    3. Einsteigerfragen
    4. Bluetooth Device is not available: No such device
      Thomas Braun Most Active @maxpd last edited by
      @maxpd
      Kannst du beides per Editor (nano) rauswerfen, dann Neustart.
        @thomas-braun habs entfernt und neu gestartet.
        Leider ändert sich an den Meldungen nichts.
        $ bluetoothctl
        Agent registered
        [bluetooth]# agent on
        Agent is already registered
        [bluetooth]# pairable on
        No default controller available
        $ hciconfig hci0
        Can't get device info: No such device
          @maxpd
          Was fährst du denn da für ein System?
          Gib mal die Langfassung von
          iob diag
          zum Besten, da kann man das direkt alles sehen.
            maxpd @Thomas Braun last edited by
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-02-02
            *** BASE SYSTEM ***
               Static hostname: donbroker
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             20:40:47 up 29 min,  1 user,  load average: 0.67, 0.87, 1.06
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest        stable release 'bookworm' in due time!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-02-08 20:40:48 CET
                       Universal time: Sat 2025-02-08 19:40:48 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pd
            HOME=/home/pd
            GROUPS=pd adm dialout cdrom sudo audio video plugdev games users input rende        r netdev bluetooth gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.8G        3.0G        4.1G        1.0M        695M        4.7G
            Swap:            99M          0B         99M
            Total:          7.9G        3.0G        4.2G
            Active iob-Instances:   46
                     7811 M total memory
                     3008 M used memory
                     3204 M active memory
                      328 M inactive memory
                     4106 M free memory
                       75 M buffer memory
                      620 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 20:40:48 up 29 min,  1 user,  load average: 0.70, 0.87, 1.06
            Tasks: 226 total,   1 running, 225 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 15.9 us,  5.8 sy,  0.0 ni, 75.4 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
            MiB Mem :   7811.3 total,   4106.3 free,   3008.8 used,    696.2 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4679.4 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4      110G   12G   95G  11% /
            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
            /dev/sda1      vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
            [Sat Feb  8 20:11:01 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=4e235        c07-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Feb  8 20:11:04 2025] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
            [Sat Feb  8 20:11:04 2025] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
            [Sat Feb  8 20:11:06 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,errors=remount-ro
            /var:
            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
            2.9G    /var/
            1.1G    /var/log/journal/44d2b021246e425b9ef7fe15da6bfb6b
            1.1G    /var/log
            864M    /var/cache
            Archived and active journals take up 1.0G in the file system.
            /opt/iobroker/backups:
            15M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.6G    /opt/iobroker/iobroker-data/
            1.1G    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
            31M     /opt/iobroker/iobroker-data/objects.jsonl
            26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
            26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c        ee985.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
            USB-Devices by-id:
            USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
            /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DA        P_L1100F9Y-if03
            /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DA        P_L1100F9Y-if00
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyACM0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.2
            /usr/bin/node           v20.18.2
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.4
            nodejs:
              Installed: 20.18.2-1nodesource1
              Candidate: 20.18.2-1nodesource1
              Version table:
             *** 20.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u5 500
                    500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            donbroker           donbroker (version: 7.0.6, hostname: donbroker     , alive, uptime: 1781)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.4.10
            javascript:     8.8.3
            nodejs modules from github:     5
            +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
            +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
            +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
            +-- iobroker.motionblinds@0.3.0 (git+ssh://git@github.com/VBen/ioBroker.motionblinds.git#0967a7b127274ef06e0327585267c313339b3b10)
            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
            Adapter State
            + system.adapter.admin.0                  : admin                 : donbroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.admin.1                  : admin                 : donbroker                                -  enabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
              system.adapter.alias-manager.0          : alias-manager         : donbroker                                - disabled
            + system.adapter.backitup.0               : backitup              : donbroker                                -  enabled
            + system.adapter.ble.0                    : ble                   : donbroker                                -  enabled
            + system.adapter.chromecast.0             : chromecast            : donbroker                                -  enabled
              system.adapter.cloud.0                  : cloud                 : donbroker                                - disabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: donbroker                                -  enabled
