    4. Update von Node 18 auf Node 20 bricht ab
      searcher57 @Thomas Braun last edited by
      @thomas-braun said in Update von Node 18 auf Node 20 bricht ab:
      @searcher57
      iob nodejs-update 20
      @searcher57
      Danach bekomme ich folgendes;
      ioBroker nodejs fixer 2024-10-10
      You requested to install latest version from nodejs v20 tree.
      Your current setup is:
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v20.18.2. Do you want to install latest version from nodejs v.20 tree?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
      Waiting for ioBroker to shut down - Give me a minute...
      Removing dfsg-nodejs
      *** These repos are active on your system:
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Get:6 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:7 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [10.4 kB]
      Get:8 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [10.4 kB]
      Fetched 33.0 kB in 1s (26.6 kB/s)
      Installing nodejs now!
      Installing the nodejs!
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
        Thomas Braun Most Active @searcher57 last edited by
        @searcher57
        Dann ist jetzt nodejs@20 richtig installiert.
          @searcher57
          So, meine Einstellungen sind endlich aktuallisiert. Trotzdem bekomme ich den Telegram- Adapter nicht auf den neuesten Stand.
          Thomas Braun S 2 Replies Last reply Reply Quote 0
            @searcher57 sagte in Update von Node 18 auf Node 20 bricht ab:
            Das heißt konktet mit welchen Meldungen?
            iob update
            iob upgrade all
              searcher57 @searcher57 last edited by
              @searcher57 said in Update von Node 18 auf Node 20 bricht ab:
              @searcher57
              Entschuldigung!! Update: Alles Gut es hat funktioniert! Danke!👍 👏
                iob update
                iob upgrade all
                Ich war mal wieder zu ungeduldig und habe nach den Eingaben nicht abgewartet, ob eine Lösung statt gefunden hat! Asche über mein Haupt!!🤕
                  searcher57 @Thomas Braun last edited by searcher57
                  iob update
                  iob upgrade all
                  @searcher57
                  Anstatt iob nodejs-update 20 habe ich iob nodejs-update v 20.18.2 eingegeben!
                    @searcher57
                    Und warum?
                    v 20.18.2 ist keine gültige Option bei dem Skript. Und das hat dir auch keiner so falsch vorgegeben. Und in der Hilfe steht das auch nicht drin. Also WARUM?
                      @searcher57
                      Und warum?
                      Weil ich das in meinem Raspi 5 so angegeben bekomme!
                      S Thomas Braun 2 Replies Last reply Reply Quote 0
                        @searcher57
                        Und warum?
                        Kann ich also die Version vom Raspi 5 nicht auf den Raspi 4 übernehmen?
                          @searcher57
                          Das ist die volle Versionierung. Bei nodejs-update gibt man aber nur die Major-Version an.
                          In der Hilfe ist das Kommando so enthalten:
                          iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
                          Hab mir eine Plausibiltätsprüfung für das Argument aber schon auf meine 'ToDo'-Liste gesetzt.
                            @searcher57
                            Und warum?
                            Seltsam ist, dass es jetzt so aussieht:
                              Warum ist das seltsam?
                              Eine volle Versionsnummer unterteilt sich in drei Segmente.
                              Major.Minor.Patch
                              Beim nodejs-update gibst du nur den Major-Zweig an, die genaue aktuelle Version findet das Skript dann automatisch.
                                @searcher57
                                Das sagt mir wenig! Hauptsache Ihr habt mir geholfen!!👍 😊
                                  Das sagt mir wenig!
                                  Deswegen meine Erläuterung einen Post zuvor.
                                    Das sagt mir wenig!
                                    OK, nochmal Danke!
                                      searcher57 @Homoran last edited by
                                      @homoran said in Update von Node 18 auf Node 20 bricht ab:
                                      einen Screen-shot:
                                      da steht's doch ganz deutlich und rot markiert
                                      usr/bin/nodejs v18.20.6
                                      ist zu alt
                                      soll!
                                      du brauchst v20
                                      Also dann sag mir doch bitte in Zukunft, was ich machen
                                        Das sagt mir wenig!
                                        OK, nochmal Danke!
                                        einen Screen-shot:
                                        ist zu alt
                                        soll!
                                        du brauchst v20
                                        Sei's drum es ist ja wieder alles in Ordnung, aber ich wünsche mir einen Umgang mit Normalos!!😙
                                          Thomas Braun Most Active @searcher57 last edited by Thomas Braun
                                          @searcher57
                                          Es steht doch eigentlich alles klar und deutlich in dem Screenshot drin...
                                          Rot markiert: nodejs20 ist erforderlich, du hast 18 laufen
                                          Im Changelog auch nochmal:
                                          Nodejs >20 ist erforderlich.
                                          Sollte auch für 'Normalos' (Was auch immer das genau sein soll) verständlich sein.
                                            Homoran Global Moderator Administrators @searcher57 last edited by
                                            was mutet dir denn unnormal an 🤔
                                            iobroker update nodejs
                                            3252
