    3. Einsteigerfragen
    4. Bluetooth Device is not available: No such device
      maxpd @Thomas Braun last edited by
      @thomas-braun gut zu wissen. Nehme ich die 2 Zeilen aus der Config einfach raus?
      Darf ich per winscp oder per nano oder gibts ein Befehl dazu?
      dtoverlay=pi3-disable-bt
        Thomas Braun Most Active @maxpd last edited by
        @maxpd
        Kannst du beides per Editor (nano) rauswerfen, dann Neustart.
          @thomas-braun habs entfernt und neu gestartet.
          Leider ändert sich an den Meldungen nichts.
          $ bluetoothctl
          Agent registered
          [bluetooth]# agent on
          Agent is already registered
          [bluetooth]# pairable on
          No default controller available
          $ hciconfig hci0
          Can't get device info: No such device
            @maxpd
            Was fährst du denn da für ein System?
            Gib mal die Langfassung von
            iob diag
            zum Besten, da kann man das direkt alles sehen.
              ========== Start marking the full check here ===========
              ```bash
              Script v.2025-02-02
              *** BASE SYSTEM ***
                 Static hostname: donbroker
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               20:40:47 up 29 min,  1 user,  load average: 0.67, 0.87, 1.06
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Debian 'bullseye' is the current oldstable version. Please upgrade to the latest        stable release 'bookworm' in due time!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Sat 2025-02-08 20:40:48 CET
                         Universal time: Sat 2025-02-08 19:40:48 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pd
              HOME=/home/pd
              GROUPS=pd adm dialout cdrom sudo audio video plugdev games users input rende        r netdev bluetooth gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.8G        3.0G        4.1G        1.0M        695M        4.7G
              Swap:            99M          0B         99M
              Total:          7.9G        3.0G        4.2G
              Active iob-Instances:   46
                       7811 M total memory
                       3008 M used memory
                       3204 M active memory
                        328 M inactive memory
                       4106 M free memory
                         75 M buffer memory
                        620 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              top - 20:40:48 up 29 min,  1 user,  load average: 0.70, 0.87, 1.06
              Tasks: 226 total,   1 running, 225 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 15.9 us,  5.8 sy,  0.0 ni, 75.4 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
              MiB Mem :   7811.3 total,   4106.3 free,   3008.8 used,    696.2 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4679.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              /dev/root      ext4      110G   12G   95G  11% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
              /dev/sda1      vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
              [Sat Feb  8 20:11:01 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=4e235        c07-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Feb  8 20:11:04 2025] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
              [Sat Feb  8 20:11:04 2025] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
              [Sat Feb  8 20:11:06 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET  SOURCE    FSTYPE OPTIONS
              /       /dev/sda2 ext4   rw,noatime
              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,errors=remount-ro
              /var:
              du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
              2.9G    /var/
              1.1G    /var/log/journal/44d2b021246e425b9ef7fe15da6bfb6b
              1.1G    /var/log
              864M    /var/cache
              Archived and active journals take up 1.0G in the file system.
