    4. vis-2-widgets-collection
    • carsten04
      carsten04 Developer @NWH last edited by
      @nwh Hast Du die aktuelle Version v1.1.15 installiert? Wenn ja, dann aktualisiere mal die vis-2 mit F5 bei geöffneten Dev-Tools und falls ein Fehler angezeigt wird, dann poste diesen hier einmal. Bei mir läuft alles ohne Probleme mit der v1.1.15.
      NWH 1 Reply Last reply Reply Quote 0
      • NWH
        NWH @carsten04 last edited by
        @carsten04
        Ja ich habe die aktuelle Version installiert.
        Bitte sehr.
        Cannot load i18n "vis2CollectionWidget": ChunkLoadError: Loading chunk src_translations_js failed.
        (error: http://192.168.100.100:8082/vis-2/widgets/vis-2-widgets-collection/static/js/src_translations_js.18023e1d.chunk.js)
        customWidgets.js:1
               GET http://192.168.100.100:8082/vis-2/widgets/vis-2-widgets-collection/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987.9c21ae2e.chunk.js net::ERR_ABORTED 404 (Not Found)
        s.l @ customWidgets.js:1
        s.f.j @ customWidgets.js:1
        (anonymous) @ ensure chunk:6
        s.e @ ensure chunk:5
        ./StateCollectionWidget @ customWidgets.js:1
        o @ customWidgets.js:1
        (anonymous) @ visLoadWidgets.tsx:144
        await in (anonymous)
        (anonymous) @ visLoadWidgets.tsx:177
        n @ visLoadWidgets.tsx:173
        (anonymous) @ visLoadWidgets.tsx:326
        Promise.then
        (anonymous) @ visLoadWidgets.tsx:254
        Promise.then
        r @ visLoadWidgets.tsx:225
        (anonymous) @ visWidgetsCatalog.tsx:302
        setTimeout
        (anonymous) @ visWidgetsCatalog.tsx:301
        collectRxInformation @ visWidgetsCatalog.tsx:300
        onWidgetsLoaded @ Runtime.jsx:813
        onLoaded @ Runtime.jsx:1028
        loadWidgets @ visEngine.jsx:1529
        await in loadWidgets
        (anonymous) @ visEngine.jsx:208
        Promise.then
        Mt @ visEngine.jsx:196
        cs @ react-dom.production.min.js:184
        Vs @ react-dom.production.min.js:197
        Hi @ react-dom.production.min.js:291
        Ml @ react-dom.production.min.js:279
        gl @ react-dom.production.min.js:279
        fl @ react-dom.production.min.js:279
        rl @ react-dom.production.min.js:267
        S @ scheduler.production.min.js:13
        T @ scheduler.production.min.js:14Understand this errorAI
        visLoadWidgets.tsx:197 Cannot load widget system.adapter.vis-2-widgets-collection.0: ChunkLoadError: Loading chunk vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987 failed.
        (error: http://192.168.100.100:8082/vis-2/widgets/vis-2-widgets-collection/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987.9c21ae2e.chunk.js)
        (anonymous) @ visLoadWidgets.tsx:197
        Promise.catch
        (anonymous) @ visLoadWidgets.tsx:196
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        visLoadWidgets.tsx:198 Cannot load widget system.adapter.vis-2-widgets-collection.0: {"message":"Loading chunk vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987 failed.\n(error: http://192.168.100.100:8082/vis-2/widgets/vis-2-widgets-collection/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987.9c21ae2e.chunk.js)","name":"ChunkLoadError","type":"error","request":"http://192.168.100.100:8082/vis-2/widgets/vis-2-widgets-collection/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-fe7987.9c21ae2e.chunk.js"}
        (anonymous) @ visLoadWidgets.tsx:198
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        carsten04 1 Reply Last reply Reply Quote 0
        • carsten04
          @nwh Hast Du immer via Admin npm installiert, oder auch direkt via Konsole?
          • NWH
            @carsten04
            Immer so als Admin
            • carsten04
              carsten04 Developer @NWH last edited by carsten04
              @nwh dann lösche mal bitte die Instanz und den Adapter und installiere neu via Admin npm (so wie ich es eben beschrieben habe, also benutzerdefiniert und dann nur iobroker.vis-2-widgets-collection).
