    4. CC2530/CC2531 als Custom-Zigbee-Aktor/Sensor
    • Asgothian
      Asgothian Developer @skvarel last edited by
      @skvarel gibt es Meldungen im log ? Ich bin wieder unterwegs und schau mal wenn ich wieder zu Hause bin
      • Asgothian
        @skvarel ich hab nochmal was angepasst. Versuch bitte mal so:
        const zigbeeHerdsmanConverters = require('zigbee-herdsman-converters');
        const zigbeeHerdsmanUtils = require('zigbee-herdsman-converters/lib/utils');
        const exposes = zigbeeHerdsmanConverters['exposes'] || require("zigbee-herdsman-converters/lib/exposes");
        const ea = exposes.access;
        const e = exposes.presets;
        const modernExposes = (e.hasOwnProperty('illuminance_lux'))? false: true;
        const fz = zigbeeHerdsmanConverters.fromZigbeeConverters || zigbeeHerdsmanConverters.fromZigbee;
        const tz = zigbeeHerdsmanConverters.toZigbeeConverters || zigbeeHerdsmanConverters.toZigbee;
        const ptvo_switch = (zigbeeHerdsmanConverters.findByModel)?zigbeeHerdsmanConverters.findByModel('ptvo.switch'):zigbeeHerdsmanConverters.findByDevice({modelID: 'ptvo.switch'});
        fz.legacy = ptvo_switch.meta.tuyaThermostatPreset;
        fz.ptvo_on_off = {
          cluster: 'genOnOff',
          type: ['attributeReport', 'readResponse'],
          convert: (model, msg, publish, options, meta) => {
              if (msg.data.hasOwnProperty('onOff')) {
                  const channel = msg.endpoint.ID;
                  const endpointName = `l${channel}`;
                  const binaryEndpoint = model.meta && model.meta.binaryEndpoints && model.meta.binaryEndpoints[endpointName];
                  const prefix = (binaryEndpoint) ? model.meta.binaryEndpoints[endpointName] : 'state';
                  const property = `${prefix}_${endpointName}`;
        	  if (binaryEndpoint) {
                    return {[property]: msg.data['onOff'] === 1};
                  return {[property]: msg.data['onOff'] === 1 ? 'ON' : 'OFF'};
        const fzlocal = {
          local_analog_switch: {
            cluster: 'genAnalogInput',
                const payload = {};
                const name = `l${channel}`;
                const endpoint = msg.endpoint;
                payload[name] = precisionRound(msg.data['presentValue'], 3);
                payload[`contact_${channel}`] = (msg.data['presentValue']  < 300)
                const cluster = 'genLevelCtrl';
                if (endpoint && (endpoint.supportsInputCluster(cluster) || endpoint.supportsOutputCluster(cluster))) {
                    payload['brightness_' + name] = msg.data['presentValue'];
                } else if (msg.data.description !== undefined) {
                    const data1 = msg.data['description'];
                    if (data1) {
                        const data2 = data1.split(',');
                        const devid = data2[1];
                        const unit = data2[0];
                        if (devid) {
                            payload['device_' + name] = devid;
                        const valRaw = msg.data['presentValue'];
                        if (unit) {
                            let val = precisionRound(valRaw, 1);
                            const nameLookup = {
                                C: 'temperature',
                                '%': 'humidity',
                                m: 'altitude',
                                Pa: 'pressure',
                                ppm: 'quality',
                                psize: 'particle_size',
                                V: 'voltage',
                                A: 'current',
                                Wh: 'energy',
                                W: 'power',
                                Hz: 'frequency',
                                pf: 'power_factor',
                                lx: 'illuminance',
                            let nameAlt = '';
                            if (unit === 'A' || unit === 'pf') {
                                if (valRaw < 1) {
                                    val = precisionRound(valRaw, 3);
                            if (unit.startsWith('mcpm') || unit.startsWith('ncpm')) {
                                const num = unit.substr(4, 1);
                                nameAlt = num === 'A' ? unit.substr(0, 4) + '10' : unit;
                                val = precisionRound(valRaw, 2);
                            } else {
                                nameAlt = nameLookup[unit];
                            if (nameAlt === undefined) {
                                const valueIndex = parseInt(unit, 10);
                                if (!isNaN(valueIndex)) {
                                    nameAlt = 'val' + unit;
                            if (nameAlt !== undefined) {
                                payload[nameAlt + '_' + name] = val;
                return payload;
        const device = {
            zigbeeModel: ['CC2531.US100'],
            model: 'CC2531.US100',
            vendor: 'inventwo',
            description: '[CC2531 w. US-100 Sensor](https://github.com/inventwo/custom-zigbee)',
            fromZigbee: [fz.ignore_basic_report, fz.ptvo_switch_uart, fzlocal.local_analog_switch,],
            toZigbee: [tz.ptvo_switch_trigger, tz.ptvo_switch_uart,],
            exposes: [
              exposes.numeric('l1', ea.STATE).withDescription('Innenraummessung').withUnit('mm'),
              e.contact().withEndpoint('l1'),
            meta: {
                multiEndpoint: true,
            endpoint: (device) => {
                return {
                    l1: 1,
              configure: async (device, coordinatorEndpoint, logger) => {
              const endpoint = device.getEndpoint(1);
              await endpoint.read('genBasic', ['modelId', 'swBuildId', 'powerSource']);
        module.exports = device;
        (wieder ohne icon)
        skvarel 1 Reply Last reply Reply Quote 0
        • skvarel
          skvarel Developer @Asgothian last edited by skvarel
          @asgothian .. Meldungen im Log:
          z2m: Exception while calling fromZigbee converter: precisionRound is not defined}
          So sieht es beim neuen Code aus:
          • Asgothian
            @skvarel das ist nachdem du die Fehlermeldung eliminiert hast oder vorher ? einfach den Aufruf zu precisionRound entfernen und den Wert direkt nutzen
            aus
            wird
            A.