              /opt/iobroker/backups:
              15M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.6G    /opt/iobroker/iobroker-data/
              1.1G    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
              31M     /opt/iobroker/iobroker-data/objects.jsonl
              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c        ee985.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DA        P_L1100F9Y-if03
              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DA        P_L1100F9Y-if00
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/ttyACM0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.2
              /usr/bin/node           v20.18.2
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.4
              nodejs:
                Installed: 20.18.2-1nodesource1
                Candidate: 20.18.2-1nodesource1
                Version table:
               *** 20.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.1-1nodesource1 1001
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              donbroker           donbroker (version: 7.0.6, hostname: donbroker     , alive, uptime: 1781)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.4.10
              javascript:     8.8.3
              nodejs modules from github:     5
              +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
              +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
              +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
              +-- iobroker.motionblinds@0.3.0 (git+ssh://git@github.com/VBen/ioBroker.motionblinds.git#0967a7b127274ef06e0327585267c313339b3b10)
              | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
              Adapter State
              + system.adapter.admin.0                  : admin                 : donbroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.admin.1                  : admin                 : donbroker                                -  enabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
                system.adapter.alias-manager.0          : alias-manager         : donbroker                                - disabled
              + system.adapter.backitup.0               : backitup              : donbroker                                -  enabled
              + system.adapter.ble.0                    : ble                   : donbroker                                -  enabled
              + system.adapter.chromecast.0             : chromecast            : donbroker                                -  enabled
                system.adapter.cloud.0                  : cloud                 : donbroker                                - disabled
                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: donbroker                                -  enabled
              + system.adapter.daikin-cloud.0           : daikin-cloud          : donbroker                                -  enabled
                system.adapter.daikin.0                 : daikin                : donbroker                                - disabled
                system.adapter.daswetter.0              : daswetter             : donbroker                                -  enabled
              + system.adapter.denon.0                  : denon                 : donbroker                                -  enabled
                system.adapter.discovery.0              : discovery             : donbroker                                - disabled
              + system.adapter.doorbird.0               : doorbird              : donbroker                                -  enabled
              + system.adapter.echarts.0                : echarts               : donbroker                                -  enabled
                system.adapter.feiertage.0              : feiertage             : donbroker                                -  enabled
                system.adapter.flot.0                   : flot                  : donbroker                                - disabled
                system.adapter.go-e.0                   : go-e                  : donbroker                                - disabled
              + system.adapter.google-sharedlocations.0 : google-sharedlocations: donbroker                                -  enabled
                system.adapter.govee-app.0              : govee-app             : donbroker                                - disabled
                system.adapter.govee-local.0            : govee-local           : donbroker                                - disabled
              + system.adapter.govee.0                  : govee                 : donbroker                                -  enabled
              + system.adapter.hass.0                   : hass                  : donbroker                                -  enabled, port: 8123
              + system.adapter.history.0                : history               : donbroker                                -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : donbroker                                -  enabled
                system.adapter.hm-rpc.0                 : hm-rpc                : donbroker                                -  enabled, port: 0
                system.adapter.hm-rpc.1                 : hm-rpc                : donbroker                                -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : donbroker                                -  enabled
              + system.adapter.influxdb.0               : influxdb              : donbroker                                -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : donbroker                                -  enabled
              + system.adapter.iot.0                    : iot                   : donbroker                                -  enabled
              + system.adapter.javascript.0             : javascript            : donbroker                                -  enabled
                system.adapter.lgtv.0                   : lgtv                  : donbroker                                - disabled
                system.adapter.lovelace.0               : lovelace              : donbroker                                - disabled, port: 8091, bind: 0.0.0.0, run as: admin
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : donbroker                                -  enabled, port: 54321
              + system.adapter.modbus.0                 : modbus                : donbroker                                -  enabled
              + system.adapter.modbus.1                 : modbus                : donbroker                                -  enabled
              + system.adapter.modbus.2                 : modbus                : donbroker                                -  enabled
              + system.adapter.motionblinds.0           : motionblinds          : donbroker                                -  enabled
              + system.adapter.mqtt-client.0            : mqtt-client           : donbroker                                -  enabled, port: 1884
                system.adapter.mqtt.0                   : mqtt                  : donbroker                                - disabled, port: 36669, bind: 192.168.178.30
                system.adapter.net-tools.0              : net-tools             : donbroker                                - disabled
              + system.adapter.ping.0                   : ping                  : donbroker                                -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : donbroker                                -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : donbroker                                -  enabled
              + system.adapter.pvforecast.1             : pvforecast            : donbroker                                -  enabled
              + system.adapter.pvforecast.2             : pvforecast            : donbroker                                -  enabled
                system.adapter.radar2.0                 : radar2                : donbroker                                - disabled
