    3. Off Topic
    4. InfluxDB
    5. InfluxDB installieren wie
      Laser @Thomas Braun last edited by
      @thomas-braun ein Influx CLI habe ich installiert. Ein Befehl scheint auch zu funktionieren:
      otto@neuheizung:~ $ influx config
      Active  Name    URL                     Org
      *       default http://localhost:8086
      allerdings kann ich influxdb immer noch nicht starten.
        Thomas Braun Most Active @Laser last edited by
        @laser
        Was läuft da sonst noch so?
        Steht in der Langversion von
        iob diag
        drin. Und lösch da nichts raus oder veränder in irgendeiner Form die Ausgabe!
          Laser last edited by Laser
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: neuheizung
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           17:24:25 up  1:41,  2 users,  load average: 0.80, 0.78, 0.84
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Wed 2025-01-01 17:24:25 CET
                     Universal time: Wed 2025-01-01 16:24:25 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          otto
          HOME=/home/otto
          GROUPS=otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.2G        2.2G        4.9G        1.3M        1.2G        6.0G
          Swap:           209M          0B        209M
          Total:          8.4G        2.2G        5.1G
          Active iob-Instances:   32
                   7808 M total memory
                   2118 M used memory
                   2338 M active memory
                    687 M inactive memory
                   4638 M free memory
                     69 M buffer memory
                   1105 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 17:24:26 up  1:41,  2 users,  load average: 0.80, 0.78, 0.84
          Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7808.9 total,   4637.0 free,   2119.7 used,   1175.3 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5689.2 avail Mem
          *** FAILED SERVICES ***
            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
          * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     781M  1.2M  780M   1% /run
          /dev/sda2      ext4      110G   16G   89G  15% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
          tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
          [Wed Jan  1 15:42:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=522926e5-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Wed Jan  1 15:42:58 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
          [Wed Jan  1 15:43:00 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.5G    /var/
          2.6G    /var/log/journal/dd88a5e009d84a8992e10dbb99d7e583
          2.6G    /var/log
          473M    /var/cache
          Archived and active journals take up 2.5G in the file system.
          /opt/iobroker/backups:
          8.0K    /opt/iobroker/backups/
          4.0K    /opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker
          /opt/iobroker/iobroker-data:
          5.9G    /opt/iobroker/iobroker-data/
          4.7G    /opt/iobroker/iobroker-data/history
          1.1G    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          30M     /opt/iobroker/iobroker-data/objects.jsonl
          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CCDE649-if00
          /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE82E1IJ-if00-port0
          /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyACM0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          debian11            debian11 (version: 4.0.24, hostname: debian11      , dead, uptime: 198)
          neuheizung          neuheizung (version: 7.0.6, hostname: neuheizung    , alive, uptime: 6072)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.vedirect@0.3.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#0a83b8b987ee94d0c49f2ee7299bbb8d5d329dde)
          Adapter State
          + system.adapter.admin.1                  : admin                 : neuheizung                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : neuheizung                               - disabled
          + system.adapter.backitup.0               : backitup              : neuheizung                               -  enabled
          + system.adapter.discovery.0              : discovery             : neuheizung                               -  enabled
          + system.adapter.echarts.0                : echarts               : neuheizung                               -  enabled
          + system.adapter.email.0                  : email                 : neuheizung                               -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : neuheizung                               -  enabled
            system.adapter.flot.0                   : flot                  : neuheizung                               - disabled
          + system.adapter.history.0                : history               : neuheizung                               -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : neuheizung                               -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : neuheizung                               -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : neuheizung                               -  enabled, port: 0
            system.adapter.i2c.0                    : i2c                   : neuheizung                               - disabled
          + system.adapter.influxdb.0               : influxdb              : neuheizung                               -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : neuheizung                               -  enabled
          + system.adapter.logparser.0              : logparser             : neuheizung                               -  enabled
          + system.adapter.modbus.0                 : modbus                : neuheizung                               -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : neuheizung                               -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : neuheizung                               -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : neuheizung                               -  enabled, port: 1888, bind: 0.0.0.0
          + system.adapter.mqtt.3                   : mqtt                  : neuheizung                               -  enabled, port: 1890, bind: 0.0.0.0
          + system.adapter.opendtu.0                : opendtu               : neuheizung                               -  enabled
          + system.adapter.opendtu.1                : opendtu               : neuheizung                               -  enabled
          + system.adapter.opendtu.2                : opendtu               : neuheizung                               -  enabled
          + system.adapter.owfs.0                   : owfs                  : neuheizung                               -  enabled, port: 4304
          + system.adapter.rpi2.0                   : rpi2                  : neuheizung                               -  enabled
          + system.adapter.shelly.0                 : shelly                : neuheizung                               -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : neuheizung                               -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : neuheizung                               -  enabled