            • skvarel
              @asgothian sagte in CC2530/CC2531 als Custom-Zigbee-Aktor/Sensor:
              Der Fehler ist jetzt weg! Die Änderung hat geholfen.
              Es bleibt aber bei N/A
              • Asgothian
                @skvarel Du bist doch auf dem ioBroker discord. Wollen wir uns da kurz zusammen hängen - geht einfacher als hier per posts.
                Ich bin einfach mal im '2 user only' channel 🙂
                A.
                skvarel 1 Reply Last reply Reply Quote 1
                • skvarel
                  @asgothian .. heute schaffe ich es leider nicht mehr. Morgen hätte ich Zeit.
                  • Asgothian
                    @skvarel morgen tuts. Wann ?
                    • skvarel
                      @asgothian .. ab späten Vormittag. Uhrzeit ist mir egal. Ich habe nichts weiter vor!
                      • Asgothian
                        @skvarel sagte in CC2530/CC2531 als Custom-Zigbee-Aktor/Sensor:
                        sagen wir 11 ?
                        skvarel 2 Replies Last reply Reply Quote 1
                        • skvarel
                          @asgothian .. das passt! Vielen Dank nochmal, bis morgen 🙂
                          • skvarel
                            @asgothian .. vielen Dank! Ich bin begeistert 🙂
                            Jetzt gehe ich an die anderen Konverter. Da müssen die Namen noch angepasst werden.
                            Das wichtigste wäre mir beim Gewächshaus, direkt Fenster und Tür sowie Heizung und Licht .. anstatt Kontakt und State
                            • skvarel
                              skvarel Developer last edited by
                              • skvarel
                                skvarel Developer last edited by skvarel
                                Sooo, nächster Konverter angepasst. @jkvarel hat mir geholfen 😉
                                Gefällt mir aber wegen der fehlenden Icons bei den Temperaturen noch nicht.
                                • skvarel
                                  @Asgothian .. ich könnte noch mal deine Hilfe gebrauchen
                                  Ich möchte gern das Icon davor haben.
                                  Hier mal mein Konverter, den ich mit @jkvarel gemacht habe:
                                  const precisionRound = zigbeeHerdsmanUtils.precisionRound;
                                  const fzlocal = {
                                            const payload = {};
                                            const mapping = {
                                              1: 'Vorlauftemperatur',
                                              2: 'Ruecklauftemperatur'
                                            if(mapping[channel] === undefined) return payload
                                            payload[mapping[channel]] = precisionRound(msg.data['presentValue'], 1)
                                            return payload
                                  const device = {
                                      zigbeeModel: ['CC2531.DS18B20'],
                                      model: 'CC2531.DS18B20',
                                      vendor: 'inventwo',
                                      description: '[CC2531 w. DS18B20 Sensor](https://github.com/inventwo/custom-zigbee)',
                                      fromZigbee: [fz.ignore_basic_report, fz.ptvo_switch_analog_input, fzlocal.local_analog_switch],
                                      toZigbee: [tz.ptvo_switch_trigger,],
                                      exposes: [
                                          exposes.numeric('Vorlauftemperatur', ea.STATE).withUnit('°C'),
                                          exposes.numeric('Ruecklauftemperatur', ea.STATE).withUnit('°C'),
                                      meta: {
                                          return {
                                              Vorlauftemperatur: 1, Ruecklauftemperatur: 2,
                                  • Asgothian
                                    @skvarel Ich fürchte da läufst du auf die Grenzen des Möglichen. Soweit ich das korrekt erkannt habe wird das Icon aus der Benennung des Payloads gemacht - genau das was du da gerade 'umbenannt' hast.
                                    Was du versuchen kannst:
                                    • 'Vorlauftemperatur' durch 'temperatur_vorlauf' ersetzen (überall wo es auftritt)
                                    • 'Ruecklauftemperatur' durch 'temperatur_ruecklauf' ersetzen (überall wo es auftritt)
                                    • hoffen 🙂
                                    A.
                                    • skvarel
                                      @asgothian .. das teste ich morgen direkt. Dann habe ich aber nicht mehr meine Wunschnamen in der Zigbee-Kachel. Einen Tod muss ich da wohl sterben.
                                      • Asgothian
                                        Das, oder wir machen eine Anpassung bei zigbee2mqtt.io das man die icons über die exposes vorgeben kann - das ist dann aber ein größerer Wurf.
                                        A.
                                        skvarel 2 Replies Last reply Reply Quote 0
                                        • skvarel
                                          @asgothian .. über die Exposes wäre ein Traum. Ich denke, ich bin da aber wohl ein Einzellfall 😉
                                          • skvarel
                                            @asgothian .. ich könnte auch mit dem Eintrag 'Temperatur' und dem Icon leben, wenn ich den Namen in der Klammer (das ist der Endpoint) ändern könnte.
                                            Das teste ich morgen nochmal.
                                            Dann hätte ich der Kachel: Temperatur (Vorlauf) anstatt: Temperatur (l1) stehen.
                                            Ich meine, das hatten wir heute schon mal. Ich weiß nur nicht mehr wann das war. Wir haben so vieles geändert 🙂
                                            diy ptvo zigbee
                                            10
                                            160
                                            22021