            + system.adapter.daikin-cloud.0           : daikin-cloud          : donbroker                                -  enabled
              system.adapter.daikin.0                 : daikin                : donbroker                                - disabled
              system.adapter.daswetter.0              : daswetter             : donbroker                                -  enabled
            + system.adapter.denon.0                  : denon                 : donbroker                                -  enabled
              system.adapter.discovery.0              : discovery             : donbroker                                - disabled
            + system.adapter.doorbird.0               : doorbird              : donbroker                                -  enabled
            + system.adapter.echarts.0                : echarts               : donbroker                                -  enabled
              system.adapter.feiertage.0              : feiertage             : donbroker                                -  enabled
              system.adapter.flot.0                   : flot                  : donbroker                                - disabled
              system.adapter.go-e.0                   : go-e                  : donbroker                                - disabled
            + system.adapter.google-sharedlocations.0 : google-sharedlocations: donbroker                                -  enabled
              system.adapter.govee-app.0              : govee-app             : donbroker                                - disabled
              system.adapter.govee-local.0            : govee-local           : donbroker                                - disabled
            + system.adapter.govee.0                  : govee                 : donbroker                                -  enabled
            + system.adapter.hass.0                   : hass                  : donbroker                                -  enabled, port: 8123
            + system.adapter.history.0                : history               : donbroker                                -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : donbroker                                -  enabled
              system.adapter.hm-rpc.0                 : hm-rpc                : donbroker                                -  enabled, port: 0
              system.adapter.hm-rpc.1                 : hm-rpc                : donbroker                                -  enabled, port: 0
              system.adapter.ical.0                   : ical                  : donbroker                                -  enabled
            + system.adapter.influxdb.0               : influxdb              : donbroker                                -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : donbroker                                -  enabled
            + system.adapter.iot.0                    : iot                   : donbroker                                -  enabled
            + system.adapter.javascript.0             : javascript            : donbroker                                -  enabled
              system.adapter.lgtv.0                   : lgtv                  : donbroker                                - disabled
              system.adapter.lovelace.0               : lovelace              : donbroker                                - disabled, port: 8091, bind: 0.0.0.0, run as: admin
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : donbroker                                -  enabled, port: 54321
            + system.adapter.modbus.0                 : modbus                : donbroker                                -  enabled
            + system.adapter.modbus.1                 : modbus                : donbroker                                -  enabled
            + system.adapter.modbus.2                 : modbus                : donbroker                                -  enabled
            + system.adapter.motionblinds.0           : motionblinds          : donbroker                                -  enabled
            + system.adapter.mqtt-client.0            : mqtt-client           : donbroker                                -  enabled, port: 1884
              system.adapter.mqtt.0                   : mqtt                  : donbroker                                - disabled, port: 36669, bind: 192.168.178.30
              system.adapter.net-tools.0              : net-tools             : donbroker                                - disabled
            + system.adapter.ping.0                   : ping                  : donbroker                                -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : donbroker                                -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : donbroker                                -  enabled
            + system.adapter.pvforecast.1             : pvforecast            : donbroker                                -  enabled
            + system.adapter.pvforecast.2             : pvforecast            : donbroker                                -  enabled
              system.adapter.radar2.0                 : radar2                : donbroker                                - disabled
            + system.adapter.roborock.0               : roborock              : donbroker                                -  enabled
              system.adapter.rpi2.0                   : rpi2                  : donbroker                                - disabled
              system.adapter.sayit.0                  : sayit                 : donbroker                                - disabled
              system.adapter.sayit.1                  : sayit                 : donbroker                                - disabled
              system.adapter.sayit.2                  : sayit                 : donbroker                                - disabled
              system.adapter.sayit.3                  : sayit                 : donbroker                                - disabled
              system.adapter.sayit.4                  : sayit                 : donbroker                                - disabled
              system.adapter.schoolfree.0             : schoolfree            : donbroker                                -  enabled