              + system.adapter.roborock.0               : roborock              : donbroker                                -  enabled
                system.adapter.rpi2.0                   : rpi2                  : donbroker                                - disabled
                system.adapter.sayit.0                  : sayit                 : donbroker                                - disabled
                system.adapter.sayit.1                  : sayit                 : donbroker                                - disabled
                system.adapter.sayit.2                  : sayit                 : donbroker                                - disabled
                system.adapter.sayit.3                  : sayit                 : donbroker                                - disabled
                system.adapter.sayit.4                  : sayit                 : donbroker                                - disabled
                system.adapter.schoolfree.0             : schoolfree            : donbroker                                -  enabled
              + system.adapter.shelly.0                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : donbroker                                -  enabled
                system.adapter.simple-api.0             : simple-api            : donbroker                                - disabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.simple-api.1             : simple-api            : donbroker                                -  enabled, port: 8101, bind: 0.0.0.0, run as: admin
              + system.adapter.sma-em.0                 : sma-em                : donbroker                                -  enabled
              + system.adapter.sonoff.0                 : sonoff                : donbroker                                -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.spotify-premium.0        : spotify-premium       : donbroker                                - disabled
                system.adapter.synology.0               : synology              : donbroker                                - disabled, port: 5000
                system.adapter.synology.1               : synology              : donbroker                                - disabled, port: 5001
                system.adapter.systeminfo.0             : systeminfo            : donbroker                                - disabled
              + system.adapter.telegram.0               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.1               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.2               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.terminal.0               : terminal              : donbroker                                - disabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.tr-064.0                 : tr-064                : donbroker                                -  enabled
              + system.adapter.tuya.0                   : tuya                  : donbroker                                -  enabled
              + system.adapter.web.0                    : web                   : donbroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : donbroker                                - disabled
              + system.adapter.wifilight.0              : wifilight             : donbroker                                -  enabled
              + system.adapter.wled.0                   : wled                  : donbroker                                -  enabled
                system.adapter.yeelight-2.0             : yeelight-2            : donbroker                                - disabled
              + system.adapter.zigbee.0                 : zigbee                : donbroker                                -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.4.10   , installed 7.4.10
              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
              Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
              Adapter    "ble"          : 0.14.0   , installed 0.14.0
              Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
              Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daikin-cloud" : 0.4.11   , installed 0.4.11
              Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
              Adapter    "echarts"      : 1.9.2    , installed 1.9.2
              Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
              Adapter    "go-e"         : 1.0.41   , installed 1.0.41
              Adapter    "govee-local"  : 0.2.7    , installed 0.2.7
              Adapter    "hass"         : 1.4.0    , installed 1.4.0
              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "lgtv"         : 2.4.0    , installed 2.3.1  [Updatable]
              Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
              Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
              Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
              Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
              Adapter    "radar2"       : 2.2.0    , installed 2.2.0
              Adapter    "roborock"     : 0.6.18   , installed 0.6.18
              Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
              Adapter    "sayit"        : 5.0.0    , installed 3.0.0  [Updatable]
              Adapter    "schoolfree"   : 1.1.7    , installed 1.1.6  [Updatable]
              Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
              Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
              Adapter    "spotify-premium": 1.5.2  , installed 1.5.0  [Updatable]
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
              Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
              Adapter    "wled"         : 0.7.2    , installed 0.7.2
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
              Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
              Objects and States
              Objects:        25484
              States:         21070
              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:3 http://deb.debian.org/debian bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          1754       845/dnsmasq
              tcp        0      0 192.168.178.30:8100     0.0.0.0:*               LISTEN      1001       23563      3063/io.doorbird.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15403      813/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14846      773/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15420      773/iobroker.js-con
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18377      2697/io.shelly.1
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19005      2503/io.sonoff.0
              tcp6       0      0 :::8101                 :::*                    LISTEN      1001       19421      2992/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16564      872/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21853      3032/io.web.0
              tcp6       0      0 :::8083                 :::*                    LISTEN      1001       15277      883/io.admin.1
              tcp6       0      0 :::22                   :::*                    LISTEN      0          15405      813/sshd: /usr/sbin
              udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       23584      3247/io.motionblind
              udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          1753       845/dnsmasq
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          1750       845/dnsmasq
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14751      656/dhclient
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17725      2267/io.mihome-vacu
              udp        0      0 0.0.0.0:54330           0.0.0.0:*                           1001       23585      3247/io.motionblind
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20634      3046/io.wled.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17558      2021/io.chromecast.