          + system.adapter.simple-api.0             : simple-api            : neuheizung                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sourceanalytix.0         : sourceanalytix        : neuheizung                               - disabled
          + system.adapter.vedirect.0               : vedirect              : neuheizung                               -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : neuheizung                               -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : neuheizung                               -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : neuheizung                               - disabled
            system.adapter.vis-material.0           : vis-material          : neuheizung                               - disabled
            system.adapter.vis-metro.0              : vis-metro             : neuheizung                               - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : neuheizung                               - disabled
            system.adapter.vis.0                    : vis                   : neuheizung                               -  enabled
          + system.adapter.web.0                    : web                   : neuheizung                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : neuheizung                               -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "i2c"          : 1.2.1    , installed 1.2.1
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
          Adapter    "owfs"         : 0.7.0    , installed 0.7.0
          Adapter    "rpi2"         : 2.2.1    , installed 2.2.2
          Adapter    "shelly"       : 8.2.1    , installed 8.3.0
          Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "web"          : 6.2.5    , installed 6.3.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects:        4489
          States:         3667
          W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       8299       1072/io.hm-rpc.1
          tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       6882       1057/io.hm-rpc.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       923        787/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       918        787/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4572       722/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7529       1213/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7570       1250/io.mqtt.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       8574       1270/io.mqtt.1
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       7627       1300/io.shelly.1
          tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       7677       1315/io.mqtt.3
          tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       9226       1289/io.mqtt.2
          tcp6       0      0 :::3000                 :::*                    LISTEN      106        6135       786/grafana
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9500       1424/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6745       876/io.admin.1
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       8696       1394/io.simple-api.
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4574       722/sshd: /usr/sbin
          udp        0      0 0.0.0.0:56980           0.0.0.0:*                           104        625        588/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        623        588/avahi-daemon: r
          udp6       0      0 fe80::75d1:70aa:4ea:546 :::*                                0          6578       665/NetworkManager
          udp6       0      0 :::42177                :::*                                104        626        588/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        624        588/avahi-daemon: r
          2025-01-01 17:23:21.360  - error: modbus.0 (8223) Request timed out.
          2025-01-01 17:23:21.361  - warn: modbus.0 (8223) [DevID_1] Poll error count: 6 code: {"err":"timeout","timeout":5000}
          2025-01-01 17:23:25.886  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:23:27.016  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:23:37.021  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:23:41.186  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:23:47.026  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:23:56.423  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:23:57.030  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:07.033  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:11.720  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:24:17.039  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:27.045  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:27.046  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:24:27.370  - warn: modbus.0 (8223) Error: undefined
          2025-01-01 17:24:27.371  - error: modbus.0 (8223) Request timed out.
          2025-01-01 17:24:27.372  - warn: modbus.0 (8223) [DevID_1] Poll error count: 7 code: {"err":"timeout","timeout":5000}
          2025-01-01 17:24:37.050  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:42.327  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:24:47.055  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:24:57.065  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:25:01.026  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          2025-01-01 17:25:07.075  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:25:17.081  - error: influxdb.0 (7260) AggregateError
          2025-01-01 17:25:17.910  - warn: shelly.0 (1213) [Mqtt.statusNotifications] 192.168.2.13 (shelly1pmminig3 / shelly1pmminig3-543204508220 / shelly1pmminig3#543204508220#1): "General Status Notifications" are disabled (see adapter documentation for details)
          iob diag has finished.
          PS: ich habe influxdb mit "autoremove" gelöscht und die 5 Befehlszeilen nochmal ausgeführt. Jetzt:
          otto@neuheizung:~ $ apt policy influxdb2
          influxdb2:
          Installed: (none)
          Candidate: (none)
          Version table:
          2.7.11-1 -1
          otto@neuheizung:~ $ sudo apt-get update && sudo apt-get install influxdb2
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists... Done
          Building dependency tree... Done
          Package influxdb2 is not available, but is referred to by another package.
          This may mean that the package is missing, has been obsoleted, or
          is only available from another source
          E: Package 'influxdb2' has no installation candidate
          otto@neuheizung:~ $
            @laser sagte in InfluxDB installieren wie:
            Stell im zigbee-Adapter den richtigen 'by-id'-Link ein, nicht /dev/ttyACM0
            HINT:
            /dev/ttyACM0
            Der Host 'debian11' muss mal auf Vordermann gebracht werden.
            Ich breche hier ab. Kannst du mal aufhören die Ausgabe ständig zu verändern?
              @thomas-braun der Host Debian 11 war nur ein Versuchsobjekt. Den gibt es erst mal nicht mehr.