            + system.adapter.shelly.0                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : donbroker                                -  enabled
              system.adapter.simple-api.0             : simple-api            : donbroker                                - disabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.simple-api.1             : simple-api            : donbroker                                -  enabled, port: 8101, bind: 0.0.0.0, run as: admin
            + system.adapter.sma-em.0                 : sma-em                : donbroker                                -  enabled
            + system.adapter.sonoff.0                 : sonoff                : donbroker                                -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.spotify-premium.0        : spotify-premium       : donbroker                                - disabled
              system.adapter.synology.0               : synology              : donbroker                                - disabled, port: 5000
              system.adapter.synology.1               : synology              : donbroker                                - disabled, port: 5001
              system.adapter.systeminfo.0             : systeminfo            : donbroker                                - disabled
            + system.adapter.telegram.0               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.2               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.terminal.0               : terminal              : donbroker                                - disabled, port: 8088, bind: 0.0.0.0, run as: admin
            + system.adapter.tr-064.0                 : tr-064                : donbroker                                -  enabled
            + system.adapter.tuya.0                   : tuya                  : donbroker                                -  enabled
            + system.adapter.web.0                    : web                   : donbroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : donbroker                                - disabled
            + system.adapter.wifilight.0              : wifilight             : donbroker                                -  enabled
            + system.adapter.wled.0                   : wled                  : donbroker                                -  enabled
              system.adapter.yeelight-2.0             : yeelight-2            : donbroker                                - disabled
            + system.adapter.zigbee.0                 : zigbee                : donbroker                                -  enabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
            Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
            Adapter    "daikin-cloud" : 0.4.11   , installed 0.4.11
            Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
            Adapter    "denon"        : 1.15.12  , installed 1.15.12
            Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "go-e"         : 1.0.41   , installed 1.0.41
            Adapter    "govee-local"  : 0.2.7    , installed 0.2.7
            Adapter    "hass"         : 1.4.0    , installed 1.4.0
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "ical"         : 1.16.1   , installed 1.16.1
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "lgtv"         : 2.4.0    , installed 2.3.1  [Updatable]
            Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
            Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
            Adapter    "radar2"       : 2.2.0    , installed 2.2.0
            Adapter    "roborock"     : 0.6.18   , installed 0.6.18
            Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
            Adapter    "sayit"        : 5.0.0    , installed 3.0.0  [Updatable]
            Adapter    "schoolfree"   : 1.1.7    , installed 1.1.6  [Updatable]
            Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
            Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "spotify-premium": 1.5.2  , installed 1.5.0  [Updatable]
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
            Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
            Adapter    "wled"         : 0.7.2    , installed 0.7.2
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
            Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
            Objects and States
            Objects:        25484
            States:         21070
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://deb.debian.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          1754       845/dnsmasq
            tcp        0      0 192.168.178.30:8100     0.0.0.0:*               LISTEN      1001       23563      3063/io.doorbird.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15403      813/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14846      773/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15420      773/iobroker.js-con
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18377      2697/io.shelly.1
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19005      2503/io.sonoff.0
            tcp6       0      0 :::8101                 :::*                    LISTEN      1001       19421      2992/io.simple-api.
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16564      872/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21853      3032/io.web.0
            tcp6       0      0 :::8083                 :::*                    LISTEN      1001       15277      883/io.admin.1
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15405      813/sshd: /usr/sbin
            udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       23584      3247/io.motionblind
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          1753       845/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          1750       845/dnsmasq
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14751      656/dhclient
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17725      2267/io.mihome-vacu
            udp        0      0 0.0.0.0:54330           0.0.0.0:*                           1001       23585      3247/io.motionblind
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20634      3046/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17558      2021/io.chromecast.
