error npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142npm error npm warn deprecated core-js-pure@3.9.0: core-js-pure@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js-pure.npm error npm warn using --force Recommended protections disabled.npm error sh: 1: del-cli: not foundnpm error npm error code 127npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXWMIZBk/node_modules/huskynpm error npm error command failednpm error npm error command sh -c npm run build && node lib/bin installnpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-13T09_37_07_303Z-debug-0.lognpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-13T09_37_01_692Z-debug-0.log
        2024-08-13 11:37:39.992 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.motionblinds@latest: 127
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        VBen 0 1 Reply Last reply Reply Quote 0
        • VBen 0
          @biker1602 Ich sehe den Fehler in der Dependency Auflösung, kann ihn auch reproduzieren, nur weiß leider nicht weich ich ihn fixen soll
            @vben-0
            Vielleicht hat ja jemand anders eine Idee und kann helfen 🤷‍♂️
            VBen 0 2 Replies Last reply Reply Quote 0
            • VBen 0
              @biker1602
              Ich hab's inzwischen gefunden, bin aber eigentlich von einem anderen Paket abhängig, ich hoffe der Maintainer patched das schnell.
              Als erste Abhilfe hier beschrieben, wie man die Entwickler Version installieren kann.
              https://github.com/VBen/ioBroker.motionblinds/issues/193
              jan98211 created this issue in VBen/ioBroker.motionblinds
              closed [BUG] Installation error #193
              • VBen 0
                @biker1602
                Es ist jetzt im npm released version 0.3.0
                B N 2 Replies Last reply Reply Quote 0
                  biker1602 @VBen 0 last edited by biker1602
                  @vben-0 said in Motion Blinds Adapter:
                  @biker1602
                  Ich habe den Adapter mal installiert aber der Akkustand wird weiterhin nicht richtig angezeigt.
                  Ich habe zwei Motion Blind Rollos und habe sie jetzt 2 Stunden geladen und in der App werden sie auch als voll angezeigt aber im ioBroker wird bei einem 85% angezeigt und bei dem anderen 97% der mit 85% ist allerdings ein neueres Modell.
                  Rollomotor MotionBlinds CMD-02 von Hornbach. der läuft aber auch über die gleiche App und gleiche Bridge. Nur der hat zusatzlich zu dem anderen ein kurze Kette dran wo man es auch manuell steuern kann einmal kurz ziehen Rollo runter nochmal kurz ziehen stop und wieder ziehen wieder hoch. Funktioniert MEGA! Gut für die Frau wenn ich mal nicht da bin👍
                  • N
                    Nobbi2 @VBen 0 last edited by
                    @vben-0 Bei den Adaptern sehe ich den noch nicht.. Oder nur über GitHub ???
                    • N
                      Nobbi2 @biker1602 last edited by
                      @biker1602 Ich habe grad mal die 0.3 über Github installiert, läuft. Die Akkuladung beobachte ich jetzt erstmal. Ich hatte meine ersten Motionblinds von Senovo, da konnte man sich aussuchen ob mit oder ohne Kette. für die Blinds habe ich die auch genommen.
                      Anfang des Jahres habe ich mir noch Gardinen mit dem Antrieb gekauft, da gibt es aber keine Kette ( oder wurde zumindest nicht angeboten )
                      Die Motionblinds bzw. diese Antriebe werden lt. meines Händlers immer beliebter. Finde ich gut 🙂
                      Allerdings werden meine Antriebe nach einem reboot oder einem Neustart von Iobroker nicht wieder eingelesen. Verbindung mit dem CM-20 ja aber die Antriebe werden vom Adapter nicht gefunden --> Da muss ich immer noch den CM-20 einmal stromlos machen und dann die Instanz neu starten...
                        maxpd last edited by maxpd
                        bei mir wird der aktuelle Stand der Rollos in Sekunden in die iobroker Datenobjekte geschrieben, soweit so gut. Aber wie steuere ich den Rollo über die Datenpunkte? Ändere ich "position" oder "fullup" "fulldown" passiert nichts, außer, dass nach ein paar Sekunden wieder der aktuelle Wert der Rollos reingeschrieben wird.
                        PS: Akku vor 7 Tagen voll geladen und Rollo nicht genutzt, zeigt bei mir 53% an.
                        Habe die CMD-01 Bridge und den CMD-02 Rollo. Multicast IP mal leergelassen, mit der vorgeschlagenen IP aus GIT bleibt der Adapter rot.
