    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Modbus EasyCharge Einstellungen
    • wendy2702
      wendy2702 @Mark last edited by
      @mark dann zeig das log doch mal
        Homoran Global Moderator Administrators @Mark last edited by
        @mark sagte in Modbus EasyCharge Einstellungen:
        Error response for FCx3: Illegal Data Address
        hast du noch Leichen auf snderen Tabs des Adapters?
          Mark @Homoran last edited by Mark
          @homoran said in Modbus EasyCharge Einstellungen:
          Ich hab nur den einen modbus adapter und auch nur eine Instanz. Angeschlossen ist auch nur das Board.
          mit den Einstellungen 8,1,even kommt
          modbus.0
          	2025-02-09 21:31:35.192	debug	Cleaning up request fifo.
          modbus.0
          	2025-02-09 21:31:35.190	debug	Clearing timeout of the current request.
          modbus.0
          	2025-02-09 21:31:35.185	info	Disconnected from slave
          modbus.0
          	2025-02-09 21:31:34.178	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
          modbus.0
          	2025-02-09 21:31:34.173	error	Request timed out.
          modbus.0
          	2025-02-09 21:31:34.171	warn	Error: undefined
          modbus.0
          	2025-02-09 21:31:29.155	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
          modbus.0
          	2025-02-09 21:31:29.153	debug	Initialization of scale factors done!
          modbus.0
          	2025-02-09 21:31:29.148	debug	[DevID_2] Poll start ---------------------
          modbus.0
          	2025-02-09 21:31:29.145	info	Connected to slave
          modbus.0
          	2025-02-09 21:31:29.116	debug	connect to serial /dev/ttyUSB0 with 9600
          modbus.0
          	2025-02-09 21:31:28.545	debug	Add holdingRegisters.40035_Temperatur: {"_id":"holdingRegisters.40035_Temperatur","type":"state","common":{"name":"Temperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
          modbus.0
          	2025-02-09 21:31:28.543	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temperatur","description":"Temperatur","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temperatur"}]
          modbus.0
          	2025-02-09 21:31:28.542	debug	Initialize Objects for inputRegs: []
          modbus.0
          	2025-02-09 21:31:28.539	debug	Initialize Objects for coils: []
          modbus.0
          	2025-02-09 21:31:28.537	debug	Initialize Objects for disInputs: []
          modbus.0
          	2025-02-09 21:31:28.216	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
          modbus.0
          	2025-02-09 21:31:27.245	debug	Plugin sentry Initialize Plugin (enabled=true)
          host.michi
          	2025-02-09 21:31:22.951	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1209
          host.michi
          	2025-02-09 21:31:21.925	info	"system.adapter.modbus.0" enabled
          admin.0
          	2025-02-09 21:31:15.087	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
          admin.0
          	2025-02-09 21:30:59.851	info	==> Connected system.user.admin from ::ffff:192.168.188.158
          wendy2702 Homoran 2 Replies Last reply Reply Quote 0
          • wendy2702
            @mark steht das eine Register jetzt bei Holding?
            Wenn ja stelle es mal bei Eingangs Register ein
              Mark @wendy2702 last edited by
              @wendy2702 said in Modbus EasyCharge Einstellungen:
              kommt genau das selbe.
              Egal ob mit none oder even, egal ob als Eingang oder Holding
              • wendy2702
                @mark Probier mal ein anderes Register. Vielleicht geht das eine gerade nicht
                  und da steht nur unter holding nur der eine Eintrag?
                    Hab schon 40155 probiert. Da müsste eigentlich eine 5 zurückkommen. Geht aber auch nicht
                      Stop!
                      ihr hängt mich ab 😁
                      zuerst kam illegal address
                      in Verbindung mit function code 3.
                      Das ist read holding register
                      also "eigentlich" alles richtig
                      mit even statt none war das weg
                      richtig?
                      M Homoran 2 Replies Last reply Reply Quote 0
                        eben nicht!
                          Stop!
                          ihr hängt mich ab 😁
                          richtig?
                          Ja, richtig.
                          Mit dem egal meinte ich, dass bei even immer das selbe kommt (egal welches Register) und bei none kommt auch das selbe (egal welches Register). Aber even und none produzieren unterschiedliche Fehler
                          • wendy2702
                            wendy2702 @Mark last edited by wendy2702
                            @mark laut deiner Beschreibung ist „none“ richtig.
                            Also damit mal ein Register bei Holding eintragen und log zeigen oder mal a/b tauschen und testen
                              ja das passt!
                              even war laut Registertanelle fettgedruckt = Werkseinstellumg!?
                              Also bleiben wir erst mal dabei.
                              dieses dämliche
                              hatten wir in einem anderen Fall schon mal.