              • NWH
                @carsten04
                Jetzt hat es geklappt, allerdings erst wie ich die alten widget aus der Vis gelöscht habe.
                • NWH
                  NWH @NWH last edited by
                  @carsten04
                  Ich würde gerne ein Garagentor damit steuern, allerdings funktioniert das nicht bzw. nur teils.
                  Wie kann ich hier Werte eingeben? Entweder "true; false" oder Zahlenwerte.
                  Wenn ich hier auf "Down" klick dann bewegt sich das Tor nur kurz!
                  Auswählen tue ich "Garage EG Antrieb fahren"
                  Das wären die DP vom KNX
                  carsten04 Merlin123 2 Replies Last reply Reply Quote 0
                  • carsten04
                    @nwh Wie hast Du das Widget denn konfiguriert?
                    • Merlin123
                      Merlin123 @NWH last edited by
                      @nwh Hmmm. welchen DP setzt Du denn über den KNX Adapter, um das Tor vollständig auf/zu zu machen? Den musst Du halt auch über das Widget setzen.
                      Und: Muss der DP dann dauerhaft auf True oder False stehen?
                      • NWH
                        NWH @Merlin123 last edited by
                        @merlin123
                        Ich setzte den Wert:
                        Dieser Wert muss auf True oder False gesetzt werden.
                        @carsten04
                        Das widget setzt den wert auf "up oder "down" somit funktioniert das nicht.
                        Konfiguriert habe ich es im Moment gar nicht nur den DP gesetzt.
                        • Merlin123
                          @nwh Kannst Du im Widget nicht einstellen, was er setzen soll? Ist der DP Boolean?
                          • NWH
                            @merlin123
                            Ich wüsste nicht wo ich den Wert definiere.
                            Hier zu sehen nur der Alias, es wird aber der Wert UP geschrieben.
                            • carsten04
                              @nwh Nein, es wird true geschrieben. Der Alias "Up" wird nur im Widget angezeigt (deswegen ja auch Alias). Das kannst Du auch im Objektbaum sehen. Da steht nicht "Up" als Wert für den State, sondern der boolsche Wert true.
                              • NWH
                                @carsten04
                                Es tut mir leid, hier steht eindeutig UP.
                                Nach drücken der up Taste im widget.
                                • carsten04
                                  @nwh Nein in den State wird 0 geschrieben, dass ist der Wert in den Klammern. Du brauchst aber wohl false. Das liegt daran weil in Deinen common.states wohl "0": "Up" als ein Schlüssel-/ Wertepaar steht.
                                  • NWH
                                    @carsten04
                                    Ok, was kann ich tun damit es bei mir funktioniert?
                                    Wenn ich die Funktion auf ein widgte mit true und false lege funktioniert es problemlos.
                                    Würde aber gerne deine widget verwenden.
                                    • carsten04
                                      @nwh
                                      • carsten04
                                        carsten04 Developer last edited by carsten04
                                        Es gibt eine neue Version v1.2.0 mit einigen Optimierungen und einem neuen Checkbox-Widget.
                                        Feedback und Fehlermeldungen gerne hier im Forum oder auf GitHub.
                                        Merlin123 2 Replies Last reply Reply Quote 1
                                        • Merlin123
                                          Merlin123 @carsten04 last edited by
                                          @carsten04 Danke für die Weiterentwicklung! Muss mal wieder meine VIS erweitern und da werde ich sicher auch Deine Widgets nutzen 🙂
                                            micklafisch last edited by
                                            Wenn ich auch einen Wunsch äußern dürfte für ein Widget:
                                            Ein Dialog/Popup mit der Breite in Dialogbox in variablen % Werten. Alle bisherigen funktionierenden Popups wie MaterialDesignWidget oder jqui laufen mit Vis-2 nicht mehr oder nicht mehr richtig.
                                            Das wäre fein wenn es da wieder etwas lauffähiges und zugleich anpassbares gibt um Dialoge zu gestalten.
                                            Merlin123 carsten04 2 Replies Last reply Reply Quote 0
                                            293
                                            60582