                        PS2: Konnte das Signal der Rollos leider nicht mit einer SONOFF Bridge abfangen, um mir die MotionBlinds Bridge zu sparen 😞
                        M B 2 Replies Last reply Reply Quote 0
                          maxpd @maxpd last edited by
                          Hier noch das Error Log. Der Adapter stürzt bei Änderung des Datenpunktes ab.
                          motionblinds.0
                          2025-02-10 09:56:10.538	info	terminating
                          motionblinds.0
                          2025-02-10 09:56:10.036	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          motionblinds.0
                          2025-02-10 09:56:10.034	info	terminating
                          motionblinds.0
                          2025-02-10 09:56:10.033	error	error while unloding module: Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
                          motionblinds.0
                          2025-02-10 09:56:10.030	info	Shutting down adapter
                          motionblinds.0
                          2025-02-10 09:56:10.024	error	Exception-Code: ERR_CRYPTO_INVALID_KEYLEN: Invalid key length
                          motionblinds.0
                          2025-02-10 09:56:10.023	error	RangeError: Invalid key length at Cipheriv.createCipherBase (node:internal/crypto/cipher:121:19) at Cipheriv.createCipherWithIV (node:internal/crypto/cipher:140:3) at new Cipheriv (node:internal/crypto/cipher:243:3) at Object.createCipheriv (node:crypto:147:10) at Function.AccessToken (/opt/iobroker/node_modules/@vben19/motionblinds/dist/motionblinds.cjs.development.js:643:36) at MotionGateway.writeDevice (/opt/iobroker/node_modules/@vben19/motionblinds/dist/motionblinds.cjs.development.js:603:35) at Motionblinds.onStateChange (/opt/iobroker/node_modules/iobroker.motionblinds/build/main.js:131:60) at Motionblinds.emit (node:events:518:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7338:39) at process.processImmediate (node:internal/timers:483:21)
                          motionblinds.0
                          2025-02-10 09:56:10.020	error	unhandled promise rejection: Invalid key length
                          motionblinds.0
                          2025-02-10 09:56:10.019	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          motionblinds.0
                          2025-02-10 09:56:10.014	info	state motionblinds.0.9c9e6e4567b00001.position changed: 50 (ack = false)
                            Ist es auch irgendwie möglich die Bluetooth Rollos von MotionBlinds ohne den Dongle direkt über das BT Modul des Raspi zu nutzen?
                            Im BLE Adapter taucht der Rollo zwar auf, aber ohne nutzbare Datenpunkte.
                              biker1602 @maxpd last edited by
                              @maxpd said in Motion Blinds Adapter:
                              So viel wie ich weiß, braucht man definitiv den Dongle.
                                IP Adresse muss nicht rein nur der Zugangstoken aus der App und damit läuft es bei mir tadellos.
                                  maxpd @biker1602 last edited by
                                  @biker1602 hab gleiches problem bei zigbee, daten kommen rein, aber gesendet wird nicht. hab da ein generelles problem.
                                    Was passiert wenn du das Rollo über die App rauf und runter fährst. Ändern sich die Werte im IOB dann?
                                      @biker1602 ja das funktioniert. Alle Antennen / Dongles an den USB Ports empfangen Daten. Das Senden funktioniert nur nicht.
                                        Fehler gefunden. Es fehlte 1 Buchstabe im Token. Dass er trotzdem alle Geräte findet und Daten erhält, aber nicht sendet, sagt einiges über das Tokensystem von Motionblinds aus.
                                        • O
                                          oxident last edited by
                                          Benutzt hier eigentlich jemand die "unsmarten" Funk-Rollos/Markisen, also die, die keine Rückmeldung geben?
                                          Mein Problem ist, dass diese ja nur "Auf", "Zu" und "Stop" können. Daher kann ich z. B. keine 50% anfahren.
                                          In der Vergangenheit hatte ich eine FHEM-Lösung hierfür verwendet und da haben die Entwickler das recht smart mit Timer gelöst. Ich glaube, Homematic und Shelly machen das (intern) ja auch so.
                                          Hat eventuell jemand so etwas schon im iobroker nachgebaut? Also quasi ein Script/Blockly, welches die Laufzeit misst und dadurch die tatsächliche Behanghöhe ermittelt.
                                          85
                                          10556