                              Ich kann mich nur nicht erinnern warum, und ob das gelöst wurde
                              • wendy2702
                                wendy2702 @Homoran last edited by
                                @homoran nö, nix Even.
                                Laut seiner Beschreibung—> keine parität
                                  Einstellung: none, Holding 40035 mit Abfrage:
                                  modbus.0
                                  	2025-02-09 21:55:26.201	debug	Cleaning up request fifo.
                                  modbus.0
                                  	2025-02-09 21:55:26.199	debug	Clearing timeout of the current request.
                                  modbus.0
                                  	2025-02-09 21:55:26.193	info	Disconnected from slave
                                  modbus.0
                                  	2025-02-09 21:55:25.193	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                  modbus.0
                                  	2025-02-09 21:55:25.187	error	Request timed out.
                                  modbus.0
                                  	2025-02-09 21:55:25.184	warn	Error: undefined
                                  modbus.0
                                  	2025-02-09 21:55:20.219	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                                  modbus.0
                                  	2025-02-09 21:55:20.217	error	Error response for FCx3: Illegal Data Address
                                  modbus.0
                                  	2025-02-09 21:55:20.169	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
                                  modbus.0
                                  	2025-02-09 21:55:20.166	debug	Initialization of scale factors done!
                                  modbus.0
                                  	2025-02-09 21:55:20.161	debug	[DevID_2] Poll start ---------------------
                                  modbus.0
                                  	2025-02-09 21:55:20.159	info	Connected to slave
                                  modbus.0
                                  	2025-02-09 21:55:20.141	debug	connect to serial /dev/ttyUSB0 with 9600
                                  modbus.0
                                  	2025-02-09 21:55:19.578	debug	Add holdingRegisters.40035_Temp: {"_id":"holdingRegisters.40035_Temp","type":"state","common":{"name":"Temp","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                                  modbus.0
                                  	2025-02-09 21:55:19.576	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temp","description":"Temp","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temp"}]
                                  modbus.0
                                  	2025-02-09 21:55:19.575	debug	Initialize Objects for inputRegs: []
                                  modbus.0
                                  	2025-02-09 21:55:19.572	debug	Initialize Objects for coils: []
                                  modbus.0
                                  	2025-02-09 21:55:19.570	debug	Initialize Objects for disInputs: []
                                  modbus.0
                                  	2025-02-09 21:55:19.249	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
                                  modbus.0
                                  	2025-02-09 21:55:18.308	debug	Plugin sentry Initialize Plugin (enabled=true)
                                  modbus.0
                                  	2025-02-09 21:55:18.241	debug	States connected to redis: 127.0.0.1:9000
                                  modbus.0
                                  	2025-02-09 21:55:18.213	debug	States create User PubSub Client
                                  modbus.0
                                  	2025-02-09 21:55:18.211	debug	States create System PubSub Client
                                  modbus.0
                                  	2025-02-09 21:55:18.195	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                  modbus.0
                                  	2025-02-09 21:55:18.158	debug	Objects connected to redis: 127.0.0.1:9001
                                  modbus.0
                                  	2025-02-09 21:55:18.139	debug	Objects client initialize lua scripts
                                  modbus.0
                                  	2025-02-09 21:55:18.095	debug	Objects create User PubSub Client
                                  modbus.0
                                  	2025-02-09 21:55:18.092	debug	Objects create System PubSub Client
                                  modbus.0
                                  	2025-02-09 21:55:18.086	debug	Objects client ready ... initialize now
                                  modbus.0
                                  	2025-02-09 21:55:18.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  host.michi
                                  	2025-02-09 21:55:14.149	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1477
                                  host.michi
                                  	2025-02-09 21:55:13.101	info	"system.adapter.modbus.0" enabled
                                  admin.0
                                  	2025-02-09 21:55:05.799	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
                                  admin.0
                                  	2025-02-09 21:54:13.438	info	==> Connected system.user.admin from ::ffff:192.168.188.158
                                    Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
                                    @wendy2702 sagte in Modbus EasyCharge Einstellungen:
                                    aber in der Registerbeschreibung ist die Zeile mit even fettgedruckt = Werkseinstellung
                                    und einen Fall mit undefined hatte ich gerade über die Suche gefunden.
                                    Da war der Stick defekt 😞
                                    • wendy2702
                                      @homoran tolle Dokumentation wenn mal none und mal even angegeben ist.
                                      Vielleicht ist der Stick auch gegrillt nachdem er falsch angeschlossen war.
                                        Man könnte noch
                                        • Leitungen A/B tauschen
                                        • Die Anzahl auf einmal gelesene Register begrenzen
                                          • einige Geräte brauchen das
                                          Würde ich ausschließen. Hab gerade einen 2. (selbe Marke) getestet. Gleiches Ergebnis.
                                            @mark ne Kontrollleuchte hat der nicht?
                                            modbus-adapter
                                            5979