              Die Ausgabe habe ich ergänzt, weil ich glaube das es wichtig sein könnte.
                @laser
                Ist mir eigentlich jetzt auch egal. Du hast dir jetzt irgendwie das Repo gelöscht.
                Also NOCHMAL die 5 Zeilen, mit denen man das richtig anlegt...
                  Laser @Thomas Braun last edited by Laser
                  @thomas-braun Ich will Dir jetzt auch nicht endlos auf den Nerv gehen. Vermutlich habe ich bei den 5 Zeilen (habe ich mir in ein xx.txt-File kopiert) einen Fehler gemacht. Ich mache das jetzt Alles noch mal, bis es klappt.
                  die Installation geht doch so: sudo apt-get update && sudo apt-get install influxdb2
                  die läuft jetzt auch durch. Auch der Status wird ohne Fehler angezeigt.
                  Es funktioniert jetzt. Kann die GUI port: 8086 öffenen.
                  Ich hoffe, durch die Neuinstallation ist das Chaos mit den Tokens beseitigt. Deshalb wollte ich das neu haben.
                  Danke für die Hilfe!
                    Laser @Laser last edited by Laser
                    @Thomas-Braun Influx funktioniert, wie es soll. Jetzt versuche ich, von einem anderen PC darauf zu zugreifen. Die GUI öffnet sich, aber meine Anmeldedaten werden nicht akzeptiert. Ist das ein Sicherheitsfeature? Die Konfigurationsdatei(en) zu finden, ist auch ein Abenteuer für sich.
                      @laser
                      Zum Umgang mit influxdb kann ich nix sagen, verwende ich nicht.
                        Evtl. weiß hierüber jemand etwas:
                          Thomas Braun Most Active @Laser last edited by Thomas Braun
                          Liegen die nicht wie üblich in /etc ?
                          Lt. debian-Package ist es
                          /etc/influxdb/influxdb.conf
                          Also gar kein Abenteuer, total langweilger Standard.
                            @thomas-braun Danke. Ja, da liegen die Konfig- Dateien. Abenteuer war etwas übertrieben. Nur mit dem Inhalt kann ich erst mal nichts anfangen. Das unterscheidet die Version 1 total von der Version 2. Ich möchte meine mühsam zum Laufen gebrachte DB nicht zerschießen.
                            Das steht drin- soll das Alles sein?
                            bolt-path = "/var/lib/influxdb/influxd.bolt"
                            engine-path = "/var/lib/influxdb/engine"
                            In den influxdb Pfad komme ich nicht rein - "Permission denied"
                              Einloggen geht jetzt auch. Mein notiertes Passwort stimmte nicht (Wieso- keine Ahnung- 1 Buchstabe falsch). Über "Einstellungen" in der Edge Seite rausgefunden.
                              Die Hilfe für Influx ist umfangreich, aber ebenso unverständlich... Kaum Beispiele, wie man wo etwas eingeben soll.
                                Die richtet sich vermutlich auch an Anwender mit gewissen Vorkenntnissen.
                                  @thomas-braun Das ist richtig, um sich von Null darin einzuarbeiten, ist das kaum geeignet.
                                    @laser
                                    Grundkenntnisse im Umgang mit dem Betriebssystem und/oder Datenbanken zu erwerben ist auch mit Sicherheit nicht das Ziel der influxdb-Dokumentation.
                                    Und deswegen ist es auch so schwierig, gute Doku zu schreiben. Und wird daher dann auch gerne vernachlässigt.
                                      @thomas-braun hier mal ein Beispiel (aus der Influx- Hilfe-Datei):
                                      Change your password
                                      Use influx command line interface (CLI) to update your password.
                                      User passwords cannot be updated in the InfluxDB UI.
                                      Change your password using the influx CLI
                                      Use the influx user password command to update a password for a user. Provide the following:
                                      An operator token using your influx CLI connection configuration, INFLUX_TOKEN environment variable, or the --token, -t flag.
                                      The username (with the --name, -n flag) or the user ID (with the --id, -i flag). View usernames and IDs in the output of influx user list.
                                      Optional: the --password, -p flag and the new password. If you don’t provide a password flag, enter the new password when prompted.
                                      Update a password
                                      influx user password \
                                        --name USERNAME \
                                        --password PASSWORD
                                      Replace the following:
                                      USERNAME: The username to change the password for
                                      PASSWORD: The new password
                                      Was this page helpful?
                                      Das Passwort konnte ich aber mit diesem Befehl ändern (user = username):
                                      influx user password -n admin --password 12345678 -t <der notierte Token>
                                      Mit der Influx Hilfe kam ich niemals auf diese Befehlseingabe. Man braucht schon sehr viel Phantasie...
                                      3553