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13611      423/avahi-daemon: r
              udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       20290      2463/io.sma-em.0
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20256      2408/io.shelly.0
              udp        0      0 0.0.0.0:55797           0.0.0.0:*                           108        13613      423/avahi-daemon: r
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19424      2556/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19425      2556/io.tuya.0
              udp6       0      0 :::5353                 :::*                                108        13612      423/avahi-daemon: r
              udp6       0      0 :::42765                :::*                                108        13614      423/avahi-daemon: r
              2025-02-08 20:41:44.636  - info: hm-rpc.0 (6193) xmlrpc -> 192.168.178.117:2001/ init ["http://192.168.178.30:2001",""]
              2025-02-08 20:41:44.650  - error: hm-rpc.0 (6193) Cannot call init: [http://192.168.178.30:2001, ""] Unknown XML-RPC tag 'TITLE'
              2025-02-08 20:41:45.582  - info: hm-rpc.1 (6186) terminating
              2025-02-08 20:41:45.587  - info: hm-rpc.1 (6186) Terminated (NO_ERROR): Without reason
              2025-02-08 20:41:45.670  - info: hm-rpc.0 (6193) terminating
              2025-02-08 20:41:45.664  - info: hm-rpc.1 (6186) terminating
              2025-02-08 20:41:45.683  - info: hm-rpc.0 (6193) Terminated (NO_ERROR): Without reason
              2025-02-08 20:41:45.767  - info: hm-rpc.0 (6193) terminating
              2025-02-08 20:41:46.447  - info: host.donbroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
              2025-02-08 20:41:46.465  - info: host.donbroker Restart adapter system.adapter.hm-rpc.1 because enabled
              2025-02-08 20:41:46.662  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
              2025-02-08 20:41:46.662  - info: influxdb.0 (1925) Influx DB Version used: 1.x
              2025-02-08 20:41:46.669  - error: influxdb.0 (1925) AggregateError
              2025-02-08 20:41:46.791  - info: host.donbroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
              2025-02-08 20:41:46.791  - info: host.donbroker Restart adapter system.adapter.hm-rpc.0 because enabled
              2025-02-08 20:41:53.374  - info: shelly.1 (2697) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
              2025-02-08 20:41:53.475  - warn: shelly.1 (2697) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
              2025-02-08 20:41:56.669  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
              2025-02-08 20:41:56.669  - info: influxdb.0 (1925) Influx DB Version used: 1.x
              2025-02-08 20:41:56.675  - error: influxdb.0 (1925) AggregateError
              2025-02-08 20:42:06.676  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
              2025-02-08 20:42:06.677  - info: influxdb.0 (1925) Influx DB Version used: 1.x
              2025-02-08 20:42:06.685  - error: influxdb.0 (1925) AggregateError
              2025-02-08 20:42:08.685  - info: shelly.1 (2697) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
              2025-02-08 20:42:08.816  - warn: shelly.1 (2697) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
                @maxpd sagte in Bluetooth Device is not available: No such device:
                bullseye
                Installier da NEU das aktuelle Release 'Bookworm'.
                Musst du eh, dann kannste es auch jetzt machen.
                  @thomas-braun Na toll 😞 neu heißt einmal alles komplett neu aufsetzen?
                  Aber geht BT unter bullseye nicht?
                  Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                    Bei Raspberry 11 'Bullseye' auf Raspberry 12 'Bookworm' ja.
                    Die Änderungen sind zu groß für ein In-Line-Upgrade.
                    • haselchen
                      haselchen Most Active @maxpd last edited by haselchen
                      @maxpd
                      Wozu hast Du 2 Instanzen vom Admin?