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13611      423/avahi-daemon: r
            udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       20290      2463/io.sma-em.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20256      2408/io.shelly.0
            udp        0      0 0.0.0.0:55797           0.0.0.0:*                           108        13613      423/avahi-daemon: r
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19424      2556/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19425      2556/io.tuya.0
            udp6       0      0 :::5353                 :::*                                108        13612      423/avahi-daemon: r
            udp6       0      0 :::42765                :::*                                108        13614      423/avahi-daemon: r
            2025-02-08 20:41:44.636  - info: hm-rpc.0 (6193) xmlrpc -> 192.168.178.117:2001/ init ["http://192.168.178.30:2001",""]
            2025-02-08 20:41:44.650  - error: hm-rpc.0 (6193) Cannot call init: [http://192.168.178.30:2001, ""] Unknown XML-RPC tag 'TITLE'
            2025-02-08 20:41:45.582  - info: hm-rpc.1 (6186) terminating
            2025-02-08 20:41:45.587  - info: hm-rpc.1 (6186) Terminated (NO_ERROR): Without reason
            2025-02-08 20:41:45.670  - info: hm-rpc.0 (6193) terminating
            2025-02-08 20:41:45.664  - info: hm-rpc.1 (6186) terminating
            2025-02-08 20:41:45.683  - info: hm-rpc.0 (6193) Terminated (NO_ERROR): Without reason
            2025-02-08 20:41:45.767  - info: hm-rpc.0 (6193) terminating
            2025-02-08 20:41:46.447  - info: host.donbroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
            2025-02-08 20:41:46.465  - info: host.donbroker Restart adapter system.adapter.hm-rpc.1 because enabled
            2025-02-08 20:41:46.662  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
            2025-02-08 20:41:46.662  - info: influxdb.0 (1925) Influx DB Version used: 1.x
            2025-02-08 20:41:46.669  - error: influxdb.0 (1925) AggregateError
            2025-02-08 20:41:46.791  - info: host.donbroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2025-02-08 20:41:46.791  - info: host.donbroker Restart adapter system.adapter.hm-rpc.0 because enabled
            2025-02-08 20:41:53.374  - info: shelly.1 (2697) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
            2025-02-08 20:41:53.475  - warn: shelly.1 (2697) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
            2025-02-08 20:41:56.669  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
            2025-02-08 20:41:56.669  - info: influxdb.0 (1925) Influx DB Version used: 1.x
            2025-02-08 20:41:56.675  - error: influxdb.0 (1925) AggregateError
            2025-02-08 20:42:06.676  - info: influxdb.0 (1925) Connecting http://localhost:8086/ ...
            2025-02-08 20:42:06.677  - info: influxdb.0 (1925) Influx DB Version used: 1.x
            2025-02-08 20:42:06.685  - error: influxdb.0 (1925) AggregateError
            2025-02-08 20:42:08.685  - info: shelly.1 (2697) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
            2025-02-08 20:42:08.816  - warn: shelly.1 (2697) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
              @maxpd sagte in Bluetooth Device is not available: No such device:
              bullseye
              Installier da NEU das aktuelle Release 'Bookworm'.
              Musst du eh, dann kannste es auch jetzt machen.
                @thomas-braun Na toll 😞 neu heißt einmal alles komplett neu aufsetzen?
                Aber geht BT unter bullseye nicht?
                Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                  Bei Raspberry 11 'Bullseye' auf Raspberry 12 'Bookworm' ja.
                  Die Änderungen sind zu groß für ein In-Line-Upgrade.
                  • haselchen
                    haselchen Most Active @maxpd last edited by haselchen
                    @maxpd
                    Wozu hast Du 2 Instanzen vom Admin?
                    Was sagt bei bluetoothctl?
                    hciconfig hci0 up
                    und dann
                    hciconfig -a hci0
                      maxpd @haselchen last edited by maxpd
                      @haselchen eine 2. Instanz hatte ich damals zum Testen angelegt, weil der Daikin Adapter den Admin mit https und Zertifikaten und so gebraucht hatte. und dann dabei belassen.