                      Was sagt bei bluetoothctl?
                      hciconfig hci0 up
                      und dann
                      hciconfig -a hci0
                        maxpd @haselchen last edited by maxpd
                        @haselchen eine 2. Instanz hatte ich damals zum Testen angelegt, weil der Daikin Adapter den Admin mit https und Zertifikaten und so gebraucht hatte. und dann dabei belassen.
                         $ hciconfig hci0 up
                         $ hciconfig -a hci0
                         $ bluetoothctl
                        Agent registered
                        [bluetooth]# scan on
                        @Thomas-Braun ich musste die 2 zeilen auch wieder in die config.txt schreiben, weil sonst pivccu nicht mehr funktioniert.
                        Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                          Ist egal. Du wirst das ja eh neuaufsetzen.
                            @thomas-braun nee. https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                            Punkt 6. scheint als wäre pivcc und BT nicht kompatibel. heißt neu aufsetzen und das Modul kaufen oder externer dongle.
                              Thomas Braun Most Active @maxpd last edited by Thomas Braun
                              @maxpd
                              Zu piVCCU kann ich nix sagen. Aber ich KANN dir sagen, das du Raspberry 12 'Bookworm' in Bälde neuaufsetzen musst, weil das Ding abgekündigt ist. Spätestens im Spätsommer 2025.
                                Homoran Global Moderator Administrators @maxpd last edited by
                                doch, muss aber entsprechend umkonfiguriert werden (Option 2)
                                welches?
                                  @homoran aus der Option 2 entnahm ich den Begriff miniuart bei dessen Eingabe mir Google Bilder vieler Module aufzeigte. sorry.
                                  habs dann umkonfiguriert. pivccu läuft weiter aber die bluetooth meldungen über fehlendes device bleiben.
                                   $ systemctl status bluetooth
                                  ● bluetooth.service - Bluetooth service
                                       Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
                                       Active: active (running) since Sun 2025-02-09 12:43:48 CET; 14s ago
                                         Docs: man:bluetoothd(8)
                                     Main PID: 8863 (bluetoothd)
                                       Status: "Running"
                                        Tasks: 1 (limit: 8754)
                                          CPU: 59ms
                                       CGroup: /system.slice/bluetooth.service
                                               └─8863 /usr/libexec/bluetooth/bluetoothd
                                  Feb 09 12:43:48 donbroker systemd[1]: Starting Bluetooth service...
                                  Feb 09 12:43:48 donbroker bluetoothd[8863]: Bluetooth daemon 5.55
                                  Feb 09 12:43:48 donbroker systemd[1]: Started Bluetooth service.
                                  Feb 09 12:43:48 donbroker bluetoothd[8863]: Starting SDP server
                                  Feb 09 12:43:48 donbroker bluetoothd[8863]: Bluetooth management interface 1.22>
                                  pd@donbroker:~ $ bluetoothctl
                                  Agent registered
                                  [bluetooth]# hciconfig hci0
                                  Invalid command in menu main: hciconfig
                                  Use "help" for a list of available commands in a menu.
                                  Use "menu <submenu>" if you want to enter any submenu.
                                  Use "back" if you want to return to menu main.
                                  [bluetooth]# exit
                                  pd@donbroker:~ $ hciconfig hci0
                                  pd@donbroker:~ $ hciconfig hci0 up
                                  Agent registered
                                  [bluetooth]#
                                    @thomas-braun Spätsommer ist gut 🙂 vllt spart man sich dann eine version direkt auf Trixie 😉
                                      @maxpd
                                      Aber auch die wirst du komplett Neuinstallieren müssen. An dem Thema kommst du nicht vorbei.
                                        Leute, habs hinbekommen.
                                        Allerdings habe ich 2 Änderungen auf einmal gemacht, sodass ich nur zu 50% weiß an was es gelegen hat 😉
                                        In der config.txt habe ich
                                        dtoverlay=pivccu-raspberrypi
                                        unter
                                        dtoverlay=pi3-miniuart-bt
                                        enable_uart=1
                                        force_turbo=1
                                        core_freq=250
                                        geschoben
                                        und ich habe eine neue Zeile eingefügt
                                        dtparam=krnbt=on
                                        1665