                       $ hciconfig hci0 up
                       $ hciconfig -a hci0
                       $ bluetoothctl
                      Agent registered
                      [bluetooth]# scan on
                      @Thomas-Braun ich musste die 2 zeilen auch wieder in die config.txt schreiben, weil sonst pivccu nicht mehr funktioniert.
                      Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                        Ist egal. Du wirst das ja eh neuaufsetzen.
                          @thomas-braun nee. https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                          Punkt 6. scheint als wäre pivcc und BT nicht kompatibel. heißt neu aufsetzen und das Modul kaufen oder externer dongle.
                            Thomas Braun Most Active @maxpd last edited by Thomas Braun
                            @maxpd
                            Zu piVCCU kann ich nix sagen. Aber ich KANN dir sagen, das du Raspberry 12 'Bookworm' in Bälde neuaufsetzen musst, weil das Ding abgekündigt ist. Spätestens im Spätsommer 2025.
                              Homoran Global Moderator Administrators @maxpd last edited by
                              doch, muss aber entsprechend umkonfiguriert werden (Option 2)
                              welches?
                                @homoran aus der Option 2 entnahm ich den Begriff miniuart bei dessen Eingabe mir Google Bilder vieler Module aufzeigte. sorry.
                                habs dann umkonfiguriert. pivccu läuft weiter aber die bluetooth meldungen über fehlendes device bleiben.
                                 $ systemctl status bluetooth
                                ● bluetooth.service - Bluetooth service
                                     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
                                     Active: active (running) since Sun 2025-02-09 12:43:48 CET; 14s ago
                                       Docs: man:bluetoothd(8)
                                   Main PID: 8863 (bluetoothd)
                                     Status: "Running"
                                      Tasks: 1 (limit: 8754)
                                        CPU: 59ms
                                     CGroup: /system.slice/bluetooth.service
                                             └─8863 /usr/libexec/bluetooth/bluetoothd
                                Feb 09 12:43:48 donbroker systemd[1]: Starting Bluetooth service...
                                Feb 09 12:43:48 donbroker bluetoothd[8863]: Bluetooth daemon 5.55
                                Feb 09 12:43:48 donbroker systemd[1]: Started Bluetooth service.
                                Feb 09 12:43:48 donbroker bluetoothd[8863]: Starting SDP server
                                Feb 09 12:43:48 donbroker bluetoothd[8863]: Bluetooth management interface 1.22>
                                pd@donbroker:~ $ bluetoothctl
                                Agent registered
                                [bluetooth]# hciconfig hci0
                                Invalid command in menu main: hciconfig
                                Use "help" for a list of available commands in a menu.
                                Use "menu <submenu>" if you want to enter any submenu.
                                Use "back" if you want to return to menu main.
                                [bluetooth]# exit
                                pd@donbroker:~ $ hciconfig hci0
                                pd@donbroker:~ $ hciconfig hci0 up
                                Agent registered
                                [bluetooth]#
                                  @thomas-braun Spätsommer ist gut 🙂 vllt spart man sich dann eine version direkt auf Trixie 😉
                                    @maxpd
                                    Aber auch die wirst du komplett Neuinstallieren müssen. An dem Thema kommst du nicht vorbei.
                                      Leute, habs hinbekommen.
                                      Allerdings habe ich 2 Änderungen auf einmal gemacht, sodass ich nur zu 50% weiß an was es gelegen hat 😉
                                      In der config.txt habe ich
                                      dtoverlay=pivccu-raspberrypi
                                      unter
                                      dtoverlay=pi3-miniuart-bt
                                      enable_uart=1
                                      force_turbo=1
                                      core_freq=250
                                      geschoben
                                      und ich habe eine neue Zeile eingefügt
                                      dtparam=krnbt=on
                                      1324
